[PATCH v3 1/1] drivers: usb: host: Add BRCM xHCI driver
Base driver for Broadcom xHCI controllers
Signed-off-by: Bharat Kumar Reddy Gooty bharat.gooty@broadcom.com Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com Signed-off-by: Vladimir Olovyannikov vladimir.olovyannikov@broadcom.com --- Changes from v2: -Address review comments from Marek Vasut, Cache hc_base in private data instead of always reading it from DT, Follow reverse xmas tree for variable declaration.
Changes from v1: -Address review comments from Marek Vasut, Use comman macro name for read and write register, Rename the macro names.
drivers/usb/host/Kconfig | 8 +++ drivers/usb/host/Makefile | 1 + drivers/usb/host/xhci-brcm.c | 98 ++++++++++++++++++++++++++++++++++++ 3 files changed, 107 insertions(+) create mode 100644 drivers/usb/host/xhci-brcm.c
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 0987ff25b1..94ac969058 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -88,6 +88,14 @@ config USB_XHCI_FSL depends on !SPL_NO_USB help Enables support for the on-chip xHCI controller on NXP Layerscape SoCs. + +config USB_XHCI_BRCM + bool "Broadcom USB3 Host XHCI controller" + depends on DM_USB + help + USB controller based on the Broadcom USB3 IP Core. + Supports USB2/3 functionality. + endif # USB_XHCI_HCD
config USB_EHCI_HCD diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 7feeff679c..b62f346094 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -44,6 +44,7 @@ obj-$(CONFIG_USB_EHCI_RMOBILE) += ehci-rmobile.o obj-$(CONFIG_USB_EHCI_ZYNQ) += ehci-zynq.o
# xhci +obj-$(CONFIG_USB_XHCI_BRCM) += xhci-brcm.o obj-$(CONFIG_USB_XHCI_HCD) += xhci.o xhci-mem.o xhci-ring.o obj-$(CONFIG_USB_XHCI_DWC3) += xhci-dwc3.o obj-$(CONFIG_USB_XHCI_DWC3_OF_SIMPLE) += dwc3-of-simple.o diff --git a/drivers/usb/host/xhci-brcm.c b/drivers/usb/host/xhci-brcm.c new file mode 100644 index 0000000000..7192305dba --- /dev/null +++ b/drivers/usb/host/xhci-brcm.c @@ -0,0 +1,98 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Broadcom. + */ + +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <usb.h> +#include <asm/io.h> +#include <usb/xhci.h> + +#define DRD2U3H_XHC_REGS_AXIWRA 0xC08 +#define DRD2U3H_XHC_REGS_AXIRDA 0xC0C + +#define USBAXI_CACHE 0xF +#define USBAXI_PROT 0x8 +#define USBAXI_SA_MASK 0x1FF +#define USBAXI_UA_MASK (0x1FF << 16) +#define USBAXI_SA_VAL ((USBAXI_CACHE << 4) | USBAXI_PROT) +#define USBAXI_UA_VAL (USBAXI_SA_VAL << 16) +#define USBAXI_SA_UA_MASK (USBAXI_UA_MASK | USBAXI_SA_MASK) +#define USBAXI_SA_UA_VAL (USBAXI_UA_VAL | USBAXI_SA_VAL) + +struct brcm_xhci_platdata { + unsigned int arcache; + unsigned int awcache; + uintptr_t hc_base; +}; + +static int xhci_brcm_probe(struct udevice *dev) +{ + struct brcm_xhci_platdata *plat = dev_get_platdata(dev); + struct xhci_hcor *hcor; + struct xhci_hccr *hcd; + int len, ret = 0; + + if (!plat) { + dev_err(dev, "Can't get xHCI Plat data\n"); + return -ENOMEM; + } + + hcd = dev_read_addr_ptr(dev); + if (!hcd) { + dev_err(dev, "Can't get the xHCI register base address\n"); + return -ENXIO; + } + + plat->hc_base = (uintptr_t)hcd; + len = HC_LENGTH(xhci_readl(&hcd->cr_capbase)); + hcor = (struct xhci_hcor *)(plat->hc_base + len); + + /* Save the default values of AXI read and write attributes */ + plat->awcache = readl(plat->hc_base + DRD2U3H_XHC_REGS_AXIWRA); + plat->arcache = readl(plat->hc_base + DRD2U3H_XHC_REGS_AXIRDA); + + /* Enable AXI write attributes */ + clrsetbits_le32(plat->hc_base + DRD2U3H_XHC_REGS_AXIWRA, + USBAXI_SA_UA_MASK, USBAXI_SA_UA_VAL); + + /* Enable AXI read attributes */ + clrsetbits_le32(plat->hc_base + DRD2U3H_XHC_REGS_AXIRDA, + USBAXI_SA_UA_MASK, USBAXI_SA_UA_VAL); + + ret = xhci_register(dev, hcd, hcor); + if (ret) + dev_err(dev, "Failed to register xHCI\n"); + + return ret; +} + +static int xhci_brcm_deregister(struct udevice *dev) +{ + struct brcm_xhci_platdata *plat = dev_get_platdata(dev); + + /* Restore the default values for AXI read and write attributes */ + writel(plat->awcache, plat->hc_base + DRD2U3H_XHC_REGS_AXIWRA); + writel(plat->arcache, plat->hc_base + DRD2U3H_XHC_REGS_AXIRDA); + + return xhci_deregister(dev); +} + +static const struct udevice_id xhci_brcm_ids[] = { + { .compatible = "brcm,generic-xhci" }, + { } +}; + +U_BOOT_DRIVER(usb_xhci) = { + .name = "xhci_brcm", + .id = UCLASS_USB, + .probe = xhci_brcm_probe, + .remove = xhci_brcm_deregister, + .ops = &xhci_usb_ops, + .of_match = xhci_brcm_ids, + .platdata_auto_alloc_size = sizeof(struct brcm_xhci_platdata), + .priv_auto_alloc_size = sizeof(struct xhci_ctrl), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
On 4/8/20 5:35 AM, Rayagonda Kokatanur wrote: [...]
- unsigned int arcache;
- unsigned int awcache;
- uintptr_t hc_base;
This could be struct xhci_hccr * instead , and then you can remove the cast ...
- struct brcm_xhci_platdata *plat = dev_get_platdata(dev);
- struct xhci_hcor *hcor;
- struct xhci_hccr *hcd;
- int len, ret = 0;
- if (!plat) {
return -ENOMEM;
- hcd = dev_read_addr_ptr(dev);
- if (!hcd) {
return -ENXIO;
- plat->hc_base = (uintptr_t)hcd;
... here.
- len = HC_LENGTH(xhci_readl(&hcd->cr_capbase));
- hcor = (struct xhci_hcor *)(plat->hc_base + len);
uintptr_t hc_base;
If we make it struct xhci_hccr * then I think we need to type cast in readl and writel function. Please let me know ?
int len, ret = 0;
if (!plat) {
return -ENOMEM;
if (!hcd) {
return -ENXIO;
... here.
On Wed, Apr 8, 2020 at 11:18 AM Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com wrote:
uintptr_t hc_base;
Hi Marek,
uintptr_t is "unsigned long int" , its not pointer. If we make hc_base as a pointer "struct xhci_hccr *" it won't work because of pointer arithmetic during readl and writel. Please let me know if I am missing anything ?
int len, ret = 0;
if (!plat) {
return -ENOMEM;
if (!hcd) {
return -ENXIO;
... here.
uintptr_t hc_base;
Ah yes, that's right, then I think you want void __iomem * ?
uintptr_t hc_base;
Done, declared as void __iomem * , thank you.
Rayagonda Kokatanur
