[U-Boot] [PATCH v3] powerpc/t2081qds: Add T2081 QDS board support
T2081 QDS is a high-performance computing evaluation, development and test platform supporting the T2081 QorIQ Power Architecture processor.
T2081QDS board Overview ----------------------- - T2081 SoC integrating four 64-bit dual-threads e6500 cores up to 1.8GHz - 2MB shared L2 and 512KB L3 CoreNet platform cache (CPC) - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - 32-/64-bit DDR3/DDR3LP SDRAM memory controller with ECC and interleaving - Ethernet interfaces: - Two on-board 10M/100M/1G bps RGMII ports - Two 10Gbps XFI with on-board SFP+ cage - 1Gbps/2.5Gbps SGMII Riser card - 10Gbps XAUI Riser card - Accelerator: - DPAA components consist of FMan, BMan, QMan, PME, DCE and SEC - SerDes: - 8 lanes up to 10.3125GHz - Supports SGMII, HiGig, XFI, XAUI and Aurora debug, - IFC: - 512MB NOR Flash, 2GB NAND Flash, PromJet debug port and Qixis FPGA - eSPI: - Three SPI flash (16MB N25Q128A + 16MB EN25S64 + 512KB SST25WF040) - USB: - Two USB2.0 ports with internal PHY (one Type-A + one micro Type mini-AB) - PCIe: - Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0 with SR-IOV) - eSDHC: - Supports various SD/SDHC/SDXC/eMMC devices with adapter cards and voltage translators - I2C: - Four I2C controllers. - UART: - Dual 4-pins UART serial ports
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- v3: add fixup devicetree for t2081qds. v2: some update for serdes and network configuration.
board/freescale/t2080qds/Makefile | 12 - board/freescale/t2080qds/ddr.c | 119 ----- board/freescale/t2080qds/ddr.h | 72 --- board/freescale/t2080qds/eth_t2080qds.c | 517 ------------------- board/freescale/t2080qds/law.c | 34 -- board/freescale/t2080qds/pci.c | 23 - board/freescale/t2080qds/t2080_pbi.cfg | 41 -- board/freescale/t2080qds/t2080_rcw.cfg | 8 - board/freescale/t2080qds/t2080qds.c | 378 -------------- board/freescale/t2080qds/t2080qds.h | 13 - board/freescale/t2080qds/t2080qds_qixis.h | 47 -- board/freescale/t2080qds/tlb.c | 146 ------ board/freescale/t208xqds/Makefile | 14 + board/freescale/t208xqds/ddr.c | 119 +++++ board/freescale/t208xqds/ddr.h | 72 +++ board/freescale/t208xqds/eth_t208xqds.c | 648 ++++++++++++++++++++++++ board/freescale/t208xqds/law.c | 34 ++ board/freescale/t208xqds/pci.c | 23 + board/freescale/t208xqds/t2080_rcw.cfg | 8 + board/freescale/t208xqds/t2081_rcw.cfg | 8 + board/freescale/t208xqds/t208x_pbi.cfg | 41 ++ board/freescale/t208xqds/t208xqds.c | 459 +++++++++++++++++ board/freescale/t208xqds/t208xqds.h | 13 + board/freescale/t208xqds/t208xqds_qixis.h | 49 ++ board/freescale/t208xqds/tlb.c | 146 ++++++ boards.cfg | 15 +- include/configs/T2080QDS.h | 804 ----------------------------- include/configs/T208xQDS.h | 817 ++++++++++++++++++++++++++++++ 28 files changed, 2461 insertions(+), 2219 deletions(-) delete mode 100644 board/freescale/t2080qds/Makefile delete mode 100644 board/freescale/t2080qds/ddr.c delete mode 100644 board/freescale/t2080qds/ddr.h delete mode 100644 board/freescale/t2080qds/eth_t2080qds.c delete mode 100644 board/freescale/t2080qds/law.c delete mode 100644 board/freescale/t2080qds/pci.c delete mode 100644 board/freescale/t2080qds/t2080_pbi.cfg delete mode 100644 board/freescale/t2080qds/t2080_rcw.cfg delete mode 100644 board/freescale/t2080qds/t2080qds.c delete mode 100644 board/freescale/t2080qds/t2080qds.h delete mode 100644 board/freescale/t2080qds/t2080qds_qixis.h delete mode 100644 board/freescale/t2080qds/tlb.c create mode 100644 board/freescale/t208xqds/Makefile create mode 100644 board/freescale/t208xqds/ddr.c create mode 100644 board/freescale/t208xqds/ddr.h create mode 100644 board/freescale/t208xqds/eth_t208xqds.c create mode 100644 board/freescale/t208xqds/law.c create mode 100644 board/freescale/t208xqds/pci.c create mode 100644 board/freescale/t208xqds/t2080_rcw.cfg create mode 100644 board/freescale/t208xqds/t2081_rcw.cfg create mode 100644 board/freescale/t208xqds/t208x_pbi.cfg create mode 100644 board/freescale/t208xqds/t208xqds.c create mode 100644 board/freescale/t208xqds/t208xqds.h create mode 100644 board/freescale/t208xqds/t208xqds_qixis.h create mode 100644 board/freescale/t208xqds/tlb.c delete mode 100644 include/configs/T2080QDS.h create mode 100644 include/configs/T208xQDS.h
diff --git a/board/freescale/t2080qds/Makefile b/board/freescale/t2080qds/Makefile deleted file mode 100644 index 0b8747b..0000000 --- a/board/freescale/t2080qds/Makefile +++ /dev/null @@ -1,12 +0,0 @@ -# -# Copyright 2013 Freescale Semiconductor, Inc. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-$(CONFIG_T2080QDS) += t2080qds.o -obj-$(CONFIG_T2080QDS) += eth_t2080qds.o -obj-$(CONFIG_PCI) += pci.o -obj-y += ddr.o -obj-y += law.o -obj-y += tlb.o diff --git a/board/freescale/t2080qds/ddr.c b/board/freescale/t2080qds/ddr.c deleted file mode 100644 index ed1334d..0000000 --- a/board/freescale/t2080qds/ddr.c +++ /dev/null @@ -1,119 +0,0 @@ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * Version 2 or later as published by the Free Software Foundation. - */ - -#include <common.h> -#include <i2c.h> -#include <hwconfig.h> -#include <asm/mmu.h> -#include <fsl_ddr_sdram.h> -#include <fsl_ddr_dimm_params.h> -#include <asm/fsl_law.h> -#include "ddr.h" - -DECLARE_GLOBAL_DATA_PTR; - -void fsl_ddr_board_options(memctl_options_t *popts, - dimm_params_t *pdimm, - unsigned int ctrl_num) -{ - const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; - ulong ddr_freq; - - if (ctrl_num > 1) { - printf("Not supported controller number %d\n", ctrl_num); - return; - } - if (!pdimm->n_ranks) - return; - - /* - * we use identical timing for all slots. If needed, change the code - * to pbsp = rdimms[ctrl_num] or pbsp = udimms[ctrl_num]; - */ - if (popts->registered_dimm_en) - pbsp = rdimms[0]; - else - pbsp = udimms[0]; - - /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr - * freqency and n_banks specified in board_specific_parameters table. - */ - ddr_freq = get_ddr_freq(0) / 1000000; - while (pbsp->datarate_mhz_high) { - if (pbsp->n_ranks == pdimm->n_ranks && - (pdimm->rank_density >> 30) >= pbsp->rank_gb) { - if (ddr_freq <= pbsp->datarate_mhz_high) { - popts->clk_adjust = pbsp->clk_adjust; - popts->wrlvl_start = pbsp->wrlvl_start; - popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; - popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; - goto found; - } - pbsp_highest = pbsp; - } - pbsp++; - } - - if (pbsp_highest) { - printf("Error: board specific timing not found"); - printf("for data rate %lu MT/s\n", ddr_freq); - printf("Trying to use the highest speed (%u) parameters\n", - pbsp_highest->datarate_mhz_high); - popts->clk_adjust = pbsp_highest->clk_adjust; - popts->wrlvl_start = pbsp_highest->wrlvl_start; - popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; - popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; - } else { - panic("DIMM is not supported by this board"); - } -found: - debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n" - "\tclk_adjust %d, wrlvl_start %d, wrlvl_ctrl_2 0x%x, " - "wrlvl_ctrl_3 0x%x\n", - pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb, - pbsp->clk_adjust, pbsp->wrlvl_start, pbsp->wrlvl_ctl_2, - pbsp->wrlvl_ctl_3); - - /* - * Factors to consider for half-strength driver enable: - * - number of DIMMs installed - */ - popts->half_strength_driver_enable = 0; - /* - * Write leveling override - */ - popts->wrlvl_override = 1; - popts->wrlvl_sample = 0xf; - - /* - * Rtt and Rtt_WR override - */ - popts->rtt_override = 0; - - /* Enable ZQ calibration */ - popts->zq_en = 1; - - /* DHC_EN =1, ODT = 75 Ohm */ - popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_75ohm); - popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_75ohm); -} - -phys_size_t initdram(int board_type) -{ - phys_size_t dram_size; - - puts("Initializing....using SPD\n"); - - dram_size = fsl_ddr_sdram(); - - dram_size = setup_ddr_tlbs(dram_size / 0x100000); - dram_size *= 0x100000; - - puts(" DDR: "); - return dram_size; -} diff --git a/board/freescale/t2080qds/ddr.h b/board/freescale/t2080qds/ddr.h deleted file mode 100644 index 9fc879a..0000000 --- a/board/freescale/t2080qds/ddr.h +++ /dev/null @@ -1,72 +0,0 @@ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __DDR_H__ -#define __DDR_H__ -struct board_specific_parameters { - u32 n_ranks; - u32 datarate_mhz_high; - u32 rank_gb; - u32 clk_adjust; - u32 wrlvl_start; - u32 wrlvl_ctl_2; - u32 wrlvl_ctl_3; -}; - -/* - * These tables contain all valid speeds we want to override with board - * specific parameters. datarate_mhz_high values need to be in ascending order - * for each n_ranks group. - */ - -static const struct board_specific_parameters udimm0[] = { - /* - * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | - */ - {2, 1200, 2, 5, 7, 0x0808090a, 0x0b0c0c0a}, - {2, 1500, 2, 5, 6, 0x07070809, 0x0a0b0b09}, - {2, 1600, 2, 5, 8, 0x090b0b0d, 0x0d0e0f0b}, - {2, 1700, 2, 4, 7, 0x080a0a0c, 0x0c0d0e0a}, - {2, 1900, 2, 5, 9, 0x0a0b0c0e, 0x0f10120c}, - {2, 2140, 2, 4, 8, 0x090a0b0d, 0x0e0f110b}, - {1, 1200, 2, 5, 7, 0x0808090a, 0x0b0c0c0a}, - {1, 1500, 2, 5, 6, 0x07070809, 0x0a0b0b09}, - {1, 1600, 2, 5, 8, 0x090b0b0d, 0x0d0e0f0b}, - {1, 1700, 2, 4, 7, 0x080a0a0c, 0x0c0d0e0a}, - {1, 1900, 2, 5, 9, 0x0a0b0c0e, 0x0f10120c}, - {1, 2140, 2, 4, 8, 0x090a0b0d, 0x0e0f110b}, - {} -}; - -static const struct board_specific_parameters rdimm0[] = { - /* - * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | - */ - /* TODO: need tuning these parameters if RDIMM is used */ - {4, 1350, 0, 5, 9, 0x08070605, 0x06070806}, - {4, 1666, 0, 5, 11, 0x0a080706, 0x07090906}, - {4, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, - {2, 1350, 0, 5, 9, 0x08070605, 0x06070806}, - {2, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, - {2, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, - {1, 1350, 0, 5, 9, 0x08070605, 0x06070806}, - {1, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, - {1, 2140, 0, 4, 12, 0x0b090807, 0x080a0b07}, - {} -}; - -static const struct board_specific_parameters *udimms[] = { - udimm0, -}; - -static const struct board_specific_parameters *rdimms[] = { - rdimm0, -}; -#endif diff --git a/board/freescale/t2080qds/eth_t2080qds.c b/board/freescale/t2080qds/eth_t2080qds.c deleted file mode 100644 index 3e4ab8f..0000000 --- a/board/freescale/t2080qds/eth_t2080qds.c +++ /dev/null @@ -1,517 +0,0 @@ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * Shengzhou Liu Shengzhou.Liu@freescale.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <netdev.h> -#include <asm/mmu.h> -#include <asm/processor.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_law.h> -#include <asm/fsl_serdes.h> -#include <asm/fsl_portals.h> -#include <asm/fsl_liodn.h> -#include <malloc.h> -#include <fm_eth.h> -#include <fsl_mdio.h> -#include <miiphy.h> -#include <phy.h> -#include <asm/fsl_dtsec.h> -#include <asm/fsl_serdes.h> -#include "../common/qixis.h" -#include "../common/fman.h" -#include "t2080qds_qixis.h" - -#define EMI_NONE 0xFFFFFFFF -#define EMI1_RGMII1 0 -#define EMI1_RGMII2 1 -#define EMI1_SLOT1 2 -#define EMI1_SLOT2 6 -#define EMI1_SLOT3 3 -#define EMI1_SLOT4 4 -#define EMI1_SLOT5 5 -#define EMI2 7 - -static int mdio_mux[NUM_FM_PORTS]; - -static const char * const mdio_names[] = { - "T2080QDS_MDIO_RGMII1", - "T2080QDS_MDIO_RGMII2", - "T2080QDS_MDIO_SLOT1", - "T2080QDS_MDIO_SLOT3", - "T2080QDS_MDIO_SLOT4", - "T2080QDS_MDIO_SLOT5", - "T2080QDS_MDIO_SLOT2", - "T2080QDS_MDIO_10GC", -}; - -/* Map SerDes1 8 lanes to default slot, will be initialized dynamically */ -static u8 lane_to_slot[] = {3, 3, 3, 3, 1, 1, 1, 1}; - -static const char *T2080qds_mdio_name_for_muxval(u8 muxval) -{ - return mdio_names[muxval]; -} - -struct mii_dev *mii_dev_for_muxval(u8 muxval) -{ - struct mii_dev *bus; - const char *name = T2080qds_mdio_name_for_muxval(muxval); - - if (!name) { - printf("No bus for muxval %x\n", muxval); - return NULL; - } - - bus = miiphy_get_dev_by_name(name); - - if (!bus) { - printf("No bus by name %s\n", name); - return NULL; - } - - return bus; -} - -struct T2080qds_mdio { - u8 muxval; - struct mii_dev *realbus; -}; - -static void T2080qds_mux_mdio(u8 muxval) -{ - u8 brdcfg4; - if (muxval < 7) { - brdcfg4 = QIXIS_READ(brdcfg[4]); - brdcfg4 &= ~BRDCFG4_EMISEL_MASK; - brdcfg4 |= (muxval << BRDCFG4_EMISEL_SHIFT); - QIXIS_WRITE(brdcfg[4], brdcfg4); - } -} - -static int T2080qds_mdio_read(struct mii_dev *bus, int addr, int devad, - int regnum) -{ - struct T2080qds_mdio *priv = bus->priv; - - T2080qds_mux_mdio(priv->muxval); - - return priv->realbus->read(priv->realbus, addr, devad, regnum); -} - -static int T2080qds_mdio_write(struct mii_dev *bus, int addr, int devad, - int regnum, u16 value) -{ - struct T2080qds_mdio *priv = bus->priv; - - T2080qds_mux_mdio(priv->muxval); - - return priv->realbus->write(priv->realbus, addr, devad, regnum, value); -} - -static int T2080qds_mdio_reset(struct mii_dev *bus) -{ - struct T2080qds_mdio *priv = bus->priv; - - return priv->realbus->reset(priv->realbus); -} - -static int T2080qds_mdio_init(char *realbusname, u8 muxval) -{ - struct T2080qds_mdio *pmdio; - struct mii_dev *bus = mdio_alloc(); - - if (!bus) { - printf("Failed to allocate T2080QDS MDIO bus\n"); - return -1; - } - - pmdio = malloc(sizeof(*pmdio)); - if (!pmdio) { - printf("Failed to allocate T2080QDS private data\n"); - free(bus); - return -1; - } - - bus->read = T2080qds_mdio_read; - bus->write = T2080qds_mdio_write; - bus->reset = T2080qds_mdio_reset; - sprintf(bus->name, T2080qds_mdio_name_for_muxval(muxval)); - - pmdio->realbus = miiphy_get_dev_by_name(realbusname); - - if (!pmdio->realbus) { - printf("No bus with name %s\n", realbusname); - free(bus); - free(pmdio); - return -1; - } - - pmdio->muxval = muxval; - bus->priv = pmdio; - - return mdio_register(bus); -} - -void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, - enum fm_port port, int offset) -{ - int phy; - char alias[20]; - struct fixed_link f_link; - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 srds_s1 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS1_PRTCL; - - srds_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; - - if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII) { - phy = fm_info_get_phy_address(port); - switch (port) { - case FM1_DTSEC1: - case FM1_DTSEC2: - case FM1_DTSEC9: - case FM1_DTSEC10: - sprintf(alias, "phy_sgmii_s3_%x", phy); - fdt_set_phy_handle(fdt, compat, addr, alias); - fdt_status_okay_by_alias(fdt, "emi1_slot3"); - break; - case FM1_DTSEC5: - case FM1_DTSEC6: - if (mdio_mux[port] == EMI1_SLOT1) { - sprintf(alias, "phy_sgmii_s1_%x", phy); - fdt_set_phy_handle(fdt, compat, addr, alias); - fdt_status_okay_by_alias(fdt, "emi1_slot1"); - } else if (mdio_mux[port] == EMI1_SLOT2) { - sprintf(alias, "phy_sgmii_s2_%x", phy); - fdt_set_phy_handle(fdt, compat, addr, alias); - fdt_status_okay_by_alias(fdt, "emi1_slot2"); - } - break; - default: - break; - } - - } else if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_XGMII) { - switch (srds_s1) { - case 0x66: /* XFI interface */ - case 0x6b: - case 0x6c: - case 0x6d: - case 0x71: - f_link.phy_id = port; - f_link.duplex = 1; - f_link.link_speed = 10000; - f_link.pause = 0; - f_link.asym_pause = 0; - /* no PHY for XFI */ - fdt_delprop(fdt, offset, "phy-handle"); - fdt_setprop(fdt, offset, "fixed-link", &f_link, - sizeof(f_link)); - break; - default: - break; - } - } -} - -void fdt_fixup_board_enet(void *fdt) -{ - return; -} - -/* - * This function reads RCW to check if Serdes1{E,F,G,H} is configured - * as slot 1/2/3 and update the lane_to_slot[] array accordingly - */ -static void initialize_lane_to_slot(void) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 srds_s1 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS1_PRTCL; - - srds_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; - - switch (srds_s1) { - case 0x51: - case 0x5f: - case 0x65: - case 0x6b: - case 0x71: - lane_to_slot[5] = 2; - lane_to_slot[6] = 2; - lane_to_slot[7] = 2; - break; - case 0xa6: - case 0x8e: - case 0x8f: - case 0x82: - case 0x83: - case 0xd3: - case 0xd9: - case 0xcb: - lane_to_slot[6] = 2; - lane_to_slot[7] = 2; - break; - case 0xda: - lane_to_slot[4] = 3; - lane_to_slot[5] = 3; - lane_to_slot[6] = 3; - lane_to_slot[7] = 3; - break; - default: - break; - } -} - -int board_eth_init(bd_t *bis) -{ -#if defined(CONFIG_FMAN_ENET) - int i, idx, lane, slot, interface; - struct memac_mdio_info dtsec_mdio_info; - struct memac_mdio_info tgec_mdio_info; - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 rcwsr13 = in_be32(&gur->rcwsr[13]); - u32 srds_s1; - - srds_s1 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS1_PRTCL; - srds_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; - - initialize_lane_to_slot(); - - /* Initialize the mdio_mux array so we can recognize empty elements */ - for (i = 0; i < NUM_FM_PORTS; i++) - mdio_mux[i] = EMI_NONE; - - dtsec_mdio_info.regs = - (struct memac_mdio_controller *)CONFIG_SYS_FM1_DTSEC_MDIO_ADDR; - - dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; - - /* Register the 1G MDIO bus */ - fm_memac_mdio_init(bis, &dtsec_mdio_info); - - tgec_mdio_info.regs = - (struct memac_mdio_controller *)CONFIG_SYS_FM1_TGEC_MDIO_ADDR; - tgec_mdio_info.name = DEFAULT_FM_TGEC_MDIO_NAME; - - /* Register the 10G MDIO bus */ - fm_memac_mdio_init(bis, &tgec_mdio_info); - - /* Register the muxing front-ends to the MDIO buses */ - T2080qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII1); - T2080qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII2); - T2080qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT1); - T2080qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT2); - T2080qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT3); - T2080qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT4); - T2080qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT5); - T2080qds_mdio_init(DEFAULT_FM_TGEC_MDIO_NAME, EMI2); - - /* Set the two on-board RGMII PHY address */ - fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY1_ADDR); - if ((rcwsr13 & FSL_CORENET_RCWSR13_EC2) == - FSL_CORENET_RCWSR13_EC2_DTSEC4_RGMII) - fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY2_ADDR); - else - fm_info_set_phy_address(FM1_DTSEC10, RGMII_PHY2_ADDR); - - switch (srds_s1) { - case 0x1c: - case 0x95: - case 0xa2: - case 0x94: - /* SGMII in Slot3 */ - fm_info_set_phy_address(FM1_DTSEC9, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); - /* SGMII in Slot2 */ - fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT4_PHY_ADDR); - break; - case 0x51: - case 0x5f: - case 0x65: - /* XAUI/HiGig in Slot3 */ - fm_info_set_phy_address(FM1_10GEC1, FM1_10GEC1_PHY_ADDR); - /* SGMII in Slot2 */ - fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT4_PHY_ADDR); - break; - case 0x66: - /* - * XFI does not need a PHY to work, but to avoid U-boot use - * default PHY address which is zero to a MAC when it found - * a MAC has no PHY address, we give a PHY address to XFI - * MAC, and should not use a real XAUI PHY address, since - * MDIO can access it successfully, and then MDIO thinks - * the XAUI card is used for the XFI MAC, which will cause - * error. - */ - fm_info_set_phy_address(FM1_10GEC1, 4); - fm_info_set_phy_address(FM1_10GEC2, 5); - fm_info_set_phy_address(FM1_10GEC3, 6); - fm_info_set_phy_address(FM1_10GEC4, 7); - break; - case 0x6b: - fm_info_set_phy_address(FM1_10GEC1, 4); - fm_info_set_phy_address(FM1_10GEC2, 5); - fm_info_set_phy_address(FM1_10GEC3, 6); - fm_info_set_phy_address(FM1_10GEC4, 7); - /* SGMII in Slot2 */ - fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); - break; - case 0x6c: - case 0x6d: - fm_info_set_phy_address(FM1_10GEC1, 4); - fm_info_set_phy_address(FM1_10GEC2, 5); - /* SGMII in Slot3 */ - fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); - break; - case 0x71: - /* SGMII in Slot3 */ - fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); - /* SGMII in Slot2 */ - fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); - break; - case 0xa6: - case 0x8e: - case 0x8f: - case 0x82: - case 0x83: - /* SGMII in Slot3 */ - fm_info_set_phy_address(FM1_DTSEC9, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); - /* SGMII in Slot2 */ - fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); - break; - case 0xa4: - case 0x96: - case 0x8a: - /* SGMII in Slot3 */ - fm_info_set_phy_address(FM1_DTSEC9, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); - break; - case 0xd9: - case 0xd3: - case 0xcb: - /* SGMII in Slot3 */ - fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); - /* SGMII in Slot2 */ - fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); - break; - default: - break; - } - - for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { - idx = i - FM1_DTSEC1; - interface = fm_info_get_enet_if(i); - switch (interface) { - case PHY_INTERFACE_MODE_SGMII: - lane = serdes_get_first_lane(FSL_SRDS_1, - SGMII_FM1_DTSEC1 + idx); - if (lane < 0) - break; - slot = lane_to_slot[lane]; - debug("FM1@DTSEC%u expects SGMII in slot %u\n", - idx + 1, slot); - if (QIXIS_READ(present2) & (1 << (slot - 1))) - fm_disable_port(i); - - switch (slot) { - case 1: - mdio_mux[i] = EMI1_SLOT1; - fm_info_set_mdio(i, mii_dev_for_muxval( - mdio_mux[i])); - break; - case 2: - mdio_mux[i] = EMI1_SLOT2; - fm_info_set_mdio(i, mii_dev_for_muxval( - mdio_mux[i])); - break; - case 3: - mdio_mux[i] = EMI1_SLOT3; - fm_info_set_mdio(i, mii_dev_for_muxval( - mdio_mux[i])); - break; - } - break; - case PHY_INTERFACE_MODE_RGMII: - if (i == FM1_DTSEC3) - mdio_mux[i] = EMI1_RGMII1; - else if (i == FM1_DTSEC4 || FM1_DTSEC10) - mdio_mux[i] = EMI1_RGMII2; - fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); - break; - default: - break; - } - } - - for (i = FM1_10GEC1; i < FM1_10GEC1 + CONFIG_SYS_NUM_FM1_10GEC; i++) { - idx = i - FM1_10GEC1; - switch (fm_info_get_enet_if(i)) { - case PHY_INTERFACE_MODE_XGMII: - if (srds_s1 == 0x51) { - lane = serdes_get_first_lane(FSL_SRDS_1, - XAUI_FM1_MAC9 + idx); - } else if ((srds_s1 == 0x5f) || (srds_s1 == 0x65)) { - lane = serdes_get_first_lane(FSL_SRDS_1, - HIGIG_FM1_MAC9 + idx); - } else { - if (i == FM1_10GEC1 || i == FM1_10GEC2) - lane = serdes_get_first_lane(FSL_SRDS_1, - XFI_FM1_MAC9 + idx); - else - lane = serdes_get_first_lane(FSL_SRDS_1, - XFI_FM1_MAC1 + idx); - } - - if (lane < 0) - break; - mdio_mux[i] = EMI2; - fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); - - if ((srds_s1 == 0x66) || (srds_s1 == 0x6b) || - (srds_s1 == 0x6c) || (srds_s1 == 0x6d) || - (srds_s1 == 0x71)) { - /* As XFI is in cage intead of a slot, so - * ensure doesn't disable the corresponding port - */ - break; - } - - slot = lane_to_slot[lane]; - if (QIXIS_READ(present2) & (1 << (slot - 1))) - fm_disable_port(i); - break; - default: - break; - } - } - - cpu_eth_init(bis); -#endif /* CONFIG_FMAN_ENET */ - - return pci_eth_init(bis); -} diff --git a/board/freescale/t2080qds/law.c b/board/freescale/t2080qds/law.c deleted file mode 100644 index 74e2a53..0000000 --- a/board/freescale/t2080qds/law.c +++ /dev/null @@ -1,34 +0,0 @@ -/* - * Copyright 2008-2012 Freescale Semiconductor, Inc. - * - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/fsl_law.h> -#include <asm/mmu.h> - -struct law_entry law_table[] = { - SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_IFC), -#ifdef CONFIG_SYS_BMAN_MEM_PHYS - SET_LAW(CONFIG_SYS_BMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_BMAN), -#endif -#ifdef CONFIG_SYS_QMAN_MEM_PHYS - SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_QMAN), -#endif -#ifdef QIXIS_BASE_PHYS - SET_LAW(QIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), -#endif -#ifdef CONFIG_SYS_DCSRBAR_PHYS - /* Limit DCSR to 32M to access NPC Trace Buffer */ - SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_DCSR), -#endif -#ifdef CONFIG_SYS_NAND_BASE_PHYS - SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_IFC), -#endif -}; - -int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/t2080qds/pci.c b/board/freescale/t2080qds/pci.c deleted file mode 100644 index 84a89da..0000000 --- a/board/freescale/t2080qds/pci.c +++ /dev/null @@ -1,23 +0,0 @@ -/* - * Copyright 2007-2013 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <pci.h> -#include <asm/fsl_pci.h> -#include <libfdt.h> -#include <fdt_support.h> -#include <asm/fsl_serdes.h> - -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} - -void pci_of_setup(void *blob, bd_t *bd) -{ - FT_FSL_PCI_SETUP; -} diff --git a/board/freescale/t2080qds/t2080_pbi.cfg b/board/freescale/t2080qds/t2080_pbi.cfg deleted file mode 100644 index e200d92..0000000 --- a/board/freescale/t2080qds/t2080_pbi.cfg +++ /dev/null @@ -1,41 +0,0 @@ -# -# Copyright 2013 Freescale Semiconductor, Inc. -# -# SPDX-License-Identifier: GPL-2.0+ -# -# Refer doc/README.pblimage for more details about how-to configure -# and create PBL boot image -# - -#PBI commands -#Initialize CPC1 -09010000 00200400 -09138000 00000000 -091380c0 00000100 -#512KB SRAM -09010100 00000000 -09010104 fff80009 -09010f00 08000000 -#enable CPC1 -09010000 80000000 -#Configure LAW for CPC1 -09000d00 00000000 -09000d04 fff80000 -09000d08 81000012 -#Initialize eSPI controller, default configuration is slow for eSPI to -#load data, this configuration comes from u-boot eSPI driver. -09110000 80000403 -09110020 2d170008 -09110024 00100008 -09110028 00100008 -0911002c 00100008 -#Errata for slowing down the MDC clock to make it <= 2.5 MHZ -094fc030 00008148 -094fd030 00008148 -#Configure alternate space -09000010 00000000 -09000014 ff000000 -09000018 81000000 -#Flush PBL data -09138000 00000000 -091380c0 00000000 diff --git a/board/freescale/t2080qds/t2080_rcw.cfg b/board/freescale/t2080qds/t2080_rcw.cfg deleted file mode 100644 index c2ad0fd..0000000 --- a/board/freescale/t2080qds/t2080_rcw.cfg +++ /dev/null @@ -1,8 +0,0 @@ -#PBL preamble and RCW header -aa55aa55 010e0100 -#SerDes Protocol: 0x66_0x16 -#Core/DDR: 1533Mhz/2133MT/s -12100017 15000000 00000000 00000000 -66160002 00008400 e8104000 c1000000 -00000000 00000000 00000000 000307fc -00000000 00000000 00000000 00000004 diff --git a/board/freescale/t2080qds/t2080qds.c b/board/freescale/t2080qds/t2080qds.c deleted file mode 100644 index 4fe8ccb..0000000 --- a/board/freescale/t2080qds/t2080qds.c +++ /dev/null @@ -1,378 +0,0 @@ -/* - * Copyright 2009-2013 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <i2c.h> -#include <netdev.h> -#include <linux/compiler.h> -#include <asm/mmu.h> -#include <asm/processor.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_law.h> -#include <asm/fsl_serdes.h> -#include <asm/fsl_portals.h> -#include <asm/fsl_liodn.h> -#include <fm_eth.h> - -#include "../common/qixis.h" -#include "../common/vsc3316_3308.h" -#include "t2080qds.h" -#include "t2080qds_qixis.h" - -DECLARE_GLOBAL_DATA_PTR; - -int checkboard(void) -{ - char buf[64]; - u8 sw; - struct cpu_type *cpu = gd->arch.cpu; - static const char *freq[4] = { - "100.00MHZ(from 8T49N222A)", "125.00MHz", - "156.25MHZ", "100.00MHz" - }; - - printf("Board: %sQDS, ", cpu->name); - sw = QIXIS_READ(arch); - printf("Sys ID: 0x%02x, Board Arch: V%d, ", QIXIS_READ(id), sw >> 4); - printf("Board Version: %c, boot from ", (sw & 0xf) + 'A' - 1); - -#ifdef CONFIG_SDCARD - puts("SD/MMC\n"); -#elif CONFIG_SPIFLASH - puts("SPI\n"); -#else - sw = QIXIS_READ(brdcfg[0]); - sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; - - if (sw < 0x8) - printf("vBank%d\n", sw); - else if (sw == 0x8) - puts("Promjet\n"); - else if (sw == 0x9) - puts("NAND\n"); - else - printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); -#endif - - printf("FPGA: v%d (%s), build %d", (int)QIXIS_READ(scver), - qixis_read_tag(buf), (int)qixis_read_minor()); - /* the timestamp string contains "\n" at the end */ - printf(" on %s", qixis_read_time(buf)); - - puts("SERDES Reference Clocks:\n"); - sw = QIXIS_READ(brdcfg[2]); - printf("SD1_CLK1=%s, SD1_CLK2=%s\n", freq[sw >> 6], - freq[(sw >> 4) & 0x3]); - printf("SD2_CLK1=%s, SD2_CLK2=%s\n", freq[(sw & 0xf) >> 2], - freq[sw & 0x3]); - - return 0; -} - -int select_i2c_ch_pca9547(u8 ch) -{ - int ret; - - ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); - if (ret) { - puts("PCA: failed to select proper channel\n"); - return ret; - } - - return 0; -} - -int brd_mux_lane_to_slot(void) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 srds_prtcl_s1, srds_prtcl_s2; - - srds_prtcl_s1 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS1_PRTCL; - srds_prtcl_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; - srds_prtcl_s2 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS2_PRTCL; - srds_prtcl_s2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; - - switch (srds_prtcl_s1) { - case 0: - /* SerDes1 is not enabled */ - break; - case 0x1c: - case 0xa2: - /* SD1(A:D) => SLOT3 SGMII - * SD1(G:H) => SLOT1 SGMII - */ - QIXIS_WRITE(brdcfg[12], 0x1a); - break; - case 0x94: - case 0x95: - /* SD1(A:B) => SLOT3 SGMII@1.25bps - * SD1(C:D) => SFP Module, SGMII@3.125bps - * SD1(E:H) => SLOT1 SGMII@1.25bps - */ - case 0x96: - /* SD1(A:B) => SLOT3 SGMII@1.25bps - * SD1(C) => SFP Module, SGMII@3.125bps - * SD1(D) => SFP Module, SGMII@1.25bps - * SD1(E:H) => SLOT1 PCIe4 x4 - */ - QIXIS_WRITE(brdcfg[12], 0x3a); - break; - case 0x51: - /* SD1(A:D) => SLOT3 XAUI - * SD1(E) => SLOT1 PCIe4 - * SD1(F:H) => SLOT2 SGMII - */ - QIXIS_WRITE(brdcfg[12], 0x15); - break; - case 0x66: - case 0x67: - /* SD1(A:D) => XFI cage - * SD1(E:H) => SLOT1 PCIe4 - */ - QIXIS_WRITE(brdcfg[12], 0xfe); - break; - case 0x6b: - /* SD1(A:D) => XFI cage - * SD1(E) => SLOT1 PCIe4 - * SD1(F:H) => SLOT2 SGMII - */ - QIXIS_WRITE(brdcfg[12], 0xf1); - break; - case 0x6c: - case 0x6d: - /* SD1(A:B) => XFI cage - * SD1(C:D) => SLOT3 SGMII - * SD1(E:H) => SLOT1 PCIe4 - */ - QIXIS_WRITE(brdcfg[12], 0xda); - break; - case 0x6e: - /* SD1(A:B) => SFP Module, XFI - * SD1(C:D) => SLOT3 SGMII - * SD1(E:F) => SLOT1 PCIe4 x2 - * SD1(G:H) => SLOT2 SGMII - */ - QIXIS_WRITE(brdcfg[12], 0xd9); - break; - case 0xda: - /* SD1(A:H) => SLOT3 PCIe3 x8 - */ - QIXIS_WRITE(brdcfg[12], 0x0); - break; - case 0xc8: - /* SD1(A) => SLOT3 PCIe3 x1 - * SD1(B) => SFP Module, SGMII@1.25bps - * SD1(C:D) => SFP Module, SGMII@3.125bps - * SD1(E:F) => SLOT1 PCIe4 x2 - * SD1(G:H) => SLOT2 SGMII - */ - QIXIS_WRITE(brdcfg[12], 0x79); - break; - case 0xab: - /* SD1(A:D) => SLOT3 PCIe3 x4 - * SD1(E:H) => SLOT1 PCIe4 x4 - */ - QIXIS_WRITE(brdcfg[12], 0x1a); - break; - default: - printf("WARNING: unsupported for SerDes1 Protocol %d\n", - srds_prtcl_s1); - return -1; - } - - switch (srds_prtcl_s2) { - case 0: - /* SerDes2 is not enabled */ - break; - case 0x01: - case 0x02: - /* SD2(A:H) => SLOT4 PCIe1 */ - QIXIS_WRITE(brdcfg[13], 0x10); - break; - case 0x15: - case 0x16: - /* - * SD2(A:D) => SLOT4 PCIe1 - * SD2(E:F) => SLOT5 PCIe2 - * SD2(G:H) => SATA1,SATA2 - */ - QIXIS_WRITE(brdcfg[13], 0xb0); - break; - case 0x18: - /* - * SD2(A:D) => SLOT4 PCIe1 - * SD2(E:F) => SLOT5 Aurora - * SD2(G:H) => SATA1,SATA2 - */ - QIXIS_WRITE(brdcfg[13], 0x78); - break; - case 0x1f: - /* - * SD2(A:D) => SLOT4 PCIe1 - * SD2(E:H) => SLOT5 PCIe2 - */ - QIXIS_WRITE(brdcfg[13], 0xa0); - break; - case 0x29: - case 0x2d: - case 0x2e: - /* - * SD2(A:D) => SLOT4 SRIO2 - * SD2(E:H) => SLOT5 SRIO1 - */ - QIXIS_WRITE(brdcfg[13], 0xa0); - break; - case 0x36: - /* - * SD2(A:D) => SLOT4 SRIO2 - * SD2(E:F) => Aurora - * SD2(G:H) => SATA1,SATA2 - */ - QIXIS_WRITE(brdcfg[13], 0x78); - break; - default: - printf("WARNING: unsupported for SerDes2 Protocol %d\n", - srds_prtcl_s2); - return -1; - } - return 0; -} - -int board_early_init_r(void) -{ - const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; - const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); - - /* - * Remap Boot flash + PROMJET region to caching-inhibited - * so that flash can be erased properly. - */ - - /* Flush d-cache and invalidate i-cache of any FLASH data */ - flush_dcache(); - invalidate_icache(); - - /* invalidate existing TLB entry for flash + promjet */ - disable_tlb(flash_esel); - - set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, flash_esel, BOOKE_PAGESZ_256M, 1); - - set_liodns(); -#ifdef CONFIG_SYS_DPAA_QBMAN - setup_portals(); -#endif - - /* Disable remote I2C connection to qixis fpga */ - QIXIS_WRITE(brdcfg[5], QIXIS_READ(brdcfg[5]) & ~BRDCFG5_IRE); - - brd_mux_lane_to_slot(); - select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); - - return 0; -} - -unsigned long get_board_sys_clk(void) -{ - u8 sysclk_conf = QIXIS_READ(brdcfg[1]); -#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT - /* use accurate clock measurement */ - int freq = QIXIS_READ(clk_freq[0]) << 8 | QIXIS_READ(clk_freq[1]); - int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); - u32 val; - - val = freq * base; - if (val) { - debug("SYS Clock measurement is: %d\n", val); - return val; - } else { - printf("Warning: SYS clock measurement is invalid, "); - printf("using value from brdcfg1.\n"); - } -#endif - - switch (sysclk_conf & 0x0F) { - case QIXIS_SYSCLK_83: - return 83333333; - case QIXIS_SYSCLK_100: - return 100000000; - case QIXIS_SYSCLK_125: - return 125000000; - case QIXIS_SYSCLK_133: - return 133333333; - case QIXIS_SYSCLK_150: - return 150000000; - case QIXIS_SYSCLK_160: - return 160000000; - case QIXIS_SYSCLK_166: - return 166666666; - } - return 66666666; -} - -unsigned long get_board_ddr_clk(void) -{ - u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); -#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT - /* use accurate clock measurement */ - int freq = QIXIS_READ(clk_freq[2]) << 8 | QIXIS_READ(clk_freq[3]); - int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); - u32 val; - - val = freq * base; - if (val) { - debug("DDR Clock measurement is: %d\n", val); - return val; - } else { - printf("Warning: DDR clock measurement is invalid, "); - printf("using value from brdcfg1.\n"); - } -#endif - - switch ((ddrclk_conf & 0x30) >> 4) { - case QIXIS_DDRCLK_100: - return 100000000; - case QIXIS_DDRCLK_125: - return 125000000; - case QIXIS_DDRCLK_133: - return 133333333; - } - return 66666666; -} - -int misc_init_r(void) -{ - return 0; -} - -void ft_board_setup(void *blob, bd_t *bd) -{ - phys_addr_t base; - phys_size_t size; - - ft_cpu_setup(blob, bd); - - base = getenv_bootm_low(); - size = getenv_bootm_size(); - - fdt_fixup_memory(blob, (u64)base, (u64)size); - -#ifdef CONFIG_PCI - pci_of_setup(blob, bd); -#endif - - fdt_fixup_liodn(blob); - fdt_fixup_dr_usb(blob, bd); - -#ifdef CONFIG_SYS_DPAA_FMAN - fdt_fixup_fman_ethernet(blob); - fdt_fixup_board_enet(blob); -#endif -} diff --git a/board/freescale/t2080qds/t2080qds.h b/board/freescale/t2080qds/t2080qds.h deleted file mode 100644 index 39fcef2..0000000 --- a/board/freescale/t2080qds/t2080qds.h +++ /dev/null @@ -1,13 +0,0 @@ -/* - * Copyright 2011-2013 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __CORENET_DS_H__ -#define __CORENET_DS_H__ - -void fdt_fixup_board_enet(void *blob); -void pci_of_setup(void *blob, bd_t *bd); - -#endif diff --git a/board/freescale/t2080qds/t2080qds_qixis.h b/board/freescale/t2080qds/t2080qds_qixis.h deleted file mode 100644 index fc83da7..0000000 --- a/board/freescale/t2080qds/t2080qds_qixis.h +++ /dev/null @@ -1,47 +0,0 @@ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __T2080QDS_QIXIS_H__ -#define __T2080QDS_QIXIS_H__ - -/* Definitions of QIXIS Registers for T2080QDS */ - -#define QIXIS_SRDS1CLK_122 0x5a -#define QIXIS_SRDS1CLK_125 0x5e - - -/* BRDCFG4[4:7]] select EC1 and EC2 as a pair */ -#define BRDCFG4_EMISEL_MASK 0xE0 -#define BRDCFG4_EMISEL_SHIFT 5 - -/* SYSCLK */ -#define QIXIS_SYSCLK_66 0x0 -#define QIXIS_SYSCLK_83 0x1 -#define QIXIS_SYSCLK_100 0x2 -#define QIXIS_SYSCLK_125 0x3 -#define QIXIS_SYSCLK_133 0x4 -#define QIXIS_SYSCLK_150 0x5 -#define QIXIS_SYSCLK_160 0x6 -#define QIXIS_SYSCLK_166 0x7 - -/* DDRCLK */ -#define QIXIS_DDRCLK_66 0x0 -#define QIXIS_DDRCLK_100 0x1 -#define QIXIS_DDRCLK_125 0x2 -#define QIXIS_DDRCLK_133 0x3 - -#define BRDCFG5_IRE 0x20 /* i2c Remote i2c1 enable */ - -#define BRDCFG12_SD3EN_MASK 0x20 -#define BRDCFG12_SD3MX_MASK 0x08 -#define BRDCFG12_SD3MX_SLOT5 0x08 -#define BRDCFG12_SD3MX_SLOT6 0x00 -#define BRDCFG12_SD4EN_MASK 0x04 -#define BRDCFG12_SD4MX_MASK 0x03 -#define BRDCFG12_SD4MX_SLOT7 0x02 -#define BRDCFG12_SD4MX_SLOT8 0x01 -#define BRDCFG12_SD4MX_AURO_SATA 0x00 -#endif diff --git a/board/freescale/t2080qds/tlb.c b/board/freescale/t2080qds/tlb.c deleted file mode 100644 index 62cd110..0000000 --- a/board/freescale/t2080qds/tlb.c +++ /dev/null @@ -1,146 +0,0 @@ -/* - * Copyright 2008-2013 Freescale Semiconductor, Inc. - * - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/mmu.h> - -struct fsl_e_tlb_entry tlb_table[] = { - /* TLB 0 - for temp stack in cache */ - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, - CONFIG_SYS_INIT_RAM_ADDR_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, - CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, - CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, - CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - - /* TLB 1 */ - /* *I*** - Covers boot page */ -#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L3_ADDR) - /* - * *I*G - L3SRAM. When L3 is used as 1M SRAM, the address of the - * SRAM is at 0xfff00000, it covered the 0xfffff000. - */ - SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 0, BOOKE_PAGESZ_1M, 1), -#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) - /* - * SRIO_PCIE_BOOT-SLAVE. When slave boot, the address of the - * space is at 0xfff00000, it covered the 0xfffff000. - */ - SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR, - CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, - 0, 0, BOOKE_PAGESZ_1M, 1), -#else - SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 0, BOOKE_PAGESZ_4K, 1), -#endif - - /* *I*G* - CCSRBAR */ - SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 1, BOOKE_PAGESZ_16M, 1), - - /* *I*G* - Flash, localbus */ - /* This will be changed to *I*G* after relocation to RAM. */ - SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, - MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, - 0, 2, BOOKE_PAGESZ_256M, 1), - - /* *I*G* - PCIe 1, 0x80000000 */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 3, BOOKE_PAGESZ_512M, 1), - - /* *I*G* - PCIe 2, 0xa0000000 */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE2_MEM_VIRT, CONFIG_SYS_PCIE2_MEM_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 4, BOOKE_PAGESZ_256M, 1), - - /* *I*G* - PCIe 3, 0xb0000000 */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT, CONFIG_SYS_PCIE3_MEM_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 5, BOOKE_PAGESZ_256M, 1), - - - /* *I*G* - PCIe 4, 0xc0000000 */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE4_MEM_VIRT, CONFIG_SYS_PCIE4_MEM_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 6, BOOKE_PAGESZ_256M, 1), - - /* *I*G* - PCI I/O */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_IO_VIRT, CONFIG_SYS_PCIE1_IO_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 7, BOOKE_PAGESZ_256K, 1), - - /* Bman/Qman */ -#ifdef CONFIG_SYS_BMAN_MEM_PHYS - SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE, CONFIG_SYS_BMAN_MEM_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 9, BOOKE_PAGESZ_16M, 1), - SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE + 0x01000000, - CONFIG_SYS_BMAN_MEM_PHYS + 0x01000000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 10, BOOKE_PAGESZ_16M, 1), -#endif -#ifdef CONFIG_SYS_QMAN_MEM_PHYS - SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE, CONFIG_SYS_QMAN_MEM_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 11, BOOKE_PAGESZ_16M, 1), - SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE + 0x01000000, - CONFIG_SYS_QMAN_MEM_PHYS + 0x01000000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 12, BOOKE_PAGESZ_16M, 1), -#endif -#ifdef CONFIG_SYS_DCSRBAR_PHYS - SET_TLB_ENTRY(1, CONFIG_SYS_DCSRBAR, CONFIG_SYS_DCSRBAR_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 13, BOOKE_PAGESZ_32M, 1), -#endif -#ifdef CONFIG_SYS_NAND_BASE - /* - * *I*G - NAND - * entry 14 and 15 has been used hard coded, they will be disabled - * in cpu_init_f, so we use entry 16 for nand. - */ - SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 16, BOOKE_PAGESZ_64K, 1), -#endif -#ifdef QIXIS_BASE_PHYS - SET_TLB_ENTRY(1, QIXIS_BASE, QIXIS_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 17, BOOKE_PAGESZ_4K, 1), -#endif -#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE - /* - * SRIO_PCIE_BOOT-SLAVE. 1M space from 0xffe00000 for - * fetching ucode and ENV from master - */ - SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR, - CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, - 0, 18, BOOKE_PAGESZ_1M, 1), -#endif - -}; - -int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/freescale/t208xqds/Makefile b/board/freescale/t208xqds/Makefile new file mode 100644 index 0000000..947b7f7 --- /dev/null +++ b/board/freescale/t208xqds/Makefile @@ -0,0 +1,14 @@ +# +# Copyright 2013 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_T2080QDS) += t208xqds.o +obj-$(CONFIG_T2080QDS) += eth_t208xqds.o +obj-$(CONFIG_T2081QDS) += t208xqds.o +obj-$(CONFIG_T2081QDS) += eth_t208xqds.o +obj-$(CONFIG_PCI) += pci.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/t208xqds/ddr.c b/board/freescale/t208xqds/ddr.c new file mode 100644 index 0000000..ed1334d --- /dev/null +++ b/board/freescale/t208xqds/ddr.c @@ -0,0 +1,119 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 or later as published by the Free Software Foundation. + */ + +#include <common.h> +#include <i2c.h> +#include <hwconfig.h> +#include <asm/mmu.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#include <asm/fsl_law.h> +#include "ddr.h" + +DECLARE_GLOBAL_DATA_PTR; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 1) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + /* + * we use identical timing for all slots. If needed, change the code + * to pbsp = rdimms[ctrl_num] or pbsp = udimms[ctrl_num]; + */ + if (popts->registered_dimm_en) + pbsp = rdimms[0]; + else + pbsp = udimms[0]; + + /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks && + (pdimm->rank_density >> 30) >= pbsp->rank_gb) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found"); + printf("for data rate %lu MT/s\n", ddr_freq); + printf("Trying to use the highest speed (%u) parameters\n", + pbsp_highest->datarate_mhz_high); + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + } else { + panic("DIMM is not supported by this board"); + } +found: + debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n" + "\tclk_adjust %d, wrlvl_start %d, wrlvl_ctrl_2 0x%x, " + "wrlvl_ctrl_3 0x%x\n", + pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb, + pbsp->clk_adjust, pbsp->wrlvl_start, pbsp->wrlvl_ctl_2, + pbsp->wrlvl_ctl_3); + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 0; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + /* DHC_EN =1, ODT = 75 Ohm */ + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_75ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_75ohm); +} + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + + puts("Initializing....using SPD\n"); + + dram_size = fsl_ddr_sdram(); + + dram_size = setup_ddr_tlbs(dram_size / 0x100000); + dram_size *= 0x100000; + + puts(" DDR: "); + return dram_size; +} diff --git a/board/freescale/t208xqds/ddr.h b/board/freescale/t208xqds/ddr.h new file mode 100644 index 0000000..9fc879a --- /dev/null +++ b/board/freescale/t208xqds/ddr.h @@ -0,0 +1,72 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __DDR_H__ +#define __DDR_H__ +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ + +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | + */ + {2, 1200, 2, 5, 7, 0x0808090a, 0x0b0c0c0a}, + {2, 1500, 2, 5, 6, 0x07070809, 0x0a0b0b09}, + {2, 1600, 2, 5, 8, 0x090b0b0d, 0x0d0e0f0b}, + {2, 1700, 2, 4, 7, 0x080a0a0c, 0x0c0d0e0a}, + {2, 1900, 2, 5, 9, 0x0a0b0c0e, 0x0f10120c}, + {2, 2140, 2, 4, 8, 0x090a0b0d, 0x0e0f110b}, + {1, 1200, 2, 5, 7, 0x0808090a, 0x0b0c0c0a}, + {1, 1500, 2, 5, 6, 0x07070809, 0x0a0b0b09}, + {1, 1600, 2, 5, 8, 0x090b0b0d, 0x0d0e0f0b}, + {1, 1700, 2, 4, 7, 0x080a0a0c, 0x0c0d0e0a}, + {1, 1900, 2, 5, 9, 0x0a0b0c0e, 0x0f10120c}, + {1, 2140, 2, 4, 8, 0x090a0b0d, 0x0e0f110b}, + {} +}; + +static const struct board_specific_parameters rdimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | + */ + /* TODO: need tuning these parameters if RDIMM is used */ + {4, 1350, 0, 5, 9, 0x08070605, 0x06070806}, + {4, 1666, 0, 5, 11, 0x0a080706, 0x07090906}, + {4, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, + {2, 1350, 0, 5, 9, 0x08070605, 0x06070806}, + {2, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, + {2, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, + {1, 1350, 0, 5, 9, 0x08070605, 0x06070806}, + {1, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, + {1, 2140, 0, 4, 12, 0x0b090807, 0x080a0b07}, + {} +}; + +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +static const struct board_specific_parameters *rdimms[] = { + rdimm0, +}; +#endif diff --git a/board/freescale/t208xqds/eth_t208xqds.c b/board/freescale/t208xqds/eth_t208xqds.c new file mode 100644 index 0000000..7d8411b --- /dev/null +++ b/board/freescale/t208xqds/eth_t208xqds.c @@ -0,0 +1,648 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Shengzhou Liu Shengzhou.Liu@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <netdev.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <malloc.h> +#include <fm_eth.h> +#include <fsl_mdio.h> +#include <miiphy.h> +#include <phy.h> +#include <asm/fsl_dtsec.h> +#include <asm/fsl_serdes.h> +#include "../common/qixis.h" +#include "../common/fman.h" +#include "t208xqds_qixis.h" + +#define EMI_NONE 0xFFFFFFFF +#define EMI1_RGMII1 0 +#define EMI1_RGMII2 1 +#define EMI1_SLOT1 2 +#if defined(CONFIG_T2080QDS) +#define EMI1_SLOT2 6 +#define EMI1_SLOT3 3 +#define EMI1_SLOT4 4 +#define EMI1_SLOT5 5 +#elif defined(CONFIG_T2081QDS) +#define EMI1_SLOT2 3 +#define EMI1_SLOT3 4 +#define EMI1_SLOT5 5 +#define EMI1_SLOT6 6 +#define EMI1_SLOT7 7 +#endif +#define EMI2 8 + +static int mdio_mux[NUM_FM_PORTS]; + +static const char * const mdio_names[] = { +#if defined(CONFIG_T2080QDS) + "T2080QDS_MDIO_RGMII1", + "T2080QDS_MDIO_RGMII2", + "T2080QDS_MDIO_SLOT1", + "T2080QDS_MDIO_SLOT3", + "T2080QDS_MDIO_SLOT4", + "T2080QDS_MDIO_SLOT5", + "T2080QDS_MDIO_SLOT2", + "T2080QDS_MDIO_10GC", +#elif defined(CONFIG_T2081QDS) + "T2081QDS_MDIO_RGMII1", + "T2081QDS_MDIO_RGMII2", + "T2081QDS_MDIO_SLOT1", + "T2081QDS_MDIO_SLOT2", + "T2081QDS_MDIO_SLOT3", + "T2081QDS_MDIO_SLOT5", + "T2081QDS_MDIO_SLOT6", + "T2081QDS_MDIO_SLOT7", + "T2081QDS_MDIO_10GC", +#endif +}; + +/* Map SerDes1 8 lanes to default slot, will be initialized dynamically */ +#if defined(CONFIG_T2080QDS) +static u8 lane_to_slot[] = {3, 3, 3, 3, 1, 1, 1, 1}; +#elif defined(CONFIG_T2081QDS) +static u8 lane_to_slot[] = {2, 2, 2, 2, 1, 1, 1, 1}; +#endif + +static const char *t208xqds_mdio_name_for_muxval(u8 muxval) +{ + return mdio_names[muxval]; +} + +struct mii_dev *mii_dev_for_muxval(u8 muxval) +{ + struct mii_dev *bus; + const char *name = t208xqds_mdio_name_for_muxval(muxval); + + if (!name) { + printf("No bus for muxval %x\n", muxval); + return NULL; + } + + bus = miiphy_get_dev_by_name(name); + + if (!bus) { + printf("No bus by name %s\n", name); + return NULL; + } + + return bus; +} + +struct t208xqds_mdio { + u8 muxval; + struct mii_dev *realbus; +}; + +static void t208xqds_mux_mdio(u8 muxval) +{ + u8 brdcfg4; + if (muxval < 8) { + brdcfg4 = QIXIS_READ(brdcfg[4]); + brdcfg4 &= ~BRDCFG4_EMISEL_MASK; + brdcfg4 |= (muxval << BRDCFG4_EMISEL_SHIFT); + QIXIS_WRITE(brdcfg[4], brdcfg4); + } +} + +static int t208xqds_mdio_read(struct mii_dev *bus, int addr, int devad, + int regnum) +{ + struct t208xqds_mdio *priv = bus->priv; + + t208xqds_mux_mdio(priv->muxval); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int t208xqds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct t208xqds_mdio *priv = bus->priv; + + t208xqds_mux_mdio(priv->muxval); + + return priv->realbus->write(priv->realbus, addr, devad, regnum, value); +} + +static int t208xqds_mdio_reset(struct mii_dev *bus) +{ + struct t208xqds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static int t208xqds_mdio_init(char *realbusname, u8 muxval) +{ + struct t208xqds_mdio *pmdio; + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate t208xqds MDIO bus\n"); + return -1; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate t208xqds private data\n"); + free(bus); + return -1; + } + + bus->read = t208xqds_mdio_read; + bus->write = t208xqds_mdio_write; + bus->reset = t208xqds_mdio_reset; + sprintf(bus->name, t208xqds_mdio_name_for_muxval(muxval)); + + pmdio->realbus = miiphy_get_dev_by_name(realbusname); + + if (!pmdio->realbus) { + printf("No bus with name %s\n", realbusname); + free(bus); + free(pmdio); + return -1; + } + + pmdio->muxval = muxval; + bus->priv = pmdio; + return mdio_register(bus); +} + +void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, + enum fm_port port, int offset) +{ + int phy; + char alias[20]; + struct fixed_link f_link; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + + srds_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + + if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII) { + phy = fm_info_get_phy_address(port); + switch (port) { +#if defined(CONFIG_T2080QDS) + case FM1_DTSEC1: + case FM1_DTSEC2: + case FM1_DTSEC9: + case FM1_DTSEC10: + if (mdio_mux[port] == EMI1_SLOT2) { + sprintf(alias, "phy_sgmii_s2_%x", phy); + fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, "emi1_slot2"); + } else if (mdio_mux[port] == EMI1_SLOT3) { + sprintf(alias, "phy_sgmii_s3_%x", phy); + fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, "emi1_slot3"); + } + break; + case FM1_DTSEC5: + case FM1_DTSEC6: + if (mdio_mux[port] == EMI1_SLOT1) { + sprintf(alias, "phy_sgmii_s1_%x", phy); + fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, "emi1_slot1"); + } else if (mdio_mux[port] == EMI1_SLOT2) { + sprintf(alias, "phy_sgmii_s2_%x", phy); + fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, "emi1_slot2"); + } + break; +#elif defined(CONFIG_T2081QDS) + case FM1_DTSEC1: + case FM1_DTSEC2: + case FM1_DTSEC5: + case FM1_DTSEC6: + case FM1_DTSEC9: + case FM1_DTSEC10: + if (mdio_mux[port] == EMI1_SLOT2) { + sprintf(alias, "phy_sgmii_s2_%x", phy); + fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, "emi1_slot2"); + } else if (mdio_mux[port] == EMI1_SLOT3) { + sprintf(alias, "phy_sgmii_s3_%x", phy); + fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, "emi1_slot3"); + } else if (mdio_mux[port] == EMI1_SLOT5) { + sprintf(alias, "phy_sgmii_s5_%x", phy); + fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, "emi1_slot5"); + } else if (mdio_mux[port] == EMI1_SLOT6) { + sprintf(alias, "phy_sgmii_s6_%x", phy); + fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, "emi1_slot6"); + } else if (mdio_mux[port] == EMI1_SLOT7) { + sprintf(alias, "phy_sgmii_s7_%x", phy); + fdt_set_phy_handle(fdt, compat, addr, alias); + fdt_status_okay_by_alias(fdt, "emi1_slot7"); + } + break; +#endif + default: + break; + } + + } else if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_XGMII) { + switch (srds_s1) { + case 0x66: /* XFI interface */ + case 0x6b: + case 0x6c: + case 0x6d: + case 0x71: + f_link.phy_id = port; + f_link.duplex = 1; + f_link.link_speed = 10000; + f_link.pause = 0; + f_link.asym_pause = 0; + /* no PHY for XFI */ + fdt_delprop(fdt, offset, "phy-handle"); + fdt_setprop(fdt, offset, "fixed-link", &f_link, + sizeof(f_link)); + break; + default: + break; + } + } +} + +void fdt_fixup_board_enet(void *fdt) +{ + return; +} + +/* + * This function reads RCW to check if Serdes1{A:H} is configured + * to slot 1/2/3/4/5/6/7 and update the lane_to_slot[] array accordingly + */ +static void initialize_lane_to_slot(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + + srds_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + + switch (srds_s1) { +#if defined(CONFIG_T2080QDS) + case 0x51: + case 0x5f: + case 0x65: + case 0x6b: + case 0x71: + lane_to_slot[5] = 2; + lane_to_slot[6] = 2; + lane_to_slot[7] = 2; + break; + case 0xa6: + case 0x8e: + case 0x8f: + case 0x82: + case 0x83: + case 0xd3: + case 0xd9: + case 0xcb: + lane_to_slot[6] = 2; + lane_to_slot[7] = 2; + break; + case 0xda: + lane_to_slot[4] = 3; + lane_to_slot[5] = 3; + lane_to_slot[6] = 3; + lane_to_slot[7] = 3; + break; +#elif defined(CONFIG_T2081QDS) + case 0x6b: + lane_to_slot[4] = 1; + lane_to_slot[5] = 3; + lane_to_slot[6] = 3; + lane_to_slot[7] = 3; + break; + case 0xca: + case 0xcb: + lane_to_slot[1] = 7; + lane_to_slot[2] = 6; + lane_to_slot[3] = 5; + lane_to_slot[5] = 3; + lane_to_slot[6] = 3; + lane_to_slot[7] = 3; + break; + case 0xf2: + lane_to_slot[1] = 7; + lane_to_slot[2] = 7; + lane_to_slot[3] = 7; + lane_to_slot[5] = 4; + lane_to_slot[6] = 3; + lane_to_slot[7] = 7; + break; +#endif + default: + break; + } +} + +int board_eth_init(bd_t *bis) +{ +#if defined(CONFIG_FMAN_ENET) + int i, idx, lane, slot, interface; + struct memac_mdio_info dtsec_mdio_info; + struct memac_mdio_info tgec_mdio_info; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 rcwsr13 = in_be32(&gur->rcwsr[13]); + u32 srds_s1; + + srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + srds_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + + initialize_lane_to_slot(); + + /* Initialize the mdio_mux array so we can recognize empty elements */ + for (i = 0; i < NUM_FM_PORTS; i++) + mdio_mux[i] = EMI_NONE; + + dtsec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_DTSEC_MDIO_ADDR; + + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fm_memac_mdio_init(bis, &dtsec_mdio_info); + + tgec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_TGEC_MDIO_ADDR; + tgec_mdio_info.name = DEFAULT_FM_TGEC_MDIO_NAME; + + /* Register the 10G MDIO bus */ + fm_memac_mdio_init(bis, &tgec_mdio_info); + + /* Register the muxing front-ends to the MDIO buses */ + t208xqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII1); + t208xqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII2); + t208xqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT1); + t208xqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT2); + t208xqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT3); +#if defined(CONFIG_T2080QDS) + t208xqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT4); +#endif + t208xqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT5); +#if defined(CONFIG_T2081QDS) + t208xqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT6); + t208xqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT7); +#endif + t208xqds_mdio_init(DEFAULT_FM_TGEC_MDIO_NAME, EMI2); + + /* Set the two on-board RGMII PHY address */ + fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY1_ADDR); + if ((rcwsr13 & FSL_CORENET_RCWSR13_EC2) == + FSL_CORENET_RCWSR13_EC2_DTSEC4_RGMII) + fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY2_ADDR); + else + fm_info_set_phy_address(FM1_DTSEC10, RGMII_PHY2_ADDR); + + switch (srds_s1) { + case 0x1c: + case 0x95: + case 0xa2: + case 0x94: + /* T2080QDS: SGMII in Slot3; T2081QDS: SGMII in Slot2 */ + fm_info_set_phy_address(FM1_DTSEC9, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); + /* T2080QDS: SGMII in Slot2; T2081QDS: SGMII in Slot1 */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT4_PHY_ADDR); + break; + case 0x51: + case 0x5f: + case 0x65: + /* T2080QDS: XAUI/HiGig in Slot3; T2081QDS: in Slot2 */ + fm_info_set_phy_address(FM1_10GEC1, FM1_10GEC1_PHY_ADDR); + /* T2080QDS: SGMII in Slot2; T2081QDS: in Slot3 */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT4_PHY_ADDR); + break; + case 0x66: + /* + * XFI does not need a PHY to work, but to avoid U-boot use + * default PHY address which is zero to a MAC when it found + * a MAC has no PHY address, we give a PHY address to XFI + * MAC, and should not use a real XAUI PHY address, since + * MDIO can access it successfully, and then MDIO thinks + * the XAUI card is used for the XFI MAC, which will cause + * error. + */ + fm_info_set_phy_address(FM1_10GEC1, 4); + fm_info_set_phy_address(FM1_10GEC2, 5); + fm_info_set_phy_address(FM1_10GEC3, 6); + fm_info_set_phy_address(FM1_10GEC4, 7); + break; + case 0x6b: + fm_info_set_phy_address(FM1_10GEC1, 4); + fm_info_set_phy_address(FM1_10GEC2, 5); + fm_info_set_phy_address(FM1_10GEC3, 6); + fm_info_set_phy_address(FM1_10GEC4, 7); + /* T2080QDS: SGMII in Slot2; T2081QDS: in Slot3 */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + break; + case 0x6c: + case 0x6d: + fm_info_set_phy_address(FM1_10GEC1, 4); + fm_info_set_phy_address(FM1_10GEC2, 5); + /* T2080QDS: SGMII in Slot3; T2081QDS: in Slot2 */ + fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); + break; + case 0x71: + /* SGMII in Slot3 */ + fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); + /* SGMII in Slot2 */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + break; + case 0xa6: + case 0x8e: + case 0x8f: + case 0x82: + case 0x83: + /* SGMII in Slot3 */ + fm_info_set_phy_address(FM1_DTSEC9, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); + /* SGMII in Slot2 */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + break; + case 0xa4: + case 0x96: + case 0x8a: + /* SGMII in Slot3 */ + fm_info_set_phy_address(FM1_DTSEC9, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); + break; +#if defined(CONFIG_T2080QDS) + case 0xd9: + case 0xd3: + case 0xcb: + /* SGMII in Slot3 */ + fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); + /* SGMII in Slot2 */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + break; +#elif defined(CONFIG_T2081QDS) + case 0xca: + case 0xcb: + /* SGMII in Slot3 */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); + /* SGMII in Slot5 */ + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT1_PHY_ADDR); + /* SGMII in Slot6 */ + fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); + /* SGMII in Slot7 */ + fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT3_PHY_ADDR); + break; +#endif + case 0xf2: + /* T2080QDS: SGMII in Slot3; T2081QDS: SGMII in Slot7 */ + fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC10, SGMII_CARD_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT4_PHY_ADDR); + break; + default: + break; + } + + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { + idx = i - FM1_DTSEC1; + interface = fm_info_get_enet_if(i); + switch (interface) { + case PHY_INTERFACE_MODE_SGMII: + lane = serdes_get_first_lane(FSL_SRDS_1, + SGMII_FM1_DTSEC1 + idx); + if (lane < 0) + break; + slot = lane_to_slot[lane]; + debug("FM1@DTSEC%u expects SGMII in slot %u\n", + idx + 1, slot); + if (QIXIS_READ(present2) & (1 << (slot - 1))) + fm_disable_port(i); + + switch (slot) { + case 1: + mdio_mux[i] = EMI1_SLOT1; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + case 2: + mdio_mux[i] = EMI1_SLOT2; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + case 3: + mdio_mux[i] = EMI1_SLOT3; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; +#if defined(CONFIG_T2081QDS) + case 5: + mdio_mux[i] = EMI1_SLOT5; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + case 6: + mdio_mux[i] = EMI1_SLOT6; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + case 7: + mdio_mux[i] = EMI1_SLOT7; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; +#endif + } + break; + case PHY_INTERFACE_MODE_RGMII: + if (i == FM1_DTSEC3) + mdio_mux[i] = EMI1_RGMII1; + else if (i == FM1_DTSEC4 || FM1_DTSEC10) + mdio_mux[i] = EMI1_RGMII2; + fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); + break; + default: + break; + } + } + + for (i = FM1_10GEC1; i < FM1_10GEC1 + CONFIG_SYS_NUM_FM1_10GEC; i++) { + idx = i - FM1_10GEC1; + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_XGMII: + if (srds_s1 == 0x51) { + lane = serdes_get_first_lane(FSL_SRDS_1, + XAUI_FM1_MAC9 + idx); + } else if ((srds_s1 == 0x5f) || (srds_s1 == 0x65)) { + lane = serdes_get_first_lane(FSL_SRDS_1, + HIGIG_FM1_MAC9 + idx); + } else { + if (i == FM1_10GEC1 || i == FM1_10GEC2) + lane = serdes_get_first_lane(FSL_SRDS_1, + XFI_FM1_MAC9 + idx); + else + lane = serdes_get_first_lane(FSL_SRDS_1, + XFI_FM1_MAC1 + idx); + } + + if (lane < 0) + break; + mdio_mux[i] = EMI2; + fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); + + if ((srds_s1 == 0x66) || (srds_s1 == 0x6b) || + (srds_s1 == 0x6c) || (srds_s1 == 0x6d) || + (srds_s1 == 0x71)) { + /* As XFI is in cage intead of a slot, so + * ensure doesn't disable the corresponding port + */ + break; + } + + slot = lane_to_slot[lane]; + if (QIXIS_READ(present2) & (1 << (slot - 1))) + fm_disable_port(i); + break; + default: + break; + } + } + + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ + + return pci_eth_init(bis); +} diff --git a/board/freescale/t208xqds/law.c b/board/freescale/t208xqds/law.c new file mode 100644 index 0000000..74e2a53 --- /dev/null +++ b/board/freescale/t208xqds/law.c @@ -0,0 +1,34 @@ +/* + * Copyright 2008-2012 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_IFC), +#ifdef CONFIG_SYS_BMAN_MEM_PHYS + SET_LAW(CONFIG_SYS_BMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_BMAN), +#endif +#ifdef CONFIG_SYS_QMAN_MEM_PHYS + SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_QMAN), +#endif +#ifdef QIXIS_BASE_PHYS + SET_LAW(QIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), +#endif +#ifdef CONFIG_SYS_DCSRBAR_PHYS + /* Limit DCSR to 32M to access NPC Trace Buffer */ + SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_DCSR), +#endif +#ifdef CONFIG_SYS_NAND_BASE_PHYS + SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_IFC), +#endif +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/t208xqds/pci.c b/board/freescale/t208xqds/pci.c new file mode 100644 index 0000000..84a89da --- /dev/null +++ b/board/freescale/t208xqds/pci.c @@ -0,0 +1,23 @@ +/* + * Copyright 2007-2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/fsl_pci.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <asm/fsl_serdes.h> + +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} + +void pci_of_setup(void *blob, bd_t *bd) +{ + FT_FSL_PCI_SETUP; +} diff --git a/board/freescale/t208xqds/t2080_rcw.cfg b/board/freescale/t208xqds/t2080_rcw.cfg new file mode 100644 index 0000000..c2ad0fd --- /dev/null +++ b/board/freescale/t208xqds/t2080_rcw.cfg @@ -0,0 +1,8 @@ +#PBL preamble and RCW header +aa55aa55 010e0100 +#SerDes Protocol: 0x66_0x16 +#Core/DDR: 1533Mhz/2133MT/s +12100017 15000000 00000000 00000000 +66160002 00008400 e8104000 c1000000 +00000000 00000000 00000000 000307fc +00000000 00000000 00000000 00000004 diff --git a/board/freescale/t208xqds/t2081_rcw.cfg b/board/freescale/t208xqds/t2081_rcw.cfg new file mode 100644 index 0000000..a2d5ecf --- /dev/null +++ b/board/freescale/t208xqds/t2081_rcw.cfg @@ -0,0 +1,8 @@ +#PBL preamble and RCW header +aa55aa55 010e0100 +#Default SerDes Protocol: 0x6C +#Core/DDR: 1533Mhz/2133MT/s +12100017 15000000 00000000 00000000 +6c000002 00008000 e8104000 c1000000 +00000000 00000000 00000000 000307fc +00000000 00000000 00000000 00000004 diff --git a/board/freescale/t208xqds/t208x_pbi.cfg b/board/freescale/t208xqds/t208x_pbi.cfg new file mode 100644 index 0000000..e200d92 --- /dev/null +++ b/board/freescale/t208xqds/t208x_pbi.cfg @@ -0,0 +1,41 @@ +# +# Copyright 2013 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Refer doc/README.pblimage for more details about how-to configure +# and create PBL boot image +# + +#PBI commands +#Initialize CPC1 +09010000 00200400 +09138000 00000000 +091380c0 00000100 +#512KB SRAM +09010100 00000000 +09010104 fff80009 +09010f00 08000000 +#enable CPC1 +09010000 80000000 +#Configure LAW for CPC1 +09000d00 00000000 +09000d04 fff80000 +09000d08 81000012 +#Initialize eSPI controller, default configuration is slow for eSPI to +#load data, this configuration comes from u-boot eSPI driver. +09110000 80000403 +09110020 2d170008 +09110024 00100008 +09110028 00100008 +0911002c 00100008 +#Errata for slowing down the MDC clock to make it <= 2.5 MHZ +094fc030 00008148 +094fd030 00008148 +#Configure alternate space +09000010 00000000 +09000014 ff000000 +09000018 81000000 +#Flush PBL data +09138000 00000000 +091380c0 00000000 diff --git a/board/freescale/t208xqds/t208xqds.c b/board/freescale/t208xqds/t208xqds.c new file mode 100644 index 0000000..9cfc0bd --- /dev/null +++ b/board/freescale/t208xqds/t208xqds.c @@ -0,0 +1,459 @@ +/* + * Copyright 2009-2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <fm_eth.h> + +#include "../common/qixis.h" +#include "../common/vsc3316_3308.h" +#include "t208xqds.h" +#include "t208xqds_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + char buf[64]; + u8 sw; + struct cpu_type *cpu = gd->arch.cpu; + static const char *freq[4] = { + "100.00MHZ(from 8T49N222A)", "125.00MHz", + "156.25MHZ", "100.00MHz" + }; + + printf("Board: %sQDS, ", cpu->name); + sw = QIXIS_READ(arch); + printf("Sys ID: 0x%02x, Board Arch: V%d, ", QIXIS_READ(id), sw >> 4); + printf("Board Version: %c, boot from ", (sw & 0xf) + 'A' - 1); + +#ifdef CONFIG_SDCARD + puts("SD/MMC\n"); +#elif CONFIG_SPIFLASH + puts("SPI\n"); +#else + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + + if (sw < 0x8) + printf("vBank%d\n", sw); + else if (sw == 0x8) + puts("Promjet\n"); + else if (sw == 0x9) + puts("NAND\n"); + else + printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); +#endif + + printf("FPGA: v%d (%s), build %d", (int)QIXIS_READ(scver), + qixis_read_tag(buf), (int)qixis_read_minor()); + /* the timestamp string contains "\n" at the end */ + printf(" on %s", qixis_read_time(buf)); + + puts("SERDES Reference Clocks:\n"); + sw = QIXIS_READ(brdcfg[2]); + printf("SD1_CLK1=%s, SD1_CLK2=%s\n", freq[sw >> 6], + freq[(sw >> 4) & 0x3]); + printf("SD2_CLK1=%s, SD2_CLK2=%s\n", freq[(sw & 0xf) >> 2], + freq[sw & 0x3]); + + return 0; +} + +int select_i2c_ch_pca9547(u8 ch) +{ + int ret; + + ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); + if (ret) { + puts("PCA: failed to select proper channel\n"); + return ret; + } + + return 0; +} + +int brd_mux_lane_to_slot(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_prtcl_s1; + + srds_prtcl_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + srds_prtcl_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; +#if defined(CONFIG_T2080QDS) + u32 srds_prtcl_s2 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + srds_prtcl_s2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; +#endif + + switch (srds_prtcl_s1) { + case 0: + /* SerDes1 is not enabled */ + break; +#if defined(CONFIG_T2080QDS) + case 0x1c: + case 0xa2: + /* SD1(A:D) => SLOT3 SGMII + * SD1(G:H) => SLOT1 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0x1a); + break; + case 0x94: + case 0x95: + /* SD1(A:B) => SLOT3 SGMII@1.25bps + * SD1(C:D) => SFP Module, SGMII@3.125bps + * SD1(E:H) => SLOT1 SGMII@1.25bps + */ + case 0x96: + /* SD1(A:B) => SLOT3 SGMII@1.25bps + * SD1(C) => SFP Module, SGMII@3.125bps + * SD1(D) => SFP Module, SGMII@1.25bps + * SD1(E:H) => SLOT1 PCIe4 x4 + */ + QIXIS_WRITE(brdcfg[12], 0x3a); + break; + case 0x51: + /* SD1(A:D) => SLOT3 XAUI + * SD1(E) => SLOT1 PCIe4 + * SD1(F:H) => SLOT2 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0x15); + break; + case 0x66: + case 0x67: + /* SD1(A:D) => XFI cage + * SD1(E:H) => SLOT1 PCIe4 + */ + QIXIS_WRITE(brdcfg[12], 0xfe); + break; + case 0x6b: + /* SD1(A:D) => XFI cage + * SD1(E) => SLOT1 PCIe4 + * SD1(F:H) => SLOT2 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0xf1); + break; + case 0x6c: + case 0x6d: + /* SD1(A:B) => XFI cage + * SD1(C:D) => SLOT3 SGMII + * SD1(E:H) => SLOT1 PCIe4 + */ + QIXIS_WRITE(brdcfg[12], 0xda); + break; + case 0x6e: + /* SD1(A:B) => SFP Module, XFI + * SD1(C:D) => SLOT3 SGMII + * SD1(E:F) => SLOT1 PCIe4 x2 + * SD1(G:H) => SLOT2 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0xd9); + break; + case 0xda: + /* SD1(A:H) => SLOT3 PCIe3 x8 + */ + QIXIS_WRITE(brdcfg[12], 0x0); + break; + case 0xc8: + /* SD1(A) => SLOT3 PCIe3 x1 + * SD1(B) => SFP Module, SGMII@1.25bps + * SD1(C:D) => SFP Module, SGMII@3.125bps + * SD1(E:F) => SLOT1 PCIe4 x2 + * SD1(G:H) => SLOT2 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0x79); + break; + case 0xab: + /* SD1(A:D) => SLOT3 PCIe3 x4 + * SD1(E:H) => SLOT1 PCIe4 x4 + */ + QIXIS_WRITE(brdcfg[12], 0x1a); + break; +#elif defined(CONFIG_T2081QDS) + case 0x51: + /* SD1(A:D) => SLOT2 XAUI + * SD1(E) => SLOT1 PCIe4 x1 + * SD1(F:H) => SLOT3 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0x98); + QIXIS_WRITE(brdcfg[13], 0x70); + break; + case 0x6b: + /* SD1(A:D) => XFI SFP Module + * SD1(E) => SLOT1 PCIe4 x1 + * SD1(F:H) => SLOT3 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0x80); + QIXIS_WRITE(brdcfg[13], 0x70); + break; + case 0x6c: + /* SD1(A:B) => XFI SFP Module + * SD1(C:D) => SLOT2 SGMII + * SD1(E:H) => SLOT1 PCIe4 x4 + */ + QIXIS_WRITE(brdcfg[12], 0xe8); + QIXIS_WRITE(brdcfg[13], 0x0); + break; + case 0x6d: + /* SD1(A:B) => XFI SFP Module + * SD1(C:D) => SLOT2 SGMII + * SD1(E:H) => SLOT1 PCIe4 x4 + */ + QIXIS_WRITE(brdcfg[12], 0xe8); + QIXIS_WRITE(brdcfg[13], 0x0); + break; + case 0xaa: + case 0xab: + /* SD1(A:D) => SLOT2 PCIe3 x4 + * SD1(F:H) => SLOT1 SGMI4 x4 + */ + QIXIS_WRITE(brdcfg[12], 0xf8); + QIXIS_WRITE(brdcfg[13], 0x0); + break; + case 0xca: + case 0xcb: + /* SD1(A) => SLOT2 PCIe3 x1 + * SD1(B) => SLOT7 SGMII + * SD1(C) => SLOT6 SGMII + * SD1(D) => SLOT5 SGMII + * SD1(E) => SLOT1 PCIe4 x1 + * SD1(F:H) => SLOT3 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0x80); + QIXIS_WRITE(brdcfg[13], 0x70); + break; + case 0xde: + case 0xdf: + /* SD1(A:D) => SLOT2 PCIe3 x4 + * SD1(E) => SLOT1 PCIe4 x1 + * SD1(F) => SLOT4 PCIe1 x1 + * SD1(G) => SLOT3 PCIe2 x1 + * SD1(H) => SLOT7 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0x98); + QIXIS_WRITE(brdcfg[13], 0x25); + break; + case 0xf2: + /* SD1(A) => SLOT2 PCIe3 x1 + * SD1(B:D) => SLOT7 SGMII + * SD1(E) => SLOT1 PCIe4 x1 + * SD1(F) => SLOT4 PCIe1 x1 + * SD1(G) => SLOT3 PCIe2 x1 + * SD1(H) => SLOT7 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0x81); + QIXIS_WRITE(brdcfg[13], 0xa5); + break; +#endif + default: + printf("WARNING: unsupported for SerDes1 Protocol %d\n", + srds_prtcl_s1); + return -1; + } + +#ifdef CONFIG_T2080QDS + switch (srds_prtcl_s2) { + case 0: + /* SerDes2 is not enabled */ + break; + case 0x01: + case 0x02: + /* SD2(A:H) => SLOT4 PCIe1 */ + QIXIS_WRITE(brdcfg[13], 0x10); + break; + case 0x15: + case 0x16: + /* + * SD2(A:D) => SLOT4 PCIe1 + * SD2(E:F) => SLOT5 PCIe2 + * SD2(G:H) => SATA1,SATA2 + */ + QIXIS_WRITE(brdcfg[13], 0xb0); + break; + case 0x18: + /* + * SD2(A:D) => SLOT4 PCIe1 + * SD2(E:F) => SLOT5 Aurora + * SD2(G:H) => SATA1,SATA2 + */ + QIXIS_WRITE(brdcfg[13], 0x78); + break; + case 0x1f: + /* + * SD2(A:D) => SLOT4 PCIe1 + * SD2(E:H) => SLOT5 PCIe2 + */ + QIXIS_WRITE(brdcfg[13], 0xa0); + break; + case 0x29: + case 0x2d: + case 0x2e: + /* + * SD2(A:D) => SLOT4 SRIO2 + * SD2(E:H) => SLOT5 SRIO1 + */ + QIXIS_WRITE(brdcfg[13], 0xa0); + break; + case 0x36: + /* + * SD2(A:D) => SLOT4 SRIO2 + * SD2(E:F) => Aurora + * SD2(G:H) => SATA1,SATA2 + */ + QIXIS_WRITE(brdcfg[13], 0x78); + break; + default: + printf("WARNING: unsupported for SerDes2 Protocol %d\n", + srds_prtcl_s2); + return -1; + } +#endif + return 0; +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + set_liodns(); +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_portals(); +#endif + + /* Disable remote I2C connection to qixis fpga */ + QIXIS_WRITE(brdcfg[5], QIXIS_READ(brdcfg[5]) & ~BRDCFG5_IRE); + + brd_mux_lane_to_slot(); + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + + return 0; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); +#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT + /* use accurate clock measurement */ + int freq = QIXIS_READ(clk_freq[0]) << 8 | QIXIS_READ(clk_freq[1]); + int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); + u32 val; + + val = freq * base; + if (val) { + debug("SYS Clock measurement is: %d\n", val); + return val; + } else { + printf("Warning: SYS clock measurement is invalid, "); + printf("using value from brdcfg1.\n"); + } +#endif + + switch (sysclk_conf & 0x0F) { + case QIXIS_SYSCLK_83: + return 83333333; + case QIXIS_SYSCLK_100: + return 100000000; + case QIXIS_SYSCLK_125: + return 125000000; + case QIXIS_SYSCLK_133: + return 133333333; + case QIXIS_SYSCLK_150: + return 150000000; + case QIXIS_SYSCLK_160: + return 160000000; + case QIXIS_SYSCLK_166: + return 166666666; + } + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); +#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT + /* use accurate clock measurement */ + int freq = QIXIS_READ(clk_freq[2]) << 8 | QIXIS_READ(clk_freq[3]); + int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); + u32 val; + + val = freq * base; + if (val) { + debug("DDR Clock measurement is: %d\n", val); + return val; + } else { + printf("Warning: DDR clock measurement is invalid, "); + printf("using value from brdcfg1.\n"); + } +#endif + + switch ((ddrclk_conf & 0x30) >> 4) { + case QIXIS_DDRCLK_100: + return 100000000; + case QIXIS_DDRCLK_125: + return 125000000; + case QIXIS_DDRCLK_133: + return 133333333; + } + return 66666666; +} + +int misc_init_r(void) +{ + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_PCI + pci_of_setup(blob, bd); +#endif + + fdt_fixup_liodn(blob); + fdt_fixup_dr_usb(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); + fdt_fixup_board_enet(blob); +#endif +} diff --git a/board/freescale/t208xqds/t208xqds.h b/board/freescale/t208xqds/t208xqds.h new file mode 100644 index 0000000..39fcef2 --- /dev/null +++ b/board/freescale/t208xqds/t208xqds.h @@ -0,0 +1,13 @@ +/* + * Copyright 2011-2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CORENET_DS_H__ +#define __CORENET_DS_H__ + +void fdt_fixup_board_enet(void *blob); +void pci_of_setup(void *blob, bd_t *bd); + +#endif diff --git a/board/freescale/t208xqds/t208xqds_qixis.h b/board/freescale/t208xqds/t208xqds_qixis.h new file mode 100644 index 0000000..bdcdc12 --- /dev/null +++ b/board/freescale/t208xqds/t208xqds_qixis.h @@ -0,0 +1,49 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __T208xQDS_QIXIS_H__ +#define __T208xQDS_QIXIS_H__ + +/* Definitions of QIXIS Registers for T208xQDS */ + +#define QIXIS_SRDS1CLK_122 0x5a +#define QIXIS_SRDS1CLK_125 0x5e + + +/* BRDCFG4[4:7]] select EC1 and EC2 as a pair */ +#define BRDCFG4_EMISEL_MASK 0xE0 +#define BRDCFG4_EMISEL_SHIFT 5 + +/* SYSCLK */ +#define QIXIS_SYSCLK_66 0x0 +#define QIXIS_SYSCLK_83 0x1 +#define QIXIS_SYSCLK_100 0x2 +#define QIXIS_SYSCLK_125 0x3 +#define QIXIS_SYSCLK_133 0x4 +#define QIXIS_SYSCLK_150 0x5 +#define QIXIS_SYSCLK_160 0x6 +#define QIXIS_SYSCLK_166 0x7 + +/* DDRCLK */ +#define QIXIS_DDRCLK_66 0x0 +#define QIXIS_DDRCLK_100 0x1 +#define QIXIS_DDRCLK_125 0x2 +#define QIXIS_DDRCLK_133 0x3 + +#define BRDCFG5_IRE 0x20 /* i2c Remote i2c1 enable */ + +#define BRDCFG9_SFP_TX_EN 0x10 + +#define BRDCFG12_SD3EN_MASK 0x20 +#define BRDCFG12_SD3MX_MASK 0x08 +#define BRDCFG12_SD3MX_SLOT5 0x08 +#define BRDCFG12_SD3MX_SLOT6 0x00 +#define BRDCFG12_SD4EN_MASK 0x04 +#define BRDCFG12_SD4MX_MASK 0x03 +#define BRDCFG12_SD4MX_SLOT7 0x02 +#define BRDCFG12_SD4MX_SLOT8 0x01 +#define BRDCFG12_SD4MX_AURO_SATA 0x00 +#endif diff --git a/board/freescale/t208xqds/tlb.c b/board/freescale/t208xqds/tlb.c new file mode 100644 index 0000000..62cd110 --- /dev/null +++ b/board/freescale/t208xqds/tlb.c @@ -0,0 +1,146 @@ +/* + * Copyright 2008-2013 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, + CONFIG_SYS_INIT_RAM_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Covers boot page */ +#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L3_ADDR) + /* + * *I*G - L3SRAM. When L3 is used as 1M SRAM, the address of the + * SRAM is at 0xfff00000, it covered the 0xfffff000. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) + /* + * SRIO_PCIE_BOOT-SLAVE. When slave boot, the address of the + * space is at 0xfff00000, it covered the 0xfffff000. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), +#else + SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_4K, 1), +#endif + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_16M, 1), + + /* *I*G* - Flash, localbus */ + /* This will be changed to *I*G* after relocation to RAM. */ + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCIe 1, 0x80000000 */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_512M, 1), + + /* *I*G* - PCIe 2, 0xa0000000 */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE2_MEM_VIRT, CONFIG_SYS_PCIE2_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCIe 3, 0xb0000000 */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE3_MEM_VIRT, CONFIG_SYS_PCIE3_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_256M, 1), + + + /* *I*G* - PCIe 4, 0xc0000000 */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE4_MEM_VIRT, CONFIG_SYS_PCIE4_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI I/O */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_IO_VIRT, CONFIG_SYS_PCIE1_IO_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 7, BOOKE_PAGESZ_256K, 1), + + /* Bman/Qman */ +#ifdef CONFIG_SYS_BMAN_MEM_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE, CONFIG_SYS_BMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 9, BOOKE_PAGESZ_16M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE + 0x01000000, + CONFIG_SYS_BMAN_MEM_PHYS + 0x01000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 10, BOOKE_PAGESZ_16M, 1), +#endif +#ifdef CONFIG_SYS_QMAN_MEM_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE, CONFIG_SYS_QMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 11, BOOKE_PAGESZ_16M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE + 0x01000000, + CONFIG_SYS_QMAN_MEM_PHYS + 0x01000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 12, BOOKE_PAGESZ_16M, 1), +#endif +#ifdef CONFIG_SYS_DCSRBAR_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_DCSRBAR, CONFIG_SYS_DCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 13, BOOKE_PAGESZ_32M, 1), +#endif +#ifdef CONFIG_SYS_NAND_BASE + /* + * *I*G - NAND + * entry 14 and 15 has been used hard coded, they will be disabled + * in cpu_init_f, so we use entry 16 for nand. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 16, BOOKE_PAGESZ_64K, 1), +#endif +#ifdef QIXIS_BASE_PHYS + SET_TLB_ENTRY(1, QIXIS_BASE, QIXIS_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 17, BOOKE_PAGESZ_4K, 1), +#endif +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE + /* + * SRIO_PCIE_BOOT-SLAVE. 1M space from 0xffe00000 for + * fetching ucode and ENV from master + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR, + CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, + 0, 18, BOOKE_PAGESZ_1M, 1), +#endif + +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 706ec96..b169510 100644 --- a/boards.cfg +++ b/boards.cfg @@ -972,11 +972,16 @@ Active powerpc mpc85xx - freescale p2041rdb Active powerpc mpc85xx - freescale t1040qds T1040QDS T1040QDS:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com Active powerpc mpc85xx - freescale t104xrdb T1040RDB T1040RDB:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com Active powerpc mpc85xx - freescale t104xrdb T1042RDB_PI T1042RDB_PI:PPC_T1042 Poonam Aggrwal poonam.aggrwal@freescale.com -Active powerpc mpc85xx - freescale t2080qds T2080QDS T2080QDS:PPC_T2080 - -Active powerpc mpc85xx - freescale t2080qds T2080QDS_NAND T2080QDS:PPC_T2080,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - -Active powerpc mpc85xx - freescale t2080qds T2080QDS_SDCARD T2080QDS:PPC_T2080,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000 - -Active powerpc mpc85xx - freescale t2080qds T2080QDS_SPIFLASH T2080QDS:PPC_T2080,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - -Active powerpc mpc85xx - freescale t2080qds T2080QDS_SRIO_PCIE_BOOT T2080QDS:PPC_T2080,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000 - +Active powerpc mpc85xx - freescale t208xqds T2080QDS T208xQDS:PPC_T2080 +Active powerpc mpc85xx - freescale t208xqds T2080QDS_SDCARD T208xQDS:PPC_T2080,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000 +Active powerpc mpc85xx - freescale t208xqds T2080QDS_SPIFLASH T208xQDS:PPC_T2080,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 +Active powerpc mpc85xx - freescale t208xqds T2080QDS_NAND T208xQDS:PPC_T2080,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 +Active powerpc mpc85xx - freescale t208xqds T2080QDS_SRIO_PCIE_BOOT T208xQDS:PPC_T2080,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000 +Active powerpc mpc85xx - freescale t208xqds T2081QDS T208xQDS:PPC_T2081 +Active powerpc mpc85xx - freescale t208xqds T2081QDS_SDCARD T208xQDS:PPC_T2081,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000 +Active powerpc mpc85xx - freescale t208xqds T2081QDS_SPIFLASH T208xQDS:PPC_T2081,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 +Active powerpc mpc85xx - freescale t208xqds T2081QDS_NAND T208xQDS:PPC_T2081,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 +Active powerpc mpc85xx - freescale t208xqds T2081QDS_SRIO_PCIE_BOOT T208xQDS:PPC_T2081,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000 Active powerpc mpc85xx - freescale t4qds T4160QDS T4240QDS:PPC_T4160 - Active powerpc mpc85xx - freescale t4qds T4160QDS_SDCARD T4240QDS:PPC_T4160,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale t4qds T4160QDS_SPIFLASH T4240QDS:PPC_T4160,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - diff --git a/include/configs/T2080QDS.h b/include/configs/T2080QDS.h deleted file mode 100644 index 9bd0fe2..0000000 --- a/include/configs/T2080QDS.h +++ /dev/null @@ -1,804 +0,0 @@ -/* - * Copyright 2011-2013 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * T2080 QDS board configuration file - */ - -#ifndef __T2080QDS_H -#define __T2080QDS_H - -#define CONFIG_T2080QDS -#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */ -#define CONFIG_MMC -#define CONFIG_SPI_FLASH -#define CONFIG_USB_EHCI -#define CONFIG_FSL_SATA_V2 -#define CONFIG_SYS_SRIO /* Enable Serial RapidIO Support */ -#define CONFIG_SRIO1 /* SRIO port 1 */ -#define CONFIG_SRIO2 /* SRIO port 2 */ - -/* High Level Configuration Options */ -#define CONFIG_PHYS_64BIT -#define CONFIG_BOOKE -#define CONFIG_E500 /* BOOKE e500 family */ -#define CONFIG_E500MC /* BOOKE e500mc family */ -#define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ -#define CONFIG_MP /* support multiple processors */ -#define CONFIG_ENABLE_36BIT_PHYS - -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_ADDR_MAP 1 -#define CONFIG_SYS_NUM_ADDR_MAP 64 /* number of TLB1 entries */ -#endif - -#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ -#define CONFIG_SYS_NUM_CPC CONFIG_NUM_DDR_CONTROLLERS -#define CONFIG_FSL_IFC /* Enable IFC Support */ -#define CONFIG_FSL_LAW /* Use common FSL init code */ -#define CONFIG_ENV_OVERWRITE - -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/t2080qds/t2080_pbi.cfg -#define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/t2080qds/t2080_rcw.cfg -#endif - -#define CONFIG_SRIO_PCIE_BOOT_MASTER -#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE -/* Set 1M boot space */ -#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) -#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS \ - (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR) -#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_SYS_NO_FLASH -#endif - -#ifndef CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_TEXT_BASE 0xeff40000 -#endif - -#ifndef CONFIG_RESET_VECTOR_ADDRESS -#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc -#endif - -/* - * These can be toggled for performance analysis, otherwise use default. - */ -#define CONFIG_SYS_CACHE_STASHING -#define CONFIG_BTB /* toggle branch predition */ -#define CONFIG_DDR_ECC -#ifdef CONFIG_DDR_ECC -#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER -#define CONFIG_MEM_INIT_VALUE 0xdeadbeef -#endif - -#ifdef CONFIG_SYS_NO_FLASH -#if !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) && !defined(CONFIG_RAMBOOT_PBL) -#define CONFIG_ENV_IS_NOWHERE -#endif -#else -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE -#endif - -#if defined(CONFIG_SPIFLASH) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#elif defined(CONFIG_SDCARD) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 1658) -#elif defined(CONFIG_NAND) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_IN_REMOTE -#define CONFIG_ENV_ADDR 0xffe20000 -#define CONFIG_ENV_SIZE 0x2000 -#elif defined(CONFIG_ENV_IS_NOWHERE) -#define CONFIG_ENV_SIZE 0x2000 -#else -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif - -#ifndef __ASSEMBLY__ -unsigned long get_board_sys_clk(void); -unsigned long get_board_ddr_clk(void); -#endif - -#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() -#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() - -/* - * Config the L3 Cache as L3 SRAM - */ -#define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE - -#define CONFIG_SYS_DCSRBAR 0xf0000000 -#define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull - -/* EEPROM */ -#define CONFIG_ID_EEPROM -#define CONFIG_SYS_I2C_EEPROM_NXID -#define CONFIG_SYS_EEPROM_BUS_NUM 0 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 - -/* - * DDR Setup - */ -#define CONFIG_VERY_BIG_RAM -#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE -#define CONFIG_DIMM_SLOTS_PER_CTLR 1 -#define CONFIG_CHIP_SELECTS_PER_CTRL (4 * CONFIG_DIMM_SLOTS_PER_CTLR) -#define CONFIG_DDR_SPD -#define CONFIG_SYS_FSL_DDR3 -#undef CONFIG_FSL_DDR_INTERACTIVE -#define CONFIG_SYS_SPD_BUS_NUM 0 -#define CONFIG_SYS_SDRAM_SIZE 2048 /* for fixed parameter use */ -#define SPD_EEPROM_ADDRESS1 0x51 -#define SPD_EEPROM_ADDRESS2 0x52 -#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 -#define CTRL_INTLV_PREFERED cacheline - -/* - * IFC Definitions - */ -#define CONFIG_SYS_FLASH_BASE 0xe0000000 -#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) -#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) -#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ - + 0x8000000) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR1_CSPR_EXT (0xf) -#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) -/* NOR Flash Timing Params */ -#define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 - -#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ - FTIM0_NOR_TEADC(0x5) | \ - FTIM0_NOR_TEAHC(0x5)) -#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ - FTIM1_NOR_TRAD_NOR(0x1A) |\ - FTIM1_NOR_TSEQRAD_NOR(0x13)) -#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ - FTIM2_NOR_TCH(0x4) | \ - FTIM2_NOR_TWPH(0x0E) | \ - FTIM2_NOR_TWP(0x1c)) -#define CONFIG_SYS_NOR_FTIM3 0x0 - -#define CONFIG_SYS_FLASH_QUIET_TEST -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ - -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ - + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} - -#define CONFIG_FSL_QIXIS /* use common QIXIS code */ -#define QIXIS_BASE 0xffdf0000 -#define QIXIS_LBMAP_SWITCH 6 -#define QIXIS_LBMAP_MASK 0x0f -#define QIXIS_LBMAP_SHIFT 0 -#define QIXIS_LBMAP_DFLTBANK 0x00 -#define QIXIS_LBMAP_ALTBANK 0x04 -#define QIXIS_RST_CTL_RESET 0x83 -#define QIXIS_RST_FORCE_MEM 0x1 -#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 -#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 -#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 -#define QIXIS_BASE_PHYS (0xf00000000ull | QIXIS_BASE) - -#define CONFIG_SYS_CSPR3_EXT (0xf) -#define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ - | CSPR_PORT_SIZE_8 \ - | CSPR_MSEL_GPCM \ - | CSPR_V) -#define CONFIG_SYS_AMASK3 IFC_AMASK(4*1024) -#define CONFIG_SYS_CSOR3 0x0 -/* QIXIS Timing parameters for IFC CS3 */ -#define CONFIG_SYS_CS3_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ - FTIM0_GPCM_TEADC(0x0e) | \ - FTIM0_GPCM_TEAHC(0x0e)) -#define CONFIG_SYS_CS3_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ - FTIM1_GPCM_TRAD(0x3f)) -#define CONFIG_SYS_CS3_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ - FTIM2_GPCM_TCH(0x0) | \ - FTIM2_GPCM_TWP(0x1f)) -#define CONFIG_SYS_CS3_FTIM3 0x0 - -/* NAND Flash on IFC */ -#define CONFIG_NAND_FSL_IFC -#define CONFIG_SYS_NAND_BASE 0xff800000 -#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) - -#define CONFIG_SYS_NAND_CSPR_EXT (0xf) -#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ - | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ - | CSPR_MSEL_NAND /* MSEL = NAND */ \ - | CSPR_V) -#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) - -#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ - | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ - | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ - | CSOR_NAND_RAL_3 /* RAL = 2Byes */ \ - | CSOR_NAND_PGS_2K /* Page Size = 2K */\ - | CSOR_NAND_SPRZ_64 /* Spare size = 64 */\ - | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ - -#define CONFIG_SYS_NAND_ONFI_DETECTION - -/* ONFI NAND Flash mode0 Timing Params */ -#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ - FTIM0_NAND_TWP(0x18) | \ - FTIM0_NAND_TWCHT(0x07) | \ - FTIM0_NAND_TWH(0x0a)) -#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ - FTIM1_NAND_TWBE(0x39) | \ - FTIM1_NAND_TRR(0x0e) | \ - FTIM1_NAND_TRP(0x18)) -#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ - FTIM2_NAND_TREH(0x0a) | \ - FTIM2_NAND_TWHRE(0x1e)) -#define CONFIG_SYS_NAND_FTIM3 0x0 - -#define CONFIG_SYS_NAND_DDR_LAW 11 -#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_MTD_NAND_VERIFY_WRITE -#define CONFIG_CMD_NAND -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - -#if defined(CONFIG_NAND) -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 -#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT -#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR -#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 -#else -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 -#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT -#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR -#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK -#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR -#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 -#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 -#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 -#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 -#endif -#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT -#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR -#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 - -#if defined(CONFIG_RAMBOOT_PBL) -#define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ -#define CONFIG_MISC_INIT_R -#define CONFIG_HWCONFIG - -/* define to use L1 as initial stack */ -#define CONFIG_L1_INIT_RAM -#define CONFIG_SYS_INIT_RAM_LOCK -#define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe0ec000 -/* The assembler doesn't like typecast */ -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ - ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ - CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) -#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) - -/* - * Serial Port - */ -#define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} -#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x11C500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) -#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) -#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) - -/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT -#define CONFIG_OF_BOARD_SETUP -#define CONFIG_OF_STDOUT_VIA_ALIAS - -/* new uImage format support */ -#define CONFIG_FIT -#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ - -/* - * I2C - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_FSL -#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C3_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C4_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C_OFFSET 0x118000 -#define CONFIG_SYS_FSL_I2C2_OFFSET 0x118100 -#define CONFIG_SYS_FSL_I2C3_OFFSET 0x119000 -#define CONFIG_SYS_FSL_I2C4_OFFSET 0x119100 -#define CONFIG_SYS_FSL_I2C_SPEED 100000 -#define CONFIG_SYS_FSL_I2C2_SPEED 100000 -#define CONFIG_SYS_FSL_I2C3_SPEED 100000 -#define CONFIG_SYS_FSL_I2C4_SPEED 100000 -#define I2C_MUX_PCA_ADDR_PRI 0x77 /* I2C bus multiplexer,primary */ -#define I2C_MUX_PCA_ADDR_SEC1 0x75 /* I2C bus multiplexer,secondary 1 */ -#define I2C_MUX_PCA_ADDR_SEC2 0x76 /* I2C bus multiplexer,secondary 2 */ -#define I2C_MUX_CH_DEFAULT 0x8 - - -/* - * RapidIO - */ -#define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull -#define CONFIG_SYS_SRIO1_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000 -#define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull -#define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */ -/* - * for slave u-boot IMAGE instored in master memory space, - * PHYS must be aligned based on the SIZE - */ -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull -/* - * for slave UCODE and ENV instored in master memory space, - * PHYS must be aligned based on the SIZE - */ -#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull -#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull -#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */ - -/* slave core release by master*/ -#define CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET 0xe00e4 -#define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */ - -/* - * SRIO_PCIE_BOOT - SLAVE - */ -#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE -#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR 0xFFE00000 -#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS \ - (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR) -#endif - -/* - * eSPI - Enhanced SPI - */ -#ifdef CONFIG_SPI_FLASH -#define CONFIG_FSL_ESPI -#define CONFIG_SPI_FLASH_SST -#define CONFIG_SPI_FLASH_STMICRO -#define CONFIG_SPI_FLASH_SPANSION -#define CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 -#endif - -/* - * General PCI - * Memory space is mapped 1-1, but I/O space must start from 0. - */ -#define CONFIG_PCI /* Enable PCI/PCIE */ -#define CONFIG_PCIE1 /* PCIE controler 1 */ -#define CONFIG_PCIE2 /* PCIE controler 2 */ -#define CONFIG_PCIE3 /* PCIE controler 3 */ -#define CONFIG_PCIE4 /* PCIE controler 4 */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ -/* controller 1, direct to uli, tgtid 3, Base address 20000 */ -#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ - -/* controller 2, Slot 2, tgtid 2, Base address 201000 */ -#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ - -/* controller 3, Slot 1, tgtid 1, Base address 202000 */ -#define CONFIG_SYS_PCIE3_MEM_VIRT 0xb0000000 -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc30000000ull -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ - -/* controller 4, Base address 203000 */ -#define CONFIG_SYS_PCIE4_MEM_VIRT 0xc0000000 -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE4_MEM_PHYS 0xc40000000ull -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ - -#ifdef CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE -#define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata LSZ ADD */ -#define CONFIG_NET_MULTI -#define CONFIG_E1000 -#define CONFIG_PCI_PNP /* do pci plug-and-play */ -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION -#endif - -/* Qman/Bman */ -#ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ -#define CONFIG_SYS_BMAN_NUM_PORTALS 18 -#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 -#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull -#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 -#define CONFIG_SYS_QMAN_NUM_PORTALS 18 -#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 -#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull -#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 - -#define CONFIG_SYS_DPAA_FMAN -#define CONFIG_SYS_DPAA_PME -#define CONFIG_SYS_PMAN -#define CONFIG_SYS_DPAA_DCE -#define CONFIG_SYS_DPAA_RMAN /* RMan */ -#define CONFIG_SYS_INTERLAKEN - -/* Default address of microcode for the Linux Fman driver */ -#if defined(CONFIG_SPIFLASH) -/* - * env is stored at 0x100000, sector size is 0x10000, ucode is stored after - * env, so we got 0x110000. - */ -#define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 -#elif defined(CONFIG_SDCARD) -/* - * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is - * about 825KB (1650 blocks), Env is stored after the image, and the env size is - * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. - */ -#define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) -#elif defined(CONFIG_NAND) -#define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) -#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -/* - * Slave has no ucode locally, it can fetch this from remote. When implementing - * in two corenet boards, slave's ucode could be stored in master's memory - * space, the address can be mapped from slave TLB->slave LAW-> - * slave SRIO or PCIE outbound window->master inbound window-> - * master LAW->the ucode address in master's memory space. - */ -#define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 -#else -#define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 -#endif -#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 -#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) -#endif /* CONFIG_NOBQFMAN */ - -#ifdef CONFIG_SYS_DPAA_FMAN -#define CONFIG_FMAN_ENET -#define CONFIG_PHYLIB_10G -#define CONFIG_PHY_VITESSE -#define CONFIG_PHY_REALTEK -#define CONFIG_PHY_TERANETICS -#define RGMII_PHY1_ADDR 0x1 -#define RGMII_PHY2_ADDR 0x2 -#define FM1_10GEC1_PHY_ADDR 0x3 -#define SGMII_CARD_PORT1_PHY_ADDR 0x1C -#define SGMII_CARD_PORT2_PHY_ADDR 0x1D -#define SGMII_CARD_PORT3_PHY_ADDR 0x1E -#define SGMII_CARD_PORT4_PHY_ADDR 0x1F -#endif - -#ifdef CONFIG_FMAN_ENET -#define CONFIG_MII /* MII PHY management */ -#define CONFIG_ETHPRIME "FM1@DTSEC3" -#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ -#endif - -/* - * SATA - */ -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_LIBATA -#define CONFIG_FSL_SATA -#define CONFIG_SYS_SATA_MAX_DEVICE 2 -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA -#define CONFIG_SATA2 -#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA -#define CONFIG_LBA48 -#define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 -#endif - -/* - * USB - */ -#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB -#define CONFIG_USB_STORAGE -#define CONFIG_USB_EHCI_FSL -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 -#define CONFIG_HAS_FSL_DR_USB -#endif - -/* - * SDHC - */ -#ifdef CONFIG_MMC -#define CONFIG_CMD_MMC -#define CONFIG_FSL_ESDHC -#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT -#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 -#define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION -#endif - -/* - * Environment - */ -#define CONFIG_LOADS_ECHO /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ELF -#define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_SETEXPR -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_BDI - -#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#define CONFIG_CMD_NET -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_CMDLINE_EDITING /* Command-line editing */ -#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ -#ifdef CONFIG_CMD_KGDB -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 64 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial map for Linux*/ -#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ - -#ifdef CONFIG_CMD_KGDB -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ -#endif - -/* - * Environment Configuration - */ -#define CONFIG_ROOTPATH "/opt/nfsroot" -#define CONFIG_BOOTFILE "uImage" -#define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server */ - -/* default location for tftp and bootm */ -#define CONFIG_LOADADDR 1000000 -#define CONFIG_BAUDRATE 115200 -#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ -#define __USB_PHY_TYPE utmi - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "hwconfig=fsl_ddr:" \ - "ctlr_intlv=" __stringify(CTRL_INTLV_PREFERED) "," \ - "bank_intlv=auto;" \ - "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ - "netdev=eth0\0" \ - "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ - "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ - "tftpflash=tftpboot $loadaddr $uboot && " \ - "protect off $ubootaddr +$filesize && " \ - "erase $ubootaddr +$filesize && " \ - "cp.b $loadaddr $ubootaddr $filesize && " \ - "protect on $ubootaddr +$filesize && " \ - "cmp.b $loadaddr $ubootaddr $filesize\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=2000000\0" \ - "ramdiskfile=t2080qds/ramdisk.uboot\0" \ - "fdtaddr=c00000\0" \ - "fdtfile=t2080qds/t2080qds.dtb\0" \ - "bdev=sda3\0" \ - "c=ffe\0" - -/* - * For emulation this causes u-boot to jump to the start of the - * proof point app code automatically - */ -#define CONFIG_PROOF_POINTS \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "cpu 1 release 0x29000000 - - -;" \ - "cpu 2 release 0x29000000 - - -;" \ - "cpu 3 release 0x29000000 - - -;" \ - "cpu 4 release 0x29000000 - - -;" \ - "cpu 5 release 0x29000000 - - -;" \ - "cpu 6 release 0x29000000 - - -;" \ - "cpu 7 release 0x29000000 - - -;" \ - "go 0x29000000" - -#define CONFIG_HVBOOT \ - "setenv bootargs config-addr=0x60000000; " \ - "bootm 0x01000000 - 0x00f00000" - -#define CONFIG_ALU \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "cpu 1 release 0x01000000 - - -;" \ - "cpu 2 release 0x01000000 - - -;" \ - "cpu 3 release 0x01000000 - - -;" \ - "cpu 4 release 0x01000000 - - -;" \ - "cpu 5 release 0x01000000 - - -;" \ - "cpu 6 release 0x01000000 - - -;" \ - "cpu 7 release 0x01000000 - - -;" \ - "go 0x01000000" - -#define CONFIG_LINUX \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "setenv ramdiskaddr 0x02000000;" \ - "setenv fdtaddr 0x00c00000;" \ - "setenv loadaddr 0x1000000;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" - -#define CONFIG_HDBOOT \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_RAMBOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $ramdiskaddr $ramdiskfile;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" - -#define CONFIG_BOOTCOMMAND CONFIG_LINUX - -#ifdef CONFIG_SECURE_BOOT -#include <asm/fsl_secure_boot.h> -#undef CONFIG_CMD_USB -#endif - -#endif /* __T2080QDS_H */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h new file mode 100644 index 0000000..36afe9e --- /dev/null +++ b/include/configs/T208xQDS.h @@ -0,0 +1,817 @@ +/* + * Copyright 2011-2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * T2080/T2081 QDS board configuration file + */ + +#ifndef __T208xQDS_H +#define __T208xQDS_H + +#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */ +#define CONFIG_MMC +#define CONFIG_SPI_FLASH +#define CONFIG_USB_EHCI +#if defined(CONFIG_PPC_T2080) +#define CONFIG_T2080QDS +#define CONFIG_FSL_SATA_V2 +#define CONFIG_SYS_SRIO /* Enable Serial RapidIO Support */ +#define CONFIG_SRIO1 /* SRIO port 1 */ +#define CONFIG_SRIO2 /* SRIO port 2 */ +#elif defined(CONFIG_PPC_T2081) +#define CONFIG_T2081QDS +#endif + +/* High Level Configuration Options */ +#define CONFIG_PHYS_64BIT +#define CONFIG_BOOKE +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_E500MC /* BOOKE e500mc family */ +#define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ +#define CONFIG_MP /* support multiple processors */ +#define CONFIG_ENABLE_36BIT_PHYS + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_ADDR_MAP 1 +#define CONFIG_SYS_NUM_ADDR_MAP 64 /* number of TLB1 entries */ +#endif + +#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ +#define CONFIG_SYS_NUM_CPC CONFIG_NUM_DDR_CONTROLLERS +#define CONFIG_FSL_IFC /* Enable IFC Support */ +#define CONFIG_FSL_LAW /* Use common FSL init code */ +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/t208xqds/t208x_pbi.cfg +#if defined(CONFIG_PPC_T2080) +#define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/t208xqds/t2080_rcw.cfg +#elif defined(CONFIG_PPC_T2081) +#define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/t208xqds/t2081_rcw.cfg +#endif +#endif + +#define CONFIG_SRIO_PCIE_BOOT_MASTER +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +/* Set 1M boot space */ +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR) +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_SYS_NO_FLASH +#endif + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff40000 +#endif + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_SYS_CACHE_STASHING +#define CONFIG_BTB /* toggle branch predition */ +#define CONFIG_DDR_ECC +#ifdef CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#endif + +#ifdef CONFIG_SYS_NO_FLASH +#if !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) && !defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_ENV_IS_NOWHERE +#endif +#else +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#endif + +#if defined(CONFIG_SPIFLASH) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_SDCARD) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (512 * 1658) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +#define CONFIG_ENV_IS_IN_REMOTE +#define CONFIG_ENV_ADDR 0xffe20000 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_ENV_IS_NOWHERE) +#define CONFIG_ENV_SIZE 0x2000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif + +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif + +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() +#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() + +/* + * Config the L3 Cache as L3 SRAM + */ +#define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE + +#define CONFIG_SYS_DCSRBAR 0xf0000000 +#define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 + +/* + * DDR Setup + */ +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (4 * CONFIG_DIMM_SLOTS_PER_CTLR) +#define CONFIG_DDR_SPD +#define CONFIG_SYS_FSL_DDR3 +#undef CONFIG_FSL_DDR_INTERACTIVE +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define CONFIG_SYS_SDRAM_SIZE 2048 /* for fixed parameter use */ +#define SPD_EEPROM_ADDRESS1 0x51 +#define SPD_EEPROM_ADDRESS2 0x52 +#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 +#define CTRL_INTLV_PREFERED cacheline + +/* + * IFC Definitions + */ +#define CONFIG_SYS_FLASH_BASE 0xe0000000 +#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) +#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 + +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ + FTIM0_NOR_TEADC(0x5) | \ + FTIM0_NOR_TEAHC(0x5)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1A) |\ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWPH(0x0E) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0x0 + +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} + +#define CONFIG_FSL_QIXIS /* use common QIXIS code */ +#define QIXIS_BASE 0xffdf0000 +#define QIXIS_LBMAP_SWITCH 6 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x04 +#define QIXIS_RST_CTL_RESET 0x83 +#define QIXIS_RST_FORCE_MEM 0x1 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_BASE_PHYS (0xf00000000ull | QIXIS_BASE) + +#define CONFIG_SYS_CSPR3_EXT (0xf) +#define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define CONFIG_SYS_AMASK3 IFC_AMASK(4*1024) +#define CONFIG_SYS_CSOR3 0x0 +/* QIXIS Timing parameters for IFC CS3 */ +#define CONFIG_SYS_CS3_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define CONFIG_SYS_CS3_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define CONFIG_SYS_CS3_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ + FTIM2_GPCM_TCH(0x0) | \ + FTIM2_GPCM_TWP(0x1f)) +#define CONFIG_SYS_CS3_FTIM3 0x0 + +/* NAND Flash on IFC */ +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_BASE 0xff800000 +#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) + +#define CONFIG_SYS_NAND_CSPR_EXT (0xf) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 2Byes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */\ + | CSOR_NAND_SPRZ_64 /* Spare size = 64 */\ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_DDR_LAW 11 +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#if defined(CONFIG_NAND) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#endif +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 + +#if defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_SYS_RAMBOOT +#endif + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ +#define CONFIG_MISC_INIT_R +#define CONFIG_HWCONFIG + +/* define to use L1 as initial stack */ +#define CONFIG_L1_INIT_RAM +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe0ec000 +/* The assembler doesn't like typecast */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ + ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ + CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) + +/* + * Serial Port + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x11C500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) +#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) +#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* + * I2C + */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_FSL +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C3_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C4_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x118000 +#define CONFIG_SYS_FSL_I2C2_OFFSET 0x118100 +#define CONFIG_SYS_FSL_I2C3_OFFSET 0x119000 +#define CONFIG_SYS_FSL_I2C4_OFFSET 0x119100 +#define CONFIG_SYS_FSL_I2C_SPEED 100000 +#define CONFIG_SYS_FSL_I2C2_SPEED 100000 +#define CONFIG_SYS_FSL_I2C3_SPEED 100000 +#define CONFIG_SYS_FSL_I2C4_SPEED 100000 +#define I2C_MUX_PCA_ADDR_PRI 0x77 /* I2C bus multiplexer,primary */ +#define I2C_MUX_PCA_ADDR_SEC1 0x75 /* I2C bus multiplexer,secondary 1 */ +#define I2C_MUX_PCA_ADDR_SEC2 0x76 /* I2C bus multiplexer,secondary 2 */ +#define I2C_MUX_CH_DEFAULT 0x8 + + +/* + * RapidIO + */ +#define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 +#define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull +#define CONFIG_SYS_SRIO1_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000 +#define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull +#define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */ +/* + * for slave u-boot IMAGE instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull +/* + * for slave UCODE and ENV instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */ + +/* slave core release by master*/ +#define CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET 0xe00e4 +#define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */ + +/* + * SRIO_PCIE_BOOT - SLAVE + */ +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR 0xFFE00000 +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR) +#endif + +/* + * eSPI - Enhanced SPI + */ +#ifdef CONFIG_SPI_FLASH +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH_SST +#define CONFIG_SPI_FLASH_STMICRO +#if defined(CONFIG_T2080QDS) +#define CONFIG_SPI_FLASH_SPANSION +#elif defined(CONFIG_T2081QDS) +#define CONFIG_SPI_FLASH_EON +#endif + +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE 0 +#endif + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCIE1 /* PCIE controler 1 */ +#define CONFIG_PCIE2 /* PCIE controler 2 */ +#define CONFIG_PCIE3 /* PCIE controler 3 */ +#define CONFIG_PCIE4 /* PCIE controler 4 */ +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ +/* controller 1, direct to uli, tgtid 3, Base address 20000 */ +#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ + +/* controller 2, Slot 2, tgtid 2, Base address 201000 */ +#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ + +/* controller 3, Slot 1, tgtid 1, Base address 202000 */ +#define CONFIG_SYS_PCIE3_MEM_VIRT 0xb0000000 +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc30000000ull +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ + +/* controller 4, Base address 203000 */ +#define CONFIG_SYS_PCIE4_MEM_VIRT 0xc0000000 +#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE4_MEM_PHYS 0xc40000000ull +#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull +#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ + +#ifdef CONFIG_PCI +#define CONFIG_PCI_INDIRECT_BRIDGE +#define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ +#define CONFIG_NET_MULTI +#define CONFIG_E1000 +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_DOS_PARTITION +#endif + +/* Qman/Bman */ +#ifndef CONFIG_NOBQFMAN +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 18 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 18 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull +#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 + +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_DPAA_PME +#define CONFIG_SYS_PMAN +#define CONFIG_SYS_DPAA_DCE +#define CONFIG_SYS_DPAA_RMAN /* RMan */ +#define CONFIG_SYS_INTERLAKEN + +/* Default address of microcode for the Linux Fman driver */ +#if defined(CONFIG_SPIFLASH) +/* + * env is stored at 0x100000, sector size is 0x10000, ucode is stored after + * env, so we got 0x110000. + */ +#define CONFIG_SYS_QE_FW_IN_SPIFLASH +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#elif defined(CONFIG_SDCARD) +/* + * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is + * about 825KB (1650 blocks), Env is stored after the image, and the env size is + * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_MMC +#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_QE_FMAN_FW_IN_NAND +#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +/* + * Slave has no ucode locally, it can fetch this from remote. When implementing + * in two corenet boards, slave's ucode could be stored in master's memory + * space, the address can be mapped from slave TLB->slave LAW-> + * slave SRIO or PCIE outbound window->master inbound window-> + * master LAW->the ucode address in master's memory space. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#else +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#endif +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif /* CONFIG_NOBQFMAN */ + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_REALTEK +#define CONFIG_PHY_TERANETICS +#define RGMII_PHY1_ADDR 0x1 +#define RGMII_PHY2_ADDR 0x2 +#define FM1_10GEC1_PHY_ADDR 0x3 +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1D +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F +#endif + +#ifdef CONFIG_FMAN_ENET +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "FM1@DTSEC3" +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* + * SATA + */ +#ifdef CONFIG_FSL_SATA_V2 +#define CONFIG_LIBATA +#define CONFIG_FSL_SATA +#define CONFIG_SYS_SATA_MAX_DEVICE 2 +#define CONFIG_SATA1 +#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR +#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA +#define CONFIG_SATA2 +#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR +#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA +#define CONFIG_LBA48 +#define CONFIG_CMD_SATA +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +#endif + +/* + * USB + */ +#ifdef CONFIG_USB_EHCI +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#define CONFIG_USB_EHCI_FSL +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_CMD_EXT2 +#define CONFIG_HAS_FSL_DR_USB +#endif + +/* + * SDHC + */ +#ifdef CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR +#define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +/* + * Environment + */ +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ERRATA +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_BDI + +#ifdef CONFIG_PCI +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks*/ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server */ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ +#define __USB_PHY_TYPE utmi + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:" \ + "ctlr_intlv=" __stringify(CTRL_INTLV_PREFERED) "," \ + "bank_intlv=auto;" \ + "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ + "netdev=eth0\0" \ + "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ + "tftpflash=tftpboot $loadaddr $uboot && " \ + "protect off $ubootaddr +$filesize && " \ + "erase $ubootaddr +$filesize && " \ + "cp.b $loadaddr $ubootaddr $filesize && " \ + "protect on $ubootaddr +$filesize && " \ + "cmp.b $loadaddr $ubootaddr $filesize\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=t2080qds/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=t2080qds/t2080qds.dtb\0" \ + "bdev=sda3\0" \ + "c=ffe\0" + +/* + * For emulation this causes u-boot to jump to the start of the + * proof point app code automatically + */ +#define CONFIG_PROOF_POINTS \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x29000000 - - -;" \ + "cpu 2 release 0x29000000 - - -;" \ + "cpu 3 release 0x29000000 - - -;" \ + "cpu 4 release 0x29000000 - - -;" \ + "cpu 5 release 0x29000000 - - -;" \ + "cpu 6 release 0x29000000 - - -;" \ + "cpu 7 release 0x29000000 - - -;" \ + "go 0x29000000" + +#define CONFIG_HVBOOT \ + "setenv bootargs config-addr=0x60000000; " \ + "bootm 0x01000000 - 0x00f00000" + +#define CONFIG_ALU \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x01000000 - - -;" \ + "cpu 2 release 0x01000000 - - -;" \ + "cpu 3 release 0x01000000 - - -;" \ + "cpu 4 release 0x01000000 - - -;" \ + "cpu 5 release 0x01000000 - - -;" \ + "cpu 6 release 0x01000000 - - -;" \ + "cpu 7 release 0x01000000 - - -;" \ + "go 0x01000000" + +#define CONFIG_LINUX \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "setenv ramdiskaddr 0x02000000;" \ + "setenv fdtaddr 0x00c00000;" \ + "setenv loadaddr 0x1000000;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_HDBOOT \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_LINUX + +#ifdef CONFIG_SECURE_BOOT +#include <asm/fsl_secure_boot.h> +#undef CONFIG_CMD_USB +#endif + +#endif /* __T208xQDS_H */
On 02/20/2014 09:16 PM, Shengzhou Liu wrote:
T2081 QDS is a high-performance computing evaluation, development and test platform supporting the T2081 QorIQ Power Architecture processor.
T2081QDS board Overview
- T2081 SoC integrating four 64-bit dual-threads e6500 cores up to 1.8GHz
- 2MB shared L2 and 512KB L3 CoreNet platform cache (CPC)
- CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation
- 32-/64-bit DDR3/DDR3LP SDRAM memory controller with ECC and interleaving
- Ethernet interfaces:
- Two on-board 10M/100M/1G bps RGMII ports
- Two 10Gbps XFI with on-board SFP+ cage
- 1Gbps/2.5Gbps SGMII Riser card
- 10Gbps XAUI Riser card
- Accelerator:
- DPAA components consist of FMan, BMan, QMan, PME, DCE and SEC
- SerDes:
- 8 lanes up to 10.3125GHz
- Supports SGMII, HiGig, XFI, XAUI and Aurora debug,
- IFC:
- 512MB NOR Flash, 2GB NAND Flash, PromJet debug port and Qixis FPGA
- eSPI:
- Three SPI flash (16MB N25Q128A + 16MB EN25S64 + 512KB SST25WF040)
- USB:
- Two USB2.0 ports with internal PHY (one Type-A + one micro Type mini-AB)
- PCIe:
- Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0 with SR-IOV)
- eSDHC:
- Supports various SD/SDHC/SDXC/eMMC devices with adapter cards and voltage translators
- I2C:
- Four I2C controllers.
- UART:
- Dual 4-pins UART serial ports
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com
v3: add fixup devicetree for t2081qds. v2: some update for serdes and network configuration.
board/freescale/t2080qds/Makefile | 12 - board/freescale/t2080qds/ddr.c | 119 ----- board/freescale/t2080qds/ddr.h | 72 --- board/freescale/t2080qds/eth_t2080qds.c | 517 ------------------- board/freescale/t2080qds/law.c | 34 -- board/freescale/t2080qds/pci.c | 23 - board/freescale/t2080qds/t2080_pbi.cfg | 41 -- board/freescale/t2080qds/t2080_rcw.cfg | 8 - board/freescale/t2080qds/t2080qds.c | 378 -------------- board/freescale/t2080qds/t2080qds.h | 13 - board/freescale/t2080qds/t2080qds_qixis.h | 47 -- board/freescale/t2080qds/tlb.c | 146 ------ board/freescale/t208xqds/Makefile | 14 + board/freescale/t208xqds/ddr.c | 119 +++++ board/freescale/t208xqds/ddr.h | 72 +++ board/freescale/t208xqds/eth_t208xqds.c | 648 ++++++++++++++++++++++++ board/freescale/t208xqds/law.c | 34 ++ board/freescale/t208xqds/pci.c | 23 + board/freescale/t208xqds/t2080_rcw.cfg | 8 + board/freescale/t208xqds/t2081_rcw.cfg | 8 + board/freescale/t208xqds/t208x_pbi.cfg | 41 ++ board/freescale/t208xqds/t208xqds.c | 459 +++++++++++++++++ board/freescale/t208xqds/t208xqds.h | 13 + board/freescale/t208xqds/t208xqds_qixis.h | 49 ++ board/freescale/t208xqds/tlb.c | 146 ++++++ boards.cfg | 15 +- include/configs/T2080QDS.h | 804 ----------------------------- include/configs/T208xQDS.h | 817 ++++++++++++++++++++++++++++++ 28 files changed, 2461 insertions(+), 2219 deletions(-) delete mode 100644 board/freescale/t2080qds/Makefile delete mode 100644 board/freescale/t2080qds/ddr.c delete mode 100644 board/freescale/t2080qds/ddr.h delete mode 100644 board/freescale/t2080qds/eth_t2080qds.c delete mode 100644 board/freescale/t2080qds/law.c delete mode 100644 board/freescale/t2080qds/pci.c delete mode 100644 board/freescale/t2080qds/t2080_pbi.cfg delete mode 100644 board/freescale/t2080qds/t2080_rcw.cfg delete mode 100644 board/freescale/t2080qds/t2080qds.c delete mode 100644 board/freescale/t2080qds/t2080qds.h delete mode 100644 board/freescale/t2080qds/t2080qds_qixis.h delete mode 100644 board/freescale/t2080qds/tlb.c create mode 100644 board/freescale/t208xqds/Makefile create mode 100644 board/freescale/t208xqds/ddr.c create mode 100644 board/freescale/t208xqds/ddr.h create mode 100644 board/freescale/t208xqds/eth_t208xqds.c create mode 100644 board/freescale/t208xqds/law.c create mode 100644 board/freescale/t208xqds/pci.c create mode 100644 board/freescale/t208xqds/t2080_rcw.cfg create mode 100644 board/freescale/t208xqds/t2081_rcw.cfg create mode 100644 board/freescale/t208xqds/t208x_pbi.cfg create mode 100644 board/freescale/t208xqds/t208xqds.c create mode 100644 board/freescale/t208xqds/t208xqds.h create mode 100644 board/freescale/t208xqds/t208xqds_qixis.h create mode 100644 board/freescale/t208xqds/tlb.c delete mode 100644 include/configs/T2080QDS.h create mode 100644 include/configs/T208xQDS.h
Next time, please format the patch with this command
git format-patch -M -C --find-copies-harder
It will generate a patch with detection of moving and copies code, so your change set will be much smaller.
York
- Accelerator:
- SerDes:
- IFC:
- eSPI:
- USB:
- PCIe:
- eSDHC:
- I2C:
- UART:
Applied to u-boot-mpc85xx/master. Thanks.
York
Shengzhou Liu
York Sun
