[U-Boot] [PATCH] bmips: configs: switch to size definitions
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com --- include/configs/bmips_bcm3380.h | 6 ++++-- include/configs/bmips_bcm6318.h | 6 ++++-- include/configs/bmips_bcm63268.h | 6 ++++-- include/configs/bmips_bcm6328.h | 6 ++++-- include/configs/bmips_bcm6338.h | 6 ++++-- include/configs/bmips_bcm6348.h | 6 ++++-- include/configs/bmips_bcm6358.h | 6 ++++-- include/configs/bmips_bcm6362.h | 8 +++++--- include/configs/bmips_bcm6368.h | 6 ++++-- include/configs/bmips_bcm6838.h | 6 ++++-- include/configs/bmips_common.h | 11 ++++++++--- include/configs/broadcom_bcm968380gerg.h | 2 +- include/configs/comtrend_ar5315u.h | 3 +-- include/configs/comtrend_ar5387un.h | 3 +-- include/configs/comtrend_ct5361.h | 3 +-- include/configs/comtrend_vr3032u.h | 3 +-- include/configs/comtrend_wap5813n.h | 3 +-- include/configs/huawei_hg556a.h | 3 +-- include/configs/netgear_cg3100d.h | 3 +-- include/configs/netgear_dgnd3700v2.h | 5 ++--- include/configs/sagem_f@st1704.h | 3 +-- include/configs/sfr_nb4_ser.h | 3 +-- 22 files changed, 61 insertions(+), 46 deletions(-)
diff --git a/include/configs/bmips_bcm3380.h b/include/configs/bmips_bcm3380.h index e2f9e76a97..573ff3e401 100644 --- a/include/configs/bmips_bcm3380.h +++ b/include/configs/bmips_bcm3380.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_BCM3380_H #define __CONFIG_BMIPS_BCM3380_H
+#include <linux/sizes.h> + /* CPU */ #define CONFIG_SYS_MIPS_TIMER_FREQ 166500000
@@ -13,11 +15,11 @@ #define CONFIG_SYS_SDRAM_BASE 0x80000000
/* U-Boot */ -#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + SZ_1M
#if defined(CONFIG_BMIPS_BOOT_RAM) #define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_SYS_INIT_SP_OFFSET 0x2000 +#define CONFIG_SYS_INIT_SP_OFFSET SZ_8K #endif
#endif /* __CONFIG_BMIPS_BCM3380_H */ diff --git a/include/configs/bmips_bcm6318.h b/include/configs/bmips_bcm6318.h index 476aa51af3..c7e7119aaf 100644 --- a/include/configs/bmips_bcm6318.h +++ b/include/configs/bmips_bcm6318.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_BCM6318_H #define __CONFIG_BMIPS_BCM6318_H
@@ -20,11 +22,11 @@ #define CONFIG_USB_OHCI_NEW
#endif /* __CONFIG_BMIPS_BCM6318_H */ diff --git a/include/configs/bmips_bcm63268.h b/include/configs/bmips_bcm63268.h index 1456b0ec47..45f26bb309 100644 --- a/include/configs/bmips_bcm63268.h +++ b/include/configs/bmips_bcm63268.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_BCM63268_H #define __CONFIG_BMIPS_BCM63268_H
+#include <linux/sizes.h> + /* CPU */ #define CONFIG_SYS_MIPS_TIMER_FREQ 200000000
#endif /* __CONFIG_BMIPS_BCM63268_H */ diff --git a/include/configs/bmips_bcm6328.h b/include/configs/bmips_bcm6328.h index faf9abcc3e..8d59438785 100644 --- a/include/configs/bmips_bcm6328.h +++ b/include/configs/bmips_bcm6328.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_BCM6328_H #define __CONFIG_BMIPS_BCM6328_H
+#include <linux/sizes.h> + /* CPU */ #define CONFIG_SYS_MIPS_TIMER_FREQ 160000000
#endif /* __CONFIG_BMIPS_BCM6328_H */ diff --git a/include/configs/bmips_bcm6338.h b/include/configs/bmips_bcm6338.h index 83050c94a6..38dd9e3af3 100644 --- a/include/configs/bmips_bcm6338.h +++ b/include/configs/bmips_bcm6338.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_BCM6338_H #define __CONFIG_BMIPS_BCM6338_H
+#include <linux/sizes.h> + /* CPU */ #define CONFIG_SYS_MIPS_TIMER_FREQ 120000000
#define CONFIG_SYS_FLASH_BASE 0xbfc00000 diff --git a/include/configs/bmips_bcm6348.h b/include/configs/bmips_bcm6348.h index 5eb8b0f9d0..061d6b25b7 100644 --- a/include/configs/bmips_bcm6348.h +++ b/include/configs/bmips_bcm6348.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_BCM6348_H #define __CONFIG_BMIPS_BCM6348_H
+#include <linux/sizes.h> + /* CPU */ #define CONFIG_SYS_MIPS_TIMER_FREQ 128000000
@@ -18,11 +20,11 @@ #define CONFIG_USB_OHCI_NEW
#define CONFIG_SYS_FLASH_BASE 0xbfc00000 diff --git a/include/configs/bmips_bcm6358.h b/include/configs/bmips_bcm6358.h index 7becf3fcb9..583217d262 100644 --- a/include/configs/bmips_bcm6358.h +++ b/include/configs/bmips_bcm6358.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_BCM6358_H #define __CONFIG_BMIPS_BCM6358_H
+#include <linux/sizes.h> + /* CPU */ #define CONFIG_SYS_MIPS_TIMER_FREQ 150000000
#define CONFIG_SYS_FLASH_BASE 0xbe000000 diff --git a/include/configs/bmips_bcm6362.h b/include/configs/bmips_bcm6362.h index 60777207e1..570bc3b33d 100644 --- a/include/configs/bmips_bcm6362.h +++ b/include/configs/bmips_bcm6362.h @@ -1,11 +1,13 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright (C) 2018 Ãlvaro Fernández Rojas noltari@gmail.com + * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com */
#ifndef __CONFIG_BMIPS_BCM6362_H #define __CONFIG_BMIPS_BCM6362_H
#endif /* __CONFIG_BMIPS_BCM6362_H */ diff --git a/include/configs/bmips_bcm6368.h b/include/configs/bmips_bcm6368.h index 1a57476e05..ab5bdac726 100644 --- a/include/configs/bmips_bcm6368.h +++ b/include/configs/bmips_bcm6368.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_BCM6368_H #define __CONFIG_BMIPS_BCM6368_H
#define CONFIG_SYS_FLASH_BASE 0xb8000000 diff --git a/include/configs/bmips_bcm6838.h b/include/configs/bmips_bcm6838.h index d735c51efc..f1ff05414d 100644 --- a/include/configs/bmips_bcm6838.h +++ b/include/configs/bmips_bcm6838.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_BCM6838_H #define __CONFIG_BMIPS_BCM6838_H
#endif /* __CONFIG_BMIPS_BCM6838_H */ diff --git a/include/configs/bmips_common.h b/include/configs/bmips_common.h index e86393a34b..3cb2d4050d 100644 --- a/include/configs/bmips_common.h +++ b/include/configs/bmips_common.h @@ -6,6 +6,8 @@ #ifndef __CONFIG_BMIPS_COMMON_H #define __CONFIG_BMIPS_COMMON_H
+#include <linux/sizes.h> + /* ETH */ #define CONFIG_PHY_RESET_DELAY 20 #define CONFIG_SYS_RX_ETH_BUFFER 6 @@ -16,8 +18,11 @@
/* Memory usage */ #define CONFIG_SYS_MAXARGS 24 -#define CONFIG_SYS_MALLOC_LEN (2 * 1024 * 1024) -#define CONFIG_SYS_BOOTPARAMS_LEN (128 * 1024) -#define CONFIG_SYS_CBSIZE 512 +#define CONFIG_SYS_MALLOC_LEN SZ_2M +#define CONFIG_SYS_BOOTPARAMS_LEN SZ_128K +#define CONFIG_SYS_CBSIZE SZ_512 + +/* U-Boot */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
#endif /* __CONFIG_BMIPS_COMMON_H */ diff --git a/include/configs/broadcom_bcm968380gerg.h b/include/configs/broadcom_bcm968380gerg.h index aa6ce67d53..b0e93376fe 100644 --- a/include/configs/broadcom_bcm968380gerg.h +++ b/include/configs/broadcom_bcm968380gerg.h @@ -6,7 +6,7 @@ #include <configs/bmips_common.h> #include <configs/bmips_bcm6838.h>
-#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_SIZE SZ_8K
#ifdef CONFIG_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/comtrend_ar5315u.h b/include/configs/comtrend_ar5315u.h index a5eb3aea19..1da96c163a 100644 --- a/include/configs/comtrend_ar5315u.h +++ b/include/configs/comtrend_ar5315u.h @@ -8,5 +8,4 @@
#define CONFIG_REMAKE_ELF
-#define CONFIG_ENV_SIZE (8 * 1024) - +#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/comtrend_ar5387un.h b/include/configs/comtrend_ar5387un.h index 71c5ba45be..73e6a5dac7 100644 --- a/include/configs/comtrend_ar5387un.h +++ b/include/configs/comtrend_ar5387un.h @@ -8,5 +8,4 @@
-#define CONFIG_ENV_SIZE (8 * 1024) - +#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/comtrend_ct5361.h b/include/configs/comtrend_ct5361.h index da70592306..72f9ecbb06 100644 --- a/include/configs/comtrend_ct5361.h +++ b/include/configs/comtrend_ct5361.h @@ -8,5 +8,4 @@
-#define CONFIG_ENV_SIZE (8 * 1024) - +#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/comtrend_vr3032u.h b/include/configs/comtrend_vr3032u.h index e183288c5d..a73483d30b 100644 --- a/include/configs/comtrend_vr3032u.h +++ b/include/configs/comtrend_vr3032u.h @@ -8,5 +8,4 @@
-#define CONFIG_ENV_SIZE (8 * 1024) - +#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/comtrend_wap5813n.h b/include/configs/comtrend_wap5813n.h index 7070a1c757..b67f6548e6 100644 --- a/include/configs/comtrend_wap5813n.h +++ b/include/configs/comtrend_wap5813n.h @@ -8,5 +8,4 @@
-#define CONFIG_ENV_SIZE (8 * 1024) - +#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/huawei_hg556a.h b/include/configs/huawei_hg556a.h index 1c9bee6d58..2aa5c66643 100644 --- a/include/configs/huawei_hg556a.h +++ b/include/configs/huawei_hg556a.h @@ -8,5 +8,4 @@
-#define CONFIG_ENV_SIZE (8 * 1024) - +#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/netgear_cg3100d.h b/include/configs/netgear_cg3100d.h index d541e9cee8..e5a9601519 100644 --- a/include/configs/netgear_cg3100d.h +++ b/include/configs/netgear_cg3100d.h @@ -6,5 +6,4 @@ #include <configs/bmips_common.h> #include <configs/bmips_bcm3380.h>
-#define CONFIG_ENV_SIZE (8 * 1024) - +#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/netgear_dgnd3700v2.h b/include/configs/netgear_dgnd3700v2.h index 9edaec9bff..3baa17ae61 100644 --- a/include/configs/netgear_dgnd3700v2.h +++ b/include/configs/netgear_dgnd3700v2.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright (C) 2018 Ãlvaro Fernández Rojas noltari@gmail.com + * Copyright (C) 2018 Álvaro Fernández Rojas noltari@gmail.com */
#include <configs/bmips_common.h> @@ -8,5 +8,4 @@
-#define CONFIG_ENV_SIZE (8 * 1024) - +#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/sagem_f@st1704.h b/include/configs/sagem_f@st1704.h index 7171dc6760..5a526d9d8b 100644 --- a/include/configs/sagem_f@st1704.h +++ b/include/configs/sagem_f@st1704.h @@ -6,5 +6,4 @@ #include <configs/bmips_common.h> #include <configs/bmips_bcm6338.h>
-#define CONFIG_ENV_SIZE (8 * 1024) - +#define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/sfr_nb4_ser.h b/include/configs/sfr_nb4_ser.h index 1c9bee6d58..2aa5c66643 100644 --- a/include/configs/sfr_nb4_ser.h +++ b/include/configs/sfr_nb4_ser.h @@ -8,5 +8,4 @@
Am 30.08.19 um 11:54 schrieb Álvaro Fernández Rojas:
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
applied to u-boot-mips, thanks.
Daniel Schwierzeck
