[U-Boot] [PATCH v2] Allow AM33xx boards to setup GPMC chipselects.
Expose the enable_gpmc_cs_config() function so AM33xx based boards can register GPMC chip selects.
Changes in V2: - Indicate this is for AM33xx (not OMAP2)
Signed-off-by: Mark Jackson mpfj@newflow.co.uk --- arch/arm/include/asm/arch-am33xx/sys_proto.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/arch-am33xx/sys_proto.h b/arch/arm/include/asm/arch-am33xx/sys_proto.h index 588d8de..97ab60d 100644 --- a/arch/arm/include/asm/arch-am33xx/sys_proto.h +++ b/arch/arm/include/asm/arch-am33xx/sys_proto.h @@ -35,5 +35,7 @@ void ddr_pll_config(unsigned int ddrpll_M); void sdelay(unsigned long); void gpmc_init(void); +void enable_gpmc_cs_config(const u32 *gpmc_config, struct gpmc_cs *cs, u32 base, + u32 size); void omap_nand_switch_ecc(int); #endif
"Mark" == Mark Jackson mpfj-list@mimc.co.uk writes:
Mark> Expose the enable_gpmc_cs_config() function so AM33xx based boards can Mark> register GPMC chip selects.
Mark> Changes in V2: Mark> - Indicate this is for AM33xx (not OMAP2)
Mark> Signed-off-by: Mark Jackson mpfj@newflow.co.uk Mark> --- Mark> arch/arm/include/asm/arch-am33xx/sys_proto.h | 2 ++ Mark> 1 file changed, 2 insertions(+)
Mark> diff --git a/arch/arm/include/asm/arch-am33xx/sys_proto.h Mark> b/arch/arm/include/asm/arch-am33xx/sys_proto.h Mark> index 588d8de..97ab60d 100644 Mark> --- a/arch/arm/include/asm/arch-am33xx/sys_proto.h Mark> +++ b/arch/arm/include/asm/arch-am33xx/sys_proto.h Mark> @@ -35,5 +35,7 @@ void ddr_pll_config(unsigned int ddrpll_M); Mark> void sdelay(unsigned long); Mark> void gpmc_init(void); Mark> +void enable_gpmc_cs_config(const u32 *gpmc_config, struct gpmc_cs Mark> *cs, u32 base, Mark> + u32 size);
Seems like your mailer line wrapped the patch.
Oops ... resent.
Mark Jackson
Peter Korsgaard
