[PULL] u-boot-usb/master
Late bunch of USB fixes (incl. the xhci usb 3.1 support)
The following changes since commit a49930f4c6ed5dcbf5127f7bf6d189afa92bffb3:
Merge https://source.denx.de/u-boot/custodians/u-boot-x86 (2021-09-22 11:43:12 -0400)
git://source.denx.de/u-boot-usb.git master
for you to fetch changes up to 53eed9adfac17921511ebf9e00c429bcb385d231:
usb: xhci-dwc3: Add support for USB 3.1 controllers (2021-09-22 21:29:56 +0200)
---------------------------------------------------------------- Mark Kettenis (1): usb: xhci-dwc3: Add support for USB 3.1 controllers
Matthias Schiffer (4): usb: add support for ULPI/SERIAL/HSIC PHY modes include/configs: replace MXC_EHCI_MODE_SERIAL with PORT_PTS_SERIAL usb: ehci-ci: remove redundant PORTSC flag definitions usb: ehci-mx6: use phy_type from device tree
Samuel Holland (4): phy: sun50i-usb3: Add a driver for the H6 USB3 PHY usb: xhci-pci: Move reset logic out of XHCI core usb: xhci-dwc3: Add support for clocks/resets configs: Enable USB3 on Allwinner H6 boards
configs/orangepi_3_defconfig | 5 +++ configs/pine_h64_defconfig | 5 +++ drivers/phy/allwinner/Kconfig | 8 +++++ drivers/phy/allwinner/Makefile | 1 + drivers/phy/allwinner/phy-sun50i-usb3.c | 171 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/common/common.c | 3 ++ drivers/usb/host/ehci-mx6.c | 25 ++++++++++++-- drivers/usb/host/xhci-dwc3.c | 59 +++++++++++++++++++++++++++++++- drivers/usb/host/xhci-mem.c | 2 -- drivers/usb/host/xhci-pci.c | 52 +++++++++++++++++++++++++--- drivers/usb/host/xhci.c | 35 ------------------- include/configs/zmx25.h | 2 +- include/linux/usb/phy.h | 3 ++ include/usb/ehci-ci.h | 12 +------ include/usb/xhci.h | 2 -- 15 files changed, 327 insertions(+), 58 deletions(-) create mode 100644 drivers/phy/allwinner/phy-sun50i-usb3.c
