[RFC PATCH] env: Export environment config to OS devicetree
There are plenty of cases where the OS wants to know where the persistent environment is stored in order to print or manipulate it.
In most cases a userspace tool like libubootenv [1] is used to handle the environment. It uses hardcoded settings in a config file in the rootfs to determine the exact location of the environment.
In order to make systems more flexible and let userspace tools detect the location of the environment currently in use, let's add an option to export the runtime configuration to the FDT passed to the OS.
This is especially useful when your device is able to use multiple locations for the environment and the rootfs containing the fw_env.config file should be kept universal.
Currently the general information like location/type, size, offset and redundancy are exported. Userspace tools might already be able to guess the correct device to access based on this information.
For further device-specific information two additional properties 'id1' and 'id2' are used. The current implementation uses them for MMC and SPI FLASH like this:
| Type | id1 | id2 | | ---------- | -------------------------- | -------------------------- | | MMC | MMC device index in U-Boot | MMC hwpart index in U-Boot | | SPI FLASH | SPI bus index in U-Boot | SPI CS index in U-Boot |
Further extensions for other environment devices are possible.
We add the necessary information to the '/chosen' node. The following shows two examples:
Redundant environment in MMC:
/chosen { u-boot,env-config { location = <5>; # according to 'enum env_location' offset = <0x1E0000>; size = <0x100000>; sect_size = <0x100000>; id1 = <1>; # MMC device index id2 = <0>; # MMC HW partition index }; u-boot,env-redund-config { offset = <0x1F0000>; }; };
Redundant environment in SPI NOR:
/chosen { u-boot,env-config { location = <10>; # according to 'enum env_location' offset = <0x1E0000>; size = <0x100000>; sect_size = <0x100000>; id1 = <0>; # SPI bus id2 = <0>; # SPI CS }; u-boot,env-redund-config { offset = <0x1F0000>; }; };
See [2] for an example parser implementation for libubootenv.
[1] https://github.com/sbabic/libubootenv [2] https://github.com/fschrempf/libubootenv/commit/726a7ac9b1b1020354ee8fe750f4...
Cc: Stefano Babic sbabic@denx.de Cc: Michael Walle michael@walle.cc Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- boot/Kconfig | 9 ++++++++ boot/image-fdt.c | 8 ++++++++ env/env.c | 53 ++++++++++++++++++++++++++++++++++++++++++++++++ include/env.h | 4 ++++ 4 files changed, 74 insertions(+)
diff --git a/boot/Kconfig b/boot/Kconfig index e8fb03b801..16a94f9b35 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -702,6 +702,15 @@ config OF_BOARD_SETUP board-specific information in the device tree for use by the OS. The device tree is then passed to the OS.
+config OF_EXPORT_ENV_CONFIG + bool "Export environment config to device tree before boot" + depends on OF_LIBFDT + help + This causes U-Boot to call fdt_environment_config() before booting into + the operating system. This function exports the currently in use + environemnt configuration to the "chosen" node of the fdt. This allows + the OS to determine where the environment is located. + config OF_SYSTEM_SETUP bool "Set up system-specific details in device tree before boot" depends on OF_LIBFDT diff --git a/boot/image-fdt.c b/boot/image-fdt.c index f10200f647..c02c8f33ef 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -643,6 +643,14 @@ int image_setup_libfdt(struct bootm_headers *images, void *blob, /* Append PStore configuration */ fdt_fixup_pstore(blob); #endif + if (IS_ENABLED(CONFIG_OF_EXPORT_ENV_CONFIG)) { + fdt_ret = fdt_environment_config(blob); + if (fdt_ret) { + printf("ERROR: environment config fdt fixup failed: %s\n", + fdt_strerror(fdt_ret)); + goto err; + } + } if (IS_ENABLED(CONFIG_OF_BOARD_SETUP)) { const char *skip_board_fixup;
diff --git a/env/env.c b/env/env.c index 2aa52c98f8..a640977205 100644 --- a/env/env.c +++ b/env/env.c @@ -8,6 +8,7 @@ #include <env.h> #include <env_internal.h> #include <log.h> +#include <mmc.h> #include <asm/global_data.h> #include <linux/bitops.h> #include <linux/bug.h> @@ -156,6 +157,58 @@ __weak enum env_location env_get_location(enum env_operation op, int prio) return arch_env_get_location(op, prio); }
+#ifdef CONFIG_OF_EXPORT_ENV_CONFIG +int fdt_environment_config(void *blob) +{ + struct mmc *mmc; + u32 location; + int chosen_offs, offs; + int ret; + + if (CONFIG_IS_ENABLED(ENV_IS_NOWHERE)) + return 0; + + chosen_offs = fdt_path_offset(blob, "/chosen"); + if (chosen_offs < 0) { + printf("Could not find chosen node.\n"); + return chosen_offs; + } + + offs = fdt_add_subnode(blob, chosen_offs, "u-boot,env-config"); + if (offs < 0) { + printf("Could not create env-config node.\n"); + return offs; + } + + location = env_get_location(0, 0); + fdt_setprop_u32(blob, offs, "location", location); + fdt_setprop_u32(blob, offs, "offset", CONFIG_ENV_OFFSET); + fdt_setprop_u32(blob, offs, "size", CONFIG_ENV_SIZE); + fdt_setprop_u32(blob, offs, "sect_size", CONFIG_ENV_SECT_SIZE); + + if (CONFIG_IS_ENABLED(ENV_IS_IN_MMC) && location == ENVL_MMC) { + fdt_setprop_u32(blob, offs, "id1", mmc_get_env_dev()); + mmc = find_mmc_device(mmc_get_env_dev()); + if (mmc) + fdt_setprop_u32(blob, offs, "id2", mmc_get_env_part(mmc)); + } else if (CONFIG_IS_ENABLED(ENV_IS_IN_SPI_FLASH) && location == ENVL_SPI_FLASH) { + fdt_setprop_u32(blob, offs, "id1", CONFIG_ENV_SPI_BUS); + fdt_setprop_u32(blob, offs, "id2", CONFIG_ENV_SPI_CS); + } + + if (CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT)) { + offs = fdt_add_subnode(blob, chosen_offs, "u-boot,env-redund-config"); + if (offs < 0) { + printf("Could not create env-redund-config node.\n"); + return offs; + } + fdt_setprop_u32(blob, offs, "offset", CONFIG_ENV_OFFSET_REDUND); + } + + return 0; +} +#endif + /** * env_driver_lookup() - Finds the most suited environment location * @op: operations performed on the environment diff --git a/include/env.h b/include/env.h index 1480efa59e..f9b45a4925 100644 --- a/include/env.h +++ b/include/env.h @@ -377,4 +377,8 @@ void env_import_fdt(void); static inline void env_import_fdt(void) {} #endif
+#ifdef CONFIG_OF_EXPORT_ENV_CONFIG +int fdt_environment_config(void *blob); +#endif + #endif
Hi Frieder,
...or the configuration file is generated, or it is located on a rw (overlayfs) partition.
Ok
One possible issue is there is a hard dependency between the properties set in DT and the user space tool. The tool in user space is bound to the list of properties, and changes / extensions for the user tool requires changes in DT semantics (which properties, their path, etc).
The same hard dependency is set by fw_env.config with its strong hardcoded and position dependent syntax. This one of the reason I introduced YAML support in libubootenv, so that the user tool is independent and can add own properties.
I am just asking if this use case requires a new interface, or it is already available in some way. I mean, the configuration is YAML instead of fw_env.config and contains multiple setup ("namespaces"), like:
mmc: size : 0x100000 lockfile : /var/lock/fw_printenv.lock devices: - path : /dev/mmcblk0boot0 offset : 0x1E0000 sectorsize : 0x100000 - path : /dev/mmcblk0boot0 offset : 0x1E0000 sectorsize : 0x100000 spi: size : 0x100000 lockfile : /var/lock/fw_printenv.lock devices: - path : /dev/mtd0 offset : 0x1E0000 sectorsize : 0x100000 - path : /dev/mtd0 offset : 0x1F0000 sectorsize : 0x100000
This configuration file can safely stored in your common rootfs and covers all possible storage for environment. It does not cover "runtime" changes, but well, I do not think this is a use case.
An advantage here is that new options, useful for the User Space tool, can be simply introduced for the tool without the need to synchronize with DT spec and U-Boot.
A mapping between location index and device path is not required. What is still required is a selector, and this can be implemented in DT or as kernel parameter.
Does this already cover your use case or do we need the introduction of this new interface ?
- bool "Export environment config to device tree before boot"
- depends on OF_LIBFDT
- help
- config OF_SYSTEM_SETUP bool "Set up system-specific details in device tree before boot" depends on OF_LIBFDT
- if (IS_ENABLED(CONFIG_OF_EXPORT_ENV_CONFIG)) {
if (fdt_ret) {
goto err;
- } if (IS_ENABLED(CONFIG_OF_BOARD_SETUP)) { const char *skip_board_fixup;
- struct mmc *mmc;
- u32 location;
- int chosen_offs, offs;
- int ret;
- if (CONFIG_IS_ENABLED(ENV_IS_NOWHERE))
- chosen_offs = fdt_path_offset(blob, "/chosen");
- if (chosen_offs < 0) {
return chosen_offs;
- offs = fdt_add_subnode(blob, chosen_offs, "u-boot,env-config");
- if (offs < 0) {
return offs;
- location = env_get_location(0, 0);
- fdt_setprop_u32(blob, offs, "location", location);
- fdt_setprop_u32(blob, offs, "offset", CONFIG_ENV_OFFSET);
- fdt_setprop_u32(blob, offs, "size", CONFIG_ENV_SIZE);
- fdt_setprop_u32(blob, offs, "sect_size", CONFIG_ENV_SECT_SIZE);
My major concern is regarding the dependency that is introduced. These properties are then compiled into U-Boot. If a new property will be required in future, this could required an update for the bootloader in field. Even if yes, bootloader's updates are done in field, they are often risky and not power-cut safe.
If the whole configuration, new properties, etc, remains as much as possible in User Space, to get the new feature we need an update of rootfs (in your example), that is (mostly) safe (and then it is not, the update procedure should be revisited). A single rootfs for multiple hardware using different locations and maybe different options (if needed or if they will be introduced) is possible, the yaml configuration will contain all of them and some detection (in user space) can do the trick to select the right one.
What do you think ?
Regards, Stefano
- if (CONFIG_IS_ENABLED(ENV_IS_IN_MMC) && location == ENVL_MMC) {
if (mmc)
- } else if (CONFIG_IS_ENABLED(ENV_IS_IN_SPI_FLASH) && location == ENVL_SPI_FLASH) {
- if (CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT)) {
if (offs < 0) {
return offs;
+} +#endif
- env_driver_lookup() - Finds the most suited environment location
- @op: operations performed on the environment
- #endif
Hi Stefano,
On 03.08.23 10:14, Stefano Babic wrote:
Hi Frieder,
Ok
Thanks for the feedback! I've seen the YAML configuration feature in libubootenv but I missed the fact, that it already supports something like the namespace parameter for selecting different configurations.
Indeed this would solve one part of the issue. And yes, I think we could use the DT or a kernel parameter to pass a selector from U-Boot to userspace.
Do you think we could add something to libubootenv to automatically select the default namespace based on some DT property or kernel parameter?
If yes, I think this would be a viable solution for me.
diff --git a/boot/Kconfig b/boot/Kconfig index e8fb03b801..16a94f9b35 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -702,6 +702,15 @@ config OF_BOARD_SETUP board-specific information in the device tree for use by the OS. The device tree is then passed to the OS. +config OF_EXPORT_ENV_CONFIG + bool "Export environment config to device tree before boot" + depends on OF_LIBFDT + help + This causes U-Boot to call fdt_environment_config() before booting into + the operating system. This function exports the currently in use + environemnt configuration to the "chosen" node of the fdt. This allows + the OS to determine where the environment is located.
config OF_SYSTEM_SETUP bool "Set up system-specific details in device tree before boot" depends on OF_LIBFDT diff --git a/boot/image-fdt.c b/boot/image-fdt.c index f10200f647..c02c8f33ef 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -643,6 +643,14 @@ int image_setup_libfdt(struct bootm_headers *images, void *blob, /* Append PStore configuration */ fdt_fixup_pstore(blob); #endif + if (IS_ENABLED(CONFIG_OF_EXPORT_ENV_CONFIG)) { + fdt_ret = fdt_environment_config(blob); + if (fdt_ret) { + printf("ERROR: environment config fdt fixup failed: %s\n", + fdt_strerror(fdt_ret)); + goto err; + } + } if (IS_ENABLED(CONFIG_OF_BOARD_SETUP)) { const char *skip_board_fixup; diff --git a/env/env.c b/env/env.c index 2aa52c98f8..a640977205 100644 --- a/env/env.c +++ b/env/env.c @@ -8,6 +8,7 @@ #include <env.h> #include <env_internal.h> #include <log.h> +#include <mmc.h> #include <asm/global_data.h> #include <linux/bitops.h> #include <linux/bug.h> @@ -156,6 +157,58 @@ __weak enum env_location env_get_location(enum env_operation op, int prio) return arch_env_get_location(op, prio); } +#ifdef CONFIG_OF_EXPORT_ENV_CONFIG +int fdt_environment_config(void *blob) +{ + struct mmc *mmc; + u32 location; + int chosen_offs, offs; + int ret;
What do you think ?
Yeah, I get your point. My idea was that the bootloader exports "everything" it knows about the environment to the DT. But indeed, there is some (minimal?) risk that changes to the exported data are needed which would require the bootloader to be updated.
Using the YAML config with multiple namespaces sounds like a good alternative. But detecting the right namespace to use can only be done based on information passed by the bootloader. So if we could build a default namespace selection by DT property or kernel parameter into libubootenv that would be great.
Thanks Frieder
Hi Frieder,
On 03.08.23 14:51, Frieder Schrempf wrote:
Hi Stefano,
Hi Frieder,
Ok
Exactly.
Yes, we just need to add a way to set up a default "namespace". There is currently a default "uboot" namespace, and we just need a way to pass the information to the library. Maybe with an env ?
Fine !
What do you think ?
Right - the idea with libubootenv is that it is hardware-independent, and setup is done just via configuration files.
Agree.
Of course, we can !
Best regards, Stefano
Thanks Frieder
On Thu, 3 Aug 2023 at 07:21, Stefano Babic sbabic@denx.de wrote:
Hi Frieder,
Hi Stefano,
Hi Frieder,
Ok
Exactly.
Fine !
- help
booting into
allows
if (fdt_ret) {
goto err;
- } if (IS_ENABLED(CONFIG_OF_BOARD_SETUP)) { const char *skip_board_fixup; diff --git a/env/env.c b/env/env.c
- struct mmc *mmc;
- u32 location;
- int ret;
return chosen_offs;
- if (offs < 0) {
return offs;
What do you think ?
Agree.
Of course, we can !
Thanks Frieder
It seems to me that U-Boot controls where the env areas are and which ones are used. How can we have a file in the root fs in that case? If we update the firmware, who updates the file?
Re the DT binding, we should send that upstream. I think it would be better if we can indicate which device holds each env, e.g. with a phandle from that device, or a phandle the other way? I suspect Rob Herring will have some ideas there.
Hi Simon,
Hi Frieder,
Hi Stefano,
Hi Frieder,
Ok
Exactly.
Fine !
- help
booting into
allows
if (fdt_ret) {
goto err;
- struct mmc *mmc;
- u32 location;
- int ret;
return chosen_offs;
- if (offs < 0) {
return offs;
What do you think ?
Agree.
Of course, we can !
Thanks Frieder
I think it is adifferent topic. This is raises a compatibility issue between User Space and bootloader, and the update concept must of course take care of this, that means, if U-Boot is updated, the SW (rootfs) must be updated as well if not compatible anymore. This already happens any time there is compatibility issue between U-Boot and User Space (switch from legacy image to fitImage for example, etc.).
Some sort of automatic detection in user space can also be possible,
My point is that, apart the added dependencies between U-Boot and User Space, we still need a sort of intermediate layer in User Space to map between such as device index / phandle, and the device node. A location = <X> does not help a lot when we access from User Space, and such sort of mapping can be simply avoided by configuring tools in USer Space with the names provided by the kernel, that can change from board to board (for example depends on the order MTD devices are detected).
Hi Simon, hi Stefano,
On 04.08.23 15:39, Stefano Babic wrote:
Hi Simon,
Hi Frieder,
Hi Stefano,
Hi Frieder,
In order to make systems more flexible and let userspace tools detect the location of the environment currently in use, let's add an option to export the runtime configuration to the FDT passed to the OS. > This is especially useful when your device is able to use multiple locations for the environment and the rootfs containing the fw_env.config file should be kept universal.
Ok
Exactly.
Fine !
What do you think ?
Agree.
Of course, we can !
Thanks Frieder
A rather sophisticated solution could maybe work without needing a separate mapping between U-Boot env device and kernel device.
Given that U-Boot is able to match the env device with a node in the devicetree passed to the kernel it could store a phandle to that node (e.g. /chosen/u-boot,env = <&mmc1>).
For specifying a partition/offset we would need a representation of the partition in the devicetree. This would work for MTD devices. I'm not sure about eMMC with hardware partitions (boot0, boot1, etc.). If they could be represented in DT this could work, too. No idea what about other potential env devices.
I also see that there is already some binding for MTD devices to specify the U-Boot env partition in [1].
Anyway this is way beyond what I can do at the moment and our primary goal to create a root FS that supports multiple env devices and is able to determine the one that is currently in use, can be achieved with minor extensions of U-Boot and libubootenv as proposed above by Stefano. So I think I will try to go down that road for now.
Best regards Frieder
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu...
Hi Frieder,
On Mon, 7 Aug 2023 at 06:19, Frieder Schrempf frieder.schrempf@kontron.de wrote:
Hi Simon,
Hi Frieder,
Hi Stefano,
Hi Frieder,
On 01.08.23 16:46, Frieder Schrempf wrote: > From: Frieder Schrempf frieder.schrempf@kontron.de > > There are plenty of cases where the OS wants to know where the > persistent environment is stored in order to print or manipulate it. > > In most cases a userspace tool like libubootenv [1] is used to handle > the environment. It uses hardcoded settings in a config file in the > rootfs to determine the exact location of the environment. >
> In order to make systems more flexible and let userspace tools > detect the location of the environment currently in use, let's > add an option to export the runtime configuration to the FDT passed > to the OS. >> This is especially useful when your device is able to use multiple > locations for the environment and the rootfs containing the > fw_env.config file should be kept universal.
Ok
Exactly.
Fine !
> > Currently the general information like location/type, size, offset > and redundancy are exported. Userspace tools might already be able > to guess the correct device to access based on this information. > > For further device-specific information two additional properties > 'id1' and 'id2' are used. The current implementation uses them for > MMC and SPI FLASH like this: > > | Type | id1 | > id2 | > | ---------- | -------------------------- | > -------------------------- | > | MMC | MMC device index in U-Boot | MMC hwpart index in > U-Boot | > | SPI FLASH | SPI bus index in U-Boot | SPI CS index in > U-Boot | > > Further extensions for other environment devices are possible. > > We add the necessary information to the '/chosen' node. The following > shows two examples: > > Redundant environment in MMC: > > /chosen { > u-boot,env-config { > location = <5>; # according to 'enum > env_location' > offset = <0x1E0000>; > size = <0x100000>; > sect_size = <0x100000>; > id1 = <1>; # MMC device index > id2 = <0>; # MMC HW partition index > }; > u-boot,env-redund-config { > offset = <0x1F0000>; > }; > }; > > Redundant environment in SPI NOR: > > /chosen { > u-boot,env-config { > location = <10>; # according to 'enum > env_location' > offset = <0x1E0000>; > size = <0x100000>; > sect_size = <0x100000>; > id1 = <0>; # SPI bus > id2 = <0>; # SPI CS > }; > u-boot,env-redund-config { > offset = <0x1F0000>; > }; > }; > > See [2] for an example parser implementation for libubootenv. > > [1] > https://github.com/sbabic/libubootenv > [2] > https://github.com/fschrempf/libubootenv/commit/726a7ac9b1b1020354ee8fe750f4... > > Cc: Stefano Babic sbabic@denx.de > Cc: Michael Walle michael@walle.cc > Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de > --- > boot/Kconfig | 9 ++++++++ > boot/image-fdt.c | 8 ++++++++ > env/env.c | 53 > ++++++++++++++++++++++++++++++++++++++++++++++++ > include/env.h | 4 ++++ > 4 files changed, 74 insertions(+) > > diff --git a/boot/Kconfig b/boot/Kconfig > index e8fb03b801..16a94f9b35 100644 > --- a/boot/Kconfig > +++ b/boot/Kconfig > @@ -702,6 +702,15 @@ config OF_BOARD_SETUP > board-specific information in the device tree for use by > the OS. > The device tree is then passed to the OS. > +config OF_EXPORT_ENV_CONFIG > + bool "Export environment config to device tree before boot" > + depends on OF_LIBFDT > + help > + This causes U-Boot to call fdt_environment_config() before > booting into > + the operating system. This function exports the currently > in use > + environemnt configuration to the "chosen" node of the fdt. > This > allows > + the OS to determine where the environment is located. > + > config OF_SYSTEM_SETUP > bool "Set up system-specific details in device tree before > boot" > depends on OF_LIBFDT > diff --git a/boot/image-fdt.c b/boot/image-fdt.c > index f10200f647..c02c8f33ef 100644 > --- a/boot/image-fdt.c > +++ b/boot/image-fdt.c > @@ -643,6 +643,14 @@ int image_setup_libfdt(struct bootm_headers > *images, void *blob, > /* Append PStore configuration */ > fdt_fixup_pstore(blob); > #endif > + if (IS_ENABLED(CONFIG_OF_EXPORT_ENV_CONFIG)) { > + fdt_ret = fdt_environment_config(blob); > + if (fdt_ret) { > + printf("ERROR: environment config fdt fixup failed: > %s\n", > + fdt_strerror(fdt_ret)); > + goto err; > + } > + } > if (IS_ENABLED(CONFIG_OF_BOARD_SETUP)) { > const char *skip_board_fixup; > diff --git a/env/env.c b/env/env.c > index 2aa52c98f8..a640977205 100644 > --- a/env/env.c > +++ b/env/env.c > @@ -8,6 +8,7 @@ > #include <env.h> > #include <env_internal.h> > #include <log.h> > +#include <mmc.h> > #include <asm/global_data.h> > #include <linux/bitops.h> > #include <linux/bug.h> > @@ -156,6 +157,58 @@ __weak enum env_location env_get_location(enum > env_operation op, int prio) > return arch_env_get_location(op, prio); > } > +#ifdef CONFIG_OF_EXPORT_ENV_CONFIG > +int fdt_environment_config(void *blob) > +{ > + struct mmc *mmc; > + u32 location; > + int chosen_offs, offs; > + int ret; > + > + if (CONFIG_IS_ENABLED(ENV_IS_NOWHERE)) > + return 0; > + > + chosen_offs = fdt_path_offset(blob, "/chosen"); > + if (chosen_offs < 0) { > + printf("Could not find chosen node.\n"); > + return chosen_offs; > + } > + > + offs = fdt_add_subnode(blob, chosen_offs, "u-boot,env-config"); > + if (offs < 0) { > + printf("Could not create env-config node.\n"); > + return offs; > + } > + > + location = env_get_location(0, 0); > + fdt_setprop_u32(blob, offs, "location", location); > + fdt_setprop_u32(blob, offs, "offset", CONFIG_ENV_OFFSET); > + fdt_setprop_u32(blob, offs, "size", CONFIG_ENV_SIZE); > + fdt_setprop_u32(blob, offs, "sect_size", CONFIG_ENV_SECT_SIZE); > +
What do you think ?
Agree.
Of course, we can !
Thanks Frieder
Yes.
OK.
Frieder Schrempf
Frieder Schrempf
Stefano Babic
