[PATCH 1/2] mx6sabreauto: Convert to DM_PMIC
The usage of DM_PMIC is preferred, so convert to it.
This also brings the benefit of causing a significant amount of code removal.
Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com --- board/freescale/mx6sabreauto/mx6sabreauto.c | 109 +++----------------- configs/mx6sabreauto_defconfig | 13 +-- include/configs/mx6sabreauto.h | 3 - 3 files changed, 19 insertions(+), 106 deletions(-)
diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index 9155dcfbd0..0ae86f42df 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -19,14 +19,12 @@ #include <linux/errno.h> #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> -#include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/spi.h> #include <mmc.h> #include <fsl_esdhc_imx.h> #include <miiphy.h> #include <asm/arch/sys_proto.h> -#include <i2c.h> #include <input.h> #include <asm/arch/mxc_hdmi.h> #include <asm/mach-imx/video.h> @@ -49,23 +47,15 @@ DECLARE_GLOBAL_DATA_PTR; #define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
-#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE | PAD_CTL_SRE_FAST) - #define GPMI_PAD_CTRL0 (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_100K_UP) #define GPMI_PAD_CTRL1 (PAD_CTL_DSE_40ohm | PAD_CTL_SPEED_MED | \ PAD_CTL_SRE_FAST) #define GPMI_PAD_CTRL2 (GPMI_PAD_CTRL0 | GPMI_PAD_CTRL1)
-#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) - #define WEIM_NOR_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
-#define I2C_PMIC 1 - int dram_init(void) { gd->ram_size = imx_ddr_size(); @@ -78,70 +68,6 @@ static iomux_v3_cfg_t const uart4_pads[] = { IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), };
- -/* I2C2 PMIC, iPod, Tuner, Codec, Touch, HDMI EDID, MIPI CSI2 card */ -static struct i2c_pads_info mx6q_i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6Q_PAD_EIM_EB2__I2C2_SCL | PC, - .gpio_mode = MX6Q_PAD_EIM_EB2__GPIO2_IO30 | PC, - .gp = IMX_GPIO_NR(2, 30) - }, - .sda = { - .i2c_mode = MX6Q_PAD_KEY_ROW3__I2C2_SDA | PC, - .gpio_mode = MX6Q_PAD_KEY_ROW3__GPIO4_IO13 | PC, - .gp = IMX_GPIO_NR(4, 13) - } -}; - -static struct i2c_pads_info mx6dl_i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6DL_PAD_EIM_EB2__I2C2_SCL | PC, - .gpio_mode = MX6DL_PAD_EIM_EB2__GPIO2_IO30 | PC, - .gp = IMX_GPIO_NR(2, 30) - }, - .sda = { - .i2c_mode = MX6DL_PAD_KEY_ROW3__I2C2_SDA | PC, - .gpio_mode = MX6DL_PAD_KEY_ROW3__GPIO4_IO13 | PC, - .gp = IMX_GPIO_NR(4, 13) - } -}; - -#ifndef CONFIG_SYS_FLASH_CFI -/* - * I2C3 MLB, Port Expanders (A, B, C), Video ADC, Light Sensor, - * Compass Sensor, Accelerometer, Res Touch - */ -static struct i2c_pads_info mx6q_i2c_pad_info2 = { - .scl = { - .i2c_mode = MX6Q_PAD_GPIO_3__I2C3_SCL | PC, - .gpio_mode = MX6Q_PAD_GPIO_3__GPIO1_IO03 | PC, - .gp = IMX_GPIO_NR(1, 3) - }, - .sda = { - .i2c_mode = MX6Q_PAD_EIM_D18__I2C3_SDA | PC, - .gpio_mode = MX6Q_PAD_EIM_D18__GPIO3_IO18 | PC, - .gp = IMX_GPIO_NR(3, 18) - } -}; - -static struct i2c_pads_info mx6dl_i2c_pad_info2 = { - .scl = { - .i2c_mode = MX6DL_PAD_GPIO_3__I2C3_SCL | PC, - .gpio_mode = MX6DL_PAD_GPIO_3__GPIO1_IO03 | PC, - .gp = IMX_GPIO_NR(1, 3) - }, - .sda = { - .i2c_mode = MX6DL_PAD_EIM_D18__I2C3_SDA | PC, - .gpio_mode = MX6DL_PAD_EIM_D18__GPIO3_IO18 | PC, - .gp = IMX_GPIO_NR(3, 18) - } -}; -#endif - -static iomux_v3_cfg_t const i2c3_pads[] = { - IOMUX_PADS(PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - static iomux_v3_cfg_t const port_exp[] = { IOMUX_PADS(PAD_SD2_DAT0__GPIO1_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL)), }; @@ -516,21 +442,10 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- /* I2C 2 and 3 setup - I2C 3 hw mux with EIM */ - if (is_mx6dq() || is_mx6dqp()) - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c_pad_info1); - else - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info1); /* I2C 3 Steer */ gpio_request(IMX_GPIO_NR(5, 4), "steer logic"); gpio_direction_output(IMX_GPIO_NR(5, 4), 1); - SETUP_IOMUX_PADS(i2c3_pads); -#ifndef CONFIG_SYS_FLASH_CFI - if (is_mx6dq() || is_mx6dqp()) - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c_pad_info2); - else - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info2); -#endif + gpio_request(IMX_GPIO_NR(1, 15), "expander en"); gpio_direction_output(IMX_GPIO_NR(1, 15), 1); SETUP_IOMUX_PADS(port_exp); @@ -554,22 +469,27 @@ int board_spi_cs_gpio(unsigned bus, unsigned cs)
int power_init_board(void) { - struct pmic *p; - unsigned int value; + struct udevice *dev; + unsigned int value; + int ret; + + ret = pmic_get("pfuze100@8", &dev); + if (ret == -ENODEV) + return 0; + + if (ret != 0) + return ret;
- p = pfuze_common_init(I2C_PMIC); - if (!p) - return -ENODEV;
if (is_mx6dqp()) { /* set SW2 staby volatage 0.975V*/ - pmic_reg_read(p, PFUZE100_SW2STBY, &value); + value = pmic_reg_read(dev, PFUZE100_SW2STBY); value &= ~0x3f; value |= 0x17; - pmic_reg_write(p, PFUZE100_SW2STBY, value); + pmic_reg_write(dev, PFUZE100_SW2STBY, value); }
- return pfuze_mode_init(p, APS_PFM); + return pfuze_mode_init(dev, APS_PFM); }
#ifdef CONFIG_CMD_BMODE @@ -979,7 +899,6 @@ void board_init_f(ulong dummy) ccgr_init(); gpr_init();
- /* iomux and setup of i2c */ board_early_init_f();
/* setup GP timer */ diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 50f63c23b1..7d26c829ae 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -11,9 +11,6 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 CONFIG_MX6QDL=y CONFIG_TARGET_MX6SABREAUTO=y -CONFIG_SYS_I2C_MXC_I2C1=y -CONFIG_SYS_I2C_MXC_I2C2=y -CONFIG_SYS_I2C_MXC_I2C3=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-sabreauto" CONFIG_SPL_TEXT_BASE=0x00908000 @@ -38,7 +35,6 @@ CONFIG_SYS_SPL_MALLOC=y CONFIG_SPL_FIT_IMAGE_TINY=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" -CONFIG_SPL_I2C=y CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_SDP_SUPPORT=y @@ -77,7 +73,6 @@ CONFIG_BOUNCE_BUFFER=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_DM_I2C=y -CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_MTD=y @@ -94,10 +89,12 @@ CONFIG_RGMII=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y -CONFIG_POWER_LEGACY=y -CONFIG_POWER_PFUZE100=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_REGULATOR=y -CONFIG_POWER_I2C=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index 05ae2fce1f..91544c8a0e 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -35,7 +35,4 @@
/* DMA stuff, needed for GPMI/MXS NAND support */
-/* PMIC */ -#define CFG_POWER_PFUZE100_I2C_ADDR 0x08 - #endif /* __MX6SABREAUTO_CONFIG_H */
Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com --- board/freescale/mx6sabresd/mx6sabresd.c | 63 +++++-------------------- configs/mx6sabresd_defconfig | 11 ++--- include/configs/mx6sabresd.h | 3 -- 3 files changed, 17 insertions(+), 60 deletions(-)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 8c35230855..96a76b0581 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -17,7 +17,6 @@ #include <env.h> #include <linux/errno.h> #include <asm/gpio.h> -#include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> @@ -28,7 +27,6 @@ #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> -#include <i2c.h> #include <input.h> #include <power/pmic.h> #include <power/pfuze100_pmic.h> @@ -49,14 +47,6 @@ DECLARE_GLOBAL_DATA_PTR; #define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
-#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE | PAD_CTL_SRE_FAST) - -#define I2C_PMIC 1 - -#define I2C_PAD MUX_PAD_CTRL(I2C_PAD_CTRL) - #define DISP0_PWR_EN IMX_GPIO_NR(1, 21)
#define KEY_VOL_UP IMX_GPIO_NR(1, 4) @@ -174,32 +164,6 @@ static void enable_lvds(struct display_info_t const *dev) enable_backlight(); }
-static struct i2c_pads_info mx6q_i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6Q_PAD_KEY_COL3__I2C2_SCL | I2C_PAD, - .gpio_mode = MX6Q_PAD_KEY_COL3__GPIO4_IO12 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6Q_PAD_KEY_ROW3__I2C2_SDA | I2C_PAD, - .gpio_mode = MX6Q_PAD_KEY_ROW3__GPIO4_IO13 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 13) - } -}; - -static struct i2c_pads_info mx6dl_i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6DL_PAD_KEY_COL3__I2C2_SCL | I2C_PAD, - .gpio_mode = MX6DL_PAD_KEY_COL3__GPIO4_IO12 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6DL_PAD_KEY_ROW3__I2C2_SDA | I2C_PAD, - .gpio_mode = MX6DL_PAD_KEY_ROW3__GPIO4_IO13 | I2C_PAD, - .gp = IMX_GPIO_NR(4, 13) - } -}; - static void setup_spi(void) { SETUP_IOMUX_PADS(ecspi1_pads); @@ -495,10 +459,7 @@ int board_init(void) #ifdef CONFIG_MXC_SPI setup_spi(); #endif - if (is_mx6dq() || is_mx6dqp()) - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c_pad_info1); - else - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info1); + #if defined(CONFIG_VIDEO_IPUV3) setup_display(); #endif @@ -511,29 +472,32 @@ int board_init(void)
int power_init_board(void) { - struct pmic *p; + struct udevice *dev; unsigned int reg; int ret;
- p = pfuze_common_init(I2C_PMIC); - if (!p) - return -ENODEV; + ret = pmic_get("pfuze100@8", &dev); + if (ret == -ENODEV) + return 0; + + if (ret != 0) + return ret;
- ret = pfuze_mode_init(p, APS_PFM); + ret = pfuze_mode_init(dev, APS_PFM); if (ret < 0) return ret;
/* Increase VGEN3 from 2.5 to 2.8V */ - pmic_reg_read(p, PFUZE100_VGEN3VOL, ®); + reg = pmic_reg_read(dev, PFUZE100_VGEN3VOL); reg &= ~LDO_VOL_MASK; reg |= LDOB_2_80V; - pmic_reg_write(p, PFUZE100_VGEN3VOL, reg); + pmic_reg_write(dev, PFUZE100_VGEN3VOL, reg);
/* Increase VGEN5 from 2.8 to 3V */ - pmic_reg_read(p, PFUZE100_VGEN5VOL, ®); + reg = pmic_reg_read(dev, PFUZE100_VGEN5VOL); reg &= ~LDO_VOL_MASK; reg |= LDOB_3_00V; - pmic_reg_write(p, PFUZE100_VGEN5VOL, reg); + pmic_reg_write(dev, PFUZE100_VGEN5VOL, reg);
return 0; } @@ -902,7 +866,6 @@ void board_init_f(ulong dummy) ccgr_init(); gpr_init();
/* setup GP timer */ diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 6905850083..0033a0e50a 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -11,9 +11,6 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 CONFIG_MX6QDL=y CONFIG_TARGET_MX6SABRESD=y -CONFIG_SYS_I2C_MXC_I2C1=y -CONFIG_SYS_I2C_MXC_I2C2=y -CONFIG_SYS_I2C_MXC_I2C3=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-sabresd" CONFIG_SPL_TEXT_BASE=0x00908000 @@ -83,7 +80,6 @@ CONFIG_FASTBOOT_BUF_SIZE=0x10000000 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=2 CONFIG_DM_I2C=y -CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y @@ -101,11 +97,12 @@ CONFIG_PCI_SCAN_SHOW=y CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y -CONFIG_POWER_LEGACY=y -CONFIG_POWER_PFUZE100=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y -CONFIG_POWER_I2C=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 30d3b9d930..844f10e422 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -24,9 +24,6 @@ #define CFG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(3, 19) #endif
-/* PMIC */ -#define CFG_POWER_PFUZE100_I2C_ADDR 0x08 - /* USB Configs */ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW)
The usage of DM_PMIC is preferred, so convert to it. This also brings the benefit of causing a significant amount of code removal. Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com
Applied to u-boot-imx, next, thanks !
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
