[U-Boot] FW: [PATCH 5/6] spl: Make CONFIG_SPL_BUILD contain more functionality
-----Original Message----- From: Wood Scott-B07421 Sent: Wednesday, May 22, 2013 3:42 AM To: Zhang Ying-B40530 Cc: u-boot@lists.denx.de; afleming@gmail.com; Xie Xiaobo-R63061; Zhang Ying-B40530; Ilya Yanok Subject: Re: [PATCH 5/6] spl: Make CONFIG_SPL_BUILD contain more functionality
Please change the title and the rest of the changelog to describe what functionality you're adding and why.
On 05/20/2013 01:07:27 AM, ying.zhang@freescale.com wrote:
diff --git a/common/env_common.c b/common/env_common.c index 906b41f..8cb81e9 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -156,7 +156,6 @@ int set_default_vars(int nvars, char * const vars[]) H_NOCLEAR | H_INTERACTIVE, nvars, vars); }
-#ifndef CONFIG_SPL_BUILD /*
- Check if CRC is valid and (if yes) import the environment.
- Note that "buf" may or may not be aligned.
@@ -188,7 +187,6 @@ int env_import(const char *buf, int check)
return 0; } -#endif
This ifndef was introduced by Ilya Yanok in commit 7ac2fe2da21d292aeaf3af74e5c80de9ce9dab56.
Ilya, what are the consequences of removing this? Is there some other symbol we can use here?
-Scott [Zhang Ying] Ilya, Can you answer this question? Thanks.
Zhang Ying-B40530
