[PATCH] ram: rk3399: don't assume phy_io_config() uses real regs
In the RK3399 DRAM driver, the function set_ds_odt() supports operating in two different modes, selected by the ctl_phy_reg argument: when true, the function reads and writes directly from the DRAM registers, accessed through "chan->pctl->denali_*"; when false, the function reads and writes from an array, accessed through "params->pctl_regs.denali_*", which is written to DRAM registers at a later time.
However, phy_config_io(), which is called by set_ds_odt() to do a subset of its register operations, operates directly on DRAM registers at all times. This means that it reads incorrect values (and writes new values prematurely) when ctl_phy_reg in set_ds_odt() is false. Fix this by passing in the address of the registers to work with.
This prevents an "Invalid DRV value" error in the SPL debug log and (presumably) results in a more correct end state. See the following logs from a RK3399 NanoPi M4 board (4GB LPDDR3):
Before:
sdram_init() Starting SDRAM initialization... phy_io_config() Invalid DRV value. phy_io_config() Invalid DRV value. sdram_init() sdram_init: data trained for rank 2, ch 0 phy_io_config() Invalid DRV value. phy_io_config() Invalid DRV value. sdram_init() sdram_init: data trained for rank 2, ch 1 Channel 0: LPDDR3, 933MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB Channel 1: LPDDR3, 933MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB 256B stride 256B stride sdram_init() Finish SDRAM initialization...
After:
sdram_init() Starting SDRAM initialization... sdram_init() sdram_init: data trained for rank 2, ch 0 sdram_init() sdram_init: data trained for rank 2, ch 1 Channel 0: LPDDR3, 933MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB Channel 1: LPDDR3, 933MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB 256B stride 256B stride sdram_init() Finish SDRAM initialization...
Signed-off-by: Thomas Hebb tommyhebb@gmail.com ---
drivers/ram/rockchip/sdram_rk3399.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index aa2ea920ba..9e61641511 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -337,11 +337,9 @@ static void set_memory_map(const struct chan_info *chan, u32 channel, writel(0x2EC7FFFF, &denali_pi[34]); }
-static int phy_io_config(const struct chan_info *chan, +static int phy_io_config(u32 *denali_phy, u32 *denali_ctl, const struct rk3399_sdram_params *params, u32 mr5) { - u32 *denali_phy = chan->publ->denali_phy; - u32 *denali_ctl = chan->pctl->denali_ctl; u32 vref_mode_dq, vref_value_dq, vref_mode_ac, vref_value_ac; u32 mode_sel; u32 speed; @@ -780,7 +778,7 @@ static void set_ds_odt(const struct chan_info *chan, /* phy_pad_fdbk_term 1bit DENALI_PHY_930 offset_17 */ clrsetbits_le32(&denali_phy[930], 0x1 << 17, reg_value);
- phy_io_config(chan, params, mr5); + phy_io_config(denali_phy, denali_ctl, params, mr5); }
static void pctl_start(struct dram_info *dram,
Before:
After:
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Kever Yang
Thomas Hebb
