[U-Boot] [PATCH v2 1/2] rockchip: configs: only add available BOOT_TARGET_DEVICES
BOOT_TARGET_DEVICES should only be added if the corresponding u-boot command is enabled.
Signed-off-by: Klaus Goger klaus.goger@theobroma-systems.com ---
Changes in v2: - Add patch to series to prevent build errors if boards don't enable the required u-boot command for distroboot
include/configs/rockchip-common.h | 39 +++++++++++++++++++++++++++------------ 1 file changed, 27 insertions(+), 12 deletions(-)
diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 2d190a964a..3292525fd5 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -11,22 +11,37 @@ #ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h>
-/* First try to boot from SD (index 0), then eMMC (index 1 */ +/* First try to boot from SD (index 0), then eMMC (index 1) */ +#ifdef CONFIG_CMD_MMC + #define BOOT_TARGET_MMC(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) +#else + #define BOOT_TARGET_MMC(func) +#endif + #ifdef CONFIG_CMD_USB -#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(MMC, mmc, 1) \ - func(USB, usb, 0) \ - func(PXE, pxe, na) \ - func(DHCP, dhcp, na) + #define BOOT_TARGET_USB(func) func(USB, usb, 0) #else -#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(MMC, mmc, 1) \ - func(PXE, pxe, na) \ - func(DHCP, dhcp, na) + #define BOOT_TARGET_USB(func) +#endif + +#if CONFIG_CMD_PXE + #define BOOT_TARGET_PXE(func) func(PXE, pxe, na) +#else + #define BOOT_TARGET_PXE(func) +#endif + +#if CONFIG_CMD_DHCP + #define BOOT_TARGET_DHCP(func) func(DHCP, dhcp, na) #endif
+#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_MMC(func) \ + BOOT_TARGET_USB(func) \ + BOOT_TARGET_PXE(func) \ + BOOT_TARGET_DHCP(func) + #define CONFIG_RANDOM_UUID
#ifdef CONFIG_ARM64
rockchip-common.h already defines values that are missing from rk3368_common.h
For example BOOT_TARGET_DEVICES was defined empty and therefore distroboot had no boot targets.
Signed-off-by: Klaus Goger klaus.goger@theobroma-systems.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v2: None
include/configs/rk3368_common.h | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 8b4155f37c..b643cc2464 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -7,6 +7,8 @@ #ifndef __CONFIG_RK3368_COMMON_H #define __CONFIG_RK3368_COMMON_H
+#include "rockchip-common.h" + #define CONFIG_SYS_CACHELINE_SIZE 64
#include <asm/arch/hardware.h> @@ -44,10 +46,6 @@ "kernel_addr_r=0x280000\0" \ "ramdisk_addr_r=0x5bf0000\0"
-#include <config_distro_defaults.h> - -#define BOOT_TARGET_DEVICES(func) - #include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \
Changes in v2:
On 6 Oct 2017, at 17:08, Klaus Goger klaus.goger@theobroma-systems.com wrote:
Required changes below.
Changes in v2:
- #define BOOT_TARGET_MMC(func) \
func(MMC, mmc, 0) \
func(MMC, mmc, 1)
+#else
- #define BOOT_TARGET_USB(func) func(USB, usb, 0)
+#if CONFIG_CMD_PXE
As this section is #ifndef CONFIG_SPL_BUILD anyway, please us CONFIG_IS_ENABLED(CMD_PXE) here.
- #define BOOT_TARGET_PXE(func) func(PXE, pxe, na)
+#else
Same as above (note that #if is not the same as #ifdef).
- #define BOOT_TARGET_DHCP(func) func(DHCP, dhcp, na)
#endif
There is an #else path missing for this one.
- BOOT_TARGET_MMC(func) \
- BOOT_TARGET_USB(func) \
- BOOT_TARGET_PXE(func) \
- BOOT_TARGET_DHCP(func)
#ifdef CONFIG_ARM64
2.11.0
Dr. Philipp Tomsich
Klaus Goger
Philipp Tomsich
