[U-Boot] [PATCH] ts4600: Disable CONFIG_DISPLAY_CPUINFO
Without this change we see: ../arch/arm/cpu/arm926ejs/mxs/mxs.c: In function ‘print_cpuinfo’: ../arch/arm/cpu/arm926ejs/mxs/mxs.c:181:23: warning: unused variable ‘data’ [-Wunused-variable] ../arch/arm/cpu/arm926ejs/mxs/mxs.c:180:6: warning: variable ‘cpurev’ set but not used [-Wunused-but-set-variable]
So the easy solution is to disable CONFIG_DISPLAY_CPUINFO
Cc: Sebastien Bourdelin sebastien.bourdelin@savoirfairelinux.com Signed-off-by: Tom Rini trini@konsulko.com --- configs/ts4600_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/ts4600_defconfig b/configs/ts4600_defconfig index c052dedf1368..1d3acd3c7126 100644 --- a/configs/ts4600_defconfig +++ b/configs/ts4600_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_SYS_CONSOLE_IS_IN_ENV=y +# CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y
Reviewed-by: Sebastien Bourdelin sebastien.bourdelin@savoirfairelinux.com
Reviewed-by: Sebastien Bourdelin sebastien.bourdelin@savoirfairelinux.com Signed-off-by: Tom Rini trini@konsulko.com
Sebastien Bourdelin
