[U-Boot] [PATCH] fsl_esdhc: Touch only relevant sys ctrl bits
Dealing with the sys ctrl register should touch only the relevant bits and not accidently the whole register. On i.MX6, the sys control register contains bits which shouldn't be reset to 0, e.g. SYS_CTRL[3-0] and IPP_RST_N (SYS_CTRL[23]).
Do this by read/modify/write instead of just a 32bit write.
Signed-off-by: Dirk Behme dirk.behme@de.bosch.com --- drivers/mmc/fsl_esdhc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 973b19f..431dac2 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -470,7 +470,7 @@ static int esdhc_init(struct mmc *mmc) int timeout = 1000;
/* Reset the entire host controller */ - esdhc_write32(®s->sysctl, SYSCTL_RSTA); + esdhc_setbits32(®s->sysctl, SYSCTL_RSTA);
/* Wait until the controller is available */ while ((esdhc_read32(®s->sysctl) & SYSCTL_RSTA) && --timeout) @@ -481,7 +481,7 @@ static int esdhc_init(struct mmc *mmc) esdhc_write32(®s->scr, 0x00000040); #endif
- esdhc_write32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN); + esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN);
/* Set the initial clock speed */ mmc_set_clock(mmc, 400000); @@ -515,7 +515,7 @@ static void esdhc_reset(struct fsl_esdhc *regs) unsigned long timeout = 100; /* wait max 100 ms */
/* reset the controller */ - esdhc_write32(®s->sysctl, SYSCTL_RSTA); + esdhc_setbits32(®s->sysctl, SYSCTL_RSTA);
/* hardware clears the bit when it is done */ while ((esdhc_read32(®s->sysctl) & SYSCTL_RSTA) && --timeout)
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Signed-off-by: Dirk Behme dirk.behme@de.bosch.com Acked-by: Stefano Babic sbabic@denx.de
Applied, thanks!
Andy
Andy Fleming
Dirk Behme
Stefano Babic
