[U-Boot] [PATCH] env: add support to sunxi save env to spi
CONFIG_ENV_SECT_SIZE value is defined via Kconfig.
Signed-off-by: Oskari Lemmela oskari@lemmela.net --- env/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index c22cbbdadc..e1070187f2 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -456,9 +456,9 @@ config ENV_SIZE
config ENV_SECT_SIZE hex "Environment Sector-Size" - depends on !ENV_IS_NOWHERE && (ARCH_ZYNQ || ARCH_ZYNQMP) + depends on !ENV_IS_NOWHERE && (ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_SUNXI ) default 0x40000 if ARCH_ZYNQMP - default 0x20000 if ARCH_ZYNQ + default 0x20000 if ARCH_ZYNQ || ARCH_SUNXI help Size of the sector containing the environment.
Looks good to me!
Reviewed-by: Paul Kocialkowski paul.kocialkowski@bootlin.com
Cheers,
Paul
- depends on !ENV_IS_NOWHERE && (ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_SUNXI ) default 0x40000 if ARCH_ZYNQMP
- default 0x20000 if ARCH_ZYNQ || ARCH_SUNXI help Size of the sector containing the environment.
Would be great if we have a detailed information flash layout, so-that we can find where will env resides.
Jagan Teki
Oskari Lemmela
Paul Kocialkowski
