[U-Boot] [PATCH] [PATCH] net/eth.c: Avoid Warning when ethxaddr is not set
The return value for eth_getenv_enetaddr_by_index produces a Warning when ethXaddr is not set (env_enetaddr is equal to 00:00:00:00:00:00).
The validity of the mac address is tested later in this function to avoid to write an erroneous address.
The test of the function's return is consequently useless and adds a warning.
Signed-off-by: Gwenhael Goavec-Merou gwenhael.goavec-merou@armadeus.com --- net/eth.c | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/net/eth.c b/net/eth.c index b4b9b43..1e61aed 100644 --- a/net/eth.c +++ b/net/eth.c @@ -175,8 +175,7 @@ int eth_write_hwaddr(struct eth_device *dev, const char *base_name, unsigned char env_enetaddr[6]; int ret = 0;
- if (!eth_getenv_enetaddr_by_index(base_name, eth_number, env_enetaddr)) - return -1; + (void)eth_getenv_enetaddr_by_index(base_name, eth_number, env_enetaddr);
if (memcmp(env_enetaddr, "\0\0\0\0\0\0", 6)) { if (memcmp(dev->enetaddr, "\0\0\0\0\0\0", 6) &&
Dear Gwenhael Goavec-Merou,
In message 1330780211-90427-1-git-send-email-gwenhael.goavec-merou@armadeus.com you wrote:
Which use case do you have in mind? Why do you think this warning is bad? I tend to consider it helpful instead.
For boards with mac address stored on an eeprom for example, the variable ethaddr is not needed. But with this test, a warning is always shown, without any reason.
Best regards, Gwenhael Goavec-Merou
Dear "gwenhael.goavec",
The environment variable is always mandatory. If it does not exist, or if it's value is different from the one stored somewhere else, a warning shall be issued (and the environment value takes precedence).
So I think current behaviour is actually correct.
The code is not ideal - I suspect with a bit of improvement we can do the right thing in both cases. See the discussion started here:
http://lists.denx.de/pipermail/u-boot/2012-February/117783.html
I think this might be the third patch to do the same thing, so perhaps one of these people might like to take on the clean-up?
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de In the beginning, there was nothing, which exploded. - Terry Pratchett, _Lords and Ladies_
gwenhael.goavec
