[U-Boot] [PATCH] README: Rearrange paragraphs to regain linear arrangement.
Two later additions to the Configuration Option section unfortunately split the description of Show boot progress and the list of its call outs.
Signed-off-by: Detlev Zundel dzu@denx.de --- README | 40 ++++++++++++++++++++-------------------- 1 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/README b/README index 2c77687..c9de016 100644 --- a/README +++ b/README @@ -1,5 +1,5 @@ # -# (C) Copyright 2000 - 2008 +# (C) Copyright 2000 - 2009 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # See file CREDITS for list of people who contributed to this @@ -1889,25 +1889,6 @@ The following options need to be configured: example, some LED's) on your board. At the moment, the following checkpoints are implemented:
-- Automatic software updates via TFTP server - CONFIG_UPDATE_TFTP - CONFIG_UPDATE_TFTP_CNT_MAX - CONFIG_UPDATE_TFTP_MSEC_MAX - - These options enable and control the auto-update feature; - for a more detailed description refer to doc/README.update. - -- MTD Support (mtdparts command, UBI support) - CONFIG_MTD_DEVICE - - Adds the MTD device infrastructure from the Linux kernel. - Needed for mtdparts command support. - - CONFIG_MTD_PARTITIONS - - Adds the MTD partitioning infrastructure from the Linux - kernel. Needed for UBI support. - Legacy uImage format:
Arg Where When @@ -2061,6 +2042,25 @@ FIT uImage format: -150 common/cmd_nand.c Incorrect FIT image format 151 common/cmd_nand.c FIT image format OK
+- Automatic software updates via TFTP server + CONFIG_UPDATE_TFTP + CONFIG_UPDATE_TFTP_CNT_MAX + CONFIG_UPDATE_TFTP_MSEC_MAX + + These options enable and control the auto-update feature; + for a more detailed description refer to doc/README.update. + +- MTD Support (mtdparts command, UBI support) + CONFIG_MTD_DEVICE + + Adds the MTD device infrastructure from the Linux kernel. + Needed for mtdparts command support. + + CONFIG_MTD_PARTITIONS + + Adds the MTD partitioning infrastructure from the Linux + kernel. Needed for UBI support. +
Modem Support: --------------
Dear Detlev Zundel,
Applied, thanks.
Detlev Zundel
