[PATCH] mmc: dw_mmc: Don't return error if data busy timeout
As described in [1], some poor hardware or cards would fail to release the bus and keep driving data lines low. Ignore it and send the next cmd directly seems okay for most cases.
[1]: https://patchwork.kernel.org/project/linux-mmc/patch/1424458179-5456-1-git-s...
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- drivers/mmc/dw_mmc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 400066fa99..e103664145 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -262,8 +262,8 @@ static int dwmci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd,
while (dwmci_readl(host, DWMCI_STATUS) & DWMCI_BUSY) { if (get_timer(start) > timeout) { - debug("%s: Timeout on data busy\n", __func__); - return -ETIMEDOUT; + debug("%s: Timeout on data busy, continue anyway\n", __func__); + break; } }
I didn't test on my board. But it's not same with below patch. Did you check all cases?
Best Regards, Jaehoon Chung
return -ETIMEDOUT;
} }break;
Jaehoon Chung
Yang Xiwen
