[U-Boot] [PATCH v2 1/2] fw_env: add redundant env support for MTD_ABSENT
Signed-off-by: Oliver Metz oliver@freetz.org Tested-by: Luka Perkov luka@openwrt.org ---
v1 -> v2: * correct spelling of redundant
tools/env/fw_env.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 44607b1..65be5f3 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -1136,6 +1136,9 @@ int fw_env_open(void) } else if (DEVTYPE(dev_current) == MTD_UBIVOLUME && DEVTYPE(!dev_current) == MTD_UBIVOLUME) { environment.flag_scheme = FLAG_INCREMENTAL; + } else if (DEVTYPE(dev_current) == MTD_ABSENT && + DEVTYPE(!dev_current) == MTD_ABSENT) { + environment.flag_scheme = FLAG_INCREMENTAL; } else { fprintf (stderr, "Incompatible flash types!\n"); return -1;
v1 -> v2: * fix checkpatch.pl warnings
tools/env/fw_env.c | 70 ++++++++++++++++++++++++++++++++---------------------- 1 file changed, 42 insertions(+), 28 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 65be5f3..577ce2d 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -727,27 +727,39 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count, MEMGETBADBLOCK needs 64 bits */ int rc;
- blocklen = DEVESIZE (dev); + /* + * For mtd devices only offset and size of the environment do matter + */ + if (mtd_type == MTD_ABSENT) { + blocklen = count; + top_of_range = offset + count; + erase_len = blocklen; + blockstart = offset; + block_seek = 0; + write_total = blocklen; + } else { + blocklen = DEVESIZE(dev);
- top_of_range = ((DEVOFFSET(dev) / blocklen) + - ENVSECTORS (dev)) * blocklen; + top_of_range = ((DEVOFFSET(dev) / blocklen) + + ENVSECTORS(dev)) * blocklen;
- erase_offset = (offset / blocklen) * blocklen; + erase_offset = (offset / blocklen) * blocklen;
- /* Maximum area we may use */ - erase_len = top_of_range - erase_offset; + /* Maximum area we may use */ + erase_len = top_of_range - erase_offset;
- blockstart = erase_offset; - /* Offset inside a block */ - block_seek = offset - erase_offset; + blockstart = erase_offset; + /* Offset inside a block */ + block_seek = offset - erase_offset;
- /* - * Data size we actually have to write: from the start of the block - * to the start of the data, then count bytes of data, and to the - * end of the block - */ - write_total = ((block_seek + count + blocklen - 1) / - blocklen) * blocklen; + /* + * Data size we actually write: from the start of the block + * to the start of the data, then count bytes of data, and + * to the end of the block + */ + write_total = ((block_seek + count + blocklen - 1) / + blocklen) * blocklen; + }
/* * Support data anywhere within erase sectors: read out the complete @@ -818,17 +830,18 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count, continue; }
- erase.start = blockstart; - ioctl (fd, MEMUNLOCK, &erase); - /* These do not need an explicit erase cycle */ - if (mtd_type != MTD_ABSENT && - mtd_type != MTD_DATAFLASH) - if (ioctl (fd, MEMERASE, &erase) != 0) { - fprintf (stderr, "MTD erase error on %s: %s\n", - DEVNAME (dev), - strerror (errno)); - return -1; - } + if (mtd_type != MTD_ABSENT) { + erase.start = blockstart; + ioctl(fd, MEMUNLOCK, &erase); + /* These do not need an explicit erase cycle */ + if (mtd_type != MTD_DATAFLASH) + if (ioctl(fd, MEMERASE, &erase) != 0) { + fprintf(stderr, + "MTD erase error on %s: %s\n", + DEVNAME(dev), strerror(errno)); + return -1; + } + }
if (lseek (fd, blockstart, SEEK_SET) == -1) { fprintf (stderr, @@ -847,7 +860,8 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count, return -1; }
- ioctl (fd, MEMLOCK, &erase); + if (mtd_type != MTD_ABSENT) + ioctl(fd, MEMLOCK, &erase);
processed += blocklen; block_seek = 0;
Applied to u-boot/master along with 2/2, thanks!
Luka Perkov
