[U-Boot] Pull request for UEFI sub-system for efi-2020-01-rc2
The following changes since commit ffc379b42c85466e1dd4c8fee8268801f26d2ab8:
Merge tag 'mips-pull-2019-10-25' of git://git.denx.de/u-boot-mips (2019-10-25 20:07:24 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2020-01-rc2
for you to fetch changes up to e731af4893f7741c66254161ad9b6f5280369895:
efi_loader: correct includes in efi_variable.c (2019-10-30 17:49:41 +0100)
The size increase in cmd/nvedit_efi.c should not worry you too much as this is not built by default except on QEMU.
Gitlab and Travis showed no problems: https://gitlab.denx.de/u-boot/custodians/u-boot-efi/pipelines/1159 https://travis-ci.org/xypron2/u-boot/builds/605091156
Primary key fingerprint: 6DC4 F9C7 1F29 A6FA 06B7 6D33 C481 DBBC 2C05 1AC4
---------------------------------------------------------------- Pull request for UEFI sub-system for efi-2020-01-rc2
Provide a better user interface for setting UEFI variables.
Bug fixes: - ext4 file system not discovered on UEFI block device - 'make tests' build error on 32bit systems
---------------------------------------------------------------- AKASHI Takahiro (1): cmd: env: extend "env [set|print] -e" to manage UEFI variables
Heinrich Schuchardt (2): blk: set log2blksz in blk_create_device() efi_loader: correct includes in efi_variable.c
cmd/nvedit.c | 19 ++- cmd/nvedit_efi.c | 277 ++++++++++++++++++++++++++++++++++++------ drivers/block/blk-uclass.c | 1 + lib/efi_loader/efi_variable.c | 8 +- 4 files changed, 256 insertions(+), 49 deletions(-)
