[U-Boot] [PATCH] sunxi: fix SID read on H3
H3 SID controller has some bug, which makes the initial SID value at SUNXI_SID_BASE wrong when boot.
Change the SID retrieve code to call the SID Controller directly on H3, which can get the correct value, and also fix the SID value at SUNXI_SID_BASE, so that it can be used by further operations.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz --- arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 1 + arch/arm/mach-sunxi/cpu_info.c | 44 +++++++++++++++++++++++++++++ 2 files changed, 45 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index 7232f6d927..3c852224e6 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -97,6 +97,7 @@ #if defined(CONFIG_MACH_SUN8I_A83T) || defined(CONFIG_MACH_SUN8I_H3) || \ defined(CONFIG_MACH_SUN50I) /* SID address space starts at 0x01c1400, but e-fuse is at offset 0x200 */ +#define SUNXI_SIDC_BASE 0x01c14000 #define SUNXI_SID_BASE 0x01c14200 #else #define SUNXI_SID_BASE 0x01c23800 diff --git a/arch/arm/mach-sunxi/cpu_info.c b/arch/arm/mach-sunxi/cpu_info.c index 76b6719d99..f1f6fd5ba4 100644 --- a/arch/arm/mach-sunxi/cpu_info.c +++ b/arch/arm/mach-sunxi/cpu_info.c @@ -99,10 +99,54 @@ int print_cpuinfo(void) } #endif
+#ifdef CONFIG_MACH_SUN8I_H3 + +#define SIDC_PRCTL 0x40 +#define SIDC_RDKEY 0x60 + +#define SIDC_OP_LOCK 0xAC + +uint32_t sun8i_efuse_read(uint32_t offset) +{ + uint32_t reg_val; + + reg_val = readl(SUNXI_SIDC_BASE + SIDC_PRCTL); + reg_val &= ~(((0x1ff) << 16) | 0x3); + reg_val |= (offset << 16); + writel(reg_val, SUNXI_SIDC_BASE + SIDC_PRCTL); + + reg_val &= ~(((0xff) << 8) | 0x3); + reg_val |= (SIDC_OP_LOCK << 8) | 0x2; + writel(reg_val, SUNXI_SIDC_BASE + SIDC_PRCTL); + + while (readl(SUNXI_SIDC_BASE + SIDC_PRCTL) & 0x2); + + reg_val &= ~(((0x1ff) << 16) | ((0xff) << 8) | 0x3); + writel(reg_val, SUNXI_SIDC_BASE + SIDC_PRCTL); + + reg_val = readl(SUNXI_SIDC_BASE + SIDC_RDKEY); + return reg_val; +} +#endif + int sunxi_get_sid(unsigned int *sid) { #ifdef CONFIG_AXP221_POWER return axp_get_sid(sid); +#elif defined CONFIG_MACH_SUN8I_H3 + /* + * H3 SID controller has a bug, which makes the initial value of + * SUNXI_SID_BASE at boot wrong. + * Read the value directly from SID controller, in order to get + * the correct value, and also refresh the wrong value at + * SUNXI_SID_BASE. + */ + int i; + + for (i = 0; i< 4; i++) + sid[i] = sun8i_efuse_read(i * 4); + + return 0; #elif defined SUNXI_SID_BASE int i;
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Thanks, Maxime
On Tue, Dec 20, 2016 at 9:12 AM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
Applied to u-boot-sunxi/master
thanks!
- uint32_t reg_val;
- reg_val = readl(SUNXI_SIDC_BASE + SIDC_PRCTL);
- reg_val &= ~(((0x1ff) << 16) | 0x3);
- reg_val |= (offset << 16);
- writel(reg_val, SUNXI_SIDC_BASE + SIDC_PRCTL);
Normally clrsetbits_le32() is used for this kind of code in U-Boot.
- reg_val &= ~(((0xff) << 8) | 0x3);
- reg_val |= (SIDC_OP_LOCK << 8) | 0x2;
- while (readl(SUNXI_SIDC_BASE + SIDC_PRCTL) & 0x2);
- reg_val &= ~(((0x1ff) << 16) | ((0xff) << 8) | 0x3);
Same here.
- reg_val = readl(SUNXI_SIDC_BASE + SIDC_RDKEY);
- return reg_val;
+} +#endif
* SUNXI_SID_BASE.
- int i;
- for (i = 0; i< 4; i++)
Thanks for this workaround. This problem has buggered some people since a while ago. It's good that you took time to investigate and fix it.
Icenowy Zheng
Jagan Teki
Maxime Ripard
Siarhei Siamashka
