[PATCH] board: siemens: iot2050: Fix M.2 detection
The "simpler" the logic, the higher the probability to not test and get things wrong, again: The absence of a "-PG2" suffix is not sufficient to derive that we are on PG1. There is also "IOT2050-ADVANCED-M2".
Finally fix that by exactly matching against the two PG1 device names.
While changing this, we can also drop the not really needed check for !board_is_sr1 in board_is_m2 and call the boards by their names ("board_is_pg1").
Reported-and-tested-by: Bao Cheng Su baocheng.su@siemens.com Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- board/siemens/iot2050/board.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/board/siemens/iot2050/board.c b/board/siemens/iot2050/board.c index e35e55fb5de..0b0686e2628 100644 --- a/board/siemens/iot2050/board.c +++ b/board/siemens/iot2050/board.c @@ -155,19 +155,20 @@ static bool board_is_advanced(void) strstr((char *)info->name, "IOT2050-ADVANCED") != NULL; }
-static bool board_is_sr1(void) +static bool board_is_pg1(void) { struct iot2050_info *info = IOT2050_INFO_DATA;
return info->magic == IOT2050_INFO_MAGIC && - strstr((char *)info->name, "-PG2") == NULL; + (strcmp((char *)info->name, "IOT2050-BASIC") == 0 || + strcmp((char *)info->name, "IOT2050-ADVANCED") == 0); }
static bool board_is_m2(void) { struct iot2050_info *info = IOT2050_INFO_DATA;
- return !board_is_sr1() && info->magic == IOT2050_INFO_MAGIC && + return info->magic == IOT2050_INFO_MAGIC && strcmp((char *)info->name, "IOT2050-ADVANCED-M2") == 0; }
@@ -217,14 +218,14 @@ void set_board_info_env(void) }
if (board_is_advanced()) { - if (board_is_sr1()) + if (board_is_pg1()) fdtfile = "ti/k3-am6548-iot2050-advanced.dtb"; else if(board_is_m2()) fdtfile = "ti/k3-am6548-iot2050-advanced-m2.dtb"; else fdtfile = "ti/k3-am6548-iot2050-advanced-pg2.dtb"; } else { - if (board_is_sr1()) + if (board_is_pg1()) fdtfile = "ti/k3-am6528-iot2050-basic.dtb"; else fdtfile = "ti/k3-am6528-iot2050-basic-pg2.dtb";
Jan Kiszka
