[U-Boot] [PATCH 0/9] ARM: ti: am57xx: Add support for latest am57xx boards
This series adds support for: - AM572x-GP evm revA3 - BeagleBoard-X15 revb1 - AM571x-IDK Also update the pinmux using the latest PMT for AM572x-IDK.
Logs: AM572x-GP evm revA3: http://pastebin.ubuntu.com/23530844/ AM572x-IDK: http://pastebin.ubuntu.com/23530850/ AM571x-IDK: http://pastebin.ubuntu.com/23530858/
Lokesh Vutla (4): ARM: dts: am57xx: sync DT with latest Linux board: ti: am57xx: Add support for detection of X15 revb1 board: ti: am572x-idk: Update pinmux using latest PMT ti_armv7_common: env: Increase IO buffer size
Nishanth Menon (3): board: ti: am57xx: Add support for detection of reva3 variations for GPEVM board: ti: am57xx: Update SR1.1 RGMII0 iodelay timings for x15/GPEVM board: ti: am572x: Add pinmux for X15/GPEVM SR2.0 using latest PMT
Schuyler Patton (1): ARM: dts: AM571x-IDK Initial Support
Steve Kipisz (1): board: ti: am57xx: Add support for the am571x idk
arch/arm/dts/Makefile | 4 +- arch/arm/dts/am571x-idk.dts | 81 +++ arch/arm/dts/am572x-idk.dts | 6 +- arch/arm/dts/am57xx-beagle-x15-common.dtsi | 600 +++++++++++++++++ arch/arm/dts/am57xx-beagle-x15-revb1.dts | 24 + arch/arm/dts/am57xx-beagle-x15.dts | 689 +------------------- arch/arm/dts/am57xx-commercial-grade.dtsi | 23 + arch/arm/dts/am57xx-idk-common.dtsi | 40 +- arch/arm/dts/am57xx-industrial-grade.dtsi | 23 + arch/arm/include/asm/arch-omap5/mux_dra7xx.h | 2 +- board/ti/am57xx/board.c | 105 ++- board/ti/am57xx/mux_data.h | 926 +++++++++++++++++++-------- configs/am57xx_evm_defconfig | 2 +- include/configs/ti_armv7_common.h | 2 +- include/configs/ti_omap5_common.h | 6 + 15 files changed, 1526 insertions(+), 1007 deletions(-) create mode 100644 arch/arm/dts/am571x-idk.dts create mode 100644 arch/arm/dts/am57xx-beagle-x15-common.dtsi create mode 100644 arch/arm/dts/am57xx-beagle-x15-revb1.dts create mode 100644 arch/arm/dts/am57xx-commercial-grade.dtsi create mode 100644 arch/arm/dts/am57xx-industrial-grade.dtsi
Sync all am57xx based dts files with latest Linux
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/am572x-idk.dts | 6 +- arch/arm/dts/am57xx-beagle-x15-common.dtsi | 600 +++++++++++++++++++++++++ arch/arm/dts/am57xx-beagle-x15-revb1.dts | 24 + arch/arm/dts/am57xx-beagle-x15.dts | 689 +---------------------------- arch/arm/dts/am57xx-commercial-grade.dtsi | 23 + arch/arm/dts/am57xx-idk-common.dtsi | 40 +- arch/arm/dts/am57xx-industrial-grade.dtsi | 23 + 8 files changed, 703 insertions(+), 703 deletions(-) create mode 100644 arch/arm/dts/am57xx-beagle-x15-common.dtsi create mode 100644 arch/arm/dts/am57xx-beagle-x15-revb1.dts create mode 100644 arch/arm/dts/am57xx-commercial-grade.dtsi create mode 100644 arch/arm/dts/am57xx-industrial-grade.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f7d9e1c..082b89c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -138,6 +138,7 @@ dtb-$(CONFIG_ARCH_SOCFPGA) += \ dtb-$(CONFIG_TARGET_DRA7XX_EVM) += dra72-evm.dtb dra7-evm.dtb \ dra72-evm-revc.dtb dra71-evm.dtb dtb-$(CONFIG_TARGET_AM57XX_EVM) += am57xx-beagle-x15.dtb \ + am57xx-beagle-x15-revb1.dtb \ am572x-idk.dtb dtb-$(CONFIG_TARGET_STV0991) += stv0991.dtb
diff --git a/arch/arm/dts/am572x-idk.dts b/arch/arm/dts/am572x-idk.dts index b340551..f9adc00 100644 --- a/arch/arm/dts/am572x-idk.dts +++ b/arch/arm/dts/am572x-idk.dts @@ -18,11 +18,7 @@ compatible = "ti,am5728-idk", "ti,am5728", "ti,dra742", "ti,dra74", "ti,dra7";
- chosen { - stdout-path = &uart3; - }; - - memory { + memory@0 { device_type = "memory"; reg = <0x0 0x80000000 0x0 0x80000000>; }; diff --git a/arch/arm/dts/am57xx-beagle-x15-common.dtsi b/arch/arm/dts/am57xx-beagle-x15-common.dtsi new file mode 100644 index 0000000..01a9e56 --- /dev/null +++ b/arch/arm/dts/am57xx-beagle-x15-common.dtsi @@ -0,0 +1,600 @@ +/* + * Copyright (C) 2014-2016 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +/dts-v1/; + +#include "dra74x.dtsi" +#include "am57xx-commercial-grade.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + compatible = "ti,am572x-beagle-x15", "ti,am5728", "ti,dra742", "ti,dra74", "ti,dra7"; + + chosen { + stdout-path = &uart3; + }; + + aliases { + rtc0 = &mcp_rtc; + rtc1 = &tps659038_rtc; + rtc2 = &rtc; + display0 = &hdmi0; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x80000000 0x0 0x80000000>; + }; + + vdd_3v3: fixedregulator-vdd_3v3 { + compatible = "regulator-fixed"; + regulator-name = "vdd_3v3"; + vin-supply = <®en1>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + aic_dvdd: fixedregulator-aic_dvdd { + compatible = "regulator-fixed"; + regulator-name = "aic_dvdd_fixed"; + vin-supply = <&vdd_3v3>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vtt_fixed: fixedregulator-vtt { + /* TPS51200 */ + compatible = "regulator-fixed"; + regulator-name = "vtt_fixed"; + vin-supply = <&smps3_reg>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>; + }; + + leds { + compatible = "gpio-leds"; + + led0 { + label = "beagle-x15:usr0"; + gpios = <&gpio7 9 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + + led1 { + label = "beagle-x15:usr1"; + gpios = <&gpio7 8 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "cpu0"; + default-state = "off"; + }; + + led2 { + label = "beagle-x15:usr2"; + gpios = <&gpio7 14 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + default-state = "off"; + }; + + led3 { + label = "beagle-x15:usr3"; + gpios = <&gpio7 15 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "disk-activity"; + default-state = "off"; + }; + }; + + gpio_fan: gpio_fan { + /* Based on 5v 500mA AFB02505HHB */ + compatible = "gpio-fan"; + gpios = <&tps659038_gpio 2 GPIO_ACTIVE_HIGH>; + gpio-fan,speed-map = <0 0>, + <13000 1>; + #cooling-cells = <2>; + }; + + hdmi0: connector { + compatible = "hdmi-connector"; + label = "hdmi"; + + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&tpd12s015_out>; + }; + }; + }; + + tpd12s015: encoder { + compatible = "ti,tpd12s015"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tpd12s015_in: endpoint { + remote-endpoint = <&hdmi_out>; + }; + }; + + port@1 { + reg = <1>; + + tpd12s015_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; + }; + }; + }; + + sound0: sound0 { + compatible = "simple-audio-card"; + simple-audio-card,name = "BeagleBoard-X15"; + simple-audio-card,widgets = + "Line", "Line Out", + "Line", "Line In"; + simple-audio-card,routing = + "Line Out", "LLOUT", + "Line Out", "RLOUT", + "MIC2L", "Line In", + "MIC2R", "Line In"; + simple-audio-card,format = "dsp_b"; + simple-audio-card,bitclock-master = <&sound0_master>; + simple-audio-card,frame-master = <&sound0_master>; + simple-audio-card,bitclock-inversion; + + simple-audio-card,cpu { + sound-dai = <&mcasp3>; + }; + + sound0_master: simple-audio-card,codec { + sound-dai = <&tlv320aic3104>; + clocks = <&clkout2_clk>; + }; + }; +}; + +&dra7_pmx_core { + mmc1_pins_default: mmc1_pins_default { + pinctrl-single,pins = < + DRA7XX_CORE_IOPAD(0x376c, PIN_INPUT | MUX_MODE14) /* mmc1sdcd.gpio219 */ + DRA7XX_CORE_IOPAD(0x3754, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */ + DRA7XX_CORE_IOPAD(0x3758, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */ + DRA7XX_CORE_IOPAD(0x375c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */ + DRA7XX_CORE_IOPAD(0x3760, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */ + DRA7XX_CORE_IOPAD(0x3764, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */ + DRA7XX_CORE_IOPAD(0x3768, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */ + >; + }; + + mmc2_pins_default: mmc2_pins_default { + pinctrl-single,pins = < + DRA7XX_CORE_IOPAD(0x349c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a23.mmc2_clk */ + DRA7XX_CORE_IOPAD(0x34b0, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */ + DRA7XX_CORE_IOPAD(0x34a0, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */ + DRA7XX_CORE_IOPAD(0x34a4, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */ + DRA7XX_CORE_IOPAD(0x34a8, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */ + DRA7XX_CORE_IOPAD(0x34ac, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */ + DRA7XX_CORE_IOPAD(0x348c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */ + DRA7XX_CORE_IOPAD(0x3490, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */ + DRA7XX_CORE_IOPAD(0x3494, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */ + DRA7XX_CORE_IOPAD(0x3498, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */ + >; + }; +}; +&i2c1 { + status = "okay"; + clock-frequency = <400000>; + + tps659038: tps659038@58 { + compatible = "ti,tps659038"; + reg = <0x58>; + interrupt-parent = <&gpio1>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + + #interrupt-cells = <2>; + interrupt-controller; + + ti,system-power-controller; + + tps659038_pmic { + compatible = "ti,tps659038-pmic"; + + regulators { + smps12_reg: smps12 { + /* VDD_MPU */ + regulator-name = "smps12"; + regulator-min-microvolt = < 850000>; + regulator-max-microvolt = <1250000>; + regulator-always-on; + regulator-boot-on; + }; + + smps3_reg: smps3 { + /* VDD_DDR */ + regulator-name = "smps3"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + smps45_reg: smps45 { + /* VDD_DSPEVE, VDD_IVA, VDD_GPU */ + regulator-name = "smps45"; + regulator-min-microvolt = < 850000>; + regulator-max-microvolt = <1250000>; + regulator-always-on; + regulator-boot-on; + }; + + smps6_reg: smps6 { + /* VDD_CORE */ + regulator-name = "smps6"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1150000>; + regulator-always-on; + regulator-boot-on; + }; + + /* SMPS7 unused */ + + smps8_reg: smps8 { + /* VDD_1V8 */ + regulator-name = "smps8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + /* SMPS9 unused */ + + ldo1_reg: ldo1 { + /* VDD_SD / VDDSHV8 */ + regulator-name = "ldo1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo2_reg: ldo2 { + /* VDD_SHV5 */ + regulator-name = "ldo2"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; + + ldo3_reg: ldo3 { + /* VDDA_1V8_PHYA */ + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + ldo4_reg: ldo4 { + /* VDDA_1V8_PHYB */ + regulator-name = "ldo4"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + ldo9_reg: ldo9 { + /* VDD_RTC */ + regulator-name = "ldo9"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + regulator-always-on; + regulator-boot-on; + }; + + ldoln_reg: ldoln { + /* VDDA_1V8_PLL */ + regulator-name = "ldoln"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + ldousb_reg: ldousb { + /* VDDA_3V_USB: VDDA_USBHS33 */ + regulator-name = "ldousb"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + }; + + regen1: regen1 { + /* VDD_3V3_ON */ + regulator-name = "regen1"; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + tps659038_rtc: tps659038_rtc { + compatible = "ti,palmas-rtc"; + interrupt-parent = <&tps659038>; + interrupts = <8 IRQ_TYPE_EDGE_FALLING>; + wakeup-source; + }; + + tps659038_pwr_button: tps659038_pwr_button { + compatible = "ti,palmas-pwrbutton"; + interrupt-parent = <&tps659038>; + interrupts = <1 IRQ_TYPE_EDGE_FALLING>; + wakeup-source; + ti,palmas-long-press-seconds = <12>; + }; + + tps659038_gpio: tps659038_gpio { + compatible = "ti,palmas-gpio"; + gpio-controller; + #gpio-cells = <2>; + }; + + extcon_usb2: tps659038_usb { + compatible = "ti,palmas-usb-vid"; + ti,enable-vbus-detection; + vbus-gpio = <&gpio4 21 GPIO_ACTIVE_HIGH>; + }; + + }; + + tmp102: tmp102@48 { + compatible = "ti,tmp102"; + reg = <0x48>; + interrupt-parent = <&gpio7>; + interrupts = <16 IRQ_TYPE_LEVEL_LOW>; + #thermal-sensor-cells = <1>; + }; + + tlv320aic3104: tlv320aic3104@18 { + #sound-dai-cells = <0>; + compatible = "ti,tlv320aic3104"; + reg = <0x18>; + assigned-clocks = <&clkoutmux2_clk_mux>; + assigned-clock-parents = <&sys_clk2_dclk_div>; + + status = "okay"; + adc-settle-ms = <40>; + + AVDD-supply = <&vdd_3v3>; + IOVDD-supply = <&vdd_3v3>; + DRVDD-supply = <&vdd_3v3>; + DVDD-supply = <&aic_dvdd>; + }; + + eeprom: eeprom@50 { + compatible = "at,24c32"; + reg = <0x50>; + }; +}; + +&i2c3 { + status = "okay"; + clock-frequency = <400000>; + + mcp_rtc: rtc@6f { + compatible = "microchip,mcp7941x"; + reg = <0x6f>; + interrupts-extended = <&crossbar_mpu GIC_SPI 2 IRQ_TYPE_EDGE_RISING>, + <&dra7_pmx_core 0x424>; + interrupt-names = "irq", "wakeup"; + + vcc-supply = <&vdd_3v3>; + wakeup-source; + }; +}; + +&gpio7 { + ti,no-reset-on-init; + ti,no-idle-on-init; +}; + +&cpu0 { + cpu0-supply = <&smps12_reg>; + voltage-tolerance = <1>; +}; + +&uart3 { + status = "okay"; + interrupts-extended = <&crossbar_mpu GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>, + <&dra7_pmx_core 0x3f8>; +}; + +&mac { + status = "okay"; + dual_emac; +}; + +&cpsw_emac0 { + phy_id = <&davinci_mdio>, <1>; + phy-mode = "rgmii"; + dual_emac_res_vlan = <1>; +}; + +&cpsw_emac1 { + phy_id = <&davinci_mdio>, <2>; + phy-mode = "rgmii"; + dual_emac_res_vlan = <2>; +}; + +&mmc1 { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins_default>; + + bus-width = <4>; + cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; /* gpio 219 */ +}; + +&mmc2 { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins_default>; + + vmmc-supply = <&vdd_3v3>; + bus-width = <8>; + ti,non-removable; + cap-mmc-dual-data-rate; +}; + +&sata { + status = "okay"; +}; + +&usb2_phy1 { + phy-supply = <&ldousb_reg>; +}; + +&usb2_phy2 { + phy-supply = <&ldousb_reg>; +}; + +&usb1 { + dr_mode = "host"; +}; + +&omap_dwc3_2 { + extcon = <&extcon_usb2>; +}; + +&usb2 { + /* + * Stand alone usage is peripheral only. + * However, with some resistor modifications + * this port can be used via expansion connectors + * as "host" or "dual-role". If so, provide + * the necessary dr_mode override in the expansion + * board's DT. + */ + dr_mode = "peripheral"; +}; + +&cpu_trips { + cpu_alert1: cpu_alert1 { + temperature = <50000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "active"; + }; +}; + +&cpu_cooling_maps { + map1 { + trip = <&cpu_alert1>; + cooling-device = <&gpio_fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; +}; + +&thermal_zones { + board_thermal: board_thermal { + polling-delay-passive = <1250>; /* milliseconds */ + polling-delay = <1500>; /* milliseconds */ + + /* sensor ID */ + thermal-sensors = <&tmp102 0>; + + board_trips: trips { + board_alert0: board_alert { + temperature = <40000>; /* millicelsius */ + hysteresis = <2000>; /* millicelsius */ + type = "active"; + }; + + board_crit: board_crit { + temperature = <105000>; /* millicelsius */ + hysteresis = <0>; /* millicelsius */ + type = "critical"; + }; + }; + + board_cooling_maps: cooling-maps { + map0 { + trip = <&board_alert0>; + cooling-device = + <&gpio_fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; +}; + +&dss { + status = "ok"; + + vdda_video-supply = <&ldoln_reg>; +}; + +&hdmi { + status = "ok"; + vdda-supply = <&ldo4_reg>; + + port { + hdmi_out: endpoint { + remote-endpoint = <&tpd12s015_in>; + }; + }; +}; + +&pcie1 { + gpios = <&gpio2 8 GPIO_ACTIVE_LOW>; +}; + +&mcasp3 { + #sound-dai-cells = <0>; + assigned-clocks = <&mcasp3_ahclkx_mux>; + assigned-clock-parents = <&sys_clkin2>; + status = "okay"; + + op-mode = <0>; /* MCASP_IIS_MODE */ + tdm-slots = <2>; + /* 4 serializers */ + serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ + 1 2 0 0 + >; + tx-num-evt = <32>; + rx-num-evt = <32>; +}; + +&mailbox5 { + status = "okay"; + mbox_ipu1_ipc3x: mbox_ipu1_ipc3x { + status = "okay"; + }; + mbox_dsp1_ipc3x: mbox_dsp1_ipc3x { + status = "okay"; + }; +}; + +&mailbox6 { + status = "okay"; + mbox_ipu2_ipc3x: mbox_ipu2_ipc3x { + status = "okay"; + }; + mbox_dsp2_ipc3x: mbox_dsp2_ipc3x { + status = "okay"; + }; +}; diff --git a/arch/arm/dts/am57xx-beagle-x15-revb1.dts b/arch/arm/dts/am57xx-beagle-x15-revb1.dts new file mode 100644 index 0000000..ca85570 --- /dev/null +++ b/arch/arm/dts/am57xx-beagle-x15-revb1.dts @@ -0,0 +1,24 @@ +/* + * Copyright (C) 2014-2016 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include "am57xx-beagle-x15-common.dtsi" + +/ { + model = "TI AM5728 BeagleBoard-X15 rev B1"; +}; + +&tpd12s015 { + gpios = <&gpio7 10 GPIO_ACTIVE_HIGH>, /* gpio7_10, CT CP HPD */ + <&gpio2 30 GPIO_ACTIVE_HIGH>, /* gpio2_30, LS OE */ + <&gpio7 12 GPIO_ACTIVE_HIGH>; /* gpio7_12/sp1_cs2, HPD */ +}; + +&mmc1 { + vmmc-supply = <&vdd_3v3>; + vmmc-aux-supply = <&ldo1_reg>; +}; diff --git a/arch/arm/dts/am57xx-beagle-x15.dts b/arch/arm/dts/am57xx-beagle-x15.dts index 38b266a..8c66f2e 100644 --- a/arch/arm/dts/am57xx-beagle-x15.dts +++ b/arch/arm/dts/am57xx-beagle-x15.dts @@ -1,699 +1,24 @@ /* - * Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/ + * Copyright (C) 2014-2016 Texas Instruments Incorporated - http://www.ti.com/ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ -/dts-v1/;
-#include "dra74x.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/irq.h> +#include "am57xx-beagle-x15-common.dtsi"
/ { + /* NOTE: This describes the "original" pre-production A2 revision */ model = "TI AM5728 BeagleBoard-X15"; - compatible = "ti,am572x-beagle-x15", "ti,am5728", "ti,dra742", "ti,dra74", "ti,dra7"; - - chosen { - stdout-path = &uart3; - }; - - aliases { - rtc0 = &mcp_rtc; - rtc1 = &tps659038_rtc; - rtc2 = &rtc; - display0 = &hdmi0; - }; - - memory { - device_type = "memory"; - reg = <0x80000000 0x80000000>; - }; - - vdd_3v3: fixedregulator-vdd_3v3 { - compatible = "regulator-fixed"; - regulator-name = "vdd_3v3"; - vin-supply = <®en1>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vtt_fixed: fixedregulator-vtt { - /* TPS51200 */ - compatible = "regulator-fixed"; - regulator-name = "vtt_fixed"; - vin-supply = <&smps3_reg>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - enable-active-high; - gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&leds_pins_default>; - - led@0 { - label = "beagle-x15:usr0"; - gpios = <&gpio7 9 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - default-state = "off"; - }; - - led@1 { - label = "beagle-x15:usr1"; - gpios = <&gpio7 8 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "cpu0"; - default-state = "off"; - }; - - led@2 { - label = "beagle-x15:usr2"; - gpios = <&gpio7 14 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc0"; - default-state = "off"; - }; - - led@3 { - label = "beagle-x15:usr3"; - gpios = <&gpio7 15 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "ide-disk"; - default-state = "off"; - }; - }; - - gpio_fan: gpio_fan { - /* Based on 5v 500mA AFB02505HHB */ - compatible = "gpio-fan"; - gpios = <&tps659038_gpio 2 GPIO_ACTIVE_HIGH>; - gpio-fan,speed-map = <0 0>, - <13000 1>; - #cooling-cells = <2>; - }; - - extcon_usb1: extcon_usb1 { - compatible = "linux,extcon-usb-gpio"; - id-gpio = <&gpio7 25 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&extcon_usb1_pins>; - }; - - extcon_usb2: extcon_usb2 { - compatible = "linux,extcon-usb-gpio"; - id-gpio = <&gpio7 24 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&extcon_usb2_pins>; - }; - - hdmi0: connector { - compatible = "hdmi-connector"; - label = "hdmi"; - - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&tpd12s015_out>; - }; - }; - }; - - tpd12s015: encoder { - compatible = "ti,tpd12s015"; - - pinctrl-names = "default"; - pinctrl-0 = <&tpd12s015_pins>; - - gpios = <&gpio7 10 GPIO_ACTIVE_HIGH>, /* gpio7_10, CT CP HPD */ - <&gpio6 28 GPIO_ACTIVE_HIGH>, /* gpio6_28, LS OE */ - <&gpio7 12 GPIO_ACTIVE_HIGH>; /* gpio7_12/sp1_cs2, HPD */ - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - tpd12s015_in: endpoint { - remote-endpoint = <&hdmi_out>; - }; - }; - - port@1 { - reg = <1>; - - tpd12s015_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; - }; - }; - }; -}; - -&dra7_pmx_core { - leds_pins_default: leds_pins_default { - pinctrl-single,pins = < - 0x3a8 (PIN_OUTPUT | MUX_MODE14) /* spi1_d1.gpio7_8 */ - 0x3ac (PIN_OUTPUT | MUX_MODE14) /* spi1_d0.gpio7_9 */ - 0x3c0 (PIN_OUTPUT | MUX_MODE14) /* spi2_sclk.gpio7_14 */ - 0x3c4 (PIN_OUTPUT | MUX_MODE14) /* spi2_d1.gpio7_15 */ - >; - }; - - i2c1_pins_default: i2c1_pins_default { - pinctrl-single,pins = < - 0x400 (PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_sda.sda */ - 0x404 (PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_scl.scl */ - >; - }; - - hdmi_pins: pinmux_hdmi_pins { - pinctrl-single,pins = < - 0x408 (PIN_INPUT | MUX_MODE1) /* i2c2_sda.hdmi1_ddc_scl */ - 0x40c (PIN_INPUT | MUX_MODE1) /* i2c2_scl.hdmi1_ddc_sda */ - >; - }; - - i2c3_pins_default: i2c3_pins_default { - pinctrl-single,pins = < - 0x2a4 (PIN_INPUT| MUX_MODE10) /* mcasp1_aclkx.i2c3_sda */ - 0x2a8 (PIN_INPUT| MUX_MODE10) /* mcasp1_fsx.i2c3_scl */ - >; - }; - - uart3_pins_default: uart3_pins_default { - pinctrl-single,pins = < - 0x3f8 (PIN_INPUT_SLEW | MUX_MODE2) /* uart2_ctsn.uart3_rxd */ - 0x3fc (PIN_INPUT_SLEW | MUX_MODE1) /* uart2_rtsn.uart3_txd */ - >; - }; - - mmc1_pins_default: mmc1_pins_default { - pinctrl-single,pins = < - 0x36c (PIN_INPUT | MUX_MODE14) /* mmc1sdcd.gpio219 */ - 0x354 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */ - 0x358 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */ - 0x35c (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */ - 0x360 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */ - 0x364 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */ - 0x368 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */ - >; - }; - - mmc2_pins_default: mmc2_pins_default { - pinctrl-single,pins = < - 0x9c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a23.mmc2_clk */ - 0xb0 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */ - 0xa0 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */ - 0xa4 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */ - 0xa8 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */ - 0xac (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */ - 0x8c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */ - 0x90 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */ - 0x94 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */ - 0x98 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */ - >; - }; - - cpsw_pins_default: cpsw_pins_default { - pinctrl-single,pins = < - /* Slave 1 */ - 0x250 (PIN_OUTPUT | MUX_MODE0) /* rgmii1_tclk */ - 0x254 (PIN_OUTPUT | MUX_MODE0) /* rgmii1_tctl */ - 0x258 (PIN_OUTPUT | MUX_MODE0) /* rgmii1_td3 */ - 0x25c (PIN_OUTPUT | MUX_MODE0) /* rgmii1_td2 */ - 0x260 (PIN_OUTPUT | MUX_MODE0) /* rgmii1_td1 */ - 0x264 (PIN_OUTPUT | MUX_MODE0) /* rgmii1_td0 */ - 0x268 (PIN_INPUT | MUX_MODE0) /* rgmii1_rclk */ - 0x26c (PIN_INPUT | MUX_MODE0) /* rgmii1_rctl */ - 0x270 (PIN_INPUT | MUX_MODE0) /* rgmii1_rd3 */ - 0x274 (PIN_INPUT | MUX_MODE0) /* rgmii1_rd2 */ - 0x278 (PIN_INPUT | MUX_MODE0) /* rgmii1_rd1 */ - 0x27c (PIN_INPUT | MUX_MODE0) /* rgmii1_rd0 */ - - /* Slave 2 */ - 0x198 (PIN_OUTPUT | MUX_MODE3) /* rgmii2_tclk */ - 0x19c (PIN_OUTPUT | MUX_MODE3) /* rgmii2_tctl */ - 0x1a0 (PIN_OUTPUT | MUX_MODE3) /* rgmii2_td3 */ - 0x1a4 (PIN_OUTPUT | MUX_MODE3) /* rgmii2_td2 */ - 0x1a8 (PIN_OUTPUT | MUX_MODE3) /* rgmii2_td1 */ - 0x1ac (PIN_OUTPUT | MUX_MODE3) /* rgmii2_td0 */ - 0x1b0 (PIN_INPUT | MUX_MODE3) /* rgmii2_rclk */ - 0x1b4 (PIN_INPUT | MUX_MODE3) /* rgmii2_rctl */ - 0x1b8 (PIN_INPUT | MUX_MODE3) /* rgmii2_rd3 */ - 0x1bc (PIN_INPUT | MUX_MODE3) /* rgmii2_rd2 */ - 0x1c0 (PIN_INPUT | MUX_MODE3) /* rgmii2_rd1 */ - 0x1c4 (PIN_INPUT | MUX_MODE3) /* rgmii2_rd0 */ - >; - - }; - - cpsw_pins_sleep: cpsw_pins_sleep { - pinctrl-single,pins = < - /* Slave 1 */ - 0x250 (PIN_INPUT | MUX_MODE15) - 0x254 (PIN_INPUT | MUX_MODE15) - 0x258 (PIN_INPUT | MUX_MODE15) - 0x25c (PIN_INPUT | MUX_MODE15) - 0x260 (PIN_INPUT | MUX_MODE15) - 0x264 (PIN_INPUT | MUX_MODE15) - 0x268 (PIN_INPUT | MUX_MODE15) - 0x26c (PIN_INPUT | MUX_MODE15) - 0x270 (PIN_INPUT | MUX_MODE15) - 0x274 (PIN_INPUT | MUX_MODE15) - 0x278 (PIN_INPUT | MUX_MODE15) - 0x27c (PIN_INPUT | MUX_MODE15) - - /* Slave 2 */ - 0x198 (PIN_INPUT | MUX_MODE15) - 0x19c (PIN_INPUT | MUX_MODE15) - 0x1a0 (PIN_INPUT | MUX_MODE15) - 0x1a4 (PIN_INPUT | MUX_MODE15) - 0x1a8 (PIN_INPUT | MUX_MODE15) - 0x1ac (PIN_INPUT | MUX_MODE15) - 0x1b0 (PIN_INPUT | MUX_MODE15) - 0x1b4 (PIN_INPUT | MUX_MODE15) - 0x1b8 (PIN_INPUT | MUX_MODE15) - 0x1bc (PIN_INPUT | MUX_MODE15) - 0x1c0 (PIN_INPUT | MUX_MODE15) - 0x1c4 (PIN_INPUT | MUX_MODE15) - >; - }; - - davinci_mdio_pins_default: davinci_mdio_pins_default { - pinctrl-single,pins = < - /* MDIO */ - 0x23c (PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_mclk */ - 0x240 (PIN_INPUT_PULLUP | MUX_MODE0) /* mdio_d */ - >; - }; - - davinci_mdio_pins_sleep: davinci_mdio_pins_sleep { - pinctrl-single,pins = < - 0x23c (PIN_INPUT | MUX_MODE15) - 0x240 (PIN_INPUT | MUX_MODE15) - >; - }; - - tps659038_pins_default: tps659038_pins_default { - pinctrl-single,pins = < - 0x418 (PIN_INPUT_PULLUP | MUX_MODE14) /* wakeup0.gpio1_0 */ - >; - }; - - tmp102_pins_default: tmp102_pins_default { - pinctrl-single,pins = < - 0x3C8 (PIN_INPUT_PULLUP | MUX_MODE14) /* spi2_d0.gpio7_16 */ - >; - }; - - mcp79410_pins_default: mcp79410_pins_default { - pinctrl-single,pins = < - 0x424 (PIN_INPUT_PULLUP | MUX_MODE1) /* wakeup3.sys_nirq1 */ - >; - }; - - usb1_pins: pinmux_usb1_pins { - pinctrl-single,pins = < - 0x280 (PIN_INPUT_SLEW | MUX_MODE0) /* usb1_drvvbus */ - >; - }; - - extcon_usb1_pins: extcon_usb1_pins { - pinctrl-single,pins = < - 0x3ec (PIN_INPUT_PULLUP | MUX_MODE14) /* uart1_rtsn.gpio7_25 */ - >; - }; - - extcon_usb2_pins: extcon_usb2_pins { - pinctrl-single,pins = < - 0x3e8 (PIN_INPUT_PULLUP | MUX_MODE14) /* uart1_ctsn.gpio7_24 */ - >; - }; - - tpd12s015_pins: pinmux_tpd12s015_pins { - pinctrl-single,pins = < - 0x3b0 (PIN_OUTPUT | MUX_MODE14) /* gpio7_10 CT_CP_HPD */ - 0x3b8 (PIN_INPUT_PULLDOWN | MUX_MODE14) /* gpio7_12 HPD */ - 0x370 (PIN_OUTPUT | MUX_MODE14) /* gpio6_28 LS_OE */ - >; - }; -}; - -&i2c1 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins_default>; - clock-frequency = <400000>; - - tps659038: tps659038@58 { - compatible = "ti,tps659038"; - reg = <0x58>; - interrupt-parent = <&gpio1>; - interrupts = <0 IRQ_TYPE_LEVEL_LOW>; - - pinctrl-names = "default"; - pinctrl-0 = <&tps659038_pins_default>; - - #interrupt-cells = <2>; - interrupt-controller; - - ti,system-power-controller; - - tps659038_pmic { - compatible = "ti,tps659038-pmic"; - - regulators { - smps12_reg: smps12 { - /* VDD_MPU */ - regulator-name = "smps12"; - regulator-min-microvolt = < 850000>; - regulator-max-microvolt = <1250000>; - regulator-always-on; - regulator-boot-on; - }; - - smps3_reg: smps3 { - /* VDD_DDR */ - regulator-name = "smps3"; - regulator-min-microvolt = <1350000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - }; - - smps45_reg: smps45 { - /* VDD_DSPEVE, VDD_IVA, VDD_GPU */ - regulator-name = "smps45"; - regulator-min-microvolt = < 850000>; - regulator-max-microvolt = <1150000>; - regulator-always-on; - regulator-boot-on; - }; - - smps6_reg: smps6 { - /* VDD_CORE */ - regulator-name = "smps6"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <1030000>; - regulator-always-on; - regulator-boot-on; - }; - - /* SMPS7 unused */ - - smps8_reg: smps8 { - /* VDD_1V8 */ - regulator-name = "smps8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - }; - - /* SMPS9 unused */ - - ldo1_reg: ldo1 { - /* VDD_SD */ - regulator-name = "ldo1"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - }; - - ldo2_reg: ldo2 { - /* VDD_SHV5 */ - regulator-name = "ldo2"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - }; - - ldo3_reg: ldo3 { - /* VDDA_1V8_PHY */ - regulator-name = "ldo3"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - }; - - ldo9_reg: ldo9 { - /* VDD_RTC */ - regulator-name = "ldo9"; - regulator-min-microvolt = <1050000>; - regulator-max-microvolt = <1050000>; - regulator-always-on; - regulator-boot-on; - }; - - ldoln_reg: ldoln { - /* VDDA_1V8_PLL */ - regulator-name = "ldoln"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - }; - - ldousb_reg: ldousb { - /* VDDA_3V_USB: VDDA_USBHS33 */ - regulator-name = "ldousb"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - }; - - regen1: regen1 { - /* VDD_3V3_ON */ - regulator-name = "regen1"; - regulator-boot-on; - regulator-always-on; - }; - }; - }; - - tps659038_rtc: tps659038_rtc { - compatible = "ti,palmas-rtc"; - interrupt-parent = <&tps659038>; - interrupts = <8 IRQ_TYPE_EDGE_FALLING>; - wakeup-source; - }; - - tps659038_pwr_button: tps659038_pwr_button { - compatible = "ti,palmas-pwrbutton"; - interrupt-parent = <&tps659038>; - interrupts = <1 IRQ_TYPE_EDGE_FALLING>; - wakeup-source; - ti,palmas-long-press-seconds = <12>; - }; - - tps659038_gpio: tps659038_gpio { - compatible = "ti,palmas-gpio"; - gpio-controller; - #gpio-cells = <2>; - }; - }; - - tmp102: tmp102@48 { - compatible = "ti,tmp102"; - reg = <0x48>; - pinctrl-names = "default"; - pinctrl-0 = <&tmp102_pins_default>; - interrupt-parent = <&gpio7>; - interrupts = <16 IRQ_TYPE_LEVEL_LOW>; - #thermal-sensor-cells = <1>; - }; -}; - -&i2c3 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_pins_default>; - clock-frequency = <400000>; - - mcp_rtc: rtc@6f { - compatible = "microchip,mcp7941x"; - reg = <0x6f>; - interrupts = <GIC_SPI 2 IRQ_TYPE_EDGE_RISING>; /* IRQ_SYS_1N */ - - pinctrl-names = "default"; - pinctrl-0 = <&mcp79410_pins_default>; - - vcc-supply = <&vdd_3v3>; - wakeup-source; - }; -}; - -&gpio7 { - ti,no-reset-on-init; - ti,no-idle-on-init; -}; - -&cpu0 { - cpu0-supply = <&smps12_reg>; - voltage-tolerance = <1>; -}; - -&uart3 { - status = "okay"; - interrupts-extended = <&crossbar_mpu GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>, - <&dra7_pmx_core 0x3f8>; - - pinctrl-names = "default"; - pinctrl-0 = <&uart3_pins_default>; -}; - -&mac { - status = "okay"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&cpsw_pins_default>; - pinctrl-1 = <&cpsw_pins_sleep>; - dual_emac; -}; - -&cpsw_emac0 { - phy_id = <&davinci_mdio>, <1>; - phy-mode = "rgmii"; - dual_emac_res_vlan = <1>; };
-&cpsw_emac1 { - phy_id = <&davinci_mdio>, <2>; - phy-mode = "rgmii"; - dual_emac_res_vlan = <2>; -}; - -&davinci_mdio { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&davinci_mdio_pins_default>; - pinctrl-1 = <&davinci_mdio_pins_sleep>; +&tpd12s015 { + gpios = <&gpio7 10 GPIO_ACTIVE_HIGH>, /* gpio7_10, CT CP HPD */ + <&gpio6 28 GPIO_ACTIVE_HIGH>, /* gpio6_28, LS OE */ + <&gpio7 12 GPIO_ACTIVE_HIGH>; /* gpio7_12/sp1_cs2, HPD */ };
&mmc1 { - status = "okay"; - - pinctrl-names = "default"; - pinctrl-0 = <&mmc1_pins_default>; - vmmc-supply = <&ldo1_reg>; - vmmc_aux-supply = <&vdd_3v3>; - pbias-supply = <&pbias_mmc_reg>; - bus-width = <4>; - cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; /* gpio 219 */ -}; - -&mmc2 { - status = "okay"; - - pinctrl-names = "default"; - pinctrl-0 = <&mmc2_pins_default>; - - vmmc-supply = <&vdd_3v3>; - bus-width = <8>; - ti,non-removable; - cap-mmc-dual-data-rate; -}; - -&sata { - status = "okay"; -}; - -&usb2_phy1 { - phy-supply = <&ldousb_reg>; -}; - -&usb2_phy2 { - phy-supply = <&ldousb_reg>; -}; - -&usb1 { - dr_mode = "host"; - pinctrl-names = "default"; - pinctrl-0 = <&usb1_pins>; -}; - -&omap_dwc3_1 { - extcon = <&extcon_usb1>; -}; - -&omap_dwc3_2 { - extcon = <&extcon_usb2>; -}; - -&usb2 { - dr_mode = "peripheral"; -}; - -&cpu_trips { - cpu_alert1: cpu_alert1 { - temperature = <50000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "active"; - }; -}; - -&cpu_cooling_maps { - map1 { - trip = <&cpu_alert1>; - cooling-device = <&gpio_fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; -}; - -&thermal_zones { - board_thermal: board_thermal { - polling-delay-passive = <1250>; /* milliseconds */ - polling-delay = <1500>; /* milliseconds */ - - /* sensor ID */ - thermal-sensors = <&tmp102 0>; - - board_trips: trips { - board_alert0: board_alert { - temperature = <40000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "active"; - }; - - board_crit: board_crit { - temperature = <105000>; /* millicelsius */ - hysteresis = <0>; /* millicelsius */ - type = "critical"; - }; - }; - - board_cooling_maps: cooling-maps { - map0 { - trip = <&board_alert0>; - cooling-device = - <&gpio_fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; -}; - -&dss { - status = "ok"; - - vdda_video-supply = <&ldoln_reg>; -}; - -&hdmi { - status = "ok"; - vdda-supply = <&ldo3_reg>; - - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_pins>; - - port { - hdmi_out: endpoint { - remote-endpoint = <&tpd12s015_in>; - }; - }; }; diff --git a/arch/arm/dts/am57xx-commercial-grade.dtsi b/arch/arm/dts/am57xx-commercial-grade.dtsi new file mode 100644 index 0000000..c183654 --- /dev/null +++ b/arch/arm/dts/am57xx-commercial-grade.dtsi @@ -0,0 +1,23 @@ +&cpu_alert0 { + temperature = <80000>; /* milliCelsius */ +}; + +&cpu_crit { + temperature = <90000>; /* milliCelsius */ +}; + +&gpu_crit { + temperature = <90000>; /* milliCelsius */ +}; + +&core_crit { + temperature = <90000>; /* milliCelsius */ +}; + +&dspeve_crit { + temperature = <90000>; /* milliCelsius */ +}; + +&iva_crit { + temperature = <90000>; /* milliCelsius */ +}; diff --git a/arch/arm/dts/am57xx-idk-common.dtsi b/arch/arm/dts/am57xx-idk-common.dtsi index a5bcd25..30118ed 100644 --- a/arch/arm/dts/am57xx-idk-common.dtsi +++ b/arch/arm/dts/am57xx-idk-common.dtsi @@ -6,12 +6,18 @@ * published by the Free Software Foundation. */
+#include "am57xx-industrial-grade.dtsi" + / { aliases { rtc0 = &tps659038_rtc; rtc1 = &rtc; };
+ chosen { + stdout-path = &uart3; + }; + vmain: fixedregulator-vmain { compatible = "regulator-fixed"; regulator-name = "VMAIN"; @@ -58,10 +64,26 @@
tps659038_pmic { compatible = "ti,tps659038-pmic"; + + smps12-in-supply = <&vmain>; + smps3-in-supply = <&vmain>; + smps45-in-supply = <&vmain>; + smps6-in-supply = <&vmain>; + smps7-in-supply = <&vmain>; + smps8-in-supply = <&vmain>; + smps9-in-supply = <&vmain>; + ldo1-in-supply = <&vmain>; + ldo2-in-supply = <&vmain>; + ldo3-in-supply = <&vmain>; + ldo4-in-supply = <&vmain>; + ldo9-in-supply = <&vmain>; + ldoln-in-supply = <&vmain>; + ldousb-in-supply = <&vmain>; + ldortc-in-supply = <&vmain>; + regulators { smps12_reg: smps12 { /* VDD_MPU */ - vin-supply = <&vmain>; regulator-name = "smps12"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; @@ -71,7 +93,6 @@
smps3_reg: smps3 { /* VDD_DDR EMIF1 EMIF2 */ - vin-supply = <&vmain>; regulator-name = "smps3"; regulator-min-microvolt = <1350000>; regulator-max-microvolt = <1350000>; @@ -82,7 +103,6 @@ smps45_reg: smps45 { /* VDD_DSPEVE on AM572 */ /* VDD_IVA + VDD_DSP on AM571 */ - vin-supply = <&vmain>; regulator-name = "smps45"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; @@ -92,7 +112,6 @@
smps6_reg: smps6 { /* VDD_GPU */ - vin-supply = <&vmain>; regulator-name = "smps6"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1250000>; @@ -102,7 +121,6 @@
smps7_reg: smps7 { /* VDD_CORE */ - vin-supply = <&vmain>; regulator-name = "smps7"; regulator-min-microvolt = <850000>; regulator-max-microvolt = <1150000>; @@ -113,13 +131,11 @@ smps8_reg: smps8 { /* 5728 - VDD_IVAHD */ /* 5718 - N.C. test point */ - vin-supply = <&vmain>; regulator-name = "smps8"; };
smps9_reg: smps9 { /* VDD_3_3D */ - vin-supply = <&vmain>; regulator-name = "smps9"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -130,7 +146,6 @@ ldo1_reg: ldo1 { /* VDDSHV8 - VSDMMC */ /* NOTE: on rev 1.3a, data supply */ - vin-supply = <&vmain>; regulator-name = "ldo1"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>; @@ -140,7 +155,6 @@
ldo2_reg: ldo2 { /* VDDSH18V */ - vin-supply = <&vmain>; regulator-name = "ldo2"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -150,7 +164,6 @@
ldo3_reg: ldo3 { /* R1.3a 572x V1_8PHY_LDO3: USB, SATA */ - vin-supply = <&vmain>; regulator-name = "ldo3"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -160,7 +173,6 @@
ldo4_reg: ldo4 { /* R1.3a 572x V1_8PHY_LDO4: PCIE, HDMI*/ - vin-supply = <&vmain>; regulator-name = "ldo4"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -172,7 +184,6 @@
ldo9_reg: ldo9 { /* VDD_RTC */ - vin-supply = <&vmain>; regulator-name = "ldo9"; regulator-min-microvolt = <840000>; regulator-max-microvolt = <1160000>; @@ -182,7 +193,6 @@
ldoln_reg: ldoln { /* VDDA_1V8_PLL */ - vin-supply = <&vmain>; regulator-name = "ldoln"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -192,7 +202,6 @@
ldousb_reg: ldousb { /* VDDA_3V_USB: VDDA_USBHS33 */ - vin-supply = <&vmain>; regulator-name = "ldousb"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -202,7 +211,6 @@
ldortc_reg: ldortc { /* VDDA_RTC */ - vin-supply = <&vmain>; regulator-name = "ldortc"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; @@ -306,7 +314,7 @@
spi-max-frequency = <76800000>; m25p80@0 { - compatible = "s25fl256s1","spi-flash"; + compatible = "s25fl256s1", "spi-flash", "jedec,spi-nor"; spi-max-frequency = <76800000>; reg = <0>; spi-tx-bus-width = <1>; diff --git a/arch/arm/dts/am57xx-industrial-grade.dtsi b/arch/arm/dts/am57xx-industrial-grade.dtsi new file mode 100644 index 0000000..70c8c4b --- /dev/null +++ b/arch/arm/dts/am57xx-industrial-grade.dtsi @@ -0,0 +1,23 @@ +&cpu_alert0 { + temperature = <90000>; /* milliCelsius */ +}; + +&cpu_crit { + temperature = <105000>; /* milliCelsius */ +}; + +&gpu_crit { + temperature = <105000>; /* milliCelsius */ +}; + +&core_crit { + temperature = <105000>; /* milliCelsius */ +}; + +&dspeve_crit { + temperature = <105000>; /* milliCelsius */ +}; + +&iva_crit { + temperature = <105000>; /* milliCelsius */ +};
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
This breaks building of am57xx_evm for me: https://travis-ci.org/trini/u-boot/jobs/180810977
I do not see this error on am57xx_evm. This series depends on dra71-evm series posted previously[1]. Is it applied? I am sorry if I missed mentioning it in cover letter.
[1] https://www.mail-archive.com/u-boot@lists.denx.de/msg231689.html
Thanks and regards, Lokesh
OK, I'll re-apply them in that order and see if that solves the problem, thanks.
AM57xx evm Rev A3 with SR2.0 platform have incompatible changes for HDMI GPIO requiring new dtb support. This implies we have to properly identify the platform now as well. Hence provide a different board name for the Rev A3 variations.
Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am57xx/board.c | 17 ++++++++++++----- include/configs/ti_omap5_common.h | 2 ++ 2 files changed, 14 insertions(+), 5 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 7aee28e..bf092e7 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -36,6 +36,9 @@
#define board_is_x15() board_ti_is("BBRDX15_") #define board_is_am572x_evm() board_ti_is("AM572PM_") +#define board_is_am572x_evm_reva3() \ + (board_ti_is("AM572PM_") && \ + (strncmp("A.30", board_ti_get_rev(), 3) <= 0)) #define board_is_am572x_idk() board_ti_is("AM572IDK")
#ifdef CONFIG_DRIVER_TI_CPSW @@ -390,15 +393,19 @@ static void setup_board_eeprom_env(void) if (rc) goto invalid_eeprom;
- if (board_is_x15()) + if (board_is_x15()) { name = "beagle_x15"; - else if (board_is_am572x_evm()) - name = "am57xx_evm"; - else if (board_is_am572x_idk()) + } else if (board_is_am572x_evm()) { + if (board_is_am572x_evm_reva3()) + name = "am57xx_evm_reva3"; + else + name = "am57xx_evm"; + } else if (board_is_am572x_idk()) { name = "am572x_idk"; - else + } else { printf("Unidentified board claims %s in eeprom header\n", board_ti_get_name()); + }
invalid_eeprom: set_board_info_env(name); diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 3bc7bf9..51608d2 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -106,6 +106,8 @@ "setenv fdtfile am572x-idk.dtb; fi;" \ "if test $board_name = am57xx_evm; then " \ "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ + "if test $board_name = am57xx_evm_reva3; then " \ + "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ "if test $fdtfile = undefined; then " \ "echo WARNING: Could not determine device tree to use; fi; \0" \ "loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile};\0" \
Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
BeagleBoard-X15 Rev B1 with SR1.1 platform have incompatible changes for HDMI GPIO requiring new dtb support. This implies we have to properly identify the platform now as well. Hence provide a different board name for the Rev B1 variants.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am57xx/board.c | 26 +++++++++++++++++++------- configs/am57xx_evm_defconfig | 2 +- include/configs/ti_omap5_common.h | 2 ++ 3 files changed, 22 insertions(+), 8 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index bf092e7..ef3940b 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -35,6 +35,8 @@ #include "mux_data.h"
#define board_is_x15() board_ti_is("BBRDX15_") +#define board_is_x15_revb1() (board_ti_is("BBRDX15_") && \ + (strncmp("B.10", board_ti_get_rev(), 3) <= 0)) #define board_is_am572x_evm() board_ti_is("AM572PM_") #define board_is_am572x_evm_reva3() \ (board_ti_is("AM572PM_") && \ @@ -394,7 +396,10 @@ static void setup_board_eeprom_env(void) goto invalid_eeprom;
if (board_is_x15()) { - name = "beagle_x15"; + if (board_is_x15_revb1()) + name = "beagle_x15_revb1"; + else + name = "beagle_x15"; } else if (board_is_am572x_evm()) { if (board_is_am572x_evm_reva3()) name = "am57xx_evm_reva3"; @@ -782,14 +787,21 @@ int ft_board_setup(void *blob, bd_t *bd) #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { - if (board_is_x15() && !strcmp(name, "am57xx-beagle-x15")) - return 0; - else if (board_is_am572x_evm() && !strcmp(name, "am57xx-beagle-x15")) + if (board_is_x15()) { + if (board_is_x15_revb1()) { + if (!strcmp(name, "am57xx-beagle-x15-revb1")) + return 0; + } else if (!strcmp(name, "am57xx-beagle-x15")) { + return 0; + } + } else if (board_is_am572x_evm() && + !strcmp(name, "am57xx-beagle-x15")) { return 0; - else if (board_is_am572x_idk() && !strcmp(name, "am572x-idk")) + } else if (board_is_am572x_idk() && !strcmp(name, "am572x-idk")) { return 0; - else - return -1; + } + + return -1; } #endif
diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 12d9a14..bffa47c 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -47,7 +47,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="am57xx-beagle-x15 am572x-idk" +CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am572x-idk" CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 51608d2..540bde8 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -102,6 +102,8 @@ "setenv fdtfile dra71-evm.dtb; fi;" \ "if test $board_name = beagle_x15; then " \ "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ + "if test $board_name = beagle_x15_revb1; then " \ + "setenv fdtfile am57xx-beagle-x15-revb1.dtb; fi;" \ "if test $board_name = am572x_idk; then " \ "setenv fdtfile am572x-idk.dtb; fi;" \ "if test $board_name = am57xx_evm; then " \
Update the timing for RGMII0 interface based on PCT_DRA75x_DRA74x_SR1.1_v1.3.10 version (Jan 2016). This update is for SR1.1
Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am57xx/mux_data.h | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/board/ti/am57xx/mux_data.h b/board/ti/am57xx/mux_data.h index b5ea8ad..424c6c7 100644 --- a/board/ti/am57xx/mux_data.h +++ b/board/ti/am57xx/mux_data.h @@ -524,11 +524,11 @@ const struct iodelay_cfg_entry iodelay_cfg_array_x15[] = { {0x0720, 0, 1614}, /* CFG_RGMII0_RXD2_IN */ {0x072C, 105, 1673}, /* CFG_RGMII0_RXD3_IN */ {0x0740, 531, 120}, /* CFG_RGMII0_TXC_OUT */ - {0x074C, 11, 60}, /* CFG_RGMII0_TXCTL_OUT */ - {0x0758, 7, 120}, /* CFG_RGMII0_TXD0_OUT */ - {0x0764, 0, 0}, /* CFG_RGMII0_TXD1_OUT */ - {0x0770, 276, 120}, /* CFG_RGMII0_TXD2_OUT */ - {0x077C, 440, 120}, /* CFG_RGMII0_TXD3_OUT */ + {0x074C, 201, 60}, /* CFG_RGMII0_TXCTL_OUT */ + {0x0758, 229, 120}, /* CFG_RGMII0_TXD0_OUT */ + {0x0764, 141, 0}, /* CFG_RGMII0_TXD1_OUT */ + {0x0770, 495, 120}, /* CFG_RGMII0_TXD2_OUT */ + {0x077C, 660, 120}, /* CFG_RGMII0_TXD3_OUT */ {0x0A70, 1551, 115}, /* CFG_VIN2A_D12_OUT */ {0x0A7C, 816, 0}, /* CFG_VIN2A_D13_OUT */ {0x0A88, 876, 0}, /* CFG_VIN2A_D14_OUT */
Update the board pinmux for AM572x-IDK board using latest PMT[1] and the board files named am572x_gp_evm_A3a_sr2p0 that were autogenerated on 19th October, 2016 by "Ahmad Rasheda-rashed@ti.com".
[1] https://dev.ti.com/pinmux/app.html#/default/
Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/arch-omap5/mux_dra7xx.h | 2 +- board/ti/am57xx/board.c | 38 ++- board/ti/am57xx/mux_data.h | 359 +++++++++++++++++---------- 3 files changed, 261 insertions(+), 138 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap5/mux_dra7xx.h b/arch/arm/include/asm/arch-omap5/mux_dra7xx.h index 2115abb..5eed98c 100644 --- a/arch/arm/include/asm/arch-omap5/mux_dra7xx.h +++ b/arch/arm/include/asm/arch-omap5/mux_dra7xx.h @@ -362,7 +362,7 @@ #define EMU3 0x454 #define EMU4 0x458 #define RESETN 0x45C -#define NMIN 0x460 +#define NMIN_DSP 0x460 #define RSTOUTN 0x464
#endif /* _MUX_DRA7XX_H_ */ diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index ef3940b..f6a4314 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -465,6 +465,7 @@ void recalibrate_iodelay(void) const struct pad_conf_entry *pconf; const struct iodelay_cfg_entry *iod; int pconf_sz, iod_sz; + int ret;
if (board_is_am572x_idk()) { pconf = core_padconf_array_essential_am572x_idk; @@ -475,11 +476,42 @@ void recalibrate_iodelay(void) /* Common for X15/GPEVM */ pconf = core_padconf_array_essential_x15; pconf_sz = ARRAY_SIZE(core_padconf_array_essential_x15); - iod = iodelay_cfg_array_x15; - iod_sz = ARRAY_SIZE(iodelay_cfg_array_x15); + /* There never was an SR1.0 X15.. So.. */ + if (omap_revision() == DRA752_ES1_1) { + iod = iodelay_cfg_array_x15_sr1_1; + iod_sz = ARRAY_SIZE(iodelay_cfg_array_x15_sr1_1); + } else { + /* Since full production should switch to SR2.0 */ + iod = iodelay_cfg_array_x15_sr2_0; + iod_sz = ARRAY_SIZE(iodelay_cfg_array_x15_sr2_0); + } + } + + /* Setup I/O isolation */ + ret = __recalibrate_iodelay_start(); + if (ret) + goto err; + + /* Do the muxing here */ + do_set_mux32((*ctrl)->control_padconf_core_base, pconf, pconf_sz); + + /* Now do the weird minor deltas that should be safe */ + if (board_is_x15() || board_is_am572x_evm()) { + if (board_is_x15_revb1() || board_is_am572x_evm_reva3()) { + pconf = core_padconf_array_delta_x15_sr2_0; + pconf_sz = ARRAY_SIZE(core_padconf_array_delta_x15_sr2_0); + } else { + pconf = core_padconf_array_delta_x15_sr1_1; + pconf_sz = ARRAY_SIZE(core_padconf_array_delta_x15_sr1_1); + } + do_set_mux32((*ctrl)->control_padconf_core_base, pconf, pconf_sz); }
- __recalibrate_iodelay(pconf, pconf_sz, iod, iod_sz); + /* Setup IOdelay configuration */ + ret = do_set_iodelay((*ctrl)->iodelay_config_base, iod, iod_sz); +err: + /* Closeup.. remove isolation */ + __recalibrate_iodelay_end(ret); } #endif
diff --git a/board/ti/am57xx/mux_data.h b/board/ti/am57xx/mux_data.h index 424c6c7..0e347d7 100644 --- a/board/ti/am57xx/mux_data.h +++ b/board/ti/am57xx/mux_data.h @@ -13,22 +13,22 @@ #include <asm/arch/mux_dra7xx.h>
const struct pad_conf_entry core_padconf_array_essential_x15[] = { - {GPMC_AD0, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad0.vin3a_d0 */ - {GPMC_AD1, (M2 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_ad1.vin3a_d1 */ - {GPMC_AD2, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad2.vin3a_d2 */ - {GPMC_AD3, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad3.vin3a_d3 */ - {GPMC_AD4, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad4.vin3a_d4 */ - {GPMC_AD5, (M2 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_ad5.vin3a_d5 */ - {GPMC_AD6, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad6.vin3a_d6 */ - {GPMC_AD7, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad7.vin3a_d7 */ - {GPMC_AD8, (M2 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_ad8.vin3a_d8 */ - {GPMC_AD9, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad9.vin3a_d9 */ - {GPMC_AD10, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad10.vin3a_d10 */ - {GPMC_AD11, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad11.vin3a_d11 */ - {GPMC_AD12, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad12.vin3a_d12 */ - {GPMC_AD13, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad13.vin3a_d13 */ - {GPMC_AD14, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_ad14.vin3a_d14 */ - {GPMC_AD15, (M2 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_ad15.vin3a_d15 */ + {GPMC_AD0, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad0.vin3a_d0 */ + {GPMC_AD1, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad1.vin3a_d1 */ + {GPMC_AD2, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad2.vin3a_d2 */ + {GPMC_AD3, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad3.vin3a_d3 */ + {GPMC_AD4, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad4.vin3a_d4 */ + {GPMC_AD5, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad5.vin3a_d5 */ + {GPMC_AD6, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad6.vin3a_d6 */ + {GPMC_AD7, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad7.vin3a_d7 */ + {GPMC_AD8, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad8.vin3a_d8 */ + {GPMC_AD9, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad9.vin3a_d9 */ + {GPMC_AD10, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad10.vin3a_d10 */ + {GPMC_AD11, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad11.vin3a_d11 */ + {GPMC_AD12, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad12.vin3a_d12 */ + {GPMC_AD13, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad13.vin3a_d13 */ + {GPMC_AD14, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad14.vin3a_d14 */ + {GPMC_AD15, (M2 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad15.vin3a_d15 */ {GPMC_A0, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a0.vin3a_d16 */ {GPMC_A1, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a1.vin3a_d17 */ {GPMC_A2, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a2.vin3a_d18 */ @@ -60,7 +60,7 @@ const struct pad_conf_entry core_padconf_array_essential_x15[] = { {GPMC_CS1, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_cs1.mmc2_cmd */ {GPMC_CS0, (M14 | PIN_INPUT_PULLDOWN)}, /* gpmc_cs0.gpio2_19 */ {GPMC_CS2, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_cs2.gpio2_20 */ - {GPMC_CS3, (M2 | PIN_INPUT_PULLDOWN)}, /* gpmc_cs3.vin3a_clk0 */ + {GPMC_CS3, (M2 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_cs3.vin3a_clk0 */ {GPMC_CLK, (M9 | PIN_INPUT_PULLDOWN)}, /* gpmc_clk.dma_evt1 */ {GPMC_ADVN_ALE, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_advn_ale.gpio2_23 */ {GPMC_OEN_REN, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_oen_ren.gpio2_24 */ @@ -68,7 +68,7 @@ const struct pad_conf_entry core_padconf_array_essential_x15[] = { {GPMC_BEN0, (M9 | PIN_INPUT_PULLDOWN)}, /* gpmc_ben0.dma_evt3 */ {GPMC_BEN1, (M9 | PIN_INPUT_PULLDOWN)}, /* gpmc_ben1.dma_evt4 */ {GPMC_WAIT0, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_wait0.gpio2_28 */ - {VIN1B_CLK1, (M14 | PIN_INPUT_SLEW)}, /* vin1b_clk1.gpio2_31 */ + {VIN1B_CLK1, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1b_clk1.gpio2_31 */ {VIN1A_D2, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d2.gpio3_6 */ {VIN1A_D3, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d3.gpio3_7 */ {VIN1A_D4, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d4.gpio3_8 */ @@ -83,120 +83,119 @@ const struct pad_conf_entry core_padconf_array_essential_x15[] = { {VIN1A_D16, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d16.gpio3_20 */ {VIN1A_D19, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d19.gpio3_23 */ {VIN1A_D20, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d20.gpio3_24 */ - {VIN1A_D21, (M0 | PIN_INPUT_PULLDOWN)}, /* vin1a_d21.vin1a_d21 */ {VIN1A_D22, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d22.gpio3_26 */ {VIN2A_CLK0, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_clk0.gpio3_28 */ {VIN2A_DE0, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_de0.gpio3_29 */ {VIN2A_FLD0, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_fld0.gpio3_30 */ {VIN2A_HSYNC0, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_hsync0.pr1_uart0_cts_n */ - {VIN2A_VSYNC0, (M11 | PIN_INPUT_PULLUP)}, /* vin2a_vsync0.pr1_uart0_rts_n */ + {VIN2A_VSYNC0, (M11 | PIN_OUTPUT_PULLUP)}, /* vin2a_vsync0.pr1_uart0_rts_n */ {VIN2A_D0, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d0.pr1_uart0_rxd */ - {VIN2A_D1, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d1.pr1_uart0_txd */ + {VIN2A_D1, (M11 | PIN_OUTPUT_PULLDOWN)}, /* vin2a_d1.pr1_uart0_txd */ {VIN2A_D2, (M8 | PIN_INPUT_PULLDOWN)}, /* vin2a_d2.uart10_rxd */ - {VIN2A_D3, (M8 | PIN_INPUT_PULLDOWN)}, /* vin2a_d3.uart10_txd */ + {VIN2A_D3, (M8 | PIN_OUTPUT_PULLDOWN)}, /* vin2a_d3.uart10_txd */ {VIN2A_D4, (M8 | PIN_INPUT_PULLDOWN)}, /* vin2a_d4.uart10_ctsn */ - {VIN2A_D5, (M8 | PIN_INPUT_PULLDOWN)}, /* vin2a_d5.uart10_rtsn */ + {VIN2A_D5, (M8 | PIN_OUTPUT_PULLDOWN)}, /* vin2a_d5.uart10_rtsn */ {VIN2A_D6, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_d6.gpio4_7 */ {VIN2A_D7, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_d7.gpio4_8 */ {VIN2A_D8, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_d8.gpio4_9 */ {VIN2A_D9, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_d9.gpio4_10 */ - {VIN2A_D10, (M10 | PIN_INPUT_PULLDOWN)}, /* vin2a_d10.ehrpwm2B */ + {VIN2A_D10, (M10 | PIN_OUTPUT_PULLDOWN)}, /* vin2a_d10.ehrpwm2B */ {VIN2A_D11, (M10 | PIN_INPUT_PULLDOWN)}, /* vin2a_d11.ehrpwm2_tripzone_input */ - {VIN2A_D12, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d12.rgmii1_txc */ - {VIN2A_D13, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d13.rgmii1_txctl */ - {VIN2A_D14, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d14.rgmii1_txd3 */ - {VIN2A_D15, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d15.rgmii1_txd2 */ - {VIN2A_D16, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d16.rgmii1_txd1 */ - {VIN2A_D17, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d17.rgmii1_txd0 */ - {VIN2A_D18, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d18.rgmii1_rxc */ - {VIN2A_D19, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d19.rgmii1_rxctl */ - {VIN2A_D20, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d20.rgmii1_rxd3 */ - {VIN2A_D21, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d21.rgmii1_rxd2 */ - {VIN2A_D22, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d22.rgmii1_rxd1 */ - {VIN2A_D23, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d23.rgmii1_rxd0 */ - {VOUT1_CLK, (M0 | PIN_OUTPUT)}, /* vout1_clk.vout1_clk */ - {VOUT1_DE, (M0 | PIN_OUTPUT)}, /* vout1_de.vout1_de */ - {VOUT1_FLD, (M14 | PIN_INPUT)}, /* vout1_fld.gpio4_21 */ + {VIN2A_D12, (M3 | PIN_OUTPUT | MANUAL_MODE)}, /* vin2a_d12.rgmii1_txc */ + {VIN2A_D13, (M3 | PIN_OUTPUT | MANUAL_MODE)}, /* vin2a_d13.rgmii1_txctl */ + {VIN2A_D14, (M3 | PIN_OUTPUT | MANUAL_MODE)}, /* vin2a_d14.rgmii1_txd3 */ + {VIN2A_D15, (M3 | PIN_OUTPUT | MANUAL_MODE)}, /* vin2a_d15.rgmii1_txd2 */ + {VIN2A_D16, (M3 | PIN_OUTPUT | MANUAL_MODE)}, /* vin2a_d16.rgmii1_txd1 */ + {VIN2A_D17, (M3 | PIN_OUTPUT | MANUAL_MODE)}, /* vin2a_d17.rgmii1_txd0 */ + {VIN2A_D18, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d18.rgmii1_rxc */ + {VIN2A_D19, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d19.rgmii1_rxctl */ + {VIN2A_D20, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d20.rgmii1_rxd3 */ + {VIN2A_D21, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d21.rgmii1_rxd2 */ + {VIN2A_D22, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d22.rgmii1_rxd1 */ + {VIN2A_D23, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d23.rgmii1_rxd0 */ + {VOUT1_CLK, (M0 | PIN_OUTPUT)}, /* vout1_clk.vout1_clk */ + {VOUT1_DE, (M0 | PIN_OUTPUT)}, /* vout1_de.vout1_de */ + {VOUT1_FLD, (M14 | PIN_INPUT)}, /* vout1_fld.gpio4_21 */ {VOUT1_HSYNC, (M0 | PIN_OUTPUT)}, /* vout1_hsync.vout1_hsync */ {VOUT1_VSYNC, (M0 | PIN_OUTPUT)}, /* vout1_vsync.vout1_vsync */ - {VOUT1_D0, (M0 | PIN_OUTPUT)}, /* vout1_d0.vout1_d0 */ - {VOUT1_D1, (M0 | PIN_OUTPUT)}, /* vout1_d1.vout1_d1 */ - {VOUT1_D2, (M0 | PIN_OUTPUT)}, /* vout1_d2.vout1_d2 */ - {VOUT1_D3, (M0 | PIN_OUTPUT)}, /* vout1_d3.vout1_d3 */ - {VOUT1_D4, (M0 | PIN_OUTPUT)}, /* vout1_d4.vout1_d4 */ - {VOUT1_D5, (M0 | PIN_OUTPUT)}, /* vout1_d5.vout1_d5 */ - {VOUT1_D6, (M0 | PIN_OUTPUT)}, /* vout1_d6.vout1_d6 */ - {VOUT1_D7, (M0 | PIN_OUTPUT)}, /* vout1_d7.vout1_d7 */ - {VOUT1_D8, (M0 | PIN_OUTPUT)}, /* vout1_d8.vout1_d8 */ - {VOUT1_D9, (M0 | PIN_OUTPUT)}, /* vout1_d9.vout1_d9 */ - {VOUT1_D10, (M0 | PIN_OUTPUT)}, /* vout1_d10.vout1_d10 */ - {VOUT1_D11, (M0 | PIN_OUTPUT)}, /* vout1_d11.vout1_d11 */ - {VOUT1_D12, (M0 | PIN_OUTPUT)}, /* vout1_d12.vout1_d12 */ - {VOUT1_D13, (M0 | PIN_OUTPUT)}, /* vout1_d13.vout1_d13 */ - {VOUT1_D14, (M0 | PIN_OUTPUT)}, /* vout1_d14.vout1_d14 */ - {VOUT1_D15, (M0 | PIN_OUTPUT)}, /* vout1_d15.vout1_d15 */ - {VOUT1_D16, (M0 | PIN_OUTPUT)}, /* vout1_d16.vout1_d16 */ - {VOUT1_D17, (M0 | PIN_OUTPUT)}, /* vout1_d17.vout1_d17 */ - {VOUT1_D18, (M0 | PIN_OUTPUT)}, /* vout1_d18.vout1_d18 */ - {VOUT1_D19, (M0 | PIN_OUTPUT)}, /* vout1_d19.vout1_d19 */ - {VOUT1_D20, (M0 | PIN_OUTPUT)}, /* vout1_d20.vout1_d20 */ - {VOUT1_D21, (M0 | PIN_OUTPUT)}, /* vout1_d21.vout1_d21 */ - {VOUT1_D22, (M0 | PIN_OUTPUT)}, /* vout1_d22.vout1_d22 */ - {VOUT1_D23, (M0 | PIN_OUTPUT)}, /* vout1_d23.vout1_d23 */ - {MDIO_MCLK, (M0 | PIN_INPUT_PULLUP)}, /* mdio_mclk.mdio_mclk */ - {MDIO_D, (M0 | PIN_INPUT_PULLUP)}, /* mdio_d.mdio_d */ + {VOUT1_D0, (M0 | PIN_OUTPUT)}, /* vout1_d0.vout1_d0 */ + {VOUT1_D1, (M0 | PIN_OUTPUT)}, /* vout1_d1.vout1_d1 */ + {VOUT1_D2, (M0 | PIN_OUTPUT)}, /* vout1_d2.vout1_d2 */ + {VOUT1_D3, (M0 | PIN_OUTPUT)}, /* vout1_d3.vout1_d3 */ + {VOUT1_D4, (M0 | PIN_OUTPUT)}, /* vout1_d4.vout1_d4 */ + {VOUT1_D5, (M0 | PIN_OUTPUT)}, /* vout1_d5.vout1_d5 */ + {VOUT1_D6, (M0 | PIN_OUTPUT)}, /* vout1_d6.vout1_d6 */ + {VOUT1_D7, (M0 | PIN_OUTPUT)}, /* vout1_d7.vout1_d7 */ + {VOUT1_D8, (M0 | PIN_OUTPUT)}, /* vout1_d8.vout1_d8 */ + {VOUT1_D9, (M0 | PIN_OUTPUT)}, /* vout1_d9.vout1_d9 */ + {VOUT1_D10, (M0 | PIN_OUTPUT)}, /* vout1_d10.vout1_d10 */ + {VOUT1_D11, (M0 | PIN_OUTPUT)}, /* vout1_d11.vout1_d11 */ + {VOUT1_D12, (M0 | PIN_OUTPUT)}, /* vout1_d12.vout1_d12 */ + {VOUT1_D13, (M0 | PIN_OUTPUT)}, /* vout1_d13.vout1_d13 */ + {VOUT1_D14, (M0 | PIN_OUTPUT)}, /* vout1_d14.vout1_d14 */ + {VOUT1_D15, (M0 | PIN_OUTPUT)}, /* vout1_d15.vout1_d15 */ + {VOUT1_D16, (M0 | PIN_OUTPUT)}, /* vout1_d16.vout1_d16 */ + {VOUT1_D17, (M0 | PIN_OUTPUT)}, /* vout1_d17.vout1_d17 */ + {VOUT1_D18, (M0 | PIN_OUTPUT)}, /* vout1_d18.vout1_d18 */ + {VOUT1_D19, (M0 | PIN_OUTPUT)}, /* vout1_d19.vout1_d19 */ + {VOUT1_D20, (M0 | PIN_OUTPUT)}, /* vout1_d20.vout1_d20 */ + {VOUT1_D21, (M0 | PIN_OUTPUT)}, /* vout1_d21.vout1_d21 */ + {VOUT1_D22, (M0 | PIN_OUTPUT)}, /* vout1_d22.vout1_d22 */ + {VOUT1_D23, (M0 | PIN_OUTPUT)}, /* vout1_d23.vout1_d23 */ + {MDIO_MCLK, (M0 | PIN_OUTPUT)}, /* mdio_mclk.mdio_mclk */ + {MDIO_D, (M0 | PIN_INPUT)}, /* mdio_d.mdio_d */ {RMII_MHZ_50_CLK, (M14 | PIN_INPUT_PULLUP)}, /* RMII_MHZ_50_CLK.gpio5_17 */ {UART3_RXD, (M14 | PIN_INPUT_PULLDOWN)}, /* uart3_rxd.gpio5_18 */ {UART3_TXD, (M14 | PIN_INPUT_PULLDOWN)}, /* uart3_txd.gpio5_19 */ - {RGMII0_TXC, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txc.rgmii0_txc */ - {RGMII0_TXCTL, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txctl.rgmii0_txctl */ - {RGMII0_TXD3, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd3.rgmii0_txd3 */ - {RGMII0_TXD2, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd2.rgmii0_txd2 */ - {RGMII0_TXD1, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd1.rgmii0_txd1 */ - {RGMII0_TXD0, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd0.rgmii0_txd0 */ - {RGMII0_RXC, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxc.rgmii0_rxc */ - {RGMII0_RXCTL, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxctl.rgmii0_rxctl */ - {RGMII0_RXD3, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd3.rgmii0_rxd3 */ - {RGMII0_RXD2, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd2.rgmii0_rxd2 */ - {RGMII0_RXD1, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd1.rgmii0_rxd1 */ - {RGMII0_RXD0, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd0.rgmii0_rxd0 */ - {USB1_DRVVBUS, (M0 | PIN_INPUT_SLEW)}, /* usb1_drvvbus.usb1_drvvbus */ - {USB2_DRVVBUS, (M0 | PIN_INPUT_SLEW)}, /* usb2_drvvbus.usb2_drvvbus */ + {RGMII0_TXC, (M0 | PIN_OUTPUT | MANUAL_MODE)}, /* rgmii0_txc.rgmii0_txc */ + {RGMII0_TXCTL, (M0 | PIN_OUTPUT | MANUAL_MODE)}, /* rgmii0_txctl.rgmii0_txctl */ + {RGMII0_TXD3, (M0 | PIN_OUTPUT | MANUAL_MODE)}, /* rgmii0_txd3.rgmii0_txd3 */ + {RGMII0_TXD2, (M0 | PIN_OUTPUT | MANUAL_MODE)}, /* rgmii0_txd2.rgmii0_txd2 */ + {RGMII0_TXD1, (M0 | PIN_OUTPUT | MANUAL_MODE)}, /* rgmii0_txd1.rgmii0_txd1 */ + {RGMII0_TXD0, (M0 | PIN_OUTPUT | MANUAL_MODE)}, /* rgmii0_txd0.rgmii0_txd0 */ + {RGMII0_RXC, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxc.rgmii0_rxc */ + {RGMII0_RXCTL, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxctl.rgmii0_rxctl */ + {RGMII0_RXD3, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxd3.rgmii0_rxd3 */ + {RGMII0_RXD2, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxd2.rgmii0_rxd2 */ + {RGMII0_RXD1, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxd1.rgmii0_rxd1 */ + {RGMII0_RXD0, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxd0.rgmii0_rxd0 */ + {USB1_DRVVBUS, (M0 | PIN_OUTPUT)}, /* usb1_drvvbus.usb1_drvvbus */ + {USB2_DRVVBUS, (M0 | PIN_OUTPUT_PULLDOWN)}, /* usb2_drvvbus.usb2_drvvbus */ {GPIO6_14, (M10 | PIN_INPUT_PULLUP)}, /* gpio6_14.timer1 */ {GPIO6_15, (M10 | PIN_INPUT_PULLUP)}, /* gpio6_15.timer2 */ {GPIO6_16, (M10 | PIN_INPUT_PULLUP)}, /* gpio6_16.timer3 */ - {XREF_CLK0, (M9 | PIN_INPUT_PULLDOWN)}, /* xref_clk0.clkout2 */ + {XREF_CLK0, (M9 | PIN_OUTPUT_PULLDOWN)}, /* xref_clk0.clkout2 */ {XREF_CLK1, (M14 | PIN_INPUT_PULLDOWN)}, /* xref_clk1.gpio6_18 */ {XREF_CLK2, (M14 | PIN_INPUT_PULLDOWN)}, /* xref_clk2.gpio6_19 */ - {XREF_CLK3, (M9 | PIN_INPUT_PULLDOWN)}, /* xref_clk3.clkout3 */ + {XREF_CLK3, (M9 | PIN_OUTPUT_PULLDOWN)}, /* xref_clk3.clkout3 */ {MCASP1_ACLKX, (M10 | PIN_INPUT_PULLUP)}, /* mcasp1_aclkx.i2c3_sda */ {MCASP1_FSX, (M10 | PIN_INPUT_PULLUP)}, /* mcasp1_fsx.i2c3_scl */ {MCASP1_ACLKR, (M10 | PIN_INPUT_PULLUP)}, /* mcasp1_aclkr.i2c4_sda */ {MCASP1_FSR, (M10 | PIN_INPUT_PULLUP)}, /* mcasp1_fsr.i2c4_scl */ - {MCASP1_AXR0, (M10 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr0.i2c5_sda */ - {MCASP1_AXR1, (M10 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr1.i2c5_scl */ + {MCASP1_AXR0, (M10 | PIN_INPUT_PULLUP)}, /* mcasp1_axr0.i2c5_sda */ + {MCASP1_AXR1, (M10 | PIN_INPUT_PULLUP)}, /* mcasp1_axr1.i2c5_scl */ {MCASP1_AXR2, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr2.gpio5_4 */ {MCASP1_AXR3, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr3.gpio5_5 */ {MCASP1_AXR4, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr4.gpio5_6 */ {MCASP1_AXR5, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr5.gpio5_7 */ {MCASP1_AXR6, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr6.gpio5_8 */ {MCASP1_AXR7, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr7.gpio5_9 */ - {MCASP1_AXR8, (M14 | PIN_INPUT_SLEW)}, /* mcasp1_axr8.gpio5_10 */ - {MCASP1_AXR9, (M14 | PIN_INPUT_SLEW)}, /* mcasp1_axr9.gpio5_11 */ - {MCASP1_AXR10, (M14 | PIN_INPUT_SLEW)}, /* mcasp1_axr10.gpio5_12 */ - {MCASP1_AXR11, (M14 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr11.gpio4_17 */ - {MCASP1_AXR12, (M1 | PIN_INPUT_SLEW)}, /* mcasp1_axr12.mcasp7_axr0 */ - {MCASP1_AXR13, (M1 | PIN_INPUT_SLEW)}, /* mcasp1_axr13.mcasp7_axr1 */ - {MCASP1_AXR14, (M1 | PIN_INPUT_SLEW)}, /* mcasp1_axr14.mcasp7_aclkx */ - {MCASP1_AXR15, (M1 | PIN_INPUT_SLEW)}, /* mcasp1_axr15.mcasp7_fsx */ + {MCASP1_AXR8, (M14 | PIN_INPUT)}, /* mcasp1_axr8.gpio5_10 */ + {MCASP1_AXR9, (M14 | PIN_INPUT)}, /* mcasp1_axr9.gpio5_11 */ + {MCASP1_AXR10, (M14 | PIN_INPUT)}, /* mcasp1_axr10.gpio5_12 */ + {MCASP1_AXR11, (M14 | PIN_INPUT_PULLUP)}, /* mcasp1_axr11.gpio4_17 */ + {MCASP1_AXR12, (M1 | PIN_INPUT | VIRTUAL_MODE10)}, /* mcasp1_axr12.mcasp7_axr0 */ + {MCASP1_AXR13, (M1 | PIN_INPUT | VIRTUAL_MODE10)}, /* mcasp1_axr13.mcasp7_axr1 */ + {MCASP1_AXR14, (M1 | PIN_INPUT | VIRTUAL_MODE10)}, /* mcasp1_axr14.mcasp7_aclkx */ + {MCASP1_AXR15, (M1 | PIN_INPUT | VIRTUAL_MODE10)}, /* mcasp1_axr15.mcasp7_fsx */ {MCASP2_ACLKX, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp2_aclkx.mcasp2_aclkx */ - {MCASP2_FSX, (M0 | PIN_INPUT_SLEW)}, /* mcasp2_fsx.mcasp2_fsx */ + {MCASP2_FSX, (M0 | PIN_INPUT)}, /* mcasp2_fsx.mcasp2_fsx */ {MCASP2_ACLKR, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp2_aclkr.mcasp2_aclkr */ {MCASP2_FSR, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp2_fsr.mcasp2_fsr */ {MCASP2_AXR0, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr0.mcasp2_axr0 */ {MCASP2_AXR1, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr1.mcasp2_axr1 */ - {MCASP2_AXR2, (M0 | PIN_INPUT_SLEW)}, /* mcasp2_axr2.mcasp2_axr2 */ - {MCASP2_AXR3, (M0 | PIN_INPUT_SLEW)}, /* mcasp2_axr3.mcasp2_axr3 */ + {MCASP2_AXR2, (M0 | PIN_INPUT)}, /* mcasp2_axr2.mcasp2_axr2 */ + {MCASP2_AXR3, (M0 | PIN_INPUT)}, /* mcasp2_axr3.mcasp2_axr3 */ {MCASP2_AXR4, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr4.mcasp2_axr4 */ {MCASP2_AXR5, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr5.mcasp2_axr5 */ {MCASP2_AXR6, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr6.mcasp2_axr6 */ @@ -205,63 +204,82 @@ const struct pad_conf_entry core_padconf_array_essential_x15[] = { {MCASP3_FSX, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp3_fsx.mcasp3_fsx */ {MCASP3_AXR0, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp3_axr0.mcasp3_axr0 */ {MCASP3_AXR1, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp3_axr1.mcasp3_axr1 */ - {MCASP4_ACLKX, (M3 | PIN_INPUT_PULLDOWN)}, /* mcasp4_aclkx.uart8_rxd */ - {MCASP4_FSX, (M3 | PIN_INPUT_PULLDOWN)}, /* mcasp4_fsx.uart8_txd */ + {MCASP4_ACLKX, (M3 | PIN_INPUT_PULLUP)}, /* mcasp4_aclkx.uart8_rxd */ + {MCASP4_FSX, (M3 | PIN_OUTPUT_PULLDOWN)}, /* mcasp4_fsx.uart8_txd */ {MCASP4_AXR0, (M3 | PIN_INPUT_PULLDOWN)}, /* mcasp4_axr0.uart8_ctsn */ - {MCASP4_AXR1, (M3 | PIN_INPUT_PULLUP)}, /* mcasp4_axr1.uart8_rtsn */ - {MCASP5_ACLKX, (M3 | PIN_INPUT_PULLDOWN)}, /* mcasp5_aclkx.uart9_rxd */ - {MCASP5_FSX, (M3 | PIN_INPUT_PULLDOWN)}, /* mcasp5_fsx.uart9_txd */ + {MCASP4_AXR1, (M3 | PIN_OUTPUT_PULLUP)}, /* mcasp4_axr1.uart8_rtsn */ + {MCASP5_ACLKX, (M3 | PIN_INPUT_PULLUP)}, /* mcasp5_aclkx.uart9_rxd */ + {MCASP5_FSX, (M3 | PIN_OUTPUT_PULLDOWN)}, /* mcasp5_fsx.uart9_txd */ {MCASP5_AXR0, (M3 | PIN_INPUT_PULLDOWN)}, /* mcasp5_axr0.uart9_ctsn */ - {MCASP5_AXR1, (M3 | PIN_INPUT_PULLUP)}, /* mcasp5_axr1.uart9_rtsn */ - {MMC1_CLK, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_clk.mmc1_clk */ + {MCASP5_AXR1, (M3 | PIN_OUTPUT_PULLUP)}, /* mcasp5_axr1.uart9_rtsn */ + {MMC1_CLK, (M0 | PIN_OUTPUT_PULLUP)}, /* mmc1_clk.mmc1_clk */ {MMC1_CMD, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_cmd.mmc1_cmd */ {MMC1_DAT0, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat0.mmc1_dat0 */ {MMC1_DAT1, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat1.mmc1_dat1 */ {MMC1_DAT2, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat2.mmc1_dat2 */ {MMC1_DAT3, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat3.mmc1_dat3 */ - {MMC1_SDCD, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_sdcd.mmc1_sdcd */ - {MMC1_SDWP, (M14 | PIN_OUTPUT)}, /* mmc1_sdwp.gpio6_28 */ - {GPIO6_10, (M10 | PIN_INPUT_PULLDOWN)}, /* gpio6_10.ehrpwm2A */ - {GPIO6_11, (M14 | PIN_INPUT_PULLUP)}, /* gpio6_11.gpio6_11 */ - {MMC3_CLK, (M0 | PIN_INPUT_PULLUP)}, /* mmc3_clk.mmc3_clk */ - {MMC3_CMD, (M0 | PIN_INPUT_PULLUP)}, /* mmc3_cmd.mmc3_cmd */ - {MMC3_DAT0, (M0 | PIN_INPUT_PULLUP)}, /* mmc3_dat0.mmc3_dat0 */ - {MMC3_DAT1, (M0 | PIN_INPUT_PULLUP)}, /* mmc3_dat1.mmc3_dat1 */ - {MMC3_DAT2, (M0 | PIN_INPUT_PULLUP)}, /* mmc3_dat2.mmc3_dat2 */ - {MMC3_DAT3, (M0 | PIN_INPUT_PULLUP)}, /* mmc3_dat3.mmc3_dat3 */ - {MMC3_DAT4, (M1 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat4.spi4_sclk */ + {MMC1_SDCD, (M14 | PIN_INPUT_PULLUP)}, /* mmc1_sdcd.gpio6_27 */ + {GPIO6_10, (M10 | PIN_OUTPUT_PULLDOWN)}, /* gpio6_10.ehrpwm2A */ + {GPIO6_11, (M0 | PIN_INPUT_PULLUP)}, /* gpio6_11.gpio6_11 */ + {MMC3_CLK, (M0 | PIN_OUTPUT_PULLUP | MANUAL_MODE)}, /* mmc3_clk.mmc3_clk */ + {MMC3_CMD, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* mmc3_cmd.mmc3_cmd */ + {MMC3_DAT0, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* mmc3_dat0.mmc3_dat0 */ + {MMC3_DAT1, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* mmc3_dat1.mmc3_dat1 */ + {MMC3_DAT2, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* mmc3_dat2.mmc3_dat2 */ + {MMC3_DAT3, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* mmc3_dat3.mmc3_dat3 */ + {MMC3_DAT4, (M1 | PIN_OUTPUT_PULLDOWN)}, /* mmc3_dat4.spi4_sclk */ {MMC3_DAT5, (M1 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat5.spi4_d1 */ {MMC3_DAT6, (M1 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat6.spi4_d0 */ - {MMC3_DAT7, (M1 | PIN_INPUT_PULLUP)}, /* mmc3_dat7.spi4_cs0 */ + {MMC3_DAT7, (M1 | PIN_OUTPUT_PULLUP)}, /* mmc3_dat7.spi4_cs0 */ {SPI1_SCLK, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_sclk.gpio7_7 */ {SPI1_D1, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_d1.gpio7_8 */ {SPI1_D0, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_d0.gpio7_9 */ - {SPI1_CS0, (M14 | PIN_OUTPUT)}, /* spi1_cs0.gpio7_10 */ - {SPI1_CS1, (M14 | PIN_OUTPUT_PULLUP)}, /* spi1_cs1.gpio7_11 */ + {SPI1_CS0, (M14 | PIN_INPUT)}, /* spi1_cs0.gpio7_10 */ + {SPI1_CS1, (M14 | PIN_INPUT)}, /* spi1_cs1.gpio7_11 */ {SPI1_CS2, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_cs2.gpio7_12 */ - {SPI1_CS3, (M6 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* spi1_cs3.hdmi1_cec */ + {SPI1_CS3, (M6 | PIN_INPUT_PULLUP)}, /* spi1_cs3.hdmi1_cec */ {SPI2_SCLK, (M14 | PIN_INPUT_PULLDOWN)}, /* spi2_sclk.gpio7_14 */ {SPI2_D1, (M14 | PIN_INPUT_PULLDOWN)}, /* spi2_d1.gpio7_15 */ {SPI2_D0, (M14 | PIN_INPUT_PULLUP)}, /* spi2_d0.gpio7_16 */ - {SPI2_CS0, (M14 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* spi2_cs0.gpio7_17 */ + {SPI2_CS0, (M14 | PIN_INPUT_PULLUP)}, /* spi2_cs0.gpio7_17 */ {DCAN1_TX, (M15 | PULL_UP)}, /* dcan1_tx.safe for dcan1_tx */ {DCAN1_RX, (M15 | PULL_UP)}, /* dcan1_rx.safe for dcan1_rx */ - {UART1_RXD, (M0 | PIN_INPUT_SLEW)}, /* uart1_rxd.uart1_rxd */ - {UART1_TXD, (M0 | PIN_INPUT_SLEW)}, /* uart1_txd.uart1_txd */ - {UART1_CTSN, (M15 | PIN_INPUT_PULLDOWN)}, /* uart1_ctsn.Driveroff */ - {UART2_RXD, (M15 | PIN_INPUT_PULLDOWN)}, /* N/A.Driveroff */ - {UART2_TXD, (M15 | PIN_INPUT_PULLDOWN)}, /* uart2_txd.Driveroff */ - {UART2_CTSN, (M2 | PIN_INPUT_SLEW)}, /* uart2_ctsn.uart3_rxd */ - {UART2_RTSN, (M1 | PIN_INPUT_SLEW)}, /* uart2_rtsn.uart3_txd */ - {I2C2_SDA, (M1 | PIN_INPUT)}, /* i2c2_sda.hdmi1_ddc_scl */ - {I2C2_SCL, (M1 | PIN_INPUT)}, /* i2c2_scl.hdmi1_ddc_sda */ - {WAKEUP0, (M0 | PULL_UP)}, /* Wakeup0.Wakeup0 */ - {WAKEUP1, (M0)}, /* Wakeup1.Wakeup1 */ - {WAKEUP2, (M0)}, /* Wakeup2.Wakeup2 */ - {WAKEUP3, (M0 | PULL_UP)}, /* Wakeup3.Wakeup3 */ - {ON_OFF, (M1 | PIN_OUTPUT_PULLUP)}, /* on_off.on_off */ - {RTC_PORZ, (M0 | PIN_OUTPUT_PULLDOWN)}, /* rtc_porz.rtc_porz */ - {RTCK, (M0 | PIN_INPUT_PULLDOWN)}, /* rtck.rtck */ + {UART1_RXD, (M0 | PIN_INPUT_PULLUP)}, /* uart1_rxd.uart1_rxd */ + {UART1_TXD, (M0 | PIN_OUTPUT_PULLDOWN)}, /* uart1_txd.uart1_txd */ + {UART1_CTSN, (M14 | PIN_INPUT_PULLDOWN)}, /* uart1_ctsn.gpio7_24 */ + {UART1_RTSN, (M14 | PIN_INPUT)}, /* uart1_rtsn.gpio7_25 */ + {UART2_RXD, (M14 | PIN_INPUT_PULLDOWN)}, /* uart2_rxd.gpio7_26 */ + {UART2_TXD, (M14 | PIN_INPUT_PULLDOWN)}, /* uart2_txd.gpio7_27 */ + {UART2_CTSN, (M2 | PIN_INPUT_PULLUP)}, /* uart2_ctsn.uart3_rxd */ + {UART2_RTSN, (M1 | PIN_OUTPUT_PULLDOWN)}, /* uart2_rtsn.uart3_txd */ + {I2C1_SDA, (M0 | PIN_INPUT_PULLUP)}, /* i2c1_sda.i2c1_sda */ + {I2C1_SCL, (M0 | PIN_INPUT_PULLUP)}, /* i2c1_scl.i2c1_scl */ + {I2C2_SDA, (M1 | PIN_INPUT_PULLUP)}, /* i2c2_sda.hdmi1_ddc_scl */ + {I2C2_SCL, (M1 | PIN_INPUT_PULLUP)}, /* i2c2_scl.hdmi1_ddc_sda */ + {WAKEUP0, (M0 | PIN_INPUT)}, /* Wakeup0.Wakeup0 */ + {WAKEUP1, (M0 | PIN_INPUT)}, /* Wakeup1.Wakeup1 */ + {WAKEUP2, (M0 | PIN_INPUT)}, /* Wakeup2.Wakeup2 */ + {WAKEUP3, (M0 | PIN_INPUT)}, /* Wakeup3.Wakeup3 */ + {ON_OFF, (M0 | PIN_OUTPUT)}, /* on_off.on_off */ + {RTC_PORZ, (M0 | PIN_INPUT)}, /* rtc_porz.rtc_porz */ + {TMS, (M0 | PIN_INPUT_PULLUP)}, /* tms.tms */ + {TDI, (M0 | PIN_INPUT_PULLUP)}, /* tdi.tdi */ + {TDO, (M0 | PIN_OUTPUT)}, /* tdo.tdo */ + {TCLK, (M0 | PIN_INPUT_PULLDOWN)}, /* tclk.tclk */ + {TRSTN, (M0 | PIN_INPUT)}, /* trstn.trstn */ + {RTCK, (M0 | PIN_OUTPUT)}, /* rtck.rtck */ + {EMU0, (M0 | PIN_INPUT)}, /* emu0.emu0 */ + {EMU1, (M0 | PIN_INPUT)}, /* emu1.emu1 */ + {NMIN_DSP, (M0 | PIN_INPUT)}, /* nmin_dsp.nmin_dsp */ + {RSTOUTN, (M0 | PIN_OUTPUT)}, /* rstoutn.rstoutn */ +}; + +const struct pad_conf_entry core_padconf_array_delta_x15_sr1_1[] = { + {MMC1_SDWP, (M14 | PIN_OUTPUT)}, /* mmc1_sdwp.gpio6_28 */ +}; + +const struct pad_conf_entry core_padconf_array_delta_x15_sr2_0[] = { + {VIN1A_CLK0, (M14 | PIN_INPUT)}, /* vin1a_clk0.gpio2_30 */ };
const struct pad_conf_entry core_padconf_array_essential_am572x_idk[] = { @@ -488,7 +506,7 @@ const struct pad_conf_entry early_padconf[] = { };
#ifdef CONFIG_IODELAY_RECALIBRATION -const struct iodelay_cfg_entry iodelay_cfg_array_x15[] = { +const struct iodelay_cfg_entry iodelay_cfg_array_x15_sr1_1[] = { {0x0114, 2980, 0}, /* CFG_GPMC_A0_IN */ {0x0120, 2648, 0}, /* CFG_GPMC_A10_IN */ {0x012C, 2918, 0}, /* CFG_GPMC_A11_IN */ @@ -543,6 +561,79 @@ const struct iodelay_cfg_entry iodelay_cfg_array_x15[] = { {0x0AF8, 0, 1397}, /* CFG_VIN2A_D23_IN */ };
+const struct iodelay_cfg_entry iodelay_cfg_array_x15_sr2_0[] = { + {0x0114, 2519, 702}, /* CFG_GPMC_A0_IN */ + {0x0120, 2435, 411}, /* CFG_GPMC_A10_IN */ + {0x012C, 2379, 755}, /* CFG_GPMC_A11_IN */ + {0x0198, 2384, 778}, /* CFG_GPMC_A1_IN */ + {0x0204, 2499, 1127}, /* CFG_GPMC_A2_IN */ + {0x0210, 2455, 1181}, /* CFG_GPMC_A3_IN */ + {0x021C, 2486, 1039}, /* CFG_GPMC_A4_IN */ + {0x0228, 2456, 938}, /* CFG_GPMC_A5_IN */ + {0x0234, 2463, 573}, /* CFG_GPMC_A6_IN */ + {0x0240, 2608, 783}, /* CFG_GPMC_A7_IN */ + {0x024C, 2430, 656}, /* CFG_GPMC_A8_IN */ + {0x0258, 2465, 850}, /* CFG_GPMC_A9_IN */ + {0x0264, 2316, 301}, /* CFG_GPMC_AD0_IN */ + {0x0270, 2324, 406}, /* CFG_GPMC_AD10_IN */ + {0x027C, 2278, 352}, /* CFG_GPMC_AD11_IN */ + {0x0288, 2297, 160}, /* CFG_GPMC_AD12_IN */ + {0x0294, 2278, 108}, /* CFG_GPMC_AD13_IN */ + {0x02A0, 2035, 0}, /* CFG_GPMC_AD14_IN */ + {0x02AC, 2279, 378}, /* CFG_GPMC_AD15_IN */ + {0x02B8, 2440, 70}, /* CFG_GPMC_AD1_IN */ + {0x02C4, 2404, 446}, /* CFG_GPMC_AD2_IN */ + {0x02D0, 2343, 212}, /* CFG_GPMC_AD3_IN */ + {0x02DC, 2355, 322}, /* CFG_GPMC_AD4_IN */ + {0x02E8, 2337, 192}, /* CFG_GPMC_AD5_IN */ + {0x02F4, 2270, 314}, /* CFG_GPMC_AD6_IN */ + {0x0300, 2339, 259}, /* CFG_GPMC_AD7_IN */ + {0x030C, 2308, 577}, /* CFG_GPMC_AD8_IN */ + {0x0318, 2334, 166}, /* CFG_GPMC_AD9_IN */ + {0x0378, 0, 0}, /* CFG_GPMC_CS3_IN */ + {0x0678, 0, 386}, /* CFG_MMC3_CLK_IN */ + {0x0680, 605, 0}, /* CFG_MMC3_CLK_OUT */ + {0x0684, 0, 0}, /* CFG_MMC3_CMD_IN */ + {0x0688, 0, 0}, /* CFG_MMC3_CMD_OEN */ + {0x068C, 0, 0}, /* CFG_MMC3_CMD_OUT */ + {0x0690, 171, 0}, /* CFG_MMC3_DAT0_IN */ + {0x0694, 0, 0}, /* CFG_MMC3_DAT0_OEN */ + {0x0698, 0, 0}, /* CFG_MMC3_DAT0_OUT */ + {0x069C, 221, 0}, /* CFG_MMC3_DAT1_IN */ + {0x06A0, 0, 0}, /* CFG_MMC3_DAT1_OEN */ + {0x06A4, 0, 0}, /* CFG_MMC3_DAT1_OUT */ + {0x06A8, 0, 0}, /* CFG_MMC3_DAT2_IN */ + {0x06AC, 0, 0}, /* CFG_MMC3_DAT2_OEN */ + {0x06B0, 0, 0}, /* CFG_MMC3_DAT2_OUT */ + {0x06B4, 474, 0}, /* CFG_MMC3_DAT3_IN */ + {0x06B8, 0, 0}, /* CFG_MMC3_DAT3_OEN */ + {0x06BC, 0, 0}, /* CFG_MMC3_DAT3_OUT */ + {0x06F0, 260, 0}, /* CFG_RGMII0_RXC_IN */ + {0x06FC, 0, 1412}, /* CFG_RGMII0_RXCTL_IN */ + {0x0708, 123, 1047}, /* CFG_RGMII0_RXD0_IN */ + {0x0714, 139, 1081}, /* CFG_RGMII0_RXD1_IN */ + {0x0720, 195, 1100}, /* CFG_RGMII0_RXD2_IN */ + {0x072C, 239, 1216}, /* CFG_RGMII0_RXD3_IN */ + {0x0740, 89, 0}, /* CFG_RGMII0_TXC_OUT */ + {0x074C, 15, 125}, /* CFG_RGMII0_TXCTL_OUT */ + {0x0758, 339, 162}, /* CFG_RGMII0_TXD0_OUT */ + {0x0764, 146, 94}, /* CFG_RGMII0_TXD1_OUT */ + {0x0770, 0, 27}, /* CFG_RGMII0_TXD2_OUT */ + {0x077C, 291, 205}, /* CFG_RGMII0_TXD3_OUT */ + {0x0A70, 0, 0}, /* CFG_VIN2A_D12_OUT */ + {0x0A7C, 219, 101}, /* CFG_VIN2A_D13_OUT */ + {0x0A88, 92, 58}, /* CFG_VIN2A_D14_OUT */ + {0x0A94, 135, 100}, /* CFG_VIN2A_D15_OUT */ + {0x0AA0, 154, 101}, /* CFG_VIN2A_D16_OUT */ + {0x0AAC, 78, 27}, /* CFG_VIN2A_D17_OUT */ + {0x0AB0, 411, 0}, /* CFG_VIN2A_D18_IN */ + {0x0ABC, 0, 382}, /* CFG_VIN2A_D19_IN */ + {0x0AD4, 320, 750}, /* CFG_VIN2A_D20_IN */ + {0x0AE0, 192, 836}, /* CFG_VIN2A_D21_IN */ + {0x0AEC, 294, 669}, /* CFG_VIN2A_D22_IN */ + {0x0AF8, 50, 700}, /* CFG_VIN2A_D23_IN */ +}; + const struct iodelay_cfg_entry iodelay_cfg_array_am572x_idk[] = { {0x0114, 2980, 0}, /* CFG_GPMC_A0_IN */ {0x0120, 2648, 0}, /* CFG_GPMC_A10_IN */
Update the board pinmux for AM572x-IDK board using latest PMT[1] and the board files named am572x_idk_v1p3b_sr2p0 that were autogenerated on 20th October, 2016 by "Steve Kipisz s-kipisz2@ti.com" and "Tom Johnson thjohnson@ti.com".
Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am57xx/mux_data.h | 436 +++++++++++++++++++++++---------------------- 1 file changed, 221 insertions(+), 215 deletions(-)
diff --git a/board/ti/am57xx/mux_data.h b/board/ti/am57xx/mux_data.h index 0e347d7..d612ec2 100644 --- a/board/ti/am57xx/mux_data.h +++ b/board/ti/am57xx/mux_data.h @@ -283,219 +283,222 @@ const struct pad_conf_entry core_padconf_array_delta_x15_sr2_0[] = { };
const struct pad_conf_entry core_padconf_array_essential_am572x_idk[] = { - {GPMC_A0, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a0.vin4b_d0 */ - {GPMC_A1, (M6 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_a1.vin4b_d1 */ - {GPMC_A2, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a2.vin4b_d2 */ - {GPMC_A3, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a3.vin4b_d3 */ - {GPMC_A4, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a4.vin4b_d4 */ - {GPMC_A5, (M6 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_a5.vin4b_d5 */ - {GPMC_A6, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a6.vin4b_d6 */ - {GPMC_A7, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a7.vin4b_d7 */ - {GPMC_A8, (M6 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_a8.vin4b_hsync1 */ - {GPMC_A9, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a9.vin4b_vsync1 */ - {GPMC_A10, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a10.vin4b_clk1 */ - {GPMC_A11, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a11.vin4b_de1 */ - {GPMC_A12, (M6 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a12.vin4b_fld1 */ - {GPMC_A13, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a13.qspi1_rtclk */ - {GPMC_A14, (M1 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_a14.qspi1_d3 */ - {GPMC_A15, (M1 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_a15.qspi1_d2 */ - {GPMC_A16, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a16.qspi1_d0 */ - {GPMC_A17, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a17.qspi1_d1 */ - {GPMC_A18, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a18.qspi1_sclk */ - {GPMC_A19, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a19.mmc2_dat4 */ - {GPMC_A20, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a20.mmc2_dat5 */ - {GPMC_A21, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a21.mmc2_dat6 */ - {GPMC_A22, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a22.mmc2_dat7 */ + {GPMC_A0, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a0.vin4b_d0 */ + {GPMC_A1, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a1.vin4b_d1 */ + {GPMC_A2, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a2.vin4b_d2 */ + {GPMC_A3, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a3.vin4b_d3 */ + {GPMC_A4, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a4.vin4b_d4 */ + {GPMC_A5, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a5.vin4b_d5 */ + {GPMC_A6, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a6.vin4b_d6 */ + {GPMC_A7, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a7.vin4b_d7 */ + {GPMC_A8, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a8.vin4b_hsync1 */ + {GPMC_A9, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a9.vin4b_vsync1 */ + {GPMC_A10, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a10.vin4b_clk1 */ + {GPMC_A11, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a11.vin4b_de1 */ + {GPMC_A12, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a12.vin4b_fld1 */ + {GPMC_A13, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a13.qspi1_rtclk */ + {GPMC_A14, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a14.qspi1_d3 */ + {GPMC_A15, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a15.qspi1_d2 */ + {GPMC_A16, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a16.qspi1_d0 */ + {GPMC_A17, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a17.qspi1_d1 */ + {GPMC_A18, (M1 | PIN_OUTPUT | MANUAL_MODE)}, /* gpmc_a18.qspi1_sclk */ + {GPMC_A19, (M1 | PIN_INPUT)}, /* gpmc_a19.mmc2_dat4 */ + {GPMC_A20, (M1 | PIN_INPUT)}, /* gpmc_a20.mmc2_dat5 */ + {GPMC_A21, (M1 | PIN_INPUT)}, /* gpmc_a21.mmc2_dat6 */ + {GPMC_A22, (M1 | PIN_INPUT)}, /* gpmc_a22.mmc2_dat7 */ {GPMC_A23, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a23.mmc2_clk */ - {GPMC_A24, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a24.mmc2_dat0 */ - {GPMC_A25, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a25.mmc2_dat1 */ - {GPMC_A26, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a26.mmc2_dat2 */ - {GPMC_A27, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a27.mmc2_dat3 */ - {GPMC_CS1, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_cs1.mmc2_cmd */ - {GPMC_CS2, (M1 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_cs2.qspi1_cs0 */ - {VIN1A_D5, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d5.gpio3_9 */ - {VIN1A_D6, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d6.gpio3_10 */ - {VIN1A_D7, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d7.gpio3_11 */ - {VIN1A_D8, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d8.gpio3_12 */ + {GPMC_A24, (M1 | PIN_INPUT)}, /* gpmc_a24.mmc2_dat0 */ + {GPMC_A25, (M1 | PIN_INPUT)}, /* gpmc_a25.mmc2_dat1 */ + {GPMC_A26, (M1 | PIN_INPUT)}, /* gpmc_a26.mmc2_dat2 */ + {GPMC_A27, (M1 | PIN_INPUT)}, /* gpmc_a27.mmc2_dat3 */ + {GPMC_CS1, (M1 | PIN_INPUT)}, /* gpmc_cs1.mmc2_cmd */ + {GPMC_CS2, (M1 | PIN_OUTPUT | MANUAL_MODE)}, /* gpmc_cs2.qspi1_cs0 */ + {VIN1A_D5, (M14 | PIN_OUTPUT)}, /* vin1a_d5.gpio3_9 */ + {VIN1A_D6, (M14 | PIN_OUTPUT)}, /* vin1a_d6.gpio3_10 */ + {VIN1A_D7, (M14 | PIN_OUTPUT)}, /* vin1a_d7.gpio3_11 */ + {VIN1A_D8, (M14 | PIN_OUTPUT)}, /* vin1a_d8.gpio3_12 */ {VIN1A_D10, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d10.gpio3_14 */ - {VIN1A_D12, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d12.gpio3_16 */ - {VIN1A_D13, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d13.gpio3_17 */ - {VIN1A_D14, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d14.gpio3_18 */ - {VIN1A_D15, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d15.gpio3_19 */ - {VIN1A_D17, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d17.gpio3_21 */ - {VIN1A_D18, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d18.gpio3_22 */ - {VIN1A_D19, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d19.gpio3_23 */ - {VIN1A_D22, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d22.gpio3_26 */ - {VIN2A_CLK0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_clk0.gpio3_28 */ - {VIN2A_DE0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_de0.gpio3_29 */ - {VIN2A_FLD0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_fld0.gpio3_30 */ + {VIN1A_D12, (M14 | PIN_INPUT)}, /* vin1a_d12.gpio3_16 */ + {VIN1A_D13, (M14 | PIN_OUTPUT)}, /* vin1a_d13.gpio3_17 */ + {VIN1A_D14, (M14 | PIN_OUTPUT)}, /* vin1a_d14.gpio3_18 */ + {VIN1A_D15, (M14 | PIN_OUTPUT)}, /* vin1a_d15.gpio3_19 */ + {VIN1A_D17, (M14 | PIN_OUTPUT)}, /* vin1a_d17.gpio3_21 */ + {VIN1A_D18, (M14 | PIN_OUTPUT_PULLDOWN)}, /* vin1a_d18.gpio3_22 */ + {VIN1A_D19, (M14 | PIN_OUTPUT_PULLUP)}, /* vin1a_d19.gpio3_23 */ + {VIN1A_D22, (M14 | PIN_INPUT)}, /* vin1a_d22.gpio3_26 */ + {VIN2A_CLK0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_clk0.gpio3_28 */ + {VIN2A_DE0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_de0.gpio3_29 */ + {VIN2A_FLD0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_fld0.gpio3_30 */ {VIN2A_HSYNC0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_hsync0.gpio3_31 */ - {VIN2A_VSYNC0, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_vsync0.gpio4_0 */ - {VIN2A_D0, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d0.pr1_uart0_rxd */ - {VIN2A_D1, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d1.pr1_uart0_txd */ - {VIN2A_D2, (M10 | PIN_INPUT_PULLDOWN)}, /* vin2a_d2.ecap1 */ - {VIN2A_D3, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_d3.gpio4_4 */ - {VIN2A_D4, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_d4.gpio4_5 */ - {VIN2A_D5, (M13 | PIN_INPUT_PULLDOWN)}, /* vin2a_d5.pr1_pru1_gpo2 */ - {VIN2A_D6, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d6.pr1_mii_mt1_clk */ - {VIN2A_D7, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d7.pr1_mii_mii1_txen */ - {VIN2A_D8, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d8.pr1_mii_mii1_txd3 */ - {VIN2A_D9, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d9.pr1_mii_mii1_txd2 */ - {VIN2A_D10, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d10.pr1_mdio_mdclk */ - {VIN2A_D11, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d11.pr1_mdio_data */ - {VIN2A_D12, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d12.rgmii1_txc */ - {VIN2A_D13, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d13.rgmii1_txctl */ - {VIN2A_D14, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d14.rgmii1_txd3 */ - {VIN2A_D15, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d15.rgmii1_txd2 */ - {VIN2A_D16, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d16.rgmii1_txd1 */ - {VIN2A_D17, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d17.rgmii1_txd0 */ + {VIN2A_VSYNC0, (M14 | PIN_INPUT)}, /* vin2a_vsync0.gpio4_0 */ + {VIN2A_D0, (M11 | PIN_INPUT)}, /* vin2a_d0.pr1_uart0_rxd */ + {VIN2A_D1, (M11 | PIN_OUTPUT)}, /* vin2a_d1.pr1_uart0_txd */ + {VIN2A_D2, (M10 | PIN_OUTPUT)}, /* vin2a_d2.eCAP1_in_PWM1_out */ + {VIN2A_D3, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d3.pr1_edc_latch0_in */ + {VIN2A_D4, (M11 | PIN_OUTPUT)}, /* vin2a_d4.pr1_edc_sync0_out */ + {VIN2A_D5, (M13 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d5.pr1_pru1_gpo2 */ + {VIN2A_D10, (M11 | PIN_OUTPUT_PULLDOWN)}, /* vin2a_d10.pr1_mdio_mdclk */ + {VIN2A_D11, (M11 | PIN_INPUT)}, /* vin2a_d11.pr1_mdio_data */ + {VIN2A_D12, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d12.rgmii1_txc */ + {VIN2A_D13, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d13.rgmii1_txctl */ + {VIN2A_D14, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d14.rgmii1_txd3 */ + {VIN2A_D15, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d15.rgmii1_txd2 */ + {VIN2A_D16, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d16.rgmii1_txd1 */ + {VIN2A_D17, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d17.rgmii1_txd0 */ {VIN2A_D18, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d18.rgmii1_rxc */ - {VIN2A_D19, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d19.rgmii1_rxctl */ + {VIN2A_D19, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d19.rgmii1_rxctl */ {VIN2A_D20, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d20.rgmii1_rxd3 */ {VIN2A_D21, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d21.rgmii1_rxd2 */ {VIN2A_D22, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d22.rgmii1_rxd1 */ {VIN2A_D23, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d23.rgmii1_rxd0 */ - {VOUT1_CLK, (M0 | PIN_OUTPUT)}, /* vout1_clk.vout1_clk */ - {VOUT1_DE, (M0 | PIN_OUTPUT)}, /* vout1_de.vout1_de */ - {VOUT1_FLD, (M14 | PIN_INPUT)}, /* vout1_fld.gpio4_21 */ + {VOUT1_CLK, (M0 | PIN_OUTPUT)}, /* vout1_clk.vout1_clk */ + {VOUT1_DE, (M0 | PIN_OUTPUT)}, /* vout1_de.vout1_de */ + {VOUT1_FLD, (M14 | PIN_OUTPUT)}, /* vout1_fld.gpio4_21 */ {VOUT1_HSYNC, (M0 | PIN_OUTPUT)}, /* vout1_hsync.vout1_hsync */ {VOUT1_VSYNC, (M0 | PIN_OUTPUT)}, /* vout1_vsync.vout1_vsync */ - {VOUT1_D0, (M0 | PIN_OUTPUT)}, /* vout1_d0.vout1_d0 */ - {VOUT1_D1, (M0 | PIN_OUTPUT)}, /* vout1_d1.vout1_d1 */ - {VOUT1_D2, (M0 | PIN_OUTPUT)}, /* vout1_d2.vout1_d2 */ - {VOUT1_D3, (M0 | PIN_OUTPUT)}, /* vout1_d3.vout1_d3 */ - {VOUT1_D4, (M0 | PIN_OUTPUT)}, /* vout1_d4.vout1_d4 */ - {VOUT1_D5, (M0 | PIN_OUTPUT)}, /* vout1_d5.vout1_d5 */ - {VOUT1_D6, (M0 | PIN_OUTPUT)}, /* vout1_d6.vout1_d6 */ - {VOUT1_D7, (M0 | PIN_OUTPUT)}, /* vout1_d7.vout1_d7 */ - {VOUT1_D8, (M0 | PIN_OUTPUT)}, /* vout1_d8.vout1_d8 */ - {VOUT1_D9, (M0 | PIN_OUTPUT)}, /* vout1_d9.vout1_d9 */ - {VOUT1_D10, (M0 | PIN_OUTPUT)}, /* vout1_d10.vout1_d10 */ - {VOUT1_D11, (M0 | PIN_OUTPUT)}, /* vout1_d11.vout1_d11 */ - {VOUT1_D12, (M0 | PIN_OUTPUT)}, /* vout1_d12.vout1_d12 */ - {VOUT1_D13, (M0 | PIN_OUTPUT)}, /* vout1_d13.vout1_d13 */ - {VOUT1_D14, (M0 | PIN_OUTPUT)}, /* vout1_d14.vout1_d14 */ - {VOUT1_D15, (M0 | PIN_OUTPUT)}, /* vout1_d15.vout1_d15 */ - {VOUT1_D16, (M0 | PIN_OUTPUT)}, /* vout1_d16.vout1_d16 */ - {VOUT1_D17, (M0 | PIN_OUTPUT)}, /* vout1_d17.vout1_d17 */ - {VOUT1_D18, (M0 | PIN_OUTPUT)}, /* vout1_d18.vout1_d18 */ - {VOUT1_D19, (M0 | PIN_OUTPUT)}, /* vout1_d19.vout1_d19 */ - {VOUT1_D20, (M0 | PIN_OUTPUT)}, /* vout1_d20.vout1_d20 */ - {VOUT1_D21, (M0 | PIN_OUTPUT)}, /* vout1_d21.vout1_d21 */ - {VOUT1_D22, (M0 | PIN_OUTPUT)}, /* vout1_d22.vout1_d22 */ - {VOUT1_D23, (M0 | PIN_OUTPUT)}, /* vout1_d23.vout1_d23 */ - {MDIO_MCLK, (M0 | PIN_INPUT_PULLUP)}, /* mdio_mclk.mdio_mclk */ - {MDIO_D, (M0 | PIN_INPUT_PULLUP)}, /* mdio_d.mdio_d */ - {RMII_MHZ_50_CLK, (M13 | PIN_INPUT_PULLDOWN)}, /* RMII_MHZ_50_CLK.pr2_pru1_gpo2 */ - {UART3_RXD, (M11 | PIN_INPUT_PULLDOWN)}, /* uart3_rxd.pr1_mii0_rxdv */ - {UART3_TXD, (M11 | PIN_INPUT_PULLDOWN)}, /* uart3_txd.rp1_mii_mr0_clk */ - {RGMII0_TXC, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txc.rgmii0_txc */ - {RGMII0_TXCTL, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txctl.rgmii0_txctl */ - {RGMII0_TXD3, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd3.rgmii0_txd3 */ - {RGMII0_TXD2, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd2.rgmii0_txd2 */ - {RGMII0_TXD1, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd1.rgmii0_txd1 */ - {RGMII0_TXD0, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd0.rgmii0_txd0 */ + {VOUT1_D0, (M0 | PIN_OUTPUT)}, /* vout1_d0.vout1_d0 */ + {VOUT1_D1, (M0 | PIN_OUTPUT)}, /* vout1_d1.vout1_d1 */ + {VOUT1_D2, (M0 | PIN_OUTPUT)}, /* vout1_d2.vout1_d2 */ + {VOUT1_D3, (M0 | PIN_OUTPUT)}, /* vout1_d3.vout1_d3 */ + {VOUT1_D4, (M0 | PIN_OUTPUT)}, /* vout1_d4.vout1_d4 */ + {VOUT1_D5, (M0 | PIN_OUTPUT)}, /* vout1_d5.vout1_d5 */ + {VOUT1_D6, (M0 | PIN_OUTPUT)}, /* vout1_d6.vout1_d6 */ + {VOUT1_D7, (M0 | PIN_OUTPUT)}, /* vout1_d7.vout1_d7 */ + {VOUT1_D8, (M0 | PIN_OUTPUT)}, /* vout1_d8.vout1_d8 */ + {VOUT1_D9, (M0 | PIN_OUTPUT)}, /* vout1_d9.vout1_d9 */ + {VOUT1_D10, (M0 | PIN_OUTPUT)}, /* vout1_d10.vout1_d10 */ + {VOUT1_D11, (M0 | PIN_OUTPUT)}, /* vout1_d11.vout1_d11 */ + {VOUT1_D12, (M0 | PIN_OUTPUT)}, /* vout1_d12.vout1_d12 */ + {VOUT1_D13, (M0 | PIN_OUTPUT)}, /* vout1_d13.vout1_d13 */ + {VOUT1_D14, (M0 | PIN_OUTPUT)}, /* vout1_d14.vout1_d14 */ + {VOUT1_D15, (M0 | PIN_OUTPUT)}, /* vout1_d15.vout1_d15 */ + {VOUT1_D16, (M0 | PIN_OUTPUT)}, /* vout1_d16.vout1_d16 */ + {VOUT1_D17, (M0 | PIN_OUTPUT)}, /* vout1_d17.vout1_d17 */ + {VOUT1_D18, (M0 | PIN_OUTPUT)}, /* vout1_d18.vout1_d18 */ + {VOUT1_D19, (M0 | PIN_OUTPUT)}, /* vout1_d19.vout1_d19 */ + {VOUT1_D20, (M0 | PIN_OUTPUT)}, /* vout1_d20.vout1_d20 */ + {VOUT1_D21, (M0 | PIN_OUTPUT)}, /* vout1_d21.vout1_d21 */ + {VOUT1_D22, (M0 | PIN_OUTPUT)}, /* vout1_d22.vout1_d22 */ + {VOUT1_D23, (M0 | PIN_OUTPUT)}, /* vout1_d23.vout1_d23 */ + {MDIO_MCLK, (M0 | PIN_OUTPUT_PULLDOWN)}, /* mdio_mclk.mdio_mclk */ + {MDIO_D, (M0 | PIN_INPUT)}, /* mdio_d.mdio_d */ + {RGMII0_TXC, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txc.rgmii0_txc */ + {RGMII0_TXCTL, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txctl.rgmii0_txctl */ + {RGMII0_TXD3, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd3.rgmii0_txd3 */ + {RGMII0_TXD2, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd2.rgmii0_txd2 */ + {RGMII0_TXD1, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd1.rgmii0_txd1 */ + {RGMII0_TXD0, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd0.rgmii0_txd0 */ {RGMII0_RXC, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxc.rgmii0_rxc */ {RGMII0_RXCTL, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxctl.rgmii0_rxctl */ {RGMII0_RXD3, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd3.rgmii0_rxd3 */ {RGMII0_RXD2, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd2.rgmii0_rxd2 */ {RGMII0_RXD1, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd1.rgmii0_rxd1 */ {RGMII0_RXD0, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd0.rgmii0_rxd0 */ - {USB1_DRVVBUS, (M0 | PIN_INPUT_SLEW)}, /* usb1_drvvbus.usb1_drvvbus */ - {USB2_DRVVBUS, (M0 | PIN_INPUT_SLEW)}, /* usb2_drvvbus.usb2_drvvbus */ - {GPIO6_14, (M14 | PIN_OUTPUT_PULLUP)}, /* gpio6_14.gpio6_14 */ - {GPIO6_15, (M0 | PIN_OUTPUT_PULLUP)}, /* gpio6_15.gpio6_15 */ - {GPIO6_16, (M0 | PIN_INPUT_PULLDOWN)}, /* gpio6_16.gpio6)_16 */ + {USB1_DRVVBUS, (M0 | PIN_OUTPUT)}, /* usb1_drvvbus.usb1_drvvbus */ + {USB2_DRVVBUS, (M0 | PIN_OUTPUT)}, /* usb2_drvvbus.usb2_drvvbus */ + {GPIO6_14, (M0 | PIN_OUTPUT)}, /* gpio6_14.gpio6_14 */ + {GPIO6_15, (M0 | PIN_OUTPUT)}, /* gpio6_15.gpio6_15 */ + {GPIO6_16, (M0 | PIN_INPUT_PULLUP)}, /* gpio6_16.gpio6_16 */ {XREF_CLK0, (M11 | PIN_INPUT_PULLDOWN)}, /* xref_clk0.pr2_mii1_col */ {XREF_CLK1, (M11 | PIN_INPUT_PULLDOWN)}, /* xref_clk1.pr2_mii1_crs */ - {XREF_CLK2, (M14 | PIN_INPUT_PULLDOWN)}, /* xref_clk2.i6_19 */ - {XREF_CLK3, (M9 | PIN_INPUT_PULLDOWN)}, /* xref_clk3.clkout3 */ - {MCASP1_ACLKX, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp1_aclkx.pr2_mdio_mdclk */ - {MCASP1_FSX, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_fsx.pr2_mdio_data */ - {MCASP1_ACLKR, (M14 | PIN_INPUT_PULLUP)}, /* mcasp1_aclkr.gpio5_0 */ - {MCASP1_FSR, (M14 | PIN_INPUT_PULLUP)}, /* mcasp1_fsr.gpio5_1 */ - {MCASP1_AXR0, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr0.pr2_mii0_rxer */ - {MCASP1_AXR1, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr1.pr2_mii_mt0_clk */ - {MCASP1_AXR2, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr2.gpio5_4 */ - {MCASP1_AXR3, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr3.gpio5_5 */ - {MCASP1_AXR4, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr4.gpio5_6 */ - {MCASP1_AXR5, (M14 | PIN_OUTPUT_PULLUP)}, /* mcasp1_axr5.gpio5_7 */ - {MCASP1_AXR6, (M14 | PIN_OUTPUT_PULLUP)}, /* mcasp1_axr6.gpio5_8 */ - {MCASP1_AXR7, (M14 | PIN_OUTPUT_PULLUP)}, /* mcasp1_axr7.gpio5_9 */ - {MCASP1_AXR8, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr8.pr2_mii0_txen */ - {MCASP1_AXR9, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr9.pr2_mii0_txd3 */ - {MCASP1_AXR10, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr10.pr2_mii0_txd2 */ - {MCASP1_AXR11, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr11.pr2_mii0_txd1 */ - {MCASP1_AXR12, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr12.pr2_mii0_txd0 */ - {MCASP1_AXR13, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr13.pr2_mii_mr0_clk */ - {MCASP1_AXR14, (M11 | PIN_INPUT_PULLDOWN | SLEWCONTROL)}, /* mcasp1_axr14.pr2_mii0_rxdv */ - {MCASP1_AXR15, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr15.pr2_mii0_rxd3 */ - {MCASP2_ACLKX, (M11 | PIN_INPUT_SLEW)}, /* mcasp2_aclkx.pr2_mii0_rxd2 */ - {MCASP2_FSX, (M11 | PIN_INPUT_SLEW)}, /* mcasp2_fsx.pr2_mii0_rxd1 */ - {MCASP2_AXR2, (M11 | PIN_INPUT_SLEW)}, /* mcasp2_axr2.pr2_mii0_rxd0 */ - {MCASP2_AXR3, (M11 | PIN_INPUT_PULLDOWN | SLEWCONTROL)}, /* mcasp2_axr3.pr2_mii0_rxlink */ - {MCASP2_AXR4, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr4.gpio1_4 */ - {MCASP2_AXR5, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr5.gpio6_7 */ - {MCASP2_AXR6, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr6.gpio2_29 */ - {MCASP2_AXR7, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr7.gpio1_5 */ + {XREF_CLK2, (M14 | PIN_OUTPUT)}, /* xref_clk2.gpio6_19 */ + {XREF_CLK3, (M9 | PIN_OUTPUT_PULLDOWN)}, /* xref_clk3.clkout3 */ + {MCASP1_ACLKX, (M11 | PIN_OUTPUT_PULLDOWN)}, /* mcasp1_aclkx.pr2_mdio_mdclk */ + {MCASP1_FSX, (M11 | PIN_INPUT)}, /* mcasp1_fsx.pr2_mdio_data */ + {MCASP1_ACLKR, (M14 | PIN_INPUT)}, /* mcasp1_aclkr.gpio5_0 */ + {MCASP1_FSR, (M14 | PIN_INPUT)}, /* mcasp1_fsr.gpio5_1 */ + {MCASP1_AXR0, (M11 | PIN_INPUT_PULLUP)}, /* mcasp1_axr0.pr2_mii0_rxer */ + {MCASP1_AXR1, (M11 | PIN_INPUT_PULLUP)}, /* mcasp1_axr1.pr2_mii_mt0_clk */ + {MCASP1_AXR2, (M14 | PIN_INPUT)}, /* mcasp1_axr2.gpio5_4 */ + {MCASP1_AXR3, (M14 | PIN_INPUT)}, /* mcasp1_axr3.gpio5_5 */ + {MCASP1_AXR4, (M14 | PIN_OUTPUT)}, /* mcasp1_axr4.gpio5_6 */ + {MCASP1_AXR5, (M14 | PIN_OUTPUT)}, /* mcasp1_axr5.gpio5_7 */ + {MCASP1_AXR6, (M14 | PIN_OUTPUT)}, /* mcasp1_axr6.gpio5_8 */ + {MCASP1_AXR7, (M14 | PIN_OUTPUT)}, /* mcasp1_axr7.gpio5_9 */ + {MCASP1_AXR8, (M11 | PIN_OUTPUT_PULLUP)}, /* mcasp1_axr8.pr2_mii0_txen */ + {MCASP1_AXR9, (M11 | PIN_OUTPUT_PULLUP)}, /* mcasp1_axr9.pr2_mii0_txd3 */ + {MCASP1_AXR10, (M11 | PIN_OUTPUT_PULLUP)}, /* mcasp1_axr10.pr2_mii0_txd2 */ + {MCASP1_AXR11, (M11 | PIN_OUTPUT_PULLUP)}, /* mcasp1_axr11.pr2_mii0_txd1 */ + {MCASP1_AXR12, (M11 | PIN_OUTPUT_PULLUP)}, /* mcasp1_axr12.pr2_mii0_txd0 */ + {MCASP1_AXR13, (M11 | PIN_INPUT_PULLUP)}, /* mcasp1_axr13.pr2_mii_mr0_clk */ + {MCASP1_AXR14, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr14.pr2_mii0_rxdv */ + {MCASP1_AXR15, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr15.pr2_mii0_rxd3 */ + {MCASP2_ACLKX, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp2_aclkx.pr2_mii0_rxd2 */ + {MCASP2_FSX, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp2_fsx.pr2_mii0_rxd1 */ + {MCASP2_AXR2, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr2.pr2_mii0_rxd0 */ + {MCASP2_AXR3, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr3.pr2_mii0_rxlink */ + {MCASP2_AXR4, (M14 | PIN_OUTPUT)}, /* mcasp2_axr4.gpio1_4 */ + {MCASP2_AXR5, (M14 | PIN_OUTPUT)}, /* mcasp2_axr5.gpio6_7 */ + {MCASP2_AXR6, (M14 | PIN_OUTPUT)}, /* mcasp2_axr6.gpio2_29 */ + {MCASP2_AXR7, (M14 | PIN_OUTPUT)}, /* mcasp2_axr7.gpio1_5 */ {MCASP3_ACLKX, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp3_aclkx.pr2_mii0_crs */ - {MCASP3_FSX, (M11 | PIN_INPUT_SLEW)}, /* mcasp3_fsx.pr2_mii0_col */ - {MCASP3_AXR0, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp3_axr0.pr2_mii1_rxer */ - {MCASP3_AXR1, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp3_axr1.pr2_mii1_rxlink */ - {MCASP4_ACLKX, (M2 | PIN_INPUT_PULLDOWN)}, /* mcasp4_aclkx.spi3_sclk */ - {MCASP4_FSX, (M2 | PIN_INPUT_PULLDOWN)}, /* mcasp4_fsx.spi3_d1 */ - {MCASP4_AXR1, (M2 | PIN_INPUT_PULLUP)}, /* mcasp4_axr1.spi3_cs0 */ - {MCASP5_ACLKX, (M13 | PIN_INPUT_PULLDOWN)}, /* mcasp5_aclkx.pr2_pru1_gpo1 */ - {MCASP5_FSX, (M12 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE14)},/* mcasp5_fsx.pr2_pru1_gpi2 */ - {MCASP5_AXR0, (M13 | PIN_INPUT_PULLDOWN)}, /* mcasp5_axr0.pr2_pru1_gpo3 */ - {MCASP5_AXR1, (M13 | PIN_INPUT_PULLDOWN)}, /* mcasp5_axr1.pr2_pru1_gpo4 */ + {MCASP3_FSX, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp3_fsx.pr2_mii0_col */ + {MCASP3_AXR0, (M11 | PIN_INPUT_PULLUP)}, /* mcasp3_axr0.pr2_mii1_rxer */ + {MCASP3_AXR1, (M11 | PIN_INPUT_PULLUP)}, /* mcasp3_axr1.pr2_mii1_rxlink */ + {MCASP4_ACLKX, (M2 | PIN_INPUT)}, /* mcasp4_aclkx.spi3_sclk */ + {MCASP4_FSX, (M2 | PIN_INPUT)}, /* mcasp4_fsx.spi3_d1 */ + {MCASP4_AXR1, (M2 | PIN_OUTPUT_PULLUP)}, /* mcasp4_axr1.spi3_cs0 */ + {MCASP5_ACLKX, (M13 | PIN_OUTPUT | MANUAL_MODE)}, /* mcasp5_aclkx.pr2_pru1_gpo1 */ + {MCASP5_FSX, (M12 | PIN_INPUT | MANUAL_MODE)}, /* mcasp5_fsx.pr2_pru1_gpi2 */ + {MMC1_CLK, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_clk.mmc1_clk */ + {MMC1_CMD, (M0 | PIN_INPUT)}, /* mmc1_cmd.mmc1_cmd */ + {MMC1_DAT0, (M0 | PIN_INPUT)}, /* mmc1_dat0.mmc1_dat0 */ + {MMC1_DAT1, (M0 | PIN_INPUT)}, /* mmc1_dat1.mmc1_dat1 */ + {MMC1_DAT2, (M0 | PIN_INPUT)}, /* mmc1_dat2.mmc1_dat2 */ + {MMC1_DAT3, (M0 | PIN_INPUT)}, /* mmc1_dat3.mmc1_dat3 */ + {MMC1_SDCD, (M14 | PIN_INPUT)}, /* mmc1_sdcd.gpio6_27 */ + {MMC1_SDWP, (M14 | PIN_INPUT)}, /* mmc1_sdwp.gpio6_28 */ {GPIO6_10, (M11 | PIN_INPUT_PULLUP)}, /* gpio6_10.pr2_mii_mt1_clk */ - {GPIO6_11, (M11 | PIN_INPUT_PULLUP)}, /* gpio6_11.pr2_mii1_txen */ - {MMC3_CLK, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_clk.pr2_mii1_txd3 */ - {MMC3_CMD, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_cmd.pr2_mii1_txd2 */ - {MMC3_DAT0, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_dat0.pr2_mii1_txd1 */ - {MMC3_DAT1, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_dat1.pr2_mii1_txd0 */ + {GPIO6_11, (M11 | PIN_OUTPUT_PULLUP)}, /* gpio6_11.pr2_mii1_txen */ + {MMC3_CLK, (M11 | PIN_OUTPUT_PULLUP)}, /* mmc3_clk.pr2_mii1_txd3 */ + {MMC3_CMD, (M11 | PIN_OUTPUT_PULLUP)}, /* mmc3_cmd.pr2_mii1_txd2 */ + {MMC3_DAT0, (M11 | PIN_OUTPUT_PULLUP)}, /* mmc3_dat0.pr2_mii1_txd1 */ + {MMC3_DAT1, (M11 | PIN_OUTPUT_PULLUP)}, /* mmc3_dat1.pr2_mii1_txd0 */ {MMC3_DAT2, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_dat2.pr2_mii_mr1_clk */ {MMC3_DAT3, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat3.pr2_mii1_rxdv */ {MMC3_DAT4, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat4.pr2_mii1_rxd3 */ {MMC3_DAT5, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat5.pr2_mii1_rxd2 */ {MMC3_DAT6, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat6.pr2_mii1_rxd1 */ {MMC3_DAT7, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat7.pr2_mii1_rxd0 */ - {SPI1_SCLK, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_sclk.gpio7_7 */ - {SPI1_D1, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_d1.gpio7_8 */ - {SPI1_D0, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_d0.gpio7_9 */ - {SPI1_CS0, (M14 | PIN_OUTPUT)}, /* spi1_cs0.gpio7_10 */ - {SPI1_CS1, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_cs1.gpio7_11 */ - {MMC1_CLK, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_clk.mmc1_clk */ - {MMC1_CMD, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_cmd.mmc1_cmd */ - {MMC1_DAT0, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat0.mmc1_dat0 */ - {MMC1_DAT1, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat1.mmc1_dat1 */ - {MMC1_DAT2, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat2.mmc1_dat2 */ - {MMC1_DAT3, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat3.mmc1_dat3 */ - {MMC1_SDCD, (M14 | PIN_INPUT_PULLUP)}, /* mmc1_sdcd.gpio6_27 */ - {MMC1_SDWP, (M14 | PIN_OUTPUT)}, /* mmc1_sdwp.gpio6_28 */ + {SPI1_SCLK, (M14 | PIN_OUTPUT)}, /* spi1_sclk.gpio7_7 */ + {SPI1_D1, (M14 | PIN_OUTPUT)}, /* spi1_d1.gpio7_8 */ + {SPI1_D0, (M14 | PIN_OUTPUT)}, /* spi1_d0.gpio7_9 */ + {SPI1_CS0, (M14 | PIN_OUTPUT)}, /* spi1_cs0.gpio7_10 */ + {SPI1_CS1, (M14 | PIN_OUTPUT)}, /* spi1_cs1.gpio7_11 */ {SPI1_CS2, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_cs2.gpio7_12 */ - {SPI1_CS3, (M6 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* spi1_cs3.hdmi1_cec */ - {DCAN1_TX, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* dcan1_tx.dcan1_tx */ - {DCAN1_RX, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* dcan1_rx.dcan1_rx */ - {UART2_CTSN, (M2 | PIN_INPUT_SLEW)}, /* uart2_ctsn.uart3_rxd */ - {UART2_RTSN, (M1 | PIN_INPUT_SLEW)}, /* uart2_rtsn.uart3_txd */ - {UART1_RXD, (M14 | PIN_INPUT_PULLDOWN)}, /* uart1_rxd.gpio7_22 */ - {UART1_TXD, (M14 | PIN_INPUT_PULLDOWN)}, /* uart3_txd.gpio7_23 */ - {I2C2_SDA, (M1 | PIN_INPUT)}, /* i2c2_sda.hdmi1_ddc_scl */ - {I2C2_SCL, (M1 | PIN_INPUT)}, /* i2c2_scl.hdmi1_ddc_sda */ - {ON_OFF, (M1 | PIN_OUTPUT_PULLUP)}, /* on_off.on_off */ - {RTC_PORZ, (M0 | PIN_OUTPUT_PULLDOWN)}, /* rtc_porz.rtc_porz */ + {SPI1_CS3, (M6 | PIN_INPUT_PULLUP)}, /* spi1_cs3.hdmi1_cec */ + {DCAN1_TX, (M15 | PULL_UP)}, /* dcan1_tx.safe for dcan1_tx */ + {DCAN1_RX, (M15 | PULL_UP)}, /* dcan1_rx.safe for dcan1_rx */ + {SPI2_SCLK, (M0 | PIN_INPUT)}, /* spi2_sclk.spi2_sclk */ + {SPI2_D1, (M0 | PIN_OUTPUT)}, /* spi2_d1.spi2_d1 */ + {SPI2_D0, (M0 | PIN_INPUT)}, /* spi2_d0.spi2_d0 */ + {SPI2_CS0, (M0 | PIN_OUTPUT)}, /* spi2_cs0.spi2_cs0 */ + {UART1_RXD, (M14 | PIN_OUTPUT)}, /* uart1_rxd.gpio7_22 */ + {UART1_TXD, (M14 | PIN_OUTPUT)}, /* uart1_txd.gpio7_23 */ + {UART2_RXD, (M4 | PIN_INPUT)}, /* uart2_rxd.uart2_rxd */ + {UART2_TXD, (M0 | PIN_OUTPUT)}, /* uart2_txd.uart2_txd */ + {UART2_CTSN, (M2 | PIN_INPUT)}, /* uart2_ctsn.uart3_rxd */ + {UART2_RTSN, (M1 | PIN_OUTPUT)}, /* uart2_rtsn.uart3_txd */ + {I2C1_SDA, (M0 | PIN_INPUT)}, /* i2c1_sda.i2c1_sda */ + {I2C1_SCL, (M0 | PIN_INPUT)}, /* i2c1_scl.i2c1_scl */ + {I2C2_SDA, (M1 | PIN_INPUT)}, /* i2c2_sda.hdmi1_ddc_scl */ + {I2C2_SCL, (M1 | PIN_INPUT)}, /* i2c2_scl.hdmi1_ddc_sda */ + {WAKEUP0, (M0 | PIN_INPUT)}, /* Wakeup0.Wakeup0 */ + {WAKEUP1, (M0 | PIN_INPUT)}, /* Wakeup1.Wakeup1 */ + {WAKEUP2, (M0 | PIN_INPUT)}, /* Wakeup2.Wakeup2 */ + {WAKEUP3, (M0 | PIN_INPUT)}, /* Wakeup3.Wakeup3 */ + {ON_OFF, (M0 | PIN_OUTPUT)}, /* on_off.on_off */ + {RTC_PORZ, (M0 | PIN_INPUT)}, /* rtc_porz.rtc_porz */ {TMS, (M0 | PIN_INPUT_PULLUP)}, /* tms.tms */ - {TDI, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* tdi.tdi */ - {TDO, (M0 | PIN_INPUT_PULLUP)}, /* tdo.tdo */ + {TDI, (M0 | PIN_INPUT_PULLUP)}, /* tdi.tdi */ + {TDO, (M0 | PIN_OUTPUT_PULLUP)}, /* tdo.tdo */ {TCLK, (M0 | PIN_INPUT_PULLUP)}, /* tclk.tclk */ {TRSTN, (M0 | PIN_INPUT_PULLDOWN)}, /* trstn.trstn */ - {RTCK, (M0 | PIN_INPUT)}, /* rtck.rtck */ + {RTCK, (M0 | PIN_OUTPUT_PULLUP)}, /* rtck.rtck */ {EMU0, (M0 | PIN_INPUT_PULLUP)}, /* emu0.emu0 */ {EMU1, (M0 | PIN_INPUT_PULLUP)}, /* emu1.emu1 */ - {RESETN, (M0 | PIN_OUTPUT_PULLUP)}, /* resetn.resetn */ - {RSTOUTN, (M0 | PIN_OUTPUT_PULLDOWN)}, /* rstoutn.rstoutn */ + {RESETN, (M0 | PIN_INPUT)}, /* resetn.resetn */ + {RSTOUTN, (M0 | PIN_OUTPUT)}, /* rstoutn.rstoutn */ };
const struct pad_conf_entry early_padconf[] = { @@ -635,51 +638,54 @@ const struct iodelay_cfg_entry iodelay_cfg_array_x15_sr2_0[] = { };
const struct iodelay_cfg_entry iodelay_cfg_array_am572x_idk[] = { - {0x0114, 2980, 0}, /* CFG_GPMC_A0_IN */ - {0x0120, 2648, 0}, /* CFG_GPMC_A10_IN */ - {0x012C, 2918, 0}, /* CFG_GPMC_A11_IN */ - {0x0138, 2605, 45}, /* CFG_GPMC_A12_IN */ - {0x0144, 0, 0}, /* CFG_GPMC_A13_IN */ - {0x0150, 1976, 1389}, /* CFG_GPMC_A14_IN */ - {0x015C, 1872, 1408}, /* CFG_GPMC_A15_IN */ - {0x0168, 1914, 1506}, /* CFG_GPMC_A16_IN */ - {0x0170, 57, 0}, /* CFG_GPMC_A16_OUT */ - {0x0174, 1904, 1471}, /* CFG_GPMC_A17_IN */ - {0x0188, 1690, 0}, /* CFG_GPMC_A18_OUT */ - {0x0198, 2917, 0}, /* CFG_GPMC_A1_IN */ - {0x0204, 3156, 178}, /* CFG_GPMC_A2_IN */ - {0x0210, 3109, 246}, /* CFG_GPMC_A3_IN */ - {0x021C, 3142, 100}, /* CFG_GPMC_A4_IN */ - {0x0228, 3084, 33}, /* CFG_GPMC_A5_IN */ - {0x0234, 2778, 0}, /* CFG_GPMC_A6_IN */ - {0x0240, 3110, 0}, /* CFG_GPMC_A7_IN */ - {0x024C, 2874, 0}, /* CFG_GPMC_A8_IN */ - {0x0258, 3072, 0}, /* CFG_GPMC_A9_IN */ - {0x0374, 0, 0}, /* CFG_GPMC_CS2_OUT */ - {0x06F0, 480, 0}, /* CFG_RGMII0_RXC_IN */ - {0x06FC, 111, 1641}, /* CFG_RGMII0_RXCTL_IN */ - {0x0708, 272, 1116}, /* CFG_RGMII0_RXD0_IN */ - {0x0714, 243, 1260}, /* CFG_RGMII0_RXD1_IN */ - {0x0720, 0, 1614}, /* CFG_RGMII0_RXD2_IN */ - {0x072C, 105, 1673}, /* CFG_RGMII0_RXD3_IN */ - {0x0740, 531, 120}, /* CFG_RGMII0_TXC_OUT */ - {0x074C, 201, 60}, /* CFG_RGMII0_TXCTL_OUT */ - {0x0758, 229, 120}, /* CFG_RGMII0_TXD0_OUT */ - {0x0764, 141, 0}, /* CFG_RGMII0_TXD1_OUT */ - {0x0770, 495, 120}, /* CFG_RGMII0_TXD2_OUT */ - {0x077C, 660, 120}, /* CFG_RGMII0_TXD3_OUT */ + {0x0114, 1861, 901}, /* CFG_GPMC_A0_IN */ + {0x0120, 0, 0}, /* CFG_GPMC_A10_IN */ + {0x012C, 1783, 1178}, /* CFG_GPMC_A11_IN */ + {0x0138, 1903, 853}, /* CFG_GPMC_A12_IN */ + {0x0144, 0, 0}, /* CFG_GPMC_A13_IN */ + {0x0150, 2575, 966}, /* CFG_GPMC_A14_IN */ + {0x015C, 2503, 889}, /* CFG_GPMC_A15_IN */ + {0x0168, 2528, 1007}, /* CFG_GPMC_A16_IN */ + {0x0170, 0, 0}, /* CFG_GPMC_A16_OUT */ + {0x0174, 2533, 980}, /* CFG_GPMC_A17_IN */ + {0x0188, 590, 0}, /* CFG_GPMC_A18_OUT */ + {0x0198, 1652, 891}, /* CFG_GPMC_A1_IN */ + {0x0204, 1888, 1212}, /* CFG_GPMC_A2_IN */ + {0x0210, 1839, 1274}, /* CFG_GPMC_A3_IN */ + {0x021C, 1868, 1113}, /* CFG_GPMC_A4_IN */ + {0x0228, 1757, 1079}, /* CFG_GPMC_A5_IN */ + {0x0234, 1800, 670}, /* CFG_GPMC_A6_IN */ + {0x0240, 1967, 898}, /* CFG_GPMC_A7_IN */ + {0x024C, 1731, 959}, /* CFG_GPMC_A8_IN */ + {0x0258, 1766, 1150}, /* CFG_GPMC_A9_IN */ + {0x0374, 0, 0}, /* CFG_GPMC_CS2_OUT */ + {0x0590, 1000, 4200}, /* CFG_MCASP5_ACLKX_OUT */ + {0x05AC, 800, 3800}, /* CFG_MCASP5_FSX_IN */ + {0x06F0, 471, 0}, /* CFG_RGMII0_RXC_IN */ + {0x06FC, 30, 1919}, /* CFG_RGMII0_RXCTL_IN */ + {0x0708, 74, 1688}, /* CFG_RGMII0_RXD0_IN */ + {0x0714, 94, 1697}, /* CFG_RGMII0_RXD1_IN */ + {0x0720, 0, 1703}, /* CFG_RGMII0_RXD2_IN */ + {0x072C, 70, 1804}, /* CFG_RGMII0_RXD3_IN */ + {0x0740, 90, 70}, /* CFG_RGMII0_TXC_OUT */ + {0x074C, 70, 70}, /* CFG_RGMII0_TXCTL_OUT */ + {0x0758, 180, 70}, /* CFG_RGMII0_TXD0_OUT */ + {0x0764, 35, 70}, /* CFG_RGMII0_TXD1_OUT */ + {0x0770, 0, 0}, /* CFG_RGMII0_TXD2_OUT */ + {0x077C, 180, 70}, /* CFG_RGMII0_TXD3_OUT */ {0x0A70, 65, 70}, /* CFG_VIN2A_D12_OUT */ {0x0A7C, 125, 70}, /* CFG_VIN2A_D13_OUT */ {0x0A88, 0, 70}, /* CFG_VIN2A_D14_OUT */ {0x0A94, 0, 70}, /* CFG_VIN2A_D15_OUT */ {0x0AA0, 65, 70}, /* CFG_VIN2A_D16_OUT */ - {0x0AAC, 0, 0}, /* CFG_VIN2A_D17_OUT */ + {0x0AAC, 0, 0}, /* CFG_VIN2A_D17_OUT */ {0x0AB0, 612, 0}, /* CFG_VIN2A_D18_IN */ {0x0ABC, 4, 927}, /* CFG_VIN2A_D19_IN */ {0x0AD4, 136, 1340}, /* CFG_VIN2A_D20_IN */ {0x0AE0, 130, 1450}, /* CFG_VIN2A_D21_IN */ {0x0AEC, 144, 1269}, /* CFG_VIN2A_D22_IN */ {0x0AF8, 0, 1330}, /* CFG_VIN2A_D23_IN */ + {0x0B30, 0, 0}, /* CFG_VIN2A_D5_OUT */ }; #endif #endif /* _MUX_DATA_BEAGLE_X15_H_ */
[1] https://dev.ti.com/pinmux/app.html#/default/
Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
The AM571x Industrial Development Kit (IDK) is a board based on TI's AM571x SoC which has a single core 1.5GHz Cortex-A15processor. This board is a development platform for the Industrial Market with:
- 1GB of DDR3L - Dual 1Gbps Ethernet - HDMI - PRU-ICSS - uSD - 16GB eMMC - CAN - RS-485 - PCIe - USB3.0 - Video Input Port - Industrial IO port and expansion connector
The PRU/ICSS will be supported by 3rd party software for EtherCat, Profibus, and other Industrial protocols.
The link to the data sheet and TRM can be found here: http://www.ti.com/product/AM5718
Signed-off-by: Steve Kipisz s-kipisz2@ti.com Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am57xx/board.c | 24 +++- board/ti/am57xx/mux_data.h | 263 ++++++++++++++++++++++++++++++++++++++ include/configs/ti_omap5_common.h | 2 + 3 files changed, 286 insertions(+), 3 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index f6a4314..a4bb117 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -42,6 +42,7 @@ (board_ti_is("AM572PM_") && \ (strncmp("A.30", board_ti_get_rev(), 3) <= 0)) #define board_is_am572x_idk() board_ti_is("AM572IDK") +#define board_is_am571x_idk() board_ti_is("AM571IDK")
#ifdef CONFIG_DRIVER_TI_CPSW #include <cpsw.h> @@ -63,9 +64,17 @@ static const struct dmm_lisa_map_regs beagle_x15_lisa_regs = { .is_ma_present = 0x1 };
+static const struct dmm_lisa_map_regs am571x_idk_lisa_regs = { + .dmm_lisa_map_3 = 0x80640100, + .is_ma_present = 0x1 +}; + void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) { - *dmm_lisa_regs = &beagle_x15_lisa_regs; + if (board_is_am571x_idk()) + *dmm_lisa_regs = &am571x_idk_lisa_regs; + else + *dmm_lisa_regs = &beagle_x15_lisa_regs; }
static const struct emif_regs beagle_x15_emif1_ddr3_532mhz_emif_regs = { @@ -379,6 +388,8 @@ void do_board_detect(void) bname = "AM572x EVM"; else if (board_is_am572x_idk()) bname = "AM572x IDK"; + else if (board_is_am571x_idk()) + bname = "AM571x IDK";
if (bname) snprintf(sysinfo.board_string, SYSINFO_BOARD_NAME_MAX_LEN, @@ -407,6 +418,8 @@ static void setup_board_eeprom_env(void) name = "am57xx_evm"; } else if (board_is_am572x_idk()) { name = "am572x_idk"; + } else if (board_is_am571x_idk()) { + name = "am571x_idk"; } else { printf("Unidentified board claims %s in eeprom header\n", board_ti_get_name()); @@ -472,6 +485,11 @@ void recalibrate_iodelay(void) pconf_sz = ARRAY_SIZE(core_padconf_array_essential_am572x_idk); iod = iodelay_cfg_array_am572x_idk; iod_sz = ARRAY_SIZE(iodelay_cfg_array_am572x_idk); + } else if (board_is_am571x_idk()) { + pconf = core_padconf_array_essential_am571x_idk; + pconf_sz = ARRAY_SIZE(core_padconf_array_essential_am571x_idk); + iod = iodelay_cfg_array_am571x_idk; + iod_sz = ARRAY_SIZE(iodelay_cfg_array_am571x_idk); } else { /* Common for X15/GPEVM */ pconf = core_padconf_array_essential_x15; @@ -749,8 +767,8 @@ int board_eth_init(bd_t *bis) ctrl_val |= 0x22; writel(ctrl_val, (*ctrl)->control_core_control_io1);
- /* The phy address for the AM572x IDK are different than x15 */ - if (board_is_am572x_idk()) { + /* The phy address for the AM57xx IDK are different than x15 */ + if (board_is_am572x_idk() || board_is_am571x_idk()) { cpsw_data.slave_data[0].phy_addr = 0; cpsw_data.slave_data[1].phy_addr = 1; } diff --git a/board/ti/am57xx/mux_data.h b/board/ti/am57xx/mux_data.h index d612ec2..2f5243e 100644 --- a/board/ti/am57xx/mux_data.h +++ b/board/ti/am57xx/mux_data.h @@ -501,6 +501,232 @@ const struct pad_conf_entry core_padconf_array_essential_am572x_idk[] = { {RSTOUTN, (M0 | PIN_OUTPUT)}, /* rstoutn.rstoutn */ };
+const struct pad_conf_entry core_padconf_array_essential_am571x_idk[] = { + {GPMC_A0, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE13)}, /* gpmc_a0.vin1b_d0 */ + {GPMC_A1, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE13)}, /* gpmc_a1.vin1b_d1 */ + {GPMC_A2, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE13)}, /* gpmc_a2.vin1b_d2 */ + {GPMC_A3, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE11)}, /* gpmc_a3.vin1b_d3 */ + {GPMC_A4, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE11)}, /* gpmc_a4.vin1b_d4 */ + {GPMC_A5, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE13)}, /* gpmc_a5.vin1b_d5 */ + {GPMC_A6, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE13)}, /* gpmc_a6.vin1b_d6 */ + {GPMC_A7, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE13)}, /* gpmc_a7.vin1b_d7 */ + {GPMC_A8, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE14)}, /* gpmc_a8.vin1b_hsync1 */ + {GPMC_A9, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE14)}, /* gpmc_a9.vin1b_vsync1 */ + {GPMC_A10, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE14)}, /* gpmc_a10.vin1b_clk1 */ + {GPMC_A11, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE13)}, /* gpmc_a11.vin1b_de1 */ + {GPMC_A12, (M6 | PIN_INPUT_PULLDOWN | VIRTUAL_MODE14)}, /* gpmc_a12.vin1b_fld1 */ + {GPMC_A13, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a13.qspi1_rtclk */ + {GPMC_A14, (M1 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_a14.qspi1_d3 */ + {GPMC_A15, (M1 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_a15.qspi1_d2 */ + {GPMC_A16, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a16.qspi1_d0 */ + {GPMC_A17, (M1 | PIN_INPUT_PULLDOWN) | MANUAL_MODE}, /* gpmc_a17.qspi1_d1 */ + {GPMC_A18, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a18.qspi1_sclk */ + {GPMC_A19, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a19.mmc2_dat4 */ + {GPMC_A20, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a20.mmc2_dat5 */ + {GPMC_A21, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a21.mmc2_dat6 */ + {GPMC_A22, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a22.mmc2_dat7 */ + {GPMC_A23, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a23.mmc2_clk */ + {GPMC_A24, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a24.mmc2_dat0 */ + {GPMC_A25, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a25.mmc2_dat1 */ + {GPMC_A26, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a26.mmc2_dat2 */ + {GPMC_A27, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a27.mmc2_dat3 */ + {GPMC_CS1, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_cs1.mmc2_cmd */ + {GPMC_CS0, (M14 | PIN_INPUT_PULLDOWN)}, /* gpmc_cs0.gpio2_19 */ + {GPMC_CS2, (M1 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_cs2.qspi1_cs0 */ + {GPMC_CS3, (M14 | PIN_INPUT_PULLDOWN)}, /* gpmc_cs3.gpio2_21 */ + {GPMC_CLK, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_clk.gpio2_22 */ + {GPMC_ADVN_ALE, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_advn_ale.gpio2_23 */ + {GPMC_OEN_REN, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_oen_ren.gpio2_24 */ + {GPMC_WEN, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_wen.gpio2_25 */ + {GPMC_BEN0, (M14 | PIN_INPUT_PULLDOWN)}, /* gpmc_ben0.gpio2_26 */ + {GPMC_BEN1, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_ben1.gpio2_27 */ + {GPMC_WAIT0, (M14 | PIN_INPUT_PULLDOWN | SLEWCONTROL)}, /* gpmc_wait0.gpio2_28 */ + {VIN2A_CLK0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_clk0.gpio3_28 */ + {VIN2A_DE0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_de0.gpio3_29 */ + {VIN2A_FLD0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_fld0.gpio3_30 */ + {VIN2A_HSYNC0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_hsync0.gpio3_31 */ + {VIN2A_VSYNC0, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_vsync0.gpio4_0 */ + {VIN2A_D0, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d0.pr1_uart0_rxd */ + {VIN2A_D1, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d1.pr1_uart0_txd */ + {VIN2A_D2, (M10 | PIN_INPUT_PULLDOWN)}, /* vin2a_d2.eCAP1_in_PWM1_out */ + {VIN2A_D3, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d3.pr1_mi1_col */ + {VIN2A_D4, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d4.pr1_mii1_txd1 */ + {VIN2A_D5, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d5.pr1_mii1_txd0 */ + {VIN2A_D6, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d6.pr1_mii_mt1_clk */ + {VIN2A_D7, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d7.pr1_mii1_txen */ + {VIN2A_D8, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d8.pr1_mii1_txd3 */ + {VIN2A_D9, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d9.pr1_mii1_txd2 */ + {VIN2A_D10, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d10.pr1_mdio_mdclk */ + {VIN2A_D11, (M11 | PIN_INPUT_PULLUP)}, /* vin2a_d11.pr1_mdio_data */ + {VIN2A_D12, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d12.rgmii1_txc */ + {VIN2A_D13, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d13.rgmii1_txctl */ + {VIN2A_D14, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d14.rgmii1_txd3 */ + {VIN2A_D15, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d15.rgmii1_txd2 */ + {VIN2A_D16, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d16.rgmii1_txd1 */ + {VIN2A_D17, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d17.rgmii1_txd0 */ + {VIN2A_D18, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d18.rgmii1_rxc */ + {VIN2A_D19, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d19.rgmii1_rxctl */ + {VIN2A_D20, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d20.rgmii1_rxd3 */ + {VIN2A_D21, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d21.rgmii1_rxd2 */ + {VIN2A_D22, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d22.rgmii1_rxd1 */ + {VIN2A_D23, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d23.rgmii1_rxd0 */ + {VOUT1_CLK, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_clk.vout1_clk */ + {VOUT1_DE, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_de.vout1_de */ + {VOUT1_FLD, (M14 | PIN_INPUT_PULLUP)}, /* vout1_fld.gpio4_21 */ + {VOUT1_HSYNC, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_hsync.vout1_hsync */ + {VOUT1_VSYNC, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_vsync.vout1_vsync */ + {VOUT1_D0, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d0.vout1_d0 */ + {VOUT1_D1, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d1.vout1_d1 */ + {VOUT1_D2, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d2.vout1_d2 */ + {VOUT1_D3, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d3.vout1_d3 */ + {VOUT1_D4, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d4.vout1_d4 */ + {VOUT1_D5, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d5.vout1_d5 */ + {VOUT1_D6, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d6.vout1_d6 */ + {VOUT1_D7, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d7.vout1_d7 */ + {VOUT1_D8, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d8.vout1_d8 */ + {VOUT1_D9, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d9.vout1_d9 */ + {VOUT1_D10, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d10.vout1_d10 */ + {VOUT1_D11, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d11.vout1_d11 */ + {VOUT1_D12, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d12.vout1_d12 */ + {VOUT1_D13, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d13.vout1_d13 */ + {VOUT1_D14, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d14.vout1_d14 */ + {VOUT1_D15, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d15.vout1_d15 */ + {VOUT1_D16, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d16.vout1_d16 */ + {VOUT1_D17, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d17.vout1_d17 */ + {VOUT1_D18, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d18.vout1_d18 */ + {VOUT1_D19, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d19.vout1_d19 */ + {VOUT1_D20, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d20.vout1_d20 */ + {VOUT1_D21, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d21.vout1_d21 */ + {VOUT1_D22, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d22.vout1_d22 */ + {VOUT1_D23, (M0 | PIN_INPUT_PULLDOWN)}, /* vout1_d23.vout1_d23 */ + {MDIO_MCLK, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mdio_mclk.mdio_mclk */ + {MDIO_D, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mdio_d.mdio_d */ + {RMII_MHZ_50_CLK, (M13 | PIN_INPUT_PULLDOWN)}, /* RMII_MHZ_50_CLK.pr2_pru1_gpo2 */ + {UART3_RXD, (M14 | PIN_INPUT_SLEW)}, /* uart3_rxd.gpio5_18 */ + {UART3_TXD, (M14 | PIN_INPUT_SLEW)}, /* uart3_txd.gpio5_19 */ + {RGMII0_TXC, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txc.rgmii0_txc */ + {RGMII0_TXCTL, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txctl.rgmii0_txctl */ + {RGMII0_TXD3, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd3.rgmii0_txd3 */ + {RGMII0_TXD2, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd2.rgmii0_txd2 */ + {RGMII0_TXD1, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd1.rgmii0_txd1 */ + {RGMII0_TXD0, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd0.rgmii0_txd0 */ + {RGMII0_RXC, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxc.rgmii0_rxc */ + {RGMII0_RXCTL, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)},/* rgmii0_rxctl.rgmii0_rxctl */ + {RGMII0_RXD3, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxd3.rgmii0_rxd3 */ + {RGMII0_RXD2, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxd2.rgmii0_rxd2 */ + {RGMII0_RXD1, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxd1.rgmii0_rxd1 */ + {RGMII0_RXD0, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxd0.rgmii0_rxd0 */ + {USB1_DRVVBUS, (M0 | PIN_INPUT_SLEW)}, /* usb1_drvvbus.usb1_drvvbus */ + {USB2_DRVVBUS, (M0 | PIN_INPUT_SLEW)}, /* usb2_drvvbus.usb2_drvvbus */ + {GPIO6_14, (M14 | PIN_INPUT_PULLUP)}, /* gpio6_14.gpio6_14 */ + {GPIO6_15, (M14 | PIN_INPUT_PULLUP)}, /* gpio6_15.gpio6_15 */ + {GPIO6_16, (M14 | PIN_INPUT_PULLDOWN)}, /* gpio6_16.gpio6_16 */ + {XREF_CLK0, (M11 | PIN_INPUT_PULLDOWN)}, /* xref_clk0.pr2_mii1_col */ + {XREF_CLK1, (M11 | PIN_INPUT_PULLDOWN)}, /* xref_clk1.pr2_mii1_crs */ + {XREF_CLK2, (M14 | PIN_INPUT_PULLDOWN)}, /* xref_clk2.gpio6_19 */ + {XREF_CLK3, (M15 | PIN_INPUT_PULLDOWN)}, /* xref_clk3.Driveroff */ + {MCASP1_ACLKX, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp1_aclkx.pr2_mdio_mdclk */ + {MCASP1_FSX, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_fsx.pr2_mdio_data */ + {MCASP1_ACLKR, (M14 | PIN_INPUT_PULLUP)}, /* mcasp1_aclkr.gpio5_0 */ + {MCASP1_FSR, (M14 | PIN_INPUT_PULLUP)}, /* mcasp1_fsr.gpio5_1 */ + {MCASP1_AXR0, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr0.pr2_mii0_rxer */ + {MCASP1_AXR1, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr1.pr2_mii_mt0_clk */ + {MCASP1_AXR2, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr2.gpio5_4 */ + {MCASP1_AXR3, (M14 | PIN_INPUT_PULLUP)}, /* mcasp1_axr3.gpio5_5 */ + {MCASP1_AXR4, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr4.gpio5_6 */ + {MCASP1_AXR5, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr5.gpio5_7 */ + {MCASP1_AXR6, (M14 | PIN_INPUT_PULLUP)}, /* mcasp1_axr6.gpio5_8 */ + {MCASP1_AXR7, (M14 | PIN_INPUT_PULLUP)}, /* mcasp1_axr7.gpio5_9 */ + {MCASP1_AXR8, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr8.pr2_mii0_txen */ + {MCASP1_AXR9, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr9.pr2_mii0_txd3 */ + {MCASP1_AXR10, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr10.pr2_mii0_txd2 */ + {MCASP1_AXR11, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr11.pr2_mii0_txd1 */ + {MCASP1_AXR12, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr12.pr2_mii0_txd0 */ + {MCASP1_AXR13, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr13.pr2_mii_mr0_clk */ + {MCASP1_AXR14, (M11 | PIN_INPUT_PULLDOWN | SLEWCONTROL)}, /* mcasp1_axr14.pr2_mii0_rxdv */ + {MCASP1_AXR15, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr15.pr2_mii0_rxd3 */ + {MCASP2_ACLKX, (M11 | PIN_INPUT_SLEW)}, /* mcasp2_aclkx.pr2_mii0_rxd2 */ + {MCASP2_FSX, (M11 | PIN_INPUT_SLEW)}, /* mcasp2_fsx.pr2_mii0_rxd1 */ + {MCASP2_ACLKR, (M15 | PIN_INPUT_PULLDOWN)}, /* mcasp2_aclkr.Driveroff */ + {MCASP2_FSR, (M15 | PIN_INPUT_PULLDOWN)}, /* mcasp2_fsr.Driveroff */ + {MCASP2_AXR0, (M15 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr0.Driveroff */ + {MCASP2_AXR1, (M15 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr1.Driveroff */ + {MCASP2_AXR2, (M11 | PIN_INPUT_SLEW)}, /* mcasp2_axr2.pr2_mii0_rxd0 */ + {MCASP2_AXR3, (M11 | PIN_INPUT_PULLDOWN | SLEWCONTROL)}, /* mcasp2_axr3.pr2_mii0_rxlink */ + {MCASP2_AXR4, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr4.gpio1_4 */ + {MCASP2_AXR5, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr5.gpio6_7 */ + {MCASP2_AXR6, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr6.gpio2_29 */ + {MCASP2_AXR7, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp2_axr7.gpio1_5 */ + {MCASP3_ACLKX, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp3_aclkx.pr2_mii0_crs */ + {MCASP3_FSX, (M11 | PIN_INPUT_SLEW)}, /* mcasp3_fsx.pr2_mii0_col */ + {MCASP3_AXR0, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp3_axr0.pr2_mii1_rxer */ + {MCASP3_AXR1, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp3_axr1.pr2_mii1_rxlink */ + {MCASP4_ACLKX, (M2 | PIN_INPUT_PULLDOWN)}, /* mcasp4_aclkx.spi3_sclk */ + {MCASP4_FSX, (M2 | PIN_INPUT_PULLDOWN)}, /* mcasp4_fsx.spi3_d1 */ + {MCASP4_AXR0, (M15 | PIN_INPUT_PULLDOWN)}, /* mcasp4_axr0.Driveroff */ + {MCASP4_AXR1, (M2 | PIN_INPUT_PULLDOWN)}, /* mcasp4_axr1.spi3_cs0 */ + {MCASP5_ACLKX, (M13 | PIN_INPUT_PULLDOWN)}, /* mcasp5_aclkx.pr2_pru1_gpo1 */ + {MCASP5_FSX, (M12 | PIN_INPUT_PULLDOWN)}, /* mcasp5_fsx.pr2_pru1_gpi2 */ + {MCASP5_AXR0, (M15 | PIN_INPUT_PULLDOWN)}, /* mcasp5_axr0.Driveroff */ + {MCASP5_AXR1, (M15 | PIN_INPUT_PULLDOWN)}, /* mcasp5_axr1.Driveroff */ + {MMC1_CLK, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_clk.mmc1_clk */ + {MMC1_CMD, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_cmd.mmc1_cmd */ + {MMC1_DAT0, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat0.mmc1_dat0 */ + {MMC1_DAT1, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat1.mmc1_dat1 */ + {MMC1_DAT2, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat2.mmc1_dat2 */ + {MMC1_DAT3, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat3.mmc1_dat3 */ + {MMC1_SDCD, (M14 | PIN_INPUT_PULLUP)}, /* mmc1_sdcd.gpio6_27 */ + {MMC1_SDWP, (M0 | PIN_OUTPUT)}, /* mmc1_sdwp.mmc1_sdwp */ + {GPIO6_10, (M11 | PIN_INPUT_PULLUP)}, /* gpio6_10.pr2_mii_mt1_clk */ + {GPIO6_11, (M11 | PIN_INPUT_PULLUP)}, /* gpio6_11.pr2_mii1_txen */ + {MMC3_CLK, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_clk.pr2_mii1_txd3 */ + {MMC3_CMD, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_cmd.pr2_mii1_txd2 */ + {MMC3_DAT0, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_dat0.pr2_mii1_txd1 */ + {MMC3_DAT1, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_dat1.pr2_mii1_txd0 */ + {MMC3_DAT2, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_dat2.pr2_mii_mr1_clk */ + {MMC3_DAT3, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat3.pr2_mii1_rxdv */ + {MMC3_DAT4, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat4.pr2_mii1_rxd3 */ + {MMC3_DAT5, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat5.pr2_mii1_rxd2 */ + {MMC3_DAT6, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat6.pr2_mii1_rxd1 */ + {MMC3_DAT7, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat7.pr2_mii1_rxd0 */ + {SPI1_SCLK, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_sclk.gpio7_7 */ + {SPI1_D1, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_d1.gpio7_8 */ + {SPI1_D0, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_d0.gpio7_9 */ + {SPI1_CS0, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_cs0.gpio7_10 */ + {SPI1_CS1, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_cs1.gpio7_11 */ + {SPI1_CS2, (M14 | PIN_INPUT_PULLDOWN)}, /* spi1_cs2.gpio7_12 */ + {SPI1_CS3, (M6 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* spi1_cs3.hdmi1_cec */ + {SPI2_SCLK, (M0 | PIN_INPUT_PULLDOWN)}, /* spi2_sclk.spi2_sclk */ + {SPI2_D1, (M0 | PIN_INPUT_SLEW)}, /* spi2_d1.spi2_d1 */ + {SPI2_D0, (M0 | PIN_INPUT_SLEW)}, /* spi2_d0.spi2_d0 */ + {SPI2_CS0, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* spi2_cs0.spi2_cs0 */ + {DCAN1_TX, (M15 | PULL_UP)}, /* dcan1_tx.safe for dcan1_tx */ + {DCAN1_RX, (M15 | PULL_UP)}, /* dcan1_rx.safe for dcan1_rx */ + {UART1_RXD, (M14 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* uart1_rxd.gpio7_22 */ + {UART1_CTSN, (M14 | PIN_INPUT_PULLDOWN)}, /* uart1_ctsn.gpio7_24 */ + {UART1_RTSN, (M14 | PIN_INPUT_PULLDOWN)}, /* uart1_rtsn.gpio7_25 */ + {UART2_RXD, (M0 | PIN_INPUT_PULLUP)}, /* uart2_rxd.uart2_rxd */ + {UART2_TXD, (M0 | PIN_INPUT_PULLUP)}, /* uart2_txd.uart2_txd */ + {UART2_CTSN, (M2 | PIN_INPUT_PULLUP)}, /* uart2_ctsn.uart3_rxd */ + {UART2_RTSN, (M1 | PIN_INPUT_PULLUP)}, /* uart2_rtsn.uart3_txd */ + {I2C2_SDA, (M1 | PIN_INPUT_PULLUP)}, /* i2c2_sda.hdmi1_ddc_scl */ + {I2C2_SCL, (M1 | PIN_INPUT_PULLUP)}, /* i2c2_scl.hdmi1_ddc_sda */ + {WAKEUP0, (M0 | PIN_OUTPUT_PULLDOWN)}, /* Wakeup0.Wakeup0 */ + {WAKEUP3, (M0 | PIN_OUTPUT_PULLDOWN)}, /* Wakeup3.Wakeup3 */ + {ON_OFF, (M0 | PIN_OUTPUT_PULLUP)}, /* on_off.on_off */ + {RTC_PORZ, (M0 | PIN_OUTPUT)}, /* rtc_porz.rtc_porz */ + {TMS, (M0 | PIN_INPUT_PULLUP)}, /* tms.tms */ + {TDI, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* tdi.tdi */ + {TDO, (M0 | PIN_INPUT_PULLUP)}, /* tdo.tdo */ + {TCLK, (M0 | PIN_INPUT_PULLUP)}, /* tclk.tclk */ + {TRSTN, (M0 | PIN_INPUT_PULLDOWN)}, /* trstn.trstn */ + {RTCK, (M0 | PIN_INPUT)}, /* rtck.rtck */ + {EMU0, (M0 | PIN_INPUT_PULLUP)}, /* emu0.emu0 */ + {EMU1, (M0 | PIN_INPUT_PULLUP)}, /* emu1.emu1 */ + {RESETN, (M0 | PIN_OUTPUT_PULLUP)}, /* resetn.resetn */ + {RSTOUTN, (M0 | PIN_OUTPUT_PULLDOWN)}, /* rstoutn.rstoutn */ +}; + const struct pad_conf_entry early_padconf[] = { {UART2_CTSN, (M2 | PIN_INPUT_SLEW)}, /* uart2_ctsn.uart3_rxd */ {UART2_RTSN, (M1 | PIN_INPUT_SLEW)}, /* uart2_rtsn.uart3_txd */ @@ -687,5 +913,42 @@ const struct iodelay_cfg_entry iodelay_cfg_array_am572x_idk[] = { {0x0AF8, 0, 1330}, /* CFG_VIN2A_D23_IN */ {0x0B30, 0, 0}, /* CFG_VIN2A_D5_OUT */ }; + +const struct iodelay_cfg_entry iodelay_cfg_array_am571x_idk[] = { + {0x0144, 0, 0}, /* CFG_GPMC_A13_IN */ + {0x0150, 2062, 2277}, /* CFG_GPMC_A14_IN */ + {0x015C, 1960, 2289}, /* CFG_GPMC_A15_IN */ + {0x0168, 2058, 2386}, /* CFG_GPMC_A16_IN */ + {0x0170, 0, 0}, /* CFG_GPMC_A16_OUT */ + {0x0174, 2062, 2350}, /* CFG_GPMC_A17_IN */ + {0x0188, 0, 0}, /* CFG_GPMC_A18_OUT */ + {0x0374, 121, 0}, /* CFG_GPMC_CS2_OUT */ + {0x06F0, 413, 0}, /* CFG_RGMII0_RXC_IN */ + {0x06FC, 27, 2296}, /* CFG_RGMII0_RXCTL_IN */ + {0x0708, 3, 1721}, /* CFG_RGMII0_RXD0_IN */ + {0x0714, 134, 1786}, /* CFG_RGMII0_RXD1_IN */ + {0x0720, 40, 1966}, /* CFG_RGMII0_RXD2_IN */ + {0x072C, 0, 2057}, /* CFG_RGMII0_RXD3_IN */ + {0x0740, 0, 60}, /* CFG_RGMII0_TXC_OUT */ + {0x074C, 0, 60}, /* CFG_RGMII0_TXCTL_OUT */ + {0x0758, 0, 60}, /* CFG_RGMII0_TXD0_OUT */ + {0x0764, 0, 0}, /* CFG_RGMII0_TXD1_OUT */ + {0x0770, 0, 60}, /* CFG_RGMII0_TXD2_OUT */ + {0x077C, 0, 120}, /* CFG_RGMII0_TXD3_OUT */ + {0x0A70, 0, 0}, /* CFG_VIN2A_D12_OUT */ + {0x0A7C, 170, 0}, /* CFG_VIN2A_D13_OUT */ + {0x0A88, 150, 0}, /* CFG_VIN2A_D14_OUT */ + {0x0A94, 0, 0}, /* CFG_VIN2A_D15_OUT */ + {0x0AA0, 60, 0}, /* CFG_VIN2A_D16_OUT */ + {0x0AAC, 60, 0}, /* CFG_VIN2A_D17_OUT */ + {0x0AB0, 530, 0}, /* CFG_VIN2A_D18_IN */ + {0x0ABC, 71, 1099}, /* CFG_VIN2A_D19_IN */ + {0x0AC8, 2229, 10}, /* CFG_VIN2A_D1_IN */ + {0x0AD4, 142, 1337}, /* CFG_VIN2A_D20_IN */ + {0x0AE0, 114, 1517}, /* CFG_VIN2A_D21_IN */ + {0x0AEC, 171, 1331}, /* CFG_VIN2A_D22_IN */ + {0x0AF8, 0, 1328}, /* CFG_VIN2A_D23_IN */ +}; + #endif #endif /* _MUX_DATA_BEAGLE_X15_H_ */ diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 540bde8..86e5464 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -110,6 +110,8 @@ "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ "if test $board_name = am57xx_evm_reva3; then " \ "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ + "if test $board_name = am571x_idk; then " \ + "setenv fdtfile am571x-idk.dtb; fi;" \ "if test $fdtfile = undefined; then " \ "echo WARNING: Could not determine device tree to use; fi; \0" \ "loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile};\0" \
- 1GB of DDR3L
- HDMI
- PRU-ICSS
- uSD
- 16GB eMMC
- CAN
- RS-485
- PCIe
- USB3.0
- Video Input Port
- 1GB of DDR3L
- HDMI
- PRU-ICSS
- uSD
- 16GB eMMC
- CAN
- RS-485
- PCIe
- USB3.0
- Video Input Port
Signed-off-by: Steve Kipisz s-kipisz2@ti.com Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Add initial DTS support for AM571-IDK evm.
Signed-off-by: Schuyler Patton spatton@ti.com Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/am571x-idk.dts | 81 ++++++++++++++++++++++++++++++++++++++++++++ board/ti/am57xx/board.c | 2 ++ configs/am57xx_evm_defconfig | 2 +- 4 files changed, 86 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/am571x-idk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 082b89c..4ea1550 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -139,7 +139,8 @@ dtb-$(CONFIG_TARGET_DRA7XX_EVM) += dra72-evm.dtb dra7-evm.dtb \ dra72-evm-revc.dtb dra71-evm.dtb dtb-$(CONFIG_TARGET_AM57XX_EVM) += am57xx-beagle-x15.dtb \ am57xx-beagle-x15-revb1.dtb \ - am572x-idk.dtb + am572x-idk.dtb \ + am571x-idk.dtb dtb-$(CONFIG_TARGET_STV0991) += stv0991.dtb
dtb-$(CONFIG_LS102XA) += ls1021a-qds-duart.dtb \ diff --git a/arch/arm/dts/am571x-idk.dts b/arch/arm/dts/am571x-idk.dts new file mode 100644 index 0000000..ac69bb0 --- /dev/null +++ b/arch/arm/dts/am571x-idk.dts @@ -0,0 +1,81 @@ +/* + * Copyright (C) 2015-2016 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +/dts-v1/; + +#include "dra72x.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include "am57xx-idk-common.dtsi" + +/ { + model = "TI AM5718 IDK"; + compatible = "ti,am5718-idk", "ti,am5718", "ti,dra7"; + + memory@80000000 { + device_type = "memory"; + reg = <0x0 0x80000000 0x0 0x40000000>; + }; + + leds { + compatible = "gpio-leds"; + cpu0-led { + label = "status0:red:cpu0"; + gpios = <&gpio2 25 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "cpu0"; + }; + + usr0-led { + label = "status0:green:usr"; + gpios = <&gpio2 26 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + heartbeat-led { + label = "status0:blue:heartbeat"; + gpios = <&gpio2 27 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "heartbeat"; + }; + + usr1-led { + label = "status1:red:usr"; + gpios = <&gpio2 28 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + usr2-led { + label = "status1:green:usr"; + gpios = <&gpio2 21 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + mmc0-led { + label = "status1:blue:mmc0"; + gpios = <&gpio2 19 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "mmc0"; + }; + }; + + extcon_usb2: extcon_usb2 { + compatible = "linux,extcon-usb-gpio"; + id-gpio = <&gpio5 7 GPIO_ACTIVE_HIGH>; + }; +}; + +&mmc1 { + status = "okay"; + vmmc-supply = <&ldo1_reg>; + bus-width = <4>; + cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; /* gpio 219 */ +}; + +&omap_dwc3_2 { + extcon = <&extcon_usb2>; +}; diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index a4bb117..226752e 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -849,6 +849,8 @@ int board_fit_config_name_match(const char *name) return 0; } else if (board_is_am572x_idk() && !strcmp(name, "am572x-idk")) { return 0; + } else if (board_is_am571x_idk() && !strcmp(name, "am571x-idk")) { + return 0; }
return -1; diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index bffa47c..37a71fd 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -47,7 +47,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am572x-idk" +CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am572x-idk am571x-idk" CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y
Signed-off-by: Schuyler Patton spatton@ti.com Signed-off-by: Nishanth Menon nm@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
There are certain environment variables whose length is greater than the defined IO buffer size. So, increase the IO buffer size to print the entire variables.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- include/configs/ti_armv7_common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 1be8137..3e4d3fa 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -160,7 +160,7 @@ #define CONFIG_SYS_MAXARGS 64
/* Console I/O Buffer Size */ -#define CONFIG_SYS_CBSIZE 512 +#define CONFIG_SYS_CBSIZE 1024 /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + sizeof(CONFIG_SYS_PROMPT) + 16)
Lokesh Vutla
