[U-Boot-Users] [PATCH 2/3] Migrate esd 405EP boards to new NAND subsystem
-cleanup -use correct io accessors (in/out_be32())
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com
--- commit c170c46a2eb53855ede1b84c0a58c9029fa54279 tree c224017237869ba2d339e7babc55968260f83106 parent aa6e97ca6365f942967f2d062dc6b3998348eb2c author Matthias Fuchs matthias.fuchs@esd-electronics.com Mon, 09 Jul 2007 09:57:17 +0200 committer Matthias Fuchs matthias.fuchs@esd-electronics.com Mon, 09 Jul 2007 09:57:17 +0200
board/esd/ash405/Makefile | 4 ++- board/esd/ash405/ash405.c | 43 +++++++++------------------------- board/esd/cms700/Makefile | 5 +++- board/esd/cms700/cms700.c | 39 ++++++------------------------- board/esd/hh405/Makefile | 5 +++- board/esd/hh405/hh405.c | 22 +---------------- board/esd/hub405/Makefile | 4 ++- board/esd/hub405/hub405.c | 34 --------------------------- board/esd/plu405/Makefile | 5 +++- board/esd/plu405/plu405.c | 56 +++++++------------------------------------- board/esd/voh405/Makefile | 4 ++- board/esd/voh405/voh405.c | 20 ---------------- board/esd/wuh405/Makefile | 4 ++- board/esd/wuh405/wuh405.c | 33 -------------------------- include/configs/ASH405.h | 43 +++++++++------------------------- include/configs/CMS700.h | 39 +++++++------------------------ include/configs/HH405.h | 39 +++++++------------------------ include/configs/HUB405.h | 39 +++++++------------------------ include/configs/PLU405.h | 57 +++++++-------------------------------------- include/configs/VOH405.h | 39 +++++++------------------------ include/configs/WUH405.h | 42 ++++++++------------------------- 21 files changed, 120 insertions(+), 456 deletions(-)
diff --git a/board/esd/ash405/Makefile b/board/esd/ash405/Makefile index 4d75868..308f752 100644 --- a/board/esd/ash405/Makefile +++ b/board/esd/ash405/Makefile @@ -28,7 +28,9 @@ endif
LIB = $(obj)lib$(BOARD).a
-COBJS = $(BOARD).o flash.o ../common/misc.o +COBJS = $(BOARD).o flash.o \ + ../common/misc.o \ + ../common/esd405ep_nand.o \
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/esd/ash405/ash405.c b/board/esd/ash405/ash405.c index 84fc3a0..ba99b22 100644 --- a/board/esd/ash405/ash405.c +++ b/board/esd/ash405/ash405.c @@ -23,6 +23,7 @@
#include <common.h> #include <asm/processor.h> +#include <asm/io.h> #include <command.h> #include <malloc.h>
@@ -33,6 +34,7 @@ #endif
extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); +extern void lxt971_no_sleep(void);
/* fpga configuration data - gzip compressed and generated by bin2c */ const unsigned char fpgadata[] = @@ -164,18 +166,12 @@ int misc_init_r (void) /* * Reset external DUARTs */ - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_DUART_RST); /* set reset to high */ + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | CFG_DUART_RST); udelay(10); /* wait 10us */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_DUART_RST); /* set reset to low */ + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) & ~CFG_DUART_RST); udelay(1000); /* wait 1ms */
/* - * Set NAND-FLASH GPIO signals to default - */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~(CFG_NAND_CLE | CFG_NAND_ALE)); - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE); - - /* * Enable interrupts in exar duart mcr[3] */ *duart0_mcr = 0x08; @@ -218,35 +214,18 @@ long int initdram (int board_type) mtdcr(memcfga, mem_mb0cf); val = mfdcr(memcfgd);
-#if 0 - printf("\nmb0cf=%x\n", val); /* test-only */ - printf("strap=%x\n", mfdcr(strap)); /* test-only */ -#endif - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); }
-int testdram (void) +void reset_phy(void) { - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} +#ifdef CONFIG_LXT971_NO_SLEEP
-/* ------------------------------------------------------------------------- */ - -#if (CONFIG_COMMANDS & CFG_CMD_NAND) -#include <linux/mtd/nand_legacy.h> -extern struct nand_chip nand_dev_desc[CFG_MAX_NAND_DEVICE]; - -void nand_init(void) -{ - nand_probe(CFG_NAND_BASE); - if (nand_dev_desc[0].ChipID != NAND_ChipID_UNKNOWN) { - print_size(nand_dev_desc[0].totlen, "\n"); - } -} + /* + * Disable sleep mode in LXT971 + */ + lxt971_no_sleep(); #endif +} diff --git a/board/esd/cms700/Makefile b/board/esd/cms700/Makefile index df48766..0d4ab2d 100644 --- a/board/esd/cms700/Makefile +++ b/board/esd/cms700/Makefile @@ -33,7 +33,10 @@ CPLD = ../common/xilinx_jtag/lenval.o ../common/xilinx_jtag/micro.o \ ../common/xilinx_jtag/ports.o
-COBJS = $(BOARD).o flash.o ../common/misc.o $(CPLD) +COBJS = $(BOARD).o flash.o \ + ../common/misc.o \ + $(CPLD) \ + ../common/esd405ep_nand.o \
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/esd/cms700/cms700.c b/board/esd/cms700/cms700.c index cb04710..81de5b2 100644 --- a/board/esd/cms700/cms700.c +++ b/board/esd/cms700/cms700.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2005 + * (C) Copyright 2005-2007 * Matthias Fuchs, esd gmbh germany, matthias.fuchs@esd-electronics.com * * See file CREDITS for list of people who contributed to this @@ -23,6 +23,7 @@
@@ -68,9 +69,9 @@ int board_early_init_f (void) /* * Reset CPLD via GPIO12 (CS3) pin */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_PLD_RESET); + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) & ~CFG_PLD_RESET); udelay(1000); /* wait 1ms */ - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_PLD_RESET); + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | CFG_PLD_RESET); udelay(1000); /* wait 1ms */
return 0; @@ -94,13 +95,7 @@ int misc_init_r (void) /* * Setup and enable EEPROM write protection */ - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_EEPROM_WP); - - /* - * Set NAND-FLASH GPIO signals to default - */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~(CFG_NAND_CLE | CFG_NAND_ALE)); - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE); + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | CFG_EEPROM_WP);
return (0); } @@ -153,11 +148,6 @@ long int initdram (int board_type) mtdcr(memcfga, mem_mb0cf); val = mfdcr(memcfgd);
@@ -180,17 +170,17 @@ int eeprom_write_enable (unsigned dev_ad switch (state) { case 1: /* Enable write access, clear bit GPIO_SINT2. */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_EEPROM_WP); + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) & ~CFG_EEPROM_WP); state = 0; break; case 0: /* Disable write access, set bit GPIO_SINT2. */ - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_EEPROM_WP); + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | CFG_EEPROM_WP); state = 0; break; default: /* Read current status back. */ - state = (0 == (in32(GPIO0_OR) & CFG_EEPROM_WP)); + state = (0 == (in_be32((void*)GPIO0_OR) & CFG_EEPROM_WP)); break; } } @@ -235,19 +225,6 @@ U_BOOT_CMD(eepwren, 2, 0, do_eep_wren,
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) -#include <linux/mtd/nand_legacy.h> -extern struct nand_chip nand_dev_desc[CFG_MAX_NAND_DEVICE]; - -void nand_init(void) -{ - nand_probe(CFG_NAND_BASE); - if (nand_dev_desc[0].ChipID != NAND_ChipID_UNKNOWN) { - print_size(nand_dev_desc[0].totlen, "\n"); - } -} -#endif - void reset_phy(void) { #ifdef CONFIG_LXT971_NO_SLEEP diff --git a/board/esd/hh405/Makefile b/board/esd/hh405/Makefile index ce7876c..0e5e57a 100644 --- a/board/esd/hh405/Makefile +++ b/board/esd/hh405/Makefile @@ -28,7 +28,10 @@ endif
-COBJS = $(BOARD).o flash.o ../common/misc.o ../common/auto_update.o +COBJS = $(BOARD).o flash.o \ + ../common/misc.o \ + ../common/esd405ep_nand.o \ + ../common/auto_update.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/esd/hh405/hh405.c b/board/esd/hh405/hh405.c index ea344c0..67b5d54 100644 --- a/board/esd/hh405/hh405.c +++ b/board/esd/hh405/hh405.c @@ -5,7 +5,7 @@ * (C) Copyright 2005 * Stefan Roese, DENX Software Engineering, sr@denx.de. * - * (C) Copyright 2006 + * (C) Copyright 2006-2007 * Matthias Fuchs, esd GmbH, matthias.fuchs@esd-electronics.com * * See file CREDITS for list of people who contributed to this @@ -477,12 +477,6 @@ int misc_init_r (void) out32(GPIO0_OR, in32(GPIO0_OR) | CFG_EEPROM_WP);
/* - * Set NAND-FLASH GPIO signals to default - */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~(CFG_NAND_CLE | CFG_NAND_ALE)); - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE); - - /* * Reset touch-screen controller */ out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_TOUCH_RST); @@ -690,20 +684,6 @@ void ide_set_reset(int on) #endif /* CONFIG_IDE_RESET */
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) -#include <linux/mtd/nand_legacy.h> -extern struct nand_chip nand_dev_desc[CFG_MAX_NAND_DEVICE]; - -void nand_init(void) -{ - nand_probe(CFG_NAND_BASE); - if (nand_dev_desc[0].ChipID != NAND_ChipID_UNKNOWN) { - print_size(nand_dev_desc[0].totlen, "\n"); - } -} -#endif - - #if defined(CFG_EEPROM_WREN) /* Input: <dev_addr> I2C address of EEPROM device to enable. * <state> -1: deliver current state diff --git a/board/esd/hub405/Makefile b/board/esd/hub405/Makefile index 4d75868..308f752 100644 --- a/board/esd/hub405/Makefile +++ b/board/esd/hub405/Makefile @@ -28,7 +28,9 @@ endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/esd/hub405/hub405.c b/board/esd/hub405/hub405.c index 1e0accb..25c8068 100644 --- a/board/esd/hub405/hub405.c +++ b/board/esd/hub405/hub405.c @@ -153,12 +153,6 @@ int misc_init_r (void) out32(GPIO0_OR, val);
/* - * Set NAND-FLASH GPIO signals to default - */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~(CFG_NAND_CLE | CFG_NAND_ALE)); - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE); - - /* * check board type and setup AP power */ str = getenv("bd_type"); /* this is only set on non prototype hardware */ @@ -242,33 +236,5 @@ long int initdram (int board_type) mtdcr(memcfga, mem_mb0cf); val = mfdcr(memcfgd);
-#if 0 - printf("\nmb0cf=%x\n", val); /* test-only */ - printf("strap=%x\n", mfdcr(strap)); /* test-only */ -#endif - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); } - - -int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} - - -#if (CONFIG_COMMANDS & CFG_CMD_NAND) -#include <linux/mtd/nand_legacy.h> -extern struct nand_chip nand_dev_desc[CFG_MAX_NAND_DEVICE]; - -void nand_init(void) -{ - nand_probe(CFG_NAND_BASE); - if (nand_dev_desc[0].ChipID != NAND_ChipID_UNKNOWN) { - print_size(nand_dev_desc[0].totlen, "\n"); - } -} -#endif diff --git a/board/esd/plu405/Makefile b/board/esd/plu405/Makefile index ce7876c..0e5e57a 100644 --- a/board/esd/plu405/Makefile +++ b/board/esd/plu405/Makefile @@ -28,7 +28,10 @@ endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/esd/plu405/plu405.c b/board/esd/plu405/plu405.c index 59171f8..3494678 100644 --- a/board/esd/plu405/plu405.c +++ b/board/esd/plu405/plu405.c @@ -23,6 +23,7 @@
@@ -31,6 +32,8 @@ #define FPGA_DEBUG #endif
+DECLARE_GLOBAL_DATA_PTR; + extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); extern void lxt971_no_sleep(void);
@@ -114,6 +117,10 @@ int misc_init_r (void) int index; int i;
+ /* adjust flash start and offset */ + gd->bd->bi_flashstart = 0 - gd->bd->bi_flashsize; + gd->bd->bi_flashoffset = 0; + dst = malloc(CFG_FPGA_MAX_SIZE); if (gunzip (dst, CFG_FPGA_MAX_SIZE, (uchar *)fpgadata, &len) != 0) { printf ("GUNZIP ERROR - must RESET board to recover\n"); @@ -177,18 +184,12 @@ int misc_init_r (void) /* * Reset external DUARTs */ - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_DUART_RST); /* set reset to high */ + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) | CFG_DUART_RST); udelay(10); /* wait 10us */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_DUART_RST); /* set reset to low */ + out_be32((void*)GPIO0_OR, in_be32((void*)GPIO0_OR) & ~CFG_DUART_RST); udelay(1000); /* wait 1ms */
/* - * Set NAND-FLASH GPIO signals to default - */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~(CFG_NAND_CLE | CFG_NAND_ALE)); - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE); - - /* * Enable interrupts in exar duart mcr[3] */ *duart0_mcr = 0x08; @@ -226,24 +227,10 @@ long int initdram (int board_type) mtdcr(memcfga, mem_mb0cf); val = mfdcr(memcfgd);
-int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} - - #ifdef CONFIG_IDE_RESET void ide_set_reset(int on) { @@ -262,31 +249,6 @@ void ide_set_reset(int on) #endif /* CONFIG_IDE_RESET */
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) -#include <linux/mtd/nand_legacy.h> -extern struct nand_chip nand_dev_desc[CFG_MAX_NAND_DEVICE]; - -void nand_init(void) -{ - nand_probe(CFG_NAND_BASE); - if (nand_dev_desc[0].ChipID != NAND_ChipID_UNKNOWN) { - print_size(nand_dev_desc[0].totlen, "\n"); - } -} -#endif - - -#ifdef CONFIG_AUTO_UPDATE_SHOW -void board_auto_update_show(int au_active) -{ - if (au_active) { - printf("\n Dies ist die board-funktion: Updating!!!\n"); - } else { - printf("\n Dies ist die board-funktion: Updating done!!!\n"); - } -} -#endif - void reset_phy(void) { #ifdef CONFIG_LXT971_NO_SLEEP diff --git a/board/esd/voh405/Makefile b/board/esd/voh405/Makefile index 4d75868..308f752 100644 --- a/board/esd/voh405/Makefile +++ b/board/esd/voh405/Makefile @@ -28,7 +28,9 @@ endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/esd/voh405/voh405.c b/board/esd/voh405/voh405.c index 22995b5..2857a0b 100644 --- a/board/esd/voh405/voh405.c +++ b/board/esd/voh405/voh405.c @@ -195,12 +195,6 @@ int misc_init_r (void) udelay(1000); /* wait 1ms */
/* - * Set NAND-FLASH GPIO signals to default - */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~(CFG_NAND_CLE | CFG_NAND_ALE)); - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE); - - /* * Enable interrupts in exar duart mcr[3] */ *duart0_mcr = 0x08; @@ -340,17 +334,3 @@ void ide_set_reset(int on) } } #endif /* CONFIG_IDE_RESET */ - - -#if (CONFIG_COMMANDS & CFG_CMD_NAND) -#include <linux/mtd/nand_legacy.h> -extern struct nand_chip nand_dev_desc[CFG_MAX_NAND_DEVICE]; - -void nand_init(void) -{ - nand_probe(CFG_NAND_BASE); - if (nand_dev_desc[0].ChipID != NAND_ChipID_UNKNOWN) { - print_size(nand_dev_desc[0].totlen, "\n"); - } -} -#endif diff --git a/board/esd/wuh405/Makefile b/board/esd/wuh405/Makefile index 4d75868..308f752 100644 --- a/board/esd/wuh405/Makefile +++ b/board/esd/wuh405/Makefile @@ -28,7 +28,9 @@ endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/esd/wuh405/wuh405.c b/board/esd/wuh405/wuh405.c index 5a1a3f3..0b53062 100644 --- a/board/esd/wuh405/wuh405.c +++ b/board/esd/wuh405/wuh405.c @@ -170,12 +170,6 @@ int misc_init_r (void) udelay(1000); /* wait 1ms */
/* - * Set NAND-FLASH GPIO signals to default - */ - out32(GPIO0_OR, in32(GPIO0_OR) & ~(CFG_NAND_CLE | CFG_NAND_ALE)); - out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE); - - /* * Enable interrupts in exar duart mcr[3] */ *duart0_mcr = 0x08; @@ -218,35 +212,8 @@ long int initdram (int board_type) mtdcr(memcfga, mem_mb0cf); val = mfdcr(memcfgd);
-int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} - -/* ------------------------------------------------------------------------- */ - -#if (CONFIG_COMMANDS & CFG_CMD_NAND) -#include <linux/mtd/nand_legacy.h> -extern struct nand_chip nand_dev_desc[CFG_MAX_NAND_DEVICE]; - -void nand_init(void) -{ - nand_probe(CFG_NAND_BASE); - if (nand_dev_desc[0].ChipID != NAND_ChipID_UNKNOWN) { - print_size(nand_dev_desc[0].totlen, "\n"); - } -} -#endif diff --git a/include/configs/ASH405.h b/include/configs/ASH405.h index d03c05b..584f490 100644 --- a/include/configs/ASH405.h +++ b/include/configs/ASH405.h @@ -53,9 +53,13 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
+#define CONFIG_NET_MULTI 1 +#undef CONFIG_HAS_ETH1 + #define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_PHY_ADDR 0 /* PHY address */ #define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ +#define CONFIG_RESET_PHY_R 1 /* use reset_phy() to disable phy sleep mode */
#define CONFIG_PHY_CLK_FREQ EMAC_STACR_CLK_66MHZ /* 66 MHz OPB clock*/
@@ -132,39 +136,16 @@ * NAND-FLASH stuff *----------------------------------------------------------------------- */ +#define CFG_NAND_BASE_LIST { CFG_NAND_BASE } +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_BIG_DELAY_US 25
-#define CFG_NAND_LEGACY - -#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#define SECTORSIZE 512 - -#define ADDR_COLUMN 1 -#define ADDR_PAGE 2 -#define ADDR_COLUMN_PAGE 3 - -#define NAND_ChipID_UNKNOWN 0x00 -#define NAND_MAX_FLOORS 1 -#define NAND_MAX_CHIPS 1 - -#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ -#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ -#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */ -#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ - -#define NAND_DISABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE);} while(0) -#define NAND_ENABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CE);} while(0) -#define NAND_CTL_CLRALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_ALE);} while(0) -#define NAND_CTL_SETALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_ALE);} while(0) -#define NAND_CTL_CLRCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CLE);} while(0) -#define NAND_CTL_SETCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CLE);} while(0) -#define NAND_WAIT_READY(nand) while (!(in32(GPIO0_IR) & CFG_NAND_RDY)) - -#define WRITE_NAND_COMMAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND_ADDRESS(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)d; } while(0) -#define READ_NAND(adr) ((volatile unsigned char)(*(volatile __u8 *)(unsigned long)adr)) +#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ +#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ +#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ +#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */
-#define CONFIG_MTD_NAND_VERIFY_WRITE 1 /* verify all writes!!! */ #define CFG_NAND_SKIP_BAD_DOT_I 1 /* ".i" read skips bad blocks */
/*----------------------------------------------------------------------- diff --git a/include/configs/CMS700.h b/include/configs/CMS700.h index 1cca285..9695211 100644 --- a/include/configs/CMS700.h +++ b/include/configs/CMS700.h @@ -81,8 +81,6 @@ /* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ #include <cmd_confdefs.h>
-#define CFG_NAND_LEGACY - #undef CONFIG_WATCHDOG /* watchdog disabled */
#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ @@ -148,34 +146,15 @@ * NAND-FLASH stuff *----------------------------------------------------------------------- */ -#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#define SECTORSIZE 512 - -#define ADDR_COLUMN 1 -#define ADDR_PAGE 2 -#define ADDR_COLUMN_PAGE 3 - -#define NAND_ChipID_UNKNOWN 0x00 -#define NAND_MAX_FLOORS 1 -#define NAND_MAX_CHIPS 1 - -#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ -#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ -#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */ -#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ - -#define NAND_DISABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE);} while(0) -#define NAND_ENABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CE);} while(0) -#define NAND_CTL_CLRALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_ALE);} while(0) -#define NAND_CTL_SETALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_ALE);} while(0) -#define NAND_CTL_CLRCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CLE);} while(0) -#define NAND_CTL_SETCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CLE);} while(0) -#define NAND_WAIT_READY(nand) while (!(in32(GPIO0_IR) & CFG_NAND_RDY)) - -#define WRITE_NAND_COMMAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND_ADDRESS(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)d; } while(0) -#define READ_NAND(adr) ((volatile unsigned char)(*(volatile __u8 *)(unsigned long)adr)) +#define CFG_NAND_BASE_LIST { CFG_NAND_BASE } +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_BIG_DELAY_US 25 + +#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ +#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ +#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ +#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */
diff --git a/include/configs/HH405.h b/include/configs/HH405.h index dc40ebc..f36777a 100644 --- a/include/configs/HH405.h +++ b/include/configs/HH405.h @@ -130,8 +130,6 @@ /* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ #include <cmd_confdefs.h>
-#define CFG_NAND_LEGACY - #undef CONFIG_BZIP2 /* include support for bzip2 compressed images */ #undef CONFIG_WATCHDOG /* watchdog disabled */
@@ -198,34 +196,15 @@ * NAND-FLASH stuff *----------------------------------------------------------------------- */ -#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#define SECTORSIZE 512 - -#define ADDR_COLUMN 1 -#define ADDR_PAGE 2 -#define ADDR_COLUMN_PAGE 3 - -#define NAND_ChipID_UNKNOWN 0x00 -#define NAND_MAX_FLOORS 1 -#define NAND_MAX_CHIPS 1 - -#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ -#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ -#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */ -#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ - -#define NAND_DISABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE);} while(0) -#define NAND_ENABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CE);} while(0) -#define NAND_CTL_CLRALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_ALE);} while(0) -#define NAND_CTL_SETALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_ALE);} while(0) -#define NAND_CTL_CLRCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CLE);} while(0) -#define NAND_CTL_SETCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CLE);} while(0) -#define NAND_WAIT_READY(nand) while (!(in32(GPIO0_IR) & CFG_NAND_RDY)) - -#define WRITE_NAND_COMMAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND_ADDRESS(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)d; } while(0) -#define READ_NAND(adr) ((volatile unsigned char)(*(volatile __u8 *)(unsigned long)adr)) +#define CFG_NAND_BASE_LIST { CFG_NAND_BASE } +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_BIG_DELAY_US 25 + +#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ +#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ +#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ +#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */
diff --git a/include/configs/HUB405.h b/include/configs/HUB405.h index f84e356..88cc6a4 100644 --- a/include/configs/HUB405.h +++ b/include/configs/HUB405.h @@ -135,36 +135,15 @@ * NAND-FLASH stuff *----------------------------------------------------------------------- */ -#define CFG_NAND_LEGACY - -#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#define SECTORSIZE 512 - -#define ADDR_COLUMN 1 -#define ADDR_PAGE 2 -#define ADDR_COLUMN_PAGE 3 - -#define NAND_ChipID_UNKNOWN 0x00 -#define NAND_MAX_FLOORS 1 -#define NAND_MAX_CHIPS 1 - -#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ -#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ -#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */ -#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ - -#define NAND_DISABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE);} while(0) -#define NAND_ENABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CE);} while(0) -#define NAND_CTL_CLRALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_ALE);} while(0) -#define NAND_CTL_SETALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_ALE);} while(0) -#define NAND_CTL_CLRCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CLE);} while(0) -#define NAND_CTL_SETCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CLE);} while(0) -#define NAND_WAIT_READY(nand) while (!(in32(GPIO0_IR) & CFG_NAND_RDY)) - -#define WRITE_NAND_COMMAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND_ADDRESS(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)d; } while(0) -#define READ_NAND(adr) ((volatile unsigned char)(*(volatile __u8 *)(unsigned long)adr)) +#define CFG_NAND_BASE_LIST { CFG_NAND_BASE } +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_BIG_DELAY_US 25 + +#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ +#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ +#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ +#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */
diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index d02c39b..ef5ecba 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -81,7 +81,6 @@ #define CONFIG_SUPPORT_VFAT
#define CONFIG_AUTO_UPDATE 1 /* autoupdate via compactflash */ -#define CONFIG_AUTO_UPDATE_SHOW 1 /* use board show routine */
/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ #include <cmd_confdefs.h> @@ -156,36 +155,15 @@ * NAND-FLASH stuff *----------------------------------------------------------------------- */ -#define CFG_NAND_LEGACY +#define CFG_NAND_BASE_LIST { CFG_NAND_BASE } +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_BIG_DELAY_US 25
@@ -264,11 +242,6 @@
#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
-#if 0 /* test-only */ -#define CFG_JFFS2_FIRST_BANK 0 /* use for JFFS2 */ -#define CFG_JFFS2_NUM_BANKS 1 /* ! second bank contains U-Boot */ -#endif - /*----------------------------------------------------------------------- * Start addresses for the final memory configuration * (Set up by the startup code) @@ -294,9 +267,6 @@ #define CFG_ENV_SIZE 0x700 /* 2048 bytes may be used for env vars*/ /* total size of a CAT24WC16 is 2048 bytes */
-#define CFG_NVRAM_BASE_ADDR 0xF0000500 /* NVRAM base address */ -#define CFG_NVRAM_SIZE 242 /* NVRAM size */ - /*----------------------------------------------------------------------- * I2C EEPROM (CAT24WC16) for environment */ @@ -305,7 +275,7 @@ #define CFG_I2C_SLAVE 0x7F
#define CFG_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT24WC08 */ -#if 1 /* test-only */ + /* CAT24WC08/16... */ #define CFG_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ /* mask of address bits that overflow into the "EEPROM chip address" */ @@ -313,15 +283,6 @@ #define CFG_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ /* 16 byte page write mode using*/ /* last 4 bits of the address */ -#else -/* CAT24WC32/64... */ -#define CFG_I2C_EEPROM_ADDR_LEN 2 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x01 -#define CFG_EEPROM_PAGE_WRITE_BITS 5 /* The Catalyst CAT24WC32 has */ - /* 32 byte page write mode using*/ - /* last 5 bits of the address */ -#endif #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ #define CFG_EEPROM_PAGE_WRITE_ENABLE
diff --git a/include/configs/VOH405.h b/include/configs/VOH405.h index 96f3d26..abd1ef4 100644 --- a/include/configs/VOH405.h +++ b/include/configs/VOH405.h @@ -141,36 +141,15 @@ * NAND-FLASH stuff *----------------------------------------------------------------------- */ -#define CFG_NAND_LEGACY - -#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#define SECTORSIZE 512 - -#define ADDR_COLUMN 1 -#define ADDR_PAGE 2 -#define ADDR_COLUMN_PAGE 3 - -#define NAND_ChipID_UNKNOWN 0x00 -#define NAND_MAX_FLOORS 1 -#define NAND_MAX_CHIPS 1 - -#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ -#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ -#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */ -#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ - -#define NAND_DISABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE);} while(0) -#define NAND_ENABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CE);} while(0) -#define NAND_CTL_CLRALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_ALE);} while(0) -#define NAND_CTL_SETALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_ALE);} while(0) -#define NAND_CTL_CLRCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CLE);} while(0) -#define NAND_CTL_SETCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CLE);} while(0) -#define NAND_WAIT_READY(nand) while (!(in32(GPIO0_IR) & CFG_NAND_RDY)) - -#define WRITE_NAND_COMMAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND_ADDRESS(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)d; } while(0) -#define READ_NAND(adr) ((volatile unsigned char)(*(volatile __u8 *)(unsigned long)adr)) +#define CFG_NAND_BASE_LIST { CFG_NAND_BASE } +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_BIG_DELAY_US 25 + +#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ +#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ +#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ +#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */
diff --git a/include/configs/WUH405.h b/include/configs/WUH405.h index faf855d..52bff40 100644 --- a/include/configs/WUH405.h +++ b/include/configs/WUH405.h @@ -133,38 +133,16 @@ * NAND-FLASH stuff *----------------------------------------------------------------------- */ -#define CFG_NAND_LEGACY - -#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#define SECTORSIZE 512 - -#define ADDR_COLUMN 1 -#define ADDR_PAGE 2 -#define ADDR_COLUMN_PAGE 3 - -#define NAND_ChipID_UNKNOWN 0x00 -#define NAND_MAX_FLOORS 1 -#define NAND_MAX_CHIPS 1 - -#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ -#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ -#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */ -#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ - -#define NAND_DISABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CE);} while(0) -#define NAND_ENABLE_CE(nand) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CE);} while(0) -#define NAND_CTL_CLRALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_ALE);} while(0) -#define NAND_CTL_SETALE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_ALE);} while(0) -#define NAND_CTL_CLRCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) & ~CFG_NAND_CLE);} while(0) -#define NAND_CTL_SETCLE(nandptr) do { out32(GPIO0_OR, in32(GPIO0_OR) | CFG_NAND_CLE);} while(0) -#define NAND_WAIT_READY(nand) while (!(in32(GPIO0_IR) & CFG_NAND_RDY)) - -#define WRITE_NAND_COMMAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND_ADDRESS(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)(d); } while(0) -#define WRITE_NAND(d, adr) do{ *(volatile __u8 *)((unsigned long)adr) = (__u8)d; } while(0) -#define READ_NAND(adr) ((volatile unsigned char)(*(volatile __u8 *)(unsigned long)adr)) - -#define CONFIG_MTD_NAND_VERIFY_WRITE 1 /* verify all writes!!! */ +#define CFG_NAND_BASE_LIST { CFG_NAND_BASE } +#define NAND_MAX_CHIPS 1 +#define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_BIG_DELAY_US 25 + +#define CFG_NAND_CE (0x80000000 >> 1) /* our CE is GPIO1 */ +#define CFG_NAND_RDY (0x80000000 >> 4) /* our RDY is GPIO4 */ +#define CFG_NAND_CLE (0x80000000 >> 2) /* our CLE is GPIO2 */ +#define CFG_NAND_ALE (0x80000000 >> 3) /* our ALE is GPIO3 */ + #define CFG_NAND_SKIP_BAD_DOT_I 1 /* ".i" read skips bad blocks */
Matthias Fuchs
