[U-Boot] [PATCH v2 0/6] Raspberry Pi4: add support for DFU over USB
Hi All!
This patchset enables support for DFU over USB protocol on Raspberry Pi4 board. The board has DWC2 UDC controller connected to the USB-C power connector. Enabling DFU on it, make the u-boot development much more convenient, as one no longer needs to swap SD-card between RPi4 board and host machine to update the u-boot binary.
Patches are based on current 'master' u-boot branch. They were tested on the 2019-07-10-raspbian-buster-lite.img sd-card image with the following lines added to config.txt: dtoverlay=dwc2,dr_mode=peripheral dtparam=i2c_arm=on dtparam=spi=on enable_uart=1 uart_2ndstage=1 kernel=u-boot.bin
To enable DFU, one has to enter follwing command: # dfu 0 mmc 0
During the development of this feature I've encountered a serious bugs in FAT write code. Over-writing discontiguous files always caused serious filesystem corruption. This was especially anoying, because the system environment is kept on FAT volume in uboot.env file, so 'saveenv' basically corrupted the boot partiting on the second call. Another bunch of the issues in the FAT write code has been revealed while removing predefined file size limit in DFU MMC code.
I hope that my fixes for FAT code will be helpful for non-RPi users too.
Best regards Marek Szyprowski Samsung R&D Institute Poland
Changelog:
v2: - added changes to rpi_4_defconfig too (arm64 version) - extended DFU entity list by confix.txt, cmdline.txt and Image.gz - fixed missing '\0' at the end of dfu_alt_info env - added reviewed-by tags - added patches for DFU MMC to remove file size limit - added patch for fat write to fix issues on non-zero file offset (revealed by previous patch)
v1: https://patchwork.ozlabs.org/cover/1162770/ - initial version
Patch summary:
Marek Szyprowski (6): fat: write: fix broken write to fragmented files fat: write: fix broken write at non-zero file offset dfu: mmc: rearrange the code dfu: mmc: remove file size limit for io operations usb: dwc2_udc_otg: add bcm2835 SoC (Raspberry Pi4) support config: enable DFU over USB on Raspberry Pi4 boards
configs/rpi_4_32b_defconfig | 11 +++ configs/rpi_4_defconfig | 11 +++ drivers/dfu/dfu_mmc.c | 93 +++++++++++++--------- drivers/usb/gadget/dwc2_udc_otg.c | 2 + drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 12 +-- fs/fat/fat_write.c | 18 ++--- include/configs/rpi.h | 17 ++++ 7 files changed, 113 insertions(+), 51 deletions(-)
The code for handing file overwrite incorrectly assumed that the file on disk is always contiguous. This resulted in corrupting disk structure every time when write to existing fragmented file happened. Fix this by adding proper check for cluster discontinuity and adjust chunk size on each partial write.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com Reviewed-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com Reviewed-by: Lukasz Majewski lukma@denx.de --- fs/fat/fat_write.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index 729cf39630..6cfa5b4565 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -794,6 +794,8 @@ set_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, __u8 *buffer,
newclust = get_fatent(mydata, endclust);
+ if ((newclust - 1) != endclust) + break; if (IS_LAST_CLUST(newclust, mydata->fatsize)) break; if (CHECK_CLUST(newclust, mydata->fatsize)) { @@ -811,7 +813,7 @@ set_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, __u8 *buffer, offset = 0; else offset = pos - cur_pos; - wsize = min(cur_pos + actsize, filesize) - pos; + wsize = min_t(unsigned long long, actsize, filesize - cur_pos); if (get_set_cluster(mydata, curclust, offset, buffer, wsize, &actsize)) { printf("Error get-and-setting cluster\n"); @@ -824,8 +826,6 @@ set_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, __u8 *buffer, if (filesize <= cur_pos) break;
- /* CHECK: newclust = get_fatent(mydata, endclust); */ - if (IS_LAST_CLUST(newclust, mydata->fatsize)) /* no more clusters */ break;
Handling of the start file offset was broken in the current code. Although the code skipped the needed clusters, it then tried to continue write with current cluster set to EOF, what caused assertion. It also lacked adjusting filesize in case of writing at the end of file and adjusting in-cluster offset for partial overwrite.
This patch fixes all those issues.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- fs/fat/fat_write.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index 6cfa5b4565..d7a814eb0c 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -756,14 +756,12 @@ set_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, __u8 *buffer, /* go to cluster at pos */ cur_pos = bytesperclust; while (1) { + newclust = get_fatent(mydata, curclust); if (pos <= cur_pos) break; - if (IS_LAST_CLUST(curclust, mydata->fatsize)) + if (IS_LAST_CLUST(newclust, mydata->fatsize)) break; - - newclust = get_fatent(mydata, curclust); - if (!IS_LAST_CLUST(newclust, mydata->fatsize) && - CHECK_CLUST(newclust, mydata->fatsize)) { + if (CHECK_CLUST(newclust, mydata->fatsize)) { debug("curclust: 0x%x\n", curclust); debug("Invalid FAT entry\n"); return -1; @@ -772,8 +770,9 @@ set_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, __u8 *buffer, cur_pos += bytesperclust; curclust = newclust; } - if (IS_LAST_CLUST(curclust, mydata->fatsize)) { + if (IS_LAST_CLUST(newclust, mydata->fatsize)) { assert(pos == cur_pos); + filesize -= pos; goto set_clusters; }
@@ -814,6 +813,7 @@ set_contents(fsdata *mydata, dir_entry *dentptr, loff_t pos, __u8 *buffer, else offset = pos - cur_pos; wsize = min_t(unsigned long long, actsize, filesize - cur_pos); + wsize -= offset; if (get_set_cluster(mydata, curclust, offset, buffer, wsize, &actsize)) { printf("Error get-and-setting cluster\n");
Hi Marek,
if (pos <= cur_pos) break;newclust = get_fatent(mydata, curclust);
- if (IS_LAST_CLUST(newclust, mydata->fatsize)) { assert(pos == cur_pos);
goto set_clusters; }filesize -= pos;
- cur_pos);
if (get_set_cluster(mydata, curclust, offset, buffer, wsize, &actsize)) { printf("Error get-and-setting cluster\n");wsize -= offset;
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Rename functions for bufferred file io operations to make them easier to understand. Also add missing file offset argument to them (currently unused). All this is a preparation to remove predefined file size limit (CONFIG_SYS_DFU_MAX_FILE_SIZE) for DFU read/write operations.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- drivers/dfu/dfu_mmc.c | 61 ++++++++++++++++++++++++------------------- 1 file changed, 34 insertions(+), 27 deletions(-)
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 403fd5351d..2d97f4528c 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -91,22 +91,8 @@ static int mmc_block_op(enum dfu_op op, struct dfu_entity *dfu, return 0; }
-static int mmc_file_buffer(struct dfu_entity *dfu, void *buf, long *len) -{ - if (dfu_file_buf_len + *len > CONFIG_SYS_DFU_MAX_FILE_SIZE) { - dfu_file_buf_len = 0; - return -EINVAL; - } - - /* Add to the current buffer. */ - memcpy(dfu_file_buf + dfu_file_buf_len, buf, *len); - dfu_file_buf_len += *len; - - return 0; -} - static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, - void *buf, u64 *len) + u64 offset, void *buf, u64 *len) { char dev_part_str[8]; int ret; @@ -137,7 +123,7 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu,
switch (op) { case DFU_OP_READ: - ret = fs_read(dfu->name, (size_t)buf, 0, 0, &size); + ret = fs_read(dfu->name, (size_t)buf, offset, 0, &size); if (ret) { puts("dfu: fs_read error!\n"); return ret; @@ -145,7 +131,7 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, *len = size; break; case DFU_OP_WRITE: - ret = fs_write(dfu->name, (size_t)buf, 0, *len, &size); + ret = fs_write(dfu->name, (size_t)buf, offset, *len, &size); if (ret) { puts("dfu: fs_write error!\n"); return ret; @@ -166,6 +152,30 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, return ret; }
+static int mmc_file_buf_write(struct dfu_entity *dfu, u64 offset, void *buf, long *len) +{ + if (dfu_file_buf_len + *len > CONFIG_SYS_DFU_MAX_FILE_SIZE) { + dfu_file_buf_len = 0; + return -EINVAL; + } + + /* Add to the current buffer. */ + memcpy(dfu_file_buf + dfu_file_buf_len, buf, *len); + dfu_file_buf_len += *len; + + return 0; +} + +static int mmc_file_buf_write_finish(struct dfu_entity *dfu) +{ + int ret = mmc_file_op(DFU_OP_WRITE, dfu, 0, dfu_file_buf, + &dfu_file_buf_len); + + /* Now that we're done */ + dfu_file_buf_len = 0; + return ret; +} + int dfu_write_medium_mmc(struct dfu_entity *dfu, u64 offset, void *buf, long *len) { @@ -177,7 +187,7 @@ int dfu_write_medium_mmc(struct dfu_entity *dfu, break; case DFU_FS_FAT: case DFU_FS_EXT4: - ret = mmc_file_buffer(dfu, buf, len); + ret = mmc_file_buf_write(dfu, offset, buf, len); break; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, @@ -193,11 +203,7 @@ int dfu_flush_medium_mmc(struct dfu_entity *dfu)
if (dfu->layout != DFU_RAW_ADDR) { /* Do stuff here. */ - ret = mmc_file_op(DFU_OP_WRITE, dfu, dfu_file_buf, - &dfu_file_buf_len); - - /* Now that we're done */ - dfu_file_buf_len = 0; + ret = mmc_file_buf_write_finish(dfu); }
return ret; @@ -214,7 +220,7 @@ int dfu_get_medium_size_mmc(struct dfu_entity *dfu, u64 *size) case DFU_FS_FAT: case DFU_FS_EXT4: dfu_file_buf_filled = -1; - ret = mmc_file_op(DFU_OP_SIZE, dfu, NULL, size); + ret = mmc_file_op(DFU_OP_SIZE, dfu, 0, NULL, size); if (ret < 0) return ret; if (*size > CONFIG_SYS_DFU_MAX_FILE_SIZE) @@ -227,14 +233,15 @@ int dfu_get_medium_size_mmc(struct dfu_entity *dfu, u64 *size) } }
-static int mmc_file_unbuffer(struct dfu_entity *dfu, u64 offset, void *buf, + +static int mmc_file_buf_read(struct dfu_entity *dfu, u64 offset, void *buf, long *len) { int ret; u64 file_len;
if (dfu_file_buf_filled == -1) { - ret = mmc_file_op(DFU_OP_READ, dfu, dfu_file_buf, &file_len); + ret = mmc_file_op(DFU_OP_READ, dfu, 0, dfu_file_buf, &file_len); if (ret < 0) return ret; dfu_file_buf_filled = file_len; @@ -259,7 +266,7 @@ int dfu_read_medium_mmc(struct dfu_entity *dfu, u64 offset, void *buf, break; case DFU_FS_FAT: case DFU_FS_EXT4: - ret = mmc_file_unbuffer(dfu, offset, buf, len); + ret = mmc_file_buf_read(dfu, offset, buf, len); break; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__,
Hi Marek,
Acked-by: Lukasz Majewski lukma@denx.de
return -EINVAL;
{ char dev_part_str[8]; int ret; @@ -137,7 +123,7 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, switch (op) { case DFU_OP_READ:
&size);
return -EINVAL;
- int ret = mmc_file_op(DFU_OP_WRITE, dfu, 0, dfu_file_buf,
&dfu_file_buf_len);
- return ret;
break; default: printf("%s: Layout (%s) not (yet) supported!\n",ret = mmc_file_buf_write(dfu, offset, buf, len);
__func__, @@ -193,11 +203,7 @@ int dfu_flush_medium_mmc(struct dfu_entity *dfu) if (dfu->layout != DFU_RAW_ADDR) { /* Do stuff here. */
&dfu_file_buf_len);
return ret;
if (ret < 0) return ret; if (*size > CONFIG_SYS_DFU_MAX_FILE_SIZE)ret = mmc_file_op(DFU_OP_SIZE, dfu, 0, NULL, size);
&file_len);
break; default: printf("%s: Layout (%s) not (yet) supported!\n",ret = mmc_file_buf_read(dfu, offset, buf, len);
__func__,
Lukasz Majewski
Add support for operations on files larger than CONFIG_SYS_DFU_MAX_FILE_SIZE. The buffered io mechanism is still used for aggregating io requests, so for files up to CONFIG_SYS_DFU_MAX_FILE_SIZE nothing is changed and they will be handled in a single filesystem call.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- drivers/dfu/dfu_mmc.c | 46 ++++++++++++++++++++++++++++--------------- 1 file changed, 30 insertions(+), 16 deletions(-)
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 2d97f4528c..b3174571ae 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -17,7 +17,7 @@
static unsigned char *dfu_file_buf; static u64 dfu_file_buf_len; -static long dfu_file_buf_filled; +static u64 dfu_file_buf_offset;
static int mmc_block_op(enum dfu_op op, struct dfu_entity *dfu, u64 offset, void *buf, long *len) @@ -123,7 +123,7 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu,
switch (op) { case DFU_OP_READ: - ret = fs_read(dfu->name, (size_t)buf, offset, 0, &size); + ret = fs_read(dfu->name, (size_t)buf, offset, *len, &size); if (ret) { puts("dfu: fs_read error!\n"); return ret; @@ -154,25 +154,38 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu,
static int mmc_file_buf_write(struct dfu_entity *dfu, u64 offset, void *buf, long *len) { - if (dfu_file_buf_len + *len > CONFIG_SYS_DFU_MAX_FILE_SIZE) { + int ret = 0; + + if (offset == 0) { dfu_file_buf_len = 0; - return -EINVAL; + dfu_file_buf_offset = 0; }
/* Add to the current buffer. */ + if (dfu_file_buf_len + *len > CONFIG_SYS_DFU_MAX_FILE_SIZE) + *len = CONFIG_SYS_DFU_MAX_FILE_SIZE - dfu_file_buf_len; memcpy(dfu_file_buf + dfu_file_buf_len, buf, *len); dfu_file_buf_len += *len;
- return 0; + if (dfu_file_buf_len == CONFIG_SYS_DFU_MAX_FILE_SIZE) { + ret = mmc_file_op(DFU_OP_WRITE, dfu, dfu_file_buf_offset, + dfu_file_buf, &dfu_file_buf_len); + dfu_file_buf_offset += dfu_file_buf_len; + dfu_file_buf_len = 0; + } + + return ret; }
static int mmc_file_buf_write_finish(struct dfu_entity *dfu) { - int ret = mmc_file_op(DFU_OP_WRITE, dfu, 0, dfu_file_buf, - &dfu_file_buf_len); + int ret = mmc_file_op(DFU_OP_WRITE, dfu, dfu_file_buf_offset, + dfu_file_buf, &dfu_file_buf_len);
/* Now that we're done */ dfu_file_buf_len = 0; + dfu_file_buf_offset = 0; + return ret; }
@@ -219,12 +232,9 @@ int dfu_get_medium_size_mmc(struct dfu_entity *dfu, u64 *size) return 0; case DFU_FS_FAT: case DFU_FS_EXT4: - dfu_file_buf_filled = -1; ret = mmc_file_op(DFU_OP_SIZE, dfu, 0, NULL, size); if (ret < 0) return ret; - if (*size > CONFIG_SYS_DFU_MAX_FILE_SIZE) - return -1; return 0; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, @@ -238,19 +248,23 @@ static int mmc_file_buf_read(struct dfu_entity *dfu, u64 offset, void *buf, long *len) { int ret; - u64 file_len;
- if (dfu_file_buf_filled == -1) { - ret = mmc_file_op(DFU_OP_READ, dfu, 0, dfu_file_buf, &file_len); + if (offset == 0 || offset >= dfu_file_buf_offset + dfu_file_buf_len || + offset + *len < dfu_file_buf_offset) { + u64 file_len = CONFIG_SYS_DFU_MAX_FILE_SIZE; + + ret = mmc_file_op(DFU_OP_READ, dfu, offset, dfu_file_buf, + &file_len); if (ret < 0) return ret; - dfu_file_buf_filled = file_len; + dfu_file_buf_len = file_len; + dfu_file_buf_offset = offset; } - if (offset + *len > dfu_file_buf_filled) + if (offset + *len > dfu_file_buf_offset + dfu_file_buf_len) return -EINVAL;
/* Add to the current buffer. */ - memcpy(buf, dfu_file_buf + offset, *len); + memcpy(buf, dfu_file_buf + offset - dfu_file_buf_offset, *len);
return 0; }
Hi Marek,
static int mmc_block_op(enum dfu_op op, struct dfu_entity *dfu, u64 offset, void *buf, long *len) @@ -123,7 +123,7 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, switch (op) { case DFU_OP_READ:
&size);
&size); if (ret) { puts("dfu: fs_read error!\n"); return ret; @@ -154,25 +154,38 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, static int mmc_file_buf_write(struct dfu_entity *dfu, u64 offset, void *buf, long *len) {
- int ret = 0;
- if (offset == 0) { dfu_file_buf_len = 0;
return -EINVAL;
- if (dfu_file_buf_len == CONFIG_SYS_DFU_MAX_FILE_SIZE) {
- return ret;
&dfu_file_buf_len);
return ret;
ret = mmc_file_op(DFU_OP_SIZE, dfu, 0, NULL, size); if (ret < 0) return ret;dfu_file_buf_filled = -1;
return 0; default: printf("%s: Layout (%s) not (yet) supported!\n",return -1;
u64 file_len;
&file_len);
- if (offset == 0 || offset >= dfu_file_buf_offset +
dfu_file_buf_len ||
dfu_file_buf,
if (ret < 0) return ret;&file_len);
}dfu_file_buf_offset = offset;
- memcpy(buf, dfu_file_buf + offset - dfu_file_buf_offset,
*len); return 0; }
Lukasz Majewski
Broadcom 2835 SoC requires special conversion of physical memory addresses for DMA purpose, so add needed wrappers to dwc2_udc_otg driver. Also extend the list of compatible devices with 'brcm,bcm2835-usb' entry. This allows to use USB gadget drivers (i.e. DFU) on Raspberry Pi4 boards.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com Reviewed-by: Lukasz Majewski lukma@denx.de --- drivers/usb/gadget/dwc2_udc_otg.c | 2 ++ drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 12 ++++++------ 2 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/gadget/dwc2_udc_otg.c b/drivers/usb/gadget/dwc2_udc_otg.c index 35f4147840..49f342eb21 100644 --- a/drivers/usb/gadget/dwc2_udc_otg.c +++ b/drivers/usb/gadget/dwc2_udc_otg.c @@ -31,6 +31,7 @@ #include <linux/usb/otg.h> #include <linux/usb/gadget.h>
+#include <phys2bus.h> #include <asm/byteorder.h> #include <asm/unaligned.h> #include <asm/io.h> @@ -1213,6 +1214,7 @@ static int dwc2_udc_otg_remove(struct udevice *dev)
static const struct udevice_id dwc2_udc_otg_ids[] = { { .compatible = "snps,dwc2" }, + { .compatible = "brcm,bcm2835-usb" }, { .compatible = "st,stm32mp1-hsotg", .data = (ulong)dwc2_set_stm32mp1_hsotg_params }, {}, diff --git a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c index 7eb632d3b1..5e695b4ff2 100644 --- a/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c +++ b/drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c @@ -28,7 +28,7 @@ static inline void dwc2_udc_ep0_zlp(struct dwc2_udc *dev) { u32 ep_ctrl;
- writel(usb_ctrl_dma_addr, ®->in_endp[EP0_CON].diepdma); + writel(phys_to_bus((unsigned long)usb_ctrl_dma_addr), ®->in_endp[EP0_CON].diepdma); writel(DIEPT_SIZ_PKT_CNT(1), ®->in_endp[EP0_CON].dieptsiz);
ep_ctrl = readl(®->in_endp[EP0_CON].diepctl); @@ -49,7 +49,7 @@ static void dwc2_udc_pre_setup(void)
writel(DOEPT_SIZ_PKT_CNT(1) | sizeof(struct usb_ctrlrequest), ®->out_endp[EP0_CON].doeptsiz); - writel(usb_ctrl_dma_addr, ®->out_endp[EP0_CON].doepdma); + writel(phys_to_bus((unsigned long)usb_ctrl_dma_addr), ®->out_endp[EP0_CON].doepdma);
ep_ctrl = readl(®->out_endp[EP0_CON].doepctl); writel(ep_ctrl|DEPCTL_EPENA, ®->out_endp[EP0_CON].doepctl); @@ -75,7 +75,7 @@ static inline void dwc2_ep0_complete_out(void)
ep_ctrl = readl(®->out_endp[EP0_CON].doepctl); writel(ep_ctrl|DEPCTL_EPENA|DEPCTL_CNAK, @@ -113,7 +113,7 @@ static int setdma_rx(struct dwc2_ep *ep, struct dwc2_request *req) (unsigned long) ep->dma_buf + ROUND(ep->len, CONFIG_SYS_CACHELINE_SIZE));
- writel((unsigned long) ep->dma_buf, ®->out_endp[ep_num].doepdma); + writel(phys_to_bus((unsigned long)ep->dma_buf), ®->out_endp[ep_num].doepdma); writel(DOEPT_SIZ_PKT_CNT(pktcnt) | DOEPT_SIZ_XFER_SIZE(length), ®->out_endp[ep_num].doeptsiz); writel(DEPCTL_EPENA|DEPCTL_CNAK|ctrl, ®->out_endp[ep_num].doepctl); @@ -161,7 +161,7 @@ static int setdma_tx(struct dwc2_ep *ep, struct dwc2_request *req) while (readl(®->grstctl) & TX_FIFO_FLUSH) ;
- writel((unsigned long) ep->dma_buf, ®->in_endp[ep_num].diepdma); + writel(phys_to_bus((unsigned long)ep->dma_buf), ®->in_endp[ep_num].diepdma); writel(DIEPT_SIZ_PKT_CNT(pktcnt) | DIEPT_SIZ_XFER_SIZE(length), ®->in_endp[ep_num].dieptsiz);
@@ -921,7 +921,7 @@ static int dwc2_udc_get_status(struct dwc2_udc *dev, (unsigned long) usb_ctrl + ROUND(sizeof(g_status), CONFIG_SYS_CACHELINE_SIZE));
- writel(usb_ctrl_dma_addr, ®->in_endp[EP0_CON].diepdma); + writel(phys_to_bus(usb_ctrl_dma_addr), ®->in_endp[EP0_CON].diepdma); writel(DIEPT_SIZ_PKT_CNT(1) | DIEPT_SIZ_XFER_SIZE(2), ®->in_endp[EP0_CON].dieptsiz);
Enable support for DFU over USB. This requires to enable USB gadget, DWC2 UDC OTG driver and DFU command. DFU entities are defined for the following firmware objects: u-boot.bin, uboot.env, config.txt, cmdline.txt and zImage/Image.gz.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com Reviewed-by: Lukasz Majewski lukma@denx.de --- configs/rpi_4_32b_defconfig | 11 +++++++++++ configs/rpi_4_defconfig | 11 +++++++++++ include/configs/rpi.h | 17 +++++++++++++++++ 3 files changed, 39 insertions(+)
diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index a31a617a5f..0a375b9736 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -12,6 +12,7 @@ CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y @@ -19,6 +20,7 @@ CONFIG_CMD_FS_UUID=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DFU_MMC=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y @@ -26,6 +28,15 @@ CONFIG_MMC_SDHCI_BCM2835=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index da8c960a2a..5b9be9b9c0 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -12,6 +12,7 @@ CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y @@ -19,6 +20,7 @@ CONFIG_CMD_FS_UUID=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DFU_MMC=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y @@ -26,6 +28,15 @@ CONFIG_MMC_SDHCI_BCM2835=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 77d2d5458a..bfe76eb392 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -70,6 +70,22 @@ #define CONFIG_TFTP_TSIZE #endif
+/* DFU over USB/UDC */ +#ifdef CONFIG_CMD_DFU +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_1M +#define CONFIG_SYS_DFU_MAX_FILE_SIZE SZ_2M + +#ifdef CONFIG_ARM64 +#define KERNEL_FILENAME "Image.gz" +#else +#define KERNEL_FILENAME "zImage" +#endif +#define ENV_DFU_SETTINGS \ + "dfu_alt_info=u-boot.bin fat 0 1;uboot.env fat 0 1;" \ + "config.txt fat 0 1;cmdline.txt fat 0 1;" \ + KERNEL_FILENAME " fat 0 1\0" +#endif + /* Console configuration */ #define CONFIG_SYS_CBSIZE 1024
@@ -185,6 +201,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "dhcpuboot=usb start; dhcp u-boot.uimg; bootm\0" \ ENV_DEVICE_SETTINGS \ + ENV_DFU_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ BOOTENV
Hi Marek,
First of all thanks for the patch and sorry for the late response.
- "dfu_alt_info=u-boot.bin fat 0 1;uboot.env fat 0 1;" \
I'm hesitant to take this file list as I think it highly depends on what you want to do with the board. For example at SUSE we use a ubootconfig.txt which get's added to config.txt. We might want to update grub, our kernel is on a different partition etc.
What do you think?
Other then that the patches look good, and I understand that they should go through my tree, also I don't know much about the FAT implementation.
Regards, Matthias
On 08/11/2019 17:57, Matthias Brugger wrote:
Hi Marek,
we are missing #else #define ENV_DFU_SETTINGS ""
otherwise armv7 builds are broken.
Regards, Matthias
What do you think?
Regards, Matthias
Hi Matthias,
What do you think?
Well, the above list is just a proposal. IMHO distro maintainers should adjust it for their needs. I can add a comment about that if you want.
Merging everything via a single tree will be the easiest way to handle the runtime dependencies.
Best regards
On 12/11/2019 10:52, Marek Szyprowski wrote:
Hi Matthias,
What do you think?
Ok, if you send a v3, then I'd propose to delete cmdline.txt as it is not part of U-Boot infrastructure.
Can please also fix the armv7 build as mentioned in my mail yesterday.
Ok, will do with you v3.
Regrads, Matthias
Enable support for DFU over USB. This requires to enable USB gadget, DWC2 UDC OTG driver and DFU command. DFU entities are defined for the following firmware objects: u-boot.bin, uboot.env, config.txt and zImage/Image.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com Reviewed-by: Lukasz Majewski lukma@denx.de --- Changelog: v3: - fixed non-RPi4 builds (missing #else ENV_DFU_SETTINGS def) - removed config.txt entity (not needed in uboot-based boot) - switched arm64 kernel filename to 'Image' --- configs/rpi_4_32b_defconfig | 11 +++++++++++ configs/rpi_4_defconfig | 11 +++++++++++ include/configs/rpi.h | 20 ++++++++++++++++++++ 3 files changed, 42 insertions(+)
diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index dc696906fd..a0ba8782bc 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -11,6 +11,7 @@ CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y @@ -19,6 +20,7 @@ CONFIG_OF_BOARD=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DFU_MMC=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y @@ -26,6 +28,15 @@ CONFIG_MMC_SDHCI_BCM2835=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index 2954e17ac3..2fcd56ebf3 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -11,6 +11,7 @@ CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y @@ -19,6 +20,7 @@ CONFIG_OF_BOARD=y CONFIG_ENV_FAT_INTERFACE="mmc" CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DFU_MMC=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y @@ -26,6 +28,15 @@ CONFIG_MMC_SDHCI_BCM2835=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 77d2d5458a..6723c7cc92 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -70,6 +70,25 @@ #define CONFIG_TFTP_TSIZE #endif
+/* DFU over USB/UDC */ +#ifdef CONFIG_CMD_DFU +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_1M +#define CONFIG_SYS_DFU_MAX_FILE_SIZE SZ_2M + +#ifdef CONFIG_ARM64 +#define KERNEL_FILENAME "Image" +#else +#define KERNEL_FILENAME "zImage" +#endif + +#define ENV_DFU_SETTINGS \ + "dfu_alt_info=u-boot.bin fat 0 1;uboot.env fat 0 1;" \ + "config.txt fat 0 1;" \ + KERNEL_FILENAME " fat 0 1\0" +#else +#define ENV_DFU_SETTINGS "" +#endif + /* Console configuration */ #define CONFIG_SYS_CBSIZE 1024
@@ -185,6 +204,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "dhcpuboot=usb start; dhcp u-boot.uimg; bootm\0" \ ENV_DEVICE_SETTINGS \ + ENV_DFU_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ BOOTENV
Looks good, I submitted the whole series for inclusion in v2020.01
Regards, Matthias
Changelog: v3:
- ENV_DFU_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ BOOTENV
Lukasz Majewski
Marek Szyprowski
Matthias Brugger
Matthias Brugger
