[U-Boot-Users] [PATCH 1/2] libfdt: Add some utilities to manipulate the reserved memory map.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- include/libfdt.h | 5 +++ libfdt/fdt_ro.c | 72 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ libfdt/fdt_wip.c | 26 +++++++++++++++++++ 3 files changed, 103 insertions(+), 0 deletions(-)
diff --git a/include/libfdt.h b/include/libfdt.h index 61f56ec..f8bac73 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -86,6 +86,8 @@ void *fdt_getprop(const void *fdt, int nodeoffset,
uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset, char **namep); +int fdt_num_reservemap(void *fdt, int *used, int *total); +int fdt_get_reservemap(void *fdt, int n, struct fdt_reserve_entry *re);
/* Write-in-place functions */ int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name, @@ -99,6 +101,8 @@ int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name,
int fdt_nop_property(void *fdt, int nodeoffset, const char *name); int fdt_nop_node(void *fdt, int nodeoffset); +int fdt_insert_reservemap_entry(void *fdt, int n, uint64_t addr, uint64_t size); +
/* Sequential-write functions */ int fdt_create(void *buf, int bufsize); @@ -115,6 +119,7 @@ int fdt_property(void *fdt, const char *name, const void *val, int len); fdt_property(fdt, name, str, strlen(str)+1) int fdt_end_node(void *fdt); int fdt_finish(void *fdt); +int fdt_replace_reservemap_entry(void *fdt, int n, uint64_t addr, uint64_t size);
/* Read-write functions */ int fdt_open_into(void *fdt, void *buf, int bufsize); diff --git a/libfdt/fdt_ro.c b/libfdt/fdt_ro.c index 2711324..af33336 100644 --- a/libfdt/fdt_ro.c +++ b/libfdt/fdt_ro.c @@ -329,3 +329,75 @@ uint32_t fdt_next_tag(const void *fdt, int offset, int *nextoffset, char **namep
return tag; } + +/* + * Return the number of used reserve map entries and total slots available. + */ +int fdt_num_reservemap(void *fdt, int *used, int *total) +{ + struct fdt_reserve_entry *re; + int start; + int end; + int err = fdt_check_header(fdt); + + if (err != 0) + return err; + + start = fdt_off_mem_rsvmap(fdt); + + /* + * Convention is that the reserve map is before the dt_struct, + * but it does not have to be. + */ + end = fdt_totalsize(fdt); + if (end > fdt_off_dt_struct(fdt)) + end = fdt_off_dt_struct(fdt); + if (end > fdt_off_dt_strings(fdt)) + end = fdt_off_dt_strings(fdt); + + /* + * Since the reserved area list is zero terminated, you get one fewer. + */ + if (total) + *total = ((end - start) / sizeof(struct fdt_reserve_entry)) - 1; + + if (used) { + *used = 0; + while (start < end) { + re = (struct fdt_reserve_entry *)(fdt + start); + if (re->size == 0) + return 0; /* zero size terminates the list */ + + *used += 1; + start += sizeof(struct fdt_reserve_entry); + } + /* + * If we get here, there was no zero size termination. + */ + return -FDT_ERR_BADLAYOUT; + } + return 0; +} + +/* + * Return the nth reserve map entry. + */ +int fdt_get_reservemap(void *fdt, int n, struct fdt_reserve_entry *re) +{ + int used; + int total; + int err; + + err = fdt_num_reservemap(fdt, &used, &total); + if (err != 0) + return err; + + if (n >= total) + return -FDT_ERR_NOSPACE; + if (re) { + *re = *(struct fdt_reserve_entry *) + _fdt_offset_ptr(fdt, n * sizeof(struct fdt_reserve_entry)); + } + return 0; +} + diff --git a/libfdt/fdt_wip.c b/libfdt/fdt_wip.c index 261b9b0..cf81183 100644 --- a/libfdt/fdt_wip.c +++ b/libfdt/fdt_wip.c @@ -110,3 +110,29 @@ int fdt_nop_node(void *fdt, int nodeoffset) nop_region(fdt_offset_ptr(fdt, nodeoffset, 0), endoffset - nodeoffset); return 0; } + +/* + * Replace a reserve map entry in the nth slot. + */ +int fdt_replace_reservemap_entry(void *fdt, int n, uint64_t addr, uint64_t size) +{ + struct fdt_reserve_entry *re; + int used; + int total; + int err; + + err = fdt_num_reservemap(fdt, &used, &total); + if (err != 0) + return err; + + if (n >= total) + return -FDT_ERR_NOSPACE; + re = (struct fdt_reserve_entry *) + (fdt + fdt_off_mem_rsvmap(fdt) + + (n * sizeof(struct fdt_reserve_entry))); + re->address = cpu_to_fdt64(addr); + re->size = cpu_to_fdt64(size); + + return 0; +} +
Hello All,
I've published two more patches for fdt handling and pushed them to the u-boot-fdt repository. This now handles ramdisks well, including modifying the reserved map entries in the blob (required some new libfdt routines).
I have not tried a multi-image (blob embedded), but have the same handling code as passing in the blob as the 2nd parameter so it should work OK. If someone could test this or send me a RTFM pointer on how to create a multi-image, I would appreciate it.
The only remaining issue is my poorly executed changes for setting the MAC addresses.
Wolfgang: This should be good to pull, but it wouldn't hurt to wait for a little for code review. Also, I'll try to get the mac address fix in in the next day or two.
Best regards, gvb
Jerry Van Baren
