[U-Boot-Users] RE: [U-Boot-CVS] u-boot/drivers omap24xx_i2c.c,NONE,1.1 Makefile,1.29,1.30 ns16550.c,1.6,1.7 serial.c,1.5,1.6
Sorry,
I ran into the build problem long ago and fixed it locally. I was preparing to resubmit a patch with a lot of additions and this one fix....as I was thinking Wolfgang had bypassed it.
I believe the real fix I used was in the driver itself not above. Its much simpler and I think the correct one.
Regards, Richard W.
The File drivers/omap2420_i2c.c needs to look like this: ----------------------------------------------------------- #include <common.h>
#ifdef CONFIG_DRIVER_OMAP24XX_I2C
#include <asm/arch/i2c.h> #include <asm/io.h>
#define inw(a) __raw_readw(a) #define outw(a,v) __raw_writew(a,v)
previously it WRONGLY looked like:
#include <common.h> #include <asm/arch/i2c.h> #include <asm/io.h>
-----Original Message----- From: Cory Tusar [mailto:ctusar@videon-central.com] Sent: Monday, January 10, 2005 9:27 AM To: [u-boot] U-Boot users list Cc: Woodruff, Richard Subject: Re: [U-Boot-CVS] u-boot/drivers omap24xx_i2c.c,NONE,1.1 Makefile,1.29,1.30 ns16550.c,1.6,1.7 serial.c,1.5,1.6
Wolfgang Denk wrote:
Update of /cvsroot/u-boot/u-boot/drivers In directory sc8-pr-cvs1.sourceforge.net:/tmp/cvs-serv8979/drivers
Modified Files: Makefile ns16550.c serial.c Added Files: omap24xx_i2c.c Log Message:
Patches by Richard Woodruff, 01 Oct 2004: add support for the TI OMAP2420 processor and its H4 reference board
Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
This changeset, notably omap24xx_i2c.c, breaks (ARM-only?)
non-omap24xx
builds. The attached patch relocates the omap24xx-specific i2c header information from asm-arm/arch-arm1136/i2c.h to include/omap24xx_i2c.h.
Patch was generated against current CVS sources.
-Cory
-- Cory T. Tusar Embedded Systems Engineer Videon Central, Inc. 2171 Sandy Drive State College, PA 16801 (814) 235-1111 x316 (814) 235-1118 fax
"Debugging is twice as hard as writing the code in the first place. Therefore, if you write the code as cleverly as possible, you are, by definition, not smart enough to debug it." --Brian W.
Kernighan
Woodruff, Richard wrote:
Sorry,
Regards, Richard W.
#include <common.h>
Agreed. After a bit more testing, I found that there were preprocessor warnings generated due to symbols being defined multiple times between your i2c.h and the omap1510.h (notably inb(), outb() and the like). I came up with pretty much the same solution as you, and am running a MAKEALL test now just to be sure there are no issues this time. Assuming not, I'll re-send just the above changes as a patch to resolve this.
Thanks.
-Cory
Sorry,
Regards, Richard W.
#include <common.h>
Attached is a patch which simply includes the above fix. This time, there were no other issues raised during a "MAKEALL arm" test.
Wolfgang, please apply this in lieu of the previous patch, as it's the simpler fix.
Thanks.
-Cory
Cory Tusar
Woodruff, Richard
