[U-Boot] [PATCH] arm: ls1021atwr: Rework local commands to not be included in SPL
Move some of the code for the "lane_bank" and "cpld" code local commands so that they are not built for SPL as they can only be used in full U-Boot. This means we can mark a few functions as static as well now.
Cc: Alison Wang alison.wang@freescale.com Cc: Sumit Garg sumit.garg@nxp.com Cc: York Sun york.sun@nxp.com Signed-off-by: Tom Rini trini@konsulko.com --- board/freescale/ls1021atwr/ls1021atwr.c | 91 ++++++++++++++++----------------- 1 file changed, 45 insertions(+), 46 deletions(-)
diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 2da06773c479..622a50095339 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -92,9 +92,7 @@ struct cpld_data { };
#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) -static void convert_serdes_mux(int type, int need_reset); - -void cpld_show(void) +static void cpld_show(void) { struct cpld_data *cpld_data = (void *)(CONFIG_SYS_CPLD_BASE);
@@ -292,6 +290,47 @@ int board_eth_init(bd_t *bis) }
#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +static void convert_serdes_mux(int type, int need_reset) +{ + char current_serdes; + struct cpld_data *cpld_data = (void *)(CONFIG_SYS_CPLD_BASE); + + current_serdes = cpld_data->serdes_mux; + + switch (type) { + case LANEB_SATA: + current_serdes &= ~MASK_LANE_B; + break; + case LANEB_SGMII1: + current_serdes |= (MASK_LANE_B | MASK_SGMII | MASK_LANE_C); + break; + case LANEC_SGMII1: + current_serdes &= ~(MASK_LANE_B | MASK_SGMII | MASK_LANE_C); + break; + case LANED_SGMII2: + current_serdes |= MASK_LANE_D; + break; + case LANEC_PCIEX1: + current_serdes |= MASK_LANE_C; + break; + case (LANED_PCIEX2 | LANEC_PCIEX1): + current_serdes |= MASK_LANE_C; + current_serdes &= ~MASK_LANE_D; + break; + default: + printf("CPLD serdes MUX: unsupported MUX type 0x%x\n", type); + return; + } + + cpld_data->soft_mux_on |= CPLD_SET_MUX_SERDES; + cpld_data->serdes_mux = current_serdes; + + if (need_reset == 1) { + printf("Reset board to enable configuration\n"); + cpld_data->system_rst = CONFIG_RESET; + } +} + int config_serdes_mux(void) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); @@ -584,7 +623,8 @@ u16 flash_read16(void *addr) return (((val) >> 8) & 0x00ff) | (((val) << 8) & 0xff00); }
-#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) \ + && !defined(CONFIG_SPL_BUILD) static void convert_flash_bank(char bank) { struct cpld_data *cpld_data = (void *)(CONFIG_SYS_CPLD_BASE); @@ -645,48 +685,7 @@ U_BOOT_CMD(
-static void convert_serdes_mux(int type, int need_reset) -{ - char current_serdes; - struct cpld_data *cpld_data = (void *)(CONFIG_SYS_CPLD_BASE); - - current_serdes = cpld_data->serdes_mux; - - switch (type) { - case LANEB_SATA: - current_serdes &= ~MASK_LANE_B; - break; - case LANEB_SGMII1: - current_serdes |= (MASK_LANE_B | MASK_SGMII | MASK_LANE_C); - break; - case LANEC_SGMII1: - current_serdes &= ~(MASK_LANE_B | MASK_SGMII | MASK_LANE_C); - break; - case LANED_SGMII2: - current_serdes |= MASK_LANE_D; - break; - case LANEC_PCIEX1: - current_serdes |= MASK_LANE_C; - break; - case (LANED_PCIEX2 | LANEC_PCIEX1): - current_serdes |= MASK_LANE_C; - current_serdes &= ~MASK_LANE_D; - break; - default: - printf("CPLD serdes MUX: unsupported MUX type 0x%x\n", type); - return; - } - - cpld_data->soft_mux_on |= CPLD_SET_MUX_SERDES; - cpld_data->serdes_mux = current_serdes; - - if (need_reset == 1) { - printf("Reset board to enable configuration\n"); - cpld_data->system_rst = CONFIG_RESET; - } -} - -void print_serdes_mux(void) +static void print_serdes_mux(void) { char current_serdes; struct cpld_data *cpld_data = (void *)(CONFIG_SYS_CPLD_BASE);
Reviewed-by: Alison Wang alison.wang@nxp.com Tested-by: Alison Wang alison.wang@nxp.com
Best Regards, Alison Wang
Minor change to commit message. Applied to fsl-qoriq master. Thanks.
York
Alison Wang
York Sun
