[U-Boot] [PATCH v2 0/4] drivers: Add a framework for MUX drivers
Add a new minimalistic subsystem that handles multiplexer controllers. It provides the same API as Linux and mux drivers should be portable with a minimum effort. This series also includes a port of the Linux's mmio-mux driver.
This series relies on a series that extend the regmap [1].
[1] : https://patchwork.ozlabs.org/project/uboot/list/?series=140752
Changes in v2: - Fixed warning in mux_of_xlate_default() - Improved documentation - Fixed SPL build - insert the mux initialization in init_sequence_r[], just before the console is initialized as its serial port may be muxed - moved the definition of dm_mux_init() in this commit - Call sandbox_set_enable_memio(true) before running the test
Jean-Jacques Hiblot (4): drivers: Add a new framework for multiplexer devices dm: board: complete the initialization of the muxes in initr_dm() drivers: mux: mmio-based syscon mux controller test: Add tests for the multiplexer framework
arch/sandbox/dts/test.dts | 26 +++ common/board_r.c | 16 ++ configs/sandbox_defconfig | 2 + drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/mux/Kconfig | 22 +++ drivers/mux/Makefile | 7 + drivers/mux/mmio.c | 155 ++++++++++++++++++ drivers/mux/mux-uclass.c | 292 ++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/dt-bindings/mux/mux.h | 17 ++ include/mux-internal.h | 103 ++++++++++++ include/mux.h | 115 +++++++++++++ test/dm/Makefile | 1 + test/dm/mux-mmio.c | 147 +++++++++++++++++ 15 files changed, 907 insertions(+) create mode 100644 drivers/mux/Kconfig create mode 100644 drivers/mux/Makefile create mode 100644 drivers/mux/mmio.c create mode 100644 drivers/mux/mux-uclass.c create mode 100644 include/dt-bindings/mux/mux.h create mode 100644 include/mux-internal.h create mode 100644 include/mux.h create mode 100644 test/dm/mux-mmio.c
Add a new subsystem that handles multiplexer controllers. The API is the same as in Linux.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com
drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/mux/Kconfig | 7 + drivers/mux/Makefile | 6 + drivers/mux/mux-uclass.c | 270 ++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/dt-bindings/mux/mux.h | 17 +++ include/mux-internal.h | 103 +++++++++++++ include/mux.h | 113 ++++++++++++++ 9 files changed, 520 insertions(+) create mode 100644 drivers/mux/Kconfig create mode 100644 drivers/mux/Makefile create mode 100644 drivers/mux/mux-uclass.c create mode 100644 include/dt-bindings/mux/mux.h create mode 100644 include/mux-internal.h create mode 100644 include/mux.h
diff --git a/drivers/Kconfig b/drivers/Kconfig index 9d99ce0226..450aa76e82 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -60,6 +60,8 @@ source "drivers/mmc/Kconfig"
source "drivers/mtd/Kconfig"
+source "drivers/mux/Kconfig" + source "drivers/net/Kconfig"
source "drivers/nvme/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index 0befeddfcb..9d64742580 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -12,6 +12,7 @@ obj-$(CONFIG_$(SPL_TPL_)INPUT) += input/ obj-$(CONFIG_$(SPL_TPL_)LED) += led/ obj-$(CONFIG_$(SPL_TPL_)MMC_SUPPORT) += mmc/ obj-$(CONFIG_$(SPL_TPL_)NAND_SUPPORT) += mtd/nand/raw/ +obj-$(CONFIG_$(SPL_)MULTIPLEXER) += mux/ obj-$(CONFIG_$(SPL_TPL_)PCH_SUPPORT) += pch/ obj-$(CONFIG_$(SPL_TPL_)PCI) += pci/ obj-$(CONFIG_$(SPL_TPL_)PHY) += phy/ diff --git a/drivers/mux/Kconfig b/drivers/mux/Kconfig new file mode 100644 index 0000000000..ad0199c058 --- /dev/null +++ b/drivers/mux/Kconfig @@ -0,0 +1,7 @@ +menu "Multiplexer drivers" + +config MULTIPLEXER + bool "Multiplexer Support" + depends on DM + +endmenu diff --git a/drivers/mux/Makefile b/drivers/mux/Makefile new file mode 100644 index 0000000000..351e4363d3 --- /dev/null +++ b/drivers/mux/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2019 +# Jean-Jacques Hiblot jjhiblot@ti.com + +obj-$(CONFIG_$(SPL_)MULTIPLEXER) += mux-uclass.o diff --git a/drivers/mux/mux-uclass.c b/drivers/mux/mux-uclass.c new file mode 100644 index 0000000000..6aaf4dc964 --- /dev/null +++ b/drivers/mux/mux-uclass.c @@ -0,0 +1,270 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Multiplexer subsystem + * + * Based on the linux multiplexer framework + * + * Copyright (C) 2017 Axentia Technologies AB + * Author: Peter Rosin peda@axentia.se + * + * Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ + * Jean-Jacques Hiblot jjhiblot@ti.com + */ + +#include <common.h> +#include <dm.h> +#include <mux-internal.h> +#include <dm/device-internal.h> +#include <dt-bindings/mux/mux.h> + +/* + * The idle-as-is "state" is not an actual state that may be selected, it + * only implies that the state should not be changed. So, use that state + * as indication that the cached state of the multiplexer is unknown. + */ +#define MUX_CACHE_UNKNOWN MUX_IDLE_AS_IS + +static inline const struct mux_control_ops *mux_dev_ops(struct udevice *dev) +{ + return (const struct mux_control_ops *)dev->driver->ops; +} + +static int mux_control_set(struct mux_control *mux, int state) +{ + int ret = mux_dev_ops(mux->dev)->set(mux, state); + + mux->cached_state = ret < 0 ? MUX_CACHE_UNKNOWN : state; + + return ret; +} + +unsigned int mux_control_states(struct mux_control *mux) +{ + return mux->states; +} + +static int __mux_control_select(struct mux_control *mux, int state) +{ + int ret; + + if (WARN_ON(state < 0 || state >= mux->states)) + return -EINVAL; + + if (mux->cached_state == state) + return 0; + + ret = mux_control_set(mux, state); + if (ret >= 0) + return 0; + + /* The mux update failed, try to revert if appropriate... */ + if (mux->idle_state != MUX_IDLE_AS_IS) + mux_control_set(mux, mux->idle_state); + + return ret; +} + +int mux_control_select(struct mux_control *mux, unsigned int state) +{ + int ret; + + if (mux->in_use) + return -EBUSY; + + ret = __mux_control_select(mux, state); + + if (ret < 0) + return ret; + + mux->in_use = true; + + return 0; +} + +int mux_control_deselect(struct mux_control *mux) +{ + int ret = 0; + + if (mux->idle_state != MUX_IDLE_AS_IS && + mux->idle_state != mux->cached_state) + ret = mux_control_set(mux, mux->idle_state); + + mux->in_use = false; + + return ret; +} + +static int mux_of_xlate_default(struct mux_chip *mux_chip, + struct ofnode_phandle_args *args, + struct mux_control **muxp) +{ + struct mux_control *mux; + int id; + + debug("%s(muxp=%p)\n", __func__, muxp); + + if (args->args_count > 1) { + debug("Invaild args_count: %d\n", args->args_count); + return -EINVAL; + } + + if (args->args_count) + id = args->args[0]; + else + id = 0; + + if (id >= mux_chip->controllers) { + dev_err(dev, "bad mux controller %u specified in %s\n", + id, ofnode_get_name(args->node)); + return -ERANGE; + } + + mux = &mux_chip->mux[id]; + mux->id = id; + *muxp = mux; + return 0; +} + +static int mux_get_by_indexed_prop(struct udevice *dev, const char *prop_name, + int index, struct mux_control **mux) +{ + int ret; + struct ofnode_phandle_args args; + struct udevice *dev_mux; + const struct mux_control_ops *ops; + struct mux_chip *mux_chip; + + debug("%s(dev=%p, index=%d, mux=%p)\n", __func__, dev, index, mux); + + ret = dev_read_phandle_with_args(dev, prop_name, "#mux-control-cells", + 0, index, &args); + if (ret) { + debug("%s: fdtdec_parse_phandle_with_args failed: err=%d\n", + __func__, ret); + return ret; + } + + ret = uclass_get_device_by_ofnode(UCLASS_MUX, args.node, &dev_mux); + if (ret) { + debug("%s: uclass_get_device_by_ofnode failed: err=%d\n", + __func__, ret); + return ret; + } + + mux_chip = dev_get_uclass_priv(dev_mux); + + ops = mux_dev_ops(dev_mux); + if (ops->of_xlate) + ret = ops->of_xlate(mux_chip, &args, mux); + else + ret = mux_of_xlate_default(mux_chip, &args, mux); + if (ret) { + debug("of_xlate() failed: %d\n", ret); + return ret; + } + (*mux)->dev = dev_mux; + + return 0; +} + +int mux_get_by_index(struct udevice *dev, int index, struct mux_control **mux) +{ + return mux_get_by_indexed_prop(dev, "mux-controls", index, mux); +} + +int mux_control_get(struct udevice *dev, const char *name, + struct mux_control **mux) +{ + int index; + + debug("%s(dev=%p, name=%s, mux=%p)\n", __func__, dev, name, mux); + + index = dev_read_stringlist_search(dev, "mux-control-names", name); + if (index < 0) { + debug("fdt_stringlist_search() failed: %d\n", index); + return index; + } + + return mux_get_by_index(dev, index, mux); +} + +void mux_control_put(struct mux_control *mux) +{ + mux_control_deselect(mux); +} + +static void devm_mux_control_release(struct udevice *dev, void *res) +{ + mux_control_put(*(struct mux_control **)res); +} + +struct mux_control *devm_mux_control_get(struct udevice *dev, const char *id) +{ + int rc; + struct mux_control **mux; + + mux = devres_alloc(devm_mux_control_release, + sizeof(struct mux_control *), __GFP_ZERO); + if (unlikely(!mux)) + return ERR_PTR(-ENOMEM); + + rc = mux_control_get(dev, id, mux); + if (rc) + return ERR_PTR(rc); + + devres_add(dev, mux); + return *mux; +} + +int mux_alloc_controllers(struct udevice *dev, unsigned int controllers) +{ + int i; + struct mux_chip *mux_chip = dev_get_uclass_priv(dev); + + mux_chip->mux = devm_kmalloc(dev, + sizeof(struct mux_control) * controllers, + __GFP_ZERO); + if (!mux_chip->mux) + return -ENOMEM; + + mux_chip->controllers = controllers; + + for (i = 0; i < mux_chip->controllers; ++i) { + struct mux_control *mux = &mux_chip->mux[i]; + + mux->dev = dev; + mux->cached_state = MUX_CACHE_UNKNOWN; + mux->idle_state = MUX_IDLE_AS_IS; + mux->in_use = false; + mux->id = i; + } + + return 0; +} + +int mux_uclass_post_probe(struct udevice *dev) +{ + int i, ret; + struct mux_chip *mux_chip = dev_get_uclass_priv(dev); + + for (i = 0; i < mux_chip->controllers; ++i) { + struct mux_control *mux = &mux_chip->mux[i]; + + if (mux->idle_state == mux->cached_state) + continue; + + ret = mux_control_set(mux, mux->idle_state); + if (ret < 0) { + dev_err(&mux_chip->dev, "unable to set idle state\n"); + return ret; + } + } + return 0; +} + +UCLASS_DRIVER(mux) = { + .id = UCLASS_MUX, + .name = "mux", + .post_probe = mux_uclass_post_probe, + .per_device_auto_alloc_size = sizeof(struct mux_chip), +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 0c563d898b..28822689a9 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -66,6 +66,7 @@ enum uclass_id { UCLASS_MMC, /* SD / MMC card or chip */ UCLASS_MOD_EXP, /* RSA Mod Exp device */ UCLASS_MTD, /* Memory Technology Device (MTD) device */ + UCLASS_MUX, /* Multiplexer device */ UCLASS_NOP, /* No-op devices */ UCLASS_NORTHBRIDGE, /* Intel Northbridge / SDRAM controller */ UCLASS_NVME, /* NVM Express device */ diff --git a/include/dt-bindings/mux/mux.h b/include/dt-bindings/mux/mux.h new file mode 100644 index 0000000000..042719218d --- /dev/null +++ b/include/dt-bindings/mux/mux.h @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides constants for most Multiplexer bindings. + * + * Most Multiplexer bindings specify an idle state. In most cases, the + * the multiplexer can be left as is when idle, and in some cases it can + * disconnect the input/output and leave the multiplexer in a high + * impedance state. + */ + +#ifndef _DT_BINDINGS_MUX_MUX_H +#define _DT_BINDINGS_MUX_MUX_H + +#define MUX_IDLE_AS_IS (-1) +#define MUX_IDLE_DISCONNECT (-2) + +#endif diff --git a/include/mux-internal.h b/include/mux-internal.h new file mode 100644 index 0000000000..c590bd0c74 --- /dev/null +++ b/include/mux-internal.h @@ -0,0 +1,103 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Based on the linux multiplexer framework + * + * Copyright (C) 2017 Axentia Technologies AB + * Author: Peter Rosin peda@axentia.se + * + * Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ + * Jean-Jacques Hiblot jjhiblot@ti.com + */ + +#ifndef _MUX_UCLASS_H +#define _MUX_UCLASS_H + +/* See mux.h for background documentation. */ + +#include <mux.h> + +struct ofnode_phandle_args; + +/** + * struct mux_chip - Represents a chip holding mux controllers. + * @controllers: Number of mux controllers handled by the chip. + * @mux: Array of mux controllers that are handled. + * @dev: Device structure. + * @ops: Mux controller operations. + * + * This a per-device uclass-private data. + */ +struct mux_chip { + unsigned int controllers; + struct mux_control *mux; +}; + +/** + * struct mux_control_ops - Mux controller operations for a mux chip. + * @set: Set the state of the given mux controller. + */ +struct mux_control_ops { + /** + * set - Apply a state to a multiplexer control + * + * @mux: A multiplexer control + * @return 0 if OK, or a negative error code. + */ + int (*set)(struct mux_control *mux, int state); + + /** + * of_xlate - Translate a client's device-tree (OF) multiplexer + * specifier. + * + * If this function pointer is set to NULL, the multiplexer core will + * use a default implementation, which assumes #mux-control-cells = <1> + * and that the DT cell contains a simple integer channel ID. + * + * @dev_mux: The multiplexer device. A single device may handle + * several multiplexer controls. + * @args: The multiplexer specifier values from device tree. + * @mux: (out) A multiplexer control + * @return 0 if OK, or a negative error code. + */ + int (*of_xlate)(struct mux_chip *dev_mux, + struct ofnode_phandle_args *args, + struct mux_control **mux); +}; + +/** + * struct mux_control - Represents a mux controller. + * @chip: The mux chip that is handling this mux controller. + * @cached_state: The current mux controller state, or -1 if none. + * @states: The number of mux controller states. + * @idle_state: The mux controller state to use when inactive, or one + * of MUX_IDLE_AS_IS and MUX_IDLE_DISCONNECT. + * + * Mux drivers may only change @states and @idle_state, and may only do so + * between allocation and registration of the mux controller. Specifically, + * @cached_state is internal to the mux core and should never be written by + * mux drivers. + */ +struct mux_control { + bool in_use; + struct udevice *dev; + int cached_state; + unsigned int states; + int idle_state; + int id; +}; + +/** + * mux_control_get_index() - Get the index of the given mux controller + * @mux: The mux-control to get the index for. + * + * Return: The index of the mux controller within the mux chip the mux + * controller is a part of. + */ +static inline unsigned int mux_control_get_index(struct mux_control *mux) +{ + return mux->id; +} + +int mux_alloc_controllers(struct udevice *dev, unsigned int controllers); + +#endif diff --git a/include/mux.h b/include/mux.h new file mode 100644 index 0000000000..060f71a47c --- /dev/null +++ b/include/mux.h @@ -0,0 +1,113 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Based on the linux multiplexer framework + * + * At its core, a multiplexer (or mux), also known as a data selector, is a + * device that selects between several analog or digital input signals and + * forwards it to a single output line. This notion can be extended to work + * with buses, like a I2C bus multiplexer for example. + * + * Copyright (C) 2017 Axentia Technologies AB + * Author: Peter Rosin peda@axentia.se + * + * Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ + * Jean-Jacques Hiblot jjhiblot@ti.com + */ + +#ifndef _MUX_H_ +#define _MUX_H_ + +#include <linux/errno.h> +#include <linux/types.h> + +struct udevice; +struct mux_control; + +#if CONFIG_IS_ENABLED(MULTIPLEXER) +/** + * mux_control_states() - Query the number of multiplexer states. + * @mux: The mux-control to query. + * + * Return: The number of multiplexer states. + */ +unsigned int mux_control_states(struct mux_control *mux); + +/** + * mux_control_select() - Select the given multiplexer state. + * @mux: The mux-control to request a change of state from. + * @state: The new requested state. + * + * On successfully selecting the mux-control state, it will be locked until + * there is a call to mux_control_deselect(). If the mux-control is already + * selected when mux_control_select() is called, the function will indicate + * -EBUSY + * + * Therefore, make sure to call mux_control_deselect() when the operation is + * complete and the mux-control is free for others to use, but do not call + * mux_control_deselect() if mux_control_select() fails. + * + * Return: 0 when the mux-control state has the requested state or a negative + * errno on error. + */ +int __must_check mux_control_select(struct mux_control *mux, + unsigned int state); +#define mux_control_try_select(mux) mux_control_select(mux) + +/** + * mux_control_deselect() - Deselect the previously selected multiplexer state. + * @mux: The mux-control to deselect. + * + * It is required that a single call is made to mux_control_deselect() for + * each and every successful call made to either of mux_control_select() or + * mux_control_try_select(). + * + * Return: 0 on success and a negative errno on error. An error can only + * occur if the mux has an idle state. Note that even if an error occurs, the + * mux-control is unlocked and is thus free for the next access. + */ +int mux_control_deselect(struct mux_control *mux); + +int mux_get_by_index(struct udevice *dev, int index, struct mux_control **mux); +int mux_control_get(struct udevice *dev, const char *name, + struct mux_control **mux); + +void mux_control_put(struct mux_control *mux); + +struct mux_control *devm_mux_control_get(struct udevice *dev, + const char *mux_name); +#else +unsigned int mux_control_states(struct mux_control *mux) +{ + return -ENOSYS; +} + +int __must_check mux_control_select(struct mux_control *mux, + unsigned int state) +{ + return -ENOSYS; +} + +#define mux_control_try_select(mux) mux_control_select(mux) + +int mux_control_deselect(struct mux_control *mux) +{ + return -ENOSYS; +} + +struct mux_control *mux_control_get(struct udevice *dev, const char *mux_name) +{ + return NULL; +} + +void mux_control_put(struct mux_control *mux) +{ +} + +struct mux_control *devm_mux_control_get(struct udevice *dev, + const char *mux_name) +{ + return NULL; +} +#endif + +#endif
Hi Jean-Jacques,
Changes in v2:
- Fixed SPL build
+config MULTIPLEXER
depends on DM
Please add help here.
- Multiplexer subsystem
- Based on the linux multiplexer framework
- Copyright (C) 2017 Axentia Technologies AB
- Author: Peter Rosin peda@axentia.se
- Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/
- Jean-Jacques Hiblot jjhiblot@ti.com
- The idle-as-is "state" is not an actual state that may be selected, it
- only implies that the state should not be changed. So, use that state
- as indication that the cached state of the multiplexer is unknown.
Please add comments to these static functions.
return ret;
return mux->states;
int ret;
return -EINVAL;
if (ret >= 0)
return ret;
int ret;
if (mux->in_use)
return -EBUSY;
if (ret < 0)
return ret;
mux->in_use = true;
int ret = 0;
return ret;
int id;
Could use log_debug() perhaps?
return -EINVAL;
id = args->args[0];
else
id = 0;
return -ERANGE;
mux->id = id;
*muxp = mux;
Again please comment these static functions.
int ret;
0, index, &args);
if (ret) {
__func__, ret);
return ret;
if (ret) {
__func__, ret);
return ret;
if (ops->of_xlate)
else
if (ret) {
return ret;
int index;
if (index < 0) {
return index;
This should return an integer error with mux_control as a parameter passed in by the caller, not allocated here. The madness below and in the caller to convert everything to pointers makes no sense to me.
int rc;
if (unlikely(!mux))
Then you don't need to alloc this since it is passed in.
if (rc)
return ERR_PTR(rc);
return *mux;
This function needs comments in its header file.
int i;
__GFP_ZERO);
if (!mux_chip->mux)
return -ENOMEM;
mux->dev = dev;
mux->id = i;
static
int i, ret;
Can you add a comment here as to what this is doing?
continue;
if (ret < 0) {
return ret;
.id = UCLASS_MUX,
.name = "mux",
- This header provides constants for most Multiplexer bindings.
- Most Multiplexer bindings specify an idle state. In most cases, the
- the multiplexer can be left as is when idle, and in some cases it can
- disconnect the input/output and leave the multiplexer in a high
- impedance state.
MUX_INTERNAL
+#include <mux.h>
Can you drop this? I don't think it is needed.
- struct mux_chip - Represents a chip holding mux controllers.
- @controllers: Number of mux controllers handled by the chip.
- @mux: Array of mux controllers that are handled.
- @dev: Device structure.
- @ops: Mux controller operations.
Doesn't seem to match the struct.
- This a per-device uclass-private data.
+struct mux_chip {
- struct mux_control_ops - Mux controller operations for a mux chip.
- @set: Set the state of the given mux controller.
* specifier.
Can you rename @muxp with the 'p' indicating it is a pointer to the value? This is the convention in driver model.
- struct mux_control - Represents a mux controller.
- @chip: The mux chip that is handling this mux controller.
- @cached_state: The current mux controller state, or -1 if none.
- @states: The number of mux controller states.
- @idle_state: The mux controller state to use when inactive, or one
Missing comments on a few fields
- Mux drivers may only change @states and @idle_state, and may only do so
- between allocation and registration of the mux controller. Specifically,
- @cached_state is internal to the mux core and should never be written by
- mux drivers.
bool in_use;
int cached_state;
int idle_state;
int id;
- mux_control_get_index() - Get the index of the given mux controller
- @mux: The mux-control to get the index for.
- Return: The index of the mux controller within the mux chip the mux
- controller is a part of.
return mux->id;
That explains the lack of comments I suppose! But we need to add them tor U-Boot.
- At its core, a multiplexer (or mux), also known as a data selector, is a
- device that selects between several analog or digital input signals and
- forwards it to a single output line. This notion can be extended to work
- with buses, like a I2C bus multiplexer for example.
- mux_control_states() - Query the number of multiplexer states.
- @mux: The mux-control to query.
- Return: The number of multiplexer states.
- mux_control_select() - Select the given multiplexer state.
- @mux: The mux-control to request a change of state from.
- @state: The new requested state.
- On successfully selecting the mux-control state, it will be locked until
- there is a call to mux_control_deselect(). If the mux-control is already
- selected when mux_control_select() is called, the function will indicate
- -EBUSY
- Therefore, make sure to call mux_control_deselect() when the operation is
- complete and the mux-control is free for others to use, but do not call
- mux_control_deselect() if mux_control_select() fails.
- Return: 0 when the mux-control state has the requested state or a negative
- errno on error.
- mux_control_deselect() - Deselect the previously selected multiplexer state.
- @mux: The mux-control to deselect.
- It is required that a single call is made to mux_control_deselect() for
- each and every successful call made to either of mux_control_select() or
- mux_control_try_select().
- Return: 0 on success and a negative errno on error. An error can only
- occur if the mux has an idle state. Note that even if an error occurs, the
- mux-control is unlocked and is thus free for the next access.
Many functions missing comments here.
return -ENOSYS;
unsigned int state)
return -ENOSYS;
return -ENOSYS;
return NULL;
return NULL;
+} +#endif
2.17.1
This will probe the multiplexer devices that have a "u-boot,mux-autoprobe" property. As a consequence they will be put in their idle state.
Changes in v2: - insert the mux initialization in init_sequence_r[], just before the console is initialized as its serial port may be muxed - moved the definition of dm_mux_init() in this commit
common/board_r.c | 16 ++++++++++++++++ drivers/mux/mux-uclass.c | 22 ++++++++++++++++++++++ include/mux.h | 2 ++ 3 files changed, 40 insertions(+)
diff --git a/common/board_r.c b/common/board_r.c index c1ecb06b74..3d410f3504 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -32,6 +32,7 @@ #include <miiphy.h> #endif #include <mmc.h> +#include <mux.h> #include <nand.h> #include <of_live.h> #include <onenand_uboot.h> @@ -178,6 +179,18 @@ static int initr_serial(void) return 0; }
+#if CONFIG_MULTIPLEXER +static int initr_mux(void) +{ + /* + * Initialize the multiplexer controls to their default state. + * This must be done early as other drivers may unknowingly rely on it. + */ + dm_mux_init(); + return 0; +} +#endif + #if defined(CONFIG_PPC) || defined(CONFIG_M68K) || defined(CONFIG_MIPS) static int initr_trap(void) { @@ -691,6 +704,9 @@ static init_fnc_t init_sequence_r[] = { #endif #ifdef CONFIG_EFI_LOADER efi_memory_init, +#endif +#if CONFIG_MULTIPLEXER + initr_mux, #endif stdio_init_tables, initr_serial, diff --git a/drivers/mux/mux-uclass.c b/drivers/mux/mux-uclass.c index 6aaf4dc964..71392e9e50 100644 --- a/drivers/mux/mux-uclass.c +++ b/drivers/mux/mux-uclass.c @@ -262,6 +262,28 @@ int mux_uclass_post_probe(struct udevice *dev) return 0; }
+void dm_mux_init(void) +{ + struct uclass *uc; + struct udevice *dev; + int ret; + + ret = uclass_get(UCLASS_MUX, &uc); + if (ret < 0) { + debug("unable to get MUX uclass\n"); + return; + } + uclass_foreach_dev(dev, uc) { + if (dev_read_bool(dev, "u-boot,mux-autoprobe")) { + ret = device_probe(dev); + if (ret) + debug("unable to probe device %s\n", dev->name); + } else { + printf("not found for dev %s\n", dev->name); + } + } +} + UCLASS_DRIVER(mux) = { .id = UCLASS_MUX, .name = "mux", diff --git a/include/mux.h b/include/mux.h index 060f71a47c..2467723951 100644 --- a/include/mux.h +++ b/include/mux.h @@ -75,6 +75,8 @@ void mux_control_put(struct mux_control *mux);
struct mux_control *devm_mux_control_get(struct udevice *dev, const char *mux_name); +void dm_mux_init(void); + #else unsigned int mux_control_states(struct mux_control *mux) {
Hi JJ,
- struct uclass *uc;
- struct udevice *dev;
- int ret;
- ret = uclass_get(UCLASS_MUX, &uc);
- if (ret < 0) {
return;
- uclass_foreach_dev(dev, uc) {
if (ret)
} else {
Is "u-boot,mux-autoprobe" a required property? The fact that its in DT makes me think its optional. If that's the case, above printf() should be reduced to debug() to avoid confusion
On 05/11/2019 14:05, Vignesh Raghavendra wrote:
Hi JJ,
- int ret;
- if (ret < 0) {
return;
if (ret)
} else {
Thanks Vignesh. It was for debug and forgot to remove it.
- UCLASS_DRIVER(mux) = { .id = UCLASS_MUX, .name = "mux",
- #else unsigned int mux_control_states(struct mux_control *mux) {
Hi Jean-Jacques,
Changes in v2:
dm_mux_init();
Needs to get an error code and at least log_debug() it here, even if it continues.
Can you rebase on x86/next? It has a initr_dm_devices() function which you can add this to.
initr_mux,
struct uclass *uc;
int ret;
if (ret < 0) {
return;
return ret
This should be a fatal error.
if (ret)
Doesn't this need to be reported to the caller?
} else {
What does this mean? If autoprobe is off we can't find the device? I suggest changing the message, and debug() as Vignesh suggests.
Function comments again.
#else unsigned int mux_control_states(struct mux_control *mux) { -- 2.17.1
This adds a driver for mmio-based syscon multiplexers controlled by bitfields in a syscon register range. This is heavily based on the linux mmio-mux driver.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
Changes in v2: None
drivers/mux/Kconfig | 15 +++++ drivers/mux/Makefile | 1 + drivers/mux/mmio.c | 155 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 171 insertions(+) create mode 100644 drivers/mux/mmio.c
diff --git a/drivers/mux/Kconfig b/drivers/mux/Kconfig index ad0199c058..bda6a2d9f5 100644 --- a/drivers/mux/Kconfig +++ b/drivers/mux/Kconfig @@ -4,4 +4,19 @@ config MULTIPLEXER bool "Multiplexer Support" depends on DM
+ +if MULTIPLEXER + +config MUX_MMIO + bool "MMIO register bitfield-controlled Multiplexer" + depends on MULTIPLEXER && SYSCON + help + MMIO register bitfield-controlled Multiplexer controller. + + The driver builds multiplexer controllers for bitfields in a syscon + register. For N bit wide bitfields, there will be 2^N possible + multiplexer states. + +endif + endmenu diff --git a/drivers/mux/Makefile b/drivers/mux/Makefile index 351e4363d3..78ebf04c7a 100644 --- a/drivers/mux/Makefile +++ b/drivers/mux/Makefile @@ -4,3 +4,4 @@ # Jean-Jacques Hiblot jjhiblot@ti.com
obj-$(CONFIG_$(SPL_)MULTIPLEXER) += mux-uclass.o +obj-$(CONFIG_$(SPL_)MUX_MMIO) += mmio.o diff --git a/drivers/mux/mmio.c b/drivers/mux/mmio.c new file mode 100644 index 0000000000..a9faaeb9fd --- /dev/null +++ b/drivers/mux/mmio.c @@ -0,0 +1,155 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * MMIO register bitfield-controlled multiplexer driver + * Based on the linux mmio multiplexer driver + * + * Copyright (C) 2017 Pengutronix, Philipp Zabel kernel@pengutronix.de + * Copyright (C) 2019 Texas Instrument, Jean-jacques Hiblot jjhiblot@ti.com + */ +#include <common.h> +#include <dm.h> +#include <mux-internal.h> +#include <regmap.h> +#include <syscon.h> +#include <dm/device.h> +#include <dm/read.h> +#include <dt-bindings/mux/mux.h> + +static int mux_mmio_set(struct mux_control *mux, int state) +{ + struct regmap_field **fields = dev_get_priv(mux->dev); + + return regmap_field_write(fields[mux_control_get_index(mux)], state); +} + +static const struct mux_control_ops mux_mmio_ops = { + .set = mux_mmio_set, +}; + +static const struct udevice_id mmio_mux_of_match[] = { + { .compatible = "mmio-mux" }, + { /* sentinel */ }, +}; + +static int mmio_mux_probe(struct udevice *dev) +{ + struct regmap_field **fields; + struct mux_chip *mux_chip = dev_get_uclass_priv(dev); + struct regmap *regmap; + u32 *mux_reg_masks; + u32 *idle_states; + int num_fields; + int ret; + int i; + + regmap = syscon_node_to_regmap(dev_ofnode(dev->parent)); + if (IS_ERR(regmap)) { + ret = PTR_ERR(regmap); + dev_err(dev, "failed to get regmap: %d\n", ret); + return ret; + } + + num_fields = dev_read_size(dev, "mux-reg-masks"); + if (num_fields < 0) { + dev_err(dev, "mux-reg-masks property missing or invalid: %d\n", + num_fields); + return num_fields; + } + num_fields /= sizeof(u32); + if (num_fields == 0 || num_fields % 2) + ret = -EINVAL; + num_fields = num_fields / 2; + + ret = mux_alloc_controllers(dev, num_fields); + if (ret < 0) { + dev_err(dev, "failed to allocate mux controllers: %d\n", + ret); + return ret; + } + + fields = devm_kmalloc(dev, num_fields * sizeof(*fields), __GFP_ZERO); + if (!fields) + return -ENOMEM; + dev->priv = fields; + + mux_reg_masks = devm_kmalloc(dev, num_fields * 2 * sizeof(u32), + __GFP_ZERO); + if (!mux_reg_masks) + return -ENOMEM; + + ret = dev_read_u32_array(dev, "mux-reg-masks", mux_reg_masks, + num_fields * 2); + if (ret < 0) { + dev_err(dev, "failed to read mux-reg-masks property: %d\n", + ret); + return ret; + } + + idle_states = devm_kmalloc(dev, num_fields * sizeof(u32), __GFP_ZERO); + if (!idle_states) + return -ENOMEM; + + ret = dev_read_u32_array(dev, "idle-states", idle_states, num_fields); + if (ret < 0) { + dev_err(dev, "failed to read idle-states property: %d\n", + ret); + devm_kfree(dev, idle_states); + idle_states = NULL; + } + + for (i = 0; i < num_fields; i++) { + struct mux_control *mux = &mux_chip->mux[i]; + struct reg_field field; + u32 reg, mask; + int bits; + + reg = mux_reg_masks[2 * i]; + mask = mux_reg_masks[2 * i + 1]; + + field.reg = reg; + field.msb = fls(mask) - 1; + field.lsb = ffs(mask) - 1; + + if (mask != GENMASK(field.msb, field.lsb)) { + dev_err(dev, "bitfield %d: invalid mask 0x%x\n", + i, mask); + return -EINVAL; + } + + fields[i] = devm_regmap_field_alloc(dev, regmap, field); + if (IS_ERR(fields[i])) { + ret = PTR_ERR(fields[i]); + dev_err(dev, "bitfield %d: failed allocate: %d\n", + i, ret); + return ret; + } + + bits = 1 + field.msb - field.lsb; + mux->states = 1 << bits; + + if (!idle_states) + continue; + + if (idle_states[i] != MUX_IDLE_AS_IS && + idle_states[i] >= mux->states) { + dev_err(dev, "bitfield: %d: out of range idle state %d\n", + i, idle_states[i]); + return -EINVAL; + } + mux->idle_state = idle_states[i]; + } + + devm_kfree(dev, mux_reg_masks); + if (idle_states) + devm_kfree(dev, idle_states); + + return 0; +} + +U_BOOT_DRIVER(mmio_mux) = { + .name = "mmio-mux", + .id = UCLASS_MUX, + .of_match = mmio_mux_of_match, + .probe = mmio_mux_probe, + .ops = &mux_mmio_ops, +};
Hi JJ,
Changes in v2: None
do you plan to add support for reg-mux too, for parent devices which are not syscon?
Thanks! Alex
On 08/11/2019 13:16, Alexandru Marginean wrote:
Hi JJ,
Changes in v2: None
I haven't planned to work on it. I kept the framework close to the linux version, so porting mux drivers from linux shouldn't be hard.
JJ
Thanks! Alex
Hi Jean-Jacques,
Changes in v2: None
Nits below.
+if MULTIPLEXER
+config MUX_MMIO
help
multiplexer states.
+endif
- MMIO register bitfield-controlled multiplexer driver
- Based on the linux mmio multiplexer driver
- Copyright (C) 2017 Pengutronix, Philipp Zabel kernel@pengutronix.de
- Copyright (C) 2019 Texas Instrument, Jean-jacques Hiblot jjhiblot@ti.com
{ /* sentinel */ },
u32 *mux_reg_masks;
u32 *idle_states;
int num_fields;
int ret;
int i;
return ret;
num_fields);
These seem like errors that should not happen in a real system.
You could use
return log_msg_ret("mux-reg-masks" ,-EINVAL)
which reduces to nothing unless CONFIG_LOG_ERROR_RETURN is set.
That gives a nice backtrace of all errors that happened with a little string tag to explain each one.
return num_fields;
ret = -EINVAL;
if (ret < 0) {
ret);
Same here and below. Seems like a waste to include this string when we are just out of memory.
return ret;
if (!fields)
return -ENOMEM;
dev->priv = fields;
__GFP_ZERO);
if (!mux_reg_masks)
return -ENOMEM;
num_fields * 2);
if (ret < 0) {
ret);
return ret;
if (!idle_states)
return -ENOMEM;
if (ret < 0) {
ret);
idle_states = NULL;
u32 reg, mask;
int bits;
field.reg = reg;
i, mask);
return -EINVAL;
i, ret);
return ret;
if (!idle_states)
continue;
i, idle_states[i]);
return -EINVAL;
if (idle_states)
.name = "mmio-mux",
.id = UCLASS_MUX,
2.17.1
Provide tests to check the behavior of the multiplexer framework. The test uses a mmio-based multiplexer.
Changes in v2: - Call sandbox_set_enable_memio(true) before running the test
arch/sandbox/dts/test.dts | 26 +++++++ configs/sandbox_defconfig | 2 + test/dm/Makefile | 1 + test/dm/mux-mmio.c | 147 ++++++++++++++++++++++++++++++++++++++ 4 files changed, 176 insertions(+) create mode 100644 test/dm/mux-mmio.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index aa9eaec338..3224a8389c 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -1,3 +1,5 @@ +#include <dt-bindings/mux/mux.h> + /dts-v1/;
/ { @@ -93,6 +95,11 @@ <&gpio_b 9 0xc 3 2 1>; int-value = <1234>; uint-value = <(-1234)>; + + mux-controls = <&muxcontroller0 0>, <&muxcontroller0 1>, + <&muxcontroller0 2>, <&muxcontroller0 3>; + mux-control-names = "mux0", "mux1", "mux2", "mux3"; + mux-syscon = <&syscon3>; };
junk { @@ -129,6 +136,9 @@ compatible = "denx,u-boot-fdt-test"; ping-expect = <3>; ping-add = <3>; + + mux-controls = <&muxcontroller0 0>; + mux-control-names = "mux0"; };
phy_provider0: gen_phy@0 { @@ -665,6 +675,22 @@ 0x58 8>; };
+ syscon3: syscon@3 { + compatible = "simple-mfd", "syscon"; + reg = <0x000100 0x10>; + + muxcontroller0: a-mux-controller { + compatible = "mmio-mux"; + #mux-control-cells = <1>; + + mux-reg-masks = <0x0 0x30>, /* 0: reg 0x0, bits 5:4 */ + <0x3 0x1E>, /* 1: reg 0x3, bits 4:1 */ + <0x1 0xFF>; /* 2: reg 0x1, bits 7:0 */ + idle-states = <MUX_IDLE_AS_IS>, <0x02>, <0x73>; + u-boot,mux-autoprobe; + }; + }; + timer { compatible = "sandbox,timer"; clock-frequency = <1000000>; diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 20ebc68997..2822dd9c74 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -144,6 +144,8 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_MULTIPLEXER=y +CONFIG_MUX_MMIO=y CONFIG_DM_ETH=y CONFIG_NVME=y CONFIG_PCI=y diff --git a/test/dm/Makefile b/test/dm/Makefile index 0c2fd5cb5e..a3fc23e527 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -47,6 +47,7 @@ obj-$(CONFIG_DM_SPI_FLASH) += sf.o obj-$(CONFIG_SMEM) += smem.o obj-$(CONFIG_DM_SPI) += spi.o obj-y += syscon.o +obj-$(CONFIG_MUX_MMIO) += mux-mmio.o obj-$(CONFIG_DM_USB) += usb.o obj-$(CONFIG_DM_PMIC) += pmic.o obj-$(CONFIG_DM_REGULATOR) += regulator.o diff --git a/test/dm/mux-mmio.c b/test/dm/mux-mmio.c new file mode 100644 index 0000000000..a3dfd34120 --- /dev/null +++ b/test/dm/mux-mmio.c @@ -0,0 +1,147 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ + * Jean-Jacques Hiblot jjhiblot@ti.com + */ + +#include <common.h> +#include <fdtdec.h> +#include <dm.h> +#include <mux.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/test.h> +#include <dm/root.h> +#include <dm/test.h> +#include <dm/util.h> +#include <test/ut.h> + +/* Test that mmio mux work correctly */ +static int dm_test_mux_mmio(struct unit_test_state *uts) +{ + struct udevice *dev, *dev_b; + struct regmap *map; + struct mux_control *ctl0_a, *ctl0_b; + struct mux_control *ctl1; + struct mux_control *ctl_err; + u32 val; + int i; + + sandbox_set_enable_memio(true); + + ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 0, &dev)); + ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 1, &dev_b)); + ut_asserteq_str("a-test", dev->name); + ut_asserteq_str("b-test", dev_b->name); + map = syscon_regmap_lookup_by_phandle(dev, "mux-syscon"); + ut_assert(!IS_ERR(map)); + ut_assert(map); + + /* check default states */ + ut_assertok(regmap_read(map, 3, &val)); + ut_asserteq(0x02, (val & 0x1E) >> 1); + ut_assertok(regmap_read(map, 1, &val)); + ut_asserteq(0x73, (val & 0xFF) >> 0); + + ut_assertok(mux_control_get(dev, "mux0", &ctl0_a)); + ut_assertok(mux_control_get(dev, "mux1", &ctl1)); + ut_asserteq(-ERANGE, mux_control_get(dev, "mux3", &ctl_err)); + ut_asserteq(-ENODATA, mux_control_get(dev, "dummy", &ctl_err)); + ut_assertok(mux_control_get(dev_b, "mux0", &ctl0_b)); + + for (i = 0; i < mux_control_states(ctl0_a); i++) { + /* select a new state and verify the value in the regmap */ + ut_assertok(mux_control_select(ctl0_a, i)); + ut_assertok(regmap_read(map, 0, &val)); + ut_asserteq(i, (val & 0x30) >> 4); + /* + * deselect the mux and verify that the value in the regmap + * reflects the idle state (fixed to MUX_IDLE_AS_IS) + */ + ut_assertok(mux_control_deselect(ctl0_a)); + ut_assertok(regmap_read(map, 0, &val)); + ut_asserteq(i, (val & 0x30) >> 4); + } + + for (i = 0; i < mux_control_states(ctl1); i++) { + /* select a new state and verify the value in the regmap */ + ut_assertok(mux_control_select(ctl1, i)); + ut_assertok(regmap_read(map, 3, &val)); + ut_asserteq(i, (val & 0x1E) >> 1); + /* + * deselect the mux and verify that the value in the regmap + * reflects the idle state (fixed to 2) + */ + ut_assertok(mux_control_deselect(ctl1)); + ut_assertok(regmap_read(map, 3, &val)); + ut_asserteq(2, (val & 0x1E) >> 1); + } + + // try unbalanced selection/deselection + ut_assertok(mux_control_select(ctl0_a, 0)); + ut_asserteq(-EBUSY, mux_control_select(ctl0_a, 1)); + ut_asserteq(-EBUSY, mux_control_select(ctl0_a, 0)); + ut_assertok(mux_control_deselect(ctl0_a)); + + // try concurent selection + ut_assertok(mux_control_select(ctl0_a, 0)); + ut_assert(mux_control_select(ctl0_b, 0)); + ut_assertok(mux_control_deselect(ctl0_a)); + ut_assertok(mux_control_select(ctl0_b, 0)); + ut_assert(mux_control_select(ctl0_a, 0)); + ut_assertok(mux_control_deselect(ctl0_b)); + ut_assertok(mux_control_select(ctl0_a, 0)); + ut_assertok(mux_control_deselect(ctl0_a)); + + return 0; +} +DM_TEST(dm_test_mux_mmio, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test that managed API for mux work correctly */ +static int dm_test_devm_mux_mmio(struct unit_test_state *uts) +{ + struct udevice *dev, *dev_b; + struct mux_control *ctl0_a, *ctl0_b; + struct mux_control *ctl1; + struct mux_control *ctl_err; + + sandbox_set_enable_memio(true); + + ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 0, &dev)); + ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 1, &dev_b)); + ut_asserteq_str("a-test", dev->name); + ut_asserteq_str("b-test", dev_b->name); + + ctl0_a = devm_mux_control_get(dev, "mux0"); + ut_assertok(IS_ERR(ctl0_a)); + ut_assert(ctl0_a); + ctl1 = devm_mux_control_get(dev, "mux1"); + ut_assertok(IS_ERR(ctl1)); + ut_assert(ctl1); + ctl_err = devm_mux_control_get(dev, "mux3"); + ut_asserteq(-ERANGE, PTR_ERR(ctl_err)); + ctl_err = devm_mux_control_get(dev, "dummy"); + ut_asserteq(-ENODATA, PTR_ERR(ctl_err)); + + ctl0_b = devm_mux_control_get(dev_b, "mux0"); + ut_assertok(IS_ERR(ctl0_b)); + ut_assert(ctl0_b); + + /* try concurent selection */ + ut_assertok(mux_control_select(ctl0_a, 0)); + ut_assert(mux_control_select(ctl0_b, 0)); + ut_assertok(mux_control_deselect(ctl0_a)); + ut_assertok(mux_control_select(ctl0_b, 0)); + ut_assert(mux_control_select(ctl0_a, 0)); + ut_assertok(mux_control_deselect(ctl0_b)); + + /* removed one device and check that the mux is released */ + ut_assertok(mux_control_select(ctl0_a, 0)); + ut_assert(mux_control_select(ctl0_b, 0)); + device_remove(dev, DM_REMOVE_NORMAL); + ut_assertok(mux_control_select(ctl0_b, 0)); + + device_remove(dev_b, DM_REMOVE_NORMAL); + return 0; +} +DM_TEST(dm_test_devm_mux_mmio, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Hi Jean-Jacques,
Changes in v2:
nits below
/dts-v1/;
mux-syscon = <&syscon3>; }; junk {
mux-control-names = "mux0"; }; phy_provider0: gen_phy@0 {
syscon3: syscon@3 {
Missing header file for device_remove() here.
struct regmap *map;
u32 val;
int i;
ut_assert(map);
Tests should be short and targeted. Could this test be split up a bit>
concurrent
Please use C comment style.
Probably need to define ut_assert_not_err() or similar.
ut_assert(ctl0_a);
ut_assert(ctl1);
ut_assert(ctl0_b);
spelling again
2.17.1
Hi Jean-Jacques,
On Tue, 24 Dec 2019 at 08:58, Simon Glass sjg@chromium.org wrote:
Hi Jean-Jacques,
Changes in v2:
One more thing...I think this multiplexer thing need some documentation and an example (e.g. using sandbox).
Also we should have a mux command to list and control muxes.
Alexandru Marginean
Jean-Jacques Hiblot
Vignesh Raghavendra
