[PATCH v3] crypto/fsl: fsl_rsa: Fix dcache issue in the driver
issue: CAAM fails with key error when perform Modular Exponentiation using PKHA Block in CAAM
Fix: add flush and invalidate dcache for keys, signature and output decrypted data processed by CAAM.
Fixes: 34276478f7 (DM: crypto/fsl - Add Freescale rsa DM driver) Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Gaurav Jain gaurav.jain@nxp.com Acked-by: Peng Fan peng.fan@nxp.com --- drivers/crypto/fsl/fsl_rsa.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/crypto/fsl/fsl_rsa.c b/drivers/crypto/fsl/fsl_rsa.c index 897ee855ea..335b7fe25a 100644 --- a/drivers/crypto/fsl/fsl_rsa.c +++ b/drivers/crypto/fsl/fsl_rsa.c @@ -6,6 +6,7 @@
#include <config.h> #include <common.h> +#include <cpu_func.h> #include <dm.h> #include <log.h> #include <asm/types.h> @@ -36,12 +37,21 @@ int fsl_mod_exp(struct udevice *dev, const uint8_t *sig, uint32_t sig_len,
inline_cnstr_jobdesc_pkha_rsaexp(desc, &pkin, out, sig_len);
+ flush_dcache_range((ulong)sig, (ulong)sig + sig_len); + flush_dcache_range((ulong)prop->modulus, (ulong)(prop->modulus) + keylen); + flush_dcache_range((ulong)prop->public_exponent, + (ulong)(prop->public_exponent) + prop->exp_len); + flush_dcache_range((ulong)desc, (ulong)desc + (sizeof(uint32_t) * MAX_CAAM_DESCSIZE)); + flush_dcache_range((ulong)out, (ulong)out + sig_len); + ret = run_descriptor_jr(desc); if (ret) { debug("%s: RSA failed to verify: %d\n", __func__, ret); return -EFAULT; }
+ invalidate_dcache_range((ulong)out, (ulong)out + sig_len); + return 0; }
Hi Gaurav,
Please always explain what changed in the current version of the patch.
I assume you fixed the build error found in CI, correct?
Hi Fabio
-----Original Message----- From: Fabio Estevam festevam@gmail.com Sent: Wednesday, June 15, 2022 6:11 PM To: Gaurav Jain gaurav.jain@nxp.com Cc: U-Boot-Denx u-boot@lists.denx.de; Stefano Babic sbabic@denx.de; Peng Fan peng.fan@nxp.com; dl-uboot-imx uboot-imx@nxp.com; Horia Geanta horia.geanta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com Subject: [EXT] Re: [PATCH v3] crypto/fsl: fsl_rsa: Fix dcache issue in the driver
Caution: EXT Email
Hi Gaurav,
This is a different patch in fsl_rsa.c I will send a different patch for the error reported by you.
Regards Gaurav Jain
On 15.06.22 14:45, Gaurav Jain wrote:
Hi Fabio
Caution: EXT Email
Hi Gaurav,
Ouch...I have misunderstood. Well, then I willwait for your patch..
Regards, Stefano
Regards Gaurav Jain
Hi Stefano
This patch is put into state "changes requested". But it is a different patch in fsl_rsa. There is no change requested with this patch.
Regards Gaurav Jain
-----Original Message----- From: Stefano Babic sbabic@denx.de Sent: Wednesday, June 15, 2022 6:20 PM To: Gaurav Jain gaurav.jain@nxp.com; Fabio Estevam festevam@gmail.com Cc: U-Boot-Denx u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com; dl- uboot-imx uboot-imx@nxp.com; Horia Geanta horia.geanta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com Subject: Re: [EXT] Re: [PATCH v3] crypto/fsl: fsl_rsa: Fix dcache issue in the driver
Caution: EXT Email
Hi Fabio
Caution: EXT Email
Hi Gaurav,
Regards, Stefano
Regards Gaurav Jain
Hi Gaurav,
On 29.06.22 09:06, Gaurav Jain wrote:
Hi Stefano
Something went wrong - I have applied this patch to push to 2022.07, but in CI I get the same errors I found before, that is PowerPC build was broken:
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/457090
I hadn't time to check this, and I suppose that issue is not yet fixed and I drop the patch from MR (Layerscape is broken, too), that is V3 has not fixed CI as in V2. Or is there anothe rpatch I had to pick up ?
Best regards, Stefano
Regards Gaurav Jain
Caution: EXT Email
Hi Fabio
Caution: EXT Email
Hi Gaurav,
Regards, Stefano
Regards Gaurav Jain
Hi Stefano
this patch is fixing dcache issue in fsl_rsa.c
Error reported is in drivers/crypto/fsl/fsl_hash.c addr = (addr << 32) | sec_in32(&ctx->sg_tbl[i].addr_lo);
reported error is fixed in [v3] crypto/fsl: fsl_hash: Fix crash in flush dcache http://patchwork.ozlabs.org/project/uboot/patch/20220616101009.809953-1-gaur...
Regards Gaurav Jain
-----Original Message----- From: Stefano Babic sbabic@denx.de Sent: Wednesday, June 29, 2022 12:51 PM To: Gaurav Jain gaurav.jain@nxp.com; Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com Cc: U-Boot-Denx u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com; dl- uboot-imx uboot-imx@nxp.com; Horia Geanta horia.geanta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com Subject: Re: [EXT] Re: [PATCH v3] crypto/fsl: fsl_rsa: Fix dcache issue in the driver
Caution: EXT Email
Hi Gaurav,
Hi Stefano
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsource.d enx.de%2Fu-boot%2Fcustodians%2Fu-boot-imx%2F- %2Fjobs%2F457090&data=05%7C01%7Cgaurav.jain%40nxp.com%7C98808 23b97ef4669f51108da599feffc%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0 %7C0%7C637920840703403368%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4 wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C %7C%7C&sdata=FGDL9eBnjyUDc423myN4jVoK7QD9VZiitvZao6mz04s%3D &reserved=0
Regards Gaurav Jain
Caution: EXT Email
Hi Fabio
Caution: EXT Email
Hi Gaurav,
Regards, Stefano
Regards Gaurav Jain
==== DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, 82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de ================================================================= ====
On 29.06.22 10:35, Gaurav Jain wrote:
Hi Stefano
Yes, and I have supposed to have merged this, too.
I will pick up again both and let CI runs.
Stefano
Regards Gaurav Jain
Caution: EXT Email
Hi Gaurav,
Hi Stefano
Regards Gaurav Jain
Caution: EXT Email
Hi Fabio
Caution: EXT Email
Hi Gaurav,
wrote:
> > From: Ye Li ye.li@nxp.com > > issue: > CAAM fails with key error when perform Modular Exponentiation > using PKHA Block in CAAM > > Fix: > add flush and invalidate dcache for keys, signature and output > decrypted data processed by CAAM. > > Fixes: 34276478f7 (DM: crypto/fsl - Add Freescale rsa DM driver) > Signed-off-by: Ye Li ye.li@nxp.com > Reviewed-by: Gaurav Jain gaurav.jain@nxp.com > Acked-by: Peng Fan peng.fan@nxp.com > ---
Regards, Stefano
Regards Gaurav Jain
Hi Gaurav,
Hi Stefano
The thread changed name, I mean "crypto/fsl: fsl_hash: Fix crash in flush dcache"
Give an another attempt, it fails and it is quite clear why:
+#ifdef CONFIG_CAAM_64BIT + addr = sec_in32(&ctx->sg_tbl[i].addr_hi); + addr = (addr << 32) | sec_in32(&ctx->sg_tbl[i].addr_lo); +#else
Fine with ARM and ARM64. In Kconfig:
config CAAM_64BIT bool default y if PHYS_64BIT && !ARCH_IMX8M && !ARCH_IMX8 help Select Crypto driver for 64 bits CAAM version
That is ok until powerpc are built that sets PHYS_64BIT. Then build fails with:
powerpc: + T4240RDB_SDCARD +drivers/crypto/fsl/fsl_hash.c: In function 'caam_hash_finish': +drivers/crypto/fsl/fsl_hash.c:151:30: error: left shift count >= width of type [-Werror=shift-count-overflow] + 151 | addr = (addr << 32) | sec_in32(&ctx->sg_tbl[i].addr_lo); + | ^~ +cc1: all warnings being treated as errors
And well, compiler is right...
Best regards, Stefano Babic
Regards Gaurav Jain
Caution: EXT Email
Hi Gaurav,
Hi Stefano
Regards Gaurav Jain
Caution: EXT Email
Hi Fabio
Caution: EXT Email
Hi Gaurav,
Regards, Stefano
Regards Gaurav Jain
Hello Stefano
-----Original Message----- From: Stefano Babic sbabic@denx.de Sent: Tuesday, July 26, 2022 2:55 PM To: Gaurav Jain gaurav.jain@nxp.com; Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com Cc: U-Boot-Denx u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com; dl- uboot-imx uboot-imx@nxp.com; Horia Geanta horia.geanta@nxp.com; Varun Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com Subject: Re: [EXT] Re: [PATCH v3] crypto/fsl: fsl_rsa: Fix dcache issue in the driver
Caution: EXT Email
Hi Gaurav,
Hi Stefano
reported error is fixed in [v3] crypto/fsl: fsl_hash: Fix crash in flush dcache https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpatch work.ozlabs.org%2Fproject%2Fuboot%2Fpatch%2F20220616101009.809953-
1-ga
urav.jain%40nxp.com%2F&data=05%7C01%7Cgaurav.jain%40nxp.com%7C b605
e737d37a4237e8ba08da6ee8bf00%7C686ea1d3bc2b4c6fa92cd99c5c301635%7 C0%7C
0%7C637944243170612332%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjA wMDAiLCJ
QIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&s data=
KUAaTlucw6GRG7W2QvlE0JMO%2FAJt0tmi7%2FM3ZcpZ6C0%3D&reserved =0
+#else
- 151 | addr = (addr << 32) |
I have sent a V4 which fixes the error for powerpc platforms.
Thanks Gaurav Jain
Regards Gaurav Jain
Caution: EXT Email
Hi Gaurav,
Hi Stefano
rce.d%2F&data=05%7C01%7Cgaurav.jain%40nxp.com%7Cb605e737d37a4 237e
8ba08da6ee8bf00%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C637 94424
3170612332%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoi V2luMz
IiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=uDXXo PFq2y
L0RyoaEyrMCUFYCQ5M5CfwN6XQG6eM4DE%3D&reserved=0 enx.de%2Fu-boot%2Fcustodians%2Fu-boot-imx%2F- %2Fjobs%2F457090&data=05%7C01%7Cgaurav.jain%40nxp.com%7C98
808
C4
3D
&reserved=0
Regards Gaurav Jain
Caution: EXT Email
Hi Fabio
> -----Original Message----- > From: Fabio Estevam festevam@gmail.com > Sent: Wednesday, June 15, 2022 6:11 PM > To: Gaurav Jain gaurav.jain@nxp.com > Cc: U-Boot-Denx u-boot@lists.denx.de; Stefano Babic > sbabic@denx.de; Peng Fan peng.fan@nxp.com; dl-uboot-imx > uboot-imx@nxp.com; Horia Geanta horia.geanta@nxp.com; Varun > Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com > Subject: [EXT] Re: [PATCH v3] crypto/fsl: fsl_rsa: Fix dcache > issue in the driver > > Caution: EXT Email > > Hi Gaurav, > > On Wed, Jun 15, 2022 at 9:35 AM Gaurav Jain gaurav.jain@nxp.com
wrote:
>> >> From: Ye Li ye.li@nxp.com >> >> issue: >> CAAM fails with key error when perform Modular Exponentiation >> using PKHA Block in CAAM >> >> Fix: >> add flush and invalidate dcache for keys, signature and output >> decrypted data processed by CAAM. >> >> Fixes: 34276478f7 (DM: crypto/fsl - Add Freescale rsa DM driver) >> Signed-off-by: Ye Li ye.li@nxp.com >> Reviewed-by: Gaurav Jain gaurav.jain@nxp.com >> Acked-by: Peng Fan peng.fan@nxp.com >> --- > > Please always explain what changed in the current version of the patch. > > I assume you fixed the build error found in CI, correct?
Regards, Stefano
Regards Gaurav Jain
On 29.07.22 12:11, Gaurav Jain wrote:
Hello Stefano
Caution: EXT Email
Hi Gaurav,
Hi Stefano
1-ga
+#else
Thanks - I merge and I start a new CI.
Stefano
Thanks Gaurav Jain
Regards Gaurav Jain
Caution: EXT Email
Hi Gaurav,
Hi Stefano
808
C4
3D
&reserved=0
Regards Gaurav Jain
Caution: EXT Email
On 15.06.22 14:45, Gaurav Jain wrote: > Hi Fabio > >> -----Original Message----- >> From: Fabio Estevam festevam@gmail.com >> Sent: Wednesday, June 15, 2022 6:11 PM >> To: Gaurav Jain gaurav.jain@nxp.com >> Cc: U-Boot-Denx u-boot@lists.denx.de; Stefano Babic >> sbabic@denx.de; Peng Fan peng.fan@nxp.com; dl-uboot-imx >> uboot-imx@nxp.com; Horia Geanta horia.geanta@nxp.com; Varun >> Sethi V.Sethi@nxp.com; Ye Li ye.li@nxp.com >> Subject: [EXT] Re: [PATCH v3] crypto/fsl: fsl_rsa: Fix dcache >> issue in the driver >> >> Caution: EXT Email >> >> Hi Gaurav, >> >> On Wed, Jun 15, 2022 at 9:35 AM Gaurav Jain gaurav.jain@nxp.com
wrote:
>>> >>> From: Ye Li ye.li@nxp.com >>> >>> issue: >>> CAAM fails with key error when perform Modular Exponentiation >>> using PKHA Block in CAAM >>> >>> Fix: >>> add flush and invalidate dcache for keys, signature and output >>> decrypted data processed by CAAM. >>> >>> Fixes: 34276478f7 (DM: crypto/fsl - Add Freescale rsa DM driver) >>> Signed-off-by: Ye Li ye.li@nxp.com >>> Reviewed-by: Gaurav Jain gaurav.jain@nxp.com >>> Acked-by: Peng Fan peng.fan@nxp.com >>> --- >> >> Please always explain what changed in the current version of the patch. >> >> I assume you fixed the build error found in CI, correct? > > This is a different patch in fsl_rsa.c I will send a different > patch for the error reported by you.
Regards, Stefano
> > Regards > Gaurav Jain
Hi Gaurav,
thanks for fix, I will put into u-boot-imx and trigger a new CI.
Stefano
return 0; }
Fabio Estevam
Gaurav Jain
Stefano Babic
