[U-Boot] [PATCH] rockchip: make_fit_atf: fix warning unit_address_vs_reg
Patch fix warning: /builddir/BUILD/u-boot-2018.05-rc2/"arch/arm/mach-rockchip/make_fit_atf.py" \ arch/arm/dts/rk3399-firefly.dtb > u-boot.its ./tools/mkimage -f u-boot.its -E u-boot.itb >/dev/null && cat /dev/null u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/uboot@1 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/atf@1 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/atf@2 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/atf@3 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /images/fdt@1 has a unit name, but no reg property u-boot.itb.tmp: Warning (unit_address_vs_reg): Node /configurations/config@1 has a unit name, but no reg property make[1]: Leaving directory '/builddir/BUILD/u-boot-2018.05-rc2/builds/firefly-rk3399'
Reported-by: Peter Robinson pbrobinson@gmail.com Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/make_fit_atf.py | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/arch/arm/mach-rockchip/make_fit_atf.py b/arch/arm/mach-rockchip/make_fit_atf.py index 7c6dd57..513e088 100755 --- a/arch/arm/mach-rockchip/make_fit_atf.py +++ b/arch/arm/mach-rockchip/make_fit_atf.py @@ -37,7 +37,7 @@ DT_HEADER="""/* #address-cells = <1>;
images { - uboot@1 { + uboot { description = "U-Boot (64-bit)"; data = /incbin/("u-boot-nodtb.bin"); type = "standalone"; @@ -61,7 +61,7 @@ def append_atf_node(file, atf_index, phy_addr): Append ATF DT node to input FIT dts file. """ data = 'bl31_0x%08x.bin' % phy_addr - print >> file, '\t\tatf@%d {' % atf_index + print >> file, '\t\tatf_%d {' % atf_index print >> file, '\t\t\tdescription = "ARM Trusted Firmware";' print >> file, '\t\t\tdata = /incbin/("%s");' % data print >> file, '\t\t\ttype = "firmware";' @@ -81,7 +81,7 @@ def append_fdt_node(file, dtbs): cnt = 1 for dtb in dtbs: dtname = os.path.basename(dtb) - print >> file, '\t\tfdt@%d {' % cnt + print >> file, '\t\tfdt_%d {' % cnt print >> file, '\t\t\tdescription = "%s";' % dtname print >> file, '\t\t\tdata = /incbin/("%s");' % dtb print >> file, '\t\t\ttype = "flat_dt";' @@ -91,17 +91,17 @@ def append_fdt_node(file, dtbs): cnt = cnt + 1
def append_conf_section(file, cnt, dtname, atf_cnt): - print >> file, '\t\tconfig@%d {' % cnt + print >> file, '\t\tconfig_%d {' % cnt print >> file, '\t\t\tdescription = "%s";' % dtname - print >> file, '\t\t\tfirmware = "atf@1";' - print >> file, '\t\t\tloadables = "uboot@1",', + print >> file, '\t\t\tfirmware = "atf_1";' + print >> file, '\t\t\tloadables = "uboot",', for i in range(1, atf_cnt): - print >> file, '"atf@%d"' % (i+1), + print >> file, '"atf_%d"' % (i+1), if i != (atf_cnt - 1): print >> file, ',', else: print >> file, ';' - print >> file, '\t\t\tfdt = "fdt@1";' + print >> file, '\t\t\tfdt = "fdt_1";' print >> file, '\t\t};' print >> file, ''
@@ -111,7 +111,7 @@ def append_conf_node(file, dtbs, atf_cnt): """ cnt = 1 print >> file, '\tconfigurations {' - print >> file, '\t\tdefault = "config@1";' + print >> file, '\t\tdefault = "config_1";' for dtb in dtbs: dtname = os.path.basename(dtb) append_conf_section(file, cnt, dtname, atf_cnt)
Kever Yang
