[U-Boot] [PATCH] mpc83xx: Size optimization of start.S
Currently there are in excess of 100 bytes located at the beginning of the image built by start.S that are not being utilized. This patch moves a few functions into this part of the image. This will create a greater number of *available* bytes that can be used by board specific code in NAND builds and will decrease the size of the assembled code in other builds.
Signed-off-by: Ron Madrid ron_madrid@sbcglobal.net --- cpu/mpc83xx/start.S | 77 ++++++++++++++++++++++++++------------------------- 1 files changed, 39 insertions(+), 38 deletions(-)
diff --git a/cpu/mpc83xx/start.S b/cpu/mpc83xx/start.S index cd566b2..b040e3b 100644 --- a/cpu/mpc83xx/start.S +++ b/cpu/mpc83xx/start.S @@ -108,6 +108,45 @@ version_string: .ascii " (", __DATE__, " - ", __TIME__, ")" .ascii " ", CONFIG_IDENT_STRING, "\0"
+ .align 2 + + .globl enable_addr_trans +enable_addr_trans: + /* enable address translation */ + mfmsr r5 + ori r5, r5, (MSR_IR | MSR_DR) + mtmsr r5 + isync + blr + + .globl disable_addr_trans +disable_addr_trans: + /* disable address translation */ + mflr r4 + mfmsr r3 + andi. r0, r3, (MSR_IR | MSR_DR) + beqlr + andc r3, r3, r0 + mtspr SRR0, r4 + mtspr SRR1, r3 + rfi + + .globl get_pvr +get_pvr: + mfspr r3, PVR + blr + + .globl ppcDWstore +ppcDWstore: + lfd 1, 0(r4) + stfd 1, 0(r3) + blr + + .globl ppcDWload +ppcDWload: + lfd 1, 0(r3) + stfd 1, 0(r4) + blr
#ifndef CONFIG_DEFAULT_IMMR #error CONFIG_DEFAULT_IMMR must be defined @@ -697,27 +736,6 @@ setup_bats:
blr
- .globl enable_addr_trans -enable_addr_trans: - /* enable address translation */ - mfmsr r5 - ori r5, r5, (MSR_IR | MSR_DR) - mtmsr r5 - isync - blr - - .globl disable_addr_trans -disable_addr_trans: - /* disable address translation */ - mflr r4 - mfmsr r3 - andi. r0, r3, (MSR_IR | MSR_DR) - beqlr - andc r3, r3, r0 - mtspr SRR0, r4 - mtspr SRR1, r3 - rfi - /* Cache functions. * * Note: requires that all cache bits in @@ -795,23 +813,6 @@ flush_dcache: b 1b 2: blr
- .globl get_pvr -get_pvr: - mfspr r3, PVR - blr - - .globl ppcDWstore -ppcDWstore: - lfd 1, 0(r4) - stfd 1, 0(r3) - blr - - .globl ppcDWload -ppcDWload: - lfd 1, 0(r3) - stfd 1, 0(r4) - blr - /*-------------------------------------------------------------------*/
Hi Ron,
Hmmm, are you sure? What if someone designs a board, where the processor shall load its reset configuration from a local bus EEPROM, e.g. the same NOR-Flash containing the U-Boot image (CFG_RESET_SOURCE[0:2] = 000b?
Or did I misunderstand something?
Kind regards, Jens
On Mon, Dec 15, 2008 at 08:26:03AM +0100, Jens Gehrlein wrote:
Hi Ron,
That's covered by the _HRCW_TABLE_ENTRY lines earlier in the file.
-Scott
Hi Scott,
Hi Ron,
I see. I understood Ron's comment as "first 100 hex bytes". Thanks for the hint, Scott.
Kind regards, Jens
I haven't received any communication about this patch in a while. Is is still being looked at or did it slip through the cracks? Or did I miss an email?
Let me know.
Ron
--- On Fri, 12/12/08, Ron Madrid ron_madrid@sbcglobal.net wrote:
From: Ron Madrid ron_madrid@sbcglobal.net Subject: [PATCH] mpc83xx: Size optimization of start.S To: u-boot@lists.denx.de Cc: "Ron Madrid" ron_madrid@sbcglobal.net Date: Friday, December 12, 2008, 1:12 PM Currently there are in excess of 100 bytes located at the beginning of the image built by start.S that are not being utilized. This patch moves a few functions into this part of the image. This will create a greater number of *available* bytes that can be used by board specific code in NAND builds and will decrease the size of the assembled code in other builds.
On Fri, 12 Dec 2008 13:12:45 -0800 Ron Madrid ron_madrid@sbcglobal.net wrote:
applied to u-boot-mpc83xx next.
Thanks, and sorry for the delay,
Kim
No worries. With the holidays and all I figured that it was just delayed.
Since my new board patch is dependent on this being applied is it possible to now resubmit my new board patch?
Thanks.
Ron
--- On Wed, 1/21/09, Kim Phillips kim.phillips@freescale.com wrote:
From: Kim Phillips kim.phillips@freescale.com Subject: Re: [U-Boot] [PATCH] mpc83xx: Size optimization of start.S To: "Ron Madrid" ron_madrid@sbcglobal.net Cc: u-boot@lists.denx.de Date: Wednesday, January 21, 2009, 4:55 PM On Fri, 12 Dec 2008 13:12:45 -0800 Ron Madrid ron_madrid@sbcglobal.net wrote:
Kim
On Thu, 22 Jan 2009 10:00:56 -0800 (PST) Ron Madrid ron_madrid@sbcglobal.net wrote:
I thought you'd never ask :)
please base it on u-boot-mpc83xx next.
Kim
Should this go to the main u-boot mail list or should I send it somewhere else?
Ron
--- On Thu, 1/22/09, Kim Phillips kim.phillips@freescale.com wrote:
From: Kim Phillips kim.phillips@freescale.com Subject: Re: [U-Boot] [PATCH] mpc83xx: Size optimization of start.S To: ron_madrid@sbcglobal.net Cc: u-boot@lists.denx.de Date: Thursday, January 22, 2009, 10:37 AM On Thu, 22 Jan 2009 10:00:56 -0800 (PST) Ron Madrid ron_madrid@sbcglobal.net wrote:
Kim
On Thu, 22 Jan 2009 13:37:11 -0800 (PST) Ron Madrid ron_madrid@sbcglobal.net wrote:
? this list (the main u-boot ML) is where we review patches for all of u-boot.
Kim
p.s. please don't top-post. See http://www.netmeister.org/news/learn2quote.html
Jens Gehrlein
Kim Phillips
Ron Madrid
Scott Wood
