[U-Boot] [PATCH 1/3] configs: kirkwood: Convert Allied Telesis boards to DM_SPI
Enable CONFIG_DM_SPI=y and CONFIG_DM_SPI_FLASH=y in the defconfig.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
configs/SBx81LIFKW_defconfig | 2 ++ configs/SBx81LIFXCAT_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index 99526c185e20..e0ce1595c5ee 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -28,6 +28,7 @@ CONFIG_SYS_I2C_MVTWSI=y CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y # CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set @@ -40,4 +41,5 @@ CONFIG_MII=y CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index a0abe23ed328..4a6e05844fec 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -32,6 +32,7 @@ CONFIG_I2C_MUX_PCA954x=y CONFIG_LED=y CONFIG_LED_GPIO=y # CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set @@ -42,4 +43,5 @@ CONFIG_MV88E61XX_PHY_PORTS=0x003 CONFIG_MV88E61XX_FIXED_PORTS=0x300 CONFIG_MII=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y
configs/ds109_defconfig | 2 ++ include/configs/ds109.h | 1 - 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 23f1886a249a..352403e57385 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -23,6 +23,7 @@ CONFIG_MVSATA_IDE=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y @@ -32,6 +33,7 @@ CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/include/configs/ds109.h b/include/configs/ds109.h index c06f0058deb5..2c7928e88c1c 100644 --- a/include/configs/ds109.h +++ b/include/configs/ds109.h @@ -38,7 +38,6 @@ #endif
#ifdef CONFIG_CMD_SF -#define CONFIG_HARD_SPI 1 #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 50000000 /* 50 MHz */
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
configs/dreamplug_defconfig | 2 ++ include/configs/dreamplug.h | 1 - 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 76c768006d35..d3263cf9cd3f 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -26,6 +26,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_MVGBE=y @@ -34,6 +35,7 @@ CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y CONFIG_SPI=y +CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index 1c94bf9fa1bf..f4d717213ce1 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -35,7 +35,6 @@ #endif
Thanks, Stefan
Thanks, Stefan
Thanks, Stefan
Thanks, Stefan
Chris Packham
Stefan Roese
