[U-Boot] [PATCH v1] env: fix crash using default -f -a
newval pointer is not checked before its usage, inside env_check_apply().
Signed-off-by: Stefano Babic sbabic@denx.de CC: gerlando.falauto@keymile.com --- common/cmd_nvedit.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 3474bc6..8144c85 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -272,7 +272,7 @@ int env_check_apply(const char *name, const char *oldval, /* * Switch to new baudrate if new baudrate is supported */ - if (strcmp(name, "baudrate") == 0) { + if ((strcmp(name, "baudrate") == 0) && (newval != NULL)) { int baudrate = simple_strtoul(newval, NULL, 10); int i; for (i = 0; i < N_BAUDRATES; ++i) { @@ -308,12 +308,12 @@ int env_check_apply(const char *name, const char *oldval, * Some variables should be updated when the corresponding * entry in the environment is changed */ - if (strcmp(name, "loadaddr") == 0) { + if ((strcmp(name, "loadaddr") == 0) && (newval != NULL)) { load_addr = simple_strtoul(newval, NULL, 16); return 0; } #if defined(CONFIG_CMD_NET) - else if (strcmp(name, "bootfile") == 0) { + else if ((strcmp(name, "bootfile") == 0) && (newval != NULL)) { copy_filename(BootFile, newval, sizeof(BootFile)); return 0; }
Some egg on my face for not catching this to start with, confirmed problem and fix here.
Tested-by: Tom Rini trini@ti.com
Hi Stefano,
thanks for reporting and providing a fix for this. I'm very sorry for introducing this problem and for the late response.
Please see my comments below.
[As a side node, I couldn't really reproduce the issue neither on PowerPC nor on ARM (though simple_strtoul should legitimately crash) as apparently accessing NULL locations doesn't really bother our architectures...]
Signed-off-by: Stefano Babicsbabic@denx.de CC: gerlando.falauto@keymile.com
if ((strcmp(name, "baudrate") == 0)&& (newval != NULL)) {
You're right in that the problem here is due to the function explicitly being called with a NULL value. My idea was to have "env default" perform some sort of cleanup before assigning the actual values from the default environment (if any). So by adding these extra checks you're subtly canceling those efforts. So I would rather provide a default value to prevent the crashes, instead of skipping settings altogether. Posting a patch in a few minutes.
Whether it's legitimate to perform these "cleanups", well that's of course open for discussion. But I believe it doesn't make much sense to call a function and pass an argument which is sort of guaranteed to have no effect whatsoever.
int baudrate = simple_strtoul(newval, NULL, 10); int i; for (i = 0; i< N_BAUDRATES; ++i) {
- if ((strcmp(name, "loadaddr") == 0)&& (newval != NULL)) { load_addr = simple_strtoul(newval, NULL, 16); return 0; } #if defined(CONFIG_CMD_NET)
- else if ((strcmp(name, "bootfile") == 0)&& (newval != NULL)) { copy_filename(BootFile, newval, sizeof(BootFile)); return 0; }
Thank you and sorry again, Gerlando
On 05/10/2012 12:29, Gerlando Falauto wrote:
Hi Stefano,
Hi Gerlando,
Right. For PowerPC, Address 0 is a valid address in memory and the system does not crash. However, I tested on a TI's ARM and address zero is not valid.
I have seen, I have not fully understood. My idea is that, if someone want to restore the environment to the default values, no actions should be taken, else the "default" values cannot be really restored.
That is correct, but in any case a check for a NULL pointer should be done before accessing to the pointer, independently what we want to do with it.
Ok, I will review it. In any case, we need a fix for the coming release.
Indeed.
Right. It is the same as calling the function with do_apply=0.
Best regards, Stefano
env default -a -f calls env_check_apply on all existing environment variables with a NULL value for "newval" as a way of cleaning up. This causes string manipulation functions to crash on most architectures. So replace a NULL argument with an empty string.
Reported-By: Stefano Babic sbabic@denx.de Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- common/cmd_nvedit.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 3474bc6..c38b475 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -213,6 +213,9 @@ int env_check_apply(const char *name, const char *oldval, { int console = -1;
+ /* Default value for NULL to protect string-manipulating functions */ + newval = newval ? : ""; + /* Check for console redirection */ if (strcmp(name, "stdin") == 0) console = stdin;
- /* Default value for NULL to protect string-manipulating functions */
- newval = newval ? : "";
- /* Check for console redirection */ if (strcmp(name, "stdin") == 0) console = stdin;
It fixes the issue.
Tested-by: Stefano Babic sbabic@denx.de
Hi Stefano,
Hi Stefano,
Hi Gerlando,
I didn't know that, thanks.
My idea here was to "apply" the changes as soon as the environment gets changed, like it would happen with a manual "setenv"/"env set". So for instance, if you switch from a custom baudrate back to the default baudrate, you get a message prompting you to switch to the new baudrate (which actually *DOES* change on the console).
Whether that should also be performed as a "cleanup" action upon restoring defaults, well I am not sure...
Absolutely. See my proposed patch.
Absolutely. Once again, I cannot apologize and thank you enough for reporting and digging into this. I assumed providing an own patch would make more sense than asking you to review yours, not sure whether it is popular practice to do so.
Indeed.
Right, but since the return value is also ignored, what's the point in calling it in the first place?
Best regards, Gerlando
This is exactly the reason I am personally not so convinced to do it. This forbids to reset the environment in a script. In fact, nobody wants that a script stops waiting for input.
Think this use case. A board come back from field and in the factory the original status should be restored. It can be easy done with a script that contains "env default -f -a", plus parts to restore the original software. The whole script should run, and not wait for input.
My personal opinion is that who issues such commands (as restoring the environment, or destroying data in flash, or..) knows what is doing and it should not be forbidden to do what he minds.
I explained my opinion above ;-). But this has nothing to do with the patch, that must fix a crash.
Never mind. It is only important to fix the bug ;-)
Gerlando Falauto
Stefano Babic
