[U-Boot] [PATCH v2] Remove static type from gunzip_bmp()
The current bmp routines support gzipped files, but compilation fails (under AVR32) due to the gunzip_bmp() function being defined as static.
This patch fixes this problem.
Signed-off-by: Mark Jackson mpfj@mimc.co.uk ---
common/cmd_bmp.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/cmd_bmp.c b/common/cmd_bmp.c index bc08b26..084ef98 100644 --- a/common/cmd_bmp.c +++ b/common/cmd_bmp.c @@ -46,7 +46,7 @@ int gunzip(void *, int, unsigned char *, unsigned long *); * didn't contain a valid BMP signature. */ #ifdef CONFIG_VIDEO_BMP_GZIP -static bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) +bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) { void *dst; unsigned long len; @@ -85,7 +85,7 @@ static bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) return bmp; } #else -static bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) +bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) { return NULL; }
Dear Mark Jackson,
As mentioned before: if you make this function publicly visible, then please also add a prototype declaration for it (and get rid of any private "external ..." declararions elsewhere).
Mark Jackson
