[PATCH] ARM: imx: pico-imx8mq: Add support for Technexion Pico-iMX8MQ
Add initial support for Technexion Pico-iMX8MQ SoM on PicoPI carrier board. Currently working is ethernet, serial, eMMC. DT is imported from Linux 5.4.28 ("462afcd6e7ea") .
Signed-off-by: Marek Vasut marek.vasut@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx8mq-pico-pi.dts | 416 ++++ arch/arm/mach-imx/imx8m/Kconfig | 6 + board/technexion/pico-imx8mq/Kconfig | 12 + board/technexion/pico-imx8mq/MAINTAINERS | 6 + board/technexion/pico-imx8mq/Makefile | 12 + board/technexion/pico-imx8mq/README | 52 + board/technexion/pico-imx8mq/lpddr4_timing.h | 14 + .../pico-imx8mq/lpddr4_timing_1gb.c | 1734 +++++++++++++++++ .../pico-imx8mq/lpddr4_timing_2gb.c | 1734 +++++++++++++++++ .../pico-imx8mq/lpddr4_timing_3gb.c | 1734 +++++++++++++++++ .../pico-imx8mq/lpddr4_timing_4gb.c | 1734 +++++++++++++++++ board/technexion/pico-imx8mq/pico-imx8mq.c | 149 ++ board/technexion/pico-imx8mq/spl.c | 241 +++ configs/pico-imx8mq_defconfig | 49 + include/configs/pico-imx8mq.h | 216 ++ 16 files changed, 8111 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mq-pico-pi.dts create mode 100644 board/technexion/pico-imx8mq/Kconfig create mode 100644 board/technexion/pico-imx8mq/MAINTAINERS create mode 100644 board/technexion/pico-imx8mq/Makefile create mode 100644 board/technexion/pico-imx8mq/README create mode 100644 board/technexion/pico-imx8mq/lpddr4_timing.h create mode 100644 board/technexion/pico-imx8mq/lpddr4_timing_1gb.c create mode 100644 board/technexion/pico-imx8mq/lpddr4_timing_2gb.c create mode 100644 board/technexion/pico-imx8mq/lpddr4_timing_3gb.c create mode 100644 board/technexion/pico-imx8mq/lpddr4_timing_4gb.c create mode 100644 board/technexion/pico-imx8mq/pico-imx8mq.c create mode 100644 board/technexion/pico-imx8mq/spl.c create mode 100644 configs/pico-imx8mq_defconfig create mode 100644 include/configs/pico-imx8mq.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9c593b2c98..e317fd321d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -721,8 +721,9 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-evk.dtb \ imx8mm-verdin.dtb \ imx8mn-ddr4-evk.dtb \ + imx8mp-evk.dtb \ imx8mq-evk.dtb \ - imx8mp-evk.dtb + imx8mq-pico-pi.dtb
dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb
diff --git a/arch/arm/dts/imx8mq-pico-pi.dts b/arch/arm/dts/imx8mq-pico-pi.dts new file mode 100644 index 0000000000..57e9ae469b --- /dev/null +++ b/arch/arm/dts/imx8mq-pico-pi.dts @@ -0,0 +1,416 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Wandboard, Org. + * Copyright 2017 NXP + * + * Author: Richard Hu hakahu@gmail.com + */ + +/dts-v1/; + +/* First 128KB is for PSCI ATF. */ +/memreserve/ 0x40000000 0x00020000; + +#include "imx8mq.dtsi" + +/ { + model = "TechNexion PICO-PI-8M"; + compatible = "technexion,pico-pi-imx8m", "fsl,imx8mq"; + + chosen { + stdout-path = &uart1; + }; + + pmic_osc: clock-pmic { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "pmic_osc"; + }; + + reg_usb_otg_vbus: regulator-usb-otg-vbus { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_otg_vbus>; + compatible = "regulator-fixed"; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio3 14 GPIO_ACTIVE_LOW>; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1 &pinctrl_enet_3v3>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; + }; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + pmic: pmic@4b { + reg = <0x4b>; + compatible = "rohm,bd71837"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + clocks = <&pmic_osc>; + clock-names = "osc"; + clock-output-names = "pmic_clk"; + interrupt-parent = <&gpio1>; + interrupts = <3 GPIO_ACTIVE_LOW>; + interrupt-names = "irq"; + + regulators { + buck1: BUCK1 { + regulator-name = "buck1"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-ramp-delay = <1250>; + rohm,dvs-run-voltage = <900000>; + rohm,dvs-idle-voltage = <850000>; + rohm,dvs-suspend-voltage = <800000>; + }; + + buck2: BUCK2 { + regulator-name = "buck2"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-ramp-delay = <1250>; + rohm,dvs-run-voltage = <1000000>; + rohm,dvs-idle-voltage = <900000>; + }; + + buck3: BUCK3 { + regulator-name = "buck3"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + rohm,dvs-run-voltage = <1000000>; + }; + + buck4: BUCK4 { + regulator-name = "buck4"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + rohm,dvs-run-voltage = <1000000>; + }; + + buck5: BUCK5 { + regulator-name = "buck5"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-boot-on; + }; + + buck6: BUCK6 { + regulator-name = "buck6"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + }; + + buck7: BUCK7 { + regulator-name = "buck7"; + regulator-min-microvolt = <1605000>; + regulator-max-microvolt = <1995000>; + regulator-boot-on; + }; + + buck8: BUCK8 { + regulator-name = "buck8"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-boot-on; + }; + + ldo1: LDO1 { + regulator-name = "ldo1"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2: LDO2 { + regulator-name = "ldo2"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3: LDO3 { + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + }; + + ldo4: LDO4 { + regulator-name = "ldo4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + }; + + ldo5: LDO5 { + regulator-name = "ldo5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + }; + + ldo6: LDO6 { + regulator-name = "ldo6"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + }; + + ldo7: LDO7 { + regulator-name = "ldo7"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + }; + }; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&uart1 { /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + bus-width = <4>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&usb3_phy0 { + status = "okay"; +}; + +&usb3_phy1 { + status = "okay"; +}; + +&usb_dwc3_1 { + dr_mode = "host"; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl_enet_3v3: enet3v3grp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO00_GPIO1_IO0 0x19 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MQ_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MQ_IOMUXC_ENET_MDIO_ENET1_MDIO 0x23 + MX8MQ_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MQ_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MQ_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MQ_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MQ_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MQ_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MQ_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MQ_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MQ_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MQ_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MQ_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MQ_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MQ_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x19 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C1_SCL_I2C1_SCL 0x4000007f + MX8MQ_IOMUXC_I2C1_SDA_I2C1_SDA 0x4000007f + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C2_SCL_I2C2_SCL 0x4000007f + MX8MQ_IOMUXC_I2C2_SDA_I2C2_SDA 0x4000007f + >; + }; + + pinctrl_otg_vbus: otgvbusgrp { + fsl,pins = < + MX8MQ_IOMUXC_NAND_DQS_GPIO3_IO14 0x19 /* USB OTG VBUS Enable */ + >; + }; + + pinctrl_pmic: pmicirq { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x41 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX8MQ_IOMUXC_UART1_RXD_UART1_DCE_RX 0x49 + MX8MQ_IOMUXC_UART1_TXD_UART1_DCE_TX 0x49 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MQ_IOMUXC_UART2_RXD_UART2_DCE_RX 0x49 + MX8MQ_IOMUXC_UART2_TXD_UART2_DCE_TX 0x49 + MX8MQ_IOMUXC_UART4_RXD_UART2_DCE_CTS_B 0x49 + MX8MQ_IOMUXC_UART4_TXD_UART2_DCE_RTS_B 0x49 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x83 + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc3 + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc3 + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc3 + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc3 + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc3 + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc3 + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc3 + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc3 + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc3 + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x83 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x85 + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc5 + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc5 + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc5 + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc5 + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc5 + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc5 + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc5 + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc5 + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc5 + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x85 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x87 + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc7 + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc7 + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc7 + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc7 + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc7 + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc7 + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc7 + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc7 + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc7 + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x87 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grpgpio { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x41 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x83 + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc3 + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc3 + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc3 + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc3 + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc3 + MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x85 + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc5 + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc5 + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc5 + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc5 + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc5 + MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x87 + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc7 + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc7 + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc7 + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc7 + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc7 + MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 58f1758ab6..8f30c269f9 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -50,6 +50,11 @@ config TARGET_IMX8MP_EVK select SUPPORT_SPL select IMX8M_LPDDR4
+config TARGET_PICO_IMX8MQ + bool "Support Technexion Pico iMX8MQ" + select IMX8MQ + select IMX8M_LPDDR4 + config TARGET_VERDIN_IMX8MM bool "Support Toradex Verdin iMX8M Mini module" select IMX8MM @@ -62,6 +67,7 @@ source "board/freescale/imx8mq_evk/Kconfig" source "board/freescale/imx8mm_evk/Kconfig" source "board/freescale/imx8mn_evk/Kconfig" source "board/freescale/imx8mp_evk/Kconfig" +source "board/technexion/pico-imx8mq/Kconfig" source "board/toradex/verdin-imx8mm/Kconfig"
endif diff --git a/board/technexion/pico-imx8mq/Kconfig b/board/technexion/pico-imx8mq/Kconfig new file mode 100644 index 0000000000..031fc1d563 --- /dev/null +++ b/board/technexion/pico-imx8mq/Kconfig @@ -0,0 +1,12 @@ +if TARGET_PICO_IMX8MQ + +config SYS_BOARD + default "pico-imx8mq" + +config SYS_VENDOR + default "technexion" + +config SYS_CONFIG_NAME + default "pico-imx8mq" + +endif diff --git a/board/technexion/pico-imx8mq/MAINTAINERS b/board/technexion/pico-imx8mq/MAINTAINERS new file mode 100644 index 0000000000..92a3bae402 --- /dev/null +++ b/board/technexion/pico-imx8mq/MAINTAINERS @@ -0,0 +1,6 @@ +i.MX8MQ EVK BOARD +M: Marek Vasut marek.vasut@gmail.com +S: Maintained +F: board/technexion/pico-imx8mq/ +F: include/configs/pico-imx8mq.h +F: configs/pico-imx8mq_defconfig diff --git a/board/technexion/pico-imx8mq/Makefile b/board/technexion/pico-imx8mq/Makefile new file mode 100644 index 0000000000..7cfe1e02ef --- /dev/null +++ b/board/technexion/pico-imx8mq/Makefile @@ -0,0 +1,12 @@ +# +# Copyright 2017 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += pico-imx8mq.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_1gb.o lpddr4_timing_2gb.o lpddr4_timing_3gb.o lpddr4_timing_4gb.o +endif diff --git a/board/technexion/pico-imx8mq/README b/board/technexion/pico-imx8mq/README new file mode 100644 index 0000000000..99fa332872 --- /dev/null +++ b/board/technexion/pico-imx8mq/README @@ -0,0 +1,52 @@ +U-Boot for the Technexion Pico i.MX8MQ + +Quick Start +=========== +- Build the TFA binary +- Get DDR and HDMI firmware +- Build U-Boot +- Boot + +Get and Build the TFA blob +========================== +Note: srctree is U-Boot source directory +Get ATF from: https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git +branch: master +$ CROSS_COMPILE=aarch64-linux-gnu- make PLAT=imx8mq bl31 +$ cp build/imx8mq/release/bl31.bin $(builddir) + +Get the DDR and HDMI firmware +============================= +$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-7.9.bin +$ chmod +x firmware-imx-7.9.bin +$ ./firmware-imx-7.9.bin +# Or use this to avoid running random scripts from the internet, +# but note that you must agree to the license the script displays: +# $ dd if=firmware-imx-7.9.bin of=firmware-imx-7.9.tar.bz2 bs=38868 skip=1 +# $ tar -xf firmware-imx-7.9.tar.bz2 +$ cp firmware-imx-7.9/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(builddir) +$ cp firmware-imx-7.9/firmware/ddr/synopsys/lpddr4*.bin $(builddir) + +Build U-Boot +============ +$ export CROSS_COMPILE=aarch64-poky-linux- +$ make pico-imx8mq_defconfig +$ make flash.bin + +Burn the flash.bin to MicroSD card offset 33KB +$ dd if=flash.bin of=/dev/mmcblkX bs=1024 seek=33 +Or into eMMC from a running system +$ dhcp flash.bin && mmc write $loadaddr 0x42 0x800 + +Boot +==== +"o" denotes a pin +"[]" denotes two pins bridged by a jumper + +eMMC boot: +J1 o[] []o J2 + []o o[] + +USB upload via USB-C connector: +J1 ooo ooo J2 + o[] []o diff --git a/board/technexion/pico-imx8mq/lpddr4_timing.h b/board/technexion/pico-imx8mq/lpddr4_timing.h new file mode 100644 index 0000000000..89b0b927bc --- /dev/null +++ b/board/technexion/pico-imx8mq/lpddr4_timing.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 Marek Vasut marek.vasut@gmail.com + */ + +#ifndef __LPDDR4_TIMING_H__ +#define __LPDDR4_TIMING_H__ + +extern struct dram_timing_info dram_timing_1gb; +extern struct dram_timing_info dram_timing_2gb; +extern struct dram_timing_info dram_timing_3gb; +extern struct dram_timing_info dram_timing_4gb; + +#endif /* __LPDDR4_TIMING_H__ */ diff --git a/board/technexion/pico-imx8mq/lpddr4_timing_1gb.c b/board/technexion/pico-imx8mq/lpddr4_timing_1gb.c new file mode 100644 index 0000000000..bcb852668c --- /dev/null +++ b/board/technexion/pico-imx8mq/lpddr4_timing_1gb.c @@ -0,0 +1,1734 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa1080020}, + {0x3d400028, 0x0}, + {0x3d400020, 0x203}, + {0x3d400024, 0x3e800}, + {0x3d400064, 0x610090}, + {0x3d4000d0, 0xc003061c}, + {0x3d4000d4, 0x9e0000}, + {0x3d4000dc, 0xd4002d}, + {0x3d4000e0, 0x310008}, + {0x3d4000e8, 0x66004a}, + {0x3d4000ec, 0x16004a}, + {0x3d400100, 0x1a201b22}, + {0x3d400104, 0x60633}, + {0x3d40010c, 0xc0c000}, + {0x3d400110, 0xf04080f}, + {0x3d400114, 0x2040c0c}, + {0x3d400118, 0x1010007}, + {0x3d40011c, 0x401}, + {0x3d400130, 0x20600}, + {0x3d400134, 0xc100002}, + {0x3d400138, 0x96}, + {0x3d400144, 0xa00050}, + {0x3d400180, 0xc3200018}, + {0x3d400184, 0x28061a8}, + {0x3d400188, 0x0}, + {0x3d400190, 0x497820a}, + {0x3d400194, 0x80303}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001b4, 0x170a}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x1}, + {0x3d4000f4, 0x639}, + {0x3d400108, 0x70e1617}, + {0x3d400200, 0x1f}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0xf070707}, + {0x3d402020, 0x1}, + {0x3d402024, 0xd0c0}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0x14001f}, + {0x3d4020dc, 0x940009}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004a}, + {0x3d4020ec, 0x16004a}, + {0x3d402100, 0xb070508}, + {0x3d402104, 0x3040b}, + {0x3d402108, 0x305090c}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x4040204}, + {0x3d402114, 0x2030303}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x20}, + {0x3d402144, 0x220011}, + {0x3d402180, 0xc0a70006}, + {0x3d402190, 0x3858202}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x502}, + {0x3d400244, 0x0}, + {0x3d400250, 0x29001505}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x5900575b}, + {0x3d400264, 0x90000096}, + {0x3d40026c, 0x1000012c}, + {0x3d400300, 0x16}, + {0x3d400304, 0x0}, + {0x3d40030c, 0x0}, + {0x3d400320, 0x1}, + {0x3d40036c, 0x11}, + {0x3d400400, 0x111}, + {0x3d400404, 0x10f3}, + {0x3d400408, 0x72ff}, + {0x3d400490, 0x1}, + {0x3d400494, 0xe00}, + {0x3d400498, 0x62ffff}, + {0x3d40049c, 0xe00}, + {0x3d4004a0, 0xffff}, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x2}, + {0x110a3, 0x3}, + {0x110a4, 0x4}, + {0x110a5, 0x5}, + {0x110a6, 0x6}, + {0x110a7, 0x7}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x2}, + {0x120a3, 0x3}, + {0x120a4, 0x4}, + {0x120a5, 0x5}, + {0x120a6, 0x6}, + {0x120a7, 0x7}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x20110, 0x2}, + {0x20111, 0x3}, + {0x20112, 0x4}, + {0x20113, 0x5}, + {0x20114, 0x0}, + {0x20115, 0x1}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x1}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x3}, + {0x120056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x320}, + {0x120008, 0xa7}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x200f0, 0x0}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5555}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x200c7, 0x80}, + {0x1200c7, 0x80}, + {0x200ca, 0x106}, + {0x1200ca, 0x106}, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x1}, + {0x54003, 0x29c}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x994}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x994}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x9400}, + {0x54033, 0x3109}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0x9400}, + {0x54039, 0x3109}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x64}, + {0x2000c, 0xc8}, + {0x2000d, 0x7d0}, + {0x2000e, 0x2c}, + {0x12000b, 0x14}, + {0x12000c, 0x29}, + {0x12000d, 0x1a1}, + {0x12000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 667mts 1D */ + .drate = 667, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_1gb = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 667, }, +}; + diff --git a/board/technexion/pico-imx8mq/lpddr4_timing_2gb.c b/board/technexion/pico-imx8mq/lpddr4_timing_2gb.c new file mode 100644 index 0000000000..9a8a323d63 --- /dev/null +++ b/board/technexion/pico-imx8mq/lpddr4_timing_2gb.c @@ -0,0 +1,1734 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa1080020}, + {0x3d400028, 0x0}, + {0x3d400020, 0x203}, + {0x3d400024, 0x3e800}, + {0x3d400064, 0x6100e0}, + {0x3d4000d0, 0xc003061c}, + {0x3d4000d4, 0x9e0000}, + {0x3d4000dc, 0xd4002d}, + {0x3d4000e0, 0x310008}, + {0x3d4000e8, 0x66004a}, + {0x3d4000ec, 0x16004a}, + {0x3d400100, 0x1a201b22}, + {0x3d400104, 0x60633}, + {0x3d40010c, 0xc0c000}, + {0x3d400110, 0xf04080f}, + {0x3d400114, 0x2040c0c}, + {0x3d400118, 0x1010007}, + {0x3d40011c, 0x401}, + {0x3d400130, 0x20600}, + {0x3d400134, 0xc100002}, + {0x3d400138, 0xe6}, + {0x3d400144, 0xa00050}, + {0x3d400180, 0xc3200018}, + {0x3d400184, 0x28061a8}, + {0x3d400188, 0x0}, + {0x3d400190, 0x497820a}, + {0x3d400194, 0x80303}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001b4, 0x170a}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x1}, + {0x3d4000f4, 0x639}, + {0x3d400108, 0x70e1617}, + {0x3d400200, 0x1f}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0x7070707}, + {0x3d402020, 0x1}, + {0x3d402024, 0xd0c0}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0x14002f}, + {0x3d4020dc, 0x940009}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004a}, + {0x3d4020ec, 0x16004a}, + {0x3d402100, 0xb070508}, + {0x3d402104, 0x3040b}, + {0x3d402108, 0x305090c}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x4040204}, + {0x3d402114, 0x2030303}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x31}, + {0x3d402144, 0x220011}, + {0x3d402180, 0xc0a70006}, + {0x3d402190, 0x3858202}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x502}, + {0x3d400244, 0x0}, + {0x3d400250, 0x29001505}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x5900575b}, + {0x3d400264, 0x90000096}, + {0x3d40026c, 0x1000012c}, + {0x3d400300, 0x16}, + {0x3d400304, 0x0}, + {0x3d40030c, 0x0}, + {0x3d400320, 0x1}, + {0x3d40036c, 0x11}, + {0x3d400400, 0x111}, + {0x3d400404, 0x10f3}, + {0x3d400408, 0x72ff}, + {0x3d400490, 0x1}, + {0x3d400494, 0xe00}, + {0x3d400498, 0x62ffff}, + {0x3d40049c, 0xe00}, + {0x3d4004a0, 0xffff}, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x2}, + {0x110a3, 0x3}, + {0x110a4, 0x4}, + {0x110a5, 0x5}, + {0x110a6, 0x6}, + {0x110a7, 0x7}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x2}, + {0x120a3, 0x3}, + {0x120a4, 0x4}, + {0x120a5, 0x5}, + {0x120a6, 0x6}, + {0x120a7, 0x7}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x20110, 0x2}, + {0x20111, 0x3}, + {0x20112, 0x4}, + {0x20113, 0x5}, + {0x20114, 0x0}, + {0x20115, 0x1}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x1}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x3}, + {0x120056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x320}, + {0x120008, 0xa7}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x200f0, 0x0}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5555}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x200c7, 0x80}, + {0x1200c7, 0x80}, + {0x200ca, 0x106}, + {0x1200ca, 0x106}, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x1}, + {0x54003, 0x29c}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x110}, + {0x54019, 0x994}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x994}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0x9400}, + {0x54033, 0x3109}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0x9400}, + {0x54039, 0x3109}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x110}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x1}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x64}, + {0x2000c, 0xc8}, + {0x2000d, 0x7d0}, + {0x2000e, 0x2c}, + {0x12000b, 0x14}, + {0x12000c, 0x29}, + {0x12000d, 0x1a1}, + {0x12000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 667mts 1D */ + .drate = 667, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_2gb = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 667, }, +}; + diff --git a/board/technexion/pico-imx8mq/lpddr4_timing_3gb.c b/board/technexion/pico-imx8mq/lpddr4_timing_3gb.c new file mode 100644 index 0000000000..0f74ce581c --- /dev/null +++ b/board/technexion/pico-imx8mq/lpddr4_timing_3gb.c @@ -0,0 +1,1734 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa3080020}, + {0x3d400028, 0x0}, + {0x3d400020, 0x203}, + {0x3d400024, 0x3e800}, + {0x3d400064, 0x6100e0}, + {0x3d4000d0, 0xc003061c}, + {0x3d4000d4, 0x9e0000}, + {0x3d4000dc, 0xd4002d}, + {0x3d4000e0, 0x310008}, + {0x3d4000e8, 0x66004a}, + {0x3d4000ec, 0x16004a}, + {0x3d400100, 0x1a201b22}, + {0x3d400104, 0x60633}, + {0x3d40010c, 0xc0c000}, + {0x3d400110, 0xf04080f}, + {0x3d400114, 0x2040c0c}, + {0x3d400118, 0x1010007}, + {0x3d40011c, 0x401}, + {0x3d400130, 0x20600}, + {0x3d400134, 0xc100002}, + {0x3d400138, 0xe6}, + {0x3d400144, 0xa00050}, + {0x3d400180, 0xc3200018}, + {0x3d400184, 0x28061a8}, + {0x3d400188, 0x0}, + {0x3d400190, 0x497820a}, + {0x3d400194, 0x80303}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001b4, 0x170a}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x1}, + {0x3d4000f4, 0x639}, + {0x3d400108, 0x70e1617}, + {0x3d400200, 0x15}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0x48080707}, + {0x3d402020, 0x1}, + {0x3d402024, 0xd0c0}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0x14002f}, + {0x3d4020dc, 0x940009}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004a}, + {0x3d4020ec, 0x16004a}, + {0x3d402100, 0xb070508}, + {0x3d402104, 0x3040b}, + {0x3d402108, 0x305090c}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x4040204}, + {0x3d402114, 0x2030303}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x31}, + {0x3d402144, 0x220011}, + {0x3d402180, 0xc0a70006}, + {0x3d402190, 0x3858202}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x502}, + {0x3d400244, 0x0}, + {0x3d400250, 0x29001505}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x5900575b}, + {0x3d400264, 0x90000096}, + {0x3d40026c, 0x1000012c}, + {0x3d400300, 0x16}, + {0x3d400304, 0x0}, + {0x3d40030c, 0x0}, + {0x3d400320, 0x1}, + {0x3d40036c, 0x11}, + {0x3d400400, 0x111}, + {0x3d400404, 0x10f3}, + {0x3d400408, 0x72ff}, + {0x3d400490, 0x1}, + {0x3d400494, 0xe00}, + {0x3d400498, 0x62ffff}, + {0x3d40049c, 0xe00}, + {0x3d4004a0, 0xffff}, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x2}, + {0x110a3, 0x3}, + {0x110a4, 0x4}, + {0x110a5, 0x5}, + {0x110a6, 0x6}, + {0x110a7, 0x7}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x2}, + {0x120a3, 0x3}, + {0x120a4, 0x4}, + {0x120a5, 0x5}, + {0x120a6, 0x6}, + {0x120a7, 0x7}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x20110, 0x2}, + {0x20111, 0x3}, + {0x20112, 0x4}, + {0x20113, 0x5}, + {0x20114, 0x0}, + {0x20115, 0x1}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x1}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x3}, + {0x120056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x320}, + {0x120008, 0xa7}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x200f0, 0x0}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5555}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x200c7, 0x80}, + {0x1200c7, 0x80}, + {0x200ca, 0x106}, + {0x1200ca, 0x106}, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x1}, + {0x54003, 0x29c}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x994}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x994}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0x9400}, + {0x54033, 0x3109}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0x9400}, + {0x54039, 0x3109}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x310}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x64}, + {0x2000c, 0xc8}, + {0x2000d, 0x7d0}, + {0x2000e, 0x2c}, + {0x12000b, 0x14}, + {0x12000c, 0x29}, + {0x12000d, 0x1a1}, + {0x12000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 667mts 1D */ + .drate = 667, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_3gb = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 667, }, +}; + diff --git a/board/technexion/pico-imx8mq/lpddr4_timing_4gb.c b/board/technexion/pico-imx8mq/lpddr4_timing_4gb.c new file mode 100644 index 0000000000..b1d1c5223e --- /dev/null +++ b/board/technexion/pico-imx8mq/lpddr4_timing_4gb.c @@ -0,0 +1,1734 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * + * Generated code from MX8M_DDR_tool + * Align with uboot-imx_v2018.03_4.14.78_1.0.0_ga + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + {0x3d400304, 0x1}, + {0x3d400030, 0x1}, + {0x3d400000, 0xa3080020}, + {0x3d400028, 0x0}, + {0x3d400020, 0x203}, + {0x3d400024, 0x3e800}, + {0x3d400064, 0x6100e0}, + {0x3d4000d0, 0xc003061c}, + {0x3d4000d4, 0x9e0000}, + {0x3d4000dc, 0xd4002d}, + {0x3d4000e0, 0x310008}, + {0x3d4000e8, 0x66004a}, + {0x3d4000ec, 0x16004a}, + {0x3d400100, 0x1a201b22}, + {0x3d400104, 0x60633}, + {0x3d40010c, 0xc0c000}, + {0x3d400110, 0xf04080f}, + {0x3d400114, 0x2040c0c}, + {0x3d400118, 0x1010007}, + {0x3d40011c, 0x401}, + {0x3d400130, 0x20600}, + {0x3d400134, 0xc100002}, + {0x3d400138, 0xe6}, + {0x3d400144, 0xa00050}, + {0x3d400180, 0xc3200018}, + {0x3d400184, 0x28061a8}, + {0x3d400188, 0x0}, + {0x3d400190, 0x497820a}, + {0x3d400194, 0x80303}, + {0x3d4001a0, 0xe0400018}, + {0x3d4001a4, 0xdf00e4}, + {0x3d4001a8, 0x80000000}, + {0x3d4001b0, 0x11}, + {0x3d4001b4, 0x170a}, + {0x3d4001c0, 0x1}, + {0x3d4001c4, 0x1}, + {0x3d4000f4, 0x639}, + {0x3d400108, 0x70e1617}, + {0x3d400200, 0x17}, + {0x3d40020c, 0x0}, + {0x3d400210, 0x1f1f}, + {0x3d400204, 0x80808}, + {0x3d400214, 0x7070707}, + {0x3d400218, 0x7070707}, + {0x3d402020, 0x1}, + {0x3d402024, 0xd0c0}, + {0x3d402050, 0x20d040}, + {0x3d402064, 0x14002f}, + {0x3d4020dc, 0x940009}, + {0x3d4020e0, 0x310000}, + {0x3d4020e8, 0x66004a}, + {0x3d4020ec, 0x16004a}, + {0x3d402100, 0xb070508}, + {0x3d402104, 0x3040b}, + {0x3d402108, 0x305090c}, + {0x3d40210c, 0x505000}, + {0x3d402110, 0x4040204}, + {0x3d402114, 0x2030303}, + {0x3d402118, 0x1010004}, + {0x3d40211c, 0x301}, + {0x3d402130, 0x20300}, + {0x3d402134, 0xa100002}, + {0x3d402138, 0x31}, + {0x3d402144, 0x220011}, + {0x3d402180, 0xc0a70006}, + {0x3d402190, 0x3858202}, + {0x3d402194, 0x80303}, + {0x3d4021b4, 0x502}, + {0x3d400244, 0x0}, + {0x3d400250, 0x29001505}, + {0x3d400254, 0x2c}, + {0x3d40025c, 0x5900575b}, + {0x3d400264, 0x90000096}, + {0x3d40026c, 0x1000012c}, + {0x3d400300, 0x16}, + {0x3d400304, 0x0}, + {0x3d40030c, 0x0}, + {0x3d400320, 0x1}, + {0x3d40036c, 0x11}, + {0x3d400400, 0x111}, + {0x3d400404, 0x10f3}, + {0x3d400408, 0x72ff}, + {0x3d400490, 0x1}, + {0x3d400494, 0xe00}, + {0x3d400498, 0x62ffff}, + {0x3d40049c, 0xe00}, + {0x3d4004a0, 0xffff}, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + {0x100a0, 0x0}, + {0x100a1, 0x1}, + {0x100a2, 0x2}, + {0x100a3, 0x3}, + {0x100a4, 0x4}, + {0x100a5, 0x5}, + {0x100a6, 0x6}, + {0x100a7, 0x7}, + {0x110a0, 0x0}, + {0x110a1, 0x1}, + {0x110a2, 0x2}, + {0x110a3, 0x3}, + {0x110a4, 0x4}, + {0x110a5, 0x5}, + {0x110a6, 0x6}, + {0x110a7, 0x7}, + {0x120a0, 0x0}, + {0x120a1, 0x1}, + {0x120a2, 0x2}, + {0x120a3, 0x3}, + {0x120a4, 0x4}, + {0x120a5, 0x5}, + {0x120a6, 0x6}, + {0x120a7, 0x7}, + {0x130a0, 0x0}, + {0x130a1, 0x1}, + {0x130a2, 0x2}, + {0x130a3, 0x3}, + {0x130a4, 0x4}, + {0x130a5, 0x5}, + {0x130a6, 0x6}, + {0x130a7, 0x7}, + {0x20110, 0x2}, + {0x20111, 0x3}, + {0x20112, 0x4}, + {0x20113, 0x5}, + {0x20114, 0x0}, + {0x20115, 0x1}, + {0x1005f, 0x1ff}, + {0x1015f, 0x1ff}, + {0x1105f, 0x1ff}, + {0x1115f, 0x1ff}, + {0x1205f, 0x1ff}, + {0x1215f, 0x1ff}, + {0x1305f, 0x1ff}, + {0x1315f, 0x1ff}, + {0x11005f, 0x1ff}, + {0x11015f, 0x1ff}, + {0x11105f, 0x1ff}, + {0x11115f, 0x1ff}, + {0x11205f, 0x1ff}, + {0x11215f, 0x1ff}, + {0x11305f, 0x1ff}, + {0x11315f, 0x1ff}, + {0x55, 0x1ff}, + {0x1055, 0x1ff}, + {0x2055, 0x1ff}, + {0x3055, 0x1ff}, + {0x4055, 0x1ff}, + {0x5055, 0x1ff}, + {0x6055, 0x1ff}, + {0x7055, 0x1ff}, + {0x8055, 0x1ff}, + {0x9055, 0x1ff}, + {0x200c5, 0x19}, + {0x1200c5, 0x7}, + {0x2002e, 0x2}, + {0x12002e, 0x1}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x20024, 0x1ab}, + {0x2003a, 0x0}, + {0x120024, 0x1ab}, + {0x2003a, 0x0}, + {0x20056, 0x3}, + {0x120056, 0xa}, + {0x1004d, 0xe00}, + {0x1014d, 0xe00}, + {0x1104d, 0xe00}, + {0x1114d, 0xe00}, + {0x1204d, 0xe00}, + {0x1214d, 0xe00}, + {0x1304d, 0xe00}, + {0x1314d, 0xe00}, + {0x11004d, 0xe00}, + {0x11014d, 0xe00}, + {0x11104d, 0xe00}, + {0x11114d, 0xe00}, + {0x11204d, 0xe00}, + {0x11214d, 0xe00}, + {0x11304d, 0xe00}, + {0x11314d, 0xe00}, + {0x10049, 0xeba}, + {0x10149, 0xeba}, + {0x11049, 0xeba}, + {0x11149, 0xeba}, + {0x12049, 0xeba}, + {0x12149, 0xeba}, + {0x13049, 0xeba}, + {0x13149, 0xeba}, + {0x110049, 0xeba}, + {0x110149, 0xeba}, + {0x111049, 0xeba}, + {0x111149, 0xeba}, + {0x112049, 0xeba}, + {0x112149, 0xeba}, + {0x113049, 0xeba}, + {0x113149, 0xeba}, + {0x43, 0x63}, + {0x1043, 0x63}, + {0x2043, 0x63}, + {0x3043, 0x63}, + {0x4043, 0x63}, + {0x5043, 0x63}, + {0x6043, 0x63}, + {0x7043, 0x63}, + {0x8043, 0x63}, + {0x9043, 0x63}, + {0x20018, 0x3}, + {0x20075, 0x4}, + {0x20050, 0x0}, + {0x20008, 0x320}, + {0x120008, 0xa7}, + {0x20088, 0x9}, + {0x200b2, 0xdc}, + {0x10043, 0x5a1}, + {0x10143, 0x5a1}, + {0x11043, 0x5a1}, + {0x11143, 0x5a1}, + {0x12043, 0x5a1}, + {0x12143, 0x5a1}, + {0x13043, 0x5a1}, + {0x13143, 0x5a1}, + {0x1200b2, 0xdc}, + {0x110043, 0x5a1}, + {0x110143, 0x5a1}, + {0x111043, 0x5a1}, + {0x111143, 0x5a1}, + {0x112043, 0x5a1}, + {0x112143, 0x5a1}, + {0x113043, 0x5a1}, + {0x113143, 0x5a1}, + {0x200fa, 0x1}, + {0x1200fa, 0x1}, + {0x20019, 0x1}, + {0x120019, 0x1}, + {0x200f0, 0x0}, + {0x200f1, 0x0}, + {0x200f2, 0x4444}, + {0x200f3, 0x8888}, + {0x200f4, 0x5555}, + {0x200f5, 0x0}, + {0x200f6, 0x0}, + {0x200f7, 0xf000}, + {0x20025, 0x0}, + {0x2002d, 0x0}, + {0x12002d, 0x0}, + {0x200c7, 0x80}, + {0x1200c7, 0x80}, + {0x200ca, 0x106}, + {0x1200ca, 0x106}, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x131f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + {0xd0000, 0x0}, + {0x54002, 0x1}, + {0x54003, 0x29c}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x121f}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400d, 0x100}, + {0x54012, 0x310}, + {0x54019, 0x994}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x994}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0x9400}, + {0x54033, 0x3109}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0x9400}, + {0x54039, 0x3109}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + {0xd0000, 0x1}, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + {0xd0000, 0x0}, + {0x54003, 0xc80}, + {0x54004, 0x2}, + {0x54005, 0x2228}, + {0x54006, 0x11}, + {0x54008, 0x61}, + {0x54009, 0xc8}, + {0x5400b, 0x2}, + {0x5400f, 0x100}, + {0x54010, 0x1f7f}, + {0x54012, 0x310}, + {0x54019, 0x2dd4}, + {0x5401a, 0x31}, + {0x5401b, 0x4a66}, + {0x5401c, 0x4a08}, + {0x5401e, 0x16}, + {0x5401f, 0x2dd4}, + {0x54020, 0x31}, + {0x54021, 0x4a66}, + {0x54022, 0x4a08}, + {0x54024, 0x16}, + {0x5402b, 0x1000}, + {0x5402c, 0x3}, + {0x54032, 0xd400}, + {0x54033, 0x312d}, + {0x54034, 0x6600}, + {0x54035, 0x84a}, + {0x54036, 0x4a}, + {0x54037, 0x1600}, + {0x54038, 0xd400}, + {0x54039, 0x312d}, + {0x5403a, 0x6600}, + {0x5403b, 0x84a}, + {0x5403c, 0x4a}, + {0x5403d, 0x1600}, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + {0xd0000, 0x0}, + {0x90000, 0x10}, + {0x90001, 0x400}, + {0x90002, 0x10e}, + {0x90003, 0x0}, + {0x90004, 0x0}, + {0x90005, 0x8}, + {0x90029, 0xb}, + {0x9002a, 0x480}, + {0x9002b, 0x109}, + {0x9002c, 0x8}, + {0x9002d, 0x448}, + {0x9002e, 0x139}, + {0x9002f, 0x8}, + {0x90030, 0x478}, + {0x90031, 0x109}, + {0x90032, 0x0}, + {0x90033, 0xe8}, + {0x90034, 0x109}, + {0x90035, 0x2}, + {0x90036, 0x10}, + {0x90037, 0x139}, + {0x90038, 0xf}, + {0x90039, 0x7c0}, + {0x9003a, 0x139}, + {0x9003b, 0x44}, + {0x9003c, 0x630}, + {0x9003d, 0x159}, + {0x9003e, 0x14f}, + {0x9003f, 0x630}, + {0x90040, 0x159}, + {0x90041, 0x47}, + {0x90042, 0x630}, + {0x90043, 0x149}, + {0x90044, 0x4f}, + {0x90045, 0x630}, + {0x90046, 0x179}, + {0x90047, 0x8}, + {0x90048, 0xe0}, + {0x90049, 0x109}, + {0x9004a, 0x0}, + {0x9004b, 0x7c8}, + {0x9004c, 0x109}, + {0x9004d, 0x0}, + {0x9004e, 0x1}, + {0x9004f, 0x8}, + {0x90050, 0x0}, + {0x90051, 0x45a}, + {0x90052, 0x9}, + {0x90053, 0x0}, + {0x90054, 0x448}, + {0x90055, 0x109}, + {0x90056, 0x40}, + {0x90057, 0x630}, + {0x90058, 0x179}, + {0x90059, 0x1}, + {0x9005a, 0x618}, + {0x9005b, 0x109}, + {0x9005c, 0x40c0}, + {0x9005d, 0x630}, + {0x9005e, 0x149}, + {0x9005f, 0x8}, + {0x90060, 0x4}, + {0x90061, 0x48}, + {0x90062, 0x4040}, + {0x90063, 0x630}, + {0x90064, 0x149}, + {0x90065, 0x0}, + {0x90066, 0x4}, + {0x90067, 0x48}, + {0x90068, 0x40}, + {0x90069, 0x630}, + {0x9006a, 0x149}, + {0x9006b, 0x10}, + {0x9006c, 0x4}, + {0x9006d, 0x18}, + {0x9006e, 0x0}, + {0x9006f, 0x4}, + {0x90070, 0x78}, + {0x90071, 0x549}, + {0x90072, 0x630}, + {0x90073, 0x159}, + {0x90074, 0xd49}, + {0x90075, 0x630}, + {0x90076, 0x159}, + {0x90077, 0x94a}, + {0x90078, 0x630}, + {0x90079, 0x159}, + {0x9007a, 0x441}, + {0x9007b, 0x630}, + {0x9007c, 0x149}, + {0x9007d, 0x42}, + {0x9007e, 0x630}, + {0x9007f, 0x149}, + {0x90080, 0x1}, + {0x90081, 0x630}, + {0x90082, 0x149}, + {0x90083, 0x0}, + {0x90084, 0xe0}, + {0x90085, 0x109}, + {0x90086, 0xa}, + {0x90087, 0x10}, + {0x90088, 0x109}, + {0x90089, 0x9}, + {0x9008a, 0x3c0}, + {0x9008b, 0x149}, + {0x9008c, 0x9}, + {0x9008d, 0x3c0}, + {0x9008e, 0x159}, + {0x9008f, 0x18}, + {0x90090, 0x10}, + {0x90091, 0x109}, + {0x90092, 0x0}, + {0x90093, 0x3c0}, + {0x90094, 0x109}, + {0x90095, 0x18}, + {0x90096, 0x4}, + {0x90097, 0x48}, + {0x90098, 0x18}, + {0x90099, 0x4}, + {0x9009a, 0x58}, + {0x9009b, 0xa}, + {0x9009c, 0x10}, + {0x9009d, 0x109}, + {0x9009e, 0x2}, + {0x9009f, 0x10}, + {0x900a0, 0x109}, + {0x900a1, 0x5}, + {0x900a2, 0x7c0}, + {0x900a3, 0x109}, + {0x900a4, 0x10}, + {0x900a5, 0x10}, + {0x900a6, 0x109}, + {0x40000, 0x811}, + {0x40020, 0x880}, + {0x40040, 0x0}, + {0x40060, 0x0}, + {0x40001, 0x4008}, + {0x40021, 0x83}, + {0x40041, 0x4f}, + {0x40061, 0x0}, + {0x40002, 0x4040}, + {0x40022, 0x83}, + {0x40042, 0x51}, + {0x40062, 0x0}, + {0x40003, 0x811}, + {0x40023, 0x880}, + {0x40043, 0x0}, + {0x40063, 0x0}, + {0x40004, 0x720}, + {0x40024, 0xf}, + {0x40044, 0x1740}, + {0x40064, 0x0}, + {0x40005, 0x16}, + {0x40025, 0x83}, + {0x40045, 0x4b}, + {0x40065, 0x0}, + {0x40006, 0x716}, + {0x40026, 0xf}, + {0x40046, 0x2001}, + {0x40066, 0x0}, + {0x40007, 0x716}, + {0x40027, 0xf}, + {0x40047, 0x2800}, + {0x40067, 0x0}, + {0x40008, 0x716}, + {0x40028, 0xf}, + {0x40048, 0xf00}, + {0x40068, 0x0}, + {0x40009, 0x720}, + {0x40029, 0xf}, + {0x40049, 0x1400}, + {0x40069, 0x0}, + {0x4000a, 0xe08}, + {0x4002a, 0xc15}, + {0x4004a, 0x0}, + {0x4006a, 0x0}, + {0x4000b, 0x623}, + {0x4002b, 0x15}, + {0x4004b, 0x0}, + {0x4006b, 0x0}, + {0x4000c, 0x4028}, + {0x4002c, 0x80}, + {0x4004c, 0x0}, + {0x4006c, 0x0}, + {0x4000d, 0xe08}, + {0x4002d, 0xc1a}, + {0x4004d, 0x0}, + {0x4006d, 0x0}, + {0x4000e, 0x623}, + {0x4002e, 0x1a}, + {0x4004e, 0x0}, + {0x4006e, 0x0}, + {0x4000f, 0x4040}, + {0x4002f, 0x80}, + {0x4004f, 0x0}, + {0x4006f, 0x0}, + {0x40010, 0x2604}, + {0x40030, 0x15}, + {0x40050, 0x0}, + {0x40070, 0x0}, + {0x40011, 0x708}, + {0x40031, 0x5}, + {0x40051, 0x0}, + {0x40071, 0x2002}, + {0x40012, 0x8}, + {0x40032, 0x80}, + {0x40052, 0x0}, + {0x40072, 0x0}, + {0x40013, 0x2604}, + {0x40033, 0x1a}, + {0x40053, 0x0}, + {0x40073, 0x0}, + {0x40014, 0x708}, + {0x40034, 0xa}, + {0x40054, 0x0}, + {0x40074, 0x2002}, + {0x40015, 0x4040}, + {0x40035, 0x80}, + {0x40055, 0x0}, + {0x40075, 0x0}, + {0x40016, 0x60a}, + {0x40036, 0x15}, + {0x40056, 0x1200}, + {0x40076, 0x0}, + {0x40017, 0x61a}, + {0x40037, 0x15}, + {0x40057, 0x1300}, + {0x40077, 0x0}, + {0x40018, 0x60a}, + {0x40038, 0x1a}, + {0x40058, 0x1200}, + {0x40078, 0x0}, + {0x40019, 0x642}, + {0x40039, 0x1a}, + {0x40059, 0x1300}, + {0x40079, 0x0}, + {0x4001a, 0x4808}, + {0x4003a, 0x880}, + {0x4005a, 0x0}, + {0x4007a, 0x0}, + {0x900a7, 0x0}, + {0x900a8, 0x790}, + {0x900a9, 0x11a}, + {0x900aa, 0x8}, + {0x900ab, 0x7aa}, + {0x900ac, 0x2a}, + {0x900ad, 0x10}, + {0x900ae, 0x7b2}, + {0x900af, 0x2a}, + {0x900b0, 0x0}, + {0x900b1, 0x7c8}, + {0x900b2, 0x109}, + {0x900b3, 0x10}, + {0x900b4, 0x2a8}, + {0x900b5, 0x129}, + {0x900b6, 0x8}, + {0x900b7, 0x370}, + {0x900b8, 0x129}, + {0x900b9, 0xa}, + {0x900ba, 0x3c8}, + {0x900bb, 0x1a9}, + {0x900bc, 0xc}, + {0x900bd, 0x408}, + {0x900be, 0x199}, + {0x900bf, 0x14}, + {0x900c0, 0x790}, + {0x900c1, 0x11a}, + {0x900c2, 0x8}, + {0x900c3, 0x4}, + {0x900c4, 0x18}, + {0x900c5, 0xe}, + {0x900c6, 0x408}, + {0x900c7, 0x199}, + {0x900c8, 0x8}, + {0x900c9, 0x8568}, + {0x900ca, 0x108}, + {0x900cb, 0x18}, + {0x900cc, 0x790}, + {0x900cd, 0x16a}, + {0x900ce, 0x8}, + {0x900cf, 0x1d8}, + {0x900d0, 0x169}, + {0x900d1, 0x10}, + {0x900d2, 0x8558}, + {0x900d3, 0x168}, + {0x900d4, 0x70}, + {0x900d5, 0x788}, + {0x900d6, 0x16a}, + {0x900d7, 0x1ff8}, + {0x900d8, 0x85a8}, + {0x900d9, 0x1e8}, + {0x900da, 0x50}, + {0x900db, 0x798}, + {0x900dc, 0x16a}, + {0x900dd, 0x60}, + {0x900de, 0x7a0}, + {0x900df, 0x16a}, + {0x900e0, 0x8}, + {0x900e1, 0x8310}, + {0x900e2, 0x168}, + {0x900e3, 0x8}, + {0x900e4, 0xa310}, + {0x900e5, 0x168}, + {0x900e6, 0xa}, + {0x900e7, 0x408}, + {0x900e8, 0x169}, + {0x900e9, 0x6e}, + {0x900ea, 0x0}, + {0x900eb, 0x68}, + {0x900ec, 0x0}, + {0x900ed, 0x408}, + {0x900ee, 0x169}, + {0x900ef, 0x0}, + {0x900f0, 0x8310}, + {0x900f1, 0x168}, + {0x900f2, 0x0}, + {0x900f3, 0xa310}, + {0x900f4, 0x168}, + {0x900f5, 0x1ff8}, + {0x900f6, 0x85a8}, + {0x900f7, 0x1e8}, + {0x900f8, 0x68}, + {0x900f9, 0x798}, + {0x900fa, 0x16a}, + {0x900fb, 0x78}, + {0x900fc, 0x7a0}, + {0x900fd, 0x16a}, + {0x900fe, 0x68}, + {0x900ff, 0x790}, + {0x90100, 0x16a}, + {0x90101, 0x8}, + {0x90102, 0x8b10}, + {0x90103, 0x168}, + {0x90104, 0x8}, + {0x90105, 0xab10}, + {0x90106, 0x168}, + {0x90107, 0xa}, + {0x90108, 0x408}, + {0x90109, 0x169}, + {0x9010a, 0x58}, + {0x9010b, 0x0}, + {0x9010c, 0x68}, + {0x9010d, 0x0}, + {0x9010e, 0x408}, + {0x9010f, 0x169}, + {0x90110, 0x0}, + {0x90111, 0x8b10}, + {0x90112, 0x168}, + {0x90113, 0x0}, + {0x90114, 0xab10}, + {0x90115, 0x168}, + {0x90116, 0x0}, + {0x90117, 0x1d8}, + {0x90118, 0x169}, + {0x90119, 0x80}, + {0x9011a, 0x790}, + {0x9011b, 0x16a}, + {0x9011c, 0x18}, + {0x9011d, 0x7aa}, + {0x9011e, 0x6a}, + {0x9011f, 0xa}, + {0x90120, 0x0}, + {0x90121, 0x1e9}, + {0x90122, 0x8}, + {0x90123, 0x8080}, + {0x90124, 0x108}, + {0x90125, 0xf}, + {0x90126, 0x408}, + {0x90127, 0x169}, + {0x90128, 0xc}, + {0x90129, 0x0}, + {0x9012a, 0x68}, + {0x9012b, 0x9}, + {0x9012c, 0x0}, + {0x9012d, 0x1a9}, + {0x9012e, 0x0}, + {0x9012f, 0x408}, + {0x90130, 0x169}, + {0x90131, 0x0}, + {0x90132, 0x8080}, + {0x90133, 0x108}, + {0x90134, 0x8}, + {0x90135, 0x7aa}, + {0x90136, 0x6a}, + {0x90137, 0x0}, + {0x90138, 0x8568}, + {0x90139, 0x108}, + {0x9013a, 0xb7}, + {0x9013b, 0x790}, + {0x9013c, 0x16a}, + {0x9013d, 0x1f}, + {0x9013e, 0x0}, + {0x9013f, 0x68}, + {0x90140, 0x8}, + {0x90141, 0x8558}, + {0x90142, 0x168}, + {0x90143, 0xf}, + {0x90144, 0x408}, + {0x90145, 0x169}, + {0x90146, 0xc}, + {0x90147, 0x0}, + {0x90148, 0x68}, + {0x90149, 0x0}, + {0x9014a, 0x408}, + {0x9014b, 0x169}, + {0x9014c, 0x0}, + {0x9014d, 0x8558}, + {0x9014e, 0x168}, + {0x9014f, 0x8}, + {0x90150, 0x3c8}, + {0x90151, 0x1a9}, + {0x90152, 0x3}, + {0x90153, 0x370}, + {0x90154, 0x129}, + {0x90155, 0x20}, + {0x90156, 0x2aa}, + {0x90157, 0x9}, + {0x90158, 0x0}, + {0x90159, 0x400}, + {0x9015a, 0x10e}, + {0x9015b, 0x8}, + {0x9015c, 0xe8}, + {0x9015d, 0x109}, + {0x9015e, 0x0}, + {0x9015f, 0x8140}, + {0x90160, 0x10c}, + {0x90161, 0x10}, + {0x90162, 0x8138}, + {0x90163, 0x10c}, + {0x90164, 0x8}, + {0x90165, 0x7c8}, + {0x90166, 0x101}, + {0x90167, 0x8}, + {0x90168, 0x0}, + {0x90169, 0x8}, + {0x9016a, 0x8}, + {0x9016b, 0x448}, + {0x9016c, 0x109}, + {0x9016d, 0xf}, + {0x9016e, 0x7c0}, + {0x9016f, 0x109}, + {0x90170, 0x0}, + {0x90171, 0xe8}, + {0x90172, 0x109}, + {0x90173, 0x47}, + {0x90174, 0x630}, + {0x90175, 0x109}, + {0x90176, 0x8}, + {0x90177, 0x618}, + {0x90178, 0x109}, + {0x90179, 0x8}, + {0x9017a, 0xe0}, + {0x9017b, 0x109}, + {0x9017c, 0x0}, + {0x9017d, 0x7c8}, + {0x9017e, 0x109}, + {0x9017f, 0x8}, + {0x90180, 0x8140}, + {0x90181, 0x10c}, + {0x90182, 0x0}, + {0x90183, 0x1}, + {0x90184, 0x8}, + {0x90185, 0x8}, + {0x90186, 0x4}, + {0x90187, 0x8}, + {0x90188, 0x8}, + {0x90189, 0x7c8}, + {0x9018a, 0x101}, + {0x90006, 0x0}, + {0x90007, 0x0}, + {0x90008, 0x8}, + {0x90009, 0x0}, + {0x9000a, 0x0}, + {0x9000b, 0x0}, + {0xd00e7, 0x400}, + {0x90017, 0x0}, + {0x9001f, 0x2a}, + {0x90026, 0x6a}, + {0x400d0, 0x0}, + {0x400d1, 0x101}, + {0x400d2, 0x105}, + {0x400d3, 0x107}, + {0x400d4, 0x10f}, + {0x400d5, 0x202}, + {0x400d6, 0x20a}, + {0x400d7, 0x20b}, + {0x2003a, 0x2}, + {0x2000b, 0x64}, + {0x2000c, 0xc8}, + {0x2000d, 0x7d0}, + {0x2000e, 0x2c}, + {0x12000b, 0x14}, + {0x12000c, 0x29}, + {0x12000d, 0x1a1}, + {0x12000e, 0x10}, + {0x9000c, 0x0}, + {0x9000d, 0x173}, + {0x9000e, 0x60}, + {0x9000f, 0x6110}, + {0x90010, 0x2152}, + {0x90011, 0xdfbd}, + {0x90012, 0x60}, + {0x90013, 0x6152}, + {0x20010, 0x5a}, + {0x20011, 0x3}, + {0x120010, 0x5a}, + {0x120011, 0x3}, + {0x40080, 0xe0}, + {0x40081, 0x12}, + {0x40082, 0xe0}, + {0x40083, 0x12}, + {0x40084, 0xe0}, + {0x40085, 0x12}, + {0x140080, 0xe0}, + {0x140081, 0x12}, + {0x140082, 0xe0}, + {0x140083, 0x12}, + {0x140084, 0xe0}, + {0x140085, 0x12}, + {0x400fd, 0xf}, + {0x10011, 0x1}, + {0x10012, 0x1}, + {0x10013, 0x180}, + {0x10018, 0x1}, + {0x10002, 0x6209}, + {0x100b2, 0x1}, + {0x101b4, 0x1}, + {0x102b4, 0x1}, + {0x103b4, 0x1}, + {0x104b4, 0x1}, + {0x105b4, 0x1}, + {0x106b4, 0x1}, + {0x107b4, 0x1}, + {0x108b4, 0x1}, + {0x11011, 0x1}, + {0x11012, 0x1}, + {0x11013, 0x180}, + {0x11018, 0x1}, + {0x11002, 0x6209}, + {0x110b2, 0x1}, + {0x111b4, 0x1}, + {0x112b4, 0x1}, + {0x113b4, 0x1}, + {0x114b4, 0x1}, + {0x115b4, 0x1}, + {0x116b4, 0x1}, + {0x117b4, 0x1}, + {0x118b4, 0x1}, + {0x12011, 0x1}, + {0x12012, 0x1}, + {0x12013, 0x180}, + {0x12018, 0x1}, + {0x12002, 0x6209}, + {0x120b2, 0x1}, + {0x121b4, 0x1}, + {0x122b4, 0x1}, + {0x123b4, 0x1}, + {0x124b4, 0x1}, + {0x125b4, 0x1}, + {0x126b4, 0x1}, + {0x127b4, 0x1}, + {0x128b4, 0x1}, + {0x13011, 0x1}, + {0x13012, 0x1}, + {0x13013, 0x180}, + {0x13018, 0x1}, + {0x13002, 0x6209}, + {0x130b2, 0x1}, + {0x131b4, 0x1}, + {0x132b4, 0x1}, + {0x133b4, 0x1}, + {0x134b4, 0x1}, + {0x135b4, 0x1}, + {0x136b4, 0x1}, + {0x137b4, 0x1}, + {0x138b4, 0x1}, + {0x2003a, 0x2}, + {0xc0080, 0x2}, + {0xd0000, 0x1} +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 667mts 1D */ + .drate = 667, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_4gb = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 667, }, +}; + diff --git a/board/technexion/pico-imx8mq/pico-imx8mq.c b/board/technexion/pico-imx8mq/pico-imx8mq.c new file mode 100644 index 0000000000..5402e8b63e --- /dev/null +++ b/board/technexion/pico-imx8mq/pico-imx8mq.c @@ -0,0 +1,149 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ + +#include <common.h> +#include <env.h> +#include <init.h> +#include <malloc.h> +#include <errno.h> +#include <asm/io.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm-generic/gpio.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/arch/clock.h> +#include <spl.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) + +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) + +static iomux_v3_cfg_t const wdog_pads[] = { + IMX8MQ_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart_pads[] = { + IMX8MQ_PAD_UART1_RXD__UART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART1_TXD__UART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + return 0; +} + +int dram_init(void) +{ + int ddr_size = readl(M4_BOOTROM_BASE_ADDR); + + if (ddr_size == 0x4) + gd->ram_size = 0x100000000; + else if (ddr_size == 0x3) + gd->ram_size = 0xc0000000; + else if (ddr_size == 0x2) + gd->ram_size = 0x80000000; + else if (ddr_size == 0x1) + gd->ram_size = 0x40000000; + else + printf("Unknown DDR type!!!\n"); + + /* rom_pointer[1] contains the size of TEE occupies */ + if (rom_pointer[1]) + gd->ram_size -= rom_pointer[1]; + + return 0; +} + +#ifdef CONFIG_FEC_MXC +#define FEC_RST_PAD IMX_GPIO_NR(1, 9) +#define FEC_PWR_PAD IMX_GPIO_NR(1, 0) +static iomux_v3_cfg_t const fec1_pads[] = { + /* Reset */ + IMX8MQ_PAD_GPIO1_IO09__GPIO1_IO9 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* Power */ + IMX8MQ_PAD_GPIO1_IO00__GPIO1_IO0 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); + + gpio_request(IMX_GPIO_NR(1, 0), "fec1_pwr"); + gpio_direction_output(IMX_GPIO_NR(1, 0), 1); + udelay(500); + + gpio_request(IMX_GPIO_NR(1, 9), "fec1_rst"); + gpio_direction_output(IMX_GPIO_NR(1, 9), 0); + udelay(500); + gpio_direction_output(IMX_GPIO_NR(1, 9), 1); +} + +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + setup_iomux_fec(); + + /* Use 125M anatop REF_CLK1 for ENET1, not from external */ + clrsetbits_le32(&gpr->gpr[1], BIT(13) | BIT(17), 0); + return set_clk_enet(ENET_125MHZ); +} + +int board_phy_config(struct phy_device *phydev) +{ + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + +int board_init(void) +{ +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + + return 0; +} + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "EVK"); + env_set("board_rev", "iMX8MQ"); +#endif + + return 0; +} diff --git a/board/technexion/pico-imx8mq/spl.c b/board/technexion/pico-imx8mq/spl.c new file mode 100644 index 0000000000..234348a6de --- /dev/null +++ b/board/technexion/pico-imx8mq/spl.c @@ -0,0 +1,241 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ + +#include <common.h> +#include <hang.h> +#include <asm/arch/clock.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <errno.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> +#include <spl.h> + +#include "lpddr4_timing.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define DDR_DET_1 IMX_GPIO_NR(3, 11) +#define DDR_DET_2 IMX_GPIO_NR(3, 12) +#define DDR_DET_3 IMX_GPIO_NR(3, 13) + +static iomux_v3_cfg_t const verdet_pads[] = { + IMX8MQ_PAD_NAND_DATA01__GPIO3_IO7 | MUX_PAD_CTRL(NO_PAD_CTRL), + IMX8MQ_PAD_NAND_DATA02__GPIO3_IO8 | MUX_PAD_CTRL(NO_PAD_CTRL), + IMX8MQ_PAD_NAND_DATA03__GPIO3_IO9 | MUX_PAD_CTRL(NO_PAD_CTRL), + IMX8MQ_PAD_NAND_DATA04__GPIO3_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), + IMX8MQ_PAD_NAND_DATA05__GPIO3_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), + IMX8MQ_PAD_NAND_DATA06__GPIO3_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL), + IMX8MQ_PAD_NAND_DATA07__GPIO3_IO13 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +/* + * DDR_DET_1 DDR_DET_2 DDR_DET_3 + * 0 0 1 4G LPDDR4 + * 1 1 1 3G LPDDR4 + * 1 1 0 2G LPDDR4 + * 1 0 1 1G LPDDR4 + */ +static void spl_dram_init(void) +{ + struct dram_timing_info *dram_timing; + u8 ddr = 0, size; + + imx_iomux_v3_setup_multiple_pads(verdet_pads, ARRAY_SIZE(verdet_pads)); + + gpio_request(DDR_DET_1, "ddr_det_1"); + gpio_direction_input(DDR_DET_1); + gpio_request(DDR_DET_2, "ddr_det_2"); + gpio_direction_input(DDR_DET_2); + gpio_request(DDR_DET_3, "ddr_det_3"); + gpio_direction_input(DDR_DET_3); + + ddr |= !!gpio_get_value(DDR_DET_3) << 0; + ddr |= !!gpio_get_value(DDR_DET_2) << 1; + ddr |= !!gpio_get_value(DDR_DET_1) << 2; + + switch (ddr) { + case 0x1: + size = 4; + dram_timing = &dram_timing_4gb; + break; + case 0x7: + size = 3; + dram_timing = &dram_timing_3gb; + break; + case 0x6: + size = 2; + dram_timing = &dram_timing_2gb; + break; + case 0x5: + size = 1; + dram_timing = &dram_timing_1gb; + break; + default: + puts("Unknown DDR type!!!\n"); + return; + } + + printf("%s: LPDDR4 %i GiB\n", __func__, size); + ddr_init(dram_timing); + writel(size, M4_BOOTROM_BASE_ADDR); +} + +#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +static struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = IMX8MQ_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SCL__GPIO5_IO14 | PC, + .gp = IMX_GPIO_NR(5, 14), + }, + .sda = { + .i2c_mode = IMX8MQ_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SDA__GPIO5_IO15 | PC, + .gp = IMX_GPIO_NR(5, 15), + }, +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 12) +#define USDHC1_PWR_GPIO IMX_GPIO_NR(2, 10) +#define USDHC2_PWR_GPIO IMX_GPIO_NR(2, 19) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + return ret; + } + + return 1; +} + +#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | \ + PAD_CTL_FSEL2) +#define USDHC_GPIO_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_DSE1) + +static iomux_v3_cfg_t const usdhc1_pads[] = { + IMX8MQ_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA4__USDHC1_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA5__USDHC1_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA6__USDHC1_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA7__USDHC1_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc2_pads[] = { + IMX8MQ_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD2_DATA0__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD2_DATA1__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD2_DATA2__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD2_DATA3__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD2_CD_B__GPIO2_IO12 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), + IMX8MQ_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), +}; + +static struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC1_BASE_ADDR, 0, 8}, + {USDHC2_BASE_ADDR, 0, 4}, +}; + +int board_mmc_init(bd_t *bis) +{ + int ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + init_clk_usdhc(0); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(USDHC1_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + gpio_request(USDHC1_PWR_GPIO, "usdhc1_reset"); + gpio_direction_output(USDHC1_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC1_PWR_GPIO, 1); + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[0]); + if (ret) + return ret; + + init_clk_usdhc(1); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(USDHC2_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + gpio_request(USDHC2_PWR_GPIO, "usdhc2_reset"); + gpio_direction_output(USDHC2_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC2_PWR_GPIO, 1); + return fsl_esdhc_initialize(bis, &usdhc_cfg[1]); +} + +void spl_board_init(void) +{ + puts("Normal Boot\n"); +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + int ret; + + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + arch_cpu_init(); + + init_uart_clk(0); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + /* Adjust pmic voltage to 1.0V for 800M */ + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/pico-imx8mq_defconfig b/configs/pico-imx8mq_defconfig new file mode 100644 index 0000000000..9193e1f406 --- /dev/null +++ b/configs/pico-imx8mq_defconfig @@ -0,0 +1,49 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_DM_GPIO=y +CONFIG_TARGET_PICO_IMX8MQ=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL=y +CONFIG_CSF_SIZE=0x2000 +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage.cfg" +CONFIG_SPL_BOARD_INIT=y +CONFIG_HUSH_PARSER=y +# CONFIG_BOOTM_NETBSD is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mq-pico-pi" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RESET=y +CONFIG_DM_THERMAL=y diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h new file mode 100644 index 0000000000..0f1c7831e6 --- /dev/null +++ b/include/configs/pico-imx8mq.h @@ -0,0 +1,216 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#ifndef __IMX8M_EVK_H +#define __IMX8M_EVK_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_SPL_MAX_SIZE (124 * 1024) +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 + +#ifdef CONFIG_SPL_BUILD +/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ +#define CONFIG_SPL_WATCHDOG_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x187FF0 +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_BSS_START_ADDR 0x00180000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */ +#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x182000 +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#undef CONFIG_DM_MMC +#undef CONFIG_DM_PMIC +#undef CONFIG_DM_PMIC_PFUZE100 + +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ +#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_PFUZE100 +#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 +#endif + +#define CONFIG_REMAKE_ELF + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT + +#undef CONFIG_CMD_EXPORTENV +#undef CONFIG_CMD_IMPORTENV +#undef CONFIG_CMD_IMLS + +#undef CONFIG_CMD_CRC32 + +/* ENET Config */ +/* ENET1 */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_MII +#define CONFIG_ETHPRIME "FEC" + +#define CONFIG_FEC_MXC +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 1 +#define FEC_QUIRK_ENET_MAC + +#define CONFIG_PHY_GIGE +#define IMX_FEC_BASE 0x30BE0000 + +#define CONFIG_PHYLIB +#define CONFIG_PHY_ATHEROS +#endif + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=Image\0" \ + "console=ttymxc0,115200\0" \ + "fdt_addr=0x43000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "boot_fdt=try\0" \ + "fdt_file=imx8mq-pico-pi.dtb\0" \ + "initrd_addr=0x43800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console} root=${mmcroot}\0 " \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "echo wait for boot; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "booti; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else booti ${loadaddr} - ${fdt_addr}; fi" + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x40480000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */ + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN ((CONFIG_ENV_SIZE + (2 * 1024)) * 1024) + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2 GiB DDR */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + (PHYS_SDRAM_SIZE >> 1)) + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +#define CONFIG_IMX_BOOTAUX + +#define CONFIG_CMD_MMC + +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#define CONFIG_MXC_GPIO + +#define CONFIG_CMD_FUSE + +/* I2C Configs */ +#define CONFIG_SYS_I2C_SPEED 100000 + +#define CONFIG_OF_SYSTEM_SETUP + +#ifndef CONFIG_SPL_BUILD +#define CONFIG_DM_PMIC +#endif + +#endif
Hi Marek,
On Wed, Apr 1, 2020 at 9:42 PM Marek Vasut marek.vasut@gmail.com wrote:
@@ -0,0 +1,416 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright 2018 Wandboard, Org.
- Copyright 2017 NXP
- Author: Richard Hu hakahu@gmail.com
+/dts-v1/;
+/* First 128KB is for PSCI ATF. */ +/memreserve/ 0x40000000 0x00020000;
Please remove this as it is not part of the official device tree.
If you really need it, then add it to the u-boot.dtsi version.
I guess this is not needed and I plan to remove it from imx8mq-evk as well.0x0},
This include file is not needed as this PMIC is not used on this board.
udelay(500);
udelay(500);
This should be done via device tree instead of board code.
This board is not an EVK ;-)
Why is this needed?
The comment does not match the code.
Can't we have caches enabled now? I don't recall why we disabled it for i.MX8MQ EVK, but I thought this is no longer an issue.
- Copyright 2018 NXP
This should be adjusted for the pico board name instead of evk.
This PMIC is not used on this board.
This could be moved to defconfig.
Not needed if you use DM.
"image=Image\0" \
"boot_fdt=try\0" \
Please remove "boot_fdt".
This only made sense when we wanted to supported both dt and non-dt platforms in the beginning of i.MX6 times.
Fabio Estevam
