[PATCH 0/3] Initial support for Pinephone Pro
This adds initial support for the PINE64 Pinephone Pro. It's a rebase to upstream core rk3399 DT pieces, and the addition of the upstream PPP DT from 6.1-rc1 and the U-Boot pieces are based on my work on the Pinebook Pro.
Peter Robinson (3): arm64: dts: rk3399: sync rk3399.dtsi from 6.1-rc1 arm64: dts: rk3399: Add upstream Pinephone Pro dts rockchip: Add initial support for the PINE64 Pinephone Pro
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-opp.dtsi | 6 +- arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi | 39 ++ arch/arm/dts/rk3399-pinephone-pro.dts | 398 ++++++++++++++++++ arch/arm/dts/rk3399-u-boot.dtsi | 36 +- arch/arm/dts/rk3399.dtsi | 200 ++++++++- arch/arm/mach-rockchip/rk3399/Kconfig | 8 + board/pine64/pinephone-pro-rk3399/Kconfig | 15 + board/pine64/pinephone-pro-rk3399/MAINTAINERS | 8 + board/pine64/pinephone-pro-rk3399/Makefile | 1 + .../pinephone-pro-rk3399.c | 76 ++++ configs/pinephone-pro-rk3399_defconfig | 104 +++++ drivers/clk/rockchip/clk_rk3399.c | 2 +- include/configs/pinephone-pro-rk3399.h | 19 + include/dt-bindings/clock/rk3399-cru.h | 24 +- include/dt-bindings/power/rk3399-power.h | 1 + 16 files changed, 875 insertions(+), 63 deletions(-) create mode 100644 arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-pinephone-pro.dts create mode 100644 board/pine64/pinephone-pro-rk3399/Kconfig create mode 100644 board/pine64/pinephone-pro-rk3399/MAINTAINERS create mode 100644 board/pine64/pinephone-pro-rk3399/Makefile create mode 100644 board/pine64/pinephone-pro-rk3399/pinephone-pro-rk3399.c create mode 100644 configs/pinephone-pro-rk3399_defconfig create mode 100644 include/configs/pinephone-pro-rk3399.h
Sync rk3399.dtsi and associated bindings includes. Fix up building of clk/rockchip/clk_rk3399.c for the changes as well as adjusting the rk3399-u-boot.dtsi for the new upstream pieces.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- arch/arm/dts/rk3399-opp.dtsi | 6 +- arch/arm/dts/rk3399-u-boot.dtsi | 36 ++-- arch/arm/dts/rk3399.dtsi | 200 ++++++++++++++++++++--- drivers/clk/rockchip/clk_rk3399.c | 2 +- include/dt-bindings/clock/rk3399-cru.h | 24 +-- include/dt-bindings/power/rk3399-power.h | 1 + 6 files changed, 206 insertions(+), 63 deletions(-)
diff --git a/arch/arm/dts/rk3399-opp.dtsi b/arch/arm/dts/rk3399-opp.dtsi index da41cd81ebb..fee5e711127 100644 --- a/arch/arm/dts/rk3399-opp.dtsi +++ b/arch/arm/dts/rk3399-opp.dtsi @@ -4,7 +4,7 @@ */
/ { - cluster0_opp: opp-table0 { + cluster0_opp: opp-table-0 { compatible = "operating-points-v2"; opp-shared;
@@ -35,7 +35,7 @@ }; };
- cluster1_opp: opp-table1 { + cluster1_opp: opp-table-1 { compatible = "operating-points-v2"; opp-shared;
@@ -74,7 +74,7 @@ }; };
- gpu_opp_table: opp-table2 { + gpu_opp_table: opp-table-2 { compatible = "operating-points-v2";
opp00 { diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi index 3c1a15fe51b..2fa8f25a3e1 100644 --- a/arch/arm/dts/rk3399-u-boot.dtsi +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -20,38 +20,12 @@ reg = <0x0 0xff620000 0x0 0x100>; };
- dfi: dfi@ff630000 { - u-boot,dm-pre-reloc; - reg = <0x00 0xff630000 0x00 0x4000>; - compatible = "rockchip,rk3399-dfi"; - rockchip,pmu = <&pmugrf>; - clocks = <&cru PCLK_DDR_MON>; - clock-names = "pclk_ddr_mon"; - }; - rng: rng@ff8b8000 { compatible = "rockchip,cryptov1-rng"; reg = <0x0 0xff8b8000 0x0 0x1000>; status = "okay"; };
- dmc: dmc { - u-boot,dm-pre-reloc; - compatible = "rockchip,rk3399-dmc"; - devfreq-events = <&dfi>; - interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_DDRCLK>; - clock-names = "dmc_clk"; - reg = <0x0 0xffa80000 0x0 0x0800 - 0x0 0xffa80800 0x0 0x1800 - 0x0 0xffa82000 0x0 0x2000 - 0x0 0xffa84000 0x0 0x1000 - 0x0 0xffa88000 0x0 0x0800 - 0x0 0xffa88800 0x0 0x1800 - 0x0 0xffa8a000 0x0 0x2000 - 0x0 0xffa8c000 0x0 0x1000>; - }; - pmusgrf: syscon@ff330000 { u-boot,dm-pre-reloc; compatible = "rockchip,rk3399-pmusgrf", "syscon"; @@ -88,6 +62,16 @@ u-boot,dm-pre-reloc; };
+&dfi { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&dmc { + u-boot,dm-pre-reloc; + status = "okay"; +}; + &emmc_phy { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 3871c7fd83b..92c2207e686 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -124,6 +124,12 @@ #cooling-cells = <2>; /* min followed by max */ dynamic-power-coefficient = <436>; cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; + + thermal-idle { + #cooling-cells = <2>; + duration-us = <10000>; + exit-latency-us = <500>; + }; };
cpu_b1: cpu@101 { @@ -136,6 +142,12 @@ #cooling-cells = <2>; /* min followed by max */ dynamic-power-coefficient = <436>; cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; + + thermal-idle { + #cooling-cells = <2>; + duration-us = <10000>; + exit-latency-us = <500>; + }; };
idle-states { @@ -166,6 +178,15 @@ ports = <&vopl_out>, <&vopb_out>; };
+ dmc: memory-controller { + compatible = "rockchip,rk3399-dmc"; + rockchip,pmu = <&pmugrf>; + devfreq-events = <&dfi>; + clocks = <&cru SCLK_DDRC>; + clock-names = "dmc_clk"; + status = "disabled"; + }; + pmu_a53 { compatible = "arm,cortex-a53-pmu"; interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster0>; @@ -361,6 +382,54 @@ status = "disabled"; };
+ debug@fe430000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0 0xfe430000 0 0x1000>; + clocks = <&cru PCLK_COREDBG_L>; + clock-names = "apb_pclk"; + cpu = <&cpu_l0>; + }; + + debug@fe432000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0 0xfe432000 0 0x1000>; + clocks = <&cru PCLK_COREDBG_L>; + clock-names = "apb_pclk"; + cpu = <&cpu_l1>; + }; + + debug@fe434000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0 0xfe434000 0 0x1000>; + clocks = <&cru PCLK_COREDBG_L>; + clock-names = "apb_pclk"; + cpu = <&cpu_l2>; + }; + + debug@fe436000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0 0xfe436000 0 0x1000>; + clocks = <&cru PCLK_COREDBG_L>; + clock-names = "apb_pclk"; + cpu = <&cpu_l3>; + }; + + debug@fe610000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0 0xfe610000 0 0x1000>; + clocks = <&cru PCLK_COREDBG_B>; + clock-names = "apb_pclk"; + cpu = <&cpu_b0>; + }; + + debug@fe710000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0 0xfe710000 0 0x1000>; + clocks = <&cru PCLK_COREDBG_B>; + clock-names = "apb_pclk"; + cpu = <&cpu_b1>; + }; + usbdrd3_0: usb@fe800000 { compatible = "rockchip,rk3399-dwc3"; #address-cells = <2>; @@ -1235,6 +1304,16 @@ status = "disabled"; };
+ dfi: dfi@ff630000 { + reg = <0x00 0xff630000 0x00 0x4000>; + compatible = "rockchip,rk3399-dfi"; + rockchip,pmu = <&pmugrf>; + interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru PCLK_DDR_MON>; + clock-names = "pclk_ddr_mon"; + status = "disabled"; + }; + vpu: video-codec@ff650000 { compatible = "rockchip,rk3399-vpu"; reg = <0x0 0xff650000 0x0 0x800>; @@ -1251,7 +1330,6 @@ compatible = "rockchip,iommu"; reg = <0x0 0xff650800 0x0 0x40>; interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "vpu_mmu"; clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; clock-names = "aclk", "iface"; #iommu-cells = <0>; @@ -1273,7 +1351,6 @@ compatible = "rockchip,iommu"; reg = <0x0 0xff660480 0x0 0x40>, <0x0 0xff6604c0 0x0 0x40>; interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "vdec_mmu"; clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>; clock-names = "aclk", "iface"; power-domains = <&power RK3399_PD_VDU>; @@ -1284,7 +1361,6 @@ compatible = "rockchip,iommu"; reg = <0x0 0xff670800 0x0 0x40>; interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "iep_mmu"; clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; clock-names = "aclk", "iface"; #iommu-cells = <0>; @@ -1356,9 +1432,11 @@ clock-names = "apb_pclk"; };
- pmucru: pmu-clock-controller@ff750000 { + pmucru: clock-controller@ff750000 { compatible = "rockchip,rk3399-pmucru"; reg = <0x0 0xff750000 0x0 0x1000>; + clocks = <&xin24m>; + clock-names = "xin24m"; rockchip,grf = <&pmugrf>; #clock-cells = <1>; #reset-cells = <1>; @@ -1369,6 +1447,8 @@ cru: clock-controller@ff760000 { compatible = "rockchip,rk3399-cru"; reg = <0x0 0xff760000 0x0 0x1000>; + clocks = <&xin24m>; + clock-names = "xin24m"; rockchip,grf = <&grf>; #clock-cells = <1>; #reset-cells = <1>; @@ -1382,7 +1462,8 @@ <&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>, <&cru ACLK_VIO>, <&cru ACLK_HDCP>, <&cru ACLK_GIC_PRE>, - <&cru PCLK_DDR>; + <&cru PCLK_DDR>, + <&cru ACLK_VDU>; assigned-clock-rates = <594000000>, <800000000>, <1000000000>, @@ -1393,7 +1474,8 @@ <100000000>, <50000000>, <400000000>, <400000000>, <200000000>, - <200000000>; + <200000000>, + <400000000>; };
grf: syscon@ff770000 { @@ -1477,6 +1559,7 @@ reg = <0xf780 0x24>; clocks = <&sdhci>; clock-names = "emmcclk"; + drive-impedance-ohm = <50>; #phy-cells = <0>; status = "disabled"; }; @@ -1487,7 +1570,6 @@ clock-names = "refclk"; #phy-cells = <1>; resets = <&cru SRST_PCIEPHY>; - drive-impedance-ohm = <50>; reset-names = "phy"; status = "disabled"; }; @@ -1582,8 +1664,9 @@ dma-names = "tx", "rx"; clock-names = "i2s_clk", "i2s_hclk"; clocks = <&cru SCLK_I2S0_8CH>, <&cru HCLK_I2S0_8CH>; - pinctrl-names = "default"; + pinctrl-names = "bclk_on", "bclk_off"; pinctrl-0 = <&i2s0_8ch_bus>; + pinctrl-1 = <&i2s0_8ch_bus_bclk_off>; power-domains = <&power RK3399_PD_SDIOAUDIO>; #sound-dai-cells = <0>; status = "disabled"; @@ -1619,7 +1702,7 @@
vopl: vop@ff8f0000 { compatible = "rockchip,rk3399-vop-lit"; - reg = <0x0 0xff8f0000 0x0 0x3efc>; + reg = <0x0 0xff8f0000 0x0 0x2000>, <0x0 0xff8f2000 0x0 0x400>; interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH 0>; assigned-clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; assigned-clock-rates = <400000000>, <100000000>; @@ -1666,7 +1749,6 @@ compatible = "rockchip,iommu"; reg = <0x0 0xff8f3f00 0x0 0x100>; interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "vopl_mmu"; clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; clock-names = "aclk", "iface"; power-domains = <&power RK3399_PD_VOPL>; @@ -1676,7 +1758,7 @@
vopb: vop@ff900000 { compatible = "rockchip,rk3399-vop-big"; - reg = <0x0 0xff900000 0x0 0x3efc>; + reg = <0x0 0xff900000 0x0 0x2000>, <0x0 0xff902000 0x0 0x1000>; interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH 0>; assigned-clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; assigned-clock-rates = <400000000>, <100000000>; @@ -1723,7 +1805,6 @@ compatible = "rockchip,iommu"; reg = <0x0 0xff903f00 0x0 0x100>; interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "vopb_mmu"; clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; clock-names = "aclk", "iface"; power-domains = <&power RK3399_PD_VOPB>; @@ -1761,7 +1842,6 @@ compatible = "rockchip,iommu"; reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "isp0_mmu"; clocks = <&cru ACLK_ISP0_WRAPPER>, <&cru HCLK_ISP0_WRAPPER>; clock-names = "aclk", "iface"; #iommu-cells = <0>; @@ -1769,11 +1849,36 @@ rockchip,disable-mmu-reset; };
+ isp1: isp1@ff920000 { + compatible = "rockchip,rk3399-cif-isp"; + reg = <0x0 0xff920000 0x0 0x4000>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru SCLK_ISP1>, + <&cru ACLK_ISP1_WRAPPER>, + <&cru HCLK_ISP1_WRAPPER>; + clock-names = "isp", "aclk", "hclk"; + iommus = <&isp1_mmu>; + phys = <&mipi_dsi1>; + phy-names = "dphy"; + power-domains = <&power RK3399_PD_ISP1>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + }; + isp1_mmu: iommu@ff924000 { compatible = "rockchip,iommu"; reg = <0x0 0xff924000 0x0 0x100>, <0x0 0xff925000 0x0 0x100>; interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "isp1_mmu"; clocks = <&cru ACLK_ISP1_WRAPPER>, <&cru HCLK_ISP1_WRAPPER>; clock-names = "aclk", "iface"; #iommu-cells = <0>; @@ -1802,10 +1907,10 @@ interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH 0>; clocks = <&cru PCLK_HDMI_CTRL>, <&cru SCLK_HDMI_SFR>, - <&cru PLL_VPLL>, + <&cru SCLK_HDMI_CEC>, <&cru PCLK_VIO_GRF>, - <&cru SCLK_HDMI_CEC>; - clock-names = "iahb", "isfr", "vpll", "grf", "cec"; + <&cru PLL_VPLL>; + clock-names = "iahb", "isfr", "cec", "grf", "ref"; power-domains = <&power RK3399_PD_HDCP>; reg-io-width = <4>; rockchip,grf = <&grf>; @@ -1878,6 +1983,7 @@ rockchip,grf = <&grf>; #address-cells = <1>; #size-cells = <0>; + #phy-cells = <0>; status = "disabled";
ports { @@ -1958,7 +2064,7 @@ #size-cells = <2>; ranges;
- gpio0: gpio0@ff720000 { + gpio0: gpio@ff720000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff720000 0x0 0x100>; clocks = <&pmucru PCLK_GPIO0_PMU>; @@ -1971,7 +2077,7 @@ #interrupt-cells = <0x2>; };
- gpio1: gpio1@ff730000 { + gpio1: gpio@ff730000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff730000 0x0 0x100>; clocks = <&pmucru PCLK_GPIO1_PMU>; @@ -1984,7 +2090,7 @@ #interrupt-cells = <0x2>; };
- gpio2: gpio2@ff780000 { + gpio2: gpio@ff780000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff780000 0x0 0x100>; clocks = <&cru PCLK_GPIO2>; @@ -1997,7 +2103,7 @@ #interrupt-cells = <0x2>; };
- gpio3: gpio3@ff788000 { + gpio3: gpio@ff788000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff788000 0x0 0x100>; clocks = <&cru PCLK_GPIO3>; @@ -2010,7 +2116,7 @@ #interrupt-cells = <0x2>; };
- gpio4: gpio4@ff790000 { + gpio4: gpio@ff790000 { compatible = "rockchip,gpio-bank"; reg = <0x0 0xff790000 0x0 0x100>; clocks = <&cru PCLK_GPIO4>; @@ -2108,12 +2214,40 @@ output-low; };
+ pcfg_input_enable: pcfg-input-enable { + input-enable; + }; + + pcfg_input_pull_up: pcfg-input-pull-up { + input-enable; + bias-pull-up; + drive-strength = <2>; + }; + + pcfg_input_pull_down: pcfg-input-pull-down { + input-enable; + bias-pull-down; + drive-strength = <2>; + }; + clock { clk_32k: clk-32k { rockchip,pins = <0 RK_PA0 2 &pcfg_pull_none>; }; };
+ cif { + cif_clkin: cif-clkin { + rockchip,pins = + <2 RK_PB2 3 &pcfg_pull_none>; + }; + + cif_clkouta: cif-clkouta { + rockchip,pins = + <2 RK_PB3 3 &pcfg_pull_none>; + }; + }; + edp { edp_hpd: edp-hpd { rockchip,pins = @@ -2276,6 +2410,19 @@ <3 RK_PD7 1 &pcfg_pull_none>, <4 RK_PA0 1 &pcfg_pull_none>; }; + + i2s0_8ch_bus_bclk_off: i2s0-8ch-bus-bclk-off { + rockchip,pins = + <3 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>, + <3 RK_PD1 1 &pcfg_pull_none>, + <3 RK_PD2 1 &pcfg_pull_none>, + <3 RK_PD3 1 &pcfg_pull_none>, + <3 RK_PD4 1 &pcfg_pull_none>, + <3 RK_PD5 1 &pcfg_pull_none>, + <3 RK_PD6 1 &pcfg_pull_none>, + <3 RK_PD7 1 &pcfg_pull_none>, + <4 RK_PA0 1 &pcfg_pull_none>; + }; };
i2s1 { @@ -2287,6 +2434,15 @@ <4 RK_PA6 1 &pcfg_pull_none>, <4 RK_PA7 1 &pcfg_pull_none>; }; + + i2s1_2ch_bus_bclk_off: i2s1-2ch-bus-bclk-off { + rockchip,pins = + <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>, + <4 RK_PA4 1 &pcfg_pull_none>, + <4 RK_PA5 1 &pcfg_pull_none>, + <4 RK_PA6 1 &pcfg_pull_none>, + <4 RK_PA7 1 &pcfg_pull_none>; + }; };
sdio0 { diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 97bf1c6e15b..e968ddf894b 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -1049,7 +1049,7 @@ static ulong rk3399_clk_set_rate(struct clk *clk, ulong rate) * return 0 to satisfy clk_set_defaults during device probe. */ return 0; - case SCLK_DDRCLK: + case SCLK_TESTCLKOUT2: ret = rk3399_ddr_set_clk(priv->cru, rate); break; case PCLK_EFUSE1024NS: diff --git a/include/dt-bindings/clock/rk3399-cru.h b/include/dt-bindings/clock/rk3399-cru.h index 211faf8fa89..44e0a319f07 100644 --- a/include/dt-bindings/clock/rk3399-cru.h +++ b/include/dt-bindings/clock/rk3399-cru.h @@ -1,6 +1,7 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0-or-later */ /* * Copyright (c) 2016 Rockchip Electronics Co. Ltd. + * Author: Xing Zheng zhengxing@rock-chips.com */
#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H @@ -121,16 +122,17 @@ #define SCLK_DPHY_RX0_CFG 165 #define SCLK_RMII_SRC 166 #define SCLK_PCIEPHY_REF100M 167 -#define SCLK_USBPHY0_480M_SRC 168 -#define SCLK_USBPHY1_480M_SRC 169 -#define SCLK_DDRCLK 170 -#define SCLK_TESTOUT2 171 +#define SCLK_DDRC 168 +#define SCLK_TESTCLKOUT1 169 +#define SCLK_TESTCLKOUT2 170
#define DCLK_VOP0 180 #define DCLK_VOP1 181 #define DCLK_VOP0_DIV 182 #define DCLK_VOP1_DIV 183 #define DCLK_M0_PERILP 184 +#define DCLK_VOP0_FRAC 185 +#define DCLK_VOP1_FRAC 186
#define FCLK_CM0S 190
@@ -592,13 +594,13 @@ #define SRST_P_SPI0 214 #define SRST_P_SPI1 215 #define SRST_P_SPI2 216 -#define SRST_P_SPI4 217 -#define SRST_P_SPI5 218 +#define SRST_P_SPI3 217 +#define SRST_P_SPI4 218 #define SRST_SPI0 219 #define SRST_SPI1 220 #define SRST_SPI2 221 -#define SRST_SPI4 222 -#define SRST_SPI5 223 +#define SRST_SPI3 222 +#define SRST_SPI4 223
/* cru_softrst_con14 */ #define SRST_I2S0_8CH 224 @@ -720,8 +722,8 @@ #define SRST_H_CM0S_NOC 3 #define SRST_DBG_CM0S 4 #define SRST_PO_CM0S 5 -#define SRST_P_SPI3 6 -#define SRST_SPI3 7 +#define SRST_P_SPI6 6 +#define SRST_SPI6 7 #define SRST_P_TIMER_0_1 8 #define SRST_P_TIMER_0 9 #define SRST_P_TIMER_1 10 diff --git a/include/dt-bindings/power/rk3399-power.h b/include/dt-bindings/power/rk3399-power.h index 168b3bfbd6f..aedd8b180fe 100644 --- a/include/dt-bindings/power/rk3399-power.h +++ b/include/dt-bindings/power/rk3399-power.h @@ -1,3 +1,4 @@ +/* SPDX-License-Identifier: GPL-2.0 */ #ifndef __DT_BINDINGS_POWER_RK3399_POWER_H__ #define __DT_BINDINGS_POWER_RK3399_POWER_H__
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- cluster0_opp: opp-table-0 { compatible = "operating-points-v2"; opp-shared;
- cluster1_opp: opp-table-1 { compatible = "operating-points-v2"; opp-shared;
opp00 {
dfi: dfi@ff630000 {
dmc: dmc {
+&dfi {
- status = "okay";
+&dmc {
- status = "okay";
- &emmc_phy { u-boot,dm-pre-reloc; };
thermal-idle {
cpu_b1: cpu@101 {
thermal-idle {
idle-states {
- dmc: memory-controller {
- pmu_a53 { compatible = "arm,cortex-a53-pmu"; interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster0>;
- debug@fe430000 {
cpu = <&cpu_l0>;
- debug@fe432000 {
cpu = <&cpu_l1>;
- debug@fe434000 {
cpu = <&cpu_l2>;
- debug@fe436000 {
cpu = <&cpu_l3>;
- debug@fe610000 {
cpu = <&cpu_b0>;
- debug@fe710000 {
cpu = <&cpu_b1>;
- usbdrd3_0: usb@fe800000 { compatible = "rockchip,rk3399-dwc3"; #address-cells = <2>;
- vpu: video-codec@ff650000 { compatible = "rockchip,rk3399-vpu"; reg = <0x0 0xff650000 0x0 0x800>;
clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; clock-names = "aclk", "iface"; #iommu-cells = <0>;interrupt-names = "vpu_mmu";
clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>; clock-names = "aclk", "iface"; power-domains = <&power RK3399_PD_VDU>;interrupt-names = "vdec_mmu";
clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; clock-names = "aclk", "iface"; #iommu-cells = <0>;interrupt-names = "iep_mmu";
- pmucru: clock-controller@ff750000 { compatible = "rockchip,rk3399-pmucru"; reg = <0x0 0xff750000 0x0 0x1000>;
clocks = <&xin24m>;
rockchip,grf = <&pmugrf>; #clock-cells = <1>; #reset-cells = <1>;clock-names = "xin24m";
clocks = <&xin24m>;
rockchip,grf = <&grf>; #clock-cells = <1>; #reset-cells = <1>;clock-names = "xin24m";
<&cru PCLK_DDR>;
<&cru PCLK_DDR>,
assigned-clock-rates = <594000000>, <800000000>, <1000000000>,<&cru ACLK_VDU>;
<200000000>;
<200000000>,
<400000000>;
};drive-impedance-ohm = <50>; #phy-cells = <0>; status = "disabled";
};drive-impedance-ohm = <50>; reset-names = "phy"; status = "disabled";
pinctrl-0 = <&i2s0_8ch_bus>;pinctrl-names = "bclk_on", "bclk_off";
power-domains = <&power RK3399_PD_SDIOAUDIO>; #sound-dai-cells = <0>; status = "disabled";pinctrl-1 = <&i2s0_8ch_bus_bclk_off>;
interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH 0>; assigned-clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; assigned-clock-rates = <400000000>, <100000000>;reg = <0x0 0xff8f0000 0x0 0x2000>, <0x0 0xff8f2000 0x0 0x400>;
clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; clock-names = "aclk", "iface"; power-domains = <&power RK3399_PD_VOPL>;interrupt-names = "vopl_mmu";
interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH 0>; assigned-clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; assigned-clock-rates = <400000000>, <100000000>;reg = <0x0 0xff900000 0x0 0x2000>, <0x0 0xff902000 0x0 0x1000>;
clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; clock-names = "aclk", "iface"; power-domains = <&power RK3399_PD_VOPB>;interrupt-names = "vopb_mmu";
clocks = <&cru ACLK_ISP0_WRAPPER>, <&cru HCLK_ISP0_WRAPPER>; clock-names = "aclk", "iface"; #iommu-cells = <0>;interrupt-names = "isp0_mmu";
- isp1: isp1@ff920000 {
phy-names = "dphy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
- isp1_mmu: iommu@ff924000 { compatible = "rockchip,iommu"; reg = <0x0 0xff924000 0x0 0x100>, <0x0 0xff925000 0x0 0x100>; interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru ACLK_ISP1_WRAPPER>, <&cru HCLK_ISP1_WRAPPER>; clock-names = "aclk", "iface"; #iommu-cells = <0>;interrupt-names = "isp1_mmu";
<&cru PLL_VPLL>,
<&cru PLL_VPLL>;
power-domains = <&power RK3399_PD_HDCP>; reg-io-width = <4>; rockchip,grf = <&grf>;clock-names = "iahb", "isfr", "cec", "grf", "ref";
#phy-cells = <0>;
ports {
input-enable;
input-enable;
bias-pull-up;
input-enable;
bias-pull-down;
cif {
rockchip,pins =
rockchip,pins =
rockchip,pins =
i2s1 {
rockchip,pins =
sdio0 {
- case SCLK_DDRCLK:
- case SCLK_TESTCLKOUT2: ret = rk3399_ddr_set_clk(priv->cru, rate); break; case PCLK_EFUSE1024NS:
- Copyright (c) 2016 Rockchip Electronics Co. Ltd.
- Author: Xing Zheng zhengxing@rock-chips.com
Hi Peter,
opp00 {
dfi: dfi@ff630000 {
dmc: dmc {
+&dfi {
- status = "okay";
+&dmc {
- status = "okay";
thermal-idle {
cpu_b1: cpu@101 {
thermal-idle {
idle-states {
- debug@fe430000 {
cpu = <&cpu_l0>;
- debug@fe432000 {
cpu = <&cpu_l1>;
- debug@fe434000 {
cpu = <&cpu_l2>;
- debug@fe436000 {
cpu = <&cpu_l3>;
- debug@fe610000 {
cpu = <&cpu_b0>;
- debug@fe710000 {
cpu = <&cpu_b1>;
clocks = <&xin24m>;
clocks = <&xin24m>;
<&cru PCLK_DDR>;
<&cru PCLK_DDR>,
<200000000>;
<200000000>,
<400000000>;
phy-names = "dphy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
<&cru PLL_VPLL>,
<&cru PLL_VPLL>;
#phy-cells = <0>;
ports {
Thanks for looking at this update, I myself was playing with this for all Rockchip devices but it's really not that easy to do unfortunately.
Please note that this will break the gpio driver, c.f. the logic here: https://source.denx.de/u-boot/u-boot/-/blob/master/drivers/gpio/rk_gpio.c#L1...
Please DO NOT use the logic used in the kernel, it's broken and works by chance and will not work in U-Boot.
I'm tempted to add a new DT property like: rockchip,gpio-controller = <0>; in gpio0, rockchip,gpio-controller = <1>; in gpio1, etc....
I don't think U-boot cares too much about DT backward compatibility so this wouldn't be much of a problem. It's a different issue in the Linux kernel but that's not the place to discuss this :)
Cheers, Quentin
input-enable;
input-enable;
bias-pull-up;
input-enable;
bias-pull-down;
cif {
rockchip,pins =
rockchip,pins =
rockchip,pins =
i2s1 {
rockchip,pins =
sdio0 {
- case SCLK_DDRCLK:
Hi Quentin,
gpu_opp_table: opp-table-2 { compatible = "operating-points-v2"; opp00 {
dfi: dfi@ff630000 {
dmc: dmc {
+&dfi {
status = "okay";
+&dmc {
status = "okay";
thermal-idle {
}; }; cpu_b1: cpu@101 {
thermal-idle {
}; }; idle-states {
debug@fe430000 {
cpu = <&cpu_l0>;
debug@fe432000 {
cpu = <&cpu_l1>;
debug@fe434000 {
cpu = <&cpu_l2>;
debug@fe436000 {
cpu = <&cpu_l3>;
debug@fe610000 {
cpu = <&cpu_b0>;
debug@fe710000 {
cpu = <&cpu_b1>;
dfi: dfi@ff630000 {
clocks = <&xin24m>;
clocks = <&xin24m>;
<&cru PCLK_DDR>;
<&cru PCLK_DDR>,
<200000000>;
<200000000>,
<400000000>; }; grf: syscon@ff770000 {
phy-names = "dphy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
<&cru PLL_VPLL>,
<&cru PLL_VPLL>;
#phy-cells = <0>; status = "disabled"; ports {
If you check v2 of this patch series I've currnently dropped this patch for now.
Well we do because for a SystemReady IR platform the firmware provides the DT and that's not a differnt DT to the one used in U-Boot.
So what ever that gets added in U-Boot needs to go upstream else it will just end up in a world of pain. Ultimately one way or the other this problem is going to have to be solved in U-Boot too.
Kever: what's the Rockchip plan here to sort this out?
input-enable;
input-enable;
bias-pull-up;
input-enable;
bias-pull-down;
cif {
rockchip,pins =
rockchip,pins =
rockchip,pins =
}; }; i2s1 {
rockchip,pins =
}; }; sdio0 {
case SCLK_DDRCLK:
On Tue, 3 Jan 2023 at 18:24, Peter Robinson pbrobinson@gmail.com wrote:
Hi Quentin,
dfi: dfi@ff630000 {
dmc: dmc {
+&dfi {
status = "okay";
+&dmc {
status = "okay";
thermal-idle {
thermal-idle {
}; }; idle-states {
debug@fe430000 {
cpu = <&cpu_l0>;
debug@fe432000 {
cpu = <&cpu_l1>;
debug@fe434000 {
cpu = <&cpu_l2>;
debug@fe436000 {
cpu = <&cpu_l3>;
debug@fe610000 {
cpu = <&cpu_b0>;
debug@fe710000 {
cpu = <&cpu_b1>;
dfi: dfi@ff630000 {
clocks = <&xin24m>;
clocks = <&xin24m>;
<&cru PCLK_DDR>;
<&cru PCLK_DDR>,
<200000000>;
<200000000>,
phy-names = "dphy";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
<&cru PLL_VPLL>,
<&cru PLL_VPLL>;
If the issue is to maintain Linux DT in U-Boot, then here is my suggestion (following the same in Allwinner as well) - Sync the DT from Linux and maintain them in -u-boot.dtsi if the specific bindings are unsupported or not working at the moment in U-Boot. In the long-run these -u-boot.dtsi specific stuff is gone if the driver is well supported.
Jagan.
Hi Peter,
On 1/3/23 13:54, Peter Robinson wrote:
Hi Quentin,
Please note that this will break the gpio driver, c.f. the logic here: https://urldefense.com/v3/__https://source.denx.de/u-boot/u-boot/-/blob/mast...
I guess that's what Simon was working on in the last few months? c.f. https://lore.kernel.org/u-boot/20221102031312.216353-1-sjg@chromium.org/
Is the plan to get rid of those -u-boot.dtsi and have those properties replaced with the ones specified in the link above, directly in DTS in the Linux kernel? Otherwise I'm quite curious on how you plan to achieve this for SystemReady IR platforms? Or are you using U-Boot's DT for the kernel?
For now, like Jagan suggested, we could have those U-Boot-specific properties in the -u-boot.dtsi, if there's a need for a new DT property (which the kernel probably won't go for since that would break backward compatibility).
Another thought I had was to just check the register address of the gpio controller and do the mapping in the driver directly. Not nice, but the most straightforward fix I think.
I've notified Heiko about the shortcomings of the kernel implementation but unless the probe order of the gpio controllers in the pinctrl node is not stable or someone specifies gpio aliases which aren't matching the same numbering scheme as the SoC GPIO controllers, there is no hurry to fix it.
Cheers, Quentin
Initial support for the PinePhone Pro has now landed upstream in Linux 6.1 RC1 so sync the dts from upstream for initial support.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-pinephone-pro.dts | 398 ++++++++++++++++++++++++++ 2 files changed, 399 insertions(+) create mode 100644 arch/arm/dts/rk3399-pinephone-pro.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 965895bc2a3..624c4f997c3 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -153,6 +153,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-nanopi-r4s.dtb \ rk3399-orangepi.dtb \ rk3399-pinebook-pro.dtb \ + rk3399-pinephone-pro.dtb \ rk3399-puma-haikou.dtb \ rk3399-roc-pc.dtb \ rk3399-roc-pc-mezzanine.dtb \ diff --git a/arch/arm/dts/rk3399-pinephone-pro.dts b/arch/arm/dts/rk3399-pinephone-pro.dts new file mode 100644 index 00000000000..2e058c31502 --- /dev/null +++ b/arch/arm/dts/rk3399-pinephone-pro.dts @@ -0,0 +1,398 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Martijn Braam martijn@brixit.nl + * Copyright (c) 2021 Kamil TrzciĆski ayufan@ayufan.eu + */ + +/* + * PinePhone Pro datasheet: + * https://files.pine64.org/doc/PinePhonePro/PinephonePro-Schematic-V1.0-202111... + */ + +/dts-v1/; +#include <dt-bindings/input/linux-event-codes.h> +#include "rk3399.dtsi" +#include "rk3399-opp.dtsi" + +/ { + model = "Pine64 PinePhonePro"; + compatible = "pine64,pinephone-pro", "rockchip,rk3399"; + chassis-type = "handset"; + + aliases { + mmc0 = &sdio0; + mmc1 = &sdmmc; + mmc2 = &sdhci; + }; + + chosen { + stdout-path = "serial2:115200n8"; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pwrbtn_pin>; + + key-power { + debounce-interval = <20>; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; + label = "Power"; + linux,code = <KEY_POWER>; + wakeup-source; + }; + }; + + vcc_sys: vcc-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + }; + + vcc3v3_sys: vcc3v3-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_sys>; + }; + + vcca1v8_s3: vcc1v8-s3-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcca1v8_s3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc3v3_sys>; + regulator-always-on; + regulator-boot-on; + }; + + vcc1v8_codec: vcc1v8-codec-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio3 RK_PA4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc1v8_codec_en>; + regulator-name = "vcc1v8_codec"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc3v3_sys>; + }; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk818: pmic@1c { + compatible = "rockchip,rk818"; + reg = <0x1c>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PC5 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc6-supply = <&vcc_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc_sys>; + vcc9-supply = <&vcc3v3_sys>; + + regulators { + vdd_cpu_l: DCDC_REG1 { + regulator-name = "vdd_cpu_l"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <875000>; + regulator-max-microvolt = <975000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_center: DCDC_REG2 { + regulator-name = "vdd_center"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1000000>; + regulator-ramp-delay = <6001>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcca3v0_codec: LDO_REG1 { + regulator-name = "vcca3v0_codec"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + }; + + vcc3v0_touch: LDO_REG2 { + regulator-name = "vcc3v0_touch"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + }; + + vcca1v8_codec: LDO_REG3 { + regulator-name = "vcca1v8_codec"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + rk818_pwr_on: LDO_REG4 { + regulator-name = "rk818_pwr_on"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_3v0: LDO_REG5 { + regulator-name = "vcc_3v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc1v8_dvp: LDO_REG7 { + regulator-name = "vcc1v8_dvp"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vcc3v3_s3: LDO_REG8 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG9 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + + vcc3v3_s0: SWITCH_REG { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + }; + }; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&vsel1_pin>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <875000>; + regulator-max-microvolt = <1150000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&vsel2_pin>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <875000>; + regulator-max-microvolt = <975000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&cluster0_opp { + opp04 { + status = "disabled"; + }; + + opp05 { + status = "disabled"; + }; +}; + +&cluster1_opp { + opp06 { + opp-hz = /bits/ 64 <1500000000>; + opp-microvolt = <1100000 1100000 1150000>; + }; + + opp07 { + status = "disabled"; + }; +}; + +&io_domains { + bt656-supply = <&vcc1v8_dvp>; + audio-supply = <&vcca1v8_codec>; + sdmmc-supply = <&vccio_sd>; + gpio1830-supply = <&vcc_3v0>; + status = "okay"; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc_1v8>; + status = "okay"; +}; + +&pinctrl { + buttons { + pwrbtn_pin: pwrbtn-pin { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + vsel1_pin: vsel1-pin { + rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + vsel2_pin: vsel2-pin { + rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + sound { + vcc1v8_codec_en: vcc1v8-codec-en { + rockchip,pins = <3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + vmmc-supply = <&vcc3v3_sys>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs200-1_8v; + non-removable; + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <1>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +};
Thanks, - Kever
- rk3399-pinephone-pro.dtb \ rk3399-puma-haikou.dtb \ rk3399-roc-pc.dtb \ rk3399-roc-pc-mezzanine.dtb \
- Copyright (c) 2020 Martijn Braam martijn@brixit.nl
- Copyright (c) 2021 Kamil TrzciĆski ayufan@ayufan.eu
- PinePhone Pro datasheet:
- model = "Pine64 PinePhonePro";
- compatible = "pine64,pinephone-pro", "rockchip,rk3399";
- chassis-type = "handset";
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen {
- gpio-keys {
key-power {
label = "Power";
wakeup-source;
- vcc_sys: vcc-sys-regulator {
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys-regulator {
regulator-boot-on;
- vcca1v8_s3: vcc1v8-s3-regulator {
regulator-boot-on;
- vcc1v8_codec: vcc1v8-codec-regulator {
enable-active-high;
+&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
+&cpu_b1 {
+&emmc_phy {
- status = "okay";
+&i2c0 {
- clock-frequency = <400000>;
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk818: pmic@1c {
reg = <0x1c>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG5 {
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- vdd_cpu_b: regulator@40 {
reg = <0x40>;
regulator-boot-on;
- vdd_gpu: regulator@41 {
reg = <0x41>;
regulator-boot-on;
+&cluster0_opp {
- opp04 {
- opp05 {
+&cluster1_opp {
- opp06 {
- opp07 {
+&io_domains {
- bt656-supply = <&vcc1v8_dvp>;
- audio-supply = <&vcca1v8_codec>;
- sdmmc-supply = <&vccio_sd>;
- gpio1830-supply = <&vcc_3v0>;
- status = "okay";
+&pmu_io_domains {
- pmu1830-supply = <&vcc_1v8>;
- status = "okay";
+&pinctrl {
- buttons {
- pmic {
- sound {
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- disable-wp;
- max-frequency = <150000000>;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>;
- vmmc-supply = <&vcc3v3_sys>;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
+&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
+&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <1>;
- status = "okay";
+&uart2 {
- status = "okay";
The Pinephone Pro is another device by PINE64. It's closely related to the Pinebook Pro of which this initial support is derived from.
Specification: - A variant of the Rockchip RK3399 - A 6 inch 720*1440 DSI display - Front and rear cameras - Type-C interface with alt mode display (DP 1.2) and PD charging - 4GB LPDDR4 RAM - 128GB eMMC - mSD card slot - An AP6255 module for 802.11ac WiFi and Bluetooth 5 - Quectel EG25-G 4G/LTE modem
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi | 39 +++++++ arch/arm/mach-rockchip/rk3399/Kconfig | 8 ++ board/pine64/pinephone-pro-rk3399/Kconfig | 15 +++ board/pine64/pinephone-pro-rk3399/MAINTAINERS | 8 ++ board/pine64/pinephone-pro-rk3399/Makefile | 1 + .../pinephone-pro-rk3399.c | 76 +++++++++++++ configs/pinephone-pro-rk3399_defconfig | 104 ++++++++++++++++++ include/configs/pinephone-pro-rk3399.h | 19 ++++ 8 files changed, 270 insertions(+) create mode 100644 arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi create mode 100644 board/pine64/pinephone-pro-rk3399/Kconfig create mode 100644 board/pine64/pinephone-pro-rk3399/MAINTAINERS create mode 100644 board/pine64/pinephone-pro-rk3399/Makefile create mode 100644 board/pine64/pinephone-pro-rk3399/pinephone-pro-rk3399.c create mode 100644 configs/pinephone-pro-rk3399_defconfig create mode 100644 include/configs/pinephone-pro-rk3399.h
diff --git a/arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi b/arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi new file mode 100644 index 00000000000..c9f1f4af635 --- /dev/null +++ b/arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Peter Robinson <pbrobinson at gmail.com> + */ + +#include "rk3399-u-boot.dtsi" +#include "rk3399-sdram-lpddr4-100.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdhci, &sdmmc; + }; + + config { + u-boot,spl-payload-offset = <0x60000>; /* @ 384KB */ + }; +}; + +&i2c0 { + u-boot,dm-pre-reloc; +}; + +&rk818 { + u-boot,dm-pre-reloc; +}; + +&rng { + status = "okay"; +}; + +&sdhci { + max-frequency = <25000000>; + u-boot,dm-pre-reloc; +}; + +&sdmmc { + max-frequency = <20000000>; + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index b48feeb3466..d01063ac98b 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -39,6 +39,13 @@ config TARGET_PINEBOOK_PRO_RK3399 with 4Gb RAM, onboard eMMC, USB-C, a USB3 and USB2 port, 1920*1080 screen and all the usual laptop features.
+config TARGET_PINEPHONE_PRO_RK3399 + bool "PinePhone Pro" + help + PinePhone Pro is a phone based on a variant of the Rockchip + rk3399 SoC with 4Gb RAM, onboard eMMC, USB-C, headphone jack, + 720x1440 screen and a Quectel 4G/LTE modem. + config TARGET_PUMA_RK3399 bool "Theobroma Systems RK3399-Q7 (Puma)" help @@ -165,6 +172,7 @@ endif # BOOTCOUNT_LIMIT source "board/firefly/roc-pc-rk3399/Kconfig" source "board/google/gru/Kconfig" source "board/pine64/pinebook-pro-rk3399/Kconfig" +source "board/pine64/pinephone-pro-rk3399/Kconfig" source "board/pine64/rockpro64_rk3399/Kconfig" source "board/rockchip/evb_rk3399/Kconfig" source "board/theobroma-systems/puma_rk3399/Kconfig" diff --git a/board/pine64/pinephone-pro-rk3399/Kconfig b/board/pine64/pinephone-pro-rk3399/Kconfig new file mode 100644 index 00000000000..13d6465ae6e --- /dev/null +++ b/board/pine64/pinephone-pro-rk3399/Kconfig @@ -0,0 +1,15 @@ +if TARGET_PINEPHONE_PRO_RK3399 + +config SYS_BOARD + default "pinephone-pro-rk3399" + +config SYS_VENDOR + default "pine64" + +config SYS_CONFIG_NAME + default "pinephone-pro-rk3399" + +config BOARD_SPECIFIC_OPTIONS + def_bool y + +endif diff --git a/board/pine64/pinephone-pro-rk3399/MAINTAINERS b/board/pine64/pinephone-pro-rk3399/MAINTAINERS new file mode 100644 index 00000000000..c923ff1be32 --- /dev/null +++ b/board/pine64/pinephone-pro-rk3399/MAINTAINERS @@ -0,0 +1,8 @@ +PINEPHONE_PRO +M: Peter Robinson pbrobinson@gmail.com +S: Maintained +F: board/pine64/rk3399-pinephone-pro/ +F: include/configs/rk3399-pinephone-pro.h +F: arch/arm/dts/rk3399-pinephone-pro.dts +F: arch/arm/dts/rk3399-pinephone-pro-u-boot.dtsi +F: configs/pinephone-pro-rk3399_defconfig diff --git a/board/pine64/pinephone-pro-rk3399/Makefile b/board/pine64/pinephone-pro-rk3399/Makefile new file mode 100644 index 00000000000..8d9203053e5 --- /dev/null +++ b/board/pine64/pinephone-pro-rk3399/Makefile @@ -0,0 +1 @@ +obj-y += pinephone-pro-rk3399.o diff --git a/board/pine64/pinephone-pro-rk3399/pinephone-pro-rk3399.c b/board/pine64/pinephone-pro-rk3399/pinephone-pro-rk3399.c new file mode 100644 index 00000000000..eb639cd0d07 --- /dev/null +++ b/board/pine64/pinephone-pro-rk3399/pinephone-pro-rk3399.c @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * (C) Copyright 2022 Peter Robinson <pbrobinson at gmail.com> + */ + +#include <common.h> +#include <dm.h> +#include <init.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/grf_rk3399.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/misc.h> +#include <power/regulator.h> + +#define GRF_IO_VSEL_BT565_SHIFT 0 +#define PMUGRF_CON0_VSEL_SHIFT 8 + +#ifndef CONFIG_SPL_BUILD +int board_early_init_f(void) +{ + struct udevice *regulator; + int ret; + + ret = regulator_get_by_platname("vcc5v0_usb", ®ulator); + if (ret) { + pr_debug("%s vcc5v0_usb init fail! ret %d\n", __func__, ret); + goto out; + } + + ret = regulator_set_enable(regulator, true); + if (ret) + pr_debug("%s vcc5v0-host-en-gpio set fail! ret %d\n", __func__, ret); + +out: + return 0; +} +#endif + +#ifdef CONFIG_MISC_INIT_R +static void setup_iodomain(void) +{ + struct rk3399_grf_regs *grf = + syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + struct rk3399_pmugrf_regs *pmugrf = + syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); + + /* BT565 is in 1.8v domain */ + rk_setreg(&grf->io_vsel, 1 << GRF_IO_VSEL_BT565_SHIFT); + + /* Set GPIO1 1.8v/3.0v source select to PMU1830_VOL */ + rk_setreg(&pmugrf->soc_con0, 1 << PMUGRF_CON0_VSEL_SHIFT); +} + +int misc_init_r(void) +{ + const u32 cpuid_offset = 0x7; + const u32 cpuid_length = 0x10; + u8 cpuid[cpuid_length]; + int ret; + + setup_iodomain(); + + ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid); + if (ret) + return ret; + + ret = rockchip_cpuid_set(cpuid, cpuid_length); + if (ret) + return ret; + + return ret; +} +#endif diff --git a/configs/pinephone-pro-rk3399_defconfig b/configs/pinephone-pro-rk3399_defconfig new file mode 100644 index 00000000000..0082d3aec39 --- /dev/null +++ b/configs/pinephone-pro-rk3399_defconfig @@ -0,0 +1,104 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-pinephone-pro" +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_PINEPHONE_PRO_RK3399=y +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0x800800 +CONFIG_DEBUG_UART=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 +CONFIG_BOOTDELAY=3 +CONFIG_USE_PREBOOT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-pinephone-pro.dtb" +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_MAX_SIZE=0x2e000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x400000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x400000 +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_SPL_SPI_LOAD=y +CONFIG_TPL=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_DM_KEYBOARD=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_ROCKCHIP_EFUSE=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y +CONFIG_DM_PMIC_FAN53555=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_DM_RESET=y +CONFIG_DM_RNG=y +CONFIG_RNG_ROCKCHIP=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=2 +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_KEYBOARD=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_EDP=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/pinephone-pro-rk3399.h b/include/configs/pinephone-pro-rk3399.h new file mode 100644 index 00000000000..78017d6bcc3 --- /dev/null +++ b/include/configs/pinephone-pro-rk3399.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Rockchip Electronics Co., Ltd + * Copyright (C) 2022 Peter Robinson <pbrobinson at gmail.com> + */ + +#ifndef __PINEPHONE_PRO_RK3399_H +#define __PINEPHONE_PRO_RK3399_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdin=serial,usbkbd\0" \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rk3399_common.h> + +#define SDRAM_BANK_SIZE (2UL << 30) + +#endif
Specification:
- 4GB LPDDR4 RAM
- 128GB eMMC
- mSD card slot
Thanks, - Kever
- Copyright (C) 2022 Peter Robinson <pbrobinson at gmail.com>
- chosen {
- config {
+&i2c0 {
+&rk818 {
+&rng {
- status = "okay";
+&sdhci {
- max-frequency = <25000000>;
+&sdmmc {
- max-frequency = <20000000>;
- bool "PinePhone Pro"
- help
- config TARGET_PUMA_RK3399 bool "Theobroma Systems RK3399-Q7 (Puma)" help
+config SYS_BOARD
- default "pinephone-pro-rk3399"
+config SYS_VENDOR
- default "pine64"
- def_bool y
- (C) Copyright 2016 Rockchip Electronics Co., Ltd
- (C) Copyright 2022 Peter Robinson <pbrobinson at gmail.com>
- struct udevice *regulator;
- int ret;
- ret = regulator_get_by_platname("vcc5v0_usb", ®ulator);
- if (ret) {
goto out;
- ret = regulator_set_enable(regulator, true);
- if (ret)
+out:
+} +#endif
- struct rk3399_grf_regs *grf =
- struct rk3399_pmugrf_regs *pmugrf =
- /* BT565 is in 1.8v domain */
- rk_setreg(&grf->io_vsel, 1 << GRF_IO_VSEL_BT565_SHIFT);
- /* Set GPIO1 1.8v/3.0v source select to PMU1830_VOL */
- rk_setreg(&pmugrf->soc_con0, 1 << PMUGRF_CON0_VSEL_SHIFT);
- const u32 cpuid_offset = 0x7;
- const u32 cpuid_length = 0x10;
- u8 cpuid[cpuid_length];
- int ret;
- setup_iodomain();
- ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid);
- if (ret)
return ret;
- ret = rockchip_cpuid_set(cpuid, cpuid_length);
- if (ret)
return ret;
- return ret;
- Copyright (C) 2016 Rockchip Electronics Co., Ltd
Jagan Teki
Kever Yang
Peter Robinson
Quentin Schulz
