Re: [U-Boot-Users] uboot porting on ARM926EJS
Look at the versatile.h inside uboot\include\configs folder for configuration & \uboot\board\versatile for board code & uboot\cpu\arm926ejs for cpu inits.
Files to look at : <board.h> inside uboot\include\configs ---> for uboot configuration( uart, flash, sdram address uboot configs, environment details and other features, <board.c> inside \uboot\board\ ---> for board init and configuration and also headers files as required. start.S inside uboot\cpu\arm926ejs for cpu init and startup script and other inits and also other files inside uboot\cpu\arm926ejs folder. driver and common files in uboot\common & uboot\drivers
If possible read README twice or thrice (this is what i did to know things better).
Regards Gururaja
________________________________
From: Pankaj PANDEY [mailto:pankaj.embedded@gmail.com] Sent: Monday, October 22, 2007 11:32 PM To: Gururaja Hebbar K R Subject: Re: [U-Boot-Users] uboot porting on ARM926EJS
Hi Gururaj,
Thanks for quick response, basically board not yet designed completly but board having a SOC in which ARM7, ARM9 and dsp preocessor are integrated on single chip. So my job is build and port a u-boot for ARM926ejs cpu. In which I need to know follow of u-boot initilization for ARM926ejs.
Thanks and Regard Pankaj
On 10/23/07, Hebbar gururajakr@sanyo.co.in wrote:
Hi Pankaj, Kindly let us know on what board you are working so that the solution can be narrowed down. for arm926ejs versatile board could be the best startup. Let me know what document you are looking for. Look at http://www.denx.de/wiki/DULG/Manual for better understanding. Also at http://docs.blackfin.uclinux.org/doku.php?id=das_u-boot_on_blackfin . this is for blackfin for can give good info Regards Gururaja Pankaj PANDEY-2 wrote: > > Hi Friends, > I am a new user on u-boot porting at ARM. I need some information or > documents that from where I can start to read about u-boot porting on > on > ARM926EJS. If anybody did this porting earlier, please I need your > important > suggestions. > > Thanks in Advance > Pankaj Pandey > > ------------------------------------------------------------------------ - > This SF.net email is sponsored by: Splunk Inc. > Still grepping through log files to find problems? Stop. > Now Search log events and configuration files using AJAX and a browser. > Download your FREE copy of Splunk now >> http://get.splunk.com/ > _______________________________________________ > U-Boot-Users mailing list > U-Boot-Users@lists.sourceforge.net > https://lists.sourceforge.net/lists/listinfo/u-boot-users > > -- View this message in context: http://www.nabble.com/uboot-porting-on-ARM926EJS-tf4671950.html#a1335759 3 Sent from the Uboot - Users mailing list archive at Nabble.com. ------------------------------------------------------------------------ - This SF.net email is sponsored by: Splunk Inc. Still grepping through log files to find problems? Stop. Now Search log events and configuration files using AJAX and a browser. Download your FREE copy of Splunk now >> http://get.splunk.com/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Gururaja Hebbar K R
