[U-Boot] Pull request: u-boot-mpc85xx
Tom,
The following changes since commit 39bc12ddc36c9e30199471da0f3a929b178a04b2:
SPL: Makefile: Build a separate autoconf.mk for SPL (2013-08-19 18:05:19 -0400)
git://git.denx.de/u-boot-mpc85xx.git master
for you to fetch changes up to b6df9b01fb8c126b212aba92b6523407d3fa60a5:
Makefile: Fix build in a separated directory tree (2013-08-21 09:03:29 -0700)
---------------------------------------------------------------- Prabhakar Kushwaha (1): powerpc: Fix CamelCase checkpatch warnings
Shaohui Xie (3): powerpc/common/vsc3316: remove const from vsc3316_config parameter define powerpc/t4240: fix lanes routing for QSGMII protocols powerpc/t4240: add QSGMII interface support
Shengzhou Liu (2): powerpc/p1010rdb: fix calculating ddr_freq_mhz powerpc/sec: Add workaround for SEC A-003571
Shruti Kanetkar (2): powerpc: Use print_size() where appropriate powerpcv2: Print hardcoded size like print_size() does
Ying Zhang (8): spl: env_common.c: make CONFIG_SPL_BUILD contain function env_import powerpc: deleted unused symbol CONFIG_SPL_NAND_MINIMAL and enabled some functionality for common SPL powerpc: mpc85xx: Support booting from SD Card with SPL powerpc: p1022ds: Enable P1022DS to boot from SD Card with SPL powerpc : spi flash : Support to start from eSPI with SPL powerpc : p1022ds : Enable p1022ds to start from eSPI with SPL TPL : introduce the TPL based on the SPL powerpc: p1022ds: add TPL for p1022ds nand boot
York Sun (2): SPDX-License-Identifier: clean up license header Makefile: Fix build in a separated directory tree
Николай Пузанов (1): Fix for incorrect conversion hex string to number (FMAN firmware address).
Makefile | 50 +++++- README | 24 +++ arch/powerpc/cpu/mpc824x/cpu.c | 8 +- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 4 + arch/powerpc/cpu/mpc85xx/cpu.c | 45 +++--- arch/powerpc/cpu/mpc85xx/cpu_init.c | 32 ++-- arch/powerpc/cpu/mpc85xx/fdt.c | 12 +- arch/powerpc/cpu/mpc85xx/speed.c | 142 ++++++++--------- arch/powerpc/cpu/mpc85xx/t4240_serdes.c | 14 +- arch/powerpc/cpu/mpc85xx/tlb.c | 3 +- arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 5 + arch/powerpc/cpu/mpc86xx/cpu.c | 22 +-- arch/powerpc/cpu/mpc86xx/speed.c | 40 ++--- arch/powerpc/cpu/mpc8xx/cpu.c | 24 ++- arch/powerpc/cpu/mpc8xx/video.c | 4 +- .../cpu/mpc8xxx/ddr/lc_common_dimm_params.c | 4 + arch/powerpc/cpu/mpc8xxx/ddr/main.c | 3 +- arch/powerpc/cpu/mpc8xxx/law.c | 6 +- arch/powerpc/cpu/ppc4xx/cpu.c | 8 +- arch/powerpc/include/asm/config_mpc85xx.h | 1 + board/freescale/b4860qds/b4860qds_crossbar_con.h | 12 +- board/freescale/common/Makefile | 2 - board/freescale/common/vsc3316_3308.c | 2 +- board/freescale/common/vsc3316_3308.h | 2 +- board/freescale/mpc8540ads/mpc8540ads.c | 2 +- board/freescale/mpc8541cds/mpc8541cds.c | 2 +- board/freescale/mpc8555cds/mpc8555cds.c | 2 +- board/freescale/mpc8560ads/mpc8560ads.c | 2 +- board/freescale/p1010rdb/spl_minimal.c | 2 +- board/freescale/p1022ds/Makefile | 3 + board/freescale/p1022ds/spl.c | 121 ++++++++++++++ board/freescale/p1022ds/spl_minimal.c | 53 +------ board/freescale/p1022ds/tlb.c | 23 ++- board/freescale/p1_p2_rdb_pc/ddr.c | 2 +- board/freescale/p1_twr/ddr.c | 2 +- board/freescale/t4qds/eth.c | 80 +++++++--- board/freescale/t4qds/t4240qds.c | 47 +++++- board/sbc8548/sbc8548.c | 4 +- board/socrates/socrates.c | 2 +- board/xes/xpedite537x/ddr.c | 2 +- common/env_common.c | 2 - config.mk | 30 +++- doc/README.TPL | 45 ++++++ doc/README.mpc85xx-sd-spi-boot | 81 ++++++++++ drivers/mmc/Makefile | 3 + drivers/mmc/fsl_esdhc_spl.c | 115 ++++++++++++++ drivers/mmc/mmc.c | 2 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/fsl_elbc_spl.c | 27 +++- drivers/mtd/spi/Makefile | 1 + drivers/mtd/spi/fsl_espi_spl.c | 62 ++++++++ drivers/mtd/spi/spi_flash.c | 2 + drivers/net/fm/eth.c | 4 +- drivers/net/fm/memac.c | 1 + drivers/net/fm/t4240.c | 40 ++++- drivers/spi/fsl_espi.c | 2 +- include/configs/MPC8313ERDB.h | 1 - include/configs/P1022DS.h | 166 ++++++++++++++++---- include/configs/p1_p2_rdb_pc.h | 1 - include/e500.h | 16 +- include/fsl_esdhc.h | 1 + include/mpc86xx.h | 6 +- spl/Makefile | 23 ++- 63 files changed, 1101 insertions(+), 349 deletions(-) create mode 100644 board/freescale/p1022ds/spl.c create mode 100644 doc/README.TPL create mode 100644 doc/README.mpc85xx-sd-spi-boot create mode 100644 drivers/mmc/fsl_esdhc_spl.c create mode 100644 drivers/mtd/spi/fsl_espi_spl.c
Thanks.
York
On Wed, Aug 21, 2013 at 10:28:29AM -0700, York Sun wrote:
Tom,
?????????????? ?????????????? (1): Fix for incorrect conversion hex string to number (FMAN firmware address).
Applied to u-boot/master (and also confirmed the bugfix), thanks!
York Sun
