[U-Boot-Users] RE: CFI conformant flash driver available
It helps if I attach the patch.
To enable the driver CFG_CFI_FLASH_DRIVER must be defined.
Attached is a patch for the cfi flash driver. The driver includes support for both the Intel and the AMD command sets.
The tar file contains 2 files, a patch for the existing sources and the cfi_flash.c which must be placed in the drivers directory. Thanks to all who are helping out. Please let me know if there are any problems or if things went well. If possible plese let me know what are the port width, chip width, flash chip and number of banks on successful uses of this driver. Wolfgang - please do not apply this until I get some feedback from those who are testing it. Thanks Brad Kemp
Brad Kemp you worte:
port
Thanks,I got it and plan to test it on LITW_DW first with 4 AM29DL323DB90VI[TOTAL 16Byte] in 4*8bit mode.As for INTEL flash,I am afriad of delaying some time for u-boot haven't booted successfully on my custom board with 4 E28F128J3A in 4*8bit mode.
Sam
_________________________________________________________ Do You Yahoo!? 繁华世界里,让我看清你 http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/cn_user_prof...
Brad,
I will test your new driver with my 2x 28F128AJ3 (2 x 16 = 32bit bus). I think I also got the older strataflash.c working on my Cogent CSB272 board last week. However, I added a couple of lines to support what my older driver was doing:
1) In flash_init(), I added flash_protect() calls to protect the monitor and environment sectors (the latter if ENV_IN_FLASH is set).
2) In flash_real_protect(), I added a couple of lines at the very beginning of the function to retrieve the current sector protection status from the flash and avoid resetting the protection if it has not changed. I did this because I did not want extra wear on the flash due to unnecessary flash_protect() calls done in #1.
I am on a different computer right now but it was something like:
if (flash_isset(info, sector, FLASH_OFFSET_PROTECT, FLASH_STATUS_PROTECT) == prot) return 0;
If you want I send send you the stataflash.c & the patch for you to review.
I have a question as well. The CFI driver is identifying the buffer in one chip and using that for buffered writes. For example, for Intel Strataflash 28F128AJ3 the buffer is 32 bytes. However, when I use 2 of these chips side by side (interleaved) shouldn't the buffer used be x2 (i.e. 64 bytes) as well. I think we are not fully taking advantage of total buffer available for buffered writes... For 4x8 (4 chips in 8 bit mode each) the total buffer would be 128 bytes.
Best regards. Tolunay
Dear Brad,
in message CFE1C3BDE1264C4D9E569E89B3AF8FA86C524D@grubber.seranoa.com you wrote:
Thanks, added.
Dear Mr. Wolfgang and Brad,
Wolfgang wrote:
To enable the driver CFG_CFI_FLASH_DRIVER must be defined. Attached is a patch for the cfi flash driver. The driver includes support for both the Intel and the AMD command sets.
Thanks, added.
Do you really want to release the patch on u-boot?There are still on the way to test it on two or more devices.At least,it didn't work in 4x8bit mode on LITE_DW.
Brad,do you want to give up testing the patch on more than one device?
Sam
_________________________________________________________ Do You Yahoo!? 完全免费的雅虎电邮,马上注册获赠额外60兆网络存储空间 http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.mail.yahoo.com
Dear Sam,
It's not "released", just added to the top-of-tree version of the CVS.
Having the patch checked in on the CVS server gives us all a common base to submit any further corrections or updates.
I'm looking forward to seeing your fixes.
Sorry and Fine!I misunderstood CVS nature.
As far as I can fix for cfi_flash.c,just two numbers and one program style.See my first patch as following.
Sam
--- drivers/cfi_flash.c Mon Feb 9 18:28:48 2004 +++ drivers/cfi_flash.c Tue Feb 10 19:49:34 2004 @@ -36,12 +36,12 @@ * * Tested Architectures * Port Width Chip Width # of banks Flash Chip Board - * 32 16 1 23F128J3 seranoa/eagle - * 64 16 1 23F128J3 seranoa/falcon + * 32 16 1 28F128J3 seranoa/eagle + * 64 16 1 28F128J3 seranoa/falcon */
/* The DEBUG define must be before common to enable debugging */ -//#define DEBUG 1 +/* #define DEBUG 1 */ #include <common.h> #include <asm/processor.h> #ifdef CFG_FLASH_CFI_DRIVER
Added. Thanks.
Brad Kemp
listmember@orkun.us
Sam Song
