[PATCH v4 0/2] allow opting out of WATCHDOG_RESET() from timer interrupt
This is a resend of v3 from a year ago. Please consider applying.
v4: rebase to current master.
v3: add fixup patch for mpc83xx_timer, add documentation hunk to README, also update m68k instead of only ppc.
v2: add documentation comment
Rasmus Villemoes (2): timer: mpc83xx_timer: fix build with CONFIG_{HW_,}WATCHDOG allow opting out of WATCHDOG_RESET() from timer interrupt
README | 9 +++++++++ arch/m68k/lib/time.c | 2 +- arch/powerpc/lib/interrupts.c | 2 +- drivers/timer/mpc83xx_timer.c | 6 +++++- 4 files changed, 16 insertions(+), 3 deletions(-)
The code, which is likely copied from arch/powerpc/lib/interrupts.c, lacks a fallback definition of CONFIG_SYS_WATCHDOG_FREQ and refers to a non-existing timestamp variable - obviously priv->timestamp is meant.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/timer/mpc83xx_timer.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/timer/mpc83xx_timer.c b/drivers/timer/mpc83xx_timer.c index f4f6e90387..9adb4b4cab 100644 --- a/drivers/timer/mpc83xx_timer.c +++ b/drivers/timer/mpc83xx_timer.c @@ -20,6 +20,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifndef CONFIG_SYS_WATCHDOG_FREQ +#define CONFIG_SYS_WATCHDOG_FREQ (CONFIG_SYS_HZ / 2) +#endif + /** * struct mpc83xx_timer_priv - Private data structure for MPC83xx timer driver * @decrementer_count: Value to which the decrementer register should be re-set @@ -171,7 +175,7 @@ void timer_interrupt(struct pt_regs *regs) priv->timestamp++;
#if defined(CONFIG_WATCHDOG) || defined(CONFIG_HW_WATCHDOG) - if ((timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) + if ((priv->timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) WATCHDOG_RESET(); #endif /* CONFIG_WATCHDOG || CONFIG_HW_WATCHDOG */
Having WATCHDOG_RESET() called automatically from the timer interrupt runs counter to the idea of a watchdog device - if the board runs into an infinite loops with interrupts still enabled, the watchdog will never fire.
When using CONFIG_(SPL_)WDT, the watchdog_reset function is a lot more complicated than just poking a few SOC-specific registers - it involves accessing all kinds of global data, and if the interrupt happens at the wrong time (say, in the middle of an WATCHDOG_RESET() call from ordinary code), that can end up corrupting said global data.
Allow the board to opt out of calling WATCHDOG_RESET() from the timer interrupt handler by setting CONFIG_SYS_WATCHDOG_FREQ to 0 - as that setting is currently nonsensical (it would be compile-time divide-by-zero), it cannot affect any existing boards.
Add documentation for both the existing and extended meaning of CONFIG_SYS_WATCHDOG_FREQ.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- README | 9 +++++++++ arch/m68k/lib/time.c | 2 +- arch/powerpc/lib/interrupts.c | 2 +- drivers/timer/mpc83xx_timer.c | 2 +- 4 files changed, 12 insertions(+), 3 deletions(-)
diff --git a/README b/README index a565748e43..ad13092bbb 100644 --- a/README +++ b/README @@ -747,6 +747,15 @@ The following options need to be configured: SoC, then define this variable and provide board specific code for the "hw_watchdog_reset" function.
+ CONFIG_SYS_WATCHDOG_FREQ + Some platforms automatically call WATCHDOG_RESET() + from the timer interrupt handler every + CONFIG_SYS_WATCHDOG_FREQ interrupts. If not set by the + board configuration file, a default of CONFIG_SYS_HZ/2 + (i.e. 500) is used. Setting CONFIG_SYS_WATCHDOG_FREQ + to 0 disables calling WATCHDOG_RESET() from the timer + interrupt. + - Real-Time Clock:
When CONFIG_CMD_DATE is selected, the type of the RTC diff --git a/arch/m68k/lib/time.c b/arch/m68k/lib/time.c index cbe29e72a8..ebb2ac54db 100644 --- a/arch/m68k/lib/time.c +++ b/arch/m68k/lib/time.c @@ -71,7 +71,7 @@ void dtimer_interrupt(void *not_used) timestamp++;
#if defined(CONFIG_WATCHDOG) || defined (CONFIG_HW_WATCHDOG) - if ((timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) { + if (CONFIG_SYS_WATCHDOG_FREQ && (timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) { WATCHDOG_RESET (); } #endif /* CONFIG_WATCHDOG || CONFIG_HW_WATCHDOG */ diff --git a/arch/powerpc/lib/interrupts.c b/arch/powerpc/lib/interrupts.c index 73f270002c..5ba4cd0c13 100644 --- a/arch/powerpc/lib/interrupts.c +++ b/arch/powerpc/lib/interrupts.c @@ -80,7 +80,7 @@ void timer_interrupt(struct pt_regs *regs) timestamp++;
#if defined(CONFIG_WATCHDOG) || defined (CONFIG_HW_WATCHDOG) - if ((timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) + if (CONFIG_SYS_WATCHDOG_FREQ && (timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) WATCHDOG_RESET (); #endif /* CONFIG_WATCHDOG || CONFIG_HW_WATCHDOG */
diff --git a/drivers/timer/mpc83xx_timer.c b/drivers/timer/mpc83xx_timer.c index 9adb4b4cab..952293195f 100644 --- a/drivers/timer/mpc83xx_timer.c +++ b/drivers/timer/mpc83xx_timer.c @@ -175,7 +175,7 @@ void timer_interrupt(struct pt_regs *regs) priv->timestamp++;
#if defined(CONFIG_WATCHDOG) || defined(CONFIG_HW_WATCHDOG) - if ((priv->timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) + if (CONFIG_SYS_WATCHDOG_FREQ && (priv->timestamp % (CONFIG_SYS_WATCHDOG_FREQ)) == 0) WATCHDOG_RESET(); #endif /* CONFIG_WATCHDOG || CONFIG_HW_WATCHDOG */
ping
ping
As watchdog stuff, Stefan?
ping
Looks good. I've pulled all ready WDT related patches and will send the pull request shortly.
Thanks, Stefan
Rasmus Villemoes
Stefan Roese
