[U-Boot] [PATCH-ARM 4/4, v3] Clean-up of s3c24x0 nand driver]
This patch re-formats the arm920t s3c24x0 nand driver in preparation for changes to add support for the Embest SBC2440-II Board.
The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports
It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 - patches 1/4, 2/4 and 3/4 of this series
Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found.
Signed-off-by: Kevin Morfitt kevin.morfitt@fearnside-systems.co.uk ---
Changes in v2: re-formatted patch to remove line wrapping Changes in v3: removed checkpatch.pl errors moved change log
drivers/mtd/nand/s3c2410_nand.c | 62 +++++++++++++++----------------------- 1 files changed, 25 insertions(+), 37 deletions(-)
diff --git a/drivers/mtd/nand/s3c2410_nand.c b/drivers/mtd/nand/s3c2410_nand.c index d27a625..f2f3e72 100644 --- a/drivers/mtd/nand/s3c2410_nand.c +++ b/drivers/mtd/nand/s3c2410_nand.c @@ -20,29 +20,10 @@
#include <common.h>
-#if 0 -#define DEBUGN printf -#else -#define DEBUGN(x, args ...) {} -#endif - #include <nand.h> #include <s3c2410.h> #include <asm/io.h>
-#define __REGb(x) (*(volatile unsigned char *)(x)) -#define __REGi(x) (*(volatile unsigned int *)(x)) - -#define NF_BASE 0x4e000000 -#define NFCONF __REGi(NF_BASE + 0x0) -#define NFCMD __REGb(NF_BASE + 0x4) -#define NFADDR __REGb(NF_BASE + 0x8) -#define NFDATA __REGb(NF_BASE + 0xc) -#define NFSTAT __REGb(NF_BASE + 0x10) -#define NFECC0 __REGb(NF_BASE + 0x14) -#define NFECC1 __REGb(NF_BASE + 0x15) -#define NFECC2 __REGb(NF_BASE + 0x16) - #define S3C2410_NFCONF_EN (1<<15) #define S3C2410_NFCONF_512BYTE (1<<14) #define S3C2410_NFCONF_4STEP (1<<13) @@ -58,11 +39,12 @@ static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) { struct nand_chip *chip = mtd->priv; + struct s3c2410_nand *nand = s3c2410_get_base_nand();
- DEBUGN("hwcontrol(): 0x%02x 0x%02x\n", cmd, ctrl); + debugX(1, "hwcontrol(): 0x%02x 0x%02x\n", cmd, ctrl);
if (ctrl & NAND_CTRL_CHANGE) { - ulong IO_ADDR_W = NF_BASE; + ulong IO_ADDR_W = (ulong)nand;
if (!(ctrl & NAND_CLE)) IO_ADDR_W |= S3C2410_ADDR_NCLE; @@ -72,9 +54,11 @@ static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) chip->IO_ADDR_W = (void *)IO_ADDR_W;
if (ctrl & NAND_NCE) - NFCONF &= ~S3C2410_NFCONF_nFCE; + writel(readl(&nand->NFCONF) & ~S3C2410_NFCONF_nFCE, + &nand->NFCONF); else - NFCONF |= S3C2410_NFCONF_nFCE; + writel(readl(&nand->NFCONF) | S3C2410_NFCONF_nFCE, + &nand->NFCONF); }
if (cmd != NAND_CMD_NONE) @@ -83,15 +67,17 @@ static void s3c2410_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl)
static int s3c2410_dev_ready(struct mtd_info *mtd) { - DEBUGN("dev_ready\n"); - return (NFSTAT & 0x01); + struct s3c2410_nand *nand = s3c2410_get_base_nand(); + debugX(1, "dev_ready\n"); + return readl(&nand->NFSTAT) & 0x01; }
#ifdef CONFIG_S3C2410_NAND_HWECC void s3c2410_nand_enable_hwecc(struct mtd_info *mtd, int mode) { - DEBUGN("s3c2410_nand_enable_hwecc(%p, %d)\n", mtd, mode); - NFCONF |= S3C2410_NFCONF_INITECC; + struct s3c2410_nand *nand = s3c2410_get_base_nand(); + debugX(1, "s3c2410_nand_enable_hwecc(%p, %d)\n", mtd, mode); + writel(readl(&nand->NFCONF) | S3C2410_NFCONF_INITECC, &nand->NFCONF); }
static int s3c2410_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, @@ -100,8 +86,8 @@ static int s3c2410_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, ecc_code[0] = NFECC0; ecc_code[1] = NFECC1; ecc_code[2] = NFECC2; - DEBUGN("s3c2410_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02x\n", - mtd , ecc_code[0], ecc_code[1], ecc_code[2]); + debugX(1, "s3c2410_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02x\n", + mtd , ecc_code[0], ecc_code[1], ecc_code[2]);
return 0; } @@ -123,24 +109,26 @@ int board_nand_init(struct nand_chip *nand) { u_int32_t cfg; u_int8_t tacls, twrph0, twrph1; - S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER(); + struct s3c24x0_clock_power *clk_power = s3c24x0_get_base_clock_power(); + struct s3c2410_nand *nand_reg = s3c2410_get_base_nand();
- DEBUGN("board_nand_init()\n"); + debugX(1, "board_nand_init()\n");
- clk_power->CLKCON |= (1 << 4); + writel(readl(&clk_power->CLKCON) | (1 << 4), &clk_power->CLKCON);
/* initialize hardware */ - twrph0 = 3; twrph1 = 0; tacls = 0; + twrph0 = 3; + twrph1 = 0; + tacls = 0;
cfg = S3C2410_NFCONF_EN; cfg |= S3C2410_NFCONF_TACLS(tacls - 1); cfg |= S3C2410_NFCONF_TWRPH0(twrph0 - 1); cfg |= S3C2410_NFCONF_TWRPH1(twrph1 - 1); - - NFCONF = cfg; + writel(cfg, &nand_reg->NFCONF);
/* initialize nand_chip data structure */ - nand->IO_ADDR_R = nand->IO_ADDR_W = (void *)0x4e00000c; + nand->IO_ADDR_R = nand->IO_ADDR_W = (void *)&nand_reg->NFDATA;
/* read_buf and write_buf are default */ /* read_byte and write_byte are default */ @@ -165,7 +153,7 @@ int board_nand_init(struct nand_chip *nand) nand->options = 0; #endif
- DEBUGN("end of nand_init\n"); + debugX(1, "end of nand_init\n");
return 0; } -- 1.6.1.2 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear kevin.morfitt
2009/10/10 kevin.morfitt@fearnside-systems.co.uk kevin.morfitt@fearnside-systems.co.uk:
non-typedef'ed ones
applied to u-boot-samsung
Thanks Minkyu Kang
Minkyu Kang
