[PATCH] arm: mvebu: AC5/AC5X: use fixed page table size
Since commit 6cdf6b7a340d ("arm64: Use FEAT_HAFDBS to track dirty pages when available") the default get_page_table_size() sets some flags for more efficient handling of dirty page table entries. This causes problems on the AC5/AC5X SoC (specifically a lockup when calling __asm_switch_ttbr() via mmu_set_region_dcache_behaviour()).
The reason for the lockup isn't at all clear but it can be avoided if we provide our own get_page_table_size() which stops gd->arch.has_hafdbs from being set to true effectively returning the AC5/AC5X to the older behaviour. This also opts for a simple fixed page table size rather than trying to duplicate the more complicated logic to optimise the table size.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
arch/arm/mach-mvebu/alleycat5/cpu.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/mach-mvebu/alleycat5/cpu.c b/arch/arm/mach-mvebu/alleycat5/cpu.c index 8204d9627515..7ba57ae75e76 100644 --- a/arch/arm/mach-mvebu/alleycat5/cpu.c +++ b/arch/arm/mach-mvebu/alleycat5/cpu.c @@ -63,6 +63,11 @@ static struct mm_region ac5_mem_map[] = {
struct mm_region *mem_map = ac5_mem_map;
+u64 get_page_table_size(void) +{ + return 0x80000; +} + void reset_cpu(void) { }
Hi Chris,
I'm not 100% happy with this approach / workaround - still it fixes an issue on your board, so:
Perhaps you (or someone else) can look into this in more depth to get to the root of this issue at a later time.
Thanks, Stefan
- return 0x80000;
- void reset_cpu(void) { }
Viele Grüße, Stefan Roese
On Fri, 20 Oct 2023, 7:18 pm Stefan Roese, sr@denx.de wrote:
Hi Chris,
Yeah I'm not super happy about this either. But this is about the best I could come up with.
I did spend a reasonable amount of time tracking down where things were going wrong, even if I couldn't figure out why. The commit message basically reflects what I found.
Thanks, Stefan
return 0x80000;
-- DENX Software Engineering GmbH, Managing Director: Erika Unter HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
On 10/20/23 10:21, Chris Packham wrote:
On Fri, 20 Oct 2023, 7:18 pm Stefan Roese, <sr@denx.de mailto:sr@denx.de> wrote:
Hi Chris, On 10/18/23 22:53, Chris Packham wrote: > Since commit 6cdf6b7a340d ("arm64: Use FEAT_HAFDBS to track dirty pages > when available") the default get_page_table_size() sets some flags for > more efficient handling of dirty page table entries. This causes > problems on the AC5/AC5X SoC (specifically a lockup when calling > __asm_switch_ttbr() via mmu_set_region_dcache_behaviour()). > > The reason for the lockup isn't at all clear but it can be avoided if we > provide our own get_page_table_size() which stops gd->arch.has_hafdbs > from being set to true effectively returning the AC5/AC5X to the older > behaviour. This also opts for a simple fixed page table size rather than > trying to duplicate the more complicated logic to optimise the table > size. > > Signed-off-by: Chris Packham <judge.packham@gmail.com <mailto:judge.packham@gmail.com>> I'm not 100% happy with this approach / workaround - still it fixes an issue on your board, so: Reviewed-by: Stefan Roese <sr@denx.de <mailto:sr@denx.de>>
Applied to u-boot-marvell/master
Thanks, Stefan
Thanks, Stefan > --- > > arch/arm/mach-mvebu/alleycat5/cpu.c | 5 +++++ > 1 file changed, 5 insertions(+) > > diff --git a/arch/arm/mach-mvebu/alleycat5/cpu.c b/arch/arm/mach-mvebu/alleycat5/cpu.c > index 8204d9627515..7ba57ae75e76 100644 > --- a/arch/arm/mach-mvebu/alleycat5/cpu.c > +++ b/arch/arm/mach-mvebu/alleycat5/cpu.c > @@ -63,6 +63,11 @@ static struct mm_region ac5_mem_map[] = { > > struct mm_region *mem_map = ac5_mem_map; > > +u64 get_page_table_size(void) > +{ > + return 0x80000; > +} > + > void reset_cpu(void) > { > } Viele Grüße, Stefan Roese -- DENX Software Engineering GmbH, Managing Director: Erika Unter HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de <mailto:sr@denx.de>
- return 0x80000;
This looks terribly wrong. In all honesty, if the original patch creates problems and that people add this sort of stuff to paper over it, I'd rather your *revert* my patch altogether.
M.
return 0x80000;
There are other platforms that define a get_page_table_size(). That may mean that they are just inadvertently avoiding the issues I'm seeing.
I'm happy to prepare a series reverting the problematic changes. But I'm sure that there's something about the AC5 that's the actual problem. I'm just out of my depth in terms of my ability to progress it.
M.
-- Jazz is not dead. It just smells funny...
Chris Packham
Marc Zyngier
Stefan Roese
