[U-Boot] [PATCH v2 0/2] mtd: nand: atmel: use another functions to set gpio value
The purpose of the patch set is to use another functions to set and get the gpio value for the atmel nand driver to fix the error to set and get the gpio value after the at91 gpio driver conversion to support the driver model.
Changes in v2: - Improve the commit log. - Add Reviewed-by tag.
Wenyou Yang (2): ARM: at91: gpio: fix at91_set_gpio_value() define mtd: nand: atmel: use another functions to set gpio value
arch/arm/mach-at91/include/mach/gpio.h | 12 +++++------- drivers/mtd/nand/atmel_nand.c | 5 +++-- 2 files changed, 8 insertions(+), 9 deletions(-)
When the CONFIG_ATMEL_LEGACY is undefined, according to the following defines, at91_set_gpio_value() references to at91_set_pio_value(x, y) with two parameters. #define at91_set_gpio_value(x, y) at91_set_pio_value(x, y) #define at91_get_gpio_value(x) at91_get_pio_value(x)
But there isn't the implementation of at91_set_pio_value(x, y) with two parameters in U-Boot. This is an error.
Same as at91_get_gpio_value(x) define.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
arch/arm/mach-at91/include/mach/gpio.h | 12 +++++------- 1 file changed, 5 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-at91/include/mach/gpio.h b/arch/arm/mach-at91/include/mach/gpio.h index 5a32bdba8d..df0f71975a 100644 --- a/arch/arm/mach-at91/include/mach/gpio.h +++ b/arch/arm/mach-at91/include/mach/gpio.h @@ -223,15 +223,13 @@ static inline unsigned pin_to_mask(unsigned pin) at91_set_pio_output((x - PIN_BASE) / 32,(x % 32), y) #define at91_set_gpio_input(x, y) \ at91_set_pio_input((x - PIN_BASE) / 32,(x % 32), y) -#define at91_set_gpio_value(x, y) \ - at91_set_pio_value((x - PIN_BASE) / 32,(x % 32), y) -#define at91_get_gpio_value(x) \ - at91_get_pio_value((x - PIN_BASE) / 32,(x % 32)) -#else -#define at91_set_gpio_value(x, y) at91_set_pio_value(x, y) -#define at91_get_gpio_value(x) at91_get_pio_value(x) #endif
+#define at91_set_gpio_value(x, y) \ + at91_set_pio_value((x / 32), (x % 32), y) +#define at91_get_gpio_value(x) \ + at91_get_pio_value((x / 32), (x % 32)) + #define GPIO_PIOA_BASE (0) #define GPIO_PIOB_BASE (GPIO_PIOA_BASE + 32) #define GPIO_PIOC_BASE (GPIO_PIOB_BASE + 32)
Because there isn't the implementation of gpio_set/get_value() and gpio_set/get_value() after the at91 gpio driver is converted to support the driver model, use at91_set_gpio_value() and at91_get_gpio_value()
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Add Reviewed-by tag.
drivers/mtd/nand/atmel_nand.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 8669432deb..21d5d0e70d 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -1222,7 +1222,8 @@ static void at91_nand_hwcontrol(struct mtd_info *mtd, IO_ADDR_W |= CONFIG_SYS_NAND_MASK_ALE;
#ifdef CONFIG_SYS_NAND_ENABLE_PIN - gpio_set_value(CONFIG_SYS_NAND_ENABLE_PIN, !(ctrl & NAND_NCE)); + at91_set_gpio_value(CONFIG_SYS_NAND_ENABLE_PIN, + !(ctrl & NAND_NCE)); #endif this->IO_ADDR_W = (void *) IO_ADDR_W; } @@ -1234,7 +1235,7 @@ static void at91_nand_hwcontrol(struct mtd_info *mtd, #ifdef CONFIG_SYS_NAND_READY_PIN static int at91_nand_ready(struct mtd_info *mtd) { - return gpio_get_value(CONFIG_SYS_NAND_READY_PIN); + return at91_get_gpio_value(CONFIG_SYS_NAND_READY_PIN); } #endif
Wenyou Yang
