[U-Boot-Users] U-boot and Mathematical Library
Hi to everyone.
I have a general question: my need is to use u-boot to initialize a PowerPC 5123 and then to continue with a custom kernel without Linux. The problem is that during initialization I must drive very early a graphical controller by PCI to show some logos and I need of mathematical library; I suspect that u-boot doesn't support any. First question there exist one compatible with u-boot ? In your opinion is it possible to follow idea of import a mathematical library to boot and draw something and after continue with a custom kernel ? There is some deep technical reason to load a Linux kernel and then plot a logo ?
Thanks and best regards.
Vincenzo Scianni a écrit :
Hi to everyone.
What kind of logo display requires math? You're going to display a bitmap probably, so the only math involved would be integer arithmetic, I think. And if you have a logo in vector form, then you can convert it to bitmap (adapted to your FB format) offline and link the bitmap from, not the vector, in u-boot.
I suspect you're right.
Don't know.
No reason why you could not; but I think that's a waste of FLASH and cycles, and you'd be better of turning your logo into a simple bitmap format that u-boot possibly already understands.
No reason for this, but again, no reason (that I can see from your description) that you'd need math in the first place. Can you elaborate on the reason that makes you need math onboard rather than off-board?
Amicalement,
Hi to everyone.
Check the splashscreen support already in place (CONFIG_CMD_BMP). It supports BMPs.
Cheers Detlev
Albert ARIBAUD
Detlev Zundel
Vincenzo Scianni
