[U-Boot] [PATCH] mmc: Move FSL_ESDHC under if MMC
The fsl esdhc driver was the only mmc driver that could be enabled if mmc support was off. It does not appear to compile in such a configuration.
Move it to be inside the "if" that makes it conditional on MMC support.
It's still possible to turn off DM_MMC and enable the driver.
It looks like a rebase mistake in the original commit that added it, as it would behaved as expected if just moved up a bit in the file.
Cc: Peng Fan peng.fan@nxp.com Cc: Mario Six mario.six@gdsys.cc Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Trent Piepho tpiepho@impinj.com --- drivers/mmc/Kconfig | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 496b2cba64..08c2dd2541 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -619,6 +619,12 @@ config MMC_MTK This is needed if support for any SD/SDIO/MMC devices is required. If unsure, say N.
+config FSL_ESDHC + bool "Freescale/NXP eSDHC controller support" + help + This selects support for the eSDHC (enhanced secure digital host + controller) found on numerous Freescale/NXP SoCs. + endif
config TEGRA124_MMC_DISABLE_EXT_LOOPBACK @@ -632,12 +638,6 @@ config TEGRA124_MMC_DISABLE_EXT_LOOPBACK TODO(marcel.ziswiler@toradex.com): Move to device tree controlled approach once proper kernel integration made it mainline.
-config FSL_ESDHC - bool "Freescale/NXP eSDHC controller support" - help - This selects support for the eSDHC (enhanced secure digital host - controller) found on numerous Freescale/NXP SoCs. - endmenu
config SYS_FSL_ERRATUM_ESDHC111
This is a configuration option specific to the tegra controller.
Doing it this way makes it show up directly under the tegra controller option, indented one level, as "Disable external clock loopback".
The way it is now, it shows up at the end of the controller list, not indented, as if it's some kind of generic MMC configuration option.
Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Simon Glass sjg@chromium.org Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Tom Warren twarren@nvidia.com Signed-off-by: Trent Piepho tpiepho@impinj.com --- drivers/mmc/Kconfig | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 08c2dd2541..759a1cceb4 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -542,6 +542,17 @@ config MMC_SDHCI_TEGRA
If unsure, say N.
+config TEGRA124_MMC_DISABLE_EXT_LOOPBACK + bool "Disable external clock loopback" + depends on MMC_SDHCI_TEGRA && TEGRA124 + help + Disable the external clock loopback and use the internal one on SDMMC3 + as per the SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 bits + being set to 0xfffd according to the TRM. + + TODO(marcel.ziswiler@toradex.com): Move to device tree controlled + approach once proper kernel integration made it mainline. + config MMC_SDHCI_ZYNQ bool "Arasan SDHCI controller support" depends on ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL @@ -627,17 +638,6 @@ config FSL_ESDHC
endif
-config TEGRA124_MMC_DISABLE_EXT_LOOPBACK - bool "Disable external clock loopback" - depends on MMC_SDHCI_TEGRA && TEGRA124 - help - Disable the external clock loopback and use the internal one on SDMMC3 - as per the SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 bits - being set to 0xfffd according to the TRM. - - TODO(marcel.ziswiler@toradex.com): Move to device tree controlled - approach once proper kernel integration made it mainline. - endmenu
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
If unsure, say N.
- help
on SDMMC3
bits
controlled
endif
- help
on SDMMC3
bits
controlled
endmenu
Marcel Ziswiler
Trent Piepho
