[U-Boot] [PATCH] Fix DM9000 MAC address handling
Proper behavior is to pull MAC address from NVRAM in the initialization() and stuff it in dev->address, then program the device from dev->address in the init() function.
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- drivers/net/dm9000x.c | 27 +++++++++++++++------------ 1 files changed, 15 insertions(+), 12 deletions(-)
diff --git a/drivers/net/dm9000x.c b/drivers/net/dm9000x.c index efe9135..d89488e 100644 --- a/drivers/net/dm9000x.c +++ b/drivers/net/dm9000x.c @@ -284,7 +284,6 @@ static int dm9000_init(struct eth_device *dev, bd_t *bd) int i, oft, lnk; u8 io_mode; struct board_info *db = &dm9000_info; - uchar enetaddr[6];
DM9000_DBG("%s\n", __func__);
@@ -342,20 +341,11 @@ static int dm9000_init(struct eth_device *dev, bd_t *bd) /* Clear interrupt status */ DM9000_iow(DM9000_ISR, ISR_ROOS | ISR_ROS | ISR_PTS | ISR_PRS);
- /* Set Node address */ - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { -#if !defined(CONFIG_DM9000_NO_SROM) - for (i = 0; i < 3; i++) - dm9000_read_srom_word(i, enetaddr + 2 * i); - eth_setenv_enetaddr("ethaddr", enetaddr); -#endif - } - - printf("MAC: %pM\n", enetaddr); + printf("MAC: %pM\n", dev->enetaddr);
/* fill device MAC address registers */ for (i = 0, oft = DM9000_PAR; i < 6; i++, oft++) - DM9000_iow(oft, enetaddr[i]); + DM9000_iow(oft, dev->enetaddr[i]); for (i = 0, oft = 0x16; i < 8; i++, oft++) DM9000_iow(oft, 0xff);
@@ -558,6 +548,16 @@ void dm9000_write_srom_word(int offset, u16 val) } #endif
+void dm9000_get_enetaddr(struct eth_device *dev) +{ +#if !defined(CONFIG_DM9000_NO_SROM) + int i; + for (i = 0; i < 3; i++) { + dm9000_read_srom_word(i, dev->enetaddr + (2 * i)); + } +#endif +} + /* Read a byte from I/O port */ @@ -621,6 +621,9 @@ int dm9000_initialize(bd_t *bis) { struct eth_device *dev = &(dm9000_info.netdev);
+ /* Load MAC address from EEPROM */ + dm9000_get_enetaddr(dev); + dev->init = dm9000_init; dev->halt = dm9000_halt; dev->send = dm9000_send;
static ?
- int i;
- for (i = 0; i < 3; i++) {
dont need the braces ... -mike
static ?
Yeah, this was thrown together pretty quickly...
- int i;
OK
-mike
thanks for the review, Ben
Ben Warren
Mike Frysinger
