[U-Boot] [PATCH] ata: ahci: drop read-only ahci_ioports members
Also get rid of ahci_setup_port(..).
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- drivers/ata/ahci.c | 12 ------------ include/ahci.h | 2 -- 2 files changed, 14 deletions(-)
diff --git a/drivers/ata/ahci.c b/drivers/ata/ahci.c index 188d843197..e3135bb75f 100644 --- a/drivers/ata/ahci.c +++ b/drivers/ata/ahci.c @@ -55,17 +55,6 @@ __weak void __iomem *ahci_port_base(void __iomem *base, u32 port) return base + 0x100 + (port * 0x80); }
- -static void ahci_setup_port(struct ahci_ioports *port, void __iomem *base, - unsigned int port_idx) -{ - base = ahci_port_base(base, port_idx); - - port->cmd_addr = base; - port->scr_addr = base + PORT_SCR; -} - - #define msleep(a) udelay(a * 1000)
static void ahci_dcache_flush_range(unsigned long begin, unsigned long len) @@ -240,7 +229,6 @@ static int ahci_host_init(struct ahci_uc_priv *uc_priv) continue; uc_priv->port[i].port_mmio = ahci_port_base(mmio, i); port_mmio = (u8 *)uc_priv->port[i].port_mmio; - ahci_setup_port(&uc_priv->port[i], mmio, i);
/* make sure port is not active */ tmp = readl(port_mmio + PORT_CMD); diff --git a/include/ahci.h b/include/ahci.h index b42df6c77e..fb96dd8861 100644 --- a/include/ahci.h +++ b/include/ahci.h @@ -134,8 +134,6 @@ struct ahci_sg { };
struct ahci_ioports { - void __iomem *cmd_addr; - void __iomem *scr_addr; void __iomem *port_mmio; struct ahci_cmd_hdr *cmd_slot; struct ahci_sg *cmd_tbl_sg;
On Tue, 14 May 2019 at 02:33, Christian Gmeiner christian.gmeiner@gmail.com wrote:
Christian Gmeiner
