[U-Boot] Pull request: u-boot-arm/master
Hello Tom,
The following changes since commit 7528cf5f016b5b8b8b12b373f6f31a10bf89233d:
Merge branch 'u-boot-imx/master' into 'u-boot-arm/master' (2013-01-08 14:59:37 +0100)
git://git.denx.de/u-boot-arm.git master
for you to fetch changes up to 61bdb9133593f0f881a57232039296f64bd662ed:
arm: remove useless code in start.S files (2013-01-08 22:14:54 +0100)
---------------------------------------------------------------- Albert ARIBAUD (2): arm: move C runtime setup code in crt0.S arm: remove useless code in start.S files
arch/arm/cpu/arm1136/start.S | 71 +++--------- arch/arm/cpu/arm1176/start.S | 62 ++--------- arch/arm/cpu/arm720t/start.S | 53 ++------- arch/arm/cpu/arm920t/start.S | 61 ++-------- arch/arm/cpu/arm925t/start.S | 65 ++--------- arch/arm/cpu/arm926ejs/start.S | 86 ++------------ arch/arm/cpu/arm946es/start.S | 56 ++-------- arch/arm/cpu/arm_intcm/start.S | 63 ++--------- arch/arm/cpu/armv7/start.S | 58 +++------- arch/arm/cpu/ixp/start.S | 55 ++------- arch/arm/cpu/pxa/start.S | 63 ++--------- arch/arm/cpu/s3c44b0/start.S | 55 ++------- arch/arm/cpu/sa1100/start.S | 50 ++------- arch/arm/lib/Makefile | 2 + arch/arm/lib/board.c | 11 -- arch/arm/lib/crt0.S | 173 +++++++++++++++++++++++++++++ include/common.h | 2 +- include/configs/socfpga_cyclone5.h | 2 +- lib/asm-offsets.c | 14 +++ nand_spl/board/freescale/mx31pdk/Makefile | 6 +- nand_spl/board/karo/tx25/Makefile | 6 +- 21 files changed, 326 insertions(+), 688 deletions(-) create mode 100644 arch/arm/lib/crt0.S
Amicalement,
On Wed, Jan 09, 2013 at 03:43:04PM +0100, Albert ARIBAUD wrote:
Hello Tom,
Albert ARIBAUD
