[PATCH v2 15/19] ARM: dts: i.mxrt1050: add lcdif node
Add lcdif node to SoC.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi index b1d98e6feb..0123f4788c 100644 --- a/arch/arm/dts/imxrt1050.dtsi +++ b/arch/arm/dts/imxrt1050.dtsi @@ -13,6 +13,7 @@
/ { aliases { + display0 = &lcdif; gpio0 = &gpio1; gpio1 = &gpio2; gpio2 = &gpio3; @@ -142,5 +143,14 @@ interrupt-controller; #interrupt-cells = <2>; }; + + lcdif: lcdif@402b8000 { + compatible = "fsl,imxrt-lcdif"; + reg = <0x402b8000 0x10000>; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMXRT1050_CLK_LCDIF>; + clock-names = "per"; + status = "disabled"; + }; }; };
Linux doesn't provide skeleton.dtsi file so let's remove its include and provide #address-cells/size-cells = <1> that were defined in skeleton.dtsi before.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050.dtsi | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/imxrt1050.dtsi b/arch/arm/dts/imxrt1050.dtsi index 0123f4788c..7cfe5f5c95 100644 --- a/arch/arm/dts/imxrt1050.dtsi +++ b/arch/arm/dts/imxrt1050.dtsi @@ -4,7 +4,6 @@ * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com */
-#include "skeleton.dtsi" #include "armv7-m.dtsi" #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/clock/imxrt1050-clock.h> @@ -12,6 +11,9 @@ #include <dt-bindings/memory/imxrt-sdram.h>
/ { + #address-cells = <1>; + #size-cells = <1>; + aliases { display0 = &lcdif; gpio0 = &gpio1;
Add lcdif node and its pinctrl.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/imxrt1050-evk.dts | 60 ++++++++++++++++++++++++++++++++++ 1 file changed, 60 insertions(+)
diff --git a/arch/arm/dts/imxrt1050-evk.dts b/arch/arm/dts/imxrt1050-evk.dts index 56b75986e2..b5e781275e 100644 --- a/arch/arm/dts/imxrt1050-evk.dts +++ b/arch/arm/dts/imxrt1050-evk.dts @@ -185,6 +185,33 @@ 0x17061 >; }; + + pinctrl_lcdif: lcdifgrp { + u-boot,dm-spl; + fsl,pins = < + MXRT1050_IOMUXC_GPIO_B0_00_LCD_CLK 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_01_LCD_ENABLE 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_02_LCD_HSYNC 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_03_LCD_VSYNC 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_04_LCD_DATA00 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_05_LCD_DATA01 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_06_LCD_DATA02 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_07_LCD_DATA03 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_08_LCD_DATA04 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_09_LCD_DATA05 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_10_LCD_DATA06 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_11_LCD_DATA07 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_12_LCD_DATA08 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_13_LCD_DATA09 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_14_LCD_DATA10 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B0_15_LCD_DATA11 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B1_01_LCD_DATA13 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B1_02_LCD_DATA14 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B1_03_LCD_DATA15 0x1b0b1 + MXRT1050_IOMUXC_GPIO_B1_15_GPIO2_IO31 0x0b069 + MXRT1050_IOMUXC_GPIO_AD_B0_02_GPIO1_IO02 0x0b069 + >; + }; }; };
@@ -198,3 +225,36 @@
cd-gpios = <&gpio2 28 GPIO_ACTIVE_LOW>; }; + +&lcdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcdif>; + display = <&display0>; + status = "okay"; + + assigned-clocks = <&clks IMXRT1050_CLK_LCDIF_SEL>; + assigned-clock-parents = <&clks IMXRT1050_CLK_PLL5_VIDEO>; + + display0: display0 { + bits-per-pixel = <16>; + bus-width = <16>; + + display-timings { + timing0: timing0 { + clock-frequency = <9300000>; + hactive = <480>; + vactive = <272>; + hback-porch = <4>; + hfront-porch = <8>; + vback-porch = <4>; + vfront-porch = <8>; + hsync-len = <41>; + vsync-len = <10>; + de-active = <1>; + pixelclk-active = <0>; + hsync-active = <0>; + vsync-active = <0>; + }; + }; + }; +};
Enable DM_VIDEO subsystem and its BACKLIGHT_GPIO. Then enable SYS_WHITE_ON_BLACK to have classic black background on display. Need also to enable CONFIG_SYS_CONSOLE_ENV_OVERWRITE to retrieve stdin/stdout/stderr from CONFIG_EXTRA_ENV_SETTINGS.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- configs/imxrt1050-evk_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/imxrt1050-evk_defconfig b/configs/imxrt1050-evk_defconfig index 71970552c0..810f391fdc 100644 --- a/configs/imxrt1050-evk_defconfig +++ b/configs/imxrt1050-evk_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_TEXT_BASE=0x20209000 CONFIG_DISTRO_DEFAULTS=y CONFIG_SD_BOOT=y # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set @@ -62,6 +63,9 @@ CONFIG_IMXRT_SDRAM=y CONFIG_FSL_LPUART=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y +CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y +CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_SHA1=y CONFIG_SHA256=y CONFIG_HEXDUMP=y
mxsfb needs a dcache function not implemented in cortex-M7, so for the moment let's keep dcache not enabled.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- configs/imxrt1050-evk_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/imxrt1050-evk_defconfig b/configs/imxrt1050-evk_defconfig index 810f391fdc..25d0ba191c 100644 --- a/configs/imxrt1050-evk_defconfig +++ b/configs/imxrt1050-evk_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y +CONFIG_SYS_DCACHE_OFF=y +# CONFIG_SPL_SYS_DCACHE_OFF is not set CONFIG_ARCH_IMXRT=y CONFIG_SYS_TEXT_BASE=0x80002000 CONFIG_SPL_GPIO_SUPPORT=y
Sorry I've sent this patch twice.
Giulio Benetti
