[RFC] rockchip: Reset to bootrom download mode on hang
Add support to reset to bootrom download mode on hang in U-Boot SPL and proper. ROCKCHIP_HANG_TO_BROM can be used to enable this feature.
Example when SPL cannot load FIT:
U-Boot SPL 2024.04-rc1 (Feb 01 2024 - 23:01:12 +0000) Trying to boot from MMC1 mmc_load_image_raw_sector: mmc block read error Trying to boot from MMC2 Card did not respond to voltage select! : -110 spl: mmc init failed with error: -95 Trying to boot from MMC1 mmc_load_image_raw_sector: mmc block read error SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### entering download mode ... resetting ...
Procedure to start bootrom download mode: - U-Boot SPL or proper write 0xEF08A53C to BOOT_MODE_REG and then reset - Bootrom loads and run boot code (TPL) from e.g. SPI > eMMC > SD-card - TPL check for 0xEF08A53C in BOOT_MODE_REG very early, i.e. Rockchip TPL blobs check for this value directly at start - TPL return to bootrom with a return value != 0 - Bootrom enter download mode
This also fixes an issue where the BOOT_MODE_REG is reset to 0 when board is reset on RK35xx after TF-A has been loaded. To fix this the SOC_CON1 reg value is reset prior to issuing a global reset.
The RK356x TF-A blobs will clear SOC_CON1 as part of a PSCI reset, however the RK3588 TF-A blobs does not seem to clear SOC_CON1.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- - Is reset to bootrom download mode on hang a feature of intereset to anyone else? - How can we best handle the issue with BOOT_MODE_REG being reset? - Should we instead enable SYSRESET_PSCI and relay on TF-A to properly reset without loosing value in BOOT_MODE_REG? Currently works on RK356x bl31 blobs but not on the RK3588 bl31 blobs. --- arch/arm/mach-rockchip/Kconfig | 9 +++++++ arch/arm/mach-rockchip/Makefile | 9 ++++--- arch/arm/mach-rockchip/boot_mode.c | 38 ++++++++++++++++++++++++++---- configs/generic-rk3568_defconfig | 1 + configs/generic-rk3588_defconfig | 1 + 5 files changed, 48 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 6ff0aa6911e2..66556d30af27 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -508,6 +508,15 @@ config TPL_ROCKCHIP_EARLYRETURN_TO_BROM This enables support code in the BOOT0 hook for the TPL stage to allow multiple entries.
+config ROCKCHIP_HANG_TO_BROM + bool "Reset to bootrom download mode on hang" + select SHOW_BOOT_PROGRESS + +config SPL_ROCKCHIP_HANG_TO_BROM + bool "Reset to bootrom download mode on hang in SPL" + default y if ROCKCHIP_HANG_TO_BROM + select SPL_SHOW_BOOT_PROGRESS + config SPL_MMC default y if !SPL_ROCKCHIP_BACK_TO_BROM
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 1dc92066bbf3..ab4446bb6b51 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -16,17 +16,16 @@ obj-tpl-$(CONFIG_ROCKCHIP_PX30) += px30-board-tpl.o obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o
ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) +obj-$(CONFIG_ROCKCHIP_COMMON_BOARD) += board.o +obj-$(CONFIG_MISC_INIT_R) += misc.o +endif
+ifeq ($(CONFIG_TPL_BUILD),) # Always include boot_mode.o, as we bypass it (i.e. turn it off) # inside of boot_mode.c when CONFIG_ROCKCHIP_BOOT_MODE_REG is 0. This way, # we can have the preprocessor correctly recognise both 0x0 and 0 # meaning "turn it off". obj-y += boot_mode.o -obj-$(CONFIG_ROCKCHIP_COMMON_BOARD) += board.o -obj-$(CONFIG_MISC_INIT_R) += misc.o -endif - -ifeq ($(CONFIG_TPL_BUILD),) obj-$(CONFIG_DISPLAY_CPUINFO) += cpu-info.o endif
diff --git a/arch/arm/mach-rockchip/boot_mode.c b/arch/arm/mach-rockchip/boot_mode.c index eb8f65ae4e9d..de9ec1414926 100644 --- a/arch/arm/mach-rockchip/boot_mode.c +++ b/arch/arm/mach-rockchip/boot_mode.c @@ -5,6 +5,7 @@
#include <common.h> #include <adc.h> +#include <bootstage.h> #include <command.h> #include <env.h> #include <log.h> @@ -23,11 +24,31 @@ int setup_boot_mode(void)
#else
-void set_back_to_bootrom_dnl_flag(void) +static void set_back_to_bootrom_dnl_flag(void) { + /* + * These SOC_CON1 regs needs to be cleared before a reset or the + * BOOT_MODE_REG do not retain its value and it is not possible + * to reset to bootrom download mode once TF-A has been started. + * + * TF-A blobs for RK3568 already clear SOC_CON1 for PSCI reset. + * However, the TF-A blobs for RK3588 does not clear SOC_CON1. + */ + if (IS_ENABLED(CONFIG_ROCKCHIP_RK3568)) + writel(0x40000, 0xFDC20104); + if (IS_ENABLED(CONFIG_ROCKCHIP_RK3588)) + writel(0xFFFF0000, 0xFD58A004); + writel(BOOT_BROM_DOWNLOAD, CONFIG_ROCKCHIP_BOOT_MODE_REG); }
+static void rockchip_reset_to_dnl_mode(void) +{ + puts("entering download mode ...\n"); + set_back_to_bootrom_dnl_flag(); + do_reset(NULL, 0, 0, NULL); +} + /* * detect download key status by adc, most rockchip * based boards use adc sample the download key status, @@ -71,12 +92,19 @@ __weak int rockchip_dnl_key_pressed(void) return false; }
-void rockchip_dnl_mode_check(void) +#if CONFIG_IS_ENABLED(ROCKCHIP_HANG_TO_BROM) +void show_boot_progress(int val) +{ + if (val == -BOOTSTAGE_ID_NEED_RESET) + rockchip_reset_to_dnl_mode(); +} +#endif + +static void rockchip_dnl_mode_check(void) { if (rockchip_dnl_key_pressed()) { - printf("download key pressed, entering download mode..."); - set_back_to_bootrom_dnl_flag(); - do_reset(NULL, 0, 0, NULL); + puts("download key pressed, "); + rockchip_reset_to_dnl_mode(); } }
diff --git a/configs/generic-rk3568_defconfig b/configs/generic-rk3568_defconfig index b90ecb643dc7..9edd4c33000e 100644 --- a/configs/generic-rk3568_defconfig +++ b/configs/generic-rk3568_defconfig @@ -11,6 +11,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3568-generic" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_ROCKCHIP_HANG_TO_BROM=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_SPL_STACK=0x400000 diff --git a/configs/generic-rk3588_defconfig b/configs/generic-rk3588_defconfig index a9329eb1c625..5872bd4802c5 100644 --- a/configs/generic-rk3588_defconfig +++ b/configs/generic-rk3588_defconfig @@ -11,6 +11,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 CONFIG_DEFAULT_DEVICE_TREE="rk3588-generic" CONFIG_ROCKCHIP_RK3588=y CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_ROCKCHIP_HANG_TO_BROM=y CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_TARGET_EVB_RK3588=y
Hello Jonas,
I find this usable, for example during development. Thus, I'd support this feature to be polished further and eventually merged.
- bool "Reset to bootrom download mode on hang"
- select SHOW_BOOT_PROGRESS
- bool "Reset to bootrom download mode on hang in SPL"
- default y if ROCKCHIP_HANG_TO_BROM
- select SPL_SHOW_BOOT_PROGRESS
#else
- if (IS_ENABLED(CONFIG_ROCKCHIP_RK3568))
- if (IS_ENABLED(CONFIG_ROCKCHIP_RK3588))
- writel(BOOT_BROM_DOWNLOAD, CONFIG_ROCKCHIP_BOOT_MODE_REG);
- puts("entering download mode ...\n");
- detect download key status by adc, most rockchip
- based boards use adc sample the download key status,
- if (val == -BOOTSTAGE_ID_NEED_RESET)
+} +#endif
}rockchip_reset_to_dnl_mode();
Hi Jonas,
I'm wondering if there isn't a simpler way to do this?
board_boot_order() could parse u-boot,spl-boot-order for e.g. "bootrom", the same way it does for "same-as-spl" for example.
If it is set, then add BOOT_DEVICE_BOOTROM to spl_boot_list.
Then this would call spl_return_to_bootrom() from common/spl/spl_bootrom.c which in turns would call board_return_to_bootrom() and back_to_bootrom().
What do you think?
Cheers, Quentin
Hi Quentin,
On 2024-02-05 11:49, Quentin Schulz wrote:
Hi Jonas,
What do you think?
Something like that is what I did in my initial implementation :-)
I appended a BOOT_DEVICE_BOOTROM at the end of board_boot_order() and implemented necessary parts in spl_return_to_bootrom(), and that worked great for SPL.
However, to catch a hang() in U-Boot proper, e.g. a failed initcall, the only existing integration callback for hang() is to override show_boot_progress().
Because the use of show_boot_progress() worked for both SPL and U-Boot proper (probably also TPL) it seemed better to only have one integration part for all phases.
I am still not sure exactly when we would want to fall back into bootrom download mode. Always at a hang() or at controlled parts e.g. when no FIT can be loaded.
I am open for any suggestions.
Regards, Jonas
Cheers, Quentin
Hello Jonas,
On 2/5/24 14:34, Jonas Karlman wrote:
Hi Quentin,
Hi Jonas,
Recently I tested BL31 with TF-A, it works, and you can send a patch to fix bugs in there if you find them ! Its open source, I gathered the patches and tested them here:
https://gitlab.collabora.com/hardware-enablement/rockchip-3588/trusted-firmw...
What do you think?
I implemented DFU in SPL at some point last year (due to DWC3 being unaligned with Linux the patches weren't accepted), and defaulting to DFU is also an option when nothing boots.
( https://patchwork.ozlabs.org/project/uboot/cover/20230801072811.10354-1-euge... )
Eugen
Regards, Jonas
Cheers, Quentin
Hi Jonas,
On 2024/2/5 20:34, Jonas Karlman wrote:
Hi Quentin,
Hi Jonas,
What do you think?
There are two case need to consider when hang() happen: - For release version: a reboot and get into reset into bootrom download mode if boot fail more than 3 times; - For debug version: a dump stack with hang() will be better(which is used in rockchip vendor u-boot); Reboot to bootrom download when hang() happen is handy for U-Boot error happen, no need to press the reset and recovery/download key in this case. The final logic would be: fall back to usb boot(bootrom) whenever we fail to boot in to next stage, so that we have chance to update an available firmware.
Thanks, - Kever
Regards, Jonas
Cheers, Quentin
reset
SD-card
What do you think?
Just as a note, falling back to BROM may actually introduce some security issues in some setups, by allowing rather low-level access to the system that may not be desired.
Perhaps not enabling the fallback to BROM by default and leaving it to the board configurations would be the desired way to move forward.
participants (5)
Dragan Simic
Eugen Hristev
Jonas Karlman
Kever Yang
Quentin Schulz
