[U-Boot] [PATCH v8 01/31] mtd: nand: Introduce CONFIG_SYS_NAND_BUSWIDTH_16BIT
Introduce CONFIG_SYS_NAND_BUSWIDTH_16BIT option so that other NAND controller drivers could use it when a 16-bit NAND is deployed.
drivers/mtd/nand/ndfc has CONFIG_SYS_NDFC_16BIT, so just rename it, so that other NAND drivers could reuse the same symbol.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Reviewed-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - New patch.
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
README | 9 ++++++--- drivers/mtd/nand/ndfc.c | 4 ++-- 2 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/README b/README index d8cb394..830c45e 100644 --- a/README +++ b/README @@ -3713,9 +3713,12 @@ Low Level (hardware related) configuration options: - CONFIG_SYS_SRIOn_MEM_SIZE: Size of SRIO port 'n' memory region
-- CONFIG_SYS_NDFC_16 - Defined to tell the NDFC that the NAND chip is using a - 16 bit bus. +- CONFIG_SYS_NAND_BUSWIDTH_16BIT + Defined to tell the NAND controller that the NAND chip is using + a 16 bit bus. + Not all NAND drivers use this symbol. + Example of driver that uses it: + - drivers/mtd/nand/ndfc.c
- CONFIG_SYS_NDFC_EBC0_CFG Sets the EBC0_CFG register for the NDFC. If not defined diff --git a/drivers/mtd/nand/ndfc.c b/drivers/mtd/nand/ndfc.c index 6ebbb5e..213d2c9 100644 --- a/drivers/mtd/nand/ndfc.c +++ b/drivers/mtd/nand/ndfc.c @@ -156,7 +156,7 @@ static uint8_t ndfc_read_byte(struct mtd_info *mtd)
struct nand_chip *chip = mtd->priv;
-#ifdef CONFIG_SYS_NDFC_16BIT +#ifdef CONFIG_SYS_NAND_BUSWIDTH_16BIT return (uint8_t) readw(chip->IO_ADDR_R); #else return readb(chip->IO_ADDR_R); @@ -218,7 +218,7 @@ int board_nand_init(struct nand_chip *nand) nand->ecc.bytes = 3; nand->select_chip = ndfc_select_chip;
-#ifdef CONFIG_SYS_NDFC_16BIT +#ifdef CONFIG_SYS_NAND_BUSWIDTH_16BIT nand->options |= NAND_BUSWIDTH_16; #endif
Currently is_16bit_nand() is a per SoC function and it decides the bus nand width by reading some boot related registers.
This method works when NAND is the boot medium, but does not work if another boot medium is used. For example: booting from a SD card and then using NAND to store the environment variables, would lead to the following error:
NAND bus width 16 instead 8 bit No NAND device found!!! 0 MiB
Use CONFIG_SYS_NAND_BUSWIDTH_16BIT symbol to decide the bus width.
If it is defined in the board file, then consider 16-bit NAND bus-width, otherwise assume 8-bit NAND is used.
This also aligns with Documentation/devicetree/bindings/mtd/nand.txt, which states:
nand-bus-width : 8 or 16 bus width if not present 8
README | 3 ++- drivers/mtd/nand/mxc_nand.c | 37 +++---------------------------------- 2 files changed, 5 insertions(+), 35 deletions(-)
diff --git a/README b/README index 830c45e..11ffa71 100644 --- a/README +++ b/README @@ -3717,8 +3717,9 @@ Low Level (hardware related) configuration options: Defined to tell the NAND controller that the NAND chip is using a 16 bit bus. Not all NAND drivers use this symbol. - Example of driver that uses it: + Example of drivers that use it: - drivers/mtd/nand/ndfc.c + - drivers/mtd/nand/mxc_nand.c
- CONFIG_SYS_NDFC_EBC0_CFG Sets the EBC0_CFG register for the NDFC. If not defined diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index d0ded48..bb475f2 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -98,45 +98,14 @@ static struct nand_ecclayout nand_hw_eccoob2k = { #endif #endif
-#ifdef CONFIG_MX27 static int is_16bit_nand(void) { - struct system_control_regs *sc_regs = - (struct system_control_regs *)IMX_SYSTEM_CTL_BASE; - - if (readl(&sc_regs->fmcr) & NF_16BIT_SEL) - return 1; - else - return 0; -} -#elif defined(CONFIG_MX31) -static int is_16bit_nand(void) -{ - struct clock_control_regs *sc_regs = - (struct clock_control_regs *)CCM_BASE; - - if (readl(&sc_regs->rcsr) & CCM_RCSR_NF16B) - return 1; - else - return 0; -} -#elif defined(CONFIG_MX25) || defined(CONFIG_MX35) -static int is_16bit_nand(void) -{ - struct ccm_regs *ccm = (struct ccm_regs *)IMX_CCM_BASE; - - if (readl(&ccm->rcsr) & CCM_RCSR_NF_16BIT_SEL) - return 1; - else - return 0; -} +#if defined(CONFIG_SYS_NAND_BUSWIDTH_16BIT) + return 1; #else -#warning "8/16 bit NAND autodetection not supported" -static int is_16bit_nand(void) -{ return 0; -} #endif +}
static uint32_t *mxc_nand_memcpy32(uint32_t *dest, uint32_t *source, size_t size) {
Add some abstraction to NFC definitions so that some parts of the current code can also be used for future i.MX5 code.
Clean up a few things by the way.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Tested-by: Fabio Estevam fabio.estevam@freescale.com --- Changes in v8: None Changes in v7: - Fix typo in patch description.
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: - Separate code reformatting from behavioral changes.
Changes in v2: - Fix warning for unused tmp variable in board_nand_init() for NFC V1.
drivers/mtd/nand/mxc_nand.c | 92 +++++++++++++++++++++--------------------- include/fsl_nfc.h | 72 ++++++++++++--------------------- nand_spl/nand_boot_fsl_nfc.c | 47 +++++++++++---------- 3 files changed, 97 insertions(+), 114 deletions(-)
diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index bb475f2..6ae95d6 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -119,7 +119,7 @@ static uint32_t *mxc_nand_memcpy32(uint32_t *dest, uint32_t *source, size_t size
/* * This function polls the NANDFC to wait for the basic operation to - * complete by checking the INT bit of config2 register. + * complete by checking the INT bit. */ static void wait_op_done(struct mxc_nand_host *host, int max_retries, uint16_t param) @@ -127,10 +127,10 @@ static void wait_op_done(struct mxc_nand_host *host, int max_retries, uint32_t tmp;
while (max_retries-- > 0) { - if (readw(&host->regs->config2) & NFC_INT) { - tmp = readw(&host->regs->config2); - tmp &= ~NFC_INT; - writew(tmp, &host->regs->config2); + tmp = readnfc(&host->regs->config2); + if (tmp & NFC_V1_V2_CONFIG2_INT) { + tmp &= ~NFC_V1_V2_CONFIG2_INT; + writenfc(tmp, &host->regs->config2); break; } udelay(1); @@ -149,8 +149,8 @@ static void send_cmd(struct mxc_nand_host *host, uint16_t cmd) { MTDDEBUG(MTD_DEBUG_LEVEL3, "send_cmd(host, 0x%x)\n", cmd);
- writew(cmd, &host->regs->flash_cmd); - writew(NFC_CMD, &host->regs->config2); + writenfc(cmd, &host->regs->flash_cmd); + writenfc(NFC_CMD, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, cmd); @@ -165,8 +165,8 @@ static void send_addr(struct mxc_nand_host *host, uint16_t addr) { MTDDEBUG(MTD_DEBUG_LEVEL3, "send_addr(host, 0x%x)\n", addr);
- writew(addr, &host->regs->flash_addr); - writew(NFC_ADDR, &host->regs->config2); + writenfc(addr, &host->regs->flash_addr); + writenfc(NFC_ADDR, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, addr); @@ -198,19 +198,19 @@ static void send_prog_page(struct mxc_nand_host *host, uint8_t buf_id, } }
- writew(buf_id, &host->regs->buf_addr); + writenfc(buf_id, &host->regs->buf_addr);
/* Configure spare or page+spare access */ if (!host->pagesize_2k) { - uint16_t config1 = readw(&host->regs->config1); + uint16_t config1 = readnfc(&host->regs->config1); if (spare_only) - config1 |= NFC_SP_EN; + config1 |= NFC_CONFIG1_SP_EN; else - config1 &= ~NFC_SP_EN; - writew(config1, &host->regs->config1); + config1 &= ~NFC_CONFIG1_SP_EN; + writenfc(config1, &host->regs->config1); }
- writew(NFC_INPUT, &host->regs->config2); + writenfc(NFC_INPUT, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, spare_only); @@ -225,19 +225,19 @@ static void send_read_page(struct mxc_nand_host *host, uint8_t buf_id, { MTDDEBUG(MTD_DEBUG_LEVEL3, "send_read_page (%d)\n", spare_only);
/* Configure spare or page+spare access */ if (!host->pagesize_2k) { - uint32_t config1 = readw(&host->regs->config1); + uint32_t config1 = readnfc(&host->regs->config1); if (spare_only) - config1 |= NFC_SP_EN; + config1 |= NFC_CONFIG1_SP_EN; else - config1 &= ~NFC_SP_EN; - writew(config1, &host->regs->config1); + config1 &= ~NFC_CONFIG1_SP_EN; + writenfc(config1, &host->regs->config1); }
- writew(NFC_OUTPUT, &host->regs->config2); + writenfc(NFC_OUTPUT, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, spare_only); @@ -265,14 +265,14 @@ static void send_read_id(struct mxc_nand_host *host) uint16_t tmp;
/* NANDFC buffer 0 is used for device ID output */ - writew(0x0, &host->regs->buf_addr); + writenfc(0x0, &host->regs->buf_addr);
/* Read ID into main buffer */ - tmp = readw(&host->regs->config1); - tmp &= ~NFC_SP_EN; - writew(tmp, &host->regs->config1); + tmp = readnfc(&host->regs->config1); + tmp &= ~NFC_CONFIG1_SP_EN; + writenfc(tmp, &host->regs->config1);
- writew(NFC_ID, &host->regs->config2); + writenfc(NFC_ID, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, 0); @@ -292,14 +292,14 @@ static uint16_t get_dev_status(struct mxc_nand_host *host) /* store the main area1 first word, later do recovery */ store = readl(main_buf); /* NANDFC buffer 1 is used for device status */ - writew(1, &host->regs->buf_addr); + writenfc(1, &host->regs->buf_addr);
/* Read status into main buffer */ - tmp = readw(&host->regs->config1); - tmp &= ~NFC_SP_EN; - writew(tmp, &host->regs->config1); + tmp = readnfc(&host->regs->config1); + tmp &= ~NFC_CONFIG1_SP_EN; + writenfc(tmp, &host->regs->config1);
- writew(NFC_STATUS, &host->regs->config2); + writenfc(NFC_STATUS, &host->regs->operation);
/* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, 0); @@ -328,13 +328,13 @@ static void _mxc_nand_enable_hwecc(struct mtd_info *mtd, int on) { struct nand_chip *nand_chip = mtd->priv; struct mxc_nand_host *host = nand_chip->priv; - uint16_t tmp = readw(&host->regs->config1); + uint16_t tmp = readnfc(&host->regs->config1);
if (on) - tmp |= NFC_ECC_EN; + tmp |= NFC_V1_V2_CONFIG1_ECC_EN; else - tmp &= ~NFC_ECC_EN; - writew(tmp, &host->regs->config1); + tmp &= ~NFC_V1_V2_CONFIG1_ECC_EN; + writenfc(tmp, &host->regs->config1); }
#ifdef CONFIG_MXC_NAND_HWECC @@ -667,7 +667,7 @@ static int mxc_nand_correct_data(struct mtd_info *mtd, u_char *dat, * additional correction. 2-Bit errors cannot be corrected by * HW ECC, so we need to return failure */ - uint16_t ecc_status = readw(&host->regs->ecc_status_result); + uint16_t ecc_status = readnfc(&host->regs->ecc_status_result);
if (((ecc_status & 0x3) == 2) || ((ecc_status >> 2) == 2)) { MTDDEBUG(MTD_DEBUG_LEVEL0, @@ -1210,24 +1210,24 @@ int board_nand_init(struct nand_chip *this) #endif
#ifdef MXC_NFC_V2_1 - tmp = readw(&host->regs->config1); - tmp |= NFC_ONE_CYCLE; - tmp |= NFC_4_8N_ECC; - writew(tmp, &host->regs->config1); + tmp = readnfc(&host->regs->config1); + tmp |= NFC_V2_CONFIG1_ONE_CYCLE; + tmp |= NFC_V2_CONFIG1_ECC_MODE_4; + writenfc(tmp, &host->regs->config1); if (host->pagesize_2k) - writew(64/2, &host->regs->spare_area_size); + writenfc(64/2, &host->regs->spare_area_size); else - writew(16/2, &host->regs->spare_area_size); + writenfc(16/2, &host->regs->spare_area_size); #endif
/* * preset operation * Unlock the internal RAM Buffer */ - writew(0x2, &host->regs->config); + writenfc(0x2, &host->regs->config);
/* Blocks to be unlocked */ - writew(0x0, &host->regs->unlockstart_blkaddr); + writenfc(0x0, &host->regs->unlockstart_blkaddr); /* Originally (Freescale LTIB 2.6.21) 0x4000 was written to the * unlockend_blkaddr, but the magic 0x4000 does not always work * when writing more than some 32 megabytes (on 2k page nands) @@ -1239,10 +1239,10 @@ int board_nand_init(struct nand_chip *this) * This might be NAND chip specific and the i.MX31 datasheet is * extremely vague about the semantics of this register. */ - writew(0xFFFF, &host->regs->unlockend_blkaddr); + writenfc(0xFFFF, &host->regs->unlockend_blkaddr);
/* Unlock Block Command for given address range */ - writew(0x4, &host->regs->wrprot); + writenfc(0x4, &host->regs->wrprot);
return 0; } diff --git a/include/fsl_nfc.h b/include/fsl_nfc.h index ff537b4..013e9e2 100644 --- a/include/fsl_nfc.h +++ b/include/fsl_nfc.h @@ -113,58 +113,38 @@ struct fsl_nfc_regs { #endif };
-/* - * Set INT to 0, FCMD to 1, rest to 0 in NFC_CONFIG2 Register for Command - * operation - */ -#define NFC_CMD 0x1 +/* Set FCMD to 1, rest to 0 for Command operation */ +#define NFC_CMD 0x1
-/* - * Set INT to 0, FADD to 1, rest to 0 in NFC_CONFIG2 Register for Address - * operation - */ -#define NFC_ADDR 0x2 +/* Set FADD to 1, rest to 0 for Address operation */ +#define NFC_ADDR 0x2
-/* - * Set INT to 0, FDI to 1, rest to 0 in NFC_CONFIG2 Register for Input - * operation - */ -#define NFC_INPUT 0x4 +/* Set FDI to 1, rest to 0 for Input operation */ +#define NFC_INPUT 0x4
-/* - * Set INT to 0, FDO to 001, rest to 0 in NFC_CONFIG2 Register for Data - * Output operation - */ -#define NFC_OUTPUT 0x8 +/* Set FDO to 001, rest to 0 for Data Output operation */ +#define NFC_OUTPUT 0x8
-/* - * Set INT to 0, FD0 to 010, rest to 0 in NFC_CONFIG2 Register for Read ID - * operation - */ -#define NFC_ID 0x10 +/* Set FDO to 010, rest to 0 for Read ID operation */ +#define NFC_ID 0x10
-/* - * Set INT to 0, FDO to 100, rest to 0 in NFC_CONFIG2 Register for Read - * Status operation - */ -#define NFC_STATUS 0x20 +/* Set FDO to 100, rest to 0 for Read Status operation */ +#define NFC_STATUS 0x20
-/* - * Set INT to 1, rest to 0 in NFC_CONFIG2 Register for Read Status - * operation - */ -#define NFC_INT 0x8000 +#define NFC_CONFIG1_SP_EN (1 << 2) +#define NFC_CONFIG1_RST (1 << 6) +#define NFC_CONFIG1_CE (1 << 7) +#define NFC_V1_V2_CONFIG1_ECC_EN (1 << 3) +#define NFC_V1_V2_CONFIG1_INT_MSK (1 << 4) +#define NFC_V1_V2_CONFIG1_BIG (1 << 5) +#define NFC_V2_CONFIG1_ECC_MODE_4 (1 << 0) +#define NFC_V2_CONFIG1_ONE_CYCLE (1 << 8) +#define NFC_V2_CONFIG1_FP_INT (1 << 11)
-#ifdef MXC_NFC_V2_1 -#define NFC_4_8N_ECC (1 << 0) -#endif -#define NFC_SP_EN (1 << 2) -#define NFC_ECC_EN (1 << 3) -#define NFC_INT_MSK (1 << 4) -#define NFC_BIG (1 << 5) -#define NFC_RST (1 << 6) -#define NFC_CE (1 << 7) -#define NFC_ONE_CYCLE (1 << 8) -#define NFC_FP_INT (1 << 11) +#define NFC_V1_V2_CONFIG2_INT (1 << 15) + +#define operation config2 +#define readnfc readw +#define writenfc writew
#endif /* __FSL_NFC_H */ diff --git a/nand_spl/nand_boot_fsl_nfc.c b/nand_spl/nand_boot_fsl_nfc.c index a40c998..615e820 100644 --- a/nand_spl/nand_boot_fsl_nfc.c +++ b/nand_spl/nand_boot_fsl_nfc.c @@ -36,13 +36,13 @@ static void nfc_wait_ready(void) { uint32_t tmp;
- while (!(readw(&nfc->config2) & NFC_INT)) + while (!(readnfc(&nfc->config2) & NFC_V1_V2_CONFIG2_INT)) ;
/* Reset interrupt flag */ - tmp = readw(&nfc->config2); - tmp &= ~NFC_INT; - writew(tmp, &nfc->config2); + tmp = readnfc(&nfc->config2); + tmp &= ~NFC_V1_V2_CONFIG2_INT; + writenfc(tmp, &nfc->config2); }
static void nfc_nand_init(void) @@ -51,43 +51,45 @@ static void nfc_nand_init(void) int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; int config1;
- writew(CONFIG_SYS_NAND_SPARE_SIZE / 2, &nfc->spare_area_size); + writenfc(CONFIG_SYS_NAND_SPARE_SIZE / 2, &nfc->spare_area_size);
/* unlocking RAM Buff */ - writew(0x2, &nfc->config); + writenfc(0x2, &nfc->config);
/* hardware ECC checking and correct */ - config1 = readw(&nfc->config1) | NFC_ECC_EN | NFC_INT_MSK | - NFC_ONE_CYCLE | NFC_FP_INT; + config1 = readnfc(&nfc->config1) | NFC_V1_V2_CONFIG1_ECC_EN | + NFC_V1_V2_CONFIG1_INT_MSK | NFC_V2_CONFIG1_ONE_CYCLE | + NFC_V2_CONFIG1_FP_INT; /* * if spare size is larger that 16 bytes per 512 byte hunk * then use 8 symbol correction instead of 4 */ if (CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16) - config1 &= ~NFC_4_8N_ECC; + config1 &= ~NFC_V2_CONFIG1_ECC_MODE_4; else - config1 |= NFC_4_8N_ECC; - writew(config1, &nfc->config1); + config1 |= NFC_V2_CONFIG1_ECC_MODE_4; + writenfc(config1, &nfc->config1); #elif defined(MXC_NFC_V1) /* unlocking RAM Buff */ - writew(0x2, &nfc->config); + writenfc(0x2, &nfc->config);
/* hardware ECC checking and correct */ - writew(NFC_ECC_EN | NFC_INT_MSK, &nfc->config1); + writenfc(NFC_V1_V2_CONFIG1_ECC_EN | NFC_V1_V2_CONFIG1_INT_MSK, + &nfc->config1); #endif }
static void nfc_nand_command(unsigned short command) { - writew(command, &nfc->flash_cmd); - writew(NFC_CMD, &nfc->config2); + writenfc(command, &nfc->flash_cmd); + writenfc(NFC_CMD, &nfc->operation); nfc_wait_ready(); }
static void nfc_nand_address(unsigned short address) { - writew(address, &nfc->flash_addr); - writew(NFC_ADDR, &nfc->config2); + writenfc(address, &nfc->flash_addr); + writenfc(NFC_ADDR, &nfc->operation); nfc_wait_ready(); }
@@ -121,8 +123,8 @@ static void nfc_nand_data_output(void) int i; #endif
- writew(0, &nfc->buf_addr); - writew(NFC_OUTPUT, &nfc->config2); + writenfc(0, &nfc->buf_addr); + writenfc(NFC_OUTPUT, &nfc->operation); nfc_wait_ready(); #ifdef NAND_MXC_2K_MULTI_CYCLE /* @@ -130,8 +132,8 @@ static void nfc_nand_data_output(void) * for pages larger than 512 bytes. */ for (i = 1; i < CONFIG_SYS_NAND_PAGE_SIZE / 512; i++) { - writew(i, &nfc->buf_addr); - writew(NFC_OUTPUT, &nfc->config2); + writenfc(i, &nfc->buf_addr); + writenfc(NFC_OUTPUT, &nfc->operation); nfc_wait_ready(); } #endif @@ -160,7 +162,8 @@ static int nfc_nand_check_ecc(void)
static void nfc_nand_read_page(unsigned int page_address) { - writew(0, &nfc->buf_addr); /* read in first 0 buffer */ + /* read in first 0 buffer */ + writenfc(0, &nfc->buf_addr); nfc_nand_command(NAND_CMD_READ0); nfc_nand_page_address(page_address);
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Tested-by: Fabio Estevam fabio.estevam@freescale.com --- Changes in v8: - Rebase on Fabio's patches using CONFIG_SYS_NAND_BUSWIDTH_16BIT instead of NAND Flash boot config pins to determine NAND Flash bus width.
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: - Separate code reformatting from behavioral changes.
Changes in v2: None
arch/arm/include/asm/arch-mx5/imx-regs.h | 9 +++ drivers/mtd/nand/mxc_nand.c | 119 +++++++++++++++++++++++++++--- include/fsl_nfc.h | 79 +++++++++++++++++++- nand_spl/nand_boot_fsl_nfc.c | 67 ++++++++++++++++- 4 files changed, 259 insertions(+), 15 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 249d15a..9aa0c6a 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -224,6 +224,15 @@ #define CS0_32M_CS1_32M_CS2_32M_CS3_32M 3
/* + * SRC register definitions + */ +#if defined(CONFIG_MX51) +#define SRC_SBMR_NF16B (1 << 2) +#elif defined(CONFIG_MX53) +#define SRC_SBMR_NF16B (1 << 13) +#endif + +/* * CSPI register definitions */ #define MXC_ECSPI diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index 6ae95d6..db72cdc 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -22,7 +22,8 @@ #include <nand.h> #include <linux/err.h> #include <asm/io.h> -#if defined(CONFIG_MX25) || defined(CONFIG_MX27) || defined(CONFIG_MX35) +#if defined(CONFIG_MX25) || defined(CONFIG_MX27) || defined(CONFIG_MX35) || \ + defined(CONFIG_MX51) || defined(CONFIG_MX53) #include <asm/arch/imx-regs.h> #endif #include <fsl_nfc.h> @@ -36,6 +37,9 @@ struct mxc_nand_host { struct nand_chip *nand;
struct fsl_nfc_regs __iomem *regs; +#ifdef MXC_NFC_V3_2 + struct fsl_nfc_ip_regs __iomem *ip_regs; +#endif int spare_only; int status_request; int pagesize_2k; @@ -77,7 +81,7 @@ static struct nand_ecclayout nand_hw_eccoob2k = { .oobfree = { {2, 4}, {11, 11}, {27, 11}, {43, 11}, {59, 5} }, }; #endif -#elif defined(MXC_NFC_V2_1) +#elif defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) #ifndef CONFIG_SYS_NAND_LARGEPAGE static struct nand_ecclayout nand_hw_eccoob = { .eccbytes = 9, @@ -127,10 +131,17 @@ static void wait_op_done(struct mxc_nand_host *host, int max_retries, uint32_t tmp;
while (max_retries-- > 0) { +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) tmp = readnfc(&host->regs->config2); if (tmp & NFC_V1_V2_CONFIG2_INT) { tmp &= ~NFC_V1_V2_CONFIG2_INT; writenfc(tmp, &host->regs->config2); +#elif defined(MXC_NFC_V3_2) + tmp = readnfc(&host->ip_regs->ipc); + if (tmp & NFC_V3_IPC_INT) { + tmp &= ~NFC_V3_IPC_INT; + writenfc(tmp, &host->ip_regs->ipc); +#endif break; } udelay(1); @@ -182,7 +193,7 @@ static void send_prog_page(struct mxc_nand_host *host, uint8_t buf_id, if (spare_only) MTDDEBUG(MTD_DEBUG_LEVEL1, "send_prog_page (%d)\n", spare_only);
- if (is_mxc_nfc_21()) { + if (is_mxc_nfc_21() || is_mxc_nfc_32()) { int i; /* * The controller copies the 64 bytes of spare data from @@ -198,11 +209,18 @@ static void send_prog_page(struct mxc_nand_host *host, uint8_t buf_id, } }
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) writenfc(buf_id, &host->regs->buf_addr); +#elif defined(MXC_NFC_V3_2) + uint32_t tmp = readnfc(&host->regs->config1); + tmp &= ~NFC_V3_CONFIG1_RBA_MASK; + tmp |= NFC_V3_CONFIG1_RBA(buf_id); + writenfc(tmp, &host->regs->config1); +#endif
/* Configure spare or page+spare access */ if (!host->pagesize_2k) { - uint16_t config1 = readnfc(&host->regs->config1); + uint32_t config1 = readnfc(&host->regs->config1); if (spare_only) config1 |= NFC_CONFIG1_SP_EN; else @@ -225,7 +243,14 @@ static void send_read_page(struct mxc_nand_host *host, uint8_t buf_id, { MTDDEBUG(MTD_DEBUG_LEVEL3, "send_read_page (%d)\n", spare_only);
/* Configure spare or page+spare access */ if (!host->pagesize_2k) { @@ -242,7 +267,7 @@ static void send_read_page(struct mxc_nand_host *host, uint8_t buf_id, /* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, spare_only);
/* @@ -262,10 +287,16 @@ static void send_read_page(struct mxc_nand_host *host, uint8_t buf_id, /* Request the NANDFC to perform a read of the NAND device ID. */ static void send_read_id(struct mxc_nand_host *host) { - uint16_t tmp; + uint32_t tmp;
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) /* NANDFC buffer 0 is used for device ID output */ writenfc(0x0, &host->regs->buf_addr); +#elif defined(MXC_NFC_V3_2) + tmp = readnfc(&host->regs->config1); + tmp &= ~NFC_V3_CONFIG1_RBA_MASK; + writenfc(tmp, &host->regs->config1); +#endif
/* Read ID into main buffer */ tmp = readnfc(&host->regs->config1); @@ -284,15 +315,19 @@ static void send_read_id(struct mxc_nand_host *host) */ static uint16_t get_dev_status(struct mxc_nand_host *host) { +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) void __iomem *main_buf = host->regs->main_area[1]; uint32_t store; - uint16_t ret, tmp; +#endif + uint32_t ret, tmp; /* Issue status request to NAND device */
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) /* store the main area1 first word, later do recovery */ store = readl(main_buf); /* NANDFC buffer 1 is used for device status */ writenfc(1, &host->regs->buf_addr); +#endif
/* Read status into main buffer */ tmp = readnfc(&host->regs->config1); @@ -304,12 +339,16 @@ static uint16_t get_dev_status(struct mxc_nand_host *host) /* Wait for operation to complete */ wait_op_done(host, TROP_US_DELAY, 0);
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) /* * Status is placed in first word of main buffer * get status, then recovery area 1 data */ ret = readw(main_buf); writel(store, main_buf); +#elif defined(MXC_NFC_V3_2) + ret = readnfc(&host->regs->config1) >> 16; +#endif
return ret; } @@ -328,6 +367,7 @@ static void _mxc_nand_enable_hwecc(struct mtd_info *mtd, int on) { struct nand_chip *nand_chip = mtd->priv; struct mxc_nand_host *host = nand_chip->priv; +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) uint16_t tmp = readnfc(&host->regs->config1);
if (on) @@ -335,6 +375,15 @@ static void _mxc_nand_enable_hwecc(struct mtd_info *mtd, int on) else tmp &= ~NFC_V1_V2_CONFIG1_ECC_EN; writenfc(tmp, &host->regs->config1); +#elif defined(MXC_NFC_V3_2) + uint32_t tmp = readnfc(&host->ip_regs->config2); + + if (on) + tmp |= NFC_V3_CONFIG2_ECC_EN; + else + tmp &= ~NFC_V3_CONFIG2_ECC_EN; + writenfc(tmp, &host->ip_regs->config2); +#endif }
#ifdef CONFIG_MXC_NAND_HWECC @@ -346,7 +395,7 @@ static void mxc_nand_enable_hwecc(struct mtd_info *mtd, int mode) */ }
-#ifdef MXC_NFC_V2_1 +#if defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) static int mxc_nand_read_oob_syndrome(struct mtd_info *mtd, struct nand_chip *chip, int page, int sndcmd) @@ -1136,8 +1185,8 @@ static struct nand_bbt_descr bbt_mirror_descr = { int board_nand_init(struct nand_chip *this) { struct mtd_info *mtd; -#ifdef MXC_NFC_V2_1 - uint16_t tmp; +#if defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) + uint32_t tmp; #endif
#ifdef CONFIG_SYS_NAND_USE_FLASH_BBT @@ -1165,13 +1214,17 @@ int board_nand_init(struct nand_chip *this) this->verify_buf = mxc_nand_verify_buf;
host->regs = (struct fsl_nfc_regs __iomem *)CONFIG_MXC_NAND_REGS_BASE; +#ifdef MXC_NFC_V3_2 + host->ip_regs = + (struct fsl_nfc_ip_regs __iomem *)CONFIG_MXC_NAND_IP_REGS_BASE; +#endif host->clk_act = 1;
#ifdef CONFIG_MXC_NAND_HWECC this->ecc.calculate = mxc_nand_calculate_ecc; this->ecc.hwctl = mxc_nand_enable_hwecc; this->ecc.correct = mxc_nand_correct_data; - if (is_mxc_nfc_21()) { + if (is_mxc_nfc_21() || is_mxc_nfc_32()) { this->ecc.mode = NAND_ECC_HW_SYNDROME; this->ecc.read_page = mxc_nand_read_page_syndrome; this->ecc.read_page_raw = mxc_nand_read_page_raw_syndrome; @@ -1209,6 +1262,7 @@ int board_nand_init(struct nand_chip *this) this->ecc.layout = &nand_hw_eccoob; #endif
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) #ifdef MXC_NFC_V2_1 tmp = readnfc(&host->regs->config1); tmp |= NFC_V2_CONFIG1_ONE_CYCLE; @@ -1243,6 +1297,49 @@ int board_nand_init(struct nand_chip *this)
/* Unlock Block Command for given address range */ writenfc(0x4, &host->regs->wrprot); +#elif defined(MXC_NFC_V3_2) + writenfc(NFC_V3_CONFIG1_RBA(0), &host->regs->config1); + writenfc(NFC_V3_IPC_CREQ, &host->ip_regs->ipc); + + /* Unlock the internal RAM Buffer */ + writenfc(NFC_V3_WRPROT_BLS_UNLOCK | NFC_V3_WRPROT_UNLOCK, + &host->ip_regs->wrprot); + + /* Blocks to be unlocked */ + for (tmp = 0; tmp < CONFIG_SYS_NAND_MAX_CHIPS; tmp++) + writenfc(0x0 | 0xFFFF << 16, + &host->ip_regs->wrprot_unlock_blkaddr[tmp]); + + writenfc(0, &host->ip_regs->ipc); + + tmp = readnfc(&host->ip_regs->config2); + tmp &= ~(NFC_V3_CONFIG2_SPAS_MASK | NFC_V3_CONFIG2_EDC_MASK | + NFC_V3_CONFIG2_ECC_MODE_8 | NFC_V3_CONFIG2_PS_MASK); + tmp |= NFC_V3_CONFIG2_ONE_CYCLE; + + if (host->pagesize_2k) { + tmp |= NFC_V3_CONFIG2_SPAS(64/2); + tmp |= NFC_V3_CONFIG2_PS_2048; + } else { + tmp |= NFC_V3_CONFIG2_SPAS(16/2); + tmp |= NFC_V3_CONFIG2_PS_512; + } + + writenfc(tmp, &host->ip_regs->config2); + + tmp = NFC_V3_CONFIG3_NUM_OF_DEVS(0) | + NFC_V3_CONFIG3_NO_SDMA | + NFC_V3_CONFIG3_RBB_MODE | + NFC_V3_CONFIG3_SBB(6) | /* Reset default */ + NFC_V3_CONFIG3_ADD_OP(0); + + if (!(this->options & NAND_BUSWIDTH_16)) + tmp |= NFC_V3_CONFIG3_FW8; + + writenfc(tmp, &host->ip_regs->config3); + + writenfc(0, &host->ip_regs->delay_line); +#endif
return 0; } diff --git a/include/fsl_nfc.h b/include/fsl_nfc.h index 013e9e2..48a6448 100644 --- a/include/fsl_nfc.h +++ b/include/fsl_nfc.h @@ -33,7 +33,8 @@ * to support up to 2K byte pagesize nand. * Reading or writing a 2K page requires 4 FDI/FDO cycles. * - * MX25 and MX35 have version 2.1, which has: + * MX25 and MX35 have version 2.1, and MX51 and MX53 have version 3.2, which + * have: * 8 512-byte main buffers and * 8 64-byte spare buffers * to support up to 4K byte pagesize nand. @@ -44,20 +45,29 @@ #define MXC_NFC_V1 #define is_mxc_nfc_1() 1 #define is_mxc_nfc_21() 0 +#define is_mxc_nfc_32() 0 #elif defined(CONFIG_MX25) || defined(CONFIG_MX35) #define MXC_NFC_V2_1 #define is_mxc_nfc_1() 0 #define is_mxc_nfc_21() 1 +#define is_mxc_nfc_32() 0 +#elif defined(CONFIG_MX51) || defined(CONFIG_MX53) +#define MXC_NFC_V3 +#define MXC_NFC_V3_2 +#define is_mxc_nfc_1() 0 +#define is_mxc_nfc_21() 0 +#define is_mxc_nfc_32() 1 #else #error "MXC NFC implementation not supported" #endif +#define is_mxc_nfc_3() is_mxc_nfc_32()
#if defined(MXC_NFC_V1) #define NAND_MXC_NR_BUFS 4 #define NAND_MXC_SPARE_BUF_SIZE 16 #define NAND_MXC_REG_OFFSET 0xe00 #define NAND_MXC_2K_MULTI_CYCLE -#elif defined(MXC_NFC_V2_1) +#elif defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) #define NAND_MXC_NR_BUFS 8 #define NAND_MXC_SPARE_BUF_SIZE 64 #define NAND_MXC_REG_OFFSET 0x1e00 @@ -110,9 +120,28 @@ struct fsl_nfc_regs { u16 unlockend_blkaddr2; u16 unlockstart_blkaddr3; u16 unlockend_blkaddr3; +#elif defined(MXC_NFC_V3_2) + u32 flash_cmd; + u32 flash_addr[12]; + u32 config1; + u32 ecc_status_result; + u32 status_sum; + u32 launch; #endif };
+#ifdef MXC_NFC_V3_2 +struct fsl_nfc_ip_regs { + u32 wrprot; + u32 wrprot_unlock_blkaddr[8]; + u32 config2; + u32 config3; + u32 ipc; + u32 err_addr; + u32 delay_line; +}; +#endif + /* Set FCMD to 1, rest to 0 for Command operation */ #define NFC_CMD 0x1
@@ -131,20 +160,66 @@ struct fsl_nfc_regs { /* Set FDO to 100, rest to 0 for Read Status operation */ #define NFC_STATUS 0x20
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) #define NFC_CONFIG1_SP_EN (1 << 2) #define NFC_CONFIG1_RST (1 << 6) #define NFC_CONFIG1_CE (1 << 7) +#elif defined(MXC_NFC_V3_2) +#define NFC_CONFIG1_SP_EN (1 << 0) +#define NFC_CONFIG1_CE (1 << 1) +#define NFC_CONFIG1_RST (1 << 2) +#endif #define NFC_V1_V2_CONFIG1_ECC_EN (1 << 3) #define NFC_V1_V2_CONFIG1_INT_MSK (1 << 4) #define NFC_V1_V2_CONFIG1_BIG (1 << 5) #define NFC_V2_CONFIG1_ECC_MODE_4 (1 << 0) #define NFC_V2_CONFIG1_ONE_CYCLE (1 << 8) #define NFC_V2_CONFIG1_FP_INT (1 << 11) +#define NFC_V3_CONFIG1_RBA_MASK (0x7 << 4) +#define NFC_V3_CONFIG1_RBA(x) (((x) & 0x7) << 4)
#define NFC_V1_V2_CONFIG2_INT (1 << 15) +#define NFC_V3_CONFIG2_PS_MASK (0x3 << 0) +#define NFC_V3_CONFIG2_PS_512 (0 << 0) +#define NFC_V3_CONFIG2_PS_2048 (1 << 0) +#define NFC_V3_CONFIG2_PS_4096 (2 << 0) +#define NFC_V3_CONFIG2_ONE_CYCLE (1 << 2) +#define NFC_V3_CONFIG2_ECC_EN (1 << 3) +#define NFC_V3_CONFIG2_2CMD_PHASES (1 << 4) +#define NFC_V3_CONFIG2_NUM_ADDR_PH0 (1 << 5) +#define NFC_V3_CONFIG2_ECC_MODE_8 (1 << 6) +#define NFC_V3_CONFIG2_PPB_MASK (0x3 << 7) +#define NFC_V3_CONFIG2_PPB(x) (((x) & 0x3) << 7) +#define NFC_V3_CONFIG2_EDC_MASK (0x7 << 9) +#define NFC_V3_CONFIG2_EDC(x) (((x) & 0x7) << 9) +#define NFC_V3_CONFIG2_NUM_ADDR_PH1(x) (((x) & 0x3) << 12) +#define NFC_V3_CONFIG2_INT_MSK (1 << 15) +#define NFC_V3_CONFIG2_SPAS_MASK (0xff << 16) +#define NFC_V3_CONFIG2_SPAS(x) (((x) & 0xff) << 16) +#define NFC_V3_CONFIG2_ST_CMD_MASK (0xff << 24) +#define NFC_V3_CONFIG2_ST_CMD(x) (((x) & 0xff) << 24) + +#define NFC_V3_CONFIG3_ADD_OP(x) (((x) & 0x3) << 0) +#define NFC_V3_CONFIG3_FW8 (1 << 3) +#define NFC_V3_CONFIG3_SBB(x) (((x) & 0x7) << 8) +#define NFC_V3_CONFIG3_NUM_OF_DEVS(x) (((x) & 0x7) << 12) +#define NFC_V3_CONFIG3_RBB_MODE (1 << 15) +#define NFC_V3_CONFIG3_NO_SDMA (1 << 20)
+#define NFC_V3_WRPROT_UNLOCK (1 << 2) +#define NFC_V3_WRPROT_BLS_UNLOCK (2 << 6) + +#define NFC_V3_IPC_CREQ (1 << 0) +#define NFC_V3_IPC_INT (1 << 31) + +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) #define operation config2 #define readnfc readw #define writenfc writew +#elif defined(MXC_NFC_V3_2) +#define operation launch +#define readnfc readl +#define writenfc writel +#endif
#endif /* __FSL_NFC_H */ diff --git a/nand_spl/nand_boot_fsl_nfc.c b/nand_spl/nand_boot_fsl_nfc.c index 615e820..1096727 100644 --- a/nand_spl/nand_boot_fsl_nfc.c +++ b/nand_spl/nand_boot_fsl_nfc.c @@ -30,12 +30,18 @@ #include <asm/io.h> #include <fsl_nfc.h>
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR; +#elif defined(MXC_NFC_V3_2) +static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR_AXI; +static struct fsl_nfc_ip_regs *const nfc_ip = (void *)NFC_BASE_ADDR; +#endif
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) while (!(readnfc(&nfc->config2) & NFC_V1_V2_CONFIG2_INT)) ;
@@ -43,11 +49,56 @@ static void nfc_wait_ready(void) tmp = readnfc(&nfc->config2); tmp &= ~NFC_V1_V2_CONFIG2_INT; writenfc(tmp, &nfc->config2); +#elif defined(MXC_NFC_V3_2) + while (!(readnfc(&nfc_ip->ipc) & NFC_V3_IPC_INT)) + ; + + /* Reset interrupt flag */ + tmp = readnfc(&nfc_ip->ipc); + tmp &= ~NFC_V3_IPC_INT; + writenfc(tmp, &nfc_ip->ipc); +#endif }
static void nfc_nand_init(void) { -#if defined(MXC_NFC_V2_1) +#if defined(MXC_NFC_V3_2) + int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; + int tmp; + + tmp = (readnfc(&nfc_ip->config2) & ~(NFC_V3_CONFIG2_SPAS_MASK | + NFC_V3_CONFIG2_EDC_MASK | NFC_V3_CONFIG2_PS_MASK)) | + NFC_V3_CONFIG2_SPAS(CONFIG_SYS_NAND_SPARE_SIZE / 2) | + NFC_V3_CONFIG2_INT_MSK | NFC_V3_CONFIG2_ECC_EN | + NFC_V3_CONFIG2_ONE_CYCLE; + if (CONFIG_SYS_NAND_PAGE_SIZE == 4096) + tmp |= NFC_V3_CONFIG2_PS_4096; + else if (CONFIG_SYS_NAND_PAGE_SIZE == 2048) + tmp |= NFC_V3_CONFIG2_PS_2048; + else if (CONFIG_SYS_NAND_PAGE_SIZE == 512) + tmp |= NFC_V3_CONFIG2_PS_512; + /* + * if spare size is larger that 16 bytes per 512 byte hunk + * then use 8 symbol correction instead of 4 + */ + if (CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16) + tmp |= NFC_V3_CONFIG2_ECC_MODE_8; + else + tmp &= ~NFC_V3_CONFIG2_ECC_MODE_8; + writenfc(tmp, &nfc_ip->config2); + + tmp = NFC_V3_CONFIG3_NUM_OF_DEVS(0) | + NFC_V3_CONFIG3_NO_SDMA | + NFC_V3_CONFIG3_RBB_MODE | + NFC_V3_CONFIG3_SBB(6) | /* Reset default */ + NFC_V3_CONFIG3_ADD_OP(0); +#ifndef CONFIG_SYS_NAND_BUSWIDTH_16 + tmp |= NFC_V3_CONFIG3_FW8; +#endif + writenfc(tmp, &nfc_ip->config3); + + writenfc(0, &nfc_ip->delay_line); +#elif defined(MXC_NFC_V2_1) int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; int config1;
@@ -123,7 +174,13 @@ static void nfc_nand_data_output(void) int i; #endif
+#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) writenfc(0, &nfc->buf_addr); +#elif defined(MXC_NFC_V3_2) + int config1 = readnfc(&nfc->config1); + config1 &= ~NFC_V3_CONFIG1_RBA_MASK; + writenfc(config1, &nfc->config1); +#endif writenfc(NFC_OUTPUT, &nfc->operation); nfc_wait_ready(); #ifdef NAND_MXC_2K_MULTI_CYCLE @@ -144,7 +201,7 @@ static int nfc_nand_check_ecc(void) #if defined(MXC_NFC_V1) u16 ecc_status = readw(&nfc->ecc_status_result); return (ecc_status & 0x3) == 2 || (ecc_status >> 2) == 2; -#elif defined(MXC_NFC_V2_1) +#elif defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) u32 ecc_status = readl(&nfc->ecc_status_result); int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; int err_limit = CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16 ? 8 : 4; @@ -163,7 +220,13 @@ static int nfc_nand_check_ecc(void) static void nfc_nand_read_page(unsigned int page_address) { /* read in first 0 buffer */ +#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) writenfc(0, &nfc->buf_addr); +#elif defined(MXC_NFC_V3_2) + int config1 = readnfc(&nfc->config1); + config1 &= ~NFC_V3_CONFIG1_RBA_MASK; + writenfc(config1, &nfc->config1); +#endif nfc_nand_command(NAND_CMD_READ0); nfc_nand_page_address(page_address);
Hi Benoît,
On Fri, Mar 1, 2013 at 9:10 AM, Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
These definitions are not used anymore and could be removed, right?
Hi Fabio,
On Friday, March 1, 2013 4:33:41 PM, Fabio Estevam wrote:
Hi Benoît,
Correct. I'll do that in v9.
Best regards, Benoît
Don't use several instructions to build constant values.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Acked-by: Stefano Babic sbabic@denx.de --- Changes in v8: None Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: - New patch.
Changes in v2: None
arch/arm/cpu/armv7/mx5/lowlevel_init.S | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/lowlevel_init.S b/arch/arm/cpu/armv7/mx5/lowlevel_init.S index 6d9396a..dfce0ca 100644 --- a/arch/arm/cpu/armv7/mx5/lowlevel_init.S +++ b/arch/arm/cpu/armv7/mx5/lowlevel_init.S @@ -309,8 +309,7 @@ setup_pll_func: ldr r0, =CCM_BASE_ADDR ldr r1, =0x00015154 str r1, [r0, #CLKCTL_CBCMR] - ldr r1, =0x02888945 - orr r1, r1, #(1 << 16) + ldr r1, =0x02898945 str r1, [r0, #CLKCTL_CBCDR] /* make sure change is effective */ 1: ldr r1, [r0, #CLKCTL_CDHIPR] @@ -321,10 +320,7 @@ setup_pll_func:
/* Switch peripheral to PLL2 */ ldr r0, =CCM_BASE_ADDR - ldr r1, =0x00808145 - orr r1, r1, #(2 << 10) - orr r1, r1, #(0 << 16) - orr r1, r1, #(1 << 19) + ldr r1, =0x00888945 str r1, [r0, #CLKCTL_CBCDR]
ldr r1, =0x00016154
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard.
eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this board, which satisfies the 30-ns NF R/W cycle requirement.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Tested-by: Fabio Estevam fabio.estevam@freescale.com --- Changes in v8: - Fix NFC pad setup using Freescale's.
Changes in v2: None
board/freescale/mx53ard/mx53ard.c | 66 +++++++++++++++++++++++++++++++++++++ include/configs/mx53ard.h | 10 ++++++ 2 files changed, 76 insertions(+)
diff --git a/board/freescale/mx53ard/mx53ard.c b/board/freescale/mx53ard/mx53ard.c index 2fc8570..8d433a3 100644 --- a/board/freescale/mx53ard/mx53ard.c +++ b/board/freescale/mx53ard/mx53ard.c @@ -58,6 +58,71 @@ void dram_init_banksize(void) gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; }
+#ifdef CONFIG_NAND_MXC +static void setup_iomux_nand(void) +{ + u32 i, reg; + #define M4IF_GENP_WEIM_MM_MASK 0x00000001 + #define WEIM_GCR2_MUX16_BYP_GRANT_MASK 0x00001000 + + reg = __raw_readl(M4IF_BASE_ADDR + 0xc); + reg &= ~M4IF_GENP_WEIM_MM_MASK; + __raw_writel(reg, M4IF_BASE_ADDR + 0xc); + for (i = 0x4; i < 0x94; i += 0x18) { + reg = __raw_readl(WEIM_BASE_ADDR + i); + reg &= ~WEIM_GCR2_MUX16_BYP_GRANT_MASK; + __raw_writel(reg, WEIM_BASE_ADDR + i); + } + + mxc_request_iomux(MX53_PIN_NANDF_CS0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_NANDF_CS0, PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_NANDF_CS1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_NANDF_CS1, PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_NANDF_RB0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_NANDF_RB0, PAD_CTL_PKE_ENABLE | + PAD_CTL_PUE_PULL | PAD_CTL_100K_PU); + mxc_request_iomux(MX53_PIN_NANDF_CLE, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_NANDF_CLE, PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_NANDF_ALE, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_NANDF_ALE, PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_NANDF_WP_B, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_NANDF_WP_B, PAD_CTL_PKE_ENABLE | + PAD_CTL_PUE_PULL | PAD_CTL_100K_PU); + mxc_request_iomux(MX53_PIN_NANDF_RE_B, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_NANDF_RE_B, PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_NANDF_WE_B, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_NANDF_WE_B, PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_EIM_DA0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA0, PAD_CTL_PKE_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_EIM_DA1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA1, PAD_CTL_PKE_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_EIM_DA2, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA2, PAD_CTL_PKE_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_EIM_DA3, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA3, PAD_CTL_PKE_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_EIM_DA4, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA4, PAD_CTL_PKE_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_EIM_DA5, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA5, PAD_CTL_PKE_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_EIM_DA6, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA6, PAD_CTL_PKE_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_DRV_HIGH); + mxc_request_iomux(MX53_PIN_EIM_DA7, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_EIM_DA7, PAD_CTL_PKE_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_DRV_HIGH); +} +#else +static void setup_iomux_nand(void) +{ +} +#endif + static void setup_iomux_uart(void) { /* UART1 RXD */ @@ -277,6 +342,7 @@ static void weim_cs1_settings(void)
int board_early_init_f(void) { + setup_iomux_nand(); setup_iomux_uart(); return 0; } diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 62cb42b..148f7a2 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -41,6 +41,16 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_GPIO
+#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR_AXI +#define CONFIG_NAND_MXC +#define CONFIG_MXC_NAND_REGS_BASE NFC_BASE_ADDR_AXI +#define CONFIG_MXC_NAND_IP_REGS_BASE NFC_BASE_ADDR +#define CONFIG_SYS_NAND_LARGEPAGE +#define CONFIG_MXC_NAND_HWECC +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_CMD_NAND + #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE
The page number indicated in the debug trace of mxc_nand_read_oob_syndrome() did not match the page being worked on.
By the way, replace the GCC-specific __FUNCTION__ with __func__.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: None Changes in v7: None Changes in v6: None Changes in v5: - Replace __FUNCTION__ with __func__.
Changes in v4: - New patch.
drivers/mtd/nand/mxc_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index db72cdc..62d6965 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -409,7 +409,7 @@ static int mxc_nand_read_oob_syndrome(struct mtd_info *mtd,
MTDDEBUG(MTD_DEBUG_LEVEL0, "%s: Reading OOB area of page %u to oob %p\n", - __FUNCTION__, host->page_addr, buf); + __func__, page, buf);
chip->cmdfunc(mtd, NAND_CMD_READOOB, mtd->writesize, page); for (i = 0; i < chip->ecc.steps; i++) {
The syndrome functions should use the page number passed as argument instead of the page number saved upon NAND_CMD_READ0.
This does not make any difference if the NAND_NO_AUTOINCR option is set, but otherwise this fixes accesses to the wrong pages.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: None Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: - New patch.
drivers/mtd/nand/mxc_nand.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index 62d6965..29ceab3 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -463,7 +463,7 @@ static int mxc_nand_read_page_raw_syndrome(struct mtd_info *mtd, int n;
_mxc_nand_enable_hwecc(mtd, 0); - chip->cmdfunc(mtd, NAND_CMD_READ0, 0x00, host->page_addr); + chip->cmdfunc(mtd, NAND_CMD_READ0, 0x00, page);
for (n = 0, steps = chip->ecc.steps; steps > 0; n++, steps--) { host->col_addr = n * eccsize; @@ -507,7 +507,7 @@ static int mxc_nand_read_page_syndrome(struct mtd_info *mtd, uint8_t *oob = chip->oob_poi;
MTDDEBUG(MTD_DEBUG_LEVEL1, "Reading page %u to buf %p oob %p\n", - host->page_addr, buf, oob); + page, buf, oob);
/* first read the data area and the available portion of OOB */ for (n = 0; eccsteps; n++, eccsteps--, p += eccsize) { @@ -545,7 +545,7 @@ static int mxc_nand_read_page_syndrome(struct mtd_info *mtd,
/* Then switch ECC off and read the OOB area to get the ECC code */ _mxc_nand_enable_hwecc(mtd, 0); - chip->cmdfunc(mtd, NAND_CMD_READOOB, mtd->writesize, host->page_addr); + chip->cmdfunc(mtd, NAND_CMD_READOOB, mtd->writesize, page); eccsteps = chip->ecc.steps; oob = chip->oob_poi + chip->ecc.prepad; for (n = 0; eccsteps; n++, eccsteps--, p += eccsize) {
_TEXT_BASE must be set to CONFIG_SPL_TEXT_BASE for generic SPL, and to CONFIG_SYS_TEXT_BASE for non-SPL builds.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - Apply to mxs SPL too.
Changes in v7: None Changes in v6: - New patch.
arch/arm/cpu/arm1136/start.S | 4 ++++ arch/arm/cpu/arm1176/start.S | 8 ++++++++ arch/arm/cpu/arm720t/start.S | 2 +- arch/arm/cpu/arm920t/start.S | 4 ++++ arch/arm/cpu/arm925t/start.S | 4 ++++ arch/arm/cpu/arm926ejs/mxs/start.S | 4 ++++ arch/arm/cpu/arm926ejs/start.S | 2 +- arch/arm/cpu/arm946es/start.S | 4 ++++ arch/arm/cpu/arm_intcm/start.S | 6 +++++- arch/arm/cpu/armv7/start.S | 4 ++++ arch/arm/cpu/ixp/start.S | 4 ++++ arch/arm/cpu/pxa/start.S | 2 +- arch/arm/cpu/s3c44b0/start.S | 4 ++++ arch/arm/cpu/sa1100/start.S | 4 ++++ 14 files changed, 52 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index a067b8a..4053e86 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -88,7 +88,11 @@ _end_vect:
.globl _TEXT_BASE _TEXT_BASE: +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) + .word CONFIG_SPL_TEXT_BASE +#else .word CONFIG_SYS_TEXT_BASE +#endif
/* * These are defined in the board-specific linker script. diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 40df4b1..d11386a 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -98,7 +98,15 @@ _end_vect:
.globl _TEXT_BASE _TEXT_BASE: +#ifdef CONFIG_NAND_SPL /* deprecated, use instead CONFIG_SPL_BUILD */ .word CONFIG_SYS_TEXT_BASE +#else +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) + .word CONFIG_SPL_TEXT_BASE +#else + .word CONFIG_SYS_TEXT_BASE +#endif +#endif
/* * Below variable is very important because we use MMU in U-Boot. diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index 771d386..83722aa 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -85,7 +85,7 @@ _pad: .word 0x12345678 /* now 16*4=64 */
.globl _TEXT_BASE _TEXT_BASE: -#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) .word CONFIG_SPL_TEXT_BASE #else .word CONFIG_SYS_TEXT_BASE diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index 511d21d..f4f14e1 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -73,7 +73,11 @@ _fiq: .word fiq
/* * These are defined in the board-specific linker script. diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index e8d6d71..95a0de7 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -79,7 +79,11 @@ _fiq: .word fiq
/* * These are defined in the board-specific linker script. diff --git a/arch/arm/cpu/arm926ejs/mxs/start.S b/arch/arm/cpu/arm926ejs/mxs/start.S index 7ccd337..94da398 100644 --- a/arch/arm/cpu/arm926ejs/mxs/start.S +++ b/arch/arm/cpu/arm926ejs/mxs/start.S @@ -119,7 +119,11 @@ fiq:
.globl _TEXT_BASE _TEXT_BASE: +#ifdef CONFIG_SPL_TEXT_BASE + .word CONFIG_SPL_TEXT_BASE +#else .word CONFIG_SYS_TEXT_BASE +#endif
/* * These are defined in the board-specific linker script. diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 66a8b65..39f9a2e 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -123,7 +123,7 @@ _TEXT_BASE: #ifdef CONFIG_NAND_SPL /* deprecated, use instead CONFIG_SPL_BUILD */ .word CONFIG_SYS_TEXT_BASE #else -#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) .word CONFIG_SPL_TEXT_BASE #else .word CONFIG_SYS_TEXT_BASE diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index a7a98a4..0d57294 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -89,7 +89,11 @@ _vectors_end:
/* * These are defined in the board-specific linker script. diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index c189849..f5e5381 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -85,7 +85,11 @@ _fiq:
.globl _TEXT_BASE _TEXT_BASE: - .word CONFIG_SYS_TEXT_BASE /* address of _start in the linked image */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) + .word CONFIG_SPL_TEXT_BASE +#else + .word CONFIG_SYS_TEXT_BASE +#endif
/* * These are defined in the board-specific linker script. diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 6b59529d..9bb42ae 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -81,7 +81,11 @@ _end_vect:
/* * These are defined in the board-specific linker script. diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index efb5a40..11e3efa 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -98,7 +98,11 @@ _fiq: .word fiq
/* * These are defined in the board-specific linker script. diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index e71803e..a276ee0 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -102,7 +102,7 @@ _end_vect:
.globl _TEXT_BASE _TEXT_BASE: -#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) .word CONFIG_SPL_TEXT_BASE #else .word CONFIG_SYS_TEXT_BASE diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 4528c91..974ca1b 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -64,7 +64,11 @@ _start: b reset
/* * These are defined in the board-specific linker script. diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 3144299..88769e3 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -74,7 +74,11 @@ _fiq: .word fiq
Signed-off-by: Beno??t Th??baudeau benoit.thebaudeau@advansee.com
Reviewed-by: Tom Rini trini@ti.com
Commit e05e5de7fae5bec79617e113916dac6631251156 made ARM's relocate_code() return to its caller, but it did not update its declaration accordingly.
Fixing this function declaration fixes dropped C code following calls to relocate_code().
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - Update relocate_code() description in ARM start.S comments.
Changes in v7: None Changes in v6: - New patch, extracted from "nand: mxc: Switch NAND SPL to generic SPL".
arch/arm/cpu/arm1136/start.S | 4 +--- arch/arm/cpu/arm1176/start.S | 4 +--- arch/arm/cpu/arm720t/start.S | 4 +--- arch/arm/cpu/arm920t/start.S | 4 +--- arch/arm/cpu/arm925t/start.S | 4 +--- arch/arm/cpu/arm926ejs/start.S | 4 +--- arch/arm/cpu/arm946es/start.S | 4 +--- arch/arm/cpu/arm_intcm/start.S | 4 +--- arch/arm/cpu/armv7/start.S | 4 +--- arch/arm/cpu/ixp/start.S | 4 +--- arch/arm/cpu/pxa/start.S | 4 +--- arch/arm/cpu/s3c44b0/start.S | 4 +--- arch/arm/cpu/sa1100/start.S | 4 +--- include/common.h | 6 +++++- 14 files changed, 18 insertions(+), 40 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 4053e86..f1cb1d5 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -176,9 +176,7 @@ next: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index d11386a..fe947cc 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -239,9 +239,7 @@ skip_tcmdisable: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index 83722aa..a3d06ce 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -154,9 +154,7 @@ reset: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index f4f14e1..e11460c 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -193,9 +193,7 @@ copyex: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 95a0de7..4030d49 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -183,9 +183,7 @@ poll1: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 39f9a2e..5600599 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -200,9 +200,7 @@ reset: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 0d57294..79ba8e3 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -158,9 +158,7 @@ reset: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index f5e5381..039677e 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -154,9 +154,7 @@ reset: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 9bb42ae..18dad12 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -167,9 +167,7 @@ reset: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ ENTRY(relocate_code) mov r4, r0 /* save addr_sp */ diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index 11e3efa..83823a6 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -256,9 +256,7 @@ reset: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index a276ee0..6325e5f 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -171,9 +171,7 @@ reset: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 974ca1b..0224898 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -139,9 +139,7 @@ reset: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 88769e3..dc79556 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -143,9 +143,7 @@ reset: /* * void relocate_code (addr_sp, gd, addr_moni) * - * This "function" does not return, instead it continues in RAM - * after relocating the monitor code. - * + * This function relocates the monitor code. */ .globl relocate_code relocate_code: diff --git a/include/common.h b/include/common.h index 4ad17ea..691e279 100644 --- a/include/common.h +++ b/include/common.h @@ -515,7 +515,11 @@ int dcache_status (void); void dcache_enable (void); void dcache_disable(void); void mmu_disable(void); -void relocate_code (ulong, gd_t *, ulong) __attribute__ ((noreturn)); +void relocate_code(ulong, gd_t *, ulong) +#if !defined(CONFIG_ARM) +__attribute__ ((noreturn)) +#endif +; ulong get_endaddr (void); void trap_init (ulong); #if defined (CONFIG_4xx) || \
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: None Changes in v7: None Changes in v6: - New patch, extracted from "nand: mxc: Switch NAND SPL to generic SPL".
arch/arm/cpu/arm1136/start.S | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index f1cb1d5..889fd53 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -237,8 +237,6 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop - bx lr - #endif
relocate_done:
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - Make sure that r9 is initialized in all cases because it may be used after relocate_code().
arch/arm/cpu/arm1136/start.S | 8 +++----- arch/arm/cpu/arm1176/start.S | 8 +++----- arch/arm/cpu/arm720t/start.S | 8 +++----- arch/arm/cpu/arm920t/start.S | 8 +++----- arch/arm/cpu/arm925t/start.S | 8 +++----- arch/arm/cpu/arm926ejs/start.S | 9 +++------ arch/arm/cpu/arm946es/start.S | 8 +++----- arch/arm/cpu/arm_intcm/start.S | 8 +++----- arch/arm/cpu/armv7/start.S | 8 +++----- arch/arm/cpu/ixp/start.S | 8 +++----- arch/arm/cpu/pxa/start.S | 8 +++----- arch/arm/cpu/s3c44b0/start.S | 8 +++----- arch/arm/cpu/sa1100/start.S | 8 +++----- 13 files changed, 39 insertions(+), 66 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 889fd53..131fd99 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -185,16 +185,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
adr r0, _start - cmp r0, r6 - moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ + subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: - ldmia r0!, {r9-r10} /* copy from source address [r0] */ - stmia r1!, {r9-r10} /* copy to target address [r1] */ + ldmia r0!, {r10-r11} /* copy from source address [r0] */ + stmia r1!, {r10-r11} /* copy to target address [r1] */ cmp r0, r2 /* until source end address [r2] */ blo copy_loop
@@ -203,7 +202,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index fe947cc..7be4e43 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -248,16 +248,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
adr r0, _start - cmp r0, r6 - moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ + subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */
@@ -266,7 +265,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index a3d06ce..74c0664 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -163,16 +163,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
@@ -181,7 +180,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index e11460c..ba4dd85 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -202,16 +202,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
@@ -220,7 +219,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 4030d49..e3b84ef 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -192,16 +192,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
@@ -210,7 +209,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 5600599..25111f6 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -209,17 +209,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
adr r0, _start - sub r9, r6, r0 /* r9 <- relocation offset */ - cmp r0, r6 - moveq r9, #0 /* no relocation. offset(r9) = 0 */ + subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */
@@ -228,7 +226,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 79ba8e3..24b8b1d 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -167,16 +167,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
@@ -185,7 +184,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index 039677e..f6934f0 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -163,16 +163,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
@@ -181,7 +180,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 18dad12..0975896 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -175,16 +175,15 @@ ENTRY(relocate_code) mov r6, r2 /* save addr of destination */
@@ -192,7 +191,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index 83823a6..397c660 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -265,16 +265,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
@@ -283,7 +282,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 6325e5f..51dd210 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -187,16 +187,15 @@ relocate_code: #endif
@@ -205,7 +204,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 0224898..f037079 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -148,16 +148,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
@@ -166,7 +165,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index dc79556..03d8a02 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -152,16 +152,15 @@ relocate_code: mov r6, r2 /* save addr of destination */
@@ -170,7 +169,6 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */
Use __image_copy_end instead of __bss_start for the end of the image to relocate. This is the same as commit 033ca72, but applied to all ARM start.S.
This is a more appropriate symbol naming for an image copy & relocate feature, and this also saves a useless copy of data put between __image_copy_end and __bss_start in linker scripts (e.g. relocation information, or MMU initialization tables used only before jumping to the relocated image).
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - Fix "space before tab" warning. - Give more details in patch description.
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
arch/arm/cpu/arm1136/start.S | 4 ++-- arch/arm/cpu/arm1176/start.S | 6 +++++- arch/arm/cpu/arm720t/start.S | 6 +++++- arch/arm/cpu/arm920t/ep93xx/u-boot.lds | 3 +++ arch/arm/cpu/arm920t/start.S | 6 +++++- arch/arm/cpu/arm925t/start.S | 6 +++++- arch/arm/cpu/arm926ejs/start.S | 6 +++++- arch/arm/cpu/arm946es/start.S | 6 +++++- arch/arm/cpu/arm_intcm/start.S | 6 +++++- arch/arm/cpu/armv7/start.S | 4 ++-- arch/arm/cpu/ixp/start.S | 6 +++++- arch/arm/cpu/ixp/u-boot.lds | 2 ++ arch/arm/cpu/pxa/start.S | 6 +++++- arch/arm/cpu/s3c44b0/start.S | 6 +++++- arch/arm/cpu/sa1100/start.S | 6 +++++- board/actux1/u-boot.lds | 3 +++ board/actux2/u-boot.lds | 3 +++ board/actux3/u-boot.lds | 3 +++ board/davinci/da8xxevm/u-boot-spl-hawk.lds | 1 + board/dvlhost/u-boot.lds | 3 +++ board/samsung/smdk6400/u-boot-nand.lds | 4 ++++ board/vpac270/u-boot-spl.lds | 2 ++ nand_spl/board/karo/tx25/u-boot.lds | 2 ++ nand_spl/board/samsung/smdk6400/u-boot.lds | 2 ++ 24 files changed, 87 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 131fd99..b3e3e37 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -104,9 +104,9 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
-.global _image_copy_end_ofs +.globl _image_copy_end_ofs _image_copy_end_ofs: - .word __image_copy_end - _start + .word __image_copy_end - _start
.globl _bss_end_ofs _bss_end_ofs: diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 7be4e43..4f98f8b 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -127,6 +127,10 @@ _TEXT_PHY_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -251,7 +255,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index 74c0664..850fce0 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -101,6 +101,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -166,7 +170,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/arm920t/ep93xx/u-boot.lds b/arch/arm/cpu/arm920t/ep93xx/u-boot.lds index 008ae89..62315de 100644 --- a/arch/arm/cpu/arm920t/ep93xx/u-boot.lds +++ b/arch/arm/cpu/arm920t/ep93xx/u-boot.lds @@ -55,6 +55,9 @@ SECTIONS }
. = ALIGN(4); + + __image_copy_end = .; + __bss_start = .; .bss : { *(.bss) } __bss_end__ = .; diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index ba4dd85..e2958d3 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -89,6 +89,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -205,7 +209,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index e3b84ef..4b64122 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -95,6 +95,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -195,7 +199,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 25111f6..edff38a 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -140,6 +140,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -212,7 +216,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 24b8b1d..48b7b62 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -105,6 +105,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -170,7 +174,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index f6934f0..5016c3c 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -101,6 +101,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
copy_loop: diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 0975896..cc68347 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -94,9 +94,9 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
.globl _bss_end_ofs _bss_end_ofs: diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index 397c660..f6bec3b 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -114,6 +114,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -268,7 +272,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/ixp/u-boot.lds b/arch/arm/cpu/ixp/u-boot.lds index 81d954f..d9bb5da 100644 --- a/arch/arm/cpu/ixp/u-boot.lds +++ b/arch/arm/cpu/ixp/u-boot.lds @@ -54,6 +54,8 @@ SECTIONS
. = ALIGN(4);
+ __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*) diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 51dd210..8c64411 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -118,6 +118,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -190,7 +194,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index f037079..0924925 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -80,6 +80,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -151,7 +155,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 03d8a02..fe6c429 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -90,6 +90,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.globl _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -155,7 +159,7 @@ relocate_code: subs r9, r6, r0 /* r9 <- relocation offset */ beq relocate_done /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/board/actux1/u-boot.lds b/board/actux1/u-boot.lds index c41eed0..34ed90d 100644 --- a/board/actux1/u-boot.lds +++ b/board/actux1/u-boot.lds @@ -61,6 +61,9 @@ SECTIONS }
. = ALIGN (4); + + __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*) diff --git a/board/actux2/u-boot.lds b/board/actux2/u-boot.lds index 8409984..8337457 100644 --- a/board/actux2/u-boot.lds +++ b/board/actux2/u-boot.lds @@ -61,6 +61,9 @@ SECTIONS }
. = ALIGN (4); + + __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*) diff --git a/board/actux3/u-boot.lds b/board/actux3/u-boot.lds index a3bd02b..a72a666 100644 --- a/board/actux3/u-boot.lds +++ b/board/actux3/u-boot.lds @@ -61,6 +61,9 @@ SECTIONS }
. = ALIGN (4); + + __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*) diff --git a/board/davinci/da8xxevm/u-boot-spl-hawk.lds b/board/davinci/da8xxevm/u-boot-spl-hawk.lds index 86dc172..174955e 100644 --- a/board/davinci/da8xxevm/u-boot-spl-hawk.lds +++ b/board/davinci/da8xxevm/u-boot-spl-hawk.lds @@ -63,6 +63,7 @@ SECTIONS }
. = ALIGN(4); + __image_copy_end = .; __rel_dyn_start = .; __rel_dyn_end = .; __dynsym_start = .; diff --git a/board/dvlhost/u-boot.lds b/board/dvlhost/u-boot.lds index 1bd1700..9c14daa 100644 --- a/board/dvlhost/u-boot.lds +++ b/board/dvlhost/u-boot.lds @@ -61,6 +61,9 @@ SECTIONS }
. = ALIGN (4); + + __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*) diff --git a/board/samsung/smdk6400/u-boot-nand.lds b/board/samsung/smdk6400/u-boot-nand.lds index fbb442a..2c3a60b 100644 --- a/board/samsung/smdk6400/u-boot-nand.lds +++ b/board/samsung/smdk6400/u-boot-nand.lds @@ -53,6 +53,10 @@ SECTIONS #include <u-boot.lst> }
+ . = ALIGN(4); + + __image_copy_end = .; + . = align(4); .mmudata : { *(.mmudata) }
diff --git a/board/vpac270/u-boot-spl.lds b/board/vpac270/u-boot-spl.lds index 20161a4..e344436 100644 --- a/board/vpac270/u-boot-spl.lds +++ b/board/vpac270/u-boot-spl.lds @@ -63,6 +63,8 @@ SECTIONS
. = ALIGN(4);
+ __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*) diff --git a/nand_spl/board/karo/tx25/u-boot.lds b/nand_spl/board/karo/tx25/u-boot.lds index ee36131..95ea8ac 100644 --- a/nand_spl/board/karo/tx25/u-boot.lds +++ b/nand_spl/board/karo/tx25/u-boot.lds @@ -54,6 +54,8 @@ SECTIONS
. = ALIGN(4);
+ __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*) diff --git a/nand_spl/board/samsung/smdk6400/u-boot.lds b/nand_spl/board/samsung/smdk6400/u-boot.lds index 2ed6466..293ae02 100644 --- a/nand_spl/board/samsung/smdk6400/u-boot.lds +++ b/nand_spl/board/samsung/smdk6400/u-boot.lds @@ -58,6 +58,8 @@ SECTIONS
. = ALIGN(4);
The purpose of .globl is to export symbols for ld, not to declare external symbols.
By the way, use the ENTRY() and ENDPROC() macros to define functions rather than using .global directly.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - Use ENTRY() and ENDPROC() to define functions.
arch/arm/lib/crt0.S | 28 ++++------------------------ 1 file changed, 4 insertions(+), 24 deletions(-)
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 4f60958..56b433e 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -24,6 +24,7 @@
#include <config.h> #include <asm-offsets.h> +#include <linux/linkage.h>
/* * This file handles the target-independent stages of the U-Boot @@ -67,33 +68,10 @@ */
/* - * declare nand_boot() or board_init_r() to jump to at end of crt0 - */ - -#if defined(CONFIG_NAND_SPL) - -.globl nand_boot - -#elif ! defined(CONFIG_SPL_BUILD) - -.globl board_init_r - -#endif - -/* - * start and end of BSS - */ - -.globl __bss_start -.globl __bss_end__ - -/* * entry point of crt0 sequence */
-.global _main - -_main: +ENTRY(_main)
/* * Set up initial C runtime environment and call board_init_f(0). @@ -171,3 +149,5 @@ clbss_l:cmp r0, r1 /* while not at end of BSS */ /* we should not return here. */
#endif + +ENDPROC(_main)
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - New patch.
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
tools/scripts/define2mk.sed | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/tools/scripts/define2mk.sed b/tools/scripts/define2mk.sed index 13e2845..c641edf 100644 --- a/tools/scripts/define2mk.sed +++ b/tools/scripts/define2mk.sed @@ -24,6 +24,8 @@ s/="([0-9][0-9]*)"/=\1/; # ... and from hex numbers s/="(0[Xx][0-9a-fA-F][0-9a-fA-F]*)"/=\1/; + # ... and from configs defined from other configs + s/="(CONFIG_[A-Za-z0-9_][A-Za-z0-9_]*)"/=$(\1)/; # Change '1' and empty values to "y" (not perfect, but # supports conditional compilation in the makefiles s/=$/=y/;
Changes in v8:
- New patch.
- # ... and from configs defined from other configs
- s/="(CONFIG_[A-Za-z0-9_][A-Za-z0-9_]*)"/=$(\1)/; # Change '1' and empty values to "y" (not perfect, but # supports conditional compilation in the makefiles s/=$/=y/;
OK, please add a little more to the commit message, such as an example of how this works or gives us now? Thanks.
Hi Tom,
Changes in v8:
- New patch.
OK, I'll do that in v9.
Thanks for the reviews.
Change CONFIG_SPL_PAD_TO from a link address to an image offset since this is more handy and closer to the purpose of this config.
Automatically define CONFIG_SPL_PAD_TO to CONFIG_SPL_MAX_SIZE (or 0 without CONFIG_SPL_MAX_SIZE).
Test that CONFIG_SPL_PAD_TO >= CONFIG_SPL_MAX_SIZE if CONFIG_SPL_PAD_TO is non-zero.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - Rebase on latest u-boot-imx/master. - Use CONFIG_SPL_PAD_TO instead of CONFIG_SPL_MAX_SIZE for u-boot-with-spl.bin padding.
Changes in v7: - Use u-boot-spl.bin instead of u-boot-spl in order to avoid having to use --change-addresses.
Changes in v6: - Fix size passed to --pad-to thanks to --change-addresses.
Makefile | 5 ++--- README | 7 +++++-- include/config_fallbacks.h | 16 ++++++++++++++++ include/configs/MPC8313ERDB.h | 2 +- 4 files changed, 24 insertions(+), 6 deletions(-)
diff --git a/Makefile b/Makefile index 33d4253..5bcc914 100644 --- a/Makefile +++ b/Makefile @@ -484,9 +484,8 @@ $(obj)u-boot.dis: $(obj)u-boot
$(obj)u-boot-with-spl.bin: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin - $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(or $(CONFIG_SPL_PAD_TO),0) \ - -O binary $(obj)spl/u-boot-spl \ - $(obj)spl/u-boot-spl-pad.bin + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(CONFIG_SPL_PAD_TO) \ + -I binary -O binary $< $(obj)spl/u-boot-spl-pad.bin cat $(obj)spl/u-boot-spl-pad.bin $(obj)u-boot.bin > $@ rm $(obj)spl/u-boot-spl-pad.bin
diff --git a/README b/README index 11ffa71..938c38a 100644 --- a/README +++ b/README @@ -2883,8 +2883,11 @@ FIT uImage format: Support for lib/libgeneric.o in SPL binary
CONFIG_SPL_PAD_TO - Linker address to which the SPL should be padded before - appending the SPL payload. + Image offset to which the SPL should be padded before appending + the SPL payload. By default, this is defined as + CONFIG_SPL_MAX_SIZE, or 0 if CONFIG_SPL_MAX_SIZE is undefined. + CONFIG_SPL_PAD_TO must be either 0, meaning to append the SPL + payload without any padding, or >= CONFIG_SPL_MAX_SIZE.
CONFIG_SPL_TARGET Final target image containing SPL and payload. Some SPLs diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index bfb9680..457c99e 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -9,6 +9,22 @@ #ifndef __CONFIG_FALLBACKS_H #define __CONFIG_FALLBACKS_H
+#ifdef CONFIG_SPL +#ifdef CONFIG_SPL_PAD_TO +#ifdef CONFIG_SPL_MAX_SIZE +#if CONFIG_SPL_PAD_TO && CONFIG_SPL_PAD_TO < CONFIG_SPL_MAX_SIZE +#error CONFIG_SPL_PAD_TO < CONFIG_SPL_MAX_SIZE +#endif +#endif +#else +#ifdef CONFIG_SPL_MAX_SIZE +#define CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE +#else +#define CONFIG_SPL_PAD_TO 0 +#endif +#endif +#endif + #ifndef CONFIG_SYS_BAUDRATE_TABLE #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } #endif diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 275d4f2..c28dfe0 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -52,7 +52,7 @@ #define CONFIG_SYS_TEXT_BASE 0x00100000 /* CONFIG_SYS_NAND_U_BOOT_DST */ #define CONFIG_SYS_TEXT_BASE_SPL 0xfff00000 #define CONFIG_SPL_MAX_SIZE (4 * 1024) -#define CONFIG_SPL_PAD_TO 0xfff04000 +#define CONFIG_SPL_PAD_TO 0x4000
#define CONFIG_SYS_NAND_U_BOOT_SIZE (512 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x00100000
Automatically build the 'u-boot.imx' (i.e. imx header + u-boot.bin) and 'SPL' (i.e. imx header + u-boot-spl.bin) make targets for all imx processors supporting this header, so for arm926ejs, arm1136 and armv7. Some combinations were missing.
At the same time, fix the build of SPL targets not supporting the imx header on arm1136. For arm1136, the 'SPL' make target was forced to build in all cases if CONFIG_SPL_BUILD was defined, even for non-imx platforms or imx setups without an imx header.
arch/arm/cpu/arm1136/config.mk | 7 +++++++ arch/arm/cpu/arm926ejs/config.mk | 8 ++++++-- arch/arm/cpu/armv7/config.mk | 6 ++++++ 3 files changed, 19 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm1136/config.mk b/arch/arm/cpu/arm1136/config.mk index 9092d91..797d122 100644 --- a/arch/arm/cpu/arm1136/config.mk +++ b/arch/arm/cpu/arm1136/config.mk @@ -31,6 +31,13 @@ PLATFORM_CPPFLAGS += -march=armv5 # ========================================================================= PF_RELFLAGS_SLB_AT := $(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,)) PLATFORM_RELFLAGS += $(PF_RELFLAGS_SLB_AT) + +ifneq ($(CONFIG_IMX_CONFIG),) +ifdef CONFIG_SPL ifdef CONFIG_SPL_BUILD ALL-y += $(OBJTREE)/SPL endif +else +ALL-y += $(obj)u-boot.imx +endif +endif diff --git a/arch/arm/cpu/arm926ejs/config.mk b/arch/arm/cpu/arm926ejs/config.mk index 6a3a1bb..f0e31d1 100644 --- a/arch/arm/cpu/arm926ejs/config.mk +++ b/arch/arm/cpu/arm926ejs/config.mk @@ -33,7 +33,11 @@ PF_RELFLAGS_SLB_AT := $(call cc-option,-mshort-load-bytes,$(call cc-option,-mali PLATFORM_RELFLAGS += $(PF_RELFLAGS_SLB_AT)
ifneq ($(CONFIG_IMX_CONFIG),) - +ifdef CONFIG_SPL +ifdef CONFIG_SPL_BUILD +ALL-y += $(OBJTREE)/SPL +endif +else ALL-y += $(obj)u-boot.imx - +endif endif diff --git a/arch/arm/cpu/armv7/config.mk b/arch/arm/cpu/armv7/config.mk index 9c3e2f3..56b8053 100644 --- a/arch/arm/cpu/armv7/config.mk +++ b/arch/arm/cpu/armv7/config.mk @@ -40,5 +40,11 @@ PF_NO_UNALIGNED := $(call cc-option, -mno-unaligned-access,) PLATFORM_NO_UNALIGNED := $(PF_NO_UNALIGNED)
ifneq ($(CONFIG_IMX_CONFIG),) +ifdef CONFIG_SPL +ifdef CONFIG_SPL_BUILD +ALL-y += $(OBJTREE)/SPL +endif +else ALL-y += $(obj)u-boot.imx endif +endif
This also fixes support for mx31pdk and tx25, which had been broken by commit e05e5de7fae5bec79617e113916dac6631251156.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Tested-by: Fabio Estevam fabio.estevam@freescale.com --- Changes in v8: - Update doc/README.arm-relocation. - Drop useless line feed at end of inline asm. - Set CONFIG_SYS_NAND_U_BOOT_OFFS to CONFIG_SPL_PAD_TO instead of CONFIG_SPL_MAX_SIZE (this is a cosmetic change since they now have the same value). - Enlarge CONFIG_SYS_NAND_U_BOOT_SIZE from 0x30000 to 0x32000 to let u-boot.bin fit in.
Changes in v7: None Changes in v6: - Automate 'u-boot.imx' and 'SPL' make targets for all imx processors. - Move board_init_f() to <board>.c. - Get rid of board SPL linker scripts. - Define CONFIG_SYS_NAND_U_BOOT_OFFS as CONFIG_SPL_MAX_SIZE rather than duplicating the constant value. - Define CONFIG_SYS_NAND_U_BOOT_DST as CONFIG_SYS_TEXT_BASE rather than duplicating the constant value. - Pass 0 as the 1st argument to relocate_code() since it's unused. - Fix stack pointers. - Rebase on latest u-boot-imx/master. - Move unrelated changes to separate patches.
Changes in v5: - Remove spaces between function name and open parenthesis. - Fix mx31pdk and tx25 Makefile-s and SPL linker scripts. - Remove the useless definition of CONFIG_SPL_LDSCRIPT. - Fix the call to nand_boot().
arch/arm/cpu/arm926ejs/start.S | 3 +- board/freescale/mx31pdk/Makefile | 3 + board/freescale/mx31pdk/config.mk | 5 -- board/freescale/mx31pdk/mx31pdk.c | 8 ++ board/karo/tx25/Makefile | 4 +- board/karo/tx25/config.mk | 5 -- board/karo/tx25/tx25.c | 8 ++ boards.cfg | 2 +- doc/README.arm-relocation | 14 +-- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/mxc_nand.c | 10 +-- include/fsl_nfc.h => drivers/mtd/nand/mxc_nand.h | 10 +-- .../mtd/nand/mxc_nand_spl.c | 26 ++---- include/configs/mx31pdk.h | 19 +++-- include/configs/tx25.h | 22 +++-- nand_spl/board/freescale/mx31pdk/Makefile | 68 --------------- nand_spl/board/freescale/mx31pdk/u-boot.lds | 87 ------------------- nand_spl/board/karo/tx25/Makefile | 89 -------------------- nand_spl/board/karo/tx25/config.mk | 1 - nand_spl/board/karo/tx25/u-boot.lds | 87 ------------------- 20 files changed, 80 insertions(+), 392 deletions(-) delete mode 100644 board/freescale/mx31pdk/config.mk delete mode 100644 board/karo/tx25/config.mk rename include/fsl_nfc.h => drivers/mtd/nand/mxc_nand.h (98%) rename nand_spl/nand_boot_fsl_nfc.c => drivers/mtd/nand/mxc_nand_spl.c (92%) delete mode 100644 nand_spl/board/freescale/mx31pdk/Makefile delete mode 100644 nand_spl/board/freescale/mx31pdk/u-boot.lds delete mode 100644 nand_spl/board/karo/tx25/Makefile delete mode 100644 nand_spl/board/karo/tx25/config.mk delete mode 100644 nand_spl/board/karo/tx25/u-boot.lds
diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index edff38a..9121af2 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -200,7 +200,6 @@ reset:
-#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_NAND_SPL) /* * void relocate_code (addr_sp, gd, addr_moni) * @@ -269,6 +268,8 @@ relocate_done:
bx lr
+#ifndef CONFIG_SPL_BUILD + _rel_dyn_start_ofs: .word __rel_dyn_start - _start _rel_dyn_end_ofs: diff --git a/board/freescale/mx31pdk/Makefile b/board/freescale/mx31pdk/Makefile index 5b7cafd..b910722 100644 --- a/board/freescale/mx31pdk/Makefile +++ b/board/freescale/mx31pdk/Makefile @@ -27,6 +27,9 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
+ifdef CONFIG_SPL_BUILD +SOBJS := lowlevel_init.o +endif COBJS := mx31pdk.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/board/freescale/mx31pdk/config.mk b/board/freescale/mx31pdk/config.mk deleted file mode 100644 index de2c642..0000000 --- a/board/freescale/mx31pdk/config.mk +++ /dev/null @@ -1,5 +0,0 @@ -ifdef CONFIG_NAND_SPL -CONFIG_SYS_TEXT_BASE = 0x87ec0000 -else -CONFIG_SYS_TEXT_BASE = 0x87f00000 -endif diff --git a/board/freescale/mx31pdk/mx31pdk.c b/board/freescale/mx31pdk/mx31pdk.c index 895396c..3d0d419 100644 --- a/board/freescale/mx31pdk/mx31pdk.c +++ b/board/freescale/mx31pdk/mx31pdk.c @@ -36,6 +36,14 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_SPL_BUILD +void board_init_f(ulong bootflag) +{ + relocate_code(0, NULL, CONFIG_SPL_TEXT_BASE); + asm volatile("ldr pc, =nand_boot"); +} +#endif + int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ diff --git a/board/karo/tx25/Makefile b/board/karo/tx25/Makefile index 9617fa5..c26bf36 100644 --- a/board/karo/tx25/Makefile +++ b/board/karo/tx25/Makefile @@ -25,8 +25,10 @@ include $(TOPDIR)/config.mk
-COBJS := tx25.o +ifdef CONFIG_SPL_BUILD SOBJS := lowlevel_init.o +endif +COBJS := tx25.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/karo/tx25/config.mk b/board/karo/tx25/config.mk deleted file mode 100644 index 18b2883..0000000 --- a/board/karo/tx25/config.mk +++ /dev/null @@ -1,5 +0,0 @@ -ifdef CONFIG_NAND_SPL -CONFIG_SYS_TEXT_BASE = 0x810c0000 -else -CONFIG_SYS_TEXT_BASE = 0x81200000 -endif diff --git a/board/karo/tx25/tx25.c b/board/karo/tx25/tx25.c index 362f00a..69ee590 100644 --- a/board/karo/tx25/tx25.c +++ b/board/karo/tx25/tx25.c @@ -33,6 +33,14 @@
+#ifdef CONFIG_SPL_BUILD +void board_init_f(ulong bootflag) +{ + relocate_code(0, NULL, CONFIG_SPL_TEXT_BASE); + asm volatile("ldr pc, =nand_boot"); +} +#endif + #ifdef CONFIG_FEC_MXC #define GPIO_FEC_RESET_B IMX_GPIO_NR(4, 7) #define GPIO_FEC_ENABLE_B IMX_GPIO_NR(4, 9) diff --git a/boards.cfg b/boards.cfg index 7a0b79d..8b4c6b8 100644 --- a/boards.cfg +++ b/boards.cfg @@ -45,7 +45,7 @@ imx31_phycore arm arm1136 - - imx31_phycore_eet arm arm1136 imx31_phycore - mx31 imx31_phycore:IMX31_PHYCORE_EET qong arm arm1136 - davedenx mx31 mx31ads arm arm1136 - freescale mx31 -mx31pdk arm arm1136 - freescale mx31 mx31pdk:NAND_U_BOOT +mx31pdk arm arm1136 - freescale mx31 tt01 arm arm1136 - hale mx31 imx31_litekit arm arm1136 - logicpd mx31 flea3 arm arm1136 - CarMediaLab mx35 diff --git a/doc/README.arm-relocation b/doc/README.arm-relocation index 5a9a2fb..645b374 100644 --- a/doc/README.arm-relocation +++ b/doc/README.arm-relocation @@ -40,15 +40,15 @@ Boards which are not fixed to support relocation will be REMOVED!
-For boards which boot from nand_spl, it is possible to save one copy +For boards which boot from spl, it is possible to save one copy if CONFIG_SYS_TEXT_BASE == relocation address! This prevents that uboot code is copied again in relocate_code().
-example for the tx25 board: +example for the tx25 board booting from NAND Flash:
a) cpu starts b) it copies the first page in nand to internal ram - (nand_spl_code) + (spl code) c) end executes this code d) this initialize CPU, RAM, ... and copy itself to RAM (this bin must fit in one page, so board_init_f() @@ -79,20 +79,20 @@ TODO
-Relocation with NAND_SPL (example for the tx25): +Relocation with SPL (example for the tx25 booting from NAND Flash):
- cpu copies the first page from NAND to 0xbb000000 (IMX_NFC_BASE) and start with code execution on this address.
-- The First page contains u-boot code from u-boot:nand_spl/nand_boot_fsl_nfc.c - which inits the dram, cpu registers, reloacte itself to CONFIG_SYS_TEXT_BASE and loads +- The First page contains u-boot code from drivers/mtd/nand/mxc_nand_spl.c + which inits the dram, cpu registers, reloacte itself to CONFIG_SPL_TEXT_BASE and loads the "real" u-boot to CONFIG_SYS_NAND_U_BOOT_DST and starts execution @CONFIG_SYS_NAND_U_BOOT_START
- This u-boot does no RAM init, nor CPU register setup. Just look where it has to copy and relocate itself to this address. If relocate address = CONFIG_SYS_TEXT_BASE (not the same, as the - CONFIG_SYS_TEXT_BASE from the nand_spl code), then there is no need + CONFIG_SPL_TEXT_BASE from the spl code), then there is no need to copy, just go on with bss clear and jump to board_init_r.
----------------------------------------------------------------------------- diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index c77c0c4..bcb7161 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -82,6 +82,7 @@ COBJS-$(CONFIG_NAND_PLAT) += nand_plat.o else # minimal SPL drivers
COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_spl.o +COBJS-$(CONFIG_NAND_MXC) += mxc_nand_spl.o
endif # drivers endif # nand diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index 29ceab3..507bbc2 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -26,7 +26,7 @@ defined(CONFIG_MX51) || defined(CONFIG_MX53) #include <asm/arch/imx-regs.h> #endif -#include <fsl_nfc.h> +#include "mxc_nand.h"
#define DRIVER_NAME "mxc_nand"
@@ -36,9 +36,9 @@ struct mxc_nand_host { struct mtd_info mtd; struct nand_chip *nand;
- struct fsl_nfc_regs __iomem *regs; + struct mxc_nand_regs __iomem *regs; #ifdef MXC_NFC_V3_2 - struct fsl_nfc_ip_regs __iomem *ip_regs; + struct mxc_nand_ip_regs __iomem *ip_regs; #endif int spare_only; int status_request; @@ -1213,10 +1213,10 @@ int board_nand_init(struct nand_chip *this) this->read_buf = mxc_nand_read_buf; this->verify_buf = mxc_nand_verify_buf;
- host->regs = (struct fsl_nfc_regs __iomem *)CONFIG_MXC_NAND_REGS_BASE; + host->regs = (struct mxc_nand_regs __iomem *)CONFIG_MXC_NAND_REGS_BASE; #ifdef MXC_NFC_V3_2 host->ip_regs = - (struct fsl_nfc_ip_regs __iomem *)CONFIG_MXC_NAND_IP_REGS_BASE; + (struct mxc_nand_ip_regs __iomem *)CONFIG_MXC_NAND_IP_REGS_BASE; #endif host->clk_act = 1;
diff --git a/include/fsl_nfc.h b/drivers/mtd/nand/mxc_nand.h similarity index 98% rename from include/fsl_nfc.h rename to drivers/mtd/nand/mxc_nand.h index 48a6448..308ff8d 100644 --- a/include/fsl_nfc.h +++ b/drivers/mtd/nand/mxc_nand.h @@ -20,8 +20,8 @@ * MA 02111-1307 USA */
-#ifndef __FSL_NFC_H -#define __FSL_NFC_H +#ifndef __MXC_NAND_H +#define __MXC_NAND_H
/* * Register map and bit definitions for the Freescale NAND Flash Controller @@ -73,7 +73,7 @@ #define NAND_MXC_REG_OFFSET 0x1e00 #endif
-struct fsl_nfc_regs { +struct mxc_nand_regs { u8 main_area[NAND_MXC_NR_BUFS][0x200]; u8 spare_area[NAND_MXC_NR_BUFS][NAND_MXC_SPARE_BUF_SIZE]; /* @@ -131,7 +131,7 @@ struct fsl_nfc_regs { };
#ifdef MXC_NFC_V3_2 -struct fsl_nfc_ip_regs { +struct mxc_nand_ip_regs { u32 wrprot; u32 wrprot_unlock_blkaddr[8]; u32 config2; @@ -222,4 +222,4 @@ struct fsl_nfc_ip_regs { #define writenfc writel #endif
-#endif /* __FSL_NFC_H */ +#endif /* __MXC_NAND_H */ diff --git a/nand_spl/nand_boot_fsl_nfc.c b/drivers/mtd/nand/mxc_nand_spl.c similarity index 92% rename from nand_spl/nand_boot_fsl_nfc.c rename to drivers/mtd/nand/mxc_nand_spl.c index 1096727..09f23c3 100644 --- a/nand_spl/nand_boot_fsl_nfc.c +++ b/drivers/mtd/nand/mxc_nand_spl.c @@ -28,13 +28,13 @@ #include <nand.h> #include <asm/arch/imx-regs.h> #include <asm/io.h> -#include <fsl_nfc.h> +#include "mxc_nand.h"
#if defined(MXC_NFC_V1) || defined(MXC_NFC_V2_1) -static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR; +static struct mxc_nand_regs *const nfc = (void *)NFC_BASE_ADDR; #elif defined(MXC_NFC_V3_2) -static struct fsl_nfc_regs *const nfc = (void *)NFC_BASE_ADDR_AXI; -static struct fsl_nfc_ip_regs *const nfc_ip = (void *)NFC_BASE_ADDR; +static struct mxc_nand_regs *const nfc = (void *)NFC_BASE_ADDR_AXI; +static struct mxc_nand_ip_regs *const nfc_ip = (void *)NFC_BASE_ADDR; #endif
static void nfc_wait_ready(void) @@ -68,7 +68,7 @@ static void nfc_nand_init(void)
tmp = (readnfc(&nfc_ip->config2) & ~(NFC_V3_CONFIG2_SPAS_MASK | NFC_V3_CONFIG2_EDC_MASK | NFC_V3_CONFIG2_PS_MASK)) | - NFC_V3_CONFIG2_SPAS(CONFIG_SYS_NAND_SPARE_SIZE / 2) | + NFC_V3_CONFIG2_SPAS(CONFIG_SYS_NAND_OOBSIZE / 2) | NFC_V3_CONFIG2_INT_MSK | NFC_V3_CONFIG2_ECC_EN | NFC_V3_CONFIG2_ONE_CYCLE; if (CONFIG_SYS_NAND_PAGE_SIZE == 4096) @@ -81,7 +81,7 @@ static void nfc_nand_init(void) * if spare size is larger that 16 bytes per 512 byte hunk * then use 8 symbol correction instead of 4 */ - if (CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16) + if (CONFIG_SYS_NAND_OOBSIZE / ecc_per_page > 16) tmp |= NFC_V3_CONFIG2_ECC_MODE_8; else tmp &= ~NFC_V3_CONFIG2_ECC_MODE_8; @@ -102,7 +102,7 @@ static void nfc_nand_init(void) int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; int config1;
- writenfc(CONFIG_SYS_NAND_SPARE_SIZE / 2, &nfc->spare_area_size); + writenfc(CONFIG_SYS_NAND_OOBSIZE / 2, &nfc->spare_area_size);
/* unlocking RAM Buff */ writenfc(0x2, &nfc->config); @@ -115,7 +115,7 @@ static void nfc_nand_init(void) * if spare size is larger that 16 bytes per 512 byte hunk * then use 8 symbol correction instead of 4 */ - if (CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16) + if (CONFIG_SYS_NAND_OOBSIZE / ecc_per_page > 16) config1 &= ~NFC_V2_CONFIG1_ECC_MODE_4; else config1 |= NFC_V2_CONFIG1_ECC_MODE_4; @@ -204,7 +204,7 @@ static int nfc_nand_check_ecc(void) #elif defined(MXC_NFC_V2_1) || defined(MXC_NFC_V3_2) u32 ecc_status = readl(&nfc->ecc_status_result); int ecc_per_page = CONFIG_SYS_NAND_PAGE_SIZE / 512; - int err_limit = CONFIG_SYS_NAND_SPARE_SIZE / ecc_per_page > 16 ? 8 : 4; + int err_limit = CONFIG_SYS_NAND_OOBSIZE / ecc_per_page > 16 ? 8 : 4; int subpages = CONFIG_SYS_NAND_PAGE_SIZE / 512;
do { @@ -332,14 +332,6 @@ static int nand_load(unsigned int from, unsigned int size, unsigned char *buf) return 0; }
-#if defined(CONFIG_ARM) -void board_init_f (ulong bootflag) -{ - relocate_code (CONFIG_SYS_TEXT_BASE - TOTAL_MALLOC_LEN, NULL, - CONFIG_SYS_TEXT_BASE); -} -#endif - /* * The main entry for NAND booting. It's necessary that SDRAM is already * configured and available since this code loads the main U-Boot image diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 34e4295..4447c64 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -45,7 +45,16 @@
#define CONFIG_MACH_TYPE MACH_TYPE_MX31_3DS
-#if defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) +#define CONFIG_SPL +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LDSCRIPT "arch/$(ARCH)/cpu/u-boot.lds" +#define CONFIG_SPL_MAX_SIZE 2048 +#define CONFIG_SPL_NAND_SUPPORT + +#define CONFIG_SPL_TEXT_BASE 0x87ec0000 +#define CONFIG_SYS_TEXT_BASE 0x87f00000 + +#ifndef CONFIG_SPL_BUILD #define CONFIG_SKIP_LOWLEVEL_INIT #endif
@@ -163,7 +172,7 @@ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_GBL_DATA_OFFSET) + CONFIG_SYS_INIT_RAM_SIZE)
/*----------------------------------------------------------------------- * FLASH and environment organization @@ -189,10 +198,10 @@ /* NAND configuration for the NAND_SPL */
/* Start copying real U-boot from the second page */ -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x800 -#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x30000 +#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x32000 /* Load U-Boot to this address */ -#define CONFIG_SYS_NAND_U_BOOT_DST 0x87f00000 +#define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST
#define CONFIG_SYS_NAND_PAGE_SIZE 0x800 diff --git a/include/configs/tx25.h b/include/configs/tx25.h index 80194d8..bdfa3e5 100644 --- a/include/configs/tx25.h +++ b/include/configs/tx25.h @@ -21,6 +21,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#include <asm/arch/imx-regs.h>
/* * KARO TX25 board - SoC Configuration @@ -31,8 +32,14 @@
#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* 256 kB for U-Boot */
-/* NAND BOOT is the only boot method */ -#define CONFIG_NAND_U_BOOT +#define CONFIG_SPL +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LDSCRIPT "arch/$(ARCH)/cpu/u-boot.lds" +#define CONFIG_SPL_MAX_SIZE 2048 +#define CONFIG_SPL_NAND_SUPPORT + +#define CONFIG_SPL_TEXT_BASE 0x810c0000 +#define CONFIG_SYS_TEXT_BASE 0x81200000
#ifndef MACH_TYPE_TX25 #define MACH_TYPE_TX25 2177 @@ -40,16 +47,16 @@
#define CONFIG_MACH_TYPE MACH_TYPE_TX25
-#ifdef CONFIG_NAND_SPL +#ifdef CONFIG_SPL_BUILD /* Start copying real U-boot from the second page */ -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x800 +#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO #define CONFIG_SYS_NAND_U_BOOT_SIZE 0x30000
-#define CONFIG_SYS_NAND_U_BOOT_DST (0x81200000) +#define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST
#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_SPARE_SIZE 64 +#define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_SIZE (128 * 1024 * 1024) @@ -173,7 +180,6 @@
/* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - /* Fix this */ \ - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (IMX_RAM_BASE + IMX_RAM_SIZE)
#endif /* __CONFIG_H */ diff --git a/nand_spl/board/freescale/mx31pdk/Makefile b/nand_spl/board/freescale/mx31pdk/Makefile deleted file mode 100644 index fd0dfc1..0000000 --- a/nand_spl/board/freescale/mx31pdk/Makefile +++ /dev/null @@ -1,68 +0,0 @@ -CONFIG_NAND_SPL = y -PAD_TO := 2048 - -include $(TOPDIR)/config.mk - -nandobj := $(OBJTREE)/nand_spl/ - -LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds -LSTSCRIPT= $(nandobj)/board/$(BOARDDIR)/u-boot.lst -LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ - $(LDFLAGS_FINAL) -AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL -CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL - -SOBJS = start.o crt0.o lowlevel_init.o -COBJS = nand_boot_fsl_nfc.o - -SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c -SRCS += $(SRCTREE)/arch/arm/cpu/arm1136/start.S -SRCS += $(SRCTREE)/arch/arm/lib/crt0.S -SRCS += $(SRCTREE)/board/freescale/mx31pdk/lowlevel_init.S -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -__OBJS := $(SOBJS) $(COBJS) -LNDIR := $(nandobj)board/$(BOARDDIR) - -ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin - -all: $(obj).depend $(ALL) - -$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ - -$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ - -$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds - cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ - -Map $(nandobj)u-boot-spl.map \ - -o $@ - -# The following line expands into whole rule which generates $(LSTSCRIPT), -# the file containing u-boots LG-array linker section. This is included into -# $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. -$(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) -$(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ - -ansi -D__ASSEMBLY__ -P - <$< >$@ - -######################################################################### - -$(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm1136/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/arch/arm/lib/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/board/freescale/mx31pdk/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/nand_spl/%.c - $(CC) $(CFLAGS) -c -o $@ $< - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/nand_spl/board/freescale/mx31pdk/u-boot.lds b/nand_spl/board/freescale/mx31pdk/u-boot.lds deleted file mode 100644 index a26110f..0000000 --- a/nand_spl/board/freescale/mx31pdk/u-boot.lds +++ /dev/null @@ -1,87 +0,0 @@ -/* - * (C) Copyright 2009 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - start.o (.text) - lowlevel_init.o (.text) - nand_boot_fsl_nfc.o (.text) - *(.text) - . = 2K; - } - - . = ALIGN(4); - .rodata : { *(.rodata) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = ALIGN(4); - .u_boot_list : { - #include <u-boot.lst> - } - - . = ALIGN(4); - - __image_copy_end = .; - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.bss*) } - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynsym*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.hash*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/nand_spl/board/karo/tx25/Makefile b/nand_spl/board/karo/tx25/Makefile deleted file mode 100644 index 82489d2..0000000 --- a/nand_spl/board/karo/tx25/Makefile +++ /dev/null @@ -1,89 +0,0 @@ -# -# (C) Copyright 2009 DENX Software Engineering -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundatio; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -CONFIG_NAND_SPL = y - -include $(TOPDIR)/config.mk -include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk - -nandobj := $(OBJTREE)/nand_spl/ - -LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds -LSTSCRIPT= $(nandobj)/board/$(BOARDDIR)/u-boot.lst -LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ - $(LDFLAGS_FINAL) -AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL -CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL - -SOBJS = start.o crt0.o lowlevel_init.o -COBJS = nand_boot_fsl_nfc.o - -SRCS := $(SRCTREE)/nand_spl/nand_boot_fsl_nfc.c -SRCS += $(SRCTREE)/arch/arm/cpu/arm926ejs/start.S -SRCS += $(SRCTREE)/arch/arm/lib/crt0.S -SRCS += $(SRCTREE)/board/karo/tx25/lowlevel_init.S -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -__OBJS := $(SOBJS) $(COBJS) -LNDIR := $(nandobj)board/$(BOARDDIR) - -ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin - -all: $(obj).depend $(ALL) - -$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ - -$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ - -$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds - cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ - -Map $(nandobj)u-boot-spl.map \ - -o $@ - -# The following line expands into whole rule which generates $(LSTSCRIPT), -# the file containing u-boots LG-array linker section. This is included into -# $(LDSCRIPT). The function make_u_boot_list is defined in helper.mk file. -$(eval $(call make_u_boot_list, $(LSTSCRIPT), $(OBJS))) -$(nandobj)u-boot.lds: $(LDSCRIPT) $(LSTSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(nandobj)/board/$(BOARDDIR) \ - -ansi -D__ASSEMBLY__ -P - <$< >$@ - -######################################################################### - -$(obj)%.o: $(SRCTREE)/arch/arm/cpu/arm926ejs/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/arch/arm/lib/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/board/karo/tx25/%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(SRCTREE)/nand_spl/%.c - $(CC) $(CFLAGS) -c -o $@ $< - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/nand_spl/board/karo/tx25/config.mk b/nand_spl/board/karo/tx25/config.mk deleted file mode 100644 index 68afbf1..0000000 --- a/nand_spl/board/karo/tx25/config.mk +++ /dev/null @@ -1 +0,0 @@ -PAD_TO := 2048 diff --git a/nand_spl/board/karo/tx25/u-boot.lds b/nand_spl/board/karo/tx25/u-boot.lds deleted file mode 100644 index 95ea8ac..0000000 --- a/nand_spl/board/karo/tx25/u-boot.lds +++ /dev/null @@ -1,87 +0,0 @@ -/* - * (C) Copyright 2009 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - start.o (.text) - lowlevel_init.o (.text) - nand_boot_fsl_nfc.o (.text) - *(.text) - . = 2K; - } - - . = ALIGN(4); - .rodata : { *(.rodata) } - - . = ALIGN(4); - .data : { - *(.data) - } - - . = ALIGN(4); - - . = ALIGN(4); - .u_boot_list : { - #include <u-boot.lst> - } - - . = ALIGN(4); - - __image_copy_end = .; - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.bss*) } - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynsym*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.hash*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -}
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: None Changes in v7: None Changes in v6: - New patch.
arch/arm/cpu/arm926ejs/start.S | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 9121af2..fd2803e 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -120,15 +120,11 @@ _fiq:
.globl _TEXT_BASE _TEXT_BASE: -#ifdef CONFIG_NAND_SPL /* deprecated, use instead CONFIG_SPL_BUILD */ - .word CONFIG_SYS_TEXT_BASE -#else #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) .word CONFIG_SPL_TEXT_BASE #else .word CONFIG_SYS_TEXT_BASE #endif -#endif
/* * These are defined in the board-specific linker script. @@ -152,12 +148,6 @@ _bss_end_ofs: _end_ofs: .word _end - _start
-#ifdef CONFIG_NAND_U_BOOT -.globl _end -_end: - .word __bss_end__ -#endif - #ifdef CONFIG_USE_IRQ /* IRQ stack memory (calculated at run-time) */ .globl IRQ_STACK_START
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of ARM's relocate_code() useless since it moved the code handling them to crt0.S. So, drop these parameters.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - Update the function prototype in start.S comments.
arch/arm/cpu/arm1136/start.S | 6 ++---- arch/arm/cpu/arm1176/start.S | 6 ++---- arch/arm/cpu/arm720t/start.S | 6 ++---- arch/arm/cpu/arm920t/start.S | 6 ++---- arch/arm/cpu/arm925t/start.S | 6 ++---- arch/arm/cpu/arm926ejs/start.S | 6 ++---- arch/arm/cpu/arm946es/start.S | 6 ++---- arch/arm/cpu/arm_intcm/start.S | 6 ++---- arch/arm/cpu/armv7/start.S | 6 ++---- arch/arm/cpu/ixp/start.S | 6 ++---- arch/arm/cpu/pxa/start.S | 6 ++---- arch/arm/cpu/s3c44b0/start.S | 6 ++---- arch/arm/cpu/sa1100/start.S | 6 ++---- arch/arm/lib/crt0.S | 8 +++----- board/freescale/mx31pdk/mx31pdk.c | 2 +- board/karo/tx25/tx25.c | 2 +- board/samsung/smdk6400/smdk6400_nand_spl.c | 3 +-- include/common.h | 8 ++++---- 18 files changed, 36 insertions(+), 65 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index b3e3e37..eb11b69 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -174,15 +174,13 @@ next: /*------------------------------------------------------------------------------*/
/* - * void relocate_code (addr_sp, gd, addr_moni) + * void relocate_code(addr_moni) * * This function relocates the monitor code. */ .globl relocate_code relocate_code: - mov r4, r0 /* save addr_sp */ - mov r5, r1 /* save addr of gd */ - mov r6, r2 /* save addr of destination */ + mov r6, r0 /* save addr of destination */
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 4f98f8b..97d347c 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -241,15 +241,13 @@ skip_tcmdisable: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index 850fce0..d455793 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -156,15 +156,13 @@ reset: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index e2958d3..a6cb33f 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -195,15 +195,13 @@ copyex: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 4b64122..78d5ab4 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -185,15 +185,13 @@ poll1: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index fd2803e..863eb8e 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -191,15 +191,13 @@ reset: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 48b7b62..cc8158d 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -160,15 +160,13 @@ reset: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index 5016c3c..8965d5f 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -156,15 +156,13 @@ reset: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index cc68347..d1b7d33 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -165,14 +165,12 @@ reset:
#ifndef CONFIG_SPL_BUILD /* - * void relocate_code (addr_sp, gd, addr_moni) + * void relocate_code(addr_moni) * * This function relocates the monitor code. */ ENTRY(relocate_code) - mov r4, r0 /* save addr_sp */ - mov r5, r1 /* save addr of gd */ - mov r6, r2 /* save addr of destination */ + mov r6, r0 /* save addr of destination */
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index f6bec3b..d986c31 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -258,15 +258,13 @@ reset: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 8c64411..3523331 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -173,15 +173,13 @@ reset: /*------------------------------------------------------------------------------*/ #ifndef CONFIG_SPL_BUILD /* - * void relocate_code (addr_sp, gd, addr_moni) + * void relocate_code(addr_moni) * * This function relocates the monitor code. */ .globl relocate_code relocate_code: - mov r4, r0 /* save addr_sp */ - mov r5, r1 /* save addr of gd */ - mov r6, r2 /* save addr of destination */ + mov r6, r0 /* save addr of destination */
/* Disable the Dcache RAM lock for stack now */ #ifdef CONFIG_CPU_PXA25X diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 0924925..62093ed 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -141,15 +141,13 @@ reset: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index fe6c429..207c190 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -145,15 +145,13 @@ reset: /*------------------------------------------------------------------------------*/
adr r0, _start subs r9, r6, r0 /* r9 <- relocation offset */ diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 56b433e..7950469 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -96,8 +96,8 @@ ENTRY(_main)
/* * Set up intermediate environment (new sp and gd) and call - * relocate_code(addr_sp, gd, addr_moni). Trick here is that - * we'll return 'here' but relocated. + * relocate_code(addr_moni). Trick here is that we'll return + * 'here' but relocated. */
ldr sp, [r8, #GD_START_ADDR_SP] /* r8 = gd->start_addr_sp */ @@ -108,9 +108,7 @@ ENTRY(_main) adr lr, here ldr r0, [r8, #GD_RELOC_OFF] /* lr = gd->start_addr_sp */ add lr, lr, r0 - ldr r0, [r8, #GD_START_ADDR_SP] /* r0 = gd->start_addr_sp */ - mov r1, r8 /* r1 = gd */ - ldr r2, [r8, #GD_RELOCADDR] /* r2 = gd->relocaddr */ + ldr r0, [r8, #GD_RELOCADDR] /* r0 = gd->relocaddr */ b relocate_code here:
diff --git a/board/freescale/mx31pdk/mx31pdk.c b/board/freescale/mx31pdk/mx31pdk.c index 3d0d419..49158bd 100644 --- a/board/freescale/mx31pdk/mx31pdk.c +++ b/board/freescale/mx31pdk/mx31pdk.c @@ -39,7 +39,7 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_SPL_BUILD void board_init_f(ulong bootflag) { - relocate_code(0, NULL, CONFIG_SPL_TEXT_BASE); + relocate_code(CONFIG_SPL_TEXT_BASE); asm volatile("ldr pc, =nand_boot"); } #endif diff --git a/board/karo/tx25/tx25.c b/board/karo/tx25/tx25.c index 69ee590..85719a0 100644 --- a/board/karo/tx25/tx25.c +++ b/board/karo/tx25/tx25.c @@ -36,7 +36,7 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_SPL_BUILD void board_init_f(ulong bootflag) { - relocate_code(0, NULL, CONFIG_SPL_TEXT_BASE); + relocate_code(CONFIG_SPL_TEXT_BASE); asm volatile("ldr pc, =nand_boot"); } #endif diff --git a/board/samsung/smdk6400/smdk6400_nand_spl.c b/board/samsung/smdk6400/smdk6400_nand_spl.c index a023284..26a6146 100644 --- a/board/samsung/smdk6400/smdk6400_nand_spl.c +++ b/board/samsung/smdk6400/smdk6400_nand_spl.c @@ -32,6 +32,5 @@
void board_init_f(unsigned long bootflag) { - relocate_code(CONFIG_SYS_TEXT_BASE - TOTAL_MALLOC_LEN, NULL, - CONFIG_SYS_TEXT_BASE); + relocate_code(CONFIG_SYS_TEXT_BASE); } diff --git a/include/common.h b/include/common.h index 691e279..3d643a6 100644 --- a/include/common.h +++ b/include/common.h @@ -515,11 +515,11 @@ int dcache_status (void); void dcache_enable (void); void dcache_disable(void); void mmu_disable(void); -void relocate_code(ulong, gd_t *, ulong) -#if !defined(CONFIG_ARM) -__attribute__ ((noreturn)) +#if defined(CONFIG_ARM) +void relocate_code(ulong); +#else +void relocate_code(ulong, gd_t *, ulong) __attribute__ ((noreturn)); #endif -; ulong get_endaddr (void); void trap_init (ulong); #if defined (CONFIG_4xx) || \
make never uses the SHELL variable from the environment. Instead, it uses /bin/sh, or the value assigned to the SHELL variable by the Makefile. This makes the export of the SHELL variable useless for sub-makes (but still useful for the environment of recipes). However, we want all makes to use the same shell.
This patch fixes this issue by moving the SHELL variable setup and export to the top config.mk, so that all Makefile-s including it use the same shell.
Since BASH is used by default, this makes it possible to use things like 'echo -e ...' in sub-makes, which would otherwise fail e.g. with /bin/sh symlinked to /bin/dash on Ubuntu.
Makefile | 7 +------ config.mk | 7 +++++++ 2 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/Makefile b/Makefile index 5bcc914..b1f0ff0 100644 --- a/Makefile +++ b/Makefile @@ -46,12 +46,7 @@ HOSTARCH := $(shell uname -m | \ HOSTOS := $(shell uname -s | tr '[:upper:]' '[:lower:]' | \ sed -e 's/(cygwin).*/cygwin/')
-# Set shell to bash if possible, otherwise fall back to sh -SHELL := $(shell if [ -x "$$BASH" ]; then echo $$BASH; \ - else if [ -x /bin/bash ]; then echo /bin/bash; \ - else echo sh; fi; fi) - -export HOSTARCH HOSTOS SHELL +export HOSTARCH HOSTOS
# Deal with colliding definitions from tcsh etc. VENDOR= diff --git a/config.mk b/config.mk index b7cd481..21c0844 100644 --- a/config.mk +++ b/config.mk @@ -23,6 +23,13 @@
+# Set shell to bash if possible, otherwise fall back to sh +SHELL := $(shell if [ -x "$$BASH" ]; then echo $$BASH; \ + else if [ -x /bin/bash ]; then echo /bin/bash; \ + else echo sh; fi; fi) + +export SHELL + include $(TOPDIR)/helper.mk
ifeq ($(CURDIR),$(SRCTREE))
Signed-off-by: Beno??t Th??baudeau benoit.thebaudeau@advansee.com
Reviewed-by: Tom Rini trini@ti.com
.gitignore | 1 + 1 file changed, 1 insertion(+)
diff --git a/.gitignore b/.gitignore index e40eb7b..a803651 100644 --- a/.gitignore +++ b/.gitignore @@ -25,6 +25,7 @@ #
/MLO +/SPL /System.map /u-boot /u-boot.hex
This image combines the SPL with the i.MX header and U-Boot. This is a convenient way of having a single image to program on some boot devices.
The i.MX header has to be added to the SPL before appending U-Boot, so that the boot ROM loads only the SPL.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - Use CONFIG_SPL_PAD_TO instead of CONFIG_SPL_MAX_SIZE for padding, which allows to pad the SPL after adding the i.MX header, which may save time when the boot ROM loads the SPL. - Add /u-boot-with-spl.imx to .gitignore.
Changes in v7: - New patch.
.gitignore | 1 + Makefile | 5 +++++ arch/arm/imx-common/Makefile | 6 ++++++ 3 files changed, 12 insertions(+)
diff --git a/.gitignore b/.gitignore index a803651..1d07fec 100644 --- a/.gitignore +++ b/.gitignore @@ -30,6 +30,7 @@ /u-boot /u-boot.hex /u-boot.imx +/u-boot-with-spl.imx /u-boot.map /u-boot.srec /u-boot.ldr diff --git a/Makefile b/Makefile index b1f0ff0..38f2ca5 100644 --- a/Makefile +++ b/Makefile @@ -484,6 +484,10 @@ $(obj)u-boot-with-spl.bin: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin cat $(obj)spl/u-boot-spl-pad.bin $(obj)u-boot.bin > $@ rm $(obj)spl/u-boot-spl-pad.bin
+$(obj)u-boot-with-spl.imx: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin + $(MAKE) -C $(SRCTREE)/arch/arm/imx-common \ + $(OBJTREE)/u-boot-with-spl.imx + $(obj)u-boot.ubl: $(obj)u-boot-with-spl.bin $(obj)tools/mkimage -n $(UBL_CONFIG) -T ublimage \ -e $(CONFIG_SYS_TEXT_BASE) -d $< $(obj)u-boot.ubl @@ -855,6 +859,7 @@ clobber: tidy @rm -f $(obj)u-boot.kwb @rm -f $(obj)u-boot.pbl @rm -f $(obj)u-boot.imx + @rm -f $(obj)u-boot-with-spl.imx @rm -f $(obj)u-boot.ubl @rm -f $(obj)u-boot.ais @rm -f $(obj)u-boot.dtb diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 6309fcd..2ce182d 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -54,6 +54,12 @@ $(OBJTREE)/SPL: $(OBJTREE)/spl/u-boot-spl.bin $(OBJTREE)/$(patsubst "%",%,$(CONF $(OBJTREE)/tools/mkimage -n $(filter-out %.bin,$^) -T imximage \ -e $(CONFIG_SPL_TEXT_BASE) -d $< $@
+$(OBJTREE)/u-boot-with-spl.imx: $(OBJTREE)/SPL $(OBJTREE)/u-boot.bin + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(CONFIG_SPL_PAD_TO) \ + -I binary -O binary $< $(OBJTREE)/spl/u-boot-spl-pad.imx + cat $(OBJTREE)/spl/u-boot-spl-pad.imx $(OBJTREE)/u-boot.bin > $@ + rm $(OBJTREE)/spl/u-boot-spl-pad.imx +
This image combines the SPL with the i.MX header, the FCB and U-Boot.
For i.MX25/35/51, the FCB is ignored by the boot ROM, so this image is just useful because it can be programmed on a NAND Flash page boundary.
For i.MX53, the FCB is required by the boot ROM.
This does not support i.MX6 so far because its FCB is more complicated.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - Change the dummy 1024-byte header into a true FCB in order to add support for i.MX53. - Use CONFIG_SPL_PAD_TO instead of CONFIG_SPL_MAX_SIZE for padding, which allows to pad the SPL after adding the i.MX header and the FCB, which may save time when the boot ROM loads the SPL. - Add /u-boot-with-nand-spl.imx to .gitignore.
.gitignore | 1 + Makefile | 5 +++++ arch/arm/imx-common/Makefile | 11 +++++++++++ 3 files changed, 17 insertions(+)
diff --git a/.gitignore b/.gitignore index 1d07fec..c991631 100644 --- a/.gitignore +++ b/.gitignore @@ -31,6 +31,7 @@ /u-boot.hex /u-boot.imx /u-boot-with-spl.imx +/u-boot-with-nand-spl.imx /u-boot.map /u-boot.srec /u-boot.ldr diff --git a/Makefile b/Makefile index 38f2ca5..0069c86 100644 --- a/Makefile +++ b/Makefile @@ -488,6 +488,10 @@ $(obj)u-boot-with-spl.imx: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin $(MAKE) -C $(SRCTREE)/arch/arm/imx-common \ $(OBJTREE)/u-boot-with-spl.imx
+$(obj)u-boot-with-nand-spl.imx: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin + $(MAKE) -C $(SRCTREE)/arch/arm/imx-common \ + $(OBJTREE)/u-boot-with-nand-spl.imx + $(obj)u-boot.ubl: $(obj)u-boot-with-spl.bin $(obj)tools/mkimage -n $(UBL_CONFIG) -T ublimage \ -e $(CONFIG_SYS_TEXT_BASE) -d $< $(obj)u-boot.ubl @@ -860,6 +864,7 @@ clobber: tidy @rm -f $(obj)u-boot.pbl @rm -f $(obj)u-boot.imx @rm -f $(obj)u-boot-with-spl.imx + @rm -f $(obj)u-boot-with-nand-spl.imx @rm -f $(obj)u-boot.ubl @rm -f $(obj)u-boot.ais @rm -f $(obj)u-boot.dtb diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 2ce182d..d54dbee 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -60,6 +60,17 @@ $(OBJTREE)/u-boot-with-spl.imx: $(OBJTREE)/SPL $(OBJTREE)/u-boot.bin cat $(OBJTREE)/spl/u-boot-spl-pad.imx $(OBJTREE)/u-boot.bin > $@ rm $(OBJTREE)/spl/u-boot-spl-pad.imx
+$(OBJTREE)/u-boot-with-nand-spl.imx: $(OBJTREE)/SPL $(OBJTREE)/u-boot.bin + (echo -ne '\x00\x00\x00\x00\x46\x43\x42\x20\x01' && \ + dd bs=1015 count=1 if=/dev/zero 2>/dev/null) | \ + cat - $< > $(OBJTREE)/spl/u-boot-nand-spl.imx + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(CONFIG_SPL_PAD_TO) \ + -I binary -O binary $(OBJTREE)/spl/u-boot-nand-spl.imx \ + $(OBJTREE)/spl/u-boot-nand-spl-pad.imx + rm $(OBJTREE)/spl/u-boot-nand-spl.imx + cat $(OBJTREE)/spl/u-boot-nand-spl-pad.imx $(OBJTREE)/u-boot.bin > $@ + rm $(OBJTREE)/spl/u-boot-nand-spl-pad.imx +
The migration of boards from Makefile to boards.cfg was due for v2012.03, but smdk6400 did not follow, and it does not build, so move it to scrapyard. It will still be possible to restore it from the Git history before fixing it.
MAINTAINERS | 4 - Makefile | 17 -- arch/arm/include/asm/mach-types.h | 13 -- board/samsung/smdk6400/.gitignore | 5 - board/samsung/smdk6400/Makefile | 48 ----- board/samsung/smdk6400/config.mk | 30 --- board/samsung/smdk6400/lowlevel_init.S | 323 ---------------------------- board/samsung/smdk6400/smdk6400.c | 134 ------------ board/samsung/smdk6400/smdk6400_nand_spl.c | 36 ---- board/samsung/smdk6400/u-boot-nand.lds | 90 -------- doc/README.scrapyard | 1 + include/configs/smdk6400.h | 296 ------------------------- nand_spl/board/samsung/smdk6400/Makefile | 117 ---------- nand_spl/board/samsung/smdk6400/config.mk | 40 ---- nand_spl/board/samsung/smdk6400/u-boot.lds | 82 ------- 15 files changed, 1 insertion(+), 1235 deletions(-) delete mode 100644 board/samsung/smdk6400/.gitignore delete mode 100644 board/samsung/smdk6400/Makefile delete mode 100644 board/samsung/smdk6400/config.mk delete mode 100644 board/samsung/smdk6400/lowlevel_init.S delete mode 100644 board/samsung/smdk6400/smdk6400.c delete mode 100644 board/samsung/smdk6400/smdk6400_nand_spl.c delete mode 100644 board/samsung/smdk6400/u-boot-nand.lds delete mode 100644 include/configs/smdk6400.h delete mode 100644 nand_spl/board/samsung/smdk6400/Makefile delete mode 100644 nand_spl/board/samsung/smdk6400/config.mk delete mode 100644 nand_spl/board/samsung/smdk6400/u-boot.lds
diff --git a/MAINTAINERS b/MAINTAINERS index 175bbe2..b7b3f0f 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1020,10 +1020,6 @@ Vladimir Zapolskiy vz@mleia.com
devkit3250 lpc32xx
-Zhong Hongbo bocui107@gmail.com - - SMDK6400 ARM1176 (S3C6400 SoC) - Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Tetsuyuki Kobayashi koba@kmckk.co.jp
diff --git a/Makefile b/Makefile index 0069c86..f09021b 100644 --- a/Makefile +++ b/Makefile @@ -788,23 +788,6 @@ lcname = $(shell echo $(1) | sed -e 's/(.*)_config/\L\1/') ucname = $(shell echo $(1) | sed -e 's/(.*)_config/\U\1/')
######################################################################### -## ARM1176 Systems -######################################################################### -smdk6400_noUSB_config \ -smdk6400_config : unconfig - @mkdir -p $(obj)include $(obj)board/samsung/smdk6400 - @mkdir -p $(obj)nand_spl/board/samsung/smdk6400 - @echo "#define CONFIG_NAND_U_BOOT" > $(obj)include/config.h - @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk - @if [ -z "$(findstring smdk6400_noUSB_config,$@)" ]; then \ - echo "RAM_TEXT = 0x57e00000" >> $(obj)board/samsung/smdk6400/config.tmp;\ - else \ - echo "RAM_TEXT = 0xc7e00000" >> $(obj)board/samsung/smdk6400/config.tmp;\ - fi - @$(MKCONFIG) smdk6400 arm arm1176 smdk6400 samsung s3c64xx - @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk - -######################################################################### #########################################################################
clean: diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index a676b6d..440b041 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -223,7 +223,6 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_MIOA701 1257 #define MACH_TYPE_ARMADILLO5X0 1260 #define MACH_TYPE_CC9P9360JS 1264 -#define MACH_TYPE_SMDK6400 1270 #define MACH_TYPE_NOKIA_N800 1271 #define MACH_TYPE_EP80219 1281 #define MACH_TYPE_GORAMO_MLR 1292 @@ -3640,18 +3639,6 @@ extern unsigned int __machine_arch_type; # define machine_is_cc9p9360js() (0) #endif
-#ifdef CONFIG_MACH_SMDK6400 -# ifdef machine_arch_type -# undef machine_arch_type -# define machine_arch_type __machine_arch_type -# else -# define machine_arch_type MACH_TYPE_SMDK6400 -# endif -# define machine_is_smdk6400() (machine_arch_type == MACH_TYPE_SMDK6400) -#else -# define machine_is_smdk6400() (0) -#endif - #ifdef CONFIG_MACH_NOKIA_N800 # ifdef machine_arch_type # undef machine_arch_type diff --git a/board/samsung/smdk6400/.gitignore b/board/samsung/smdk6400/.gitignore deleted file mode 100644 index 25ab492..0000000 --- a/board/samsung/smdk6400/.gitignore +++ /dev/null @@ -1,5 +0,0 @@ -# -# Generated files -# - -/config.tmp diff --git a/board/samsung/smdk6400/Makefile b/board/samsung/smdk6400/Makefile deleted file mode 100644 index 0d3e63b..0000000 --- a/board/samsung/smdk6400/Makefile +++ /dev/null @@ -1,48 +0,0 @@ -# -# (C) Copyright 2000, 2001, 2002 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# (C) Copyright 2008 -# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := smdk6400.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(SOBJS) $(OBJS) - $(call cmd_link_o_target, $(SOBJS) $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/samsung/smdk6400/config.mk b/board/samsung/smdk6400/config.mk deleted file mode 100644 index 6f04c2f..0000000 --- a/board/samsung/smdk6400/config.mk +++ /dev/null @@ -1,30 +0,0 @@ -# -# (C) Copyright 2002 -# Gary Jennejohn, DENX Software Engineering, garyj@denx.de -# David Mueller, ELSOFT AG, d.mueller@elsoft.ch -# -# (C) Copyright 2008 -# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de -# -# SAMSUNG SMDK6400 board with mDirac3 (ARM1176) cpu -# -# see http://www.samsung.com/ for more information on SAMSUNG - -# On SMDK6400 we use the 64 MB SDRAM bank at -# -# 0x50000000 to 0x58000000 -# -# Linux-Kernel is expected to be at 0x50008000, entry 0x50008000 -# -# we load ourselves to 0x57e00000 without MMU -# with MMU, load address is changed to 0xc7e00000 -# -# download area is 0x5000c000 - -sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp - -ifndef CONFIG_NAND_SPL -CONFIG_SYS_TEXT_BASE = $(RAM_TEXT) -else -CONFIG_SYS_TEXT_BASE = 0 -endif diff --git a/board/samsung/smdk6400/lowlevel_init.S b/board/samsung/smdk6400/lowlevel_init.S deleted file mode 100644 index f7ce176..0000000 --- a/board/samsung/smdk6400/lowlevel_init.S +++ /dev/null @@ -1,323 +0,0 @@ -/* - * Memory Setup stuff - taken from blob memsetup.S - * - * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and - * Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl) - * - * Modified for the Samsung SMDK2410 by - * (C) Copyright 2002 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - - -#include <config.h> -#include <version.h> - -#include <asm/arch/s3c6400.h> - -#ifdef CONFIG_SERIAL1 -#define ELFIN_UART_CONSOLE_BASE (ELFIN_UART_BASE + ELFIN_UART0_OFFSET) -#elif defined(CONFIG_SERIAL2) -#define ELFIN_UART_CONSOLE_BASE (ELFIN_UART_BASE + ELFIN_UART1_OFFSET) -#else -#define ELFIN_UART_CONSOLE_BASE (ELFIN_UART_BASE + ELFIN_UART2_OFFSET) -#endif - -_TEXT_BASE: - .word CONFIG_SYS_TEXT_BASE - - .globl lowlevel_init -lowlevel_init: - mov r12, lr - - /* LED on only #8 */ - ldr r0, =ELFIN_GPIO_BASE - ldr r1, =0x55540000 - str r1, [r0, #GPNCON_OFFSET] - - ldr r1, =0x55555555 - str r1, [r0, #GPNPUD_OFFSET] - - ldr r1, =0xf000 - str r1, [r0, #GPNDAT_OFFSET] - - /* Disable Watchdog */ - ldr r0, =0x7e000000 @0x7e004000 - orr r0, r0, #0x4000 - mov r1, #0 - str r1, [r0] - - /* External interrupt pending clear */ - ldr r0, =(ELFIN_GPIO_BASE+EINTPEND_OFFSET) /*EINTPEND*/ - ldr r1, [r0] - str r1, [r0] - - ldr r0, =ELFIN_VIC0_BASE_ADDR @0x71200000 - ldr r1, =ELFIN_VIC1_BASE_ADDR @0x71300000 - - /* Disable all interrupts (VIC0 and VIC1) */ - mvn r3, #0x0 - str r3, [r0, #oINTMSK] - str r3, [r1, #oINTMSK] - - /* Set all interrupts as IRQ */ - mov r3, #0x0 - str r3, [r0, #oINTMOD] - str r3, [r1, #oINTMOD] - - /* Pending Interrupt Clear */ - mov r3, #0x0 - str r3, [r0, #oVECTADDR] - str r3, [r1, #oVECTADDR] - - /* init system clock */ - bl system_clock_init - -#ifndef CONFIG_NAND_SPL - /* for UART */ - bl uart_asm_init -#endif - -#ifdef CONFIG_BOOT_NAND - /* simple init for NAND */ - bl nand_asm_init -#endif - - /* Memory subsystem address 0x7e00f120 */ - ldr r0, =ELFIN_MEM_SYS_CFG - - /* Xm0CSn2 = NFCON CS0, Xm0CSn3 = NFCON CS1 */ - mov r1, #S3C64XX_MEM_SYS_CFG_NAND - str r1, [r0] - - bl mem_ctrl_asm_init - -/* Wakeup support. Don't know if it's going to be used, untested. */ - ldr r0, =(ELFIN_CLOCK_POWER_BASE + RST_STAT_OFFSET) - ldr r1, [r0] - bic r1, r1, #0xfffffff7 - cmp r1, #0x8 - beq wakeup_reset - -1: - mov lr, r12 - mov pc, lr - -wakeup_reset: - - /* Clear wakeup status register */ - ldr r0, =(ELFIN_CLOCK_POWER_BASE + WAKEUP_STAT_OFFSET) - ldr r1, [r0] - str r1, [r0] - - /* LED test */ - ldr r0, =ELFIN_GPIO_BASE - ldr r1, =0x3000 - str r1, [r0, #GPNDAT_OFFSET] - - /* Load return address and jump to kernel */ - ldr r0, =(ELFIN_CLOCK_POWER_BASE + INF_REG0_OFFSET) - /* r1 = physical address of s3c6400_cpu_resume function */ - ldr r1, [r0] - /* Jump to kernel (sleep-s3c6400.S) */ - mov pc, r1 - nop - nop -/* - * system_clock_init: Initialize core clock and bus clock. - * void system_clock_init(void) - */ -system_clock_init: - ldr r0, =ELFIN_CLOCK_POWER_BASE /* 0x7e00f000 */ - -#ifdef CONFIG_SYNC_MODE - ldr r1, [r0, #OTHERS_OFFSET] - mov r2, #0x40 - orr r1, r1, r2 - str r1, [r0, #OTHERS_OFFSET] - - nop - nop - nop - nop - nop - - ldr r2, =0x80 - orr r1, r1, r2 - str r1, [r0, #OTHERS_OFFSET] - -check_syncack: - ldr r1, [r0, #OTHERS_OFFSET] - ldr r2, =0xf00 - and r1, r1, r2 - cmp r1, #0xf00 - bne check_syncack -#else /* ASYNC Mode */ - nop - nop - nop - nop - nop - - /* - * This was unconditional in original Samsung sources, but it doesn't - * seem to make much sense on S3C6400. - */ -#ifndef CONFIG_S3C6400 - ldr r1, [r0, #OTHERS_OFFSET] - bic r1, r1, #0xC0 - orr r1, r1, #0x40 - str r1, [r0, #OTHERS_OFFSET] - -wait_for_async: - ldr r1, [r0, #OTHERS_OFFSET] - and r1, r1, #0xf00 - cmp r1, #0x0 - bne wait_for_async -#endif - - ldr r1, [r0, #OTHERS_OFFSET] - bic r1, r1, #0x40 - str r1, [r0, #OTHERS_OFFSET] -#endif - - mov r1, #0xff00 - orr r1, r1, #0xff - str r1, [r0, #APLL_LOCK_OFFSET] - str r1, [r0, #MPLL_LOCK_OFFSET] - - /* Set Clock Divider */ - ldr r1, [r0, #CLK_DIV0_OFFSET] - bic r1, r1, #0x30000 - bic r1, r1, #0xff00 - bic r1, r1, #0xff - ldr r2, =CLK_DIV_VAL - orr r1, r1, r2 - str r1, [r0, #CLK_DIV0_OFFSET] - - ldr r1, =APLL_VAL - str r1, [r0, #APLL_CON_OFFSET] - ldr r1, =MPLL_VAL - str r1, [r0, #MPLL_CON_OFFSET] - - /* FOUT of EPLL is 96MHz */ - ldr r1, =0x200203 - str r1, [r0, #EPLL_CON0_OFFSET] - ldr r1, =0x0 - str r1, [r0, #EPLL_CON1_OFFSET] - - /* APLL, MPLL, EPLL select to Fout */ - ldr r1, [r0, #CLK_SRC_OFFSET] - orr r1, r1, #0x7 - str r1, [r0, #CLK_SRC_OFFSET] - - /* wait at least 200us to stablize all clock */ - mov r1, #0x10000 -1: subs r1, r1, #1 - bne 1b - - /* Synchronization for VIC port */ -#if defined(CONFIG_SYNC_MODE) - ldr r1, [r0, #OTHERS_OFFSET] - orr r1, r1, #0x20 - str r1, [r0, #OTHERS_OFFSET] -#elif !defined(CONFIG_S3C6400) - /* According to 661558um_S3C6400X_rev10.pdf 0x20 is reserved */ - ldr r1, [r0, #OTHERS_OFFSET] - bic r1, r1, #0x20 - str r1, [r0, #OTHERS_OFFSET] -#endif - mov pc, lr - - -#ifndef CONFIG_NAND_SPL -/* - * uart_asm_init: Initialize UART's pins - */ -uart_asm_init: - /* set GPIO to enable UART */ - ldr r0, =ELFIN_GPIO_BASE - ldr r1, =0x220022 - str r1, [r0, #GPACON_OFFSET] - mov pc, lr -#endif - -#ifdef CONFIG_BOOT_NAND -/* - * NAND Interface init for SMDK6400 - */ -nand_asm_init: - ldr r0, =ELFIN_NAND_BASE - ldr r1, [r0, #NFCONF_OFFSET] - orr r1, r1, #0x70 - orr r1, r1, #0x7700 - str r1, [r0, #NFCONF_OFFSET] - - ldr r1, [r0, #NFCONT_OFFSET] - orr r1, r1, #0x07 - str r1, [r0, #NFCONT_OFFSET] - - mov pc, lr -#endif - -#ifdef CONFIG_ENABLE_MMU -/* - * MMU Table for SMDK6400 - */ - - /* form a first-level section entry */ -.macro FL_SECTION_ENTRY base,ap,d,c,b - .word (\base << 20) | (\ap << 10) | \ - (\d << 5) | (1<<4) | (\c << 3) | (\b << 2) | (1<<1) -.endm - -.section .mmudata, "a" - .align 14 - /* the following alignment creates the mmu table at address 0x4000. */ - .globl mmu_table -mmu_table: - .set __base, 0 - /* 1:1 mapping for debugging */ - .rept 0xA00 - FL_SECTION_ENTRY __base, 3, 0, 0, 0 - .set __base, __base + 1 - .endr - - /* access is not allowed. */ - .rept 0xC00 - 0xA00 - .word 0x00000000 - .endr - - /* 128MB for SDRAM 0xC0000000 -> 0x50000000 */ - .set __base, 0x500 - .rept 0xC80 - 0xC00 - FL_SECTION_ENTRY __base, 3, 0, 1, 1 - .set __base, __base + 1 - .endr - - /* access is not allowed. */ - .rept 0x1000 - 0xc80 - .word 0x00000000 - .endr -#endif diff --git a/board/samsung/smdk6400/smdk6400.c b/board/samsung/smdk6400/smdk6400.c deleted file mode 100644 index c40d1f9..0000000 --- a/board/samsung/smdk6400/smdk6400.c +++ /dev/null @@ -1,134 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <netdev.h> -#include <asm/arch/s3c6400.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* ------------------------------------------------------------------------- */ -#define CS8900_Tacs 0x0 /* 0clk address set-up */ -#define CS8900_Tcos 0x4 /* 4clk chip selection set-up */ -#define CS8900_Tacc 0xE /* 14clk access cycle */ -#define CS8900_Tcoh 0x1 /* 1clk chip selection hold */ -#define CS8900_Tah 0x4 /* 4clk address holding time */ -#define CS8900_Tacp 0x6 /* 6clk page mode access cycle */ -#define CS8900_PMC 0x0 /* normal(1data)page mode configuration */ - -static inline void delay(unsigned long loops) -{ - __asm__ volatile ("1:\n" "subs %0, %1, #1\n" - "bne 1b" - : "=r" (loops) : "0" (loops)); -} - -/* - * Miscellaneous platform dependent initialisations - */ - -static void cs8900_pre_init(void) -{ - SROM_BW_REG &= ~(0xf << 4); - SROM_BW_REG |= (1 << 7) | (1 << 6) | (1 << 4); - SROM_BC1_REG = ((CS8900_Tacs << 28) + (CS8900_Tcos << 24) + - (CS8900_Tacc << 16) + (CS8900_Tcoh << 12) + - (CS8900_Tah << 8) + (CS8900_Tacp << 4) + CS8900_PMC); -} - -int board_init(void) -{ - cs8900_pre_init(); - - /* NOR-flash in SROM0 */ - - /* Enable WAIT */ - SROM_BW_REG |= 4 | 8 | 1; - - gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; - - return 0; -} - -void dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; -} - -int dram_init(void) -{ - gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, - PHYS_SDRAM_1_SIZE); - - return 0; -} - -#ifdef CONFIG_DISPLAY_BOARDINFO -int checkboard(void) -{ - printf("Board: SMDK6400\n"); - return 0; -} -#endif - -#ifdef CONFIG_ENABLE_MMU -ulong virt_to_phy_smdk6400(ulong addr) -{ - if ((0xc0000000 <= addr) && (addr < 0xc8000000)) - return addr - 0xc0000000 + 0x50000000; - else - printf("do not support this address : %08lx\n", addr); - - return addr; -} -#endif - -ulong board_flash_get_legacy (ulong base, int banknum, flash_info_t *info) -{ - if (banknum == 0) { /* non-CFI boot flash */ - info->portwidth = FLASH_CFI_16BIT; - info->chipwidth = FLASH_CFI_BY16; - info->interface = FLASH_CFI_X16; - return 1; - } else - return 0; -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_CS8900 - rc = cs8900_initialize(0, CONFIG_CS8900_BASE); -#endif - return rc; -} -#endif diff --git a/board/samsung/smdk6400/smdk6400_nand_spl.c b/board/samsung/smdk6400/smdk6400_nand_spl.c deleted file mode 100644 index 26a6146..0000000 --- a/board/samsung/smdk6400/smdk6400_nand_spl.c +++ /dev/null @@ -1,36 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> - -void board_init_f(unsigned long bootflag) -{ - relocate_code(CONFIG_SYS_TEXT_BASE); -} diff --git a/board/samsung/smdk6400/u-boot-nand.lds b/board/samsung/smdk6400/u-boot-nand.lds deleted file mode 100644 index 2c3a60b..0000000 --- a/board/samsung/smdk6400/u-boot-nand.lds +++ /dev/null @@ -1,90 +0,0 @@ -/* - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - arch/arm/cpu/arm1176/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data) } - - . = ALIGN(4); - .got : { *(.got) } - - - . = align(4); - .u_boot_list : { - #include <u-boot.lst> - } - - . = ALIGN(4); - - __image_copy_end = .; - - . = align(4); - .mmudata : { *(.mmudata) } - - . = ALIGN(4); - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } - - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -} diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 2b868e6..b3a445f 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -11,6 +11,7 @@ easily if here is something they might want to dig for...
Board Arch CPU removed Commit last known maintainer/contact ============================================================================= +smdk6400 arm arm1176 - - Zhong Hongbo bocui107@gmail.com AMX860 powerpc mpc860 - - Wolfgang Denk wd@denx.de c2mon powerpc mpc855 - - Wolfgang Denk wd@denx.de ETX094 powerpc mpc850 - - Wolfgang Denk wd@denx.de diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h deleted file mode 100644 index d4dc8ef..0000000 --- a/include/configs/smdk6400.h +++ /dev/null @@ -1,296 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * Gary Jennejohn garyj@denx.de - * David Mueller d.mueller@elsoft.ch - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * Configuation settings for the SAMSUNG SMDK6400(mDirac-III) board. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_S3C6400 1 /* in a SAMSUNG S3C6400 SoC */ -#define CONFIG_S3C64XX 1 /* in a SAMSUNG S3C64XX Family */ -#define CONFIG_SMDK6400 1 /* on a SAMSUNG SMDK6400 Board */ - -#define CONFIG_PERIPORT_REMAP -#define CONFIG_PERIPORT_BASE 0x70000000 -#define CONFIG_PERIPORT_SIZE 0x13 - -#define CONFIG_SYS_IRAM_BASE 0x0c000000 /* Internal SRAM base address */ -#define CONFIG_SYS_IRAM_SIZE 0x2000 /* 8 KB of internal SRAM memory */ -#define CONFIG_SYS_IRAM_END (CONFIG_SYS_IRAM_BASE + CONFIG_SYS_IRAM_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_IRAM_END - GENERATED_GBL_DATA_SIZE) - -#define CONFIG_SYS_SDRAM_BASE 0x50000000 - -/* input clock of PLL: SMDK6400 has 12MHz input clock */ -#define CONFIG_SYS_CLK_FREQ 12000000 - -#if !defined(CONFIG_NAND_SPL) && (CONFIG_SYS_TEXT_BASE >= 0xc0000000) -#define CONFIG_ENABLE_MMU -#endif - -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_CMDLINE_TAG -#define CONFIG_INITRD_TAG - -/* - * Architecture magic and machine type - */ -#define CONFIG_MACH_TYPE 1270 - -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO - -/* - * Size of malloc() pool - */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024) - -/* - * Hardware drivers - */ -#define CONFIG_CS8900 /* we have a CS8900 on-board */ -#define CONFIG_CS8900_BASE 0x18800300 -#define CONFIG_CS8900_BUS16 /* follow the Linux driver */ - -/* - * select serial console configuration - */ -#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on SMDK6400 */ - -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ - -#define CONFIG_CMDLINE_EDITING - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE - -#define CONFIG_BAUDRATE 115200 - -/*********************************************************** - * Command definition - ***********************************************************/ -#include <config_cmd_default.h> - -#define CONFIG_CMD_CACHE -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_LOADB -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_NAND -#if defined(CONFIG_BOOT_ONENAND) -#define CONFIG_CMD_ONENAND -#endif -#define CONFIG_CMD_PING -#define CONFIG_CMD_ELF -#define CONFIG_CMD_FAT -#define CONFIG_CMD_EXT2 - -#define CONFIG_BOOTDELAY 3 - -#define CONFIG_ZERO_BOOTDELAY_CHECK - -#if (CONFIG_COMMANDS & CONFIG_CMD_KGDB) -#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ -#define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "SMDK6400 # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x7e00000) /* 126MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE /* default load address */ - -#define CONFIG_SYS_HZ 1000 - -/********************************** - Support Clock Settings - ********************************** - Setting SYNC ASYNC - ---------------------------------- - 667_133_66 X O - 533_133_66 O O - 400_133_66 X O - 400_100_50 O O - **********************************/ - -/*#define CONFIG_CLK_667_133_66*/ -#define CONFIG_CLK_533_133_66 -/* -#define CONFIG_CLK_400_100_50 -#define CONFIG_CLK_400_133_66 -#define CONFIG_SYNC_MODE -*/ - -/* SMDK6400 has 2 banks of DRAM, but we use only one in U-Boot */ -#define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB in Bank #1 */ - -#define CONFIG_SYS_FLASH_BASE 0x10000000 -#define CONFIG_SYS_MONITOR_BASE 0x00000000 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -/* AM29LV160B has 35 sectors, AM29LV800B - 19 */ -#define CONFIG_SYS_MAX_FLASH_SECT 40 - -#define CONFIG_AMD_LV800 -#define CONFIG_SYS_FLASH_CFI 1 /* Use CFI parameters (needed?) */ -/* Use drivers/cfi_flash.c, even though the flash is not CFI-compliant */ -#define CONFIG_FLASH_CFI_DRIVER 1 -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT -#define CONFIG_FLASH_CFI_LEGACY -#define CONFIG_SYS_FLASH_LEGACY_512Kx16 - -/* timeout values are in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (5 * CONFIG_SYS_HZ) /* Timeout for Flash Erase */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (5 * CONFIG_SYS_HZ) /* Timeout for Flash Write */ - -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -/* - * SMDK6400 board specific data - */ - -#define CONFIG_IDENT_STRING " for SMDK6400" - -/* base address for uboot */ -#define CONFIG_SYS_PHY_UBOOT_BASE (CONFIG_SYS_SDRAM_BASE + 0x07e00000) -/* total memory available to uboot */ -#define CONFIG_SYS_UBOOT_SIZE (1024 * 1024) - -/* Put environment copies after the end of U-Boot owned RAM */ -#define CONFIG_NAND_ENV_DST (CONFIG_SYS_UBOOT_BASE + CONFIG_SYS_UBOOT_SIZE) - -#ifdef CONFIG_ENABLE_MMU -#define CONFIG_SYS_MAPPED_RAM_BASE 0xc0000000 -#define CONFIG_BOOTCOMMAND "nand read 0xc0018000 0x60000 0x1c0000;" \ - "bootm 0xc0018000" -#else -#define CONFIG_SYS_MAPPED_RAM_BASE CONFIG_SYS_SDRAM_BASE -#define CONFIG_BOOTCOMMAND "nand read 0x50018000 0x60000 0x1c0000;" \ - "bootm 0x50018000" -#endif - -/* NAND U-Boot load and start address */ -#define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_MAPPED_RAM_BASE + 0x07e00000) - -#define CONFIG_ENV_OFFSET 0x0040000 - -/* NAND configuration */ -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BASE 0x70200010 -#define CONFIG_SYS_S3C_NAND_HWECC - -#define CONFIG_SYS_NAND_SKIP_BAD_DOT_I 1 /* ".i" read skips bad blocks */ -#define CONFIG_SYS_NAND_WP 1 -#define CONFIG_SYS_NAND_YAFFS_WRITE 1 /* support yaffs write */ -#define CONFIG_SYS_NAND_BBT_2NDPAGE 1 /* bad-block markers in 1st and 2nd pages */ - -#define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_PHY_UBOOT_BASE /* NUB load-addr */ -#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST /* NUB start-addr */ - -#define CONFIG_SYS_NAND_U_BOOT_OFFS (4 * 1024) /* Offset to RAM U-Boot image */ -#define CONFIG_SYS_NAND_U_BOOT_SIZE (252 * 1024) /* Size of RAM U-Boot image */ - -/* NAND chip page size */ -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -/* NAND chip block size */ -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) -/* NAND chip page per block count */ -#define CONFIG_SYS_NAND_PAGE_COUNT 64 -/* Location of the bad-block label */ -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 -/* Extra address cycle for > 128MiB */ -#define CONFIG_SYS_NAND_5_ADDR_CYCLE - -/* Size of the block protected by one OOB (Spare Area in Samsung terminology) */ -#define CONFIG_SYS_NAND_ECCSIZE CONFIG_SYS_NAND_PAGE_SIZE -/* Number of ECC bytes per OOB - S3C6400 calculates 4 bytes ECC in 1-bit mode */ -#define CONFIG_SYS_NAND_ECCBYTES 4 -/* Size of a single OOB region */ -#define CONFIG_SYS_NAND_OOBSIZE 64 -/* ECC byte positions */ -#define CONFIG_SYS_NAND_ECCPOS {40, 41, 42, 43, 44, 45, 46, 47, \ - 48, 49, 50, 51, 52, 53, 54, 55, \ - 56, 57, 58, 59, 60, 61, 62, 63} - -/* Boot configuration (define only one of next 3) */ -#define CONFIG_BOOT_NAND -/* None of these are currently implemented. Left from the original Samsung - * version for reference -#define CONFIG_BOOT_NOR -#define CONFIG_BOOT_MOVINAND -#define CONFIG_BOOT_ONENAND -*/ - -#define CONFIG_NAND -#define CONFIG_NAND_S3C64XX -/* Unimplemented or unsupported. See comment above. -#define CONFIG_ONENAND -#define CONFIG_MOVINAND -*/ - -/* Settings as above boot configuration */ -#define CONFIG_ENV_IS_IN_NAND -#define CONFIG_BOOTARGS "console=ttySAC,115200" - -#if !defined(CONFIG_ENABLE_MMU) -#define CONFIG_CMD_USB 1 -#define CONFIG_USB_S3C64XX -#define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x74300000 -#define CONFIG_SYS_USB_OHCI_SLOT_NAME "s3c6400" -#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3 -#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 - -#define CONFIG_USB_STORAGE 1 -#endif -#define CONFIG_DOS_PARTITION 1 - -#if defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_ENABLE_MMU) -# error "usb_ohci.c is currently broken with MMU enabled." -#endif - -#endif /* __CONFIG_H */ diff --git a/nand_spl/board/samsung/smdk6400/Makefile b/nand_spl/board/samsung/smdk6400/Makefile deleted file mode 100644 index c9e75ba..0000000 --- a/nand_spl/board/samsung/smdk6400/Makefile +++ /dev/null @@ -1,117 +0,0 @@ -# -# (C) Copyright 2006-2007 -# Stefan Roese, DENX Software Engineering, sr@denx.de. -# -# (C) Copyright 2008 -# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -CONFIG_NAND_SPL = y - -include $(TOPDIR)/config.mk -include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk - -nandobj := $(OBJTREE)/nand_spl/ - -LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds -LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ - $(LDFLAGS_FINAL) -gc-sections -AFLAGS += -DCONFIG_NAND_SPL -CFLAGS += -DCONFIG_NAND_SPL -ffunction-sections - -SOBJS = start.o cpu_init.o lowlevel_init.o -COBJS = nand_boot.o nand_ecc.o s3c64xx.o smdk6400_nand_spl.o nand_base.o - -SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -__OBJS := $(SOBJS) $(COBJS) -LNDIR := $(nandobj)board/$(BOARDDIR) - -ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin $(nandobj)u-boot-spl-16k.bin - -all: $(obj).depend $(ALL) - -$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ - -$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl - $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ - -$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds - cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ - -Map $(nandobj)u-boot-spl.map \ - -o $(nandobj)u-boot-spl - -$(nandobj)u-boot.lds: $(LDSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ - -# create symbolic links for common files - -# from cpu directory -$(obj)start.S: - @rm -f $@ - @ln -s $(TOPDIR)/arch/arm/cpu/arm1176/start.S $@ - -# from SoC directory -$(obj)cpu_init.S: - @rm -f $@ - @ln -s $(TOPDIR)/arch/arm/cpu/arm1176/s3c64xx/cpu_init.S $@ - -# from board directory -$(obj)lowlevel_init.S: - @rm -f $@ - @ln -s $(TOPDIR)/board/samsung/smdk6400/lowlevel_init.S $@ - -# from nand_spl directory -$(obj)nand_boot.c: - @rm -f $@ - @ln -s $(TOPDIR)/nand_spl/nand_boot.c $@ - -# from drivers/mtd/nand directory -$(obj)nand_ecc.c: - @rm -f $@ - @ln -s $(TOPDIR)/drivers/mtd/nand/nand_ecc.c $@ - -$(obj)s3c64xx.c: - @rm -f $@ - @ln -s $(TOPDIR)/drivers/mtd/nand/s3c64xx.c $@ - -$(obj)smdk6400_nand_spl.c: - @rm -f $@ - @ln -s $(TOPDIR)/board/samsung/smdk6400/smdk6400_nand_spl.c $@ - -$(obj)nand_base.c: - @rm -f $@ - @ln -s $(TOPDIR)/drivers/mtd/nand/nand_base.c $@ -######################################################################### - -$(obj)%.o: $(obj)%.S - $(CC) $(AFLAGS) -c -o $@ $< - -$(obj)%.o: $(obj)%.c - $(CC) $(CFLAGS) -c -o $@ $< - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/nand_spl/board/samsung/smdk6400/config.mk b/nand_spl/board/samsung/smdk6400/config.mk deleted file mode 100644 index 8bea498..0000000 --- a/nand_spl/board/samsung/smdk6400/config.mk +++ /dev/null @@ -1,40 +0,0 @@ -# -# (C) Copyright 2006 -# Stefan Roese, DENX Software Engineering, sr@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# -# Samsung S3C64xx Reference Platform (smdk6400) board - -# CONFIG_SYS_TEXT_BASE for SPL: -# -# On S3C64xx platforms the SPL is located in SRAM at 0. -# -# CONFIG_SYS_TEXT_BASE = 0 - -include $(TOPDIR)/board/$(BOARDDIR)/config.mk - -# PAD_TO used to generate a 4kByte binary needed for the combined image -# -> PAD_TO = CONFIG_SYS_TEXT_BASE + 4096 -PAD_TO := $(shell expr $$[$(CONFIG_SYS_TEXT_BASE) + 4096]) - -ifeq ($(debug),1) -PLATFORM_CPPFLAGS += -DDEBUG -endif diff --git a/nand_spl/board/samsung/smdk6400/u-boot.lds b/nand_spl/board/samsung/smdk6400/u-boot.lds deleted file mode 100644 index 293ae02..0000000 --- a/nand_spl/board/samsung/smdk6400/u-boot.lds +++ /dev/null @@ -1,82 +0,0 @@ -/* - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - start.o (.text) - cpu_init.o (.text) - nand_boot.o (.text) - - *(.text) - } - - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(4); - .data : { *(.data) } - - . = ALIGN(4); - .got : { *(.got) } - - - . = ALIGN(4); - .u_boot_list : { - #include <u-boot.lst> - } - - . = ALIGN(4); - - __image_copy_end = .; - - .rel.dyn : { - __rel_dyn_start = .; - *(.rel*) - __rel_dyn_end = .; - } - - .dynsym : { - __dynsym_start = .; - *(.dynsym) - } - - _end = .; - - .bss __rel_dyn_start (OVERLAY) : { - __bss_start = .; - *(.bss) - . = ALIGN(4); - __bss_end__ = .; - } -}
This reverts commit 1285a2808a254f3d1a809c1a541f0c0f746e03d7 since the migration of boards from Makefile to boards.cfg is now complete.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - New patch.
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
doc/feature-removal-schedule.txt | 16 ---------------- mkconfig | 9 --------- 2 files changed, 25 deletions(-)
diff --git a/doc/feature-removal-schedule.txt b/doc/feature-removal-schedule.txt index e04ba2d..6abb7d1 100644 --- a/doc/feature-removal-schedule.txt +++ b/doc/feature-removal-schedule.txt @@ -18,22 +18,6 @@ Who: Andy Fleming afleming@freescale.com and driver maintainers
-What: boards with xxx_config targets in top level Makefile -When: Release v2012.03 - -Why: We have a boards.cfg file which the vast majority of boards have - converted over to. Boards that still manually run mkconfig in the - top level Makefile are either dead, or the maintainer doesn't care, - or they are doing something weird/wrong that should be fixed in a - different way, or they need to extend boards.cfg syntax (unlikely). - - In any case, if no one cares about these boards to figure out how - to make boards.cfg work, then we'll just punt them. - -Who: Mike Frysinger vapier@gentoo.org - ---------------------------- - What: GPL cleanup When: August 2009 Why: Over time, a couple of files have sneaked in into the U-Boot diff --git a/mkconfig b/mkconfig index 7c9aa74..73f852e 100755 --- a/mkconfig +++ b/mkconfig @@ -29,15 +29,6 @@ if [ ( $# -eq 2 ) -a ( "$1" = "-A" ) ] ; then set ${line} # add default board name if needed [ $# = 3 ] && set ${line} ${1} -elif [ "${MAKEFLAGS+set}${MAKELEVEL+set}" = "setset" ] ; then - # only warn when using a config target in the Makefile - cat <<-EOF - - warning: Please migrate to boards.cfg. Failure to do so will - mean removal of your board in the next release. - - EOF - sleep 5 fi
while [ $# -gt 0 ] ; do
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so move it to scrapyard. It will still be possible to restore it later from the Git history if necessary.
arch/arm/cpu/arm1176/s3c64xx/Makefile | 50 -- arch/arm/cpu/arm1176/s3c64xx/config.mk | 34 - arch/arm/cpu/arm1176/s3c64xx/cpu_init.S | 135 ---- arch/arm/cpu/arm1176/s3c64xx/init.c | 26 - arch/arm/cpu/arm1176/s3c64xx/reset.S | 34 - arch/arm/cpu/arm1176/s3c64xx/speed.c | 145 ----- arch/arm/cpu/arm1176/s3c64xx/timer.c | 160 ----- arch/arm/include/asm/arch-s3c64xx/hardware.h | 63 -- arch/arm/include/asm/arch-s3c64xx/s3c6400.h | 895 -------------------------- arch/arm/include/asm/arch-s3c64xx/s3c64x0.h | 90 --- doc/driver-model/UDM-serial.txt | 42 +- drivers/mtd/nand/Makefile | 1 - drivers/mtd/nand/s3c64xx.c | 295 --------- drivers/mtd/onenand/onenand_base.c | 4 - drivers/mtd/onenand/samsung.c | 60 +- drivers/serial/Makefile | 1 - drivers/serial/s3c64xx.c | 187 ------ drivers/serial/serial.c | 2 - drivers/usb/host/Makefile | 1 - drivers/usb/host/ohci-hcd.c | 1 - drivers/usb/host/s3c64xx-hcd.c | 45 -- include/common.h | 1 - include/onenand_uboot.h | 4 - 23 files changed, 23 insertions(+), 2253 deletions(-) delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/Makefile delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/config.mk delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/cpu_init.S delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/init.c delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/reset.S delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/speed.c delete mode 100644 arch/arm/cpu/arm1176/s3c64xx/timer.c delete mode 100644 arch/arm/include/asm/arch-s3c64xx/hardware.h delete mode 100644 arch/arm/include/asm/arch-s3c64xx/s3c6400.h delete mode 100644 arch/arm/include/asm/arch-s3c64xx/s3c64x0.h delete mode 100644 drivers/mtd/nand/s3c64xx.c delete mode 100644 drivers/serial/s3c64xx.c delete mode 100644 drivers/usb/host/s3c64xx-hcd.c
diff --git a/arch/arm/cpu/arm1176/s3c64xx/Makefile b/arch/arm/cpu/arm1176/s3c64xx/Makefile deleted file mode 100644 index 266a073..0000000 --- a/arch/arm/cpu/arm1176/s3c64xx/Makefile +++ /dev/null @@ -1,50 +0,0 @@ -# -# (C) Copyright 2000-2003 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# (C) Copyright 2008 -# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS = reset.o - -COBJS-$(CONFIG_S3C6400) += cpu_init.o speed.o -COBJS-y += timer.o init.o - -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm1176/s3c64xx/config.mk b/arch/arm/cpu/arm1176/s3c64xx/config.mk deleted file mode 100644 index 222d352..0000000 --- a/arch/arm/cpu/arm1176/s3c64xx/config.mk +++ /dev/null @@ -1,34 +0,0 @@ -# -# (C) Copyright 2002 -# Gary Jennejohn, DENX Software Engineering, garyj@denx.de -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -PLATFORM_RELFLAGS += -fno-common -ffixed-r8 -msoft-float - -# Make ARMv5 to allow more compilers to work, even though its v6. -PLATFORM_CPPFLAGS += -march=armv5t -# ========================================================================= -# -# Supply options according to compiler version -# -# ========================================================================= -PF_RELFLAGS_SLB_AT := $(call cc-option,-mshort-load-bytes,\ - $(call cc-option,-malignment-traps,)) -PLATFORM_RELFLAGS += $(PF_RELFLAGS_SLB_AT) diff --git a/arch/arm/cpu/arm1176/s3c64xx/cpu_init.S b/arch/arm/cpu/arm1176/s3c64xx/cpu_init.S deleted file mode 100644 index df88cba..0000000 --- a/arch/arm/cpu/arm1176/s3c64xx/cpu_init.S +++ /dev/null @@ -1,135 +0,0 @@ -/* - * Originates from Samsung's u-boot 1.1.6 port to S3C6400 / SMDK6400 - * - * Copyright (C) 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <asm/arch/s3c6400.h> - - .globl mem_ctrl_asm_init -mem_ctrl_asm_init: - /* DMC1 base address 0x7e001000 */ - ldr r0, =ELFIN_DMC1_BASE - - ldr r1, =0x4 - str r1, [r0, #INDEX_DMC_MEMC_CMD] - - ldr r1, =DMC_DDR_REFRESH_PRD - str r1, [r0, #INDEX_DMC_REFRESH_PRD] - - ldr r1, =DMC_DDR_CAS_LATENCY - str r1, [r0, #INDEX_DMC_CAS_LATENCY] - - ldr r1, =DMC_DDR_t_DQSS - str r1, [r0, #INDEX_DMC_T_DQSS] - - ldr r1, =DMC_DDR_t_MRD - str r1, [r0, #INDEX_DMC_T_MRD] - - ldr r1, =DMC_DDR_t_RAS - str r1, [r0, #INDEX_DMC_T_RAS] - - ldr r1, =DMC_DDR_t_RC - str r1, [r0, #INDEX_DMC_T_RC] - - ldr r1, =DMC_DDR_t_RCD - ldr r2, =DMC_DDR_schedule_RCD - orr r1, r1, r2 - str r1, [r0, #INDEX_DMC_T_RCD] - - ldr r1, =DMC_DDR_t_RFC - ldr r2, =DMC_DDR_schedule_RFC - orr r1, r1, r2 - str r1, [r0, #INDEX_DMC_T_RFC] - - ldr r1, =DMC_DDR_t_RP - ldr r2, =DMC_DDR_schedule_RP - orr r1, r1, r2 - str r1, [r0, #INDEX_DMC_T_RP] - - ldr r1, =DMC_DDR_t_RRD - str r1, [r0, #INDEX_DMC_T_RRD] - - ldr r1, =DMC_DDR_t_WR - str r1, [r0, #INDEX_DMC_T_WR] - - ldr r1, =DMC_DDR_t_WTR - str r1, [r0, #INDEX_DMC_T_WTR] - - ldr r1, =DMC_DDR_t_XP - str r1, [r0, #INDEX_DMC_T_XP] - - ldr r1, =DMC_DDR_t_XSR - str r1, [r0, #INDEX_DMC_T_XSR] - - ldr r1, =DMC_DDR_t_ESR - str r1, [r0, #INDEX_DMC_T_ESR] - - ldr r1, =DMC1_MEM_CFG - str r1, [r0, #INDEX_DMC_MEMORY_CFG] - - ldr r1, =DMC1_MEM_CFG2 - str r1, [r0, #INDEX_DMC_MEMORY_CFG2] - - ldr r1, =DMC1_CHIP0_CFG - str r1, [r0, #INDEX_DMC_CHIP_0_CFG] - - ldr r1, =DMC_DDR_32_CFG - str r1, [r0, #INDEX_DMC_USER_CONFIG] - - /* DMC0 DDR Chip 0 configuration direct command reg */ - ldr r1, =DMC_NOP0 - str r1, [r0, #INDEX_DMC_DIRECT_CMD] - - /* Precharge All */ - ldr r1, =DMC_PA0 - str r1, [r0, #INDEX_DMC_DIRECT_CMD] - - /* Auto Refresh 2 time */ - ldr r1, =DMC_AR0 - str r1, [r0, #INDEX_DMC_DIRECT_CMD] - str r1, [r0, #INDEX_DMC_DIRECT_CMD] - - /* MRS */ - ldr r1, =DMC_mDDR_EMR0 - str r1, [r0, #INDEX_DMC_DIRECT_CMD] - - /* Mode Reg */ - ldr r1, =DMC_mDDR_MR0 - str r1, [r0, #INDEX_DMC_DIRECT_CMD] - - /* Enable DMC1 */ - mov r1, #0x0 - str r1, [r0, #INDEX_DMC_MEMC_CMD] - -check_dmc1_ready: - ldr r1, [r0, #INDEX_DMC_MEMC_STATUS] - mov r2, #0x3 - and r1, r1, r2 - cmp r1, #0x1 - bne check_dmc1_ready - nop - - mov pc, lr - - .ltorg diff --git a/arch/arm/cpu/arm1176/s3c64xx/init.c b/arch/arm/cpu/arm1176/s3c64xx/init.c deleted file mode 100644 index f113d8e..0000000 --- a/arch/arm/cpu/arm1176/s3c64xx/init.c +++ /dev/null @@ -1,26 +0,0 @@ -/* - * (C) Copyright 2012 Ashok Kumar Reddy Kourla - * ashokkourla2000@gmail.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include<common.h> - -int arch_cpu_init(void) -{ - icache_enable(); - - return 0; -} diff --git a/arch/arm/cpu/arm1176/s3c64xx/reset.S b/arch/arm/cpu/arm1176/s3c64xx/reset.S deleted file mode 100644 index eae572e..0000000 --- a/arch/arm/cpu/arm1176/s3c64xx/reset.S +++ /dev/null @@ -1,34 +0,0 @@ -/* - * Copyright (c) 2009 Samsung Electronics. - * Minkyu Kang mk7.kang@samsung.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <asm/arch/s3c6400.h> - -.globl reset_cpu -reset_cpu: - ldr r1, =ELFIN_CLOCK_POWER_BASE - ldr r2, [r1, #SYS_ID_OFFSET] - ldr r3, =0xffff - and r2, r3, r2, lsr #12 - str r2, [r1, #SW_RST_OFFSET] -_loop_forever: - b _loop_forever diff --git a/arch/arm/cpu/arm1176/s3c64xx/speed.c b/arch/arm/cpu/arm1176/s3c64xx/speed.c deleted file mode 100644 index 11962ac..0000000 --- a/arch/arm/cpu/arm1176/s3c64xx/speed.c +++ /dev/null @@ -1,145 +0,0 @@ -/* - * (C) Copyright 2001-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2002 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * This code should work for both the S3C2400 and the S3C2410 - * as they seem to have the same PLL and clock machinery inside. - * The different address mapping is handled by the s3c24xx.h files below. - */ - -#include <common.h> -#include <asm/arch/s3c6400.h> - -#define APLL 0 -#define MPLL 1 -#define EPLL 2 - -/* ------------------------------------------------------------------------- */ -/* - * NOTE: This describes the proper use of this file. - * - * CONFIG_SYS_CLK_FREQ should be defined as the input frequency of the PLL. - * - * get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of - * the specified bus in HZ. - */ -/* ------------------------------------------------------------------------- */ - -static ulong get_PLLCLK(int pllreg) -{ - ulong r, m, p, s; - - switch (pllreg) { - case APLL: - r = APLL_CON_REG; - break; - case MPLL: - r = MPLL_CON_REG; - break; - case EPLL: - r = EPLL_CON0_REG; - break; - default: - hang(); - } - - m = (r >> 16) & 0x3ff; - p = (r >> 8) & 0x3f; - s = r & 0x7; - - return m * (CONFIG_SYS_CLK_FREQ / (p * (1 << s))); -} - -/* return ARMCORE frequency */ -ulong get_ARMCLK(void) -{ - ulong div; - - div = CLK_DIV0_REG; - - return get_PLLCLK(APLL) / ((div & 0x7) + 1); -} - -/* return FCLK frequency */ -ulong get_FCLK(void) -{ - return get_PLLCLK(APLL); -} - -/* return HCLK frequency */ -ulong get_HCLK(void) -{ - ulong fclk; - - uint hclkx2_div = ((CLK_DIV0_REG >> 9) & 0x7) + 1; - uint hclk_div = ((CLK_DIV0_REG >> 8) & 0x1) + 1; - - /* - * Bit 7 exists on s3c6410, and not on s3c6400, it is reserved on - * s3c6400 and is always 0, and it is indeed running in ASYNC mode - */ - if (OTHERS_REG & 0x80) - fclk = get_FCLK(); /* SYNC Mode */ - else - fclk = get_PLLCLK(MPLL); /* ASYNC Mode */ - - return fclk / (hclk_div * hclkx2_div); -} - -/* return PCLK frequency */ -ulong get_PCLK(void) -{ - ulong fclk; - uint hclkx2_div = ((CLK_DIV0_REG >> 9) & 0x7) + 1; - uint pre_div = ((CLK_DIV0_REG >> 12) & 0xf) + 1; - - if (OTHERS_REG & 0x80) - fclk = get_FCLK(); /* SYNC Mode */ - else - fclk = get_PLLCLK(MPLL); /* ASYNC Mode */ - - return fclk / (hclkx2_div * pre_div); -} - -/* return UCLK frequency */ -ulong get_UCLK(void) -{ - return get_PLLCLK(EPLL); -} - -int print_cpuinfo(void) -{ - printf("\nCPU: S3C6400@%luMHz\n", get_ARMCLK() / 1000000); - printf(" Fclk = %luMHz, Hclk = %luMHz, Pclk = %luMHz ", - get_FCLK() / 1000000, get_HCLK() / 1000000, - get_PCLK() / 1000000); - - if (OTHERS_REG & 0x80) - printf("(SYNC Mode) \n"); - else - printf("(ASYNC Mode) \n"); - return 0; -} diff --git a/arch/arm/cpu/arm1176/s3c64xx/timer.c b/arch/arm/cpu/arm1176/s3c64xx/timer.c deleted file mode 100644 index f16a37b..0000000 --- a/arch/arm/cpu/arm1176/s3c64xx/timer.c +++ /dev/null @@ -1,160 +0,0 @@ -/* - * (C) Copyright 2003 - * Texas Instruments <www.ti.com> - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Alex Zuepke azu@sysgo.de - * - * (C) Copyright 2002-2004 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * (C) Copyright 2004 - * Philippe Robin, ARM Ltd. philippe.robin@arm.com - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/proc-armv/ptrace.h> -#include <asm/arch/s3c6400.h> -#include <div64.h> - -static ulong timer_load_val; - -#define PRESCALER 167 - -static s3c64xx_timers *s3c64xx_get_base_timers(void) -{ - return (s3c64xx_timers *)ELFIN_TIMER_BASE; -} - -/* macro to read the 16 bit timer */ -static inline ulong read_timer(void) -{ - s3c64xx_timers *const timers = s3c64xx_get_base_timers(); - - return timers->TCNTO4; -} - -/* Internal tick units */ -/* Last decremneter snapshot */ -static unsigned long lastdec; -/* Monotonic incrementing timer */ -static unsigned long long timestamp; - -int timer_init(void) -{ - s3c64xx_timers *const timers = s3c64xx_get_base_timers(); - - /* use PWM Timer 4 because it has no output */ - /* - * We use the following scheme for the timer: - * Prescaler is hard fixed at 167, divider at 1/4. - * This gives at PCLK frequency 66MHz approx. 10us ticks - * The timer is set to wrap after 100s, at 66MHz this obviously - * happens after 10,000,000 ticks. A long variable can thus - * keep values up to 40,000s, i.e., 11 hours. This should be - * enough for most uses:-) Possible optimizations: select a - * binary-friendly frequency, e.g., 1ms / 128. Also calculate - * the prescaler automatically for other PCLK frequencies. - */ - timers->TCFG0 = PRESCALER << 8; - if (timer_load_val == 0) { - timer_load_val = get_PCLK() / PRESCALER * (100 / 4); /* 100s */ - timers->TCFG1 = (timers->TCFG1 & ~0xf0000) | 0x20000; - } - - /* load value for 10 ms timeout */ - lastdec = timers->TCNTB4 = timer_load_val; - /* auto load, manual update of Timer 4 */ - timers->TCON = (timers->TCON & ~0x00700000) | TCON_4_AUTO | - TCON_4_UPDATE; - - /* auto load, start Timer 4 */ - timers->TCON = (timers->TCON & ~0x00700000) | TCON_4_AUTO | COUNT_4_ON; - timestamp = 0; - - return 0; -} - -/* - * timer without interrupts - */ - -/* - * This function is derived from PowerPC code (read timebase as long long). - * On ARM it just returns the timer value. - */ -unsigned long long get_ticks(void) -{ - ulong now = read_timer(); - - if (lastdec >= now) { - /* normal mode */ - timestamp += lastdec - now; - } else { - /* we have an overflow ... */ - timestamp += lastdec + timer_load_val - now; - } - lastdec = now; - - return timestamp; -} - -/* - * This function is derived from PowerPC code (timebase clock frequency). - * On ARM it returns the number of timer ticks per second. - */ -ulong get_tbclk(void) -{ - /* We overrun in 100s */ - return (ulong)(timer_load_val / 100); -} - -ulong get_timer_masked(void) -{ - unsigned long long res = get_ticks(); - do_div (res, (timer_load_val / (100 * CONFIG_SYS_HZ))); - return res; -} - -ulong get_timer(ulong base) -{ - return get_timer_masked() - base; -} - -void __udelay(unsigned long usec) -{ - unsigned long long tmp; - ulong tmo; - - tmo = (usec + 9) / 10; - tmp = get_ticks() + tmo; /* get current timestamp */ - - while (get_ticks() < tmp)/* loop till event */ - /*NOP*/; -} diff --git a/arch/arm/include/asm/arch-s3c64xx/hardware.h b/arch/arm/include/asm/arch-s3c64xx/hardware.h deleted file mode 100644 index 84d24c9..0000000 --- a/arch/arm/include/asm/arch-s3c64xx/hardware.h +++ /dev/null @@ -1,63 +0,0 @@ -/* - * Originates from Samsung's u-boot 1.1.6 port to S3C6400 / SMDK6400 - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _ARCH_HARDWARE_H_ -#define _ARCH_HARDWARE_H_ - -#include <asm/sizes.h> - -#ifndef __ASSEMBLY__ -#define UData(Data) ((unsigned long) (Data)) - -#define __REG(x) (*(vu_long *)(x)) -#define __REGl(x) (*(vu_long *)(x)) -#define __REGw(x) (*(vu_short *)(x)) -#define __REGb(x) (*(vu_char *)(x)) -#define __REG2(x, y) (*(vu_long *)((x) + (y))) -#else -#define UData(Data) (Data) - -#define __REG(x) (x) -#define __REGl(x) (x) -#define __REGw(x) (x) -#define __REGb(x) (x) -#define __REG2(x, y) ((x) + (y)) -#endif - -#define Fld(Size, Shft) (((Size) << 16) + (Shft)) - -#define FSize(Field) ((Field) >> 16) -#define FShft(Field) ((Field) & 0x0000FFFF) -#define FMsk(Field) (((UData (1) << FSize (Field)) - 1) << FShft (Field)) -#define FAlnMsk(Field) ((UData (1) << FSize (Field)) - 1) -#define F1stBit(Field) (UData (1) << FShft (Field)) - -#define FClrBit(Data, Bit) (Data = (Data & ~(Bit))) -#define FClrFld(Data, Field) (Data = (Data & ~FMsk(Field))) - -#define FInsrt(Value, Field) \ - (UData (Value) << FShft (Field)) - -#define FExtr(Data, Field) \ - ((UData (Data) >> FShft (Field)) & FAlnMsk (Field)) - -#endif /* _ARCH_HARDWARE_H_ */ diff --git a/arch/arm/include/asm/arch-s3c64xx/s3c6400.h b/arch/arm/include/asm/arch-s3c64xx/s3c6400.h deleted file mode 100644 index 10b3324..0000000 --- a/arch/arm/include/asm/arch-s3c64xx/s3c6400.h +++ /dev/null @@ -1,895 +0,0 @@ -/* - * (C) Copyright 2007 - * Byungjae Lee, Samsung Erectronics, bjlee@samsung.com. - * - only support for S3C6400 - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/************************************************ - * NAME : s3c6400.h - * - * Based on S3C6400 User's manual Rev 0.0 - ************************************************/ - -#ifndef __S3C6400_H__ -#define __S3C6400_H__ - -#define S3C64XX_UART_CHANNELS 3 -#define S3C64XX_SPI_CHANNELS 2 - -#include <asm/hardware.h> - -#define ELFIN_CLOCK_POWER_BASE 0x7e00f000 - -/* Clock & Power Controller for mDirac3*/ -#define APLL_LOCK_OFFSET 0x00 -#define MPLL_LOCK_OFFSET 0x04 -#define EPLL_LOCK_OFFSET 0x08 -#define APLL_CON_OFFSET 0x0C -#define MPLL_CON_OFFSET 0x10 -#define EPLL_CON0_OFFSET 0x14 -#define EPLL_CON1_OFFSET 0x18 -#define CLK_SRC_OFFSET 0x1C -#define CLK_DIV0_OFFSET 0x20 -#define CLK_DIV1_OFFSET 0x24 -#define CLK_DIV2_OFFSET 0x28 -#define CLK_OUT_OFFSET 0x2C -#define HCLK_GATE_OFFSET 0x30 -#define PCLK_GATE_OFFSET 0x34 -#define SCLK_GATE_OFFSET 0x38 -#define AHB_CON0_OFFSET 0x100 -#define AHB_CON1_OFFSET 0x104 -#define AHB_CON2_OFFSET 0x108 -#define SELECT_DMA_OFFSET 0x110 -#define SW_RST_OFFSET 0x114 -#define SYS_ID_OFFSET 0x118 -#define MEM_SYS_CFG_OFFSET 0x120 -#define QOS_OVERRIDE0_OFFSET 0x124 -#define QOS_OVERRIDE1_OFFSET 0x128 -#define MEM_CFG_STAT_OFFSET 0x12C -#define PWR_CFG_OFFSET 0x804 -#define EINT_MASK_OFFSET 0x808 -#define NOR_CFG_OFFSET 0x810 -#define STOP_CFG_OFFSET 0x814 -#define SLEEP_CFG_OFFSET 0x818 -#define OSC_FREQ_OFFSET 0x820 -#define OSC_STABLE_OFFSET 0x824 -#define PWR_STABLE_OFFSET 0x828 -#define FPC_STABLE_OFFSET 0x82C -#define MTC_STABLE_OFFSET 0x830 -#define OTHERS_OFFSET 0x900 -#define RST_STAT_OFFSET 0x904 -#define WAKEUP_STAT_OFFSET 0x908 -#define BLK_PWR_STAT_OFFSET 0x90C -#define INF_REG0_OFFSET 0xA00 -#define INF_REG1_OFFSET 0xA04 -#define INF_REG2_OFFSET 0xA08 -#define INF_REG3_OFFSET 0xA0C -#define INF_REG4_OFFSET 0xA10 -#define INF_REG5_OFFSET 0xA14 -#define INF_REG6_OFFSET 0xA18 -#define INF_REG7_OFFSET 0xA1C - -#define OSC_CNT_VAL_OFFSET 0x824 -#define PWR_CNT_VAL_OFFSET 0x828 -#define FPC_CNT_VAL_OFFSET 0x82C -#define MTC_CNT_VAL_OFFSET 0x830 - -#define APLL_LOCK_REG __REG(ELFIN_CLOCK_POWER_BASE + APLL_LOCK_OFFSET) -#define MPLL_LOCK_REG __REG(ELFIN_CLOCK_POWER_BASE + MPLL_LOCK_OFFSET) -#define EPLL_LOCK_REG __REG(ELFIN_CLOCK_POWER_BASE + EPLL_LOCK_OFFSET) -#define APLL_CON_REG __REG(ELFIN_CLOCK_POWER_BASE + APLL_CON_OFFSET) -#define MPLL_CON_REG __REG(ELFIN_CLOCK_POWER_BASE + MPLL_CON_OFFSET) -#define EPLL_CON0_REG __REG(ELFIN_CLOCK_POWER_BASE + EPLL_CON0_OFFSET) -#define EPLL_CON1_REG __REG(ELFIN_CLOCK_POWER_BASE + EPLL_CON1_OFFSET) -#define CLK_SRC_REG __REG(ELFIN_CLOCK_POWER_BASE + CLK_SRC_OFFSET) -#define CLK_DIV0_REG __REG(ELFIN_CLOCK_POWER_BASE + CLK_DIV0_OFFSET) -#define CLK_DIV1_REG __REG(ELFIN_CLOCK_POWER_BASE + CLK_DIV1_OFFSET) -#define CLK_DIV2_REG __REG(ELFIN_CLOCK_POWER_BASE + CLK_DIV2_OFFSET) -#define CLK_OUT_REG __REG(ELFIN_CLOCK_POWER_BASE + CLK_OUT_OFFSET) -#define HCLK_GATE_REG __REG(ELFIN_CLOCK_POWER_BASE + HCLK_GATE_OFFSET) -#define PCLK_GATE_REG __REG(ELFIN_CLOCK_POWER_BASE + PCLK_GATE_OFFSET) -#define SCLK_GATE_REG __REG(ELFIN_CLOCK_POWER_BASE + SCLK_GATE_OFFSET) -#define AHB_CON0_REG __REG(ELFIN_CLOCK_POWER_BASE + AHB_CON0_OFFSET) -#define AHB_CON1_REG __REG(ELFIN_CLOCK_POWER_BASE + AHB_CON1_OFFSET) -#define AHB_CON2_REG __REG(ELFIN_CLOCK_POWER_BASE + AHB_CON2_OFFSET) -#define SELECT_DMA_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - SELECT_DMA_OFFSET) -#define SW_RST_REG __REG(ELFIN_CLOCK_POWER_BASE + SW_RST_OFFSET) -#define SYS_ID_REG __REG(ELFIN_CLOCK_POWER_BASE + SYS_ID_OFFSET) -#define MEM_SYS_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - MEM_SYS_CFG_OFFSET) -#define QOS_OVERRIDE0_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - QOS_OVERRIDE0_OFFSET) -#define QOS_OVERRIDE1_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - QOS_OVERRIDE1_OFFSET) -#define MEM_CFG_STAT_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - MEM_CFG_STAT_OFFSET) -#define PWR_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE + PWR_CFG_OFFSET) -#define EINT_MASK_REG __REG(ELFIN_CLOCK_POWER_BASE + EINT_MASK_OFFSET) -#define NOR_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE + NOR_CFG_OFFSET) -#define STOP_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE + STOP_CFG_OFFSET) -#define SLEEP_CFG_REG __REG(ELFIN_CLOCK_POWER_BASE + SLEEP_CFG_OFFSET) -#define OSC_FREQ_REG __REG(ELFIN_CLOCK_POWER_BASE + OSC_FREQ_OFFSET) -#define OSC_CNT_VAL_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - OSC_CNT_VAL_OFFSET) -#define PWR_CNT_VAL_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - PWR_CNT_VAL_OFFSET) -#define FPC_CNT_VAL_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - FPC_CNT_VAL_OFFSET) -#define MTC_CNT_VAL_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - MTC_CNT_VAL_OFFSET) -#define OTHERS_REG __REG(ELFIN_CLOCK_POWER_BASE + OTHERS_OFFSET) -#define RST_STAT_REG __REG(ELFIN_CLOCK_POWER_BASE + RST_STAT_OFFSET) -#define WAKEUP_STAT_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - WAKEUP_STAT_OFFSET) -#define BLK_PWR_STAT_REG __REG(ELFIN_CLOCK_POWER_BASE + \ - BLK_PWR_STAT_OFFSET) -#define INF_REG0_REG __REG(ELFIN_CLOCK_POWER_BASE + INF_REG0_OFFSET) -#define INF_REG1_REG __REG(ELFIN_CLOCK_POWER_BASE + INF_REG1_OFFSET) -#define INF_REG2_REG __REG(ELFIN_CLOCK_POWER_BASE + INF_REG2_OFFSET) -#define INF_REG3_REG __REG(ELFIN_CLOCK_POWER_BASE + INF_REG3_OFFSET) -#define INF_REG4_REG __REG(ELFIN_CLOCK_POWER_BASE + INF_REG4_OFFSET) -#define INF_REG5_REG __REG(ELFIN_CLOCK_POWER_BASE + INF_REG5_OFFSET) -#define INF_REG6_REG __REG(ELFIN_CLOCK_POWER_BASE + INF_REG6_OFFSET) -#define INF_REG7_REG __REG(ELFIN_CLOCK_POWER_BASE + INF_REG7_OFFSET) - -#define APLL_LOCK (ELFIN_CLOCK_POWER_BASE + APLL_LOCK_OFFSET) -#define MPLL_LOCK (ELFIN_CLOCK_POWER_BASE + MPLL_LOCK_OFFSET) -#define EPLL_LOCK (ELFIN_CLOCK_POWER_BASE + EPLL_LOCK_OFFSET) -#define APLL_CON (ELFIN_CLOCK_POWER_BASE + APLL_CON_OFFSET) -#define MPLL_CON (ELFIN_CLOCK_POWER_BASE + MPLL_CON_OFFSET) -#define EPLL_CON0 (ELFIN_CLOCK_POWER_BASE + EPLL_CON0_OFFSET) -#define EPLL_CON1 (ELFIN_CLOCK_POWER_BASE + EPLL_CON1_OFFSET) -#define CLK_SRC (ELFIN_CLOCK_POWER_BASE + CLK_SRC_OFFSET) -#define CLK_DIV0 (ELFIN_CLOCK_POWER_BASE + CLK_DIV0_OFFSET) -#define CLK_DIV1 (ELFIN_CLOCK_POWER_BASE + CLK_DIV1_OFFSET) -#define CLK_DIV2 (ELFIN_CLOCK_POWER_BASE + CLK_DIV2_OFFSET) -#define CLK_OUT (ELFIN_CLOCK_POWER_BASE + CLK_OUT_OFFSET) -#define HCLK_GATE (ELFIN_CLOCK_POWER_BASE + HCLK_GATE_OFFSET) -#define PCLK_GATE (ELFIN_CLOCK_POWER_BASE + PCLK_GATE_OFFSET) -#define SCLK_GATE (ELFIN_CLOCK_POWER_BASE + SCLK_GATE_OFFSET) -#define AHB_CON0 (ELFIN_CLOCK_POWER_BASE + AHB_CON0_OFFSET) -#define AHB_CON1 (ELFIN_CLOCK_POWER_BASE + AHB_CON1_OFFSET) -#define AHB_CON2 (ELFIN_CLOCK_POWER_BASE + AHB_CON2_OFFSET) -#define SELECT_DMA (ELFIN_CLOCK_POWER_BASE + SELECT_DMA_OFFSET) -#define SW_RST (ELFIN_CLOCK_POWER_BASE + SW_RST_OFFSET) -#define SYS_ID (ELFIN_CLOCK_POWER_BASE + SYS_ID_OFFSET) -#define MEM_SYS_CFG (ELFIN_CLOCK_POWER_BASE + MEM_SYS_CFG_OFFSET) -#define QOS_OVERRIDE0 (ELFIN_CLOCK_POWER_BASE + QOS_OVERRIDE0_OFFSET) -#define QOS_OVERRIDE1 (ELFIN_CLOCK_POWER_BASE + QOS_OVERRIDE1_OFFSET) -#define MEM_CFG_STAT (ELFIN_CLOCK_POWER_BASE + MEM_CFG_STAT_OFFSET) -#define PWR_CFG (ELFIN_CLOCK_POWER_BASE + PWR_CFG_OFFSET) -#define EINT_MASK (ELFIN_CLOCK_POWER_BASE + EINT_MASK_OFFSET) -#define NOR_CFG (ELFIN_CLOCK_POWER_BASE + NOR_CFG_OFFSET) -#define STOP_CFG (ELFIN_CLOCK_POWER_BASE + STOP_CFG_OFFSET) -#define SLEEP_CFG (ELFIN_CLOCK_POWER_BASE + SLEEP_CFG_OFFSET) -#define OSC_FREQ (ELFIN_CLOCK_POWER_BASE + OSC_FREQ_OFFSET) -#define OSC_CNT_VAL (ELFIN_CLOCK_POWER_BASE + OSC_CNT_VAL_OFFSET) -#define PWR_CNT_VAL (ELFIN_CLOCK_POWER_BASE + PWR_CNT_VAL_OFFSET) -#define FPC_CNT_VAL (ELFIN_CLOCK_POWER_BASE + FPC_CNT_VAL_OFFSET) -#define MTC_CNT_VAL (ELFIN_CLOCK_POWER_BASE + MTC_CNT_VAL_OFFSET) -#define OTHERS (ELFIN_CLOCK_POWER_BASE + OTHERS_OFFSET) -#define RST_STAT (ELFIN_CLOCK_POWER_BASE + RST_STAT_OFFSET) -#define WAKEUP_STAT (ELFIN_CLOCK_POWER_BASE + WAKEUP_STAT_OFFSET) -#define BLK_PWR_STAT (ELFIN_CLOCK_POWER_BASE + BLK_PWR_STAT_OFFSET) -#define INF_REG0 (ELFIN_CLOCK_POWER_BASE + INF_REG0_OFFSET) -#define INF_REG1 (ELFIN_CLOCK_POWER_BASE + INF_REG1_OFFSET) -#define INF_REG2 (ELFIN_CLOCK_POWER_BASE + INF_REG2_OFFSET) -#define INF_REG3 (ELFIN_CLOCK_POWER_BASE + INF_REG3_OFFSET) -#define INF_REG4 (ELFIN_CLOCK_POWER_BASE + INF_REG4_OFFSET) -#define INF_REG5 (ELFIN_CLOCK_POWER_BASE + INF_REG5_OFFSET) -#define INF_REG6 (ELFIN_CLOCK_POWER_BASE + INF_REG6_OFFSET) -#define INF_REG7 (ELFIN_CLOCK_POWER_BASE + INF_REG7_OFFSET) - - -/* - * GPIO - */ -#define ELFIN_GPIO_BASE 0x7f008000 - -#define GPACON_OFFSET 0x00 -#define GPADAT_OFFSET 0x04 -#define GPAPUD_OFFSET 0x08 -#define GPACONSLP_OFFSET 0x0C -#define GPAPUDSLP_OFFSET 0x10 -#define GPBCON_OFFSET 0x20 -#define GPBDAT_OFFSET 0x24 -#define GPBPUD_OFFSET 0x28 -#define GPBCONSLP_OFFSET 0x2C -#define GPBPUDSLP_OFFSET 0x30 -#define GPCCON_OFFSET 0x40 -#define GPCDAT_OFFSET 0x44 -#define GPCPUD_OFFSET 0x48 -#define GPCCONSLP_OFFSET 0x4C -#define GPCPUDSLP_OFFSET 0x50 -#define GPDCON_OFFSET 0x60 -#define GPDDAT_OFFSET 0x64 -#define GPDPUD_OFFSET 0x68 -#define GPDCONSLP_OFFSET 0x6C -#define GPDPUDSLP_OFFSET 0x70 -#define GPECON_OFFSET 0x80 -#define GPEDAT_OFFSET 0x84 -#define GPEPUD_OFFSET 0x88 -#define GPECONSLP_OFFSET 0x8C -#define GPEPUDSLP_OFFSET 0x90 -#define GPFCON_OFFSET 0xA0 -#define GPFDAT_OFFSET 0xA4 -#define GPFPUD_OFFSET 0xA8 -#define GPFCONSLP_OFFSET 0xAC -#define GPFPUDSLP_OFFSET 0xB0 -#define GPGCON_OFFSET 0xC0 -#define GPGDAT_OFFSET 0xC4 -#define GPGPUD_OFFSET 0xC8 -#define GPGCONSLP_OFFSET 0xCC -#define GPGPUDSLP_OFFSET 0xD0 -#define GPHCON0_OFFSET 0xE0 -#define GPHCON1_OFFSET 0xE4 -#define GPHDAT_OFFSET 0xE8 -#define GPHPUD_OFFSET 0xEC -#define GPHCONSLP_OFFSET 0xF0 -#define GPHPUDSLP_OFFSET 0xF4 -#define GPICON_OFFSET 0x100 -#define GPIDAT_OFFSET 0x104 -#define GPIPUD_OFFSET 0x108 -#define GPICONSLP_OFFSET 0x10C -#define GPIPUDSLP_OFFSET 0x110 -#define GPJCON_OFFSET 0x120 -#define GPJDAT_OFFSET 0x124 -#define GPJPUD_OFFSET 0x128 -#define GPJCONSLP_OFFSET 0x12C -#define GPJPUDSLP_OFFSET 0x130 -#define MEM0DRVCON_OFFSET 0x1D0 -#define MEM1DRVCON_OFFSET 0x1D4 -#define GPKCON0_OFFSET 0x800 -#define GPKCON1_OFFSET 0x804 -#define GPKDAT_OFFSET 0x808 -#define GPKPUD_OFFSET 0x80C -#define GPLCON0_OFFSET 0x810 -#define GPLCON1_OFFSET 0x814 -#define GPLDAT_OFFSET 0x818 -#define GPLPUD_OFFSET 0x81C -#define GPMCON_OFFSET 0x820 -#define GPMDAT_OFFSET 0x824 -#define GPMPUD_OFFSET 0x828 -#define GPNCON_OFFSET 0x830 -#define GPNDAT_OFFSET 0x834 -#define GPNPUD_OFFSET 0x838 -#define GPOCON_OFFSET 0x140 -#define GPODAT_OFFSET 0x144 -#define GPOPUD_OFFSET 0x148 -#define GPOCONSLP_OFFSET 0x14C -#define GPOPUDSLP_OFFSET 0x150 -#define GPPCON_OFFSET 0x160 -#define GPPDAT_OFFSET 0x164 -#define GPPPUD_OFFSET 0x168 -#define GPPCONSLP_OFFSET 0x16C -#define GPPPUDSLP_OFFSET 0x170 -#define GPQCON_OFFSET 0x180 -#define GPQDAT_OFFSET 0x184 -#define GPQPUD_OFFSET 0x188 -#define GPQCONSLP_OFFSET 0x18C -#define GPQPUDSLP_OFFSET 0x190 - -#define EINTPEND_OFFSET 0x924 - -#define GPACON_REG __REG(ELFIN_GPIO_BASE + GPACON_OFFSET) -#define GPADAT_REG __REG(ELFIN_GPIO_BASE + GPADAT_OFFSET) -#define GPAPUD_REG __REG(ELFIN_GPIO_BASE + GPAPUD_OFFSET) -#define GPACONSLP_REG __REG(ELFIN_GPIO_BASE + GPACONSLP_OFFSET) -#define GPAPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPAPUDSLP_OFFSET) -#define GPBCON_REG __REG(ELFIN_GPIO_BASE + GPBCON_OFFSET) -#define GPBDAT_REG __REG(ELFIN_GPIO_BASE + GPBDAT_OFFSET) -#define GPBPUD_REG __REG(ELFIN_GPIO_BASE + GPBPUD_OFFSET) -#define GPBCONSLP_REG __REG(ELFIN_GPIO_BASE + GPBCONSLP_OFFSET) -#define GPBPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPBPUDSLP_OFFSET) -#define GPCCON_REG __REG(ELFIN_GPIO_BASE + GPCCON_OFFSET) -#define GPCDAT_REG __REG(ELFIN_GPIO_BASE + GPCDAT_OFFSET) -#define GPCPUD_REG __REG(ELFIN_GPIO_BASE + GPCPUD_OFFSET) -#define GPCCONSLP_REG __REG(ELFIN_GPIO_BASE + GPCCONSLP_OFFSET) -#define GPCPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPCPUDSLP_OFFSET) -#define GPDCON_REG __REG(ELFIN_GPIO_BASE + GPDCON_OFFSET) -#define GPDDAT_REG __REG(ELFIN_GPIO_BASE + GPDDAT_OFFSET) -#define GPDPUD_REG __REG(ELFIN_GPIO_BASE + GPDPUD_OFFSET) -#define GPDCONSLP_REG __REG(ELFIN_GPIO_BASE + GPDCONSLP_OFFSET) -#define GPDPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPDPUDSLP_OFFSET) -#define GPECON_REG __REG(ELFIN_GPIO_BASE + GPECON_OFFSET) -#define GPEDAT_REG __REG(ELFIN_GPIO_BASE + GPEDAT_OFFSET) -#define GPEPUD_REG __REG(ELFIN_GPIO_BASE + GPEPUD_OFFSET) -#define GPECONSLP_REG __REG(ELFIN_GPIO_BASE + GPECONSLP_OFFSET) -#define GPEPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPEPUDSLP_OFFSET) -#define GPFCON_REG __REG(ELFIN_GPIO_BASE + GPFCON_OFFSET) -#define GPFDAT_REG __REG(ELFIN_GPIO_BASE + GPFDAT_OFFSET) -#define GPFPUD_REG __REG(ELFIN_GPIO_BASE + GPFPUD_OFFSET) -#define GPFCONSLP_REG __REG(ELFIN_GPIO_BASE + GPFCONSLP_OFFSET) -#define GPFPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPFPUDSLP_OFFSET) -#define GPGCON_REG __REG(ELFIN_GPIO_BASE + GPGCON_OFFSET) -#define GPGDAT_REG __REG(ELFIN_GPIO_BASE + GPGDAT_OFFSET) -#define GPGPUD_REG __REG(ELFIN_GPIO_BASE + GPGPUD_OFFSET) -#define GPGCONSLP_REG __REG(ELFIN_GPIO_BASE + GPGCONSLP_OFFSET) -#define GPGPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPGPUDSLP_OFFSET) -#define GPHCON0_REG __REG(ELFIN_GPIO_BASE + GPHCON0_OFFSET) -#define GPHCON1_REG __REG(ELFIN_GPIO_BASE + GPHCON1_OFFSET) -#define GPHDAT_REG __REG(ELFIN_GPIO_BASE + GPHDAT_OFFSET) -#define GPHPUD_REG __REG(ELFIN_GPIO_BASE + GPHPUD_OFFSET) -#define GPHCONSLP_REG __REG(ELFIN_GPIO_BASE + GPHCONSLP_OFFSET) -#define GPHPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPHPUDSLP_OFFSET) -#define GPICON_REG __REG(ELFIN_GPIO_BASE + GPICON_OFFSET) -#define GPIDAT_REG __REG(ELFIN_GPIO_BASE + GPIDAT_OFFSET) -#define GPIPUD_REG __REG(ELFIN_GPIO_BASE + GPIPUD_OFFSET) -#define GPICONSLP_REG __REG(ELFIN_GPIO_BASE + GPICONSLP_OFFSET) -#define GPIPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPIPUDSLP_OFFSET) -#define GPJCON_REG __REG(ELFIN_GPIO_BASE + GPJCON_OFFSET) -#define GPJDAT_REG __REG(ELFIN_GPIO_BASE + GPJDAT_OFFSET) -#define GPJPUD_REG __REG(ELFIN_GPIO_BASE + GPJPUD_OFFSET) -#define GPJCONSLP_REG __REG(ELFIN_GPIO_BASE + GPJCONSLP_OFFSET) -#define GPJPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPJPUDSLP_OFFSET) -#define GPKCON0_REG __REG(ELFIN_GPIO_BASE + GPKCON0_OFFSET) -#define GPKCON1_REG __REG(ELFIN_GPIO_BASE + GPKCON1_OFFSET) -#define GPKDAT_REG __REG(ELFIN_GPIO_BASE + GPKDAT_OFFSET) -#define GPKPUD_REG __REG(ELFIN_GPIO_BASE + GPKPUD_OFFSET) -#define GPLCON0_REG __REG(ELFIN_GPIO_BASE + GPLCON0_OFFSET) -#define GPLCON1_REG __REG(ELFIN_GPIO_BASE + GPLCON1_OFFSET) -#define GPLDAT_REG __REG(ELFIN_GPIO_BASE + GPLDAT_OFFSET) -#define GPLPUD_REG __REG(ELFIN_GPIO_BASE + GPLPUD_OFFSET) -#define GPMCON_REG __REG(ELFIN_GPIO_BASE + GPMCON_OFFSET) -#define GPMDAT_REG __REG(ELFIN_GPIO_BASE + GPMDAT_OFFSET) -#define GPMPUD_REG __REG(ELFIN_GPIO_BASE + GPMPUD_OFFSET) -#define GPNCON_REG __REG(ELFIN_GPIO_BASE + GPNCON_OFFSET) -#define GPNDAT_REG __REG(ELFIN_GPIO_BASE + GPNDAT_OFFSET) -#define GPNPUD_REG __REG(ELFIN_GPIO_BASE + GPNPUD_OFFSET) -#define GPOCON_REG __REG(ELFIN_GPIO_BASE + GPOCON_OFFSET) -#define GPODAT_REG __REG(ELFIN_GPIO_BASE + GPODAT_OFFSET) -#define GPOPUD_REG __REG(ELFIN_GPIO_BASE + GPOPUD_OFFSET) -#define GPOCONSLP_REG __REG(ELFIN_GPIO_BASE + GPOCONSLP_OFFSET) -#define GPOPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPOPUDSLP_OFFSET) -#define GPPCON_REG __REG(ELFIN_GPIO_BASE + GPPCON_OFFSET) -#define GPPDAT_REG __REG(ELFIN_GPIO_BASE + GPPDAT_OFFSET) -#define GPPPUD_REG __REG(ELFIN_GPIO_BASE + GPPPUD_OFFSET) -#define GPPCONSLP_REG __REG(ELFIN_GPIO_BASE + GPPCONSLP_OFFSET) -#define GPPPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPPPUDSLP_OFFSET) -#define GPQCON_REG __REG(ELFIN_GPIO_BASE + GPQCON_OFFSET) -#define GPQDAT_REG __REG(ELFIN_GPIO_BASE + GPQDAT_OFFSET) -#define GPQPUD_REG __REG(ELFIN_GPIO_BASE + GPQPUD_OFFSET) -#define GPQCONSLP_REG __REG(ELFIN_GPIO_BASE + GPQCONSLP_OFFSET) -#define GPQPUDSLP_REG __REG(ELFIN_GPIO_BASE + GPQPUDSLP_OFFSET) - -/* - * Bus Matrix - */ -#define ELFIN_MEM_SYS_CFG 0x7e00f120 - -#define S3C64XX_MEM_SYS_CFG_16BIT (1 << 12) - -#define S3C64XX_MEM_SYS_CFG_NAND 0x0008 -#define S3C64XX_MEM_SYS_CFG_ONENAND S3C64XX_MEM_SYS_CFG_16BIT - -#define GPACON (ELFIN_GPIO_BASE + GPACON_OFFSET) -#define GPADAT (ELFIN_GPIO_BASE + GPADAT_OFFSET) -#define GPAPUD (ELFIN_GPIO_BASE + GPAPUD_OFFSET) -#define GPACONSLP (ELFIN_GPIO_BASE + GPACONSLP_OFFSET) -#define GPAPUDSLP (ELFIN_GPIO_BASE + GPAPUDSLP_OFFSET) -#define GPBCON (ELFIN_GPIO_BASE + GPBCON_OFFSET) -#define GPBDAT (ELFIN_GPIO_BASE + GPBDAT_OFFSET) -#define GPBPUD (ELFIN_GPIO_BASE + GPBPUD_OFFSET) -#define GPBCONSLP (ELFIN_GPIO_BASE + GPBCONSLP_OFFSET) -#define GPBPUDSLP (ELFIN_GPIO_BASE + GPBPUDSLP_OFFSET) -#define GPCCON (ELFIN_GPIO_BASE + GPCCON_OFFSET) -#define GPCDAT (ELFIN_GPIO_BASE + GPCDAT_OFFSET) -#define GPCPUD (ELFIN_GPIO_BASE + GPCPUD_OFFSET) -#define GPCCONSLP (ELFIN_GPIO_BASE + GPCCONSLP_OFFSET) -#define GPCPUDSLP (ELFIN_GPIO_BASE + GPCPUDSLP_OFFSET) -#define GPDCON (ELFIN_GPIO_BASE + GPDCON_OFFSET) -#define GPDDAT (ELFIN_GPIO_BASE + GPDDAT_OFFSET) -#define GPDPUD (ELFIN_GPIO_BASE + GPDPUD_OFFSET) -#define GPDCONSLP (ELFIN_GPIO_BASE + GPDCONSLP_OFFSET) -#define GPDPUDSLP (ELFIN_GPIO_BASE + GPDPUDSLP_OFFSET) -#define GPECON (ELFIN_GPIO_BASE + GPECON_OFFSET) -#define GPEDAT (ELFIN_GPIO_BASE + GPEDAT_OFFSET) -#define GPEPUD (ELFIN_GPIO_BASE + GPEPUD_OFFSET) -#define GPECONSLP (ELFIN_GPIO_BASE + GPECONSLP_OFFSET) -#define GPEPUDSLP (ELFIN_GPIO_BASE + GPEPUDSLP_OFFSET) -#define GPFCON (ELFIN_GPIO_BASE + GPFCON_OFFSET) -#define GPFDAT (ELFIN_GPIO_BASE + GPFDAT_OFFSET) -#define GPFPUD (ELFIN_GPIO_BASE + GPFPUD_OFFSET) -#define GPFCONSLP (ELFIN_GPIO_BASE + GPFCONSLP_OFFSET) -#define GPFPUDSLP (ELFIN_GPIO_BASE + GPFPUDSLP_OFFSET) -#define GPGCON (ELFIN_GPIO_BASE + GPGCON_OFFSET) -#define GPGDAT (ELFIN_GPIO_BASE + GPGDAT_OFFSET) -#define GPGPUD (ELFIN_GPIO_BASE + GPGPUD_OFFSET) -#define GPGCONSLP (ELFIN_GPIO_BASE + GPGCONSLP_OFFSET) -#define GPGPUDSLP (ELFIN_GPIO_BASE + GPGPUDSLP_OFFSET) -#define GPHCON0 (ELFIN_GPIO_BASE + GPHCON0_OFFSET) -#define GPHCON1 (ELFIN_GPIO_BASE + GPHCON1_OFFSET) -#define GPHDAT (ELFIN_GPIO_BASE + GPHDAT_OFFSET) -#define GPHPUD (ELFIN_GPIO_BASE + GPHPUD_OFFSET) -#define GPHCONSLP (ELFIN_GPIO_BASE + GPHCONSLP_OFFSET) -#define GPHPUDSLP (ELFIN_GPIO_BASE + GPHPUDSLP_OFFSET) -#define GPICON (ELFIN_GPIO_BASE + GPICON_OFFSET) -#define GPIDAT (ELFIN_GPIO_BASE + GPIDAT_OFFSET) -#define GPIPUD (ELFIN_GPIO_BASE + GPIPUD_OFFSET) -#define GPICONSLP (ELFIN_GPIO_BASE + GPICONSLP_OFFSET) -#define GPIPUDSLP (ELFIN_GPIO_BASE + GPIPUDSLP_OFFSET) -#define GPJCON (ELFIN_GPIO_BASE + GPJCON_OFFSET) -#define GPJDAT (ELFIN_GPIO_BASE + GPJDAT_OFFSET) -#define GPJPUD (ELFIN_GPIO_BASE + GPJPUD_OFFSET) -#define GPJCONSLP (ELFIN_GPIO_BASE + GPJCONSLP_OFFSET) -#define GPJPUDSLP (ELFIN_GPIO_BASE + GPJPUDSLP_OFFSET) -#define GPKCON0 (ELFIN_GPIO_BASE + GPKCON0_OFFSET) -#define GPKCON1 (ELFIN_GPIO_BASE + GPKCON1_OFFSET) -#define GPKDAT (ELFIN_GPIO_BASE + GPKDAT_OFFSET) -#define GPKPUD (ELFIN_GPIO_BASE + GPKPUD_OFFSET) -#define GPLCON0 (ELFIN_GPIO_BASE + GPLCON0_OFFSET) -#define GPLCON1 (ELFIN_GPIO_BASE + GPLCON1_OFFSET) -#define GPLDAT (ELFIN_GPIO_BASE + GPLDAT_OFFSET) -#define GPLPUD (ELFIN_GPIO_BASE + GPLPUD_OFFSET) -#define GPMCON (ELFIN_GPIO_BASE + GPMCON_OFFSET) -#define GPMDAT (ELFIN_GPIO_BASE + GPMDAT_OFFSET) -#define GPMPUD (ELFIN_GPIO_BASE + GPMPUD_OFFSET) -#define GPNCON (ELFIN_GPIO_BASE + GPNCON_OFFSET) -#define GPNDAT (ELFIN_GPIO_BASE + GPNDAT_OFFSET) -#define GPNPUD (ELFIN_GPIO_BASE + GPNPUD_OFFSET) -#define GPOCON (ELFIN_GPIO_BASE + GPOCON_OFFSET) -#define GPODAT (ELFIN_GPIO_BASE + GPODAT_OFFSET) -#define GPOPUD (ELFIN_GPIO_BASE + GPOPUD_OFFSET) -#define GPOCONSLP (ELFIN_GPIO_BASE + GPOCONSLP_OFFSET) -#define GPOPUDSLP (ELFIN_GPIO_BASE + GPOPUDSLP_OFFSET) -#define GPPCON (ELFIN_GPIO_BASE + GPPCON_OFFSET) -#define GPPDAT (ELFIN_GPIO_BASE + GPPDAT_OFFSET) -#define GPPPUD (ELFIN_GPIO_BASE + GPPPUD_OFFSET) -#define GPPCONSLP (ELFIN_GPIO_BASE + GPPCONSLP_OFFSET) -#define GPPPUDSLP (ELFIN_GPIO_BASE + GPPPUDSLP_OFFSET) -#define GPQCON (ELFIN_GPIO_BASE + GPQCON_OFFSET) -#define GPQDAT (ELFIN_GPIO_BASE + GPQDAT_OFFSET) -#define GPQPUD (ELFIN_GPIO_BASE + GPQPUD_OFFSET) -#define GPQCONSLP (ELFIN_GPIO_BASE + GPQCONSLP_OFFSET) -#define GPQPUDSLP (ELFIN_GPIO_BASE + GPQPUDSLP_OFFSET) - -/* - * Memory controller - */ -#define ELFIN_SROM_BASE 0x70000000 - -#define SROM_BW_REG __REG(ELFIN_SROM_BASE + 0x0) -#define SROM_BC0_REG __REG(ELFIN_SROM_BASE + 0x4) -#define SROM_BC1_REG __REG(ELFIN_SROM_BASE + 0x8) -#define SROM_BC2_REG __REG(ELFIN_SROM_BASE + 0xC) -#define SROM_BC3_REG __REG(ELFIN_SROM_BASE + 0x10) -#define SROM_BC4_REG __REG(ELFIN_SROM_BASE + 0x14) -#define SROM_BC5_REG __REG(ELFIN_SROM_BASE + 0x18) - -/* - * SDRAM Controller - */ -#define ELFIN_DMC0_BASE 0x7e000000 -#define ELFIN_DMC1_BASE 0x7e001000 - -#define INDEX_DMC_MEMC_STATUS 0x00 -#define INDEX_DMC_MEMC_CMD 0x04 -#define INDEX_DMC_DIRECT_CMD 0x08 -#define INDEX_DMC_MEMORY_CFG 0x0C -#define INDEX_DMC_REFRESH_PRD 0x10 -#define INDEX_DMC_CAS_LATENCY 0x14 -#define INDEX_DMC_T_DQSS 0x18 -#define INDEX_DMC_T_MRD 0x1C -#define INDEX_DMC_T_RAS 0x20 -#define INDEX_DMC_T_RC 0x24 -#define INDEX_DMC_T_RCD 0x28 -#define INDEX_DMC_T_RFC 0x2C -#define INDEX_DMC_T_RP 0x30 -#define INDEX_DMC_T_RRD 0x34 -#define INDEX_DMC_T_WR 0x38 -#define INDEX_DMC_T_WTR 0x3C -#define INDEX_DMC_T_XP 0x40 -#define INDEX_DMC_T_XSR 0x44 -#define INDEX_DMC_T_ESR 0x48 -#define INDEX_DMC_MEMORY_CFG2 0x4C -#define INDEX_DMC_CHIP_0_CFG 0x200 -#define INDEX_DMC_CHIP_1_CFG 0x204 -#define INDEX_DMC_CHIP_2_CFG 0x208 -#define INDEX_DMC_CHIP_3_CFG 0x20C -#define INDEX_DMC_USER_STATUS 0x300 -#define INDEX_DMC_USER_CONFIG 0x304 - -/* - * Memory Chip direct command - */ -#define DMC_NOP0 0x0c0000 -#define DMC_NOP1 0x1c0000 -#define DMC_PA0 0x000000 /* Precharge all */ -#define DMC_PA1 0x100000 -#define DMC_AR0 0x040000 /* Autorefresh */ -#define DMC_AR1 0x140000 -#define DMC_SDR_MR0 0x080032 /* MRS, CAS 3, Burst Length 4 */ -#define DMC_SDR_MR1 0x180032 -#define DMC_DDR_MR0 0x080162 -#define DMC_DDR_MR1 0x180162 -#define DMC_mDDR_MR0 0x080032 /* CAS 3, Burst Length 4 */ -#define DMC_mDDR_MR1 0x180032 -#define DMC_mSDR_EMR0 0x0a0000 /* EMRS, DS:Full, PASR:Full Array */ -#define DMC_mSDR_EMR1 0x1a0000 -#define DMC_DDR_EMR0 0x090000 -#define DMC_DDR_EMR1 0x190000 -#define DMC_mDDR_EMR0 0x0a0000 /* DS:Full, PASR:Full Array */ -#define DMC_mDDR_EMR1 0x1a0000 - -/* - * Definitions for memory configuration - * Set memory configuration - * active_chips = 1'b0 (1 chip) - * qos_master_chip = 3'b000(ARID[3:0]) - * memory burst = 3'b010(burst 4) - * stop_mem_clock = 1'b0(disable dynamical stop) - * auto_power_down = 1'b0(disable auto power-down mode) - * power_down_prd = 6'b00_0000(0 cycle for auto power-down) - * ap_bit = 1'b0 (bit position of auto-precharge is 10) - * row_bits = 3'b010(# row address 13) - * column_bits = 3'b010(# column address 10 ) - * - * Set user configuration - * 2'b10=SDRAM/mSDRAM, 2'b11=DDR, 2'b01=mDDR - * - * Set chip select for chip [n] - * row bank control, bank address 0x3000_0000 ~ 0x37ff_ffff - * CHIP_[n]_CFG=0x30F8, 30: ADDR[31:24], F8: Mask[31:24] - */ - -/* - * Nand flash controller - */ -#define ELFIN_NAND_BASE 0x70200000 - -#define NFCONF_OFFSET 0x00 -#define NFCONT_OFFSET 0x04 -#define NFCMMD_OFFSET 0x08 -#define NFADDR_OFFSET 0x0c -#define NFDATA_OFFSET 0x10 -#define NFMECCDATA0_OFFSET 0x14 -#define NFMECCDATA1_OFFSET 0x18 -#define NFSECCDATA0_OFFSET 0x1c -#define NFSBLK_OFFSET 0x20 -#define NFEBLK_OFFSET 0x24 -#define NFSTAT_OFFSET 0x28 -#define NFESTAT0_OFFSET 0x2c -#define NFESTAT1_OFFSET 0x30 -#define NFMECC0_OFFSET 0x34 -#define NFMECC1_OFFSET 0x38 -#define NFSECC_OFFSET 0x3c -#define NFMLCBITPT_OFFSET 0x40 - -#define NFCONF (ELFIN_NAND_BASE + NFCONF_OFFSET) -#define NFCONT (ELFIN_NAND_BASE + NFCONT_OFFSET) -#define NFCMMD (ELFIN_NAND_BASE + NFCMMD_OFFSET) -#define NFADDR (ELFIN_NAND_BASE + NFADDR_OFFSET) -#define NFDATA (ELFIN_NAND_BASE + NFDATA_OFFSET) -#define NFMECCDATA0 (ELFIN_NAND_BASE + NFMECCDATA0_OFFSET) -#define NFMECCDATA1 (ELFIN_NAND_BASE + NFMECCDATA1_OFFSET) -#define NFSECCDATA0 (ELFIN_NAND_BASE + NFSECCDATA0_OFFSET) -#define NFSBLK (ELFIN_NAND_BASE + NFSBLK_OFFSET) -#define NFEBLK (ELFIN_NAND_BASE + NFEBLK_OFFSET) -#define NFSTAT (ELFIN_NAND_BASE + NFSTAT_OFFSET) -#define NFESTAT0 (ELFIN_NAND_BASE + NFESTAT0_OFFSET) -#define NFESTAT1 (ELFIN_NAND_BASE + NFESTAT1_OFFSET) -#define NFMECC0 (ELFIN_NAND_BASE + NFMECC0_OFFSET) -#define NFMECC1 (ELFIN_NAND_BASE + NFMECC1_OFFSET) -#define NFSECC (ELFIN_NAND_BASE + NFSECC_OFFSET) -#define NFMLCBITPT (ELFIN_NAND_BASE + NFMLCBITPT_OFFSET) - -#define NFCONF_REG __REG(ELFIN_NAND_BASE + NFCONF_OFFSET) -#define NFCONT_REG __REG(ELFIN_NAND_BASE + NFCONT_OFFSET) -#define NFCMD_REG __REG(ELFIN_NAND_BASE + NFCMMD_OFFSET) -#define NFADDR_REG __REG(ELFIN_NAND_BASE + NFADDR_OFFSET) -#define NFDATA_REG __REG(ELFIN_NAND_BASE + NFDATA_OFFSET) -#define NFDATA8_REG __REGb(ELFIN_NAND_BASE + NFDATA_OFFSET) -#define NFMECCDATA0_REG __REG(ELFIN_NAND_BASE + NFMECCDATA0_OFFSET) -#define NFMECCDATA1_REG __REG(ELFIN_NAND_BASE + NFMECCDATA1_OFFSET) -#define NFSECCDATA0_REG __REG(ELFIN_NAND_BASE + NFSECCDATA0_OFFSET) -#define NFSBLK_REG __REG(ELFIN_NAND_BASE + NFSBLK_OFFSET) -#define NFEBLK_REG __REG(ELFIN_NAND_BASE + NFEBLK_OFFSET) -#define NFSTAT_REG __REG(ELFIN_NAND_BASE + NFSTAT_OFFSET) -#define NFESTAT0_REG __REG(ELFIN_NAND_BASE + NFESTAT0_OFFSET) -#define NFESTAT1_REG __REG(ELFIN_NAND_BASE + NFESTAT1_OFFSET) -#define NFMECC0_REG __REG(ELFIN_NAND_BASE + NFMECC0_OFFSET) -#define NFMECC1_REG __REG(ELFIN_NAND_BASE + NFMECC1_OFFSET) -#define NFSECC_REG __REG(ELFIN_NAND_BASE + NFSECC_OFFSET) -#define NFMLCBITPT_REG __REG(ELFIN_NAND_BASE + NFMLCBITPT_OFFSET) - -#define NFCONF_ECC_4BIT (1<<24) - -#define NFCONT_ECC_ENC (1<<18) -#define NFCONT_WP (1<<16) -#define NFCONT_MECCLOCK (1<<7) -#define NFCONT_SECCLOCK (1<<6) -#define NFCONT_INITMECC (1<<5) -#define NFCONT_INITSECC (1<<4) -#define NFCONT_INITECC (NFCONT_INITMECC | NFCONT_INITSECC) -#define NFCONT_CS_ALT (1<<2) -#define NFCONT_CS (1<<1) -#define NFCONT_ENABLE (1<<0) - -#define NFSTAT_ECCENCDONE (1<<7) -#define NFSTAT_ECCDECDONE (1<<6) -#define NFSTAT_RnB (1<<0) - -#define NFESTAT0_ECCBUSY (1<<31) - -/* - * Interrupt - */ -#define ELFIN_VIC0_BASE_ADDR 0x71200000 -#define ELFIN_VIC1_BASE_ADDR 0x71300000 -#define oINTMOD 0x0C /* VIC INT SELECT (IRQ or FIQ) */ -#define oINTUNMSK 0x10 /* VIC INT EN (write 1 to unmask) */ -#define oINTMSK 0x14 /* VIC INT EN CLEAR (write 1 to mask) */ -#define oINTSUBMSK 0x1C /* VIC SOFT INT CLEAR */ -#define oVECTADDR 0xF00 /* VIC ADDRESS */ - -/* - * Watchdog timer - */ -#define ELFIN_WATCHDOG_BASE 0x7E004000 - -#define WTCON_REG __REG(0x7E004004) -#define WTDAT_REG __REG(0x7E004008) -#define WTCNT_REG __REG(0x7E00400C) - - -/* - * UART - */ -#define ELFIN_UART_BASE 0x7F005000 - -#define ELFIN_UART0_OFFSET 0x0000 -#define ELFIN_UART1_OFFSET 0x0400 -#define ELFIN_UART2_OFFSET 0x0800 - -#define ULCON_OFFSET 0x00 -#define UCON_OFFSET 0x04 -#define UFCON_OFFSET 0x08 -#define UMCON_OFFSET 0x0C -#define UTRSTAT_OFFSET 0x10 -#define UERSTAT_OFFSET 0x14 -#define UFSTAT_OFFSET 0x18 -#define UMSTAT_OFFSET 0x1C -#define UTXH_OFFSET 0x20 -#define URXH_OFFSET 0x24 -#define UBRDIV_OFFSET 0x28 -#define UDIVSLOT_OFFSET 0x2C -#define UINTP_OFFSET 0x30 -#define UINTSP_OFFSET 0x34 -#define UINTM_OFFSET 0x38 - -#define ULCON0_REG __REG(0x7F005000) -#define UCON0_REG __REG(0x7F005004) -#define UFCON0_REG __REG(0x7F005008) -#define UMCON0_REG __REG(0x7F00500C) -#define UTRSTAT0_REG __REG(0x7F005010) -#define UERSTAT0_REG __REG(0x7F005014) -#define UFSTAT0_REG __REG(0x7F005018) -#define UMSTAT0_REG __REG(0x7F00501c) -#define UTXH0_REG __REG(0x7F005020) -#define URXH0_REG __REG(0x7F005024) -#define UBRDIV0_REG __REG(0x7F005028) -#define UDIVSLOT0_REG __REG(0x7F00502c) -#define UINTP0_REG __REG(0x7F005030) -#define UINTSP0_REG __REG(0x7F005034) -#define UINTM0_REG __REG(0x7F005038) - -#define ULCON1_REG __REG(0x7F005400) -#define UCON1_REG __REG(0x7F005404) -#define UFCON1_REG __REG(0x7F005408) -#define UMCON1_REG __REG(0x7F00540C) -#define UTRSTAT1_REG __REG(0x7F005410) -#define UERSTAT1_REG __REG(0x7F005414) -#define UFSTAT1_REG __REG(0x7F005418) -#define UMSTAT1_REG __REG(0x7F00541c) -#define UTXH1_REG __REG(0x7F005420) -#define URXH1_REG __REG(0x7F005424) -#define UBRDIV1_REG __REG(0x7F005428) -#define UDIVSLOT1_REG __REG(0x7F00542c) -#define UINTP1_REG __REG(0x7F005430) -#define UINTSP1_REG __REG(0x7F005434) -#define UINTM1_REG __REG(0x7F005438) - -#define UTRSTAT_TX_EMPTY (1 << 2) -#define UTRSTAT_RX_READY (1 << 0) -#define UART_ERR_MASK 0xF - -/* - * PWM timer - */ -#define ELFIN_TIMER_BASE 0x7F006000 - -#define TCFG0_REG __REG(0x7F006000) -#define TCFG1_REG __REG(0x7F006004) -#define TCON_REG __REG(0x7F006008) -#define TCNTB0_REG __REG(0x7F00600c) -#define TCMPB0_REG __REG(0x7F006010) -#define TCNTO0_REG __REG(0x7F006014) -#define TCNTB1_REG __REG(0x7F006018) -#define TCMPB1_REG __REG(0x7F00601c) -#define TCNTO1_REG __REG(0x7F006020) -#define TCNTB2_REG __REG(0x7F006024) -#define TCMPB2_REG __REG(0x7F006028) -#define TCNTO2_REG __REG(0x7F00602c) -#define TCNTB3_REG __REG(0x7F006030) -#define TCMPB3_REG __REG(0x7F006034) -#define TCNTO3_REG __REG(0x7F006038) -#define TCNTB4_REG __REG(0x7F00603c) -#define TCNTO4_REG __REG(0x7F006040) - -/* Fields */ -#define fTCFG0_DZONE Fld(8, 16) /* the dead zone length (=timer 0) */ -#define fTCFG0_PRE1 Fld(8, 8) /* prescaler value for time 2,3,4 */ -#define fTCFG0_PRE0 Fld(8, 0) /* prescaler value for time 0,1 */ -#define fTCFG1_MUX4 Fld(4, 16) -/* bits */ -#define TCFG0_DZONE(x) FInsrt((x), fTCFG0_DZONE) -#define TCFG0_PRE1(x) FInsrt((x), fTCFG0_PRE1) -#define TCFG0_PRE0(x) FInsrt((x), fTCFG0_PRE0) -#define TCON_4_AUTO (1 << 22) /* auto reload on/off for Timer 4 */ -#define TCON_4_UPDATE (1 << 21) /* manual Update TCNTB4 */ -#define TCON_4_ONOFF (1 << 20) /* 0: Stop, 1: start Timer 4 */ -#define COUNT_4_ON (TCON_4_ONOFF * 1) -#define COUNT_4_OFF (TCON_4_ONOFF * 0) -#define TCON_3_AUTO (1 << 19) /* auto reload on/off for Timer 3 */ -#define TIMER3_ATLOAD_ON (TCON_3_AUTO * 1) -#define TIMER3_ATLAOD_OFF FClrBit(TCON, TCON_3_AUTO) -#define TCON_3_INVERT (1 << 18) /* 1: Inverter on for TOUT3 */ -#define TIMER3_IVT_ON (TCON_3_INVERT * 1) -#define TIMER3_IVT_OFF (FClrBit(TCON, TCON_3_INVERT)) -#define TCON_3_MAN (1 << 17) /* manual Update TCNTB3,TCMPB3 */ -#define TIMER3_MANUP (TCON_3_MAN*1) -#define TIMER3_NOP (FClrBit(TCON, TCON_3_MAN)) -#define TCON_3_ONOFF (1 << 16) /* 0: Stop, 1: start Timer 3 */ -#define TIMER3_ON (TCON_3_ONOFF * 1) -#define TIMER3_OFF (FClrBit(TCON, TCON_3_ONOFF)) - -#if defined(CONFIG_CLK_400_100_50) -#define STARTUP_AMDIV 400 -#define STARTUP_MDIV 400 -#define STARTUP_PDIV 6 -#define STARTUP_SDIV 1 -#elif defined(CONFIG_CLK_400_133_66) -#define STARTUP_AMDIV 400 -#define STARTUP_MDIV 533 -#define STARTUP_PDIV 6 -#define STARTUP_SDIV 1 -#elif defined(CONFIG_CLK_533_133_66) -#define STARTUP_AMDIV 533 -#define STARTUP_MDIV 533 -#define STARTUP_PDIV 6 -#define STARTUP_SDIV 1 -#elif defined(CONFIG_CLK_667_133_66) -#define STARTUP_AMDIV 667 -#define STARTUP_MDIV 533 -#define STARTUP_PDIV 6 -#define STARTUP_SDIV 1 -#endif - -#define STARTUP_PCLKDIV 3 -#define STARTUP_HCLKX2DIV 1 -#define STARTUP_HCLKDIV 1 -#define STARTUP_MPLLDIV 1 -#define STARTUP_APLLDIV 0 - -#define CLK_DIV_VAL ((STARTUP_PCLKDIV << 12) | (STARTUP_HCLKX2DIV << 9) | \ - (STARTUP_HCLKDIV << 8) | (STARTUP_MPLLDIV<<4) | STARTUP_APLLDIV) -#define MPLL_VAL ((1 << 31) | (STARTUP_MDIV << 16) | \ - (STARTUP_PDIV << 8) | STARTUP_SDIV) -#define STARTUP_MPLL (((CONFIG_SYS_CLK_FREQ >> STARTUP_SDIV) / \ - STARTUP_PDIV) * STARTUP_MDIV) - -#if defined(CONFIG_SYNC_MODE) -#define APLL_VAL ((1 << 31) | (STARTUP_MDIV << 16) | \ - (STARTUP_PDIV << 8) | STARTUP_SDIV) -#define STARTUP_APLL (((CONFIG_SYS_CLK_FREQ >> STARTUP_SDIV) / \ - STARTUP_PDIV) * STARTUP_MDIV) -#define STARTUP_HCLK (STARTUP_MPLL / (STARTUP_HCLKX2DIV + 1) / \ - (STARTUP_HCLKDIV + 1)) -#else -#define APLL_VAL ((1 << 31) | (STARTUP_AMDIV << 16) | \ - (STARTUP_PDIV << 8) | STARTUP_SDIV) -#define STARTUP_APLL (((CONFIG_SYS_CLK_FREQ >> STARTUP_SDIV) / \ - STARTUP_PDIV) * STARTUP_AMDIV) -#define STARTUP_HCLK (STARTUP_MPLL / (STARTUP_HCLKX2DIV + 1) / \ - (STARTUP_HCLKDIV + 1)) -#endif - - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define DMC1_MEM_CFG 0x00010012 /* burst 4, 13-bit row, 10-bit col */ -#define DMC1_MEM_CFG2 0xB45 -#define DMC1_CHIP0_CFG 0x150F8 /* 0x5000_0000~0x57ff_ffff (128 MiB) */ -#define DMC_DDR_32_CFG 0x0 /* 32bit, DDR */ - -/* Memory Parameters */ -/* DDR Parameters */ -#define DDR_tREFRESH 7800 /* ns */ -#define DDR_tRAS 45 /* ns (min: 45ns)*/ -#define DDR_tRC 68 /* ns (min: 67.5ns)*/ -#define DDR_tRCD 23 /* ns (min: 22.5ns)*/ -#define DDR_tRFC 80 /* ns (min: 80ns)*/ -#define DDR_tRP 23 /* ns (min: 22.5ns)*/ -#define DDR_tRRD 15 /* ns (min: 15ns)*/ -#define DDR_tWR 15 /* ns (min: 15ns)*/ -#define DDR_tXSR 120 /* ns (min: 120ns)*/ -#define DDR_CASL 3 /* CAS Latency 3 */ - -/* - * mDDR memory configuration - */ - -#define NS_TO_CLK(t) ((STARTUP_HCLK / 1000 * (t) - 1) / 1000000) - -#define DMC_DDR_BA_EMRS 2 -#define DMC_DDR_MEM_CASLAT 3 -/* 6 Set Cas Latency to 3 */ -#define DMC_DDR_CAS_LATENCY (DDR_CASL << 1) -/* Min 0.75 ~ 1.25 */ -#define DMC_DDR_t_DQSS 1 -/* Min 2 tck */ -#define DMC_DDR_t_MRD 2 -/* 7, Min 45ns */ -#define DMC_DDR_t_RAS (NS_TO_CLK(DDR_tRAS) + 1) -/* 10, Min 67.5ns */ -#define DMC_DDR_t_RC (NS_TO_CLK(DDR_tRC) + 1) -/* 4,5(TRM), Min 22.5ns */ -#define DMC_DDR_t_RCD (NS_TO_CLK(DDR_tRCD) + 1) -#define DMC_DDR_schedule_RCD ((DMC_DDR_t_RCD - 3) << 3) -/* 11,18(TRM) Min 80ns */ -#define DMC_DDR_t_RFC (NS_TO_CLK(DDR_tRFC) + 1) -#define DMC_DDR_schedule_RFC ((DMC_DDR_t_RFC - 3) << 5) -/* 4, 5(TRM) Min 22.5ns */ -#define DMC_DDR_t_RP (NS_TO_CLK(DDR_tRP) + 1) -#define DMC_DDR_schedule_RP ((DMC_DDR_t_RP - 3) << 3) -/* 3, Min 15ns */ -#define DMC_DDR_t_RRD (NS_TO_CLK(DDR_tRRD) + 1) -/* Min 15ns */ -#define DMC_DDR_t_WR (NS_TO_CLK(DDR_tWR) + 1) -#define DMC_DDR_t_WTR 2 -/* 1tck + tIS(1.5ns) */ -#define DMC_DDR_t_XP 2 -/* 17, Min 120ns */ -#define DMC_DDR_t_XSR (NS_TO_CLK(DDR_tXSR) + 1) -#define DMC_DDR_t_ESR DMC_DDR_t_XSR -/* TRM 2656 */ -#define DMC_DDR_REFRESH_PRD (NS_TO_CLK(DDR_tREFRESH)) -/* 2b01 : mDDR */ -#define DMC_DDR_USER_CONFIG 1 - -#ifndef __ASSEMBLY__ -enum s3c64xx_uarts_nr { - S3C64XX_UART0, - S3C64XX_UART1, - S3C64XX_UART2, -}; - -#include "s3c64x0.h" - -static inline s3c64xx_uart *s3c64xx_get_base_uart(enum s3c64xx_uarts_nr nr) -{ - return (s3c64xx_uart *)(ELFIN_UART_BASE + (nr * 0x400)); -} -#endif - -#endif /*__S3C6400_H__*/ diff --git a/arch/arm/include/asm/arch-s3c64xx/s3c64x0.h b/arch/arm/include/asm/arch-s3c64xx/s3c64x0.h deleted file mode 100644 index 0bbf1d0..0000000 --- a/arch/arm/include/asm/arch-s3c64xx/s3c64x0.h +++ /dev/null @@ -1,90 +0,0 @@ -/* - * (C) Copyright 2003 - * David MÃŒller ELSOFT AG Switzerland. d.mueller@elsoft.ch - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/************************************************ - * NAME : S3C64XX.h - * Version : 31.3.2003 - * - * common stuff for SAMSUNG S3C64XX SoC - ************************************************/ - -#ifndef __S3C64XX_H__ -#define __S3C64XX_H__ - -#if defined(CONFIG_SYNC_MODE) && defined(CONFIG_S3C6400) -#error CONFIG_SYNC_MODE unavailable on S3C6400, please, fix your configuration! -#endif - -#include <asm/types.h> - -/* UART (see manual chapter 11) */ -typedef struct { - volatile u32 ULCON; - volatile u32 UCON; - volatile u32 UFCON; - volatile u32 UMCON; - volatile u32 UTRSTAT; - volatile u32 UERSTAT; - volatile u32 UFSTAT; - volatile u32 UMSTAT; -#ifdef __BIG_ENDIAN - volatile u8 res1[3]; - volatile u8 UTXH; - volatile u8 res2[3]; - volatile u8 URXH; -#else /* Little Endian */ - volatile u8 UTXH; - volatile u8 res1[3]; - volatile u8 URXH; - volatile u8 res2[3]; -#endif - volatile u32 UBRDIV; -#ifdef __BIG_ENDIAN - volatile u8 res3[2]; - volatile u16 UDIVSLOT; -#else - volatile u16 UDIVSLOT; - volatile u8 res3[2]; -#endif -} s3c64xx_uart; - -/* PWM TIMER (see manual chapter 10) */ -typedef struct { - volatile u32 TCNTB; - volatile u32 TCMPB; - volatile u32 TCNTO; -} s3c64xx_timer; - -typedef struct { - volatile u32 TCFG0; - volatile u32 TCFG1; - volatile u32 TCON; - s3c64xx_timer ch[4]; - volatile u32 TCNTB4; - volatile u32 TCNTO4; -} s3c64xx_timers; - -#endif /*__S3C64XX_H__*/ diff --git a/doc/driver-model/UDM-serial.txt b/doc/driver-model/UDM-serial.txt index c6a8ab0..7e0ac55 100644 --- a/doc/driver-model/UDM-serial.txt +++ b/doc/driver-model/UDM-serial.txt @@ -96,88 +96,84 @@ III) Analysis of in-tree drivers ------------------ No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 10) s3c64xx.c + 10) sandbox.c ------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 11) sandbox.c - ------------- - No support for CONFIG_SERIAL_MULTI. Simple conversion possible. - - 12) serial.c + 11) serial.c ------------ This is a complementary part of NS16550 UART driver, see above.
- 13) serial_clps7111.c + 12) serial_clps7111.c --------------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 14) serial_imx.c + 13) serial_imx.c ---------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible. This driver might be removed in favor of serial_mxc.c .
- 15) serial_ixp.c + 14) serial_ixp.c ---------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 16) serial_ks8695.c + 15) serial_ks8695.c ------------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 17) serial_max3100.c + 16) serial_max3100.c -------------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 18) serial_mxc.c + 17) serial_mxc.c ---------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 19) serial_netarm.c + 18) serial_netarm.c ------------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 20) serial_pl01x.c + 19) serial_pl01x.c ------------------ No support for CONFIG_SERIAL_MULTI. Simple conversion possible, though this driver in fact contains two drivers in total.
- 21) serial_pxa.c + 20) serial_pxa.c ---------------- This driver is a bit complicated, but due to clean support for CONFIG_SERIAL_MULTI, there are no expected obstructions throughout the conversion process.
- 22) serial_s3c24x0.c + 21) serial_s3c24x0.c -------------------- This driver, being quite ad-hoc might need some work to bring back to shape.
- 23) serial_s3c44b0.c + 22) serial_s3c44b0.c -------------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 24) serial_s5p.c + 23) serial_s5p.c ---------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 25) serial_sa1100.c + 24) serial_sa1100.c ------------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 26) serial_sh.c + 25) serial_sh.c --------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 27) serial_xuartlite.c + 26) serial_xuartlite.c ---------------------- No support for CONFIG_SERIAL_MULTI. Simple conversion possible.
- 28) usbtty.c + 27) usbtty.c ------------ This driver seems very complicated and entangled with USB framework. The conversion might be complicated here.
- 29) arch/powerpc/cpu/mpc512x/serial.c + 28) arch/powerpc/cpu/mpc512x/serial.c ------------------------------------- This driver supports CONFIG_SERIAL_MULTI. This driver will need to be moved to proper place. diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index bcb7161..35769c5 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -73,7 +73,6 @@ COBJS-$(CONFIG_NAND_MXS) += mxs_nand.o COBJS-$(CONFIG_NAND_NDFC) += ndfc.o COBJS-$(CONFIG_NAND_NOMADIK) += nomadik.o COBJS-$(CONFIG_NAND_S3C2410) += s3c2410_nand.o -COBJS-$(CONFIG_NAND_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_NAND_SPEAR) += spr_nand.o COBJS-$(CONFIG_TEGRA_NAND) += tegra_nand.o COBJS-$(CONFIG_NAND_OMAP_GPMC) += omap_gpmc.o diff --git a/drivers/mtd/nand/s3c64xx.c b/drivers/mtd/nand/s3c64xx.c deleted file mode 100644 index 87f0341..0000000 --- a/drivers/mtd/nand/s3c64xx.c +++ /dev/null @@ -1,295 +0,0 @@ -/* - * (C) Copyright 2006 DENX Software Engineering - * - * Implementation for U-Boot 1.1.6 by Samsung - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> - -#include <nand.h> -#include <linux/mtd/nand.h> - -#include <asm/arch/s3c6400.h> - -#include <asm/io.h> -#include <asm/errno.h> - -#define MAX_CHIPS 2 -static int nand_cs[MAX_CHIPS] = {0, 1}; - -#ifdef CONFIG_NAND_SPL -#define printf(arg...) do {} while (0) -#endif - -/* Nand flash definition values by jsgood */ -#ifdef S3C_NAND_DEBUG -/* - * Function to print out oob buffer for debugging - * Written by jsgood - */ -static void print_oob(const char *header, struct mtd_info *mtd) -{ - int i; - struct nand_chip *chip = mtd->priv; - - printf("%s:\t", header); - - for (i = 0; i < 64; i++) - printf("%02x ", chip->oob_poi[i]); - - printf("\n"); -} -#endif /* S3C_NAND_DEBUG */ - -static void s3c_nand_select_chip(struct mtd_info *mtd, int chip) -{ - int ctrl = readl(NFCONT); - - switch (chip) { - case -1: - ctrl |= 6; - break; - case 0: - ctrl &= ~2; - break; - case 1: - ctrl &= ~4; - break; - default: - return; - } - - writel(ctrl, NFCONT); -} - -/* - * Hardware specific access to control-lines function - * Written by jsgood - */ -static void s3c_nand_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) -{ - struct nand_chip *this = mtd->priv; - - if (ctrl & NAND_CTRL_CHANGE) { - if (ctrl & NAND_CLE) - this->IO_ADDR_W = (void __iomem *)NFCMMD; - else if (ctrl & NAND_ALE) - this->IO_ADDR_W = (void __iomem *)NFADDR; - else - this->IO_ADDR_W = (void __iomem *)NFDATA; - if (ctrl & NAND_NCE) - s3c_nand_select_chip(mtd, *(int *)this->priv); - else - s3c_nand_select_chip(mtd, -1); - } - - if (cmd != NAND_CMD_NONE) - writeb(cmd, this->IO_ADDR_W); -} - -/* - * Function for checking device ready pin - * Written by jsgood - */ -static int s3c_nand_device_ready(struct mtd_info *mtdinfo) -{ - return !!(readl(NFSTAT) & NFSTAT_RnB); -} - -#ifdef CONFIG_SYS_S3C_NAND_HWECC -/* - * This function is called before encoding ecc codes to ready ecc engine. - * Written by jsgood - */ -static void s3c_nand_enable_hwecc(struct mtd_info *mtd, int mode) -{ - u_long nfcont, nfconf; - - /* - * The original driver used 4-bit ECC for "new" MLC chips, i.e., for - * those with non-zero ID[3][3:2], which anyway only holds for ST - * (Numonyx) chips - */ - nfconf = readl(NFCONF) & ~NFCONF_ECC_4BIT; - - writel(nfconf, NFCONF); - - /* Initialize & unlock */ - nfcont = readl(NFCONT); - nfcont |= NFCONT_INITECC; - nfcont &= ~NFCONT_MECCLOCK; - - if (mode == NAND_ECC_WRITE) - nfcont |= NFCONT_ECC_ENC; - else if (mode == NAND_ECC_READ) - nfcont &= ~NFCONT_ECC_ENC; - - writel(nfcont, NFCONT); -} - -/* - * This function is called immediately after encoding ecc codes. - * This function returns encoded ecc codes. - * Written by jsgood - */ -static int s3c_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat, - u_char *ecc_code) -{ - u_long nfcont, nfmecc0; - - /* Lock */ - nfcont = readl(NFCONT); - nfcont |= NFCONT_MECCLOCK; - writel(nfcont, NFCONT); - - nfmecc0 = readl(NFMECC0); - - ecc_code[0] = nfmecc0 & 0xff; - ecc_code[1] = (nfmecc0 >> 8) & 0xff; - ecc_code[2] = (nfmecc0 >> 16) & 0xff; - ecc_code[3] = (nfmecc0 >> 24) & 0xff; - - return 0; -} - -/* - * This function determines whether read data is good or not. - * If SLC, must write ecc codes to controller before reading status bit. - * If MLC, status bit is already set, so only reading is needed. - * If status bit is good, return 0. - * If correctable errors occured, do that. - * If uncorrectable errors occured, return -1. - * Written by jsgood - */ -static int s3c_nand_correct_data(struct mtd_info *mtd, u_char *dat, - u_char *read_ecc, u_char *calc_ecc) -{ - int ret = -1; - u_long nfestat0, nfmeccdata0, nfmeccdata1, err_byte_addr; - u_char err_type, repaired; - - /* SLC: Write ecc to compare */ - nfmeccdata0 = (calc_ecc[1] << 16) | calc_ecc[0]; - nfmeccdata1 = (calc_ecc[3] << 16) | calc_ecc[2]; - writel(nfmeccdata0, NFMECCDATA0); - writel(nfmeccdata1, NFMECCDATA1); - - /* Read ecc status */ - nfestat0 = readl(NFESTAT0); - err_type = nfestat0 & 0x3; - - switch (err_type) { - case 0: /* No error */ - ret = 0; - break; - - case 1: - /* - * 1 bit error (Correctable) - * (nfestat0 >> 7) & 0x7ff :error byte number - * (nfestat0 >> 4) & 0x7 :error bit number - */ - err_byte_addr = (nfestat0 >> 7) & 0x7ff; - repaired = dat[err_byte_addr] ^ (1 << ((nfestat0 >> 4) & 0x7)); - - printf("S3C NAND: 1 bit error detected at byte %ld. " - "Correcting from 0x%02x to 0x%02x...OK\n", - err_byte_addr, dat[err_byte_addr], repaired); - - dat[err_byte_addr] = repaired; - - ret = 1; - break; - - case 2: /* Multiple error */ - case 3: /* ECC area error */ - printf("S3C NAND: ECC uncorrectable error detected. " - "Not correctable.\n"); - ret = -1; - break; - } - - return ret; -} -#endif /* CONFIG_SYS_S3C_NAND_HWECC */ - -/* - * Board-specific NAND initialization. The following members of the - * argument are board-specific (per include/linux/mtd/nand.h): - * - IO_ADDR_R?: address to read the 8 I/O lines of the flash device - * - IO_ADDR_W?: address to write the 8 I/O lines of the flash device - * - hwcontrol: hardwarespecific function for accesing control-lines - * - dev_ready: hardwarespecific function for accesing device ready/busy line - * - enable_hwecc?: function to enable (reset) hardware ecc generator. Must - * only be provided if a hardware ECC is available - * - eccmode: mode of ecc, see defines - * - chip_delay: chip dependent delay for transfering data from array to - * read regs (tR) - * - options: various chip options. They can partly be set to inform - * nand_scan about special functionality. See the defines for further - * explanation - * Members with a "?" were not set in the merged testing-NAND branch, - * so they are not set here either. - */ -int board_nand_init(struct nand_chip *nand) -{ - static int chip_n; - - if (chip_n >= MAX_CHIPS) - return -ENODEV; - - NFCONT_REG = (NFCONT_REG & ~NFCONT_WP) | NFCONT_ENABLE | 0x6; - - nand->IO_ADDR_R = (void __iomem *)NFDATA; - nand->IO_ADDR_W = (void __iomem *)NFDATA; - nand->cmd_ctrl = s3c_nand_hwcontrol; - nand->dev_ready = s3c_nand_device_ready; - nand->select_chip = s3c_nand_select_chip; - nand->options = 0; -#ifdef CONFIG_NAND_SPL - nand->read_byte = nand_read_byte; - nand->write_buf = nand_write_buf; - nand->read_buf = nand_read_buf; -#endif - -#ifdef CONFIG_SYS_S3C_NAND_HWECC - nand->ecc.hwctl = s3c_nand_enable_hwecc; - nand->ecc.calculate = s3c_nand_calculate_ecc; - nand->ecc.correct = s3c_nand_correct_data; - - /* - * If you get more than 1 NAND-chip with different page-sizes on the - * board one day, it will get more complicated... - */ - nand->ecc.mode = NAND_ECC_HW; - nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE; - nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES; -#else - nand->ecc.mode = NAND_ECC_SOFT; -#endif /* ! CONFIG_SYS_S3C_NAND_HWECC */ - - nand->priv = nand_cs + chip_n++; - - return 0; -} diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 1a7b40e..858e322 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -632,10 +632,6 @@ static int onenand_check_bufferram(struct mtd_info *mtd, loff_t addr) int blockpage, found = 0; unsigned int i;
-#ifdef CONFIG_S3C64XX - return 0; -#endif - if (ONENAND_IS_2PLANE(this)) blockpage = onenand_get_2x_blockpage(mtd, addr); else diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c index 0d94ea5..5eb2b3a 100644 --- a/drivers/mtd/onenand/samsung.c +++ b/drivers/mtd/onenand/samsung.c @@ -1,5 +1,5 @@ /* - * S3C64XX/S5PC100 OneNAND driver at U-Boot + * S5PC100 OneNAND driver at U-Boot * * Copyright (C) 2008-2009 Samsung Electronics * Kyungmin Park kyungmin.park@samsung.com @@ -62,12 +62,7 @@ do { \ #define ONENAND_MAIN_SPARE_ACCESS 0x16 #define ONENAND_PIPELINE_READ 0x4000
-#if defined(CONFIG_S3C64XX) -#define MAP_00 (0x0 << 24) -#define MAP_01 (0x1 << 24) -#define MAP_10 (0x2 << 24) -#define MAP_11 (0x3 << 24) -#elif defined(CONFIG_S5P) +#if defined(CONFIG_S5P) #define MAP_00 (0x0 << 26) #define MAP_01 (0x1 << 26) #define MAP_10 (0x2 << 26) @@ -116,12 +111,7 @@ static void s3c_write_cmd(int value, unsigned int cmd) * return the buffer address on the memory device * It will be combined with CMD_MAP_XX */ -#if defined(CONFIG_S3C64XX) -static unsigned int s3c_mem_addr(int fba, int fpa, int fsa) -{ - return (fba << 12) | (fpa << 6) | (fsa << 4); -} -#elif defined(CONFIG_S5P) +#if defined(CONFIG_S5P) static unsigned int s3c_mem_addr(int fba, int fpa, int fsa) { return (fba << 13) | (fpa << 7) | (fsa << 5); @@ -550,45 +540,6 @@ static void s3c_onenand_unlock_all(struct mtd_info *mtd) s3c_onenand_check_lock_status(mtd); }
-#ifdef CONFIG_S3C64XX -static void s3c_set_width_regs(struct onenand_chip *this) -{ - int dev_id, density; - int fba, fpa, fsa; - int dbs_dfs; - - dev_id = DEVICE_ID0_REG; - - density = (dev_id >> ONENAND_DEVICE_DENSITY_SHIFT) & 0xf; - dbs_dfs = !!(dev_id & ONENAND_DEVICE_IS_DDP); - - fba = density + 7; - if (dbs_dfs) - fba--; /* Decrease the fba */ - fpa = 6; - if (density >= ONENAND_DEVICE_DENSITY_512Mb) - fsa = 2; - else - fsa = 1; - - DPRINTK("FBA %lu, FPA %lu, FSA %lu, DDP %lu", - FBA_WIDTH0_REG, FPA_WIDTH0_REG, FSA_WIDTH0_REG, - DDP_DEVICE_REG); - - DPRINTK("mem_cfg0 0x%lx, sync mode %lu, " - "dev_page_size %lu, BURST LEN %lu", - MEM_CFG0_REG, SYNC_MODE_REG, - DEV_PAGE_SIZE_REG, BURST_LEN0_REG); - - DEV_PAGE_SIZE_REG = 0x1; - - FBA_WIDTH0_REG = fba; - FPA_WIDTH0_REG = fpa; - FSA_WIDTH0_REG = fsa; - DBS_DFS_WIDTH0_REG = dbs_dfs; -} -#endif - int s5pc110_chip_probe(struct mtd_info *mtd) { return 0; @@ -620,10 +571,7 @@ void s3c_onenand_init(struct mtd_info *mtd)
onenand->mtd = mtd;
-#if defined(CONFIG_S3C64XX) - onenand->base = (void *)0x70100000; - onenand->ahb_addr = (void *)0x20000000; -#elif defined(CONFIG_S5P) +#if defined(CONFIG_S5P) onenand->base = (void *)0xE7100000; onenand->ahb_addr = (void *)0xB0000000; #endif diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 5e8b648..395ddc2 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -36,7 +36,6 @@ COBJS-$(CONFIG_MCFUART) += mcfuart.o COBJS-$(CONFIG_NS9750_UART) += ns9750_serial.o COBJS-$(CONFIG_OPENCORES_YANU) += opencores_yanu.o COBJS-$(CONFIG_SYS_NS16550) += ns16550.o -COBJS-$(CONFIG_S3C64XX) += s3c64xx.o COBJS-$(CONFIG_S5P) += serial_s5p.o COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial_ns16550.o COBJS-$(CONFIG_IMX_SERIAL) += serial_imx.o diff --git a/drivers/serial/s3c64xx.c b/drivers/serial/s3c64xx.c deleted file mode 100644 index b590992..0000000 --- a/drivers/serial/s3c64xx.c +++ /dev/null @@ -1,187 +0,0 @@ -/* - * (C) Copyright 2002 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * (C) Copyright 2008 - * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#include <common.h> -#include <linux/compiler.h> -#include <serial.h> -#include <asm/arch/s3c6400.h> - -DECLARE_GLOBAL_DATA_PTR; - -#ifdef CONFIG_SERIAL1 -#define UART_NR S3C64XX_UART0 - -#elif defined(CONFIG_SERIAL2) -#define UART_NR S3C64XX_UART1 - -#elif defined(CONFIG_SERIAL3) -#define UART_NR S3C64XX_UART2 - -#else -#error "Bad: you didn't configure serial ..." -#endif - -/* - * The coefficient, used to calculate the baudrate on S3C6400 UARTs is - * calculated as - * C = UBRDIV * 16 + number_of_set_bits_in_UDIVSLOT - * however, section 31.6.11 of the datasheet doesn't recomment using 1 for 1, - * 3 for 2, ... (2^n - 1) for n, instead, they suggest using these constants: - */ -static const int udivslot[] = { - 0, - 0x0080, - 0x0808, - 0x0888, - 0x2222, - 0x4924, - 0x4a52, - 0x54aa, - 0x5555, - 0xd555, - 0xd5d5, - 0xddd5, - 0xdddd, - 0xdfdd, - 0xdfdf, - 0xffdf, -}; - -static void s3c64xx_serial_setbrg(void) -{ - s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); - u32 pclk = get_PCLK(); - u32 baudrate = gd->baudrate; - int i; - - i = (pclk / baudrate) % 16; - - uart->UBRDIV = pclk / baudrate / 16 - 1; - uart->UDIVSLOT = udivslot[i]; - - for (i = 0; i < 100; i++) - barrier(); -} - -/* - * Initialise the serial port with the given baudrate. The settings - * are always 8 data bits, no parity, 1 stop bit, no start bits. - */ -static int s3c64xx_serial_init(void) -{ - s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); - - /* reset and enable FIFOs, set triggers to the maximum */ - uart->UFCON = 0xff; - uart->UMCON = 0; - /* 8N1 */ - uart->ULCON = 3; - /* No interrupts, no DMA, pure polling */ - uart->UCON = 5; - - serial_setbrg(); - - return 0; -} - -/* - * Read a single byte from the serial port. Returns 1 on success, 0 - * otherwise. When the function is succesfull, the character read is - * written into its argument c. - */ -static int s3c64xx_serial_getc(void) -{ - s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); - - /* wait for character to arrive */ - while (!(uart->UTRSTAT & 0x1)); - - return uart->URXH & 0xff; -} - -#ifdef CONFIG_MODEM_SUPPORT -static int be_quiet; -void disable_putc(void) -{ - be_quiet = 1; -} - -void enable_putc(void) -{ - be_quiet = 0; -} -#endif - - -/* - * Output a single byte to the serial port. - */ -static void s3c64xx_serial_putc(const char c) -{ - s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); - -#ifdef CONFIG_MODEM_SUPPORT - if (be_quiet) - return; -#endif - - /* wait for room in the tx FIFO */ - while (!(uart->UTRSTAT & 0x2)); - - uart->UTXH = c; - - /* If \n, also do \r */ - if (c == '\n') - serial_putc('\r'); -} - -/* - * Test whether a character is in the RX buffer - */ -static int s3c64xx_serial_tstc(void) -{ - s3c64xx_uart *const uart = s3c64xx_get_base_uart(UART_NR); - - return uart->UTRSTAT & 0x1; -} - -static struct serial_device s3c64xx_serial_drv = { - .name = "s3c64xx_serial", - .start = s3c64xx_serial_init, - .stop = NULL, - .setbrg = s3c64xx_serial_setbrg, - .putc = s3c64xx_serial_putc, - .puts = default_serial_puts, - .getc = s3c64xx_serial_getc, - .tstc = s3c64xx_serial_tstc, -}; - -void s3c64xx_serial_initialize(void) -{ - serial_register(&s3c64xx_serial_drv); -} - -__weak struct serial_device *default_serial_console(void) -{ - return &s3c64xx_serial_drv; -} diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index 1f8955a..f77a112 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -166,7 +166,6 @@ serial_initfunc(lpc32xx_serial_initialize); serial_initfunc(mcf_serial_initialize); serial_initfunc(ns9750_serial_initialize); serial_initfunc(oc_serial_initialize); -serial_initfunc(s3c64xx_serial_initialize); serial_initfunc(sandbox_serial_initialize); serial_initfunc(clps7111_serial_initialize); serial_initfunc(imx_serial_initialize); @@ -261,7 +260,6 @@ void serial_initialize(void) mcf_serial_initialize(); ns9750_serial_initialize(); oc_serial_initialize(); - s3c64xx_serial_initialize(); sandbox_serial_initialize(); clps7111_serial_initialize(); imx_serial_initialize(); diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 6c94794..9405736 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -31,7 +31,6 @@ COBJS-$(CONFIG_USB_ATMEL) += ohci-at91.o COBJS-$(CONFIG_USB_OHCI_DA8XX) += ohci-da8xx.o COBJS-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o COBJS-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o -COBJS-$(CONFIG_USB_S3C64XX) += s3c64xx-hcd.o COBJS-$(CONFIG_USB_SL811HS) += sl811-hcd.o COBJS-$(CONFIG_USB_OHCI_S3C24XX) += ohci-s3c24xx.o
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index bdbe250..bc17b85 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -66,7 +66,6 @@
#if defined(CONFIG_ARM920T) || \ defined(CONFIG_S3C24X0) || \ - defined(CONFIG_S3C6400) || \ defined(CONFIG_440EP) || \ defined(CONFIG_PCI_OHCI) || \ defined(CONFIG_MPC5200) || \ diff --git a/drivers/usb/host/s3c64xx-hcd.c b/drivers/usb/host/s3c64xx-hcd.c deleted file mode 100644 index cd295da..0000000 --- a/drivers/usb/host/s3c64xx-hcd.c +++ /dev/null @@ -1,45 +0,0 @@ -/* - * URB OHCI HCD (Host Controller Driver) initialization for USB on the S3C64XX. - * - * Copyright (C) 2008, - * Guennadi Liakhovetski, DENX Software Engineering lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - * - */ - -#include <common.h> -#include <asm/arch/s3c6400.h> - -int usb_cpu_init(void) -{ - OTHERS_REG |= 0x10000; - return 0; -} - -int usb_cpu_stop(void) -{ - OTHERS_REG &= ~0x10000; - return 0; -} - -void usb_cpu_init_fail(void) -{ - OTHERS_REG &= ~0x10000; -} diff --git a/include/common.h b/include/common.h index 3d643a6..eede07c 100644 --- a/include/common.h +++ b/include/common.h @@ -632,7 +632,6 @@ ulong get_PCI_freq (void); #endif #if defined(CONFIG_S3C24X0) || \ defined(CONFIG_LH7A40X) || \ - defined(CONFIG_S3C6400) || \ defined(CONFIG_EP93XX) ulong get_FCLK (void); ulong get_HCLK (void); diff --git a/include/onenand_uboot.h b/include/onenand_uboot.h index f321d8a..fd01040 100644 --- a/include/onenand_uboot.h +++ b/include/onenand_uboot.h @@ -48,10 +48,6 @@ extern int flexonenand_region(struct mtd_info *mtd, loff_t addr); extern int flexonenand_set_boundary(struct mtd_info *mtd, int die, int boundary, int lock);
-/* S3C64xx */ -extern void s3c64xx_onenand_init(struct mtd_info *); -extern void s3c64xx_set_width_regs(struct onenand_chip *); - /* SPL */ void onenand_spl_load_image(uint32_t offs, uint32_t size, void *dst);
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- Changes in v8: - New patch.
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
arch/arm/config.mk | 2 -- arch/arm/cpu/arm1176/start.S | 12 ++++-------- arch/arm/lib/crt0.S | 16 ++-------------- 3 files changed, 6 insertions(+), 24 deletions(-)
diff --git a/arch/arm/config.mk b/arch/arm/config.mk index 24b9d7c..83320cb 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -84,9 +84,7 @@ endif endif
# needed for relocation -ifndef CONFIG_NAND_SPL LDFLAGS_u-boot += -pie -endif
# # FIXME: binutils versions < 2.22 have a bug in the assembler where diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 97d347c..b3c686a 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -51,7 +51,7 @@
.globl _start _start: b reset -#ifndef CONFIG_NAND_SPL +#ifndef CONFIG_SPL_BUILD ldr pc, _undefined_instruction ldr pc, _software_interrupt ldr pc, _prefetch_abort @@ -98,15 +98,11 @@ _end_vect:
.globl _TEXT_BASE _TEXT_BASE: -#ifdef CONFIG_NAND_SPL /* deprecated, use instead CONFIG_SPL_BUILD */ - .word CONFIG_SYS_TEXT_BASE -#else #if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) .word CONFIG_SPL_TEXT_BASE #else .word CONFIG_SYS_TEXT_BASE #endif -#endif
/* * Below variable is very important because we use MMU in U-Boot. @@ -176,7 +172,7 @@ cpu_init_crit: * When booting from NAND - it has definitely been a reset, so, no need * to flush caches and disable the MMU */ -#ifndef CONFIG_NAND_SPL +#ifndef CONFIG_SPL_BUILD /* * flush v4 I/D caches */ @@ -361,7 +357,7 @@ c_runtime_cpu_setup:
mov pc, lr
-#ifndef CONFIG_NAND_SPL +#ifndef CONFIG_SPL_BUILD /* * we assume that cache operation is done before. (eg. cleanup_before_linux()) * actually, we don't need to do anything about cache if not use d-cache in @@ -539,4 +535,4 @@ fiq: get_bad_stack bad_save_user_regs bl do_fiq -#endif /* CONFIG_NAND_SPL */ +#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 7950469..6fcb7d1 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -64,7 +64,7 @@ * have some work left to do at this point regarding memory, so * call c_runtime_cpu_setup. * - * 6. Branch to either nand_boot() or board_init_r(). + * 6. Branch to board_init_r(). */
/* @@ -77,10 +77,7 @@ ENTRY(_main) * Set up initial C runtime environment and call board_init_f(0). */
-#if defined(CONFIG_NAND_SPL) - /* deprecated, use instead CONFIG_SPL_BUILD */ - ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) -#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) ldr sp, =(CONFIG_SPL_STACK) #else ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) @@ -129,21 +126,12 @@ clbss_l:cmp r0, r1 /* while not at end of BSS */ bl coloured_LED_init bl red_led_on
-#if defined(CONFIG_NAND_SPL) - - /* call _nand_boot() */ - ldr pc, =nand_boot - -#else - /* call board_init_r(gd_t *id, ulong dest_addr) */ mov r0, r8 /* gd_t */ ldr r1, [r8, #GD_RELOCADDR] /* dest_addr */ /* call board_init_r */ ldr pc, =board_init_r /* this is auto-relocated! */
-#endif - /* we should not return here. */
#endif
Following the removal of the smdk6400 board, the MMU setup code in arm1176/start.S becomes unused, so move it to scrapyard. It will still be possible to restore it later from the Git history if necessary, in which case it should be moved out from the relocate_code() function.
arch/arm/cpu/arm1176/start.S | 91 +----------------------------------------- 1 file changed, 1 insertion(+), 90 deletions(-)
diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index b3c686a..18ac8d5 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -33,11 +33,8 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> -#ifdef CONFIG_ENABLE_MMU -#include <asm/proc/domain.h> -#endif
-#if !defined(CONFIG_ENABLE_MMU) && !defined(CONFIG_SYS_PHY_UBOOT_BASE) +#ifndef CONFIG_SYS_PHY_UBOOT_BASE #define CONFIG_SYS_PHY_UBOOT_BASE CONFIG_SYS_UBOOT_BASE #endif
@@ -105,14 +102,6 @@ _TEXT_BASE: #endif
/* - * Below variable is very important because we use MMU in U-Boot. - * Without it, we cannot run code correctly before MMU is ON. - * by scsuh. - */ -_TEXT_PHY_BASE: - .word CONFIG_SYS_PHY_UBOOT_BASE - -/* * These are defined in the board-specific linker script. * Subtracting _start from them lets the linker put their * relative position in the executable instead of leaving @@ -298,44 +287,6 @@ fixnext: blo fixloop #endif
-#ifdef CONFIG_ENABLE_MMU -enable_mmu: - /* enable domain access */ - ldr r5, =0x0000ffff - mcr p15, 0, r5, c3, c0, 0 /* load domain access register */ - - /* Set the TTB register */ - ldr r0, _mmu_table_base - ldr r1, =CONFIG_SYS_PHY_UBOOT_BASE - ldr r2, =0xfff00000 - bic r0, r0, r2 - orr r1, r0, r1 - mcr p15, 0, r1, c2, c0, 0 - - /* Enable the MMU */ - mrc p15, 0, r0, c1, c0, 0 - orr r0, r0, #1 /* Set CR_M to enable MMU */ - - /* Prepare to enable the MMU */ - adr r1, skip_hw_init - and r1, r1, #0x3fc - ldr r2, _TEXT_BASE - ldr r3, =0xfff00000 - and r2, r2, r3 - orr r2, r2, r1 - b mmu_enable - - .align 5 - /* Run in a single cache-line */ -mmu_enable: - - mcr p15, 0, r0, c1, c0, 0 - nop - nop - mov pc, r2 -skip_hw_init: -#endif - relocate_done:
bx lr @@ -347,11 +298,6 @@ _rel_dyn_end_ofs: _dynsym_start_ofs: .word __dynsym_start - _start
-#ifdef CONFIG_ENABLE_MMU -_mmu_table_base: - .word mmu_table -#endif - .globl c_runtime_cpu_setup c_runtime_cpu_setup:
@@ -359,41 +305,6 @@ c_runtime_cpu_setup:
#ifndef CONFIG_SPL_BUILD /* - * we assume that cache operation is done before. (eg. cleanup_before_linux()) - * actually, we don't need to do anything about cache if not use d-cache in - * U-Boot. So, in this function we clean only MMU. by scsuh - * - * void theLastJump(void *kernel, int arch_num, uint boot_params); - */ -#ifdef CONFIG_ENABLE_MMU - .globl theLastJump -theLastJump: - mov r9, r0 - ldr r3, =0xfff00000 - ldr r4, _TEXT_PHY_BASE - adr r5, phy_last_jump - bic r5, r5, r3 - orr r5, r5, r4 - mov pc, r5 -phy_last_jump: - /* - * disable MMU stuff - */ - mrc p15, 0, r0, c1, c0, 0 - bic r0, r0, #0x00002300 /* clear bits 13, 9:8 (--V- --RS) */ - bic r0, r0, #0x00000087 /* clear bits 7, 2:0 (B--- -CAM) */ - orr r0, r0, #0x00000002 /* set bit 2 (A) Align */ - orr r0, r0, #0x00001000 /* set bit 12 (I) I-Cache */ - mcr p15, 0, r0, c1, c0, 0 - - mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */ - - mov r0, #0 - mov pc, r9 -#endif - - -/* ************************************************************************* * * Interrupt handling
Hi Benoît,
On Fri, 1 Mar 2013 13:10:38 +0100, Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
Avoid using "scrapyard" here, as 'scrapyard' is already being used for whole board support removal (see doc/README.scrapyard), and this patch is not about board support removal.
Amicalement,
Hi Albert,
On Friday, March 1, 2013 4:25:25 PM, Albert ARIBAUD wrote:
Hi Benoît,
OK, then I suppose that the same applies to 27/31.
I will reword in v9.
Best regards, Benoît
Let all ARM linker scripts handle properly -ffunction-sections and -fdata-sections. This will be useful for the following changes in order to create symbol-specific sections in the common crt0.S.
arch/arm/cpu/arm1136/u-boot-spl.lds | 2 +- arch/arm/cpu/arm920t/ep93xx/u-boot.lds | 10 +++++----- arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds | 6 +++--- arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds | 6 +++--- arch/arm/cpu/armv7/omap-common/u-boot-spl.lds | 2 +- arch/arm/cpu/armv7/socfpga/u-boot-spl.lds | 2 +- board/ait/cam_enc_4xx/u-boot-spl.lds | 2 +- board/davinci/da8xxevm/u-boot-spl-da850evm.lds | 2 +- board/davinci/da8xxevm/u-boot-spl-hawk.lds | 8 ++++---- board/freescale/mx31ads/u-boot.lds | 20 ++++++++++---------- board/samsung/smdk5250/smdk5250-uboot-spl.lds | 2 +- board/vpac270/u-boot-spl.lds | 4 ++-- 12 files changed, 33 insertions(+), 33 deletions(-)
diff --git a/arch/arm/cpu/arm1136/u-boot-spl.lds b/arch/arm/cpu/arm1136/u-boot-spl.lds index a0462ab..deae361 100644 --- a/arch/arm/cpu/arm1136/u-boot-spl.lds +++ b/arch/arm/cpu/arm1136/u-boot-spl.lds @@ -38,7 +38,7 @@ SECTIONS .text : { __start = .; - arch/arm/cpu/arm1136/start.o (.text) + arch/arm/cpu/arm1136/start.o (.text*) *(.text*) } >.sram
diff --git a/arch/arm/cpu/arm920t/ep93xx/u-boot.lds b/arch/arm/cpu/arm920t/ep93xx/u-boot.lds index 62315de..72912de 100644 --- a/arch/arm/cpu/arm920t/ep93xx/u-boot.lds +++ b/arch/arm/cpu/arm920t/ep93xx/u-boot.lds @@ -31,18 +31,18 @@ SECTIONS . = ALIGN(4); .text : { - arch/arm/cpu/arm920t/start.o (.text) + arch/arm/cpu/arm920t/start.o (.text*) /* the EP93xx expects to find the pattern 'CRUS' at 0x1000 */ . = 0x1000; LONG(0x53555243) - *(.text) + *(.text*) }
. = ALIGN(4); - .rodata : { *(.rodata) } + .rodata : { *(.rodata*) }
. = ALIGN(4); - .data : { *(.data) } + .data : { *(.data*) }
. = ALIGN(4); .got : { *(.got) } @@ -59,7 +59,7 @@ SECTIONS __image_copy_end = .;
__bss_start = .; - .bss : { *(.bss) } + .bss : { *(.bss*) } __bss_end__ = .;
_end = .; diff --git a/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds b/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds index 6dc681a..80693da 100644 --- a/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds +++ b/arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds @@ -37,8 +37,8 @@ SECTIONS . = ALIGN(4); .text : { - arch/arm/cpu/arm926ejs/mxs/start.o (.text) - *(.text) + arch/arm/cpu/arm926ejs/mxs/start.o (.text*) + *(.text*) }
. = ALIGN(4); @@ -46,7 +46,7 @@ SECTIONS
. = ALIGN(4); .data : { - *(.data) + *(.data*) }
. = ALIGN(4); diff --git a/arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds b/arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds index f3bd5e7..3146f79 100644 --- a/arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds +++ b/arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds @@ -37,8 +37,8 @@ SECTIONS . = ALIGN(4); .text : { - arch/arm/cpu/arm926ejs/spear/start.o (.text) - *(.text) + arch/arm/cpu/arm926ejs/spear/start.o (.text*) + *(.text*) }
. = ALIGN(4); diff --git a/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds b/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds index 9979c30..0b923f8 100644 --- a/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds +++ b/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds @@ -38,7 +38,7 @@ SECTIONS .text : { __start = .; - arch/arm/cpu/armv7/start.o (.text) + arch/arm/cpu/armv7/start.o (.text*) *(.text*) } >.sram
diff --git a/arch/arm/cpu/armv7/socfpga/u-boot-spl.lds b/arch/arm/cpu/armv7/socfpga/u-boot-spl.lds index 7cd409c..ff309b9 100644 --- a/arch/arm/cpu/armv7/socfpga/u-boot-spl.lds +++ b/arch/arm/cpu/armv7/socfpga/u-boot-spl.lds @@ -27,7 +27,7 @@ SECTIONS . = ALIGN(4); .text : { - arch/arm/cpu/armv7/start.o (.text) + arch/arm/cpu/armv7/start.o (.text*) *(.text*) } >.sdram
diff --git a/board/ait/cam_enc_4xx/u-boot-spl.lds b/board/ait/cam_enc_4xx/u-boot-spl.lds index 656b2fb..a9d797b 100644 --- a/board/ait/cam_enc_4xx/u-boot-spl.lds +++ b/board/ait/cam_enc_4xx/u-boot-spl.lds @@ -38,7 +38,7 @@ SECTIONS .text : { __start = .; - arch/arm/cpu/arm926ejs/start.o (.text) + arch/arm/cpu/arm926ejs/start.o (.text*) *(.text*) } >.sram
diff --git a/board/davinci/da8xxevm/u-boot-spl-da850evm.lds b/board/davinci/da8xxevm/u-boot-spl-da850evm.lds index c5fd93c..e5ebd82 100644 --- a/board/davinci/da8xxevm/u-boot-spl-da850evm.lds +++ b/board/davinci/da8xxevm/u-boot-spl-da850evm.lds @@ -38,7 +38,7 @@ SECTIONS .text : { __start = .; - arch/arm/cpu/arm926ejs/start.o (.text) + arch/arm/cpu/arm926ejs/start.o (.text*) *(.text*) } >.sram
diff --git a/board/davinci/da8xxevm/u-boot-spl-hawk.lds b/board/davinci/da8xxevm/u-boot-spl-hawk.lds index 174955e..9b2f0dd 100644 --- a/board/davinci/da8xxevm/u-boot-spl-hawk.lds +++ b/board/davinci/da8xxevm/u-boot-spl-hawk.lds @@ -34,15 +34,15 @@ SECTIONS . = ALIGN(4); .text : { - arch/arm/cpu/arm926ejs/start.o (.text) - arch/arm/cpu/arm926ejs/davinci/libdavinci.o (.text) - drivers/mtd/nand/libnand.o (.text) + arch/arm/cpu/arm926ejs/start.o (.text*) + arch/arm/cpu/arm926ejs/davinci/libdavinci.o (.text*) + drivers/mtd/nand/libnand.o (.text*)
*(.text*) }
. = ALIGN(4); .data : { diff --git a/board/freescale/mx31ads/u-boot.lds b/board/freescale/mx31ads/u-boot.lds index 5267729..d011c7a 100644 --- a/board/freescale/mx31ads/u-boot.lds +++ b/board/freescale/mx31ads/u-boot.lds @@ -37,23 +37,23 @@ SECTIONS /* WARNING - the following is hand-optimized to fit within */ /* the sector layout of our flash chips! XXX FIXME XXX */
- arch/arm/cpu/arm1136/start.o (.text) - board/freescale/mx31ads/libmx31ads.o (.text) - arch/arm/lib/libarm.o (.text) - net/libnet.o (.text) - drivers/mtd/libmtd.o (.text) + arch/arm/cpu/arm1136/start.o (.text*) + board/freescale/mx31ads/libmx31ads.o (.text*) + arch/arm/lib/libarm.o (.text*) + net/libnet.o (.text*) + drivers/mtd/libmtd.o (.text*)
. = DEFINED(env_offset) ? env_offset : .; - common/env_embedded.o(.text) + common/env_embedded.o(.text*)
- *(.text) + *(.text*) } . = ALIGN(4); - .rodata : { *(.rodata) } + .rodata : { *(.rodata*) }
. = ALIGN(4); @@ -82,7 +82,7 @@ SECTIONS
.bss __rel_dyn_start (OVERLAY) : { __bss_start = .; - *(.bss) + *(.bss*) . = ALIGN(4); __bss_end__ = .; } diff --git a/board/samsung/smdk5250/smdk5250-uboot-spl.lds b/board/samsung/smdk5250/smdk5250-uboot-spl.lds index 951d8ce..e662a35 100644 --- a/board/samsung/smdk5250/smdk5250-uboot-spl.lds +++ b/board/samsung/smdk5250/smdk5250-uboot-spl.lds @@ -37,7 +37,7 @@ SECTIONS .text : { __start = .; - arch/arm/cpu/armv7/start.o (.text) + arch/arm/cpu/armv7/start.o (.text*) *(.text*) } >.sram . = ALIGN(4); diff --git a/board/vpac270/u-boot-spl.lds b/board/vpac270/u-boot-spl.lds index e344436..183ff8f 100644 --- a/board/vpac270/u-boot-spl.lds +++ b/board/vpac270/u-boot-spl.lds @@ -54,7 +54,7 @@ SECTIONS
.u_boot_list : { @@ -82,7 +82,7 @@ SECTIONS
Factorize start.S code as much as possible.
Functions that may need to be customized for some start.S are defined weak for that purpose.
relocate_code_prepare() and relocate_code_finish() are introduced as hooks to be executed at the beginning and at the end of relocate_code() if needed by some start.S, e.g. for special cache or MMU operations.
arch/arm/cpu/arm1136/start.S | 130 +-------------------------- arch/arm/cpu/arm1176/start.S | 113 +---------------------- arch/arm/cpu/arm720t/start.S | 124 +------------------------- arch/arm/cpu/arm920t/start.S | 125 +------------------------- arch/arm/cpu/arm925t/start.S | 124 +------------------------- arch/arm/cpu/arm926ejs/mxs/start.S | 45 +--------- arch/arm/cpu/arm926ejs/start.S | 131 +-------------------------- arch/arm/cpu/arm946es/start.S | 124 +------------------------- arch/arm/cpu/arm_intcm/start.S | 124 +------------------------- arch/arm/cpu/armv7/start.S | 117 +----------------------- arch/arm/cpu/ixp/start.S | 124 +------------------------- arch/arm/cpu/pxa/start.S | 141 +++-------------------------- arch/arm/cpu/s3c44b0/start.S | 124 +------------------------- arch/arm/cpu/sa1100/start.S | 124 +------------------------- arch/arm/include/asm/start_macro.S | 172 ++++++++++++++++++++++++++++++++++++ arch/arm/lib/crt0.S | 21 +++++ 16 files changed, 241 insertions(+), 1622 deletions(-) create mode 100644 arch/arm/include/asm/start_macro.S
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index eb11b69..19081e8 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -31,6 +31,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> +#include <asm/start_macro.S> .globl _start _start: b reset #ifdef CONFIG_SPL_BUILD @@ -86,52 +87,7 @@ _end_vect: ************************************************************************* */
-.globl _TEXT_BASE -_TEXT_BASE: -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) - .word CONFIG_SPL_TEXT_BASE -#else - .word CONFIG_SYS_TEXT_BASE -#endif - -/* - * These are defined in the board-specific linker script. - * Subtracting _start from them lets the linker put their - * relative position in the executable instead of leaving - * them null. - */ -.globl _bss_start_ofs -_bss_start_ofs: - .word __bss_start - _start - -.globl _image_copy_end_ofs -_image_copy_end_ofs: - .word __image_copy_end - _start - -.globl _bss_end_ofs -_bss_end_ofs: - .word __bss_end__ - _start - -.globl _end_ofs -_end_ofs: - .word _end - _start - -#ifdef CONFIG_USE_IRQ -/* IRQ stack memory (calculated at run-time) */ -.globl IRQ_STACK_START -IRQ_STACK_START: - .word 0x0badc0de - -/* IRQ stack memory (calculated at run-time) */ -.globl FIQ_STACK_START -FIQ_STACK_START: - .word 0x0badc0de -#endif - -/* IRQ stack memory (calculated at run-time) + 8 bytes */ -.globl IRQ_STACK_START_IN -IRQ_STACK_START_IN: - .word 0x0badc0de + define_start_symbols
/* * the actual reset code @@ -173,87 +129,7 @@ next:
-/* - * void relocate_code(addr_moni) - * - * This function relocates the monitor code. - */ - .globl relocate_code -relocate_code: - mov r6, r0 /* save addr of destination */ - - adr r0, _start - subs r9, r6, r0 /* r9 <- relocation offset */ - beq relocate_done /* skip relocation */ - mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _image_copy_end_ofs - add r2, r0, r3 /* r2 <- source end address */ - -copy_loop: - ldmia r0!, {r10-r11} /* copy from source address [r0] */ - stmia r1!, {r10-r11} /* copy to target address [r1] */ - cmp r0, r2 /* until source end address [r2] */ - blo copy_loop - -#ifndef CONFIG_SPL_BUILD - /* - * fix .rel.dyn relocations - */ - ldr r0, _TEXT_BASE /* r0 <- Text base */ - ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ - add r10, r10, r0 /* r10 <- sym table in FLASH */ - ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ - add r2, r2, r0 /* r2 <- rel dyn start in FLASH */ - ldr r3, _rel_dyn_end_ofs /* r3 <- rel dyn end ofs */ - add r3, r3, r0 /* r3 <- rel dyn end in FLASH */ -fixloop: - ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ - add r0, r0, r9 /* r0 <- location to fix up in RAM */ - ldr r1, [r2, #4] - and r7, r1, #0xff - cmp r7, #23 /* relative fixup? */ - beq fixrel - cmp r7, #2 /* absolute fixup? */ - beq fixabs - /* ignore unknown type of fixup */ - b fixnext -fixabs: - /* absolute fix: set location to (offset) symbol value */ - mov r1, r1, LSR #4 /* r1 <- symbol index in .dynsym */ - add r1, r10, r1 /* r1 <- address of symbol in table */ - ldr r1, [r1, #4] /* r1 <- symbol value */ - add r1, r1, r9 /* r1 <- relocated sym addr */ - b fixnext -fixrel: - /* relative fix: increase location by offset */ - ldr r1, [r0] - add r1, r1, r9 -fixnext: - str r1, [r0] - add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ - cmp r2, r3 - blo fixloop -#endif - -relocate_done: - - bx lr - -#ifndef CONFIG_SPL_BUILD - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - -#endif - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - bx lr + define_relocate_code
/* ************************************************************************* diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 18ac8d5..10dd4fc 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -33,6 +33,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> +#include <asm/start_macro.S>
#ifndef CONFIG_SYS_PHY_UBOOT_BASE #define CONFIG_SYS_PHY_UBOOT_BASE CONFIG_SYS_UBOOT_BASE @@ -93,41 +94,7 @@ _end_vect: ************************************************************************* */
-.globl _TEXT_BASE -_TEXT_BASE: -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) - .word CONFIG_SPL_TEXT_BASE -#else - .word CONFIG_SYS_TEXT_BASE -#endif - -/* - * These are defined in the board-specific linker script. - * Subtracting _start from them lets the linker put their - * relative position in the executable instead of leaving - * them null. - */ - -.globl _bss_start_ofs -_bss_start_ofs: - .word __bss_start - _start - -.globl _image_copy_end_ofs -_image_copy_end_ofs: - .word __image_copy_end - _start - -.globl _bss_end_ofs -_bss_end_ofs: - .word __bss_end__ - _start - -.globl _end_ofs -_end_ofs: - .word _end - _start - -/* IRQ stack memory (calculated at run-time) + 8 bytes */ -.globl IRQ_STACK_START_IN -IRQ_STACK_START_IN: - .word 0x0badc0de + define_start_symbols
/* * the actual reset code @@ -225,84 +192,10 @@ skip_tcmdisable:
-/* - * void relocate_code(addr_moni) - * - * This function relocates the monitor code. - */ - .globl relocate_code -relocate_code: - mov r6, r0 /* save addr of destination */ - - adr r0, _start - subs r9, r6, r0 /* r9 <- relocation offset */ - beq relocate_done /* skip relocation */ - mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _image_copy_end_ofs - add r2, r0, r3 /* r2 <- source end address */ - -copy_loop: - ldmia r0!, {r10-r11} /* copy from source address [r0] */ - stmia r1!, {r10-r11} /* copy to target address [r1] */ - cmp r0, r2 /* until source end address [r2] */ - blo copy_loop - #ifndef CONFIG_SPL_BUILD - /* - * fix .rel.dyn relocations - */ - ldr r0, _TEXT_BASE /* r0 <- Text base */ - ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ - add r10, r10, r0 /* r10 <- sym table in FLASH */ - ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ - add r2, r2, r0 /* r2 <- rel dyn start in FLASH */ - ldr r3, _rel_dyn_end_ofs /* r3 <- rel dyn end ofs */ - add r3, r3, r0 /* r3 <- rel dyn end in FLASH */ -fixloop: - ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ - add r0, r0, r9 /* r0 <- location to fix up in RAM */ - ldr r1, [r2, #4] - and r7, r1, #0xff - cmp r7, #23 /* relative fixup? */ - beq fixrel - cmp r7, #2 /* absolute fixup? */ - beq fixabs - /* ignore unknown type of fixup */ - b fixnext -fixabs: - /* absolute fix: set location to (offset) symbol value */ - mov r1, r1, LSR #4 /* r1 <- symbol index in .dynsym */ - add r1, r10, r1 /* r1 <- address of symbol in table */ - ldr r1, [r1, #4] /* r1 <- symbol value */ - add r1, r1, r9 /* r1 <- relocated sym addr */ - b fixnext -fixrel: - /* relative fix: increase location by offset */ - ldr r1, [r0] - add r1, r1, r9 -fixnext: - str r1, [r0] - add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ - cmp r2, r3 - blo fixloop + define_relocate_code #endif
-relocate_done: - - bx lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - mov pc, lr - #ifndef CONFIG_SPL_BUILD /* ************************************************************************* diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index d455793..e7150a6 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -27,6 +27,7 @@ #include <config.h> #include <version.h> #include <asm/hardware.h> +#include <asm/start_macro.S>
/* ************************************************************************* @@ -83,52 +84,7 @@ _pad: .word 0x12345678 /* now 16*4=64 */ ************************************************************************* */
/* * the actual reset code @@ -155,84 +111,10 @@ reset:
-relocate_done: - - mov pc, lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - mov pc, lr - /* ************************************************************************* * diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index a6cb33f..db30842 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -25,8 +25,8 @@ */
#include <asm-offsets.h> -#include <common.h> #include <config.h> +#include <asm/start_macro.S>
/* ************************************************************************* @@ -71,52 +71,7 @@ _fiq: .word fiq ************************************************************************* */
/* * the actual start code @@ -194,84 +149,10 @@ copyex:
-relocate_done: - - mov pc, lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - mov pc, lr - /* ************************************************************************* * diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 78d5ab4..6b77e94 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -33,6 +33,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> +#include <asm/start_macro.S>
/* ************************************************************************* @@ -77,52 +78,7 @@ _fiq: .word fiq ************************************************************************* */
/* * the actual reset code @@ -184,84 +140,10 @@ poll1:
-relocate_done: - - mov pc, lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - mov pc, lr - /* ************************************************************************* * diff --git a/arch/arm/cpu/arm926ejs/mxs/start.S b/arch/arm/cpu/arm926ejs/mxs/start.S index 94da398..be8dda0 100644 --- a/arch/arm/cpu/arm926ejs/mxs/start.S +++ b/arch/arm/cpu/arm926ejs/mxs/start.S @@ -37,8 +37,8 @@
#include <asm-offsets.h> #include <config.h> -#include <common.h> #include <version.h> +#include <asm/start_macro.S>
/* ************************************************************************* @@ -117,48 +117,7 @@ fiq: ************************************************************************* */
-.globl _TEXT_BASE -_TEXT_BASE: -#ifdef CONFIG_SPL_TEXT_BASE - .word CONFIG_SPL_TEXT_BASE -#else - .word CONFIG_SYS_TEXT_BASE -#endif - -/* - * These are defined in the board-specific linker script. - * Subtracting _start from them lets the linker put their - * relative position in the executable instead of leaving - * them null. - */ -.globl _bss_start_ofs -_bss_start_ofs: - .word __bss_start - _start - -.globl _bss_end_ofs -_bss_end_ofs: - .word __bss_end__ - _start - -.globl _end_ofs -_end_ofs: - .word _end - _start - -#ifdef CONFIG_USE_IRQ -/* IRQ stack memory (calculated at run-time) */ -.globl IRQ_STACK_START -IRQ_STACK_START: - .word 0x0badc0de - -/* IRQ stack memory (calculated at run-time) */ -.globl FIQ_STACK_START -FIQ_STACK_START: - .word 0x0badc0de -#endif - -/* IRQ stack memory (calculated at run-time) + 8 bytes */ -.globl IRQ_STACK_START_IN -IRQ_STACK_START_IN: - .word 0x0badc0de + define_start_symbols
/* * the actual reset code diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 863eb8e..9022af8 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -33,8 +33,8 @@
/* ************************************************************************* @@ -118,52 +118,7 @@ _fiq: ************************************************************************* */
/* * the actual reset code @@ -190,87 +145,7 @@ reset:
-/* - * void relocate_code(addr_moni) - * - * This function relocates the monitor code. - */ - .globl relocate_code -relocate_code: - mov r6, r0 /* save addr of destination */ - - adr r0, _start - subs r9, r6, r0 /* r9 <- relocation offset */ - beq relocate_done /* skip relocation */ - mov r1, r6 /* r1 <- scratch for copy loop */ - ldr r3, _image_copy_end_ofs - add r2, r0, r3 /* r2 <- source end address */ - -copy_loop: - ldmia r0!, {r10-r11} /* copy from source address [r0] */ - stmia r1!, {r10-r11} /* copy to target address [r1] */ - cmp r0, r2 /* until source end address [r2] */ - blo copy_loop - -#ifndef CONFIG_SPL_BUILD - /* - * fix .rel.dyn relocations - */ - ldr r0, _TEXT_BASE /* r0 <- Text base */ - ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ - add r10, r10, r0 /* r10 <- sym table in FLASH */ - ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ - add r2, r2, r0 /* r2 <- rel dyn start in FLASH */ - ldr r3, _rel_dyn_end_ofs /* r3 <- rel dyn end ofs */ - add r3, r3, r0 /* r3 <- rel dyn end in FLASH */ -fixloop: - ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ - add r0, r0, r9 /* r0 <- location to fix up in RAM */ - ldr r1, [r2, #4] - and r7, r1, #0xff - cmp r7, #23 /* relative fixup? */ - beq fixrel - cmp r7, #2 /* absolute fixup? */ - beq fixabs - /* ignore unknown type of fixup */ - b fixnext -fixabs: - /* absolute fix: set location to (offset) symbol value */ - mov r1, r1, LSR #4 /* r1 <- symbol index in .dynsym */ - add r1, r10, r1 /* r1 <- address of symbol in table */ - ldr r1, [r1, #4] /* r1 <- symbol value */ - add r1, r1, r9 /* r1 <- relocated sym addr */ - b fixnext -fixrel: - /* relative fix: increase location by offset */ - ldr r1, [r0] - add r1, r1, r9 -fixnext: - str r1, [r0] - add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ - cmp r2, r3 - blo fixloop -#endif - -relocate_done: - - bx lr - -#ifndef CONFIG_SPL_BUILD - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - -#endif - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - bx lr + define_relocate_code
/* ************************************************************************* diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index cc8158d..c3c3938 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -34,6 +34,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> +#include <asm/start_macro.S>
/* ************************************************************************* @@ -87,52 +88,7 @@ _vectors_end: ************************************************************************* */
/* * the actual reset code @@ -159,84 +115,10 @@ reset:
-relocate_done: - - mov pc, lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - mov pc, lr - /* ************************************************************************* * diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index 8965d5f..e74ee14 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -33,6 +33,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> +#include <asm/start_macro.S>
/* ************************************************************************* @@ -83,52 +84,7 @@ _fiq: ************************************************************************* */
-relocate_done: - - bx lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - mov pc, lr - /* ************************************************************************* * diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index d1b7d33..713420b 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -34,6 +34,7 @@ #include <version.h> #include <asm/system.h> #include <linux/linkage.h> +#include <asm/start_macro.S>
.globl _start _start: b reset @@ -79,49 +80,7 @@ _end_vect: * *************************************************************************/
-.globl _TEXT_BASE -_TEXT_BASE: -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) - .word CONFIG_SPL_TEXT_BASE -#else - .word CONFIG_SYS_TEXT_BASE -#endif - -/* - * These are defined in the board-specific linker script. - */ -.globl _bss_start_ofs -_bss_start_ofs: - .word __bss_start - _start - -.globl _image_copy_end_ofs -_image_copy_end_ofs: - .word __image_copy_end - _start - -.globl _bss_end_ofs -_bss_end_ofs: - .word __bss_end__ - _start - -.globl _end_ofs -_end_ofs: - .word _end - _start - -#ifdef CONFIG_USE_IRQ -/* IRQ stack memory (calculated at run-time) */ -.globl IRQ_STACK_START -IRQ_STACK_START: - .word 0x0badc0de - -/* IRQ stack memory (calculated at run-time) */ -.globl FIQ_STACK_START -FIQ_STACK_START: - .word 0x0badc0de -#endif - -/* IRQ stack memory (calculated at run-time) + 8 bytes */ -.globl IRQ_STACK_START_IN -IRQ_STACK_START_IN: - .word 0x0badc0de + define_start_symbols
/* * the actual reset code @@ -164,77 +123,7 @@ reset: /*------------------------------------------------------------------------------*/
#ifndef CONFIG_SPL_BUILD -/* - * void relocate_code(addr_moni) - * - * This function relocates the monitor code. - */ -ENTRY(relocate_code) - mov r6, r0 /* save addr of destination */ - - adr r0, _start - subs r9, r6, r0 /* r9 <- relocation offset */ - beq relocate_done /* skip relocation */ - mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _image_copy_end_ofs - add r2, r0, r3 /* r2 <- source end address */ - -copy_loop: - ldmia r0!, {r10-r11} /* copy from source address [r0] */ - stmia r1!, {r10-r11} /* copy to target address [r1] */ - cmp r0, r2 /* until source end address [r2] */ - blo copy_loop - - /* - * fix .rel.dyn relocations - */ - ldr r0, _TEXT_BASE /* r0 <- Text base */ - ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ - add r10, r10, r0 /* r10 <- sym table in FLASH */ - ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ - add r2, r2, r0 /* r2 <- rel dyn start in FLASH */ - ldr r3, _rel_dyn_end_ofs /* r3 <- rel dyn end ofs */ - add r3, r3, r0 /* r3 <- rel dyn end in FLASH */ -fixloop: - ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ - add r0, r0, r9 /* r0 <- location to fix up in RAM */ - ldr r1, [r2, #4] - and r7, r1, #0xff - cmp r7, #23 /* relative fixup? */ - beq fixrel - cmp r7, #2 /* absolute fixup? */ - beq fixabs - /* ignore unknown type of fixup */ - b fixnext -fixabs: - /* absolute fix: set location to (offset) symbol value */ - mov r1, r1, LSR #4 /* r1 <- symbol index in .dynsym */ - add r1, r10, r1 /* r1 <- address of symbol in table */ - ldr r1, [r1, #4] /* r1 <- symbol value */ - add r1, r1, r9 /* r1 <- relocated sym addr */ - b fixnext -fixrel: - /* relative fix: increase location by offset */ - ldr r1, [r0] - add r1, r1, r9 -fixnext: - str r1, [r0] - add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ - cmp r2, r3 - blo fixloop - -relocate_done: - - bx lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start -ENDPROC(relocate_code) - + define_relocate_code #endif
ENTRY(c_runtime_cpu_setup) diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index d986c31..b24529d 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -30,6 +30,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> +#include <asm/start_macro.S> #include <asm/arch/ixp425.h>
#define MMU_Control_M 0x001 /* Enable MMU */ @@ -96,52 +97,7 @@ _fiq: .word fiq * - jump to second stage */
/* * the actual reset code @@ -257,84 +213,10 @@ reset:
-relocate_done: - - bx lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - bx lr - /****************************************************************************/ /* */ /* Interrupt handling */ diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 3523331..fbad057 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -38,6 +38,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> +#include <asm/start_macro.S>
#ifdef CONFIG_CPU_PXA25X #if ((CONFIG_SYS_INIT_SP_ADDR) != 0xfffff800) @@ -100,52 +101,7 @@ _end_vect: ************************************************************************* */
/* * the actual reset code @@ -171,94 +127,11 @@ reset: bl _main
/*------------------------------------------------------------------------------*/ -#ifndef CONFIG_SPL_BUILD -/* - * void relocate_code(addr_moni) - * - * This function relocates the monitor code. - */ - .globl relocate_code -relocate_code: - mov r6, r0 /* save addr of destination */ - -/* Disable the Dcache RAM lock for stack now */ -#ifdef CONFIG_CPU_PXA25X - mov r12, lr - bl cpu_init_crit - mov lr, r12 -#endif - - adr r0, _start - subs r9, r6, r0 /* r9 <- relocation offset */ - beq relocate_done /* skip relocation */ - mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _image_copy_end_ofs - add r2, r0, r3 /* r2 <- source end address */ - -copy_loop: - ldmia r0!, {r10-r11} /* copy from source address [r0] */ - stmia r1!, {r10-r11} /* copy to target address [r1] */ - cmp r0, r2 /* until source end address [r2] */ - blo copy_loop
-relocate_done: - - bx lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - -#endif - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - bx lr - /* ************************************************************************* * @@ -269,6 +142,9 @@ c_runtime_cpu_setup: * ************************************************************************* */ +#ifdef CONFIG_CPU_PXA25X +ENTRY(relocate_code_prepare) +#endif #if !defined(CONFIG_SKIP_LOWLEVEL_INIT) || defined(CONFIG_CPU_PXA25X) cpu_init_crit: /* @@ -288,8 +164,11 @@ cpu_init_crit: orr r0, r0, #0x00001000 @ set bit 12 (I) I-Cache mcr p15, 0, r0, c1, c0, 0
- mov pc, lr /* back to my caller */ + bx lr /* back to my caller */ #endif /* !CONFIG_SKIP_LOWLEVEL_INIT || CONFIG_CPU_PXA25X */ +#ifdef CONFIG_CPU_PXA25X +ENDPROC(relocate_code_prepare) +#endif
#ifndef CONFIG_SPL_BUILD /* diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 62093ed..cb9bc6e 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -30,6 +30,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> +#include <asm/start_macro.S>
/* * Jump vector table @@ -62,52 +63,7 @@ _start: b reset ************************************************************************* */
/* * the actual reset code @@ -140,84 +96,10 @@ reset:
-relocate_done: - - bx lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - bx lr - /* ************************************************************************* * diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 207c190..90fafc3 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -28,6 +28,7 @@ #include <asm-offsets.h> #include <config.h> #include <version.h> +#include <asm/start_macro.S>
/* ************************************************************************* @@ -72,52 +73,7 @@ _fiq: .word fiq ************************************************************************* */
/* * the actual reset code @@ -144,84 +100,10 @@ reset:
-relocate_done: - - mov pc, lr - -_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - - .globl c_runtime_cpu_setup -c_runtime_cpu_setup: - - mov pc, lr - /* ************************************************************************* * diff --git a/arch/arm/include/asm/start_macro.S b/arch/arm/include/asm/start_macro.S new file mode 100644 index 0000000..539317e --- /dev/null +++ b/arch/arm/include/asm/start_macro.S @@ -0,0 +1,172 @@ +/* + * Macros for ARM start.S files + * + * (C) Copyright 2013 ADVANSEE + * Benoît Thébaudeau benoit.thebaudeau@advansee.com + * + * Based on arch/arm/cpu/armv7/start.S, which is: + * Copyright (c) 2004 Texas Instruments r-woodruff2@ti.com + * Copyright (c) 2001 Marius Gröger mag@sysgo.de + * Copyright (c) 2002 Alex Züpke azu@sysgo.de + * Copyright (c) 2002 Gary Jennejohn garyj@denx.de + * Copyright (c) 2003 Richard Woodruff r-woodruff2@ti.com + * Copyright (c) 2003 Kshitij kshitij@ti.com + * Copyright (c) 2006-2008 Syed Mohammed Khasim x0khasim@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __START_MACRO_S +#define __START_MACRO_S + +#include <config.h> +#include <asm-offsets.h> +#include <linux/linkage.h> + + .macro define_start_symbols +ENTRY(_TEXT_BASE) +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_TEXT_BASE) + .word CONFIG_SPL_TEXT_BASE +#else + .word CONFIG_SYS_TEXT_BASE +#endif +END(_TEXT_BASE) + +/* + * These are defined in the board-specific linker script. + * Subtracting _start from them lets the linker put their + * relative position in the executable instead of leaving + * them null. + */ + +ENTRY(_end_ofs) + .word _end - _start +END(_end_ofs) + +ENTRY(_bss_start_ofs) + .word __bss_start - _start +END(_bss_start_ofs) + +ENTRY(_bss_end_ofs) + .word __bss_end__ - _start +END(_bss_end_ofs) + +#ifdef CONFIG_USE_IRQ +/* IRQ stack memory (calculated at run-time) */ +ENTRY(IRQ_STACK_START) + .word 0x0badc0de +END(IRQ_STACK_START) + +/* FIQ stack memory (calculated at run-time) */ +ENTRY(FIQ_STACK_START) + .word 0x0badc0de +END(FIQ_STACK_START) +#endif + +/* IRQ stack memory (calculated at run-time) + 8 bytes */ +ENTRY(IRQ_STACK_START_IN) + .word 0x0badc0de +END(IRQ_STACK_START_IN) + .endm /* define_start_symbols */ + +/*----------------------------------------------------------------------------*/ + + .macro define_relocate_code +/* + * void relocate_code(addr_moni) + * + * This function relocates the monitor code. + */ +ENTRY(relocate_code) + mov r6, r0 /* save addr of destination */ + + mov r4, lr + bl relocate_code_prepare + mov lr, r4 + + adr r0, _start + subs r9, r6, r0 /* r9 <- relocation offset */ + beq relocate_done /* skip relocation */ + mov r1, r6 /* r1 <- scratch for copy_loop */ + ldr r3, _image_copy_end_ofs + add r2, r0, r3 /* r2 <- source end address */ + +copy_loop: + ldmia r0!, {r4-r5} /* copy from source address [r0] */ + stmia r1!, {r4-r5} /* copy to target address [r1] */ + cmp r0, r2 /* until source end address [r2] */ + blo copy_loop + +#ifndef CONFIG_SPL_BUILD + /* + * fix .rel.dyn relocations + */ + ldr r0, _TEXT_BASE /* r0 <- Text base */ + ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ + add r10, r10, r0 /* r10 <- sym table in FLASH */ + ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ + add r2, r2, r0 /* r2 <- rel dyn start in FLASH */ + ldr r3, _rel_dyn_end_ofs /* r3 <- rel dyn end ofs */ + add r3, r3, r0 /* r3 <- rel dyn end in FLASH */ +fixloop: + ldr r0, [r2] /* r0 <- location to fix up in FLASH */ + add r0, r0, r9 /* r0 <- location to fix up in RAM */ + ldr r1, [r2, #4] + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ + beq fixrel + cmp r7, #2 /* absolute fixup? */ + beq fixabs + /* ignore unknown type of fixup */ + b fixnext +fixabs: + /* absolute fix: set location to (offset) symbol value */ + mov r1, r1, LSR #4 /* r1 <- symbol index in .dynsym */ + add r1, r10, r1 /* r1 <- address of symbol in table */ + ldr r1, [r1, #4] /* r1 <- symbol value */ + add r1, r1, r9 /* r1 <- relocated sym addr */ + b fixnext +fixrel: + /* relative fix: increase location by offset */ + ldr r1, [r0] + add r1, r1, r9 +fixnext: + str r1, [r0] + add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ + cmp r2, r3 + blo fixloop +#endif + +relocate_done: + b relocate_code_finish + +_image_copy_end_ofs: + .word __image_copy_end - _start +#ifndef CONFIG_SPL_BUILD +_rel_dyn_start_ofs: + .word __rel_dyn_start - _start +_rel_dyn_end_ofs: + .word __rel_dyn_end - _start +_dynsym_start_ofs: + .word __dynsym_start - _start +#endif +ENDPROC(relocate_code) + .endm /* define_relocate_code */ + +#endif /* __START_MACRO_S */ diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 6fcb7d1..4559d40 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -68,9 +68,30 @@ */
/* + * A section is created for each symbol in order to optimize section garbage + * collection at link time if --gc-sections is used, which is the case for SPL + * builds. + */ + + .section .text.crt0_default_hooks,"ax",%progbits +ENTRY(relocate_code_prepare) +ENTRY(relocate_code_finish) +ENTRY(c_runtime_cpu_setup) +#ifdef __ARM_ARCH_4__ + mov pc, lr +#else + bx lr +#endif +ENDPROC(c_runtime_cpu_setup) +ENDPROC(relocate_code_finish) +ENDPROC(relocate_code_prepare) + .weak relocate_code_prepare, relocate_code_finish, c_runtime_cpu_setup + +/* * entry point of crt0 sequence */
+ .section .text._main,"ax",%progbits ENTRY(_main)
Hi Benoît,
On Fri, 1 Mar 2013 13:10:40 +0100, Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
NAK.
1. I don't like this idea of planting hooks inside relocate-code(). This function is about relocating code, not about MMU stuff. If there are any MMU steps to be performed between calls to board_init_f(), relocate_code() or board_init_r(), I want them laid out as calls of their own right in crt0.S.
2. If we're going to factorize out relocate_code() from the various start.S files, I want it moved not in crt0.S but in its own file. This way, i) people can easily create binaries which use crt0.S but do not relocate, ii) people who want to make relocate_code() a C function will have it easier, and iii) crt0.S keeps being the ugly ASM glue needed for flash inits, relocation and RAM inits to have a C proper run-time environment.
Incidentally, CC:ing Simon:
Changes in v8:
- New patch.
Is this produced by patman? If so, is there a way to avoid it? We *know* it's a new patch in v8, so any history pre-v8 here is meaningless.
Amicalement,
Hi Albert,
On Friday, March 1, 2013 4:46:07 PM, Albert ARIBAUD wrote:
Hi Benoît,
NAK.
- I don't like this idea of planting hooks inside relocate-code().
I also don't like it. The finish hook was used by SMDK6400 before it was removed, and the prepare hook is still used by pxa.
So is it OK for you if I just drop relocate_code_finish() and move and rename the call to relocate_code_prepare() to crt0.S?
- If we're going to factorize out relocate_code() from the various
It is not in crt0.S, but in arch/arm/include/asm/start_marco.S, which is almost its own file apart from another macro.
Which is already the case with this implementation?
Changes in v8:
- New patch.
Yes.
Not that I know of.
Sure.
On Friday, March 1, 2013 4:50:44 PM, Benoît Thébaudeau wrote:
Hi Albert,
Hi Benoît,
NAK.
And in case you ask, with relocate_code() as a function in its own file instead of a macro called from start.S, it does not work because of the _start-relative word values that require relocate_code() to be in _start's section.
Hi Benoît,
On Fri, 1 Mar 2013 16:50:44 +0100 (CET), Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
Hi Albert,
Hi Benoît,
NAK.
Fine, except for the name: "prepare for relocation" is what every instruction does from board_init_f() return to relocate_code() entry. This 'hook' does only a small part, if at all, of preparing for relocation, and this part must get a less improper name. If we are enabling the I-cache here, then let's name the function accordingly. Better yet, let us find out if we do need to enable the instruction cache here at all.
I do not want it as a macro. It is and should stay a function. Regarding your added comment:
Actually, I'd stopped dead at the relocate_code() changes, but the other macros I don't like much either; I don't see the point of it.
To be faire, I don't see the point of the whole patch wrt the objective.
How does it "not work" exactly?
Not with relocate_code() as a macro, though.
This whole thing/way of "factorizing" start.S using macros feels wrong to me; this departs from what I have started with crt0.S, where code is actually really factorized in a single file which is actually a compilation unit, not a helper file.
Do you need patch 31/31 in your series?
Changes in v8:
- New patch.
Yes [...]
Ok, then, don't bother to fix patman's behavior manually in your own patches -- I'll try and see if I can submit a patch to fix patman itself.
Amicalement,
Hi Albert,
On Fri, 1 Mar 2013 22:56:50 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Benoît,
Hi Albert,
Hi Benoît,
NAK.
Sorry for the mixup here. Drop the "Regarding..." just above...
... it should go here.
Changes in v8:
- New patch.
Yes [...]
Amicalement,
Amicalement,
Hi Albert,
On Friday, March 1, 2013 10:56:50 PM, Albert ARIBAUD wrote:
Hi Benoît,
Hi Albert,
Hi Benoît,
NAK.
Correct. For PXA25X, this cpu_init_crit() is paired with lock_cache_for_stack(), apparently for some hardware hack, but this is not very clear if this is required or if it could not be done otherwise. Do you know a PXA expert?
Marek, you introduced that in commit 7f4cfcf. Do you know the details about why?
If we could drop it or move it elsewhere, that would be great.
This patch is just appended to the series because it depends on it, not because the series needs it.
This patch only aims at cleaning up code by removing copied/pasted code in order to simplify maintenance and to clarify things.
There have been many changes in this relocate_code(), and not always the same for all start.S, so from the outside, the purpose is unclear because one might wonder if those differences have been created on purpose or not.
The assembler issues an error (I don't remember the exact message) for all lines like ".word __rel_dyn_start - _start", complaining that this is not a kind of expression that it can prepare for the linker to resolve.
Though, it would still be possible to find a more complicated way of doing the same thing at runtime.
Yes. Well, for this patch, I had first moved relocate_code() to crt0.S (could have been its own file), but I eventually switched to the macro solution because of the assembler errors.
As explained above, no. But I really think that something should be done to stop relocate_code() duplication, one way or another, by me or someone else. I just wanted to help here.
Changes in v8:
- New patch.
Yes [...]
OK.
patman had also removed some "Reviewed-by" that I had to restore manually before sending. This is a documented behavior, but not cool.
And contrary to what the documentation says, patman adds my SoB line even if I have forced another SoB in the commit message, which I also had to fix manually.
On Fri, Mar 1, 2013 at 2:54 PM, Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
Hi Albert,
Hi Benoît,
Hi Albert,
Hi Benoît,
NAK.
Changes in v8:
- New patch.
Yes [...]
OK.
Yes I have hit this myself. Someone should do a couple of patches to fix this. I will put it on my list in case someone else doesn't get to it first. Specifically:
- Don't touch/add Signed-off-by: but perhaps just want if there is not at least one in a patch - Don't touch Reviewed-by: in the normal case - but perhaps provide a flag to remove this Geritt tag
Hi Simon,
On Fri, 1 Mar 2013 13:10:40 +0100, Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote: Incidentally, CC:ing Simon:
Changes in v8:
- New patch.
Yes [...]
OK.
Thanks, that'd be great. And also a 3rd one for what Albert said (which he might do himself): - Do not report version changes before a patch has been introduced: if a patch has been introduced in version n, start reporting version changes for this patch from version n. This will probably require a new tag to tell patman in which version a patch has been created, e.g.:
Patch-creation: n
Hi Benoît,
On Fri, 1 Mar 2013 23:54:26 +0100 (CET), Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
Re: assembler error messages:
(later)
I've had issue in the past similar to this when I implemented the ELF relocation, the crt0.S factorization and more recently the R_ARM_ABS32 relocation record removal. These must be fixed with much attention, for instance in order to not produce R_ARM_ABS32 relocations, the removal of which I have just submitted a patch for. I think there is a way to factorize relocate_code() (and other parts) out of start.S files, built on what I did for crt0.S, and which should not cause these issues.
Re: patch 31/31 generally:
(picked up from later in the reply)
First, let me say that I appreciate the great help that you're giving us with this (30-patch!) series.
And I agree about the premise that ARM startup sequence, including but not limited to relocate_code(), is literally all over the place and that there is a need to fix this; I wrote so in the cover letter of my crt0.S patch series, which I consider a starting point and example of how I consider this should be done.
Also, we must keep in mind that part of the code in ARM should, and eventually will, be merged into a single U-Boot-wide version. ELF code relocation is not ARM specific except for the two (to be reduced soon to only one) ARM relocation record types. Thus, when we touch this code, we must keep it close, or make it closer, to the code in other U-Boot architectures; IIRC there are already patches out there to make relocate_code() a single project-wide true C function.
And I think that this newly added patch 31/31 in your series does not match either the way I want ARM startup simplification to go or the general goal of unifying relocate_code().
Thus, if you don't mind, I'd prefer patch 31/31 to move out of the series. And, since I want to avoid anyone the hassle of going through this again, I guess I will have to submit a patch for relocate_code() factorization -- quite probably above your series, since many fixes you make in it may be useful or even needed.
Amicalement,
Hi Albert,
On Saturday, March 2, 2013 7:45:06 AM, Albert ARIBAUD wrote:
Hi Benoît,
(later)
Yes, I think so. In the worst case, it should be possible to access out-of-range symbol relatively using adr or adrl extensively at runtime instead of pre-computed _start-relative offsets.
OK, let's do this. It will also help to stop postponing the application of this series because of more new versions.
Please just Cc me when you will post these patches so that I review them.
Hi Benoît,
On Sat, 2 Mar 2013 14:42:16 +0100 (CET), Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
Also, yes.
One minor request re your upcoming v9: beside posting the series as you do on the mailing list, can you provide a git repo and a branch which could be pulled, even if it contains patman annotations? This way, the review process continues unchanged on the list, and I can begin the relocate_code() work without having to wait for your series to be applied or to apply every patch in your series manualy myself.
I will.
Amicalement,
Hi Fabio,
On Friday, March 1, 2013 1:10:10 PM, Benoît Thébaudeau wrote:
Introduce CONFIG_SYS_NAND_BUSWIDTH_16BIT option so that other NAND controller drivers could use it when a 16-bit NAND is deployed.
drivers/mtd/nand/ndfc has CONFIG_SYS_NDFC_16BIT, so just rename it, so that other NAND drivers could reuse the same symbol.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Reviewed-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com
Changes in v8:
- New patch.
README | 9 ++++++--- drivers/mtd/nand/ndfc.c | 4 ++-- 2 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/README b/README index d8cb394..830c45e 100644 --- a/README +++ b/README @@ -3713,9 +3713,12 @@ Low Level (hardware related) configuration options:
- CONFIG_SYS_SRIOn_MEM_SIZE: Size of SRIO port 'n' memory region
-- CONFIG_SYS_NDFC_16
Defined to tell the NDFC that the NAND chip is using a
16 bit bus.
+- CONFIG_SYS_NAND_BUSWIDTH_16BIT
Defined to tell the NAND controller that the NAND chip is using
a 16 bit bus.
Not all NAND drivers use this symbol.
Example of driver that uses it:
FYI, I've just fixed a space damage (space before tab warning) here when applying.
On Fri, Mar 1, 2013 at 12:33 PM, Benoît Thébaudeau benoit.thebaudeau@advansee.com wrote:
Ok, thanks for fixing it.
participants (5)
Albert ARIBAUD
Benoît Thébaudeau
Fabio Estevam
